  4. Test Adapter deConz v1.3.x Github/npm
    5.6k
deconzphoscon appconbee
160 Beiträge 33 Kommentatoren 30.9k Aufrufe 31 Beobachtet
    ticaki
    #61
    Issue erstellt.
    Spenden
    • K Kugelkopf
      Inzw. sind es auch wieder 4 gleichzeitige Verbindungen.
      2020-04-20 14:13:23.272  - info: javascript.0 (1468) script.js.Eigene.DimmerSkript: 4002
      2020-04-20 14:13:23.273  - info: javascript.0 (1468) script.js.Eigene.DimmerSkript: setForeignState(id=deconz.0.Lights.1.on, state=false)
      2020-04-20 14:13:23.274  - info: javascript.0 (1468) script.js.Eigene.DimmerSkript: getState(id=deconz.0.Lights.1.bri, timerId=undefined) => {"val":1,"ack":true,"ts":1587384798828,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1587342025743}
      2020-04-20 14:13:23.297  - debug: deconz.0 (28200) stateChange Lights.1 {"val":false,"ack":false,"ts":1587384803263,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1587384803263}
      2020-04-20 14:13:23.299  - debug: deconz.0 (28200) dp: on; id:Lights.1 tmp: deconz,0,Lights,1
      2020-04-20 14:13:23.303  - debug: deconz.0 (28200) stateChange Lights.1 {"val":false,"ack":false,"ts":1587384803263,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1587384803263}
      2020-04-20 14:13:23.304  - debug: deconz.0 (28200) dp: on; id:Lights.1 tmp: deconz,0,Lights,1
      2020-04-20 14:13:23.308  - debug: deconz.0 (28200) stateChange Lights.1 {"val":false,"ack":false,"ts":1587384803264,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1587384803264}
      2020-04-20 14:13:23.310  - debug: deconz.0 (28200) dp: on; id:Lights.1 tmp: deconz,0,Lights,1
      2020-04-20 14:13:23.321  - debug: deconz.0 (28200) stateChange Lights.1 {"val":false,"ack":false,"ts":1587384803306,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1587384803264}
      2020-04-20 14:13:23.322  - debug: deconz.0 (28200) dp: on; id:Lights.1 tmp: deconz,0,Lights,1
      inzw. sind es über 50.
      Jey CeeJ Online
      Jey CeeJ Online
      Jey Cee
      #62
      @Kugelkopf kannst du bitte mal upnp von deConz deaktivieren und beobachten was passiert?
      Hier eine Anleitung für Linux wie man upnp deaktiviert.
      Persönlicher Support
      Spenden -> paypal.me/J3YC33
      K 1 Antwort Letzte Antwort
      • Jey CeeJ Online
        Jey CeeJ Online
        Jey Cee
        #63
        Die 1.3.4 ist verfügbar, damit sollte die Meldung "State value to set is invalid" der Vergangenheit angehören.
        Außerdem werden jetzt ein paar Fehler abgefangen die über Sentry gemeldet wurden.
        Eine Neuerung ist das Werte die nicht dem Typ des Datenpunkts entsprechen, also wenn man statt einer Nummer einen Text eingibt, nicht mehr an deConz gesendet werden. Das es der Falsche Typ ist wird schon von ioBroker im Log gemeldet, es gibt also keine neue Meldung im Log dazu.
        Diese Maßnahme soll nur Verhindern das Unnötige anfragen an deConz geschickt werden.
        • Jey CeeJ Jey Cee
          Kugelkopf
          #64
          @Jey-Cee
          Ok, hab nun geupdated auf den neusten JS-Controller3, Nodejs12 und deconz 1.3.4. Zusätzlich die Upnp Geschichte ausgeschaltet! Werde es weiter beobachten. Besten Dank!
          • 123brokerei1 Offline
            123brokerei
            #65
            @ jey cee
            Seite dem Update heute auf 1.3.4 und dem Update auf den JS controller 3.0.17 schaffe ich es leider nicht mehr mich mit dem Dienst zu verbinden. Die Phosconapp läuft einwandfrei. Anbei ein Auszug des Logs. Kann da jemand helfen?
            deconz.0	2020-04-23 17:54:06.390	info	(13562) Code 403: Forbidden get devices: [{"error":{"address":"/devices","description":"unauthorized user","type":1}}]
            deconz.0	2020-04-23 17:54:06.389	info	(13562) Code 403: Forbidden get all groups: [{"error":{"address":"/groups","description":"unauthorized user","type":1}}]
            deconz.0	2020-04-23 17:54:06.387	info	(13562) Code 403: Forbidden get all sensors: [{"error":{"address":"/sensors","description":"unauthorized user","type":1}}]
            deconz.0	2020-04-23 17:54:06.384	info	(13562) Code 403: Forbidden get all lights: [{"error":{"address":"/lights","description":"unauthorized user","type":1}}]
            deconz.0	2020-04-23 17:54:06.324	info	(13562) deConz Version: 2.5.74; API version: 1.16.0
            deconz.0	2020-04-23 17:54:06.308	info	(13562) Terminated (NO_ERROR): Without reason
            deconz.0	2020-04-23 17:54:06.307	info	(13562) terminating
            deconz.0	2020-04-23 17:54:06.269	info	(13562) cleaned everything up...
