  4. Log Warn: (22241) Empty pattern! im Web adapter ???
logweb
7 Beiträge 5 Kommentatoren 1.3k Aufrufe 5 Beobachtet
  • Agria4800A Offline
    Agria4800A Offline
    Agria4800
    Kann mir jemand erklären, weshalb dieser Warn im Log geschrieben wird ?
    web.0	2020-03-24 19:49:47.406	warn	(22241) Empty pattern!
    Log:
    web.0	2020-03-24 19:53:04.656	info	(22241) <==Disconnect system.user.admin from ::ffff:192.168.178.124 vis.0
    web.0	2020-03-24 19:50:07.266	debug	(22241) Subscribes: vis.0.control.instance, vis.0.control.data, vis.0.control.command, system.adapter.coronavirus-statistics.0.connected, coronavirus-statistics.0._Last_Update, coronavirus-statistics.
    web.0	2020-03-24 19:50:07.007	debug	(22241) Subscribes: vis.0.control.instance, vis.0.control.data, vis.0.control.command, system.adapter.coronavirus-statistics.0.connected, coronavirus-statistics.0._Last_Update, coronavirus-statistics.
    web.0	2020-03-24 19:50:06.991	debug	(22241) Subscribes: vis.0.control.instance, vis.0.control.data, vis.0.control.command, system.adapter.coronavirus-statistics.0.connected, coronavirus-statistics.0._Last_Update, coronavirus-statistics.
    web.0	2020-03-24 19:50:06.991	warn	(22241) Empty pattern!
    web.0	2020-03-24 19:50:06.774	debug	(22241) Subscribes: vis.0.control.instance, vis.0.control.data, vis.0.control.command, system.adapter.coronavirus-statistics.0.connected, coronavirus-statistics.0._Last_Update, coronavirus-statistics.
    web.0	2020-03-24 19:50:06.506	debug	(22241) Subscribes: vis.0.control.instance, vis.0.control.data, vis.0.control.command, system.adapter.coronavirus-statistics.0.connected, coronavirus-statistics.0._Last_Update, coronavirus-statistics.
    web.0	2020-03-24 19:50:06.244	debug	(22241) Subscribes: vis.0.control.instance, vis.0.control.data, vis.0.control.command
    web.0	2020-03-24 19:50:03.947	debug	(22241) 2020-03-24T18:50:03.947Z Request authenticate [system.user.admin]
    web.0	2020-03-24 19:50:03.896	debug	(22241) Connection from vis.0
    web.0	2020-03-24 19:50:03.869	info	(22241) ==>Connected system.user.admin from ::ffff:192.168.178.124
    web.0	2020-03-24 19:50:03.241	info	(22241) <==Disconnect system.user.admin from ::ffff:192.168.178.124 vis.0
    web.0	2020-03-24 19:49:47.414	debug	(22241) Subscribes: vis.0.control.instance, vis.0.control.data, vis.0.control.command, system.adapter.coronavirus-statistics.0.connected, coronavirus-statistics.0._Last_Update, coronavirus-statistics.
    web.0	2020-03-24 19:49:47.353	debug	(22241) Subscribes: vis.0.control.instance, vis.0.control.data, vis.0.control.command
    web.0	2020-03-24 19:49:44.956	debug	(22241) 2020-03-24T18:49:44.956Z Request authenticate [system.user.admin]
    web.0	2020-03-24 19:49:44.956	debug	(22241) Connection from vis.0
    web.0	2020-03-24 19:49:44.815	info	(22241) ==>Connected system.user.admin from ::ffff:192.168.178.124
    web.0	2020-03-24 19:45:43.051	info	(22241) <==Disconnect system.user.admin from ::ffff:192.168.178.124 vis.0
    web.0	2020-03-24 19:44:50.763	debug	(22241) system.adapter.admin.0: logging true
    web.0	2020-03-24 18:44:47.159	debug	(22241) Subscribes: vis.0.control.instance, vis.0.control.data, vis.0.control.command, system.adapter.coronavirus-statistics.0.connected, coronavirus-statistics.0._Last_Update, coronavirus-statistics.
    web.0	2020-03-24 18:44:46.901	debug	(22241) Subscribes: vis.0.control.instance, vis.0.control.data, vis.0.control.command, system.adapter.coronavirus-statistics.0.connected, coronavirus-statistics.0._Last_Update, coronavirus-statistics.
    web.0	2020-03-24 18:44:46.885	debug	(22241) Subscribes: vis.0.control.instance, vis.0.control.data, vis.0.control.command, system.adapter.coronavirus-statistics.0.connected, coronavirus-statistics.0._Last_Update, coronavirus-statistics.
    web.0	2020-03-24 18:44:46.885	warn	(22241) Empty pattern!
    web.0	2020-03-24 18:44:46.871	debug	(22241) Subscribes: vis.0.control.instance, vis.0.control.data, vis.0.control.command, system.adapter.coronavirus-statistics.0.connected, coronavirus-statistics.0._Last_Update, coronavirus-statistics.
