  5. [Vorlage] Generisches Fensteroffenskript + Vis
    5.1k
javascripttemplatemonitoring
768 Beiträge 81 Kommentatoren 289.5k Aufrufe 97 Beobachtet
  • T terne
    @Pittini
    raw datenpunkt Küchenfensterkontakt:
      "from": "system.adapter.hm-rega.0",
      "user": "system.user.admin",
      "ts": 1592727382184,
      "common": {
        "name": "Küchenfensterkontakt:1.STATE",
        "def": "CLOSED",
        "type": "number",
        "role": "value.window",
        "min": 0,
        "max": 1,
        "read": true,
        "write": false,
        "states": {
          "0": "CLOSED",
          "1": "OPEN"
      "native": {
        "MIN": "CLOSED",
        "UNIT": "",
        "MAX": "OPEN",
        "ID": "STATE",
        "TYPE": "ENUM",
        "DEFAULT": "CLOSED",
        "CONTROL": "DOOR_SENSOR.STATE",
        "OPERATIONS": 5,
        "FLAGS": 1,
        "TAB_ORDER": 0,
        "VALUE_LIST": [
          "CLOSED",
          "OPEN"
      "acl": {
        "object": 1636,
        "owner": "system.user.admin",
        "state": 1636
      "_id": "hm-rpc.1.00109709AAA7C6.1.STATE",
      "type": "state"
    und der screenshot:
    terne
    #241
    @Pittini
    und der Terrassensensor:
      "type": "state",
      "common": {
        "name": "Terrassentürkontakt:1.STATE",
        "def": "CLOSED",
        "type": "number",
        "read": true,
        "write": false,
        "min": 0,
        "max": 1,
        "states": {
          "0": "CLOSED",
          "1": "OPEN"
      "native": {
        "MIN": "CLOSED",
        "UNIT": "\"\"",
        "OPERATIONS": 5,
        "MAX": "OPEN",
        "FLAGS": 1,
        "ID": "STATE",
        "TAB_ORDER": 0,
        "TYPE": "ENUM",
        "VALUE_LIST": [
          "CLOSED",
          "OPEN"
      "ts": 1592727381745,
      "_id": "hm-rpc.1.001098A993A02E.1.STATE",
      "acl": {
        "object": 1636,
        "state": 1636,
    und die Screenshot dazu:
    Grüße
    Raspimatic und ioBroker auf ProxMox-Server
    ioBroker JS-Controler 3.3.18 redis/redis
    P 1 Antwort Letzte Antwort
    • T terne
      @Pittini
        "type": "state",
        "common": {
          "def": "CLOSED",
          "type": "number",
          "read": true,
          "write": false,
          "min": 0,
          "max": 1,
          "states": {
            "0": "CLOSED",
            "1": "OPEN"
        "native": {
          "MIN": "CLOSED",
          "UNIT": "\"\"",
          "OPERATIONS": 5,
          "MAX": "OPEN",
          "FLAGS": 1,
          "ID": "STATE",
          "TAB_ORDER": 0,
          "TYPE": "ENUM",
          "VALUE_LIST": [
            "CLOSED",
            "OPEN"
        "acl": {
          "object": 1636,
          "state": 1636,
      Grüße
      Pittini
      #242
      @terne Ok, danke. Da brauch ich bitte noch ein komplettes startlog und das Log beim öffnen des Küchenfensters.