            deconz.0	2020-04-23 17:54:06.266	error	at process._tickCallback (internal/process/next_tick.js:68:7)
            deconz.0	2020-04-23 17:54:06.266	error	at getAutoUpdates (/opt/iobroker/node_modules/iobroker.deconz/main.js:678:14)
            deconz.0	2020-04-23 17:54:06.266	error	at new WebSocket (/opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/lib/websocket.js:72:7)
            deconz.0	2020-04-23 17:54:06.266	error	at initAsClient (/opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/lib/websocket.js:478:17)
            deconz.0	2020-04-23 17:54:06.266	error	at new URL (internal/url.js:319:5)
            deconz.0	2020-04-23 17:54:06.266	error	at onParseError (internal/url.js:241:17)
            deconz.0	2020-04-23 17:54:06.266	error	(13562) TypeError [ERR_INVALID_URL]: Invalid URL: ws://192.168.178.62:undefined
            deconz.0	2020-04-23 17:54:06.256	error	(13562) uncaught exception: Invalid URL: ws://192.168.178.62:undefined
            deconz.0	2020-04-23 17:54:06.175	info	(13562) starting. Version 1.3.4 in /opt/iobroker/node_modules/iobroker.deconz, node: v10.20.1, js-controller: 3.0.17
            deconz.0	2020-04-23 17:53:32.591	info	(12993) Code 403: Forbidden get devices: [{"error":{"address":"/devices","description":"unauthorized user","type":1}}]
            deconz.0	2020-04-23 17:53:32.590	info	(12993) Code 403: Forbidden get all groups: [{"error":{"address":"/groups","description":"unauthorized user","type":1}}]
            deconz.0	2020-04-23 17:53:32.588	info	(12993) Code 403: Forbidden get all sensors: [{"error":{"address":"/sensors","description":"unauthorized user","type":1}}]
            deconz.0	2020-04-23 17:53:32.578	info	(12993) Code 403: Forbidden get all lights: [{"error":{"address":"/lights","description":"unauthorized user","type":1}}]
            deconz.0	2020-04-23 17:53:32.516	info	(12993) deConz Version: 2.5.74; API version: 1.16.0
            deconz.0	2020-04-23 17:53:32.505	info	(12993) Terminated (NO_ERROR): Without reason
            deconz.0	2020-04-23 17:53:32.503	info	(12993) terminating
            deconz.0	2020-04-23 17:53:32.466	info	(12993) cleaned everything up...
            deconz.0	2020-04-23 17:53:32.463	error	at process._tickCallback (internal/process/next_tick.js:68:7)
            deconz.0	2020-04-23 17:53:32.463	error	at getAutoUpdates (/opt/iobroker/node_modules/iobroker.deconz/main.js:678:14)
            deconz.0	2020-04-23 17:53:32.463	error	at new WebSocket (/opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/lib/websocket.js:72:7)
            deconz.0	2020-04-23 17:53:32.463	error	at initAsClient (/opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/lib/websocket.js:478:17)
            deconz.0	2020-04-23 17:53:32.463	error	at new URL (internal/url.js:319:5)
            deconz.0	2020-04-23 17:53:32.463	error	at onParseError (internal/url.js:241:17)
            deconz.0	2020-04-23 17:53:32.463	error	(12993) TypeError [ERR_INVALID_URL]: Invalid URL: ws://192.168.178.62:undefined
            deconz.0	2020-04-23 17:53:32.454	error	(12993) uncaught exception: Invalid URL: ws://192.168.178.62:undefined
            deconz.0	2020-04-23 17:53:32.365	info	(12993) starting. Version 1.3.4 in /opt/iobroker/node_modules/iobroker.deconz, node: v10.20.1, js-controller: 3.0.17
            deconz.0	2020-04-23 17:52:59.256	info	(12297) Code 403: Forbidden get devices: [{"error":{"address":"/devices","description":"unauthorized user","type":1}}]
            deconz.0	2020-04-23 17:52:59.254	info	(12297) Code 403: Forbidden get all groups: [{"error":{"address":"/groups","description":"unauthorized user","type":1}}]
            deconz.0	2020-04-23 17:52:59.252	info	(12297) Code 403: Forbidden get all sensors: [{"error":{"address":"/sensors","description":"unauthorized user","type":1}}]
            deconz.0	2020-04-23 17:52:59.249	info	(12297) Code 403: Forbidden get all lights: [{"error":{"address":"/lights","description":"unauthorized user","type":1}}]
            deconz.0	2020-04-23 17:52:59.211	info	(12297) deConz Version: 2.5.74; API version: 1.16.0
            deconz.0	2020-04-23 17:52:59.197	info	(12297) Terminated (NO_ERROR): Without reason
            deconz.0	2020-04-23 17:52:59.195	info	(12297) terminating
            deconz.0	2020-04-23 17:52:59.140	info	(12297) cleaned everything up...
