  4. MieleCloudService Adapter
    1.0k
    6.1k
mielemieleathomemielecloudservice
888 Beiträge 93 Kommentatoren 375.5k Aufrufe 99 Beobachtet
  • Sascha LöbbertS Sascha Löbbert
    Hallo!
    Bekomme seit dem 4.0.20 Update folgende Fehlermeldungen im Log:
    mielecloudservice.0	2021-05-03 11:32:12.173	error	at Timeout.schedule [as _onTimeout] (/opt/iobroker/node_modules/iobroker.mielecloudservice/main.js:672:21)
    mielecloudservice.0	2021-05-03 11:32:12.173	error	at splitMieleDevices (/opt/iobroker/node_modules/iobroker.mielecloudservice/main.js:287:9)
    mielecloudservice.0	2021-05-03 11:32:12.173	error	at parseMieleDevice (/opt/iobroker/node_modules/iobroker.mielecloudservice/main.js:311:5)
    mielecloudservice.0	2021-05-03 11:32:12.173	error	at addMieleDevice (/opt/iobroker/node_modules/iobroker.mielecloudservice/main.js:352:17)
    mielecloudservice.0	2021-05-03 11:32:12.173	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
    mielecloudservice.0	2021-05-03 11:32:12.173	error	at runMicrotasks (<anonymous>)
    mielecloudservice.0	2021-05-03 11:32:12.173	error	at addMieleDeviceState (/opt/iobroker/node_modules/iobroker.mielecloudservice/main.js:403:34)
    mielecloudservice.0	2021-05-03 11:32:12.173	error	(1037) [addMieleDeviceState]: mieleTools.createStateSpinAPIStartActionningSpeed is not a function, Stacktrace: TypeError: mieleTools.createStateSpinAPIStartActionningSpeed is not a function
    mielecloudservice.0	2021-05-03 11:32:11.620	info	(1037) Starting poll timer with a [3] Minute(s) interval.
    mielecloudservice.0	2021-05-03 11:32:11.619	error	at main (/opt/iobroker/node_modules/iobroker.mielecloudservice/main.js:664:13)
    mielecloudservice.0	2021-05-03 11:32:11.619	error	at splitMieleDevices (/opt/iobroker/node_modules/iobroker.mielecloudservice/main.js:287:9)
    mielecloudservice.0	2021-05-03 11:32:11.619	error	at parseMieleDevice (/opt/iobroker/node_modules/iobroker.mielecloudservice/main.js:311:5)
    mielecloudservice.0	2021-05-03 11:32:11.619	error	at addMieleDevice (/opt/iobroker/node_modules/iobroker.mielecloudservice/main.js:352:17)
    mielecloudservice.0	2021-05-03 11:32:11.619	error	at addMieleDeviceState (/opt/iobroker/node_modules/iobroker.mielecloudservice/main.js:403:34)
    mielecloudservice.0	2021-05-03 11:32:11.619	error	(1037) [addMieleDeviceState]: mieleTools.createStateSpinAPIStartActionningSpeed is not a function, Stacktrace: TypeError: mieleTools.createStateSpinAPIStartActionningSpeed is not a function
    mielecloudservice.0	2021-05-03 11:32:09.858	info	(1037) Setting up devices ...
    Soll ich dafür ein Ticket in github aufmachen oder reicht dir das hier als info?
    GrizzelbeeG Offline
    GrizzelbeeG Offline
    Grizzelbee
    #321
    @sascha-löbbert sagte in MieleCloudService Adapter:
    Reicht. Ist in 4.0.21 gefixed.
    @marka sagte in MieleCloudService Adapter:
    dank des neuen js-controller erhalte ich unter 4.0.20 die folgenden Meldungen:
    Bezüglich des "Licht Problems" der Abzugshaube bin ich mit Miele noch im Austausch.
    Alles klar. Danke für die Info.
    V4.0.21 (2021-05-03) (The Edge)
    • (grizzelbee) Fix: Fixed accidental function name: createStateSpinAPIStartActionningSpeed
    • (grizzelbee) Fix: Fixed State value to set for "*.PlateStep_1" has to be type "number" but received type "string"
    J 1 Antwort Letzte Antwort
    • M michael 1975
      @grizzelbee ok hatte vielleicht nur einen Schluckauf jetzt geht es wieder, man ist halt schon verwöhnt wenn man morgens in die Küche kommt und die Machine ist schon an.
      Danke nochmal für die Superarbeit von dir.
      Stormbringer
      schrieb am zuletzt editiert von Stormbringer
      #322
      @michael-1975 Bin auch grad am überlegen ob ich mir eine hole… Kann man mit der Maschine inzwischen auch übern Broker automatisch nen Kaffee raus lassen in der Früh oder muss man da jedes mal vorm Schlafen gehen MobileControl einschalten? Wenn nein, geht nur einschalten ohne jedes mal MobileControl zu drücken?
