  4. Update js-controller und node.js
    6.8k
update js-controller node.js
93 Beiträge 10 Kommentatoren 71.2k Aufrufe 10 Beobachtet
    @Smartuser
    npm i libvips@8.9.1
    Smartuser
    #61
    @Thomas-Braun sagte in Update js-controller und node.js:
    @Smartuser
    npm i libvips@8.9.1
    rock64@rock64:/opt/iobroker$ npm i libvips@8.9.1
    npm ERR! code ETARGET
    npm ERR! notarget No matching version found for libvips@8.9.1.
    npm ERR! notarget In most cases you or one of your dependencies are requesting
    npm ERR! notarget a package version that doesn't exist.
    npm ERR!     /home/iobroker/.npm/_logs/2020-05-09T20_47_31_974Z-debug.log
    • S Smartuser
      @Smartuser
      npm i libvips@8.9.1
      #62
      @Smartuser Komisch. Die Kiste baut oben, aber mit den falschen sourcen. Keine Ahnung wie man den auf latest oder eine Version >= 8.9.1 bringen kann.
      npm i libvips@latest
      :-D
      • Thomas BraunT Online
        #63
        Seltsamerweise baut das bei mir, denn da liegen auch die richtigen Quelltexte.
        /home/iobroker/.npm/_libvips
        /home/iobroker/.npm/_libvips/libvips-8.9.0-linux-armv7.tar.gz
        /home/iobroker/.npm/_libvips/libvips-8.9.1-linux-armv7.tar.gz
          :-D
          Smartuser
          #64
          :-D
          Ich versteh es gleich gar nicht ;) :D
          rock64@rock64:/opt/iobroker$ npm i libvips@latest
          > sharp@0.25.2 install /opt/iobroker/node_modules/sharp
          > (node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)
          ERR! sharp Use with glibc 2.28 requires manual installation of libvips >= 8.9.1
          info sharp Attempting to build from source via node-gyp but this may fail due to the above error
          info sharp Please see https://sharp.pixelplumbing.com/install for required dependencies
          make: Entering directory '/opt/iobroker/node_modules/sharp/build'
            CC(target) Release/obj.target/nothing/../node-addon-api/src/nothing.o
            AR(target) Release/obj.target/../node-addon-api/src/nothing.a
            COPY Release/nothing.a
            TOUCH Release/obj.target/libvips-cpp.stamp
            CXX(target) Release/obj.target/sharp/src/common.o
          In file included from ../src/common.cc:23:
          /usr/include/vips/vips8:35:10: fatal error: glib-object.h: No such file or directory
           #include <glib-object.h>
          compilation terminated.
          make: *** [sharp.target.mk:139: Release/obj.target/sharp/src/common.o] Error 1
          make: Leaving directory '/opt/iobroker/node_modules/sharp/build'
          gyp ERR! build error
          gyp ERR! stack Error: `make` failed with exit code: 2
          gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
          gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
          gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
          gyp ERR! System Linux 4.4.213-rockchip64
          gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
          gyp ERR! cwd /opt/iobroker/node_modules/sharp
          gyp ERR! node -v v12.16.3
          gyp ERR! node-gyp -v v5.1.0
          gyp ERR! not ok
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.25.2 (node_modules/sharp):
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.25.2 install: `(node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)`
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
          + libvips@0.0.2
          updated 1 package in 49.631s
          22 packages are looking for funding
            run `npm fund` for details
          • S Smartuser
            :-D
            gyp ERR! not ok
            + libvips@0.0.2
            #65
            @Smartuser
            npm i vips
              @Smartuser
              npm i vips
              Smartuser
              #66
              npm i vips
              rock64@rock64:/opt/iobroker$ npm i vips
              gyp ERR! not ok
              + vips@1.0.0
              added 1 package from 1 contributor in 44.674s
              • S Smartuser
                npm i vips
                gyp ERR! not ok
                + vips@1.0.0
                #67
                @Smartuser
                npm i canvas
                  @Smartuser
                  npm i canvas
                  Smartuser
                  #68
                  npm i canvas
                  Es lief eine Weile, am Ende dieses Ergebnis:
                  make: Leaving directory '/opt/iobroker/node_modules/canvas/build'
                  gyp ERR! not ok
                  + canvas@2.6.1
                  updated 1 package in 158.31s
                  • S Smartuser
                    npm i canvas
                    gyp ERR! not ok
                    + canvas@2.6.1
                    #69
                    @Smartuser
                    Sorry, irgendwas übersehe ich. Ich hab nur keinen Schimmer was.