            deconz.0	2020-04-23 17:52:59.137	error	at process._tickCallback (internal/process/next_tick.js:68:7)
            deconz.0	2020-04-23 17:52:59.137	error	at getAutoUpdates (/opt/iobroker/node_modules/iobroker.deconz/main.js:678:14)
            deconz.0	2020-04-23 17:52:59.137	error	at new WebSocket (/opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/lib/websocket.js:72:7)
            deconz.0	2020-04-23 17:52:59.137	error	at initAsClient (/opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/lib/websocket.js:478:17)
            deconz.0	2020-04-23 17:52:59.137	error	at new URL (internal/url.js:319:5)
            deconz.0	2020-04-23 17:52:59.137	error	at onParseError (internal/url.js:241:17)
            deconz.0	2020-04-23 17:52:59.137	error	(12297) TypeError [ERR_INVALID_URL]: Invalid URL: ws://192.168.178.62:undefined
            deconz.0	2020-04-23 17:52:59.127	error	(12297) uncaught exception: Invalid URL: ws://192.168.178.62:undefined
            deconz.0	2020-04-23 17:52:59.047	info	(12297) starting. Version 1.3.4 in /opt/iobroker/node_modules/iobroker.deconz, node: v10.20.1, js-controller: 3.0.17
            deconz.0	2020-04-23 17:52:25.462	info	(11719) Code 403: Forbidden get devices: [{"error":{"address":"/devices","description":"unauthorized user","type":1}}]
            deconz.0	2020-04-23 17:52:25.460	info	(11719) Code 403: Forbidden get all groups: [{"error":{"address":"/groups","description":"unauthorized user","type":1}}]
            deconz.0	2020-04-23 17:52:25.458	info	(11719) Terminated (NO_ERROR): Without reason
            deconz.0	2020-04-23 17:52:25.456	info	(11719) terminating
            deconz.0	2020-04-23 17:52:25.446	info	(11719) Code 403: Forbidden get all sensors: [{"error":{"address":"/sensors","description":"unauthorized user","type":1}}]
            deconz.0	2020-04-23 17:52:25.444	info	(11719) Code 403: Forbidden get all lights: [{"error":{"address":"/lights","description":"unauthorized user","type":1}}]
            deconz.0	2020-04-23 17:52:25.384	info	(11719) cleaned everything up...
            deconz.0	2020-04-23 17:52:25.380	error	at process._tickCallback (internal/process/next_tick.js:68:7)
            deconz.0	2020-04-23 17:52:25.380	error	at getAutoUpdates (/opt/iobroker/node_modules/iobroker.deconz/main.js:678:14)
            deconz.0	2020-04-23 17:52:25.380	error	at new WebSocket (/opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/lib/websocket.js:72:7)
            deconz.0	2020-04-23 17:52:25.380	error	at initAsClient (/opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/lib/websocket.js:478:17)
            deconz.0	2020-04-23 17:52:25.380	error	at new URL (internal/url.js:319:5)
            deconz.0	2020-04-23 17:52:25.380	error	at onParseError (internal/url.js:241:17)
            deconz.0	2020-04-23 17:52:25.380	error	(11719) TypeError [ERR_INVALID_URL]: Invalid URL: ws://192.168.178.62:undefined
            deconz.0	2020-04-23 17:52:25.371	error	(11719) uncaught exception: Invalid URL: ws://192.168.178.62:undefined
            deconz.0	2020-04-23 17:52:25.357	info	(11719) deConz Version: 2.5.74; API version: 1.16.0
            deconz.0	2020-04-23 17:52:25.233	info	(11719) starting. Version 1.3.4 in /opt/iobroker/node_modules/iobroker.deconz, node: v10.20.1, js-controller: 3.0.17
            deconz.0	2020-04-23 17:51:51.871	info	(11152) Code 403: Forbidden get devices: [{"error":{"address":"/devices","description":"unauthorized user","type":1}}]
            deconz.0	2020-04-23 17:51:51.847	info	(11152) Code 403: Forbidden get all groups: [{"error":{"address":"/groups","description":"unauthorized user","type":1}}]
            deconz.0	2020-04-23 17:51:51.845	info	(11152) Code 403: Forbidden get all sensors: [{"error":{"address":"/sensors","description":"unauthorized user","type":1}}]
            deconz.0	2020-04-23 17:51:51.843	info	(11152) Code 403: Forbidden get all lights: [{"error":{"address":"/lights","description":"unauthorized user","type":1}}]
            deconz.0	2020-04-23 17:51:51.808	info	(11152) deConz Version: 2.5.74; API version: 1.16.0
            deconz.0	2020-04-23 17:51:51.794	info	(11152) Terminated (NO_ERROR): Without reason
            deconz.0	2020-04-23 17:51:51.789	info	(11152) terminating
            deconz.0	2020-04-23 17:51:51.722	info	(11152) cleaned everything up...
            deconz.0	2020-04-23 17:51:51.718	error	at process._tickCallback (internal/process/next_tick.js:68:7)
            deconz.0	2020-04-23 17:51:51.718	error	at getAutoUpdates (/opt/iobroker/node_modules/iobroker.deconz/main.js:678:14)
            deconz.0	2020-04-23 17:51:51.718	error	at new WebSocket (/opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/lib/websocket.js:72:7)
            deconz.0	2020-04-23 17:51:51.718	error	at initAsClient (/opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/lib/websocket.js:478:17)
            deconz.0	2020-04-23 17:51:51.718	error	at new URL (internal/url.js:319:5)
            deconz.0	2020-04-23 17:51:51.718	error	at onParseError (internal/url.js:241:17)
            deconz.0	2020-04-23 17:51:51.718	error	(11152) TypeError [ERR_INVALID_URL]: Invalid URL: ws://192.168.178.62:undefined
            deconz.0	2020-04-23 17:51:51.708	error	(11152) uncaught exception: Invalid URL: ws://192.168.178.62:undefined
            deconz.0	2020-04-23 17:51:51.583	info	(11152) starting. Version 1.3.4 in /opt/iobroker/node_modules/iobroker.deconz, node: v10.20.1, js-controller: 3.0.17
            deconz.0	2020-04-23 17:51:18.207	info	(10583) Code 403: Forbidden get devices: [{"error":{"address":"/devices","description":"unauthorized user","type":1}}]
            deconz.0	2020-04-23 17:51:18.206	info	(10583) Code 403: Forbidden get all groups: [{"error":{"address":"/groups","description":"unauthorized user","type":1}}]
            deconz.0	2020-04-23 17:51:18.204	info	(10583) Code 403: Forbidden get all sensors: [{"error":{"address":"/sensors","description":"unauthorized user","type":1}}]
            deconz.0	2020-04-23 17:51:18.202	info	(10583) Code 403: Forbidden get all lights: [{"error":{"address":"/lights","description":"unauthorized user","type":1}}]
            deconz.0	2020-04-23 17:51:18.140	info	(10583) Terminated (NO_ERROR): Without reason
            deconz.0	2020-04-23 17:51:18.139	info	(10583) terminating
            deconz.0	2020-04-23 17:51:18.131	info	(10583) deConz Version: 2.5.74; API version: 1.16.0
            deconz.0	2020-04-23 17:51:18.082	info	(10583) cleaned everything up...