      • P Pittini
        terne
        #243
        @Pittini
        jawohl :-)
        javascript.0	2020-06-30 20:23:29.351	info	(1182) script.js.common.Fensterscript: Reaching CreateRoomsWithVentWarnings
        javascript.0	2020-06-30 20:23:29.351	info	(1182) script.js.common.Fensterscript: RoomsWithOpenings: Küche 1 gekipptes Fenster<br>
        javascript.0	2020-06-30 20:23:29.351	info	(1182) script.js.common.Fensterscript: CreateOpenRoomsList()
        javascript.0	2020-06-30 20:23:29.351	info	(1182) script.js.common.Fensterscript: RoomsWithTiltedWindows: Küche 1 gekipptes Fenster
        javascript.0	2020-06-30 20:23:29.351	info	(1182) script.js.common.Fensterscript: Reaching CreateRoomsWithTiltedWindowsList
        javascript.0	2020-06-30 20:23:29.351	info	(1182) script.js.common.Fensterscript: RoomsWithOpenWindows: Küche 1 gekipptes Fenster
        javascript.0	2020-06-30 20:23:29.351	info	(1182) script.js.common.Fensterscript: Reaching CreateRoomsWithOpenWindowsList
        javascript.0	2020-06-30 20:23:29.350	info	(1182) script.js.common.Fensterscript: RoomsWithOpenDoors: Keine Tür/en geöffnet
        javascript.0	2020-06-30 20:23:29.350	info	(1182) script.js.common.Fensterscript: Reaching CreateRoomsWithOpenDoorsList
        javascript.0	2020-06-30 20:23:29.350	info	(1182) script.js.common.Fensterscript: Reaching CreateRoomsWithVentWarnings
        javascript.0	2020-06-30 20:23:29.350	info	(1182) script.js.common.Fensterscript: Room 4 = Terrassentür is open or disabled, no vent warning set
        javascript.0	2020-06-30 20:23:29.350	info	(1182) script.js.common.Fensterscript: Reaching VentCheck x=4 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1593525272635
        javascript.0	2020-06-30 20:23:29.349	info	(1182) script.js.common.Fensterscript: Room 3 = Küche is open or disabled, no vent warning set
        javascript.0	2020-06-30 20:23:29.349	info	(1182) script.js.common.Fensterscript: Reaching VentCheck x=3 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1593525862375
        javascript.0	2020-06-30 20:23:29.349	info	(1182) script.js.common.Fensterscript: Reaching CreateRoomsWithVentWarnings
        javascript.0	2020-06-30 20:23:29.349	info	(1182) script.js.common.Fensterscript: Room 2 = Keller2 is open or disabled, no vent warning set
        javascript.0	2020-06-30 20:23:29.349	info	(1182) script.js.common.Fensterscript: Reaching VentCheck x=2 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1593525272635
        javascript.0	2020-06-30 20:23:29.349	info	(1182) script.js.common.Fensterscript: Room 1 = Haustür is open or disabled, no vent warning set
        javascript.0	2020-06-30 20:23:29.349	info	(1182) script.js.common.Fensterscript: Reaching VentCheck x=1 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1593525272635
        javascript.0	2020-06-30 20:23:29.349	info	(1182) script.js.common.Fensterscript: Room 0 = Garagentür is open or disabled, no vent warning set
        javascript.0	2020-06-30 20:23:29.349	info	(1182) script.js.common.Fensterscript: Reaching VentCheck x=0 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1593525272635
        javascript.0	2020-06-30 20:23:29.348	info	(1182) script.js.common.Fensterscript: Offene Türen gesamt= 0
        javascript.0	2020-06-30 20:23:29.348	info	(1182) script.js.common.Fensterscript: Alle Türen geschlossen.
        javascript.0	2020-06-30 20:23:29.348	info	(1182) script.js.common.Fensterscript: Offene Fenster gesamt= 1
        javascript.0	2020-06-30 20:23:29.348	info	(1182) script.js.common.Fensterscript: reaching ClearWarnTime - [x] = 4
        javascript.0	2020-06-30 20:23:29.348	info	(1182) script.js.common.Fensterscript: RoomOpenDoorCount[TempRoomIndex]=0 TempRoom=Terrassentür TempRoomIndex=4
        javascript.0	2020-06-30 20:23:29.348	info	(1182) script.js.common.Fensterscript: reaching CheckWindow, SensorVal[4]=closed SensorOldVal= TempRoom=Terrassentür SensorType[x]=Door TempRoomIndex=4
        javascript.0	2020-06-30 20:23:29.348	info	(1182) script.js.common.Fensterscript: Reaching GetRoom x=4
        javascript.0	2020-06-30 20:23:29.347	info	(1182) script.js.common.Fensterscript: Reaching CheckForHmShit val=0 typof val=string x=4 Sensor[x]=hm-rpc.1.001098A993A02E.1.STATE
        javascript.0	2020-06-30 20:23:29.347	info	(1182) script.js.common.Fensterscript: Offene Türen gesamt= 0
        javascript.0	2020-06-30 20:23:29.347	info	(1182) script.js.common.Fensterscript: Alle Türen geschlossen.