                    Muss sich einer anschauen, der in node tiefer drin ist.
                    Auf meinem Raspberry mit ARMV7l Architektur baut der Kram.
                    Keine Ahnung, ob das mit deiner AARCH64 zusammenhängt.
                      @Smartuser
                      Smartuser
                      #70
                      @Smartuser
                      Auf meinem Raspberry mit ARMV71 Architektur baut der Kram.
                      Ok .... danke für deine Mühe. 👍 👍 👏
                      Eventuell nehm ich mal ein ayufan Image für den Rock64, vielleicht geht es damit
                      • S Smartuser
                        @Smartuser
                        #71
                        @Smartuser
                        Ich installier mir das OS immer selber. Dann weiß ich auch mehr oder weniger was da läuft.
                          @Smartuser
                          AlCalzoneA Offline
                          AlCalzoneA Offline
                          AlCalzone
                          #72
                          @Thomas-Braun @Smartuser
                          libvips ist gar kein npm-Paket. Da könnt ihr lange probieren
                          ==> https://libvips.github.io/libvips/install.html#building-libvips-from-a-source-tarball
                          Danach kann sharp rebuilded werden.
                          • AlCalzoneA AlCalzone
                            #73
                            @AlCalzone Arrrgh! Schwerer Denkfehler von mir! Danke fürs aufwecken!
                            Nur warum liegt das bei mir alles im node?
                            pi@raspberrypi:~ $ locate libvips
                            /opt/iobroker/node_modules/sharp/build/Release/.deps/Release/obj.target/libvips-cpp.stamp.d
                            /opt/iobroker/node_modules/sharp/build/Release/obj.target/libvips-cpp.stamp
                            /opt/iobroker/node_modules/sharp/build/libvips-cpp.target.mk
                            /opt/iobroker/node_modules/sharp/install/libvips.js
                            /opt/iobroker/node_modules/sharp/lib/libvips.js
                            /opt/iobroker/node_modules/sharp/src/libvips
                            /opt/iobroker/node_modules/sharp/src/libvips/cplusplus
                            /opt/iobroker/node_modules/sharp/src/libvips/cplusplus/VConnection.cpp
                            /opt/iobroker/node_modules/sharp/src/libvips/cplusplus/VError.cpp
                            /opt/iobroker/node_modules/sharp/src/libvips/cplusplus/VImage.cpp
                            /opt/iobroker/node_modules/sharp/src/libvips/cplusplus/VInterpolate.cpp
                            /opt/iobroker/node_modules/sharp/src/libvips/cplusplus/vips-operators.cpp
                            /opt/iobroker/node_modules/sharp/vendor/lib/libvips-cpp.so
                            /opt/iobroker/node_modules/sharp/vendor/lib/libvips-cpp.so.42
                            /opt/iobroker/node_modules/sharp/vendor/lib/libvips-cpp.so.42.12.1
                            /opt/iobroker/node_modules/sharp/vendor/lib/libvips.so
                            /opt/iobroker/node_modules/sharp/vendor/lib/libvips.so.42
                            /opt/iobroker/node_modules/sharp/vendor/lib/libvips.so.42.12.1
                            Und sharp ist bei mir drin:
                            pi@raspberrypi:/opt/iobroker $ npm list sharp --depth=2
                            iobroker.inst@2.0.3 /opt/iobroker
                            └─┬ iobroker.iot@1.4.14
                              └── sharp@0.25.2
                            S AlCalzoneA 2 Antworten Letzte Antwort
                                └── sharp@0.25.2
                              Smartuser
                              #74
                              @Thomas-Braun @AlCalzone
                              Viele Dank euch Beiden. Ich konnte jetzt erfolgreich die aktuelle libvips-version bauen.
                              Jetzt funktioniert alles. :) 👍
                              Ich habe es wie folgt gemacht:
                              cd /tmp
                              wget https://github.com/libvips/libvips/releases/download/v8.9.2/vips-8.9.2.tar.gz
                              tar xf vips-8.9.2.tar.gz
                              cd vips-8.9.2
                              ./configure
                              make
                              sudo make install
                              sudo ldconfig
                              Danach Sharp installiert.