            • 123brokerei1 123brokerei
              @ jey cee
              Jey CeeJ Online
              Jey CeeJ Online
              Jey Cee
              #66
              @123brokerei hast du schon den Api Key neu erzeugt?
                123brokerei
                #67
                Das ist eben das Problem... ich bekomme nur noch sehr sporadisch einen zugeteilt (von 10 Versuchen vielleicht 1 Treffer) Nach "speichern und schließen" bleibt der Adapter dann aber auf rot. Öffne ich die Einstellungen erneut, ist zwar die IP noch eingetragen, aber der Key ist wieder weg/leer.
                  123brokerei
                  #68
                  @Jey-Cee hast du mir noch einen Tip was ich machen kann? Oder könnte es ein Fehler im Adapter sein? Ich habe inzwischen auch einen Downgrade auf 1.2.6 versucht. Ich bekomme dort zwar zuverlässig einen Key aber eine stabile Verbindung, in der die Befehle zuverlässig übertragen werden ist auch dort nicht möglich. Ich habe langsam den Zusammenhang mit dem Update auf den js-controller 3.0.xx im Verdacht. Da ich zuvor eine stabile Verbindung mit deiner Version 1.3.3 hatte. Das ist jetzt nicht mehr möglich. Anbei nochmals ein Log-Auszug.
                  deconz.0	2020-04-24 16:48:45.821	info	(424) Code 404: Ressource not found get devices: []
                  deconz.0	2020-04-24 16:48:45.715	info	(424) deConz Version: 2.5.74; API version: 1.16.0
                  deconz.0	2020-04-24 16:48:45.587	info	(424) starting. Version 1.3.4 in /opt/iobroker/node_modules/iobroker.deconz, node: v10.20.1, js-controller: 3.0.18
                  deconz.0	2020-04-24 16:48:12.247	info	(31204) Terminated (NO_ERROR): Without reason
                  deconz.0	2020-04-24 16:48:12.245	info	(31204) terminating
                  deconz.0	2020-04-24 16:48:12.187	info	(31204) cleaned everything up...
                  deconz.0	2020-04-24 16:48:12.185	error	at process._tickCallback (internal/process/next_tick.js:68:7)
                  deconz.0	2020-04-24 16:48:12.185	error	at getState (/opt/iobroker/node_modules/iobroker.deconz/main.js:213:59)
                  deconz.0	2020-04-24 16:48:12.185	error	(31204) TypeError: Cannot read property 'id' of undefined
                  deconz.0	2020-04-24 16:48:12.177	error	(31204) uncaught exception: Cannot read property 'id' of undefined
                  deconz.0	2020-04-24 16:47:09.689	info	(31204) Code 404: Ressource not found get devices: []
                  deconz.0	2020-04-24 16:47:09.588	info	(31204) deConz Version: 2.5.74; API version: 1.16.0
                  deconz.0	2020-04-24 16:47:09.467	info	(31204) starting. Version 1.3.4 in /opt/iobroker/node_modules/iobroker.deconz, node: v10.20.1, js-controller: 3.0.18
                  deconz.0	2020-04-24 16:47:03.139	info	(29669) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  deconz.0	2020-04-24 16:47:03.137	info	(29669) terminating
                  deconz.0	2020-04-24 16:47:03.136	info	(29669) cleaned everything up...
                  deconz.0	2020-04-24 16:47:03.134	info	(29669) Got terminate signal TERMINATE_YOURSELF
                  deconz.0	2020-04-24 16:47:01.121	info	(29669) Code 404: Ressource not found get config: <html><head></head><body><h1>This is not the page you are looking for</h1><p>The file /:undefined/api/undefined/config couldn't be found.</p></body>
                  deconz.0	2020-04-24 16:47:01.104	info	(29669) "8820AED9C3"
                  deconz.0	2020-04-24 16:47:01.102	info	(29669) STATUS: {"statusCode":200,"body":"[{\"success\":{\"username\":\"8820AED9C3\"}}]","headers":{"access-control-allow-origin":"*","content-type":"application/json; charset=utf-8","content-length"
                  deconz.0	2020-04-24 16:45:41.780	info	(29669) Code 404: Ressource not found get config: <html><head></head><body><h1>This is not the page you are looking for</h1><p>The file /:undefined/api/undefined/config couldn't be found.</p></body>
                  deconz.0	2020-04-24 16:45:41.650	info	(29669) starting. Version 1.3.4 in /opt/iobroker/node_modules/iobroker.deconz, node: v10.20.1, js-controller: 3.0.18
                  deconz.0	2020-04-24 16:45:36.088	info	(28075) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  deconz.0	2020-04-24 16:45:36.087	info	(28075) terminating
                    Jey CeeJ Online
                    Jey CeeJ Online
                    Jey Cee
                    #69
                    @123brokerei also das ist ein Problem im Adapter, aber das dürfte nicht Auftretten.