        javascript.0	2020-06-30 20:23:29.347	info	(1182) script.js.common.Fensterscript: Offene Fenster gesamt= 1
        javascript.0	2020-06-30 20:23:29.347	info	(1182) script.js.common.Fensterscript: reaching ClearWarnTime - [x] = 0
        javascript.0	2020-06-30 20:23:29.347	info	(1182) script.js.common.Fensterscript: RoomOpenDoorCount[TempRoomIndex]=0 TempRoom=Garagentür TempRoomIndex=0
        javascript.0	2020-06-30 20:23:29.347	info	(1182) script.js.common.Fensterscript: reaching CheckWindow, SensorVal[3]=closed SensorOldVal= TempRoom=Garagentür SensorType[x]=Door TempRoomIndex=0
        javascript.0	2020-06-30 20:23:29.347	info	(1182) script.js.common.Fensterscript: Reaching GetRoom x=3
        javascript.0	2020-06-30 20:23:29.347	info	(1182) script.js.common.Fensterscript: Reaching CheckForHmShit val=0 typof val=string x=3 Sensor[x]=hm-rpc.1.00109A498AE939.1.STATE
        javascript.0	2020-06-30 20:23:29.346	info	(1182) script.js.common.Fensterscript: Offene Türen gesamt= 0
        javascript.0	2020-06-30 20:23:29.346	info	(1182) script.js.common.Fensterscript: Alle Türen geschlossen.
        javascript.0	2020-06-30 20:23:29.346	info	(1182) script.js.common.Fensterscript: Offene Fenster gesamt= 1
        javascript.0	2020-06-30 20:23:29.346	info	(1182) script.js.common.Fensterscript: reaching ClearWarnTime - [x] = 1
        javascript.0	2020-06-30 20:23:29.346	info	(1182) script.js.common.Fensterscript: RoomOpenDoorCount[TempRoomIndex]=0 TempRoom=Haustür TempRoomIndex=1
        javascript.0	2020-06-30 20:23:29.346	info	(1182) script.js.common.Fensterscript: reaching CheckWindow, SensorVal[2]=closed SensorOldVal= TempRoom=Haustür SensorType[x]=Door TempRoomIndex=1
        javascript.0	2020-06-30 20:23:29.346	info	(1182) script.js.common.Fensterscript: Reaching GetRoom x=2
        javascript.0	2020-06-30 20:23:29.346	info	(1182) script.js.common.Fensterscript: Reaching CheckForHmShit val=0 typof val=string x=2 Sensor[x]=hm-rpc.1.00109709ADC2FC.1.STATE
        javascript.0	2020-06-30 20:23:29.345	info	(1182) script.js.common.Fensterscript: Offene Türen gesamt= 0
        javascript.0	2020-06-30 20:23:29.345	info	(1182) script.js.common.Fensterscript: Alle Türen geschlossen.
        javascript.0	2020-06-30 20:23:29.345	info	(1182) script.js.common.Fensterscript: Offene Fenster gesamt= 1
        javascript.0	2020-06-30 20:23:29.344	info	(1182) script.js.common.Fensterscript: reaching ClearWarnTime - [x] = 2
        javascript.0	2020-06-30 20:23:29.344	info	(1182) script.js.common.Fensterscript: reaching CheckWindow, SensorVal[1]=closed SensorOldVal= TempRoom=Keller2 SensorType[x]=Window TempRoomIndex=2
        javascript.0	2020-06-30 20:23:29.344	info	(1182) script.js.common.Fensterscript: Reaching GetRoom x=1
        javascript.0	2020-06-30 20:23:29.344	info	(1182) script.js.common.Fensterscript: hm-rpc.0.NEQ1476360.1.STATE hat Zustandstext CLOSED, Wert= 0 Wert wird durch Zustandstext ersetzt
        javascript.0	2020-06-30 20:23:29.343	info	(1182) script.js.common.Fensterscript: Reaching CheckForHmShit val=0 typof val=string x=1 Sensor[x]=hm-rpc.0.NEQ1476360.1.STATE
        javascript.0	2020-06-30 20:23:29.343	info	(1182) script.js.common.Fensterscript: Offene Türen gesamt= 0
        javascript.0	2020-06-30 20:23:29.343	info	(1182) script.js.common.Fensterscript: Alle Türen geschlossen.
