  4. ioBroker startet nicht
funktioniertnicht
50 Beiträge 4 Kommentatoren 6.8k Aufrufe 1 Beobachtet
  • N Nier
    @haselchen said in ioBroker startet nicht:
    npm i iobroker.js-controller
    Leider gehts immer noch nicht
    root@NiermannSmartHome:/opt/iobroker# npm i iobroker.js-controller
    npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
    > iobroker.js-controller@2.2.9 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.13.4
    > iobroker.js-controller@2.2.9 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
    npm WARN winston-daily-rotate-file@4.4.2 requires a peer of winston@^3 but none is installed. You must install peer dependencies yourself.
    npm WARN winston-syslog@2.4.0 requires a peer of winston@^3.0.0 but none is installed. You must install peer dependencies yourself.
    npm WARN ajv-keywords@2.1.1 requires a peer of ajv@^5.0.0 but none is installed. You must install peer dependencies yourself.
    + iobroker.js-controller@2.2.9
    updated 1 package and audited 4642 packages in 50.317s
    2 packages are looking for funding
     run `npm fund` for details
    found 50 vulnerabilities (32 low, 18 high)
     run `npm audit fix` to fix them, or `npm audit` for details
    Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
    Hier gehts zur Hilfe.
    AlCalzoneA Offline
    AlCalzoneA Offline
    AlCalzone
    schrieb am zuletzt editiert von AlCalzone
    #41
    @Nier sagte in ioBroker startet nicht:
    updated 1 package
    iobroker.admin@3.7.8
    removed 23 packages and updated 1 package
    Geht doch!
    Und hierzu:
    This adapter cannot be installed directly from github.
    You must install it from npm.
    Write for that "npm install iobroker.admin" in according directory.
    Du hast den Admin zuvor über Github installiert.
    Les dir bitte https://www.iobroker.net/#de/documentation/tutorial/adapter.md?dieinstallationvongithub und mach es dann nie wieder. Außer du wirst explizit dazu aufgefordert.
    Warum sudo böse ist: https://forum.iobroker.net/post/17109
    N 1 Antwort Letzte Antwort
    • AlCalzoneA AlCalzone
      updated 1 package
      Geht doch!
      Und hierzu:
      N Offline
      N Offline
      Nier
      #42
      @AlCalzone Kann man das noch irgendwie fixieren? Denn mit npm install iobroker.admin geht es ja leider auch nicht....
      werde es auf jeden fall nie wieder tun 😞
      haselchenH AlCalzoneA 2 Antworten Letzte Antwort
      • N Nier
        haselchenH Offline
        haselchenH Offline
        haselchen
        #43
        @Nier
        Was geht denn nicht ?
        • N Nier
          AlCalzoneA Offline
          AlCalzoneA Offline
          AlCalzone
          #44
          @Nier
          cd /opt/iobroker
          iobroker upload admin
          iobroker start admin.0
          • haselchenH haselchen
            @Nier
            N Offline
            N Offline
            Nier
            #45
            @haselchen Wenn ich den iobroker öffne kommt nur:
            ich komm leider gar nicht auf die oberfläche und kann halt nichts machen
            • N Nier
              AlCalzoneA Offline
              AlCalzoneA Offline
              AlCalzone
              #46
              @Nier Das sind Befehle für die Konsole!
                N Offline
                N Offline
                Nier
                #47
                @AlCalzone DANKE!!! Es hat geklappt. Ich kann dir grade gar nicht genug danken. Auch an @haselchen !
                • N Nier
                  haselchenH Offline
                  haselchenH Offline
                  haselchen
                  #48
                  @Nier
                  Das Kind ist geboren . Halleluja 😎
                  In der Oberfläche im Admin den Verwahrungsort auf Latest stellen und auf der Oberfläche den Admin auf 4.0.5 updaten.
                    @Nier
                    N Offline
                    N Offline
                    Nier
                    #49
                    @haselchen alles klar danke :)
                    • N Nier
                      NPM version: 6.13.4
                      #50
                      Spoiler
                      wo ist das Problem?
                      WARN: skipping OPTIONAL dependencies
                      Also kein Fehler nur eine Warnung - ist ok!