                    Ich weis wie ich das behebe und werde das auch bald machen.
                    Mich interessiert aber der Auslöser, kannst du mal das Log Level, Instanz Übersicht -> Exprtenmodus, auf debug stellen und dann das log posten.
                      123brokerei
                      #70
                      @Jey-Cee ... Super schon jetzt vielen Dank für die schnellen Rückmeldungen. Ich habe dir jetzt nochmals ein Log-Auszug mit Log-Status "debug". Ich habe verschiedene Dinge durchgeführt. Unter anderem Key gelöscht und neu angefordert. (das hat dieses Mal sogar geklappt und der Adapter ging gleich auf "grün") Ich habe dann ein paar Szenen in der Lichtgruppe per "recall" aktivieren möchten bzw. die Lichtgruppe mit dem .on Attribut einschalten möchten. Keines der befehle wurde umgesetzt. Solltest du genaue Aktionen im Log sehen wollen gib Bescheid.
                      deconz.0	2020-04-24 18:46:17.004	debug	(838) Subscribed to updates...
                      deconz.0	2020-04-24 18:46:16.996	debug	(838) Websocket connection closed
                      deconz.0	2020-04-24 18:46:05.594	debug	(838) Code 200: Request succeded get group attributes 30777: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["4"]
                      deconz.0	2020-04-24 18:46:05.547	debug	(838) Code 200: Request succeded get group attributes 1: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":"1","xy":[0,0]},"devicemembership":[],"etag":
                      deconz.0	2020-04-24 18:46:05.425	info	(838) Code 404: Ressource not found get devices: []
                      deconz.0	2020-04-24 18:46:05.398	debug	(838) Code 200: Request succeded get all groups: {"1":{"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":"1","xy":[0,0]},"devicemembership":[],"etag":"d7
                      deconz.0	2020-04-24 18:46:05.376	debug	(838) Code 200: Request succeded get all sensors: {"1":{"config":{"configured":true,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":"b0fafddac9f903ff38e433f7206ec413","manufacturername":"Phili
                      deconz.0	2020-04-24 18:46:05.341	debug	(838) Code 200: Request succeded get all lights: {"3":{"ctmax":454,"ctmin":153,"etag":"d72501d6efa9f8470bca294b128cb730","hascolor":true,"manufacturername":"Philips","modelid":"LTW010","name":"Buero C
                      deconz.0	2020-04-24 18:46:05.316	debug	(838) Subscribed to updates...
                      deconz.0	2020-04-24 18:46:05.290	info	(838) deConz Version: 2.5.74; API version: 1.16.0
                      deconz.0	2020-04-24 18:46:05.287	debug	(838) Code 200: Request succeded get config: {"UTC":"2020-04-24T16:46:05","apiversion":"1.16.0","backup":{"errorcode":0,"status":"idle"},"bridgeid":"00212EFFFF05A119","datastoreversion":"60","devicen
                      deconz.0	2020-04-24 18:46:05.162	info	(838) starting. Version 1.3.4 in /opt/iobroker/node_modules/iobroker.deconz, node: v10.20.1, js-controller: 3.0.18
                      deconz.0	2020-04-24 18:46:04.994	debug	(838) Plugin sentry Initialize Plugin (enabled=true)
                      deconz.0	2020-04-24 18:45:31.802	info	(32551) Terminated (NO_ERROR): Without reason
                      deconz.0	2020-04-24 18:45:31.801	debug	(32551) Plugin sentry destroyed
                      deconz.0	2020-04-24 18:45:31.800	info	(32551) terminating
                      deconz.0	2020-04-24 18:45:31.754	debug	(32551) Websocket connection closed
                      deconz.0	2020-04-24 18:45:31.741	info	(32551) cleaned everything up...