    web.0	2020-03-24 18:44:46.416	debug	(22241) Subscribes: vis.0.control.instance, vis.0.control.data, vis.0.control.command, system.adapter.coronavirus-statistics.0.connected, coronavirus-statistics.0._Last_Update, coronavirus-statistics.
    web.0	2020-03-24 18:44:46.211	debug	(22241) Subscribes: vis.0.control.instance, vis.0.control.data, vis.0.control.command
    web.0	2020-03-24 18:44:39.158	debug	(22241) 2020-03-24T17:44:39.158Z Request authenticate [system.user.admin]
    web.0	2020-03-24 18:44:39.105	debug	(22241) Connection from vis.0
    web.0	2020-03-24 18:44:39.092	info	(22241) ==>Connected system.user.admin from ::ffff:192.168.178.124
    web.0	2020-03-24 18:44:37.920	info	(22241) <==Disconnect system.user.admin from ::ffff:192.168.178.124 vis.0
    web.0	2020-03-24 18:43:19.309	debug	(22241) Subscribes: vis.0.control.instance, vis.0.control.data, vis.0.control.command, system.adapter.coronavirus-statistics.0.connected, coronavirus-statistics.0._Last_Update, coronavirus-statistics.
    web.0	2020-03-24 18:43:19.286	warn	(22241) Empty pattern!
    web.0	2020-03-24 18:43:18.924	debug	(22241) Subscribes: vis.0.control.instance, vis.0.control.data, vis.0.control.command
    web.0	2020-03-24 18:43:09.528	debug	(22241) 2020-03-24T17:43:09.528Z Request authenticate [system.user.admin]
    web.0	2020-03-24 18:43:09.464	debug	(22241) Connection from vis.0
    web.0	2020-03-24 18:43:09.429	info	(22241) ==>Connected system.user.admin from ::ffff:192.168.178.124
    web.0	2020-03-24 18:43:00.008	info	(22241) <==Disconnect system.user.admin from ::ffff:192.168.178.124 vis.0
    web.0	2020-03-24 18:40:02.055	debug	(22241) Subscribes: vis.0.control.instance, vis.0.control.data, vis.0.control.command, system.adapter.coronavirus-statistics.0.connected, coronavirus-statistics.0._Last_Update, coronavirus-statistics.
    web.0	2020-03-24 18:40:02.038	warn	(22241) Empty pattern!
    web.0	2020-03-24 18:40:01.530	debug	(22241) Subscribes: vis.0.control.instance, vis.0.control.data, vis.0.control.command
    web.0	2020-03-24 18:39:59.145	debug	(22241) 2020-03-24T17:39:59.145Z Request authenticate [system.user.admin]
    web.0	2020-03-24 18:39:59.021	debug	(22241) Connection from vis.0
    web.0	2020-03-24 18:39:59.007	info	(22241) ==>Connected system.user.admin from ::ffff:192.168.178.124
    web.0	2020-03-24 18:28:11.257	info	(22241) <==Disconnect system.user.admin from ::ffff:192.168.178.124 vis.0
    • Agria4800A Agria4800
      Log:
      GlasfaserG Offline
      GlasfaserG Offline
      Glasfaser
      @Agria4800
      Keine Lösung dazu ... aber crunchip hat die gleiche Meldung
      Link Text
      Agria4800A 1 Antwort Letzte Antwort
      • GlasfaserG Glasfaser
        @Agria4800
        Link Text
        Agria4800A Offline
        Agria4800A Offline
        Agria4800
        @Glasfaser: ich hab mal den Web Adapter deinstalliert und frisch aufgespielt, auch verschiedene Downgrade versucht, der Fehler tritt aber weiterhin auf! Mir ist aufgefallen, das diese Meldung kommt, wenn ich die Runtime Vis aufrufe!
        Hat jemand vielleicht noch ne Erklärung dafür?
        • smartboartS Offline
          smartboartS Offline
          smartboart
          habe die meldung auch..
          • crunchipC Abwesend
            crunchipC Abwesend
            das "empty pattern" kommt nicht direkt vom web Adapter, sondern kommt vom socketio
            folglich, hat man socketio im web Adapter "integriert"...kommt die Meldung vom web.0
            hat man auf socketio...also eigenständigen Adapter socketio, kommt die selbe Meldung , jedoch nicht vom web.0, sondern eben vom socketio.0
            warum und weshalb, weiss ich leider bis heute nicht, kam erst mit den zusammenhängenden Update`s zwecks js-controller 3.x
            K 1 Antwort Letzte Antwort
              Kueppert
              @crunchip ich hab diese Meldung auch (wenn ich iQontrol im Browser anzeigen lasse). Hast du inzwischen herausgefunden woran das liegt??
              • K Kueppert
                crunchipC Abwesend
                crunchipC Abwesend
                @kueppert nö, aber kannste ignorieren