        javascript.0	2020-06-30 20:23:29.343	info	(1182) script.js.common.Fensterscript: Offene Fenster gesamt= 1
        javascript.0	2020-06-30 20:23:29.343	info	(1182) script.js.common.Fensterscript: TiltedWindowCount=1 RoomTiltedWindowCount=1 TempRoomIndex=3
        javascript.0	2020-06-30 20:23:29.343	info	(1182) script.js.common.Fensterscript: Reaching tilted+ in checkWindow
        javascript.0	2020-06-30 20:23:29.343	info	(1182) script.js.common.Fensterscript: Setting Interval to Room:Küche
        javascript.0	2020-06-30 20:23:29.342	info	(1182) script.js.common.Fensterscript: SendWindowWarnMsg=true TempRoomIndex=3
        javascript.0	2020-06-30 20:23:29.342	info	(1182) script.js.common.Fensterscript: RoomOpenWindowCount für Küche=1
        javascript.0	2020-06-30 20:23:29.342	info	(1182) script.js.common.Fensterscript: reaching CheckWindow, SensorVal[0]=tilted SensorOldVal= TempRoom=Küche SensorType[x]=Window TempRoomIndex=3
        javascript.0	2020-06-30 20:23:29.342	info	(1182) script.js.common.Fensterscript: Reaching GetRoom x=0
        javascript.0	2020-06-30 20:23:29.342	info	(1182) script.js.common.Fensterscript: Reaching CheckForHmShit val=1 typof val=string x=0 Sensor[x]=hm-rpc.1.00109709AAA7C6.1.STATE
        javascript.0	2020-06-30 20:23:29.341	info	(1182) script.js.common.Fensterscript: x=4=Terrassentür SendWindowWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
        javascript.0	2020-06-30 20:23:29.341	info	(1182) script.js.common.Fensterscript: x=3=Küche SendWindowWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
        javascript.0	2020-06-30 20:23:29.341	info	(1182) script.js.common.Fensterscript: x=2=Keller2 SendWindowWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
        javascript.0	2020-06-30 20:23:29.341	info	(1182) script.js.common.Fensterscript: x=1=Haustür SendWindowWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
        javascript.0	2020-06-30 20:23:29.341	info	(1182) script.js.common.Fensterscript: x=0=Garagentür SendWindowWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
        javascript.0	2020-06-30 20:23:29.341	info	(1182) script.js.common.Fensterscript: CreateStates fertig!
        javascript.0	2020-06-30 20:23:29.339	info	(1182) script.js.common.Fensterscript: registered 0 subscriptions and 0 schedules
        javascript.0	2020-06-30 20:23:29.336	info	(1182) script.js.common.Fensterscript: Raum- 4 = Terrassentür hat Türsensor/en
        javascript.0	2020-06-30 20:23:29.336	info	(1182) script.js.common.Fensterscript: Raum- 3 = Garagentür hat Türsensor/en
        javascript.0	2020-06-30 20:23:29.336	info	(1182) script.js.common.Fensterscript: Raum- 2 = Haustür hat Türsensor/en
        javascript.0	2020-06-30 20:23:29.335	info	(1182) script.js.common.Fensterscript: Raum- 1 = Keller2 hat Fenstersensor/en
        javascript.0	2020-06-30 20:23:29.335	info	(1182) script.js.common.Fensterscript: Raum- 0 = Küche hat Fenstersensor/en
        javascript.0	2020-06-30 20:23:29.335	info	(1182) script.js.common.Fensterscript: starting Fensterskript, Version 1.6.3
        javascript.0	2020-06-30 20:23:29.331	info	(1182) Start javascript script.js.common.Fensterscript
        javascript.0	2020-06-30 20:23:25.499	info	(1182) script.js.common.Fensterscript: reaching ClearWarnTime - [x] = 4
        javascript.0	2020-06-30 20:23:25.499	info	(1182) script.js.common.Fensterscript: Clearing Interval for 3
        javascript.0	2020-06-30 20:23:25.498	info	(1182) script.js.common.Fensterscript: reaching ClearWarnTime - [x] = 3