                      deconz.0	2020-04-24 18:45:31.739	error	at process._tickCallback (internal/process/next_tick.js:68:7)
                      deconz.0	2020-04-24 18:45:31.739	error	at getState (/opt/iobroker/node_modules/iobroker.deconz/main.js:213:59)
                      deconz.0	2020-04-24 18:45:31.739	error	(32551) TypeError: Cannot read property 'id' of undefined
                      deconz.0	2020-04-24 18:45:31.732	error	(32551) uncaught exception: Cannot read property 'id' of undefined
                      deconz.0	2020-04-24 18:45:31.721	debug	(32551) dp: recall; id:Groups.1.Scene_1 tmp: deconz,0,Groups,1,Scene_1
                      deconz.0	2020-04-24 18:45:31.721	debug	(32551) stateChange Groups.1.Scene_1 {"val":true,"ack":false,"ts":1587746731715,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1587739242267}
                      deconz.0	2020-04-24 18:45:24.814	debug	(32551) Code 200: Request succeded get group attributes 30777: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["
                      deconz.0	2020-04-24 18:45:24.767	debug	(32551) Code 200: Request succeded get group attributes 1: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":"1","xy":[0,0]},"devicemembership":[],"eta
                      deconz.0	2020-04-24 18:45:24.703	info	(32551) Code 404: Ressource not found get devices: []
                      deconz.0	2020-04-24 18:45:24.666	debug	(32551) Code 200: Request succeded get all groups: {"1":{"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":"1","xy":[0,0]},"devicemembership":[],"etag":
                      deconz.0	2020-04-24 18:45:24.650	debug	(32551) Code 200: Request succeded get all sensors: {"1":{"config":{"configured":true,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":"b0fafddac9f903ff38e433f7206ec413","manufacturername":"Ph
                      deconz.0	2020-04-24 18:45:24.600	debug	(32551) Code 200: Request succeded get all lights: {"3":{"ctmax":454,"ctmin":153,"etag":"d72501d6efa9f8470bca294b128cb730","hascolor":true,"manufacturername":"Philips","modelid":"LTW010","name":"Buer
                      deconz.0	2020-04-24 18:45:24.578	debug	(32551) Subscribed to updates...
                      deconz.0	2020-04-24 18:45:24.565	info	(32551) deConz Version: 2.5.74; API version: 1.16.0
                      deconz.0	2020-04-24 18:45:24.562	debug	(32551) Code 200: Request succeded get config: {"UTC":"2020-04-24T16:45:24","apiversion":"1.16.0","backup":{"errorcode":0,"status":"idle"},"bridgeid":"00212EFFFF05A119","datastoreversion":"60","devi
                      deconz.0	2020-04-24 18:45:24.436	info	(32551) starting. Version 1.3.4 in /opt/iobroker/node_modules/iobroker.deconz, node: v10.20.1, js-controller: 3.0.18
                      deconz.0	2020-04-24 18:45:24.255	debug	(32551) Plugin sentry Initialize Plugin (enabled=true)
                      deconz.0	2020-04-24 18:45:22.637	debug	(32551) statesDB connected
                      deconz.0	2020-04-24 18:45:22.636	debug	(32551) States connected to redis: 0.0.0.0:9000
                      deconz.0	2020-04-24 18:45:22.596	debug	(32551) States create System PubSub Client
                      deconz.0	2020-04-24 18:45:22.593	debug	(32551) States create User PubSub Client
                      deconz.0	2020-04-24 18:45:22.571	debug	(32551) Redis States: Use Redis connection: 0.0.0.0:9000
                      deconz.0	2020-04-24 18:45:22.568	debug	(32551) objectDB connected
                      deconz.0	2020-04-24 18:45:22.562	debug	(32551) Objects connected to redis: 0.0.0.0:9001
                      deconz.0	2020-04-24 18:45:22.545	debug	(32551) Objects client initialize lua scripts
                      deconz.0	2020-04-24 18:45:22.544	debug	(32551) Objects create User PubSub Client
                      deconz.0	2020-04-24 18:45:22.543	debug	(32551) Objects create System PubSub Client
                      deconz.0	2020-04-24 18:45:22.538	debug	(32551) Objects client ready ... initialize now
                      deconz.0	2020-04-24 18:45:22.502	debug	(32551) Redis Objects: Use Redis connection: 0.0.0.0:9001
                      deconz.0	2020-04-24 18:45:18.360	debug	(31503) system.adapter.admin.0: logging true
                      deconz.0	2020-04-24 18:45:18.289	debug	(31503) Websocket connection closed
                      deconz.0	2020-04-24 18:45:18.288	info	(31503) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      deconz.0	2020-04-24 18:45:18.287	debug	(31503) Plugin sentry destroyed
                      deconz.0	2020-04-24 18:45:18.285	info	(31503) terminating
                      deconz.0	2020-04-24 18:45:18.284	info	(31503) cleaned everything up...