                              cd /opt/iobroker
                              npm i sharp
                              Ohne Errors - Log:
                              rock64@rock64:/opt/iobroker$ npm i sharp
                              info sharp Detected globally-installed libvips v8.9.2
                              info sharp Building from source via node-gyp
                                CXX(target) Release/obj.target/sharp/src/metadata.o
                                CXX(target) Release/obj.target/sharp/src/stats.o
                                CXX(target) Release/obj.target/sharp/src/operations.o
                                CXX(target) Release/obj.target/sharp/src/pipeline.o
                                CXX(target) Release/obj.target/sharp/src/utilities.o
                                CXX(target) Release/obj.target/sharp/src/sharp.o
                                SOLINK_MODULE(target) Release/obj.target/sharp.node
                                COPY Release/sharp.node
                              + sharp@0.25.2
                              added 4 packages from 112 contributors in 137.029s
                              Zur Sicherheit nochmal den "Fixer" ausgeführt. Wahrscheinlich nicht notwendig, aber schadet ja auch nicht :)
                              iobroker stop
                              iobroker fix
                              iobroker start
                              Grüße
                                  └── sharp@0.25.2
                                AlCalzoneA Offline
                                AlCalzoneA Offline
                                AlCalzone
                                #75
                                @Thomas-Braun Zeile 5-22 ist alles das sharp-Modul
                                2-4 bin ich mir nicht sicher, sieht aber nach vorkompilierten binaries aus, die ggf von sharp bei der Installation heruntergeladen werden.
                                • K Offline
                                  klausiob
                                  #76
                                  @Smartuser habe Deine Installation auf meinen Raspi mit rasbian stretch ausgeführt. Hat zwar ganz schön lang gedauert. Besonders die sharp-Installation. Dabei war meine Netzwerkverbindung noch abgebrochen.
                                  iobroker.inst@1.3.1 /opt/iobroker
                                  ├─┬ iobroker.iot@1.4.10
                                  │ └── sharp@0.25.2  deduped
                                  └── sharp@0.25.2
                                  Habe jetzt so 5 Adapter upgedatet und die obigen Fehlermeldungen sind weg. Danke an alle.
                                  VG klausiob
                                  Pi4B, Pi3B+, Master-Slave, EchoPlus, 3xEchoDot, FireTVstick, Xiaomi Sensoren, Fritzbox, DECT200, HS100, ZBT-ExtendedColor (ALDI), Shelly 2.5, 2xZigBee-Router-Plugs, Sileno 500 smart, Somfy switch, IONIQ5, tibber
                                  node.js: 22.21.0 - npm: 10.9.4 - linux: raspbian-trixie - admin 7.7.19 - vis 1.5.6 - js-controller: 7.0.7
                                    adaer
                                    schrieb am zuletzt editiert von adaer
                                    #77
                                    @Smartuser: Auch ich hatte diese lästige Meldungen und habe deine Installation auf meinen Raspi mit rasbian stretch ebenfalls ausgeführt. Alles wieder im Lot.. :)
                                    pi@MyRasPi:/opt/iobroker $ npm list sharp --depth=2
                                    iobroker.inst@1.1.2 /opt/iobroker
                                    ├─┬ iobroker.iot@1.4.14
                                    └── sharp@0.25.2
                                    Nochmals Danke ...
                                    Gruss..
                                    Henry
                                    • W Offline
                                      W Offline
                                      Wing.Stefan
                                      #78
                                      Wie kann ich auf Synology im Docker den JS-Controller updaten?
                                      Die gefundenen Anleitungen waren für Linux Windows usw. Im Syno Docker gibt es kein Sudo und kein SToppen von iobroker weil dann geht nichts mehr.
                                      suche daher schritt für schritt Anleitung
                                      • W Wing.Stefan
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        Glasfaser
                                        #79
                                        @maestro sagte in Update js-controller und node.js:
                                        was meinst du damit !?
                                        pkill io
                                        iobroker update
                                        iobroker upgrade self
                                        iobroker start
                                        W 1 Antwort Letzte Antwort
                                        • GlasfaserG Glasfaser
                                          pkill io
                                          iobroker update
                                          iobroker start
                                          W Offline
                                          W Offline
                                          Wing.Stefan
                                          schrieb am zuletzt editiert von Wing.Stefan
                                          #80
                                          @Glasfaser
                                          die befehle bringen nichst weil das pkill io oder kill io nichts macht, ab befehl 3 sagt er nämlich das noch etwas läuft