      Angaben zur Installation: JS Controller 5.0.12, npm 9.6.7, node 18.17.1, auf einem Intel NUC mit Ubuntu 22.04
      • S Stormbringer
        michael 1975
        #323
        @stormbringer Also ich kann bei meiner Maschine über den Iobroker nur einschalten. Was mir eigentlich reicht da sie sowieso erst spült.
        Bei Mir ist es so wenn der Alexa Wecker geklingt hat (ich stehe zu unterschiedlichen zeiten auf) und ich dann an einem Bewegungsmelder vorbei kommen geht die Maschine an und bis ich in der Küche bin ist sie an und hat gespült und ich kann mein Kaffee rauslassen.
        Gruß Michael
        • M michael 1975
          Gruß Michael
          Stormbringer
          #324
          @michael-1975 Ok, danke für die Info 😉 Klingt interessant. Aber MobileControl muss man ned immer drücken bevor man ins Bett geht? Sorry, dass ich so blöd frag aber seit der Waschmaschine und dem Trockner (wo das so ist) bin ich da n bisschen vorsichtig 😋
          • L LaplaceII
            @grizzelbee
            Prima, danke für die ausführlichen Antworten. Verstehe nun besser, warum das eine oder andere nicht so funktioniert wie es eigentlich sein sollte. Also werde ich die Punkte mal bei Miele absetzen....mal schauen wie die Reaktion ist...
            LaplaceII
            #325
            @laplaceii sagte in MieleCloudService Adapter:
            @grizzelbee
            Hier die Antwort von Miele....klingt vielversprechend....
            *aktuell kann die MobileStart-Funktion nur über die App angestoßen werden.
            Nach Rücksprache mit der zuständigen Fachabteilung können wir Ihnen mitteilen, dass zur Zeit daran gearbeitet wird, diese Funktion in Zukunft auch über die 3rd Party API zur Verfügung zu stellen.*
            • S Stormbringer
              michael 1975
              #326
              @stormbringer ne das hat meine Kaffemaschine nicht nur Fernsteuerung einmal aktivieren und der bleibt auch drin
              • GrizzelbeeG Grizzelbee
                JoergH
                #327
                @grizzelbee
                Erstmal vielen Dank für den Adapter!
                Ich habe eine Geschirrspüle, die ich per APP auch pausieren lassen und dann das Programm auch wieder fortsetzen kann. Geht das auch irgendwie mit dem Adapter?
                Wenn ich die Action "Stop" nutze, dann bricht er komplett ab und man kann das Programm nicht mehr fortsetzen. Das wäre halt für die PV Überschuss-Steuerung sehr hilfreich...
                GrizzelbeeG 1 Antwort Letzte Antwort
                • J JoergH
                  @grizzelbee
                  GrizzelbeeG Offline
                  GrizzelbeeG Offline
                  Grizzelbee
                  schrieb am zuletzt editiert von Grizzelbee
                  #328
                  Hallo @joergh
                  Darauf kann ich nur mit einem klaren und entschiedenen "Vielleicht!" antworten.
                  Ich selbst habe "nur" eine Waschmaschine und einen Trockner - deshalb kann ich nicht für alle Geräteklassen alles austesten. Zumal es innerhalb der Klassen auch noch Unterschiede gibt. Deshalb kann ich mich nur an der offiziellen Doku von Miele entlang hangeln:
                  Und die gibt eben genau das her, was aktuell implementiert ist. Allerdings: ist die Doku in sich auch nicht immer konsistent. Das führt uns zum: "Mach mit!" Ansatz. Die ganze API ist im Netz veröffentlicht und mit den Zugangsdaten, die dir für den Adapter bereits vorliegen, kannst du sie online testen: https://www.miele.com/developer/swagger-ui/swagger.html
                  Probiere doch einfach aus ob der Pause Befehl (oder sogar weitere) funktioniert und wenn ja, dann schreib mir das und ich baue das gerne ein. So z.B. gerade geschehen für Start, Stop, Pause für den Scout RX2 in der v4.1.0.
                  https://github.com/Grizzelbee/ioBroker.mielecloudservice/issues/149
                  J maeb3M 2 Antworten Letzte Antwort
                    Hallo @joergh
                    JoergH
                    #329
                    Hallo @grizzelbee
                    vielen Dank für das Feedback und das Angebot. Da ich ja die APP habe und dort die Pausefunktion funktioniert, sollte es ja gehen,oder...?
                    Wäre klasse, wenn Du das einbauen kannst!
                    • J JoergH
                      Hallo @grizzelbee
                      GrizzelbeeG Offline
                      GrizzelbeeG Offline
                      Grizzelbee
                      #330
                      @joergh sagte in MieleCloudService Adapter:
                      Nicht zwingend. Die API kann bisher einiges weniger als die APP.
                      Gerne - Nachdem die Funktionsfähigkeit bestätigt ist.