                      deconz.0	2020-04-24 18:45:18.280	info	(31503) Got terminate signal TERMINATE_YOURSELF
                      deconz.0	2020-04-24 18:45:18.194	debug	(31503) sendTo "saveConfig" to system.adapter.admin.0 from system.adapter.deconz.0
                      deconz.0	2020-04-24 18:45:11.161	info	(31503) Code 403: Forbidden get devices: [{"error":{"address":"/","description":"unauthorized user","type":1}}]
                      deconz.0	2020-04-24 18:45:11.159	info	(31503) Code 403: Forbidden get all groups: [{"error":{"address":"/","description":"unauthorized user","type":1}}]
                      deconz.0	2020-04-24 18:45:11.157	info	(31503) Code 403: Forbidden get all sensors: [{"error":{"address":"/","description":"unauthorized user","type":1}}]
                      deconz.0	2020-04-24 18:45:11.105	info	(31503) Code 403: Forbidden get all lights: [{"error":{"address":"/","description":"unauthorized user","type":1}}]
                      deconz.0	2020-04-24 18:45:11.089	info	(31503) deConz Version: 2.5.74; API version: 1.16.0
                      deconz.0	2020-04-24 18:45:11.087	debug	(31503) Code 200: Request succeded get config: {"apiversion":"1.16.0","bridgeid":"00212EFFFF05A119","datastoreversion":"60","devicename":"ConBee II","factorynew":false,"mac":"ce:80:a4:c0:61:58","mod
                      deconz.0	2020-04-24 18:45:11.076	debug	(31503) sendTo "createAPIkey" to system.adapter.admin.0 from system.adapter.deconz.0: {"error":0,"message":"EC3D78C13E"}
                      deconz.0	2020-04-24 18:45:11.076	info	(31503) "EC3D78C13E"
                      deconz.0	2020-04-24 18:45:11.075	debug	(31503) Code 200: Request succeded create API key: [{"success":{"username":"EC3D78C13E"}}]
                      deconz.0	2020-04-24 18:45:11.074	info	(31503) STATUS: {"statusCode":200,"body":"[{\"success\":{\"username\":\"EC3D78C13E\"}}]","headers":{"access-control-allow-origin":"*","content-type":"application/json; charset=utf-8","content-length"
                      deconz.0	2020-04-24 18:45:11.063	debug	(31503) 192.168.178.62: auth: ZGVsaWdodDpkZWxpZ2h0
                      deconz.0	2020-04-24 18:45:07.066	debug	(31503) sendTo "createAPIkey" to system.adapter.admin.0 from system.adapter.deconz.0: {"error":101,"message":"Unlock Key not pressed"}
                      deconz.0	2020-04-24 18:45:07.065	info	(31503) STATUS: {"statusCode":403,"body":"[{\"error\":{\"address\":\"/\",\"description\":\"link button not pressed\",\"type\":101}}]","headers":{"access-control-allow-origin":"*","content-type":"appl
                      deconz.0	2020-04-24 18:45:07.060	debug	(31503) 192.168.178.62: auth: ZGVsaWdodDpkZWxpZ2h0
                      deconz.0	2020-04-24 18:45:03.050	debug	(31503) sendTo "createAPIkey" to system.adapter.admin.0 from system.adapter.deconz.0: {"error":101,"message":"Unlock Key not pressed"}
                      deconz.0	2020-04-24 18:45:03.049	info	(31503) STATUS: {"statusCode":403,"body":"[{\"error\":{\"address\":\"/\",\"description\":\"link button not pressed\",\"type\":101}}]","headers":{"access-control-allow-origin":"*","content-type":"appl
                      deconz.0	2020-04-24 18:45:03.043	debug	(31503) 192.168.178.62: auth: ZGVsaWdodDpkZWxpZ2h0
                      deconz.0	2020-04-24 18:45:00.118	debug	(31503) system.adapter.admin.0: logging false
                      deconz.0	2020-04-24 18:44:59.992	debug	(31503) sendTo "createAPIkey" to system.adapter.admin.0 from system.adapter.deconz.0: {"error":101,"message":"Unlock Key not pressed"}
                      deconz.0	2020-04-24 18:44:59.990	info	(31503) STATUS: {"statusCode":403,"body":"[{\"error\":{\"address\":\"/\",\"description\":\"link button not pressed\",\"type\":101}}]","headers":{"access-control-allow-origin":"*","content-type":"appl
                      deconz.0	2020-04-24 18:44:59.981	debug	(31503) 192.168.178.62: auth: ZGVsaWdodDpkZWxpZ2h0
                      deconz.0	2020-04-24 18:44:58.323	info	(31503) API key deleted
                      deconz.0	2020-04-24 18:44:58.322	debug	(31503) Code 200: Request succeded delete API key: [{"success":"/config/whitelist/8820AED9C3 deleted."}]
                      deconz.0	2020-04-24 18:44:58.311	info	(31503) deleteAPIkey
                      deconz.0	2020-04-24 18:44:37.005	debug	(31503) Subscribed to updates...
                      deconz.0	2020-04-24 18:44:36.998	debug	(31503) Websocket connection closed
                      deconz.0	2020-04-24 18:44:30.001	debug	(31503) Code 200: Request succeded get group attributes 30777: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["
                      deconz.0	2020-04-24 18:44:29.962	debug	(31503) Code 200: Request succeded get group attributes 1: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":"1","xy":[0,0]},"devicemembership":[],"eta
                      deconz.0	2020-04-24 18:44:29.882	info	(31503) Code 404: Ressource not found get devices: []
                      deconz.0	2020-04-24 18:44:29.879	debug	(31503) Code 200: Request succeded get all groups: {"1":{"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":"1","xy":[0,0]},"devicemembership":[],"etag":
                      deconz.0	2020-04-24 18:44:29.848	debug	(31503) Code 200: Request succeded get all sensors: {"1":{"config":{"configured":true,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":"b0fafddac9f903ff38e433f7206ec413","manufacturername":"Ph
                      deconz.0	2020-04-24 18:44:29.804	debug	(31503) Code 200: Request succeded get all lights: {"3":{"ctmax":454,"ctmin":153,"etag":"d72501d6efa9f8470bca294b128cb730","hascolor":true,"manufacturername":"Philips","modelid":"LTW010","name":"Buer
                      deconz.0	2020-04-24 18:44:29.774	info	(31503) deConz Version: 2.5.74; API version: 1.16.0
                        Jey CeeJ Online
                        Jey CeeJ Online
                        Jey Cee
                        #71
                        @123brokerei da ist auf jeden Fall ein Problem mit JS-Controller 3, allerdings bekomme ich einen anderen Fehler. Wird etwas dauern bis ich dahinter steige wo das Problem ist.
                          123brokerei
                          #72
                          Hi @Jey-Cee kurze Rückmeldung zu deiner Vorabversion von 1.3.5 auf github. Der API.Key wird nun zuverlässig übernommen und auch das .level Attribut wird zumindest in den Einzelleuchten korrekt aktualisiert, wenn ich eine andere Szene wähle. Vielen Dank! Gibt es voraussichtlich noch Anpassungen an der Vorabversion?
