  4. Zigbee Adapter kann nicht auf Zigbee Stick zugreifen
zigbee adapterzigbee adapter cc2531
17 Beiträge 3 Kommentatoren 4.1k Aufrufe 3 Beobachtet
    TrippleP
    schrieb am zuletzt editiert von TrippleP
    Ich versuche den Zigbee adapter ans laufen zu bekommen.
    lsusb zeigt das Device korrekt als: Bus 001 Device 004: ID 0451:16ae Texas Instruments, Inc.
    Pfad ist /dev/ttys0
    admin 3.7.8
    Zigbee 1.0.2
    aber:
    zigbee.0	2020-02-13 14:14:24.392	error	(2739) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port' at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/zn
    zigbee.0	2020-02-13 14:14:24.391	error	(2739) Failed to start Zigbee
    zigbee.0	2020-02-13 14:14:24.119	info	(2739) Starting Zigbee...
    zigbee.0	2020-02-13 14:14:24.118	info	(2739) Try to reconnect. 1 attempts left
    zigbee.0	2020-02-13 14:14:14.117	error	(2739) Error: AREQ - SYS - resetInd after 30000ms at Timeout.object.timer.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:44:24) at ontimeout (tim
    zigbee.0	2020-02-13 14:14:14.114	error	(2739) Failed to start Zigbee
    zigbee.0	2020-02-13 14:28:03.014	error	at binding.open.then.err (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12)
    zigbee.0	2020-02-13 14:28:03.014	error	at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
    zigbee.0	2020-02-13 14:28:03.014	error	at SerialPort.serialPort.open (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:111:49)
    zigbee.0	2020-02-13 14:28:03.014	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:4:12)
    zigbee.0	2020-02-13 14:28:03.014	error	at new Promise (<anonymous>)
    zigbee.0	2020-02-13 14:28:03.014	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:8:71
    zigbee.0	2020-02-13 14:28:03.014	error	at Generator.next (<anonymous>)
    zigbee.0	2020-02-13 14:28:03.014	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:113:32)
    zigbee.0	2020-02-13 14:28:03.014	error	(3340) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
    zigbee.0	2020-02-13 14:28:03.013	error	(3340) Failed to start Zigbee
    Zudem schwankt die Grüße des Adapters im Speicher zwischen 330MB und 680MB
    Übersehe ich etwas?
    Patrick
    arteckA AsgothianA 2 Antworten Letzte Antwort
    • T TrippleP
      Pfad ist /dev/ttys0
      admin 3.7.8
      Zigbee 1.0.2
      aber:
      Übersehe ich etwas?
      Patrick
      arteckA Offline
      arteckA Offline
      arteck
      @TrippleP sagte in Zigbee Adapter kann nicht auf Zigbee Stick zugreifen:
      das ist die Fehlermeldung..
      • T TrippleP
        Pfad ist /dev/ttys0
        admin 3.7.8
        Zigbee 1.0.2
        aber:
        Übersehe ich etwas?
        Patrick
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        Pfad ist /dev/ttys0
        Bist du sicher das es /dev/ttys0 als serielles Device ist ? Das ist für die Zigbee-Sticks ein unüblicher device name.
        Die Fehlermeldung "cannot lock port" deutet darauf hin das die Schnittstelle die er zu nutzen versucht entweder belegt ist oder der entsprechende Benutzer darauf nicht zugreifen kann.
        A.
          TrippleP
          Danke für die Antworten
          Ich habe Serial0 mit dem ttyAMA01 fpr den Z-Wave Adapter und der einzig andere Serial istSerial1 als ttyS0. Es sind auch die einzigen beiden Devices die mir im Zigbee Adapter angeboten werden.
          lrwxrwxrwx  1 root root           7 Feb 13 11:23 serial0 -> ttyAMA0
          lrwxrwxrwx  1 root root           5 Feb 13 11:23 serial1 -> ttyS0
          Berechtigungen haben beide voll für alle.
          Ich habe leider keinen Anhaltspunkt gefunden, wo ich ansetzen könnte.
          • T TrippleP
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            @TrippleP
            Entferne bitte mal den Zigbee-Stick vom Rechner und schau dann nach welche seriellen Ports noch existieren.
            A.
              TrippleP
              verschwinden tut keiner, auch nicht nach reboot, auf jeden Fall ist ttyS0 das erste Mal nach einstecken des Zigbee hoch gekommen.
              Zwave läuft problemlos auf ttyAMA0
              pi@Jarvis:~ $ ls /dev -al > ohne.txt
              pi@Jarvis:~ $ ls /dev -al > mit.txt
              pi@Jarvis:~ $ diff -q mit.txt ohne.txt
              Dateien mit.txt und ohne.txt sind verschieden.
              pi@Jarvis:~ $ diff mit.txt ohne.txt
              9c9
              < drwxr-xr-x  2 root root        2720 Feb 14 09:17 char
              > drwxr-xr-x  2 root root        2700 Feb 14 09:12 char
              • T TrippleP
                9c9
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                @TrippleP
                • Hast du den Stick vorher schon einmal genutzt ?
                • Was fuer ein stick ist es ?
                Für mich sieht es so aus als ob der Stick keine korrekte Firmware hat.
                A.
                • AsgothianA Asgothian
                  @TrippleP
                  A.
                  TrippleP
                  @Asgothian
                  ein CC2531, angeblich mit passender FW
                  • T TrippleP
                    @Asgothian
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    angeblich ?
                    Welche Quelle ?
                    A.
                      angeblich ?
                      Welche Quelle ?
                      A.
                      TrippleP
                      @Asgothian
                      siehe Link
                      • T TrippleP
                        @Asgothian
                        siehe Link
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        @TrippleP Ah.. link übersehen. Ich gehe davon aus das da keine FW drauf ist. Den musst du erst flashen
                        A.
                          TrippleP
                          Hmmm hatte gedacht er hätte die FW...
                          Das wäre blöd, sofern das nciht mittlerweile über USB geht :D
                          Der sollte gehen?
                          • T TrippleP
                            Der sollte gehen?
                            AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            @TrippleP Sollte er, ja.
                            A.
                              A.
                              TrippleP
                              @Asgothian
                              Danke, dann werde ich ihn wohl mal bestellen und hoffen das er läuft.
                              Ist es eigentlich normal, das der Adapter hunderte von MB belegt?
                              • T TrippleP
                                @Asgothian
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                @TrippleP nein, bei mir belegt er 50 mb in etwa
                                T 2 Antworten Letzte Antwort
                                  TrippleP
                                  @Asgothian
                                  Dann beobachte ich das mal mit dem neuen Stick, evtl war es wegen der Probleme.
                                    TrippleP
                                    @Asgothian
                                    Vielen Dank, es lag wirklich am Stick....
                                    Viele Grüße