        javascript.0	2020-06-30 20:23:25.498	info	(1182) script.js.common.Fensterscript: reaching ClearWarnTime - [x] = 2
        javascript.0	2020-06-30 20:23:25.498	info	(1182) script.js.common.Fensterscript: reaching ClearWarnTime - [x] = 1
        javascript.0	2020-06-30 20:23:25.498	info	(1182) script.js.common.Fensterscript: reaching ClearWarnTime - [x] = 0
        javascript.0	2020-06-30 20:23:25.497	info	(1182) Stop script script.js.common.Fensterscript
        und das Öffnen des Fensters:
        javascript.0	2020-06-30 20:27:15.098	info	(1182) script.js.common.Fensterscript: RoomsWithOpenings: Küche 1 gekipptes Fenster<br>
        javascript.0	2020-06-30 20:27:15.098	info	(1182) script.js.common.Fensterscript: CreateOpenRoomsList()
        javascript.0	2020-06-30 20:27:15.098	info	(1182) script.js.common.Fensterscript: RoomsWithOpenDoors: Keine Tür/en geöffnet
        javascript.0	2020-06-30 20:27:15.097	info	(1182) script.js.common.Fensterscript: Reaching CreateRoomsWithOpenDoorsList
        javascript.0	2020-06-30 20:27:15.097	info	(1182) script.js.common.Fensterscript: RoomsWithTiltedWindows: Küche 1 gekipptes Fenster
        javascript.0	2020-06-30 20:27:15.097	info	(1182) script.js.common.Fensterscript: Reaching CreateRoomsWithTiltedWindowsList
        javascript.0	2020-06-30 20:27:15.097	info	(1182) script.js.common.Fensterscript: RoomsWithOpenWindows: Küche 1 gekipptes Fenster
        javascript.0	2020-06-30 20:27:15.097	info	(1182) script.js.common.Fensterscript: Reaching CreateRoomsWithOpenWindowsList
        javascript.0	2020-06-30 20:27:15.097	info	(1182) script.js.common.Fensterscript: RoomStateTimeStamp at checkWindow= 1593541635095 ms =30.06.2020 20:27:15
        javascript.0	2020-06-30 20:27:15.097	info	(1182) script.js.common.Fensterscript: Reaching CreateRoomsWithVentWarnings
        javascript.0	2020-06-30 20:27:15.097	info	(1182) script.js.common.Fensterscript: Room 3 = Küche is open or disabled, no vent warning set
        javascript.0	2020-06-30 20:27:15.097	info	(1182) script.js.common.Fensterscript: Reaching VentCheck x=3 Init=false VentwarnTime[x]=0 RoomStateTimeStamp[x]=1593541635095
        javascript.0	2020-06-30 20:27:15.097	info	(1182) script.js.common.Fensterscript: Offene Türen gesamt= 0
        javascript.0	2020-06-30 20:27:15.096	info	(1182) script.js.common.Fensterscript: Alle Türen geschlossen.
        javascript.0	2020-06-30 20:27:15.096	info	(1182) script.js.common.Fensterscript: Offene Fenster gesamt= 1
        javascript.0	2020-06-30 20:27:15.096	info	(1182) script.js.common.Fensterscript: TiltedWindowCount=1 RoomTiltedWindowCount=1 TempRoomIndex=3
        javascript.0	2020-06-30 20:27:15.096	info	(1182) script.js.common.Fensterscript: Reaching tilted+ in checkWindow
        javascript.0	2020-06-30 20:27:15.096	info	(1182) script.js.common.Fensterscript: Setting Interval to Room:Küche
        javascript.0	2020-06-30 20:27:15.095	info	(1182) script.js.common.Fensterscript: SendWindowWarnMsg=true TempRoomIndex=3
        javascript.0	2020-06-30 20:27:15.095	info	(1182) script.js.common.Fensterscript: TempMessageLog=30.06.2020 20:27:15: Küche Fenster gekippt!,30.06.2020 20:25:46: Küche Fenster geschlossen!,30.06.2020 20:22:05: Terrassentür Tür geschlossen!,30
        javascript.0	2020-06-30 20:27:15.095	info	(1182) script.js.common.Fensterscript: Reaching WriteMessageLog, Message=Küche Fenster gekippt!
        javascript.0	2020-06-30 20:27:15.095	info	(1182) script.js.common.Fensterscript: Reaching Meldung, msg= Küche Fenster gekippt!