                            123brokerei
                            schrieb am zuletzt editiert von 123brokerei
                            #73
                            Hi @Jey-Cee kann es sein, dass in der 1.3.5 die Arttribute .dimup und .dimdown sowohl in einer Lichtgruppe als auch bei den Einzellampen keine Funktion mehr hat?
                            Jey CeeJ 2 Antworten Letzte Antwort
                              Jey CeeJ Online
                              Jey CeeJ Online
                              Jey Cee
                              #74
                              @123brokerei kann sein, die sind irgendwie Problematisch bei mir funktionieren die nie wie erwartet. Ich benutz sie aber auch nicht, die hat mal jemand anders eingebaut.
                              Hab jetzt noch nicht genauer geschaut, aber auf den ersten Blick seh ich nicht wo das Problem ist.
                              • Jey CeeJ Online
                                Jey CeeJ Online
                                Jey Cee
                                #75
                                Es ist jetzt version 1.3.5 auch auf npm also latest verfügbar.
                                E 1 Antwort Letzte Antwort
                                  Tirador
                                  #76
                                  Ich muss Mal ein danke hierlassen, dass dieser Adapter so reibungslos funktioniert. Super Arbeit!
                                  • T Tirador
                                    skokarl
                                    #77
                                    @Tirador sagte in Test Adapter deConz v1.3.x Github/npm:
                                    jipp, läuft bei mir auch super.
                                    DANKE @Jey-Cee
                                    • Jey CeeJ Jey Cee
                                      e-s
                                      schrieb am zuletzt editiert von e-s
                                      #78
                                      @Jey-Cee
                                      Hallo, ich habe hier eine Ikea RGB Buld die mich nervt, irgendwie nimmt die nicht alle Befehle an:
                                      deconz.0	2020-04-29 20:55:25.602	info	(17962) {"val":3,"ack":false,"ts":1588186470705,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1588186470705}
                                      deconz.0	2020-04-29 20:55:12.655	warn	(17962) Code 400: Bad request set light state 2: [{"error":{"address":"/lights/2/state","description":"body contains invalid JSON","type":2}}]
                                      deconz.0	2020-04-29 20:54:03.801	info	(17962) {"val":1,"ack":false,"ts":1588186402714,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1588186402714}
                                      deconz.0	2020-04-29 20:52:03.962	warn	(17962) {"address":"/lights/2","description":"parameter, /lights/2/effect, is not modifiable. Device is set to off.","type":201}
                                      deconz.0	2020-04-29 20:52:03.943	info	(17962) {"val":100,"ack":false,"ts":1584128353844,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1584128353844}
                                      deconz.0	2020-04-29 20:41:26.086	info	(17962) Code 404: Ressource not found get devices: []
                                      deconz.0	2020-04-29 20:41:25.779	info	(17962) deConz Version: 2.5.75; API version: 1.16.0
                                      deconz.0	2020-04-29 20:41:25.614	info	(17962) starting. Version 1.3.5 in /opt/iobroker/node_modules/iobroker.deconz, node: v14.0.0, js-controller: 3.0.20
                                      host.ubuntuserver	2020-04-29 20:41:21.455	info	instance system.adapter.deconz.0 started with pid 17962
                                      Helligkeit geht immer ohne Probleme, aber Farbe und Sättigung so gut wie nie, vielleicht war es auch zufall wenn sich da mal verändert hat. Auf jedenfall nicht nachvollziehbar.
                                      Habe auch mal ein debuglog laufen lassen, aber ich schaffe es da nie eine funktionierende Umschaltung zu loggen.
                                      Was mich wundert, ein paar mal hat sich die Farbe erst geändert nachdem ich die Sättigung verändert habe.
                                      alert funktioniert auch, colorloop aber nicht, steht aber auch im log mit effect is not modifiable
                                      • S skokarl
                                        @Jey-Cee
                                        moin,
                                        nur mal so am Rande, ich habe meinen IOBroker neu aufgesetzt, ( hatte andere Gründe ),
                                        dabei natürlich auch die Deconz Software aktualisiert, und den Adapter 1.31 installiert.
                                        Läuft alles sauber und einwandfrei.
                                        Vielleicht sollten die Leute die Probleme haben auch mal die Deconz Installation überprüfen.
                                        aktuelle Files gibt es ja hier.
                                        http://deconz.dresden-elektronik.de/ubuntu/beta/
                                        Berchemer
                                        schrieb am zuletzt editiert von Berchemer
                                        #79
                                        @skokarl sagte in Test Adapter deConz v1.3.x Github/npm:
                                        Danke für die Info.
                                        Da ich nach Update auf Version 1.3.4 des Deconz-Adapters die Fehlermeldung mit 404 bekam, die hier einige Male angesprochen wurde, dachte ich, vielleicht ist ein Update doch keine so schlechte Sache.
                                        Bisher bin ich nur davor zurückgeschreckt, weil die 2.5.75 ja eine Beta ist.
                                        Du sagst, dass Du mit der Beta im Zusammenhang mit 1.3.4 vollkommen zufrieden bist???
                                        • E e-s
                                          @Jey-Cee
                                          Jey CeeJ Online
                                          Jey CeeJ Online
                                          Jey Cee
                                          #80
                                          @e-s wie verstellst du die Farbe, Hue oder xy?
