  4. Admin4.0.2 Log herunterladen
adminlogerrorsyntaxerror unexpectedinvalid base
1 Beiträge 1 Kommentatoren 303 Aufrufe 1 Beobachtet
  • crunchipC Offline
    crunchipC Offline
    Log herunterladen, noch nicht behoben worden?
    2020-02-13 10:46:33.090 - info: admin.0 (6088) starting. Version 4.0.2 in /opt/iobroker/node_modules/iobroker.admin, node: v10.19.0
    2020-02-13 10:46:33.149 - info: admin.0 (6088) requesting all states
    2020-02-13 10:46:33.150 - info: admin.0 (6088) requesting all objects
    2020-02-13 10:46:36.161 - info: admin.0 (6088) received all objects
    2020-02-13 10:46:36.481 - info: admin.0 (6088) http server listening on port 8081
    2020-02-13 10:46:36.482 - info: admin.0 (6088) Use link "http://localhost:8081" to configure.
    2020-02-13 10:47:11.017 - error: admin.0 (6088) uncaught exception: invalid base256 encoding
    2020-02-13 10:47:11.018 - error: admin.0 (6088) TypeError: invalid base256 encoding
    at Object.exports.parse (/opt/iobroker/node_modules/tar/lib/large-numbers.js:53:11)
    at decNumber (/opt/iobroker/node_modules/tar/lib/header.js:245:27)
    at Header.decode (/opt/iobroker/node_modules/tar/lib/header.js:55:17)
    at new Header (/opt/iobroker/node_modules/tar/lib/header.js:39:12)
    at Unpack.[consumeHeader] (/opt/iobroker/node_modules/tar/lib/parse.js:105:20)
    at Unpack.[consumeChunkSub] (/opt/iobroker/node_modules/tar/lib/parse.js:386:30)
    at Unpack.[consumeChunk] (/opt/iobroker/node_modules/tar/lib/parse.js:363:30)
    at Unzip.(anonymous function).on.chunk (/opt/iobroker/node_modules/tar/lib/parse.js:292:59)
    at Unzip.emit (events.js:198:13)
    at Unzip.emit (/opt/iobroker/node_modules/minipass/index.js:307:25)
    2020-02-13 10:47:11.019 - info: admin.0 (6088) terminating http server on port 8081
    2020-02-13 10:47:11.068 - info: admin.0 (6088) terminating
    2020-02-13 10:47:11.070 - info: admin.0 (6088) Terminated (NO_ERROR): Without reason
    2020-02-13 10:47:11.620 - error: host.IoBroker Caught by controller[0]: TypeError: invalid base256 encoding
    2020-02-13 10:47:11.621 - error: host.IoBroker Caught by controller[0]: at Object.exports.parse (/opt/iobroker/node_modules/tar/lib/large-numbers.js:53:11)
    2020-02-13 10:47:11.621 - error: host.IoBroker Caught by controller[0]: at decNumber (/opt/iobroker/node_modules/tar/lib/header.js:245:27)
    2020-02-13 10:47:11.621 - error: host.IoBroker Caught by controller[0]: at Header.decode (/opt/iobroker/node_modules/tar/lib/header.js:55:17)
    2020-02-13 10:47:11.621 - error: host.IoBroker Caught by controller[0]: at new Header (/opt/iobroker/node_modules/tar/lib/header.js:39:12)
    2020-02-13 10:47:11.622 - error: host.IoBroker Caught by controller[0]: at Unpack.[consumeHeader] (/opt/iobroker/node_modules/tar/lib/parse.js:105:20)
    2020-02-13 10:47:11.622 - error: host.IoBroker Caught by controller[0]: at Unpack.[consumeChunkSub] (/opt/iobroker/node_modules/tar/lib/parse.js:386:30)
    2020-02-13 10:47:11.622 - error: host.IoBroker Caught by controller[0]: at Unpack.[consumeChunk] (/opt/iobroker/node_modules/tar/lib/parse.js:363:30)
    2020-02-13 10:47:11.622 - error: host.IoBroker Caught by controller[0]: at Unzip.(anonymous function).on.chunk (/opt/iobroker/node_modules/tar/lib/parse.js:292:59)
    2020-02-13 10:47:11.622 - error: host.IoBroker Caught by controller[0]: at Unzip.emit (events.js:198:13)
    2020-02-13 10:47:11.622 - error: host.IoBroker Caught by controller[0]: at Unzip.emit (/opt/iobroker/node_modules/minipass/index.js:307:25)
    2020-02-13 10:47:11.623 - info: host.IoBroker instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
    2020-02-13 10:47:11.623 - info: host.IoBroker Restart adapter system.adapter.admin.0 because enabled
    2020-02-13 10:47:41.646 - info: host.IoBroker instance system.adapter.admin.0 started with pid 6265
    2020-02-13 10:47:44.783 - info: admin.0 (6265) starting. Version 4.0.2 in /opt/iobroker/node_modules/iobroker.admin, node: v10.19.0
    Hatte bereits ein Issue für 4.0.1 erstellt.
    siehe auch https://forum.iobroker.net/post/375734
    EDIT: https://forum.iobroker.net/post/376893