        javascript.0	2020-06-30 20:27:15.095	info	(1182) script.js.common.Fensterscript: Küche Fenster gekippt
        javascript.0	2020-06-30 20:27:15.095	info	(1182) script.js.common.Fensterscript: RoomOpenWindowCount für Küche=1
        javascript.0	2020-06-30 20:27:15.094	info	(1182) script.js.common.Fensterscript: reaching CheckWindow, SensorVal[0]=tilted SensorOldVal=closed TempRoom=Küche SensorType[x]=Window TempRoomIndex=3
        javascript.0	2020-06-30 20:27:15.094	info	(1182) script.js.common.Fensterscript: Reaching GetRoom x=0
        javascript.0	2020-06-30 20:27:15.094	info	(1182) script.js.common.Fensterscript: Reaching CheckForHmShit val=1 typof val=string x=0 Sensor[x]=hm-rpc.1.00109709AAA7C6.1.STATE
        javascript.0	2020-06-30 20:27:15.094	info	(1182) script.js.common.Fensterscript: Ignore Timeout for 0 exceeded, Value change happend, starting Functions
        javascript.0	2020-06-30 20:27:15.094	info	(1182) script.js.common.Fensterscript: InTimeout - Trigger= 0 Wert= 1 Alter Wert= 0
        javascript.0	2020-06-30 20:27:05.092	info	(1182) script.js.common.Fensterscript: Activating Ignore Timeout for 0, Value to ignore=closed
        javascript.0	2020-06-30 20:27:05.092	info	(1182) script.js.common.Fensterscript: Reaching CheckForHmShit val=0 typof val=string x=0 Sensor[x]=hm-rpc.1.00109709AAA7C6.1.STATE
        javascript.0	2020-06-30 20:27:05.092	info	(1182) script.js.common.Fensterscript: Oldstate=0
        javascript.0	2020-06-30 20:27:05.092	info	(1182) script.js.common.Fensterscript: Trigger= 0 Wert= 1 Alter Wert= 0
        • T terne
          @Pittini
          jawohl :-)
          Pittini
          #244
          @terne Mal bitte folgendes testen:
          Zeile 1062 lautet aktuell:
              if (Sensor[x].indexOf("hm-rpc.0") != -1) { //Prüfen ob Sensor= HM Sensor
          Lösch mal bitte die 0 und gugg obs dann geht.
          • P Pittini
            Generisches Skript um offene Fenster pro Raum und insgesamt zu zählen sowie offen/zu States anzulegen.
            • Kann beliebige Tür/Fenster Kontakte verwenden.
            • Berücksichtigt mehrflügelige Fenster bzw. mehrere Fenster pro Raum und zählt diese.
            • Legt pro Raum zwei Datenpunkte an (Raumfensteroffenzähler und Raumfensterstatus), sowie vier Datenpunkte fürs gesamte.
            • Möglichkeit eine Meldung/Ansage via Telegram/Alexa nach x Minuten einmalig oder zyklisch bis Fensterschließung auszugeben.
            • Gibt dynamische HTML Tabelle mit Übersicht aller Räume aus.
            • Flexibel konfigurierbar, direkt integriert sind HM, HMIP und Xiaomi Tür-/Fensterkontakte bzw. Drehgriffe
            Genaueres in der readme beim Projekt auf Git.
            sigi234S Online
            sigi234S Online
            sigi234
            #245
            @Pittini
            Hallo, versteh das nicht warum es in Tagen ist?
            Anzahl der Tage nach der eine Lüftungsempfehlung ausgegeben wird
            Immer Daten sichern!
            • sigi234S sigi234
              @Pittini
              Pittini
              #246
              @sigi234 sagte in [Vorlage] Generisches Fensteroffenskript + Vis:
              Weil die meisten halt täglich lüften und ich es deswegen so festgelegt hab. Könnten genausogut Millsekunden sein. Und wenn Du 2mal täglich lüften willst kannste ja 0.5 eingeben.
              • P Pittini
                sigi234S Online
                sigi234S Online
                sigi234
                #247
                @Pittini sagte in [Vorlage] Generisches Fensteroffenskript + Vis:
                Danke, das war der entscheidende Hinweis. 😀
                • P Pittini
                  terne
                  #248
                  @Pittini
                  mal wieder perfekt :)
                  Funktioniert - vielen Dank
                  • Christoph1337C Offline
                    Christoph1337
                    #249
                    @Pittini
                    Ich hätte zwei Fragen zu der aktuellen Version.
                    1. NoMsgAtPresence
                      Ich habe oben einen DP (ist true) dafür angefügt und NoMsgAtPresence = true gesetzt.
                      trotzdem bekomme ich eine Ausgabe über Alexa und Telegram.
                    Macht ich etwas falsch?
                    Neuerdings werden auch Türen erfasst.
                    Kannst du die die Darstellung dafür vielleicht wie folgt anpassen:
                    Wenn ein Raum nur Fenster oder Tür -> eine Spalte.
                    Wenn Raum Fenster und Tür -> zwei Spalten.
                    Das wäre in der Darstellung deutlich schöner, da man in der Regel ja nur an wenigen Türen solche Türsensoren hat.
                    • Christoph1337C Christoph1337
                      @Pittini
                      1. NoMsgAtPresence
                      Pittini
                      #250
                      @Christoph1337 sagte in [Vorlage] Generisches Fensteroffenskript + Vis:
                      NoMsgAtPresence
                      Nein, Bug, is im nächsten update gefixt.
                      Gute Idee, bau ich grad ein.
                        Bibo*13
                        #251
                        erstmal herzlichen Dank für das schöne Skript.
                        Ich habe eine Frage, wäre es möglich auch eine Nachricht auszugeben wenn eine Tür länger aufsteht.
                        Also Ansage wie bei einem Fenster "Tür seit nMinuten ist offen"
                        vielen Dank
                        • B Bibo*13
                          vielen Dank
                          Pittini
                          #252
                          @Bibo-13 sagte in [Vorlage] Generisches Fensteroffenskript + Vis:
                          Aktuell nicht, aber ich schau mal wie groß der Aufwand wäre, evtl. bau ichs Dir rein.
                            Bibo*13
                            #253
                            Ok. Danke. Wäre schön wenns ginge.
                            • B Bibo*13
                              Pittini
                              #254
                              Is drin. V1.6.5
                              crunchipC B 2 Antworten Letzte Antwort
                              • P Pittini
                                Is drin. V1.6.5
                                crunchipC Abwesend
                                crunchipC Abwesend
                                #255
                                @Pittini habs nu mal aktualisiert,von V 1.6.3 auf V 1.6.5 ab Zeile 30 Tabelleneinstellungen, muss noch etwas beachtet werden?Bekomme nun aber nach Scriptstart folgendes
                                  Pittini
                                  #256
                                  @crunchip sagte in [Vorlage] Generisches Fensteroffenskript + Vis:
                                  habs nu mal aktualisiert, ab Zeile 30 Tabelleneinstellungen, muss noch etwas beachtet werden?Bekomme nun aber nach Scriptstart folgendes
                                  Ja is klar dass der Fehler kommt, Du mußt schon das ganze Skript aktualisieren, nicht erst ab Zeile 30. Da is ne Variable dazugekommen und eine wurde umbenannt.
                                  • P Pittini
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    #257
                                    @Pittini und die Wäre??
                                    Ich sehe da nix, Zeile 1 hab ich ja geändert auf const Skriptversion = "1.6.5"
                                    Erste Änderung im Script ist bei Zeile 33 const DoorTiltedImg =
                                    Edit, Zeile 19 überlesen🤦
                                    passt wieder👍
                                      rotamint
                                      #258
                                      ich habe eine Frage zu Zeile 48:
                                      const RoomSortMode = 1; //0= Raumliste unsortiert, 1= alpabetisch sortiert, 2= Benutzerdefinierte Sortierung
                                      Wo kann ich das nach "2 / benutzerdefiniert" einrichten? Ich habe nichts gefunden.
                                      Danke. Gruß Stefan.
                                      NegaleinN P 2 Antworten Letzte Antwort
                                      • R rotamint
                                        Danke. Gruß Stefan.
                                        NegaleinN Offline
                                        NegaleinN Offline
                                        Negalein
                                        #259
                                        @Pittini
                                        bei mir muss ich das Script alle 1-2 Tage neu starten, da die Anzahl der offenen Fenster hängenbleibt, bzw. sogar hochgezählt wird bei ein und dem selben Fenster.
                                        Hab noch die 1.5.2, da ich derzeit das mit den Türen nicht benötige.
                                        ° Fixer ---> iob fix
                                        • R rotamint
                                          Danke. Gruß Stefan.
                                          Pittini
                                          #260
                                          @rotamint sagte in [Vorlage] Generisches Fensteroffenskript + Vis:
                                          Anleitung .6.13
                                          R 1 Antwort Letzte Antwort