                      J 2 Antworten Letzte Antwort
                        JoergH
                        #331
                        @grizzelbee
                        Aha, ok. Wie funktioniert denn das? Ich habe die Seite gesehen, aber gibt es dazu eine Anleitung, wie ich das dort testen kann?
                          JoergH
                          #332
                          @grizzelbee
                          Ich habe jetzt mal probiert und mich eingeloggt, dann den Befehl ProcessAction 3 (Pause) ausgelöst und siehe da, die APP zeigt an, dass das Programm pausiert :-)
                          • J JoergH
                            @grizzelbee
                            GrizzelbeeG Offline
                            GrizzelbeeG Offline
                            Grizzelbee
                            #333
                            @joergh
                            V4.2.0 (2021-05-17) (A new Dimension)
                            • (grizzelbee) New: Adding Pause action to dish washers
                              @joergh
                              JoergH
                              #334
                              @grizzelbee Super! Vielen Dank!
                              oberfraggerO 1 Antwort Letzte Antwort
                              • J JoergH
                                oberfraggerO Offline
                                oberfragger
                                schrieb am zuletzt editiert von oberfragger
                                #335
                                @joergh Hab auch nen Dishwasher von Miele-
                                Wofür nutzt du das Pause Feature. Mir fällt da wirklich kein UseCase ein...
                                Btw. Wären die Geräte nicht so teuer... würde ich mir wünschen Bachhofen, Kaffeemaschine, Dunstabzugshaube und Herd wären von Miele. So gut wie @Grizzelbee den Adapter pflegt und so problemlos das funktiont. Das hätte ich auch gern bei Homeconnect. Irgendwie gehts da nicht voran.
                                Danke für deine Arbeit @Grizzelbee !
                                • oberfraggerO oberfragger
                                  JoergH
                                  #336
                                  @oberfragger
                                  Ich optimiere meinen PV Stromverbrauch über ein Loadmanagement: Wenn ich die Geschirrspüle einschalte, prüft er ob genug Überschussstrom vorhanden ist; wenn nicht, dann pausiert er bis genug da ist.
                                  Pausieren geht übrigens bestens, aber bisher gelingt es mir nur per APP den Spülgang fortzusetzen. Ich habe probiert erneut die Pause Funktion zu aktivieren - geht nicht, alternativ die Start-Funktion, geht auch nicht. Dann habe ich eine relative Startzeit von einer Minute eingestellt und dann die Start-Funktion getriggert, leider auch erfolglos.
                                  Habt ihr da schon Erfahrungen mit anderen Geräten gemacht?
                                  • J JoergH
                                    @oberfragger
                                    timbo
                                    #337
                                    Moin,
                                    ich nutze den Adapter noch nicht so lange, aber es häufen sich momentan folgende Fehlermeldungen:
                                    mielecloudservice.0 2021-05-22 11:53:14.493 error --- property 'socket' closes the circle] |-> JSON.stringify(error):{}
                                    mielecloudservice.0 2021-05-22 11:53:14.493 error | property '_httpMessage' -> object with constructor 'ClientRequest'
                                    mielecloudservice.0 2021-05-22 11:53:14.493 error --> starting at object with constructor 'TLSSocket'
                                    mielecloudservice.0 2021-05-22 11:53:14.493 error (10930) [refreshMieleData] [TypeError: Converting circular structure to JSON
                                    mielecloudservice.0 2021-05-22 11:53:14.492 error (10930) The request was made but no response was received:
                                    mielecloudservice.0 2021-05-22 11:53:14.491 error at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:66:26)
                                    mielecloudservice.0 2021-05-22 11:53:14.491 error (10930) [APISendRequest] {"message":"getaddrinfo ENOTFOUND api.mcs3.miele.com","name":"Error","stack":"Error: getaddrinfo E
                                    Hat das noch jemand oder eine Idee wo es dran liegen könnte?
                                    Gruß Timo
                                    • T timbo
                                      Moin,
                                      Gruß Timo
                                      GrizzelbeeG Offline
                                      GrizzelbeeG Offline
                                      Grizzelbee
                                      #338
                                      Moin!
                                      @timbo sagte in MieleCloudService Adapter:
                                      Für mich sieht das ein bisschen danach aus, als hättest du deinem Adccount noch keine Geräte zugeordnet.
                                      "[refreshMieleData]" ist der regelmäßige Refresh der Daten von Miele (alle x Minuten, je nachdem was du in der Config eingestellt hast. Und wenn der sagt: "The request was made but no response was received" klingt das für mich danach, als wären dem Account keine Geräte zugeordnet. Aber das ist nur ein Schuss ins Blaue. Zumindest bist du der Erste, der über dieses Problem klagt.
                                      Poste mal ein Debug-Log (vom Start des Adapters bis mindestens zum Fehler, gerne großzügig) - dann kann ich vielleicht mehr sagen.
                                      Kühlt die Maschine dann nicht kmplett aus und muss wieder aufgeheizt werden? Oder wird die die ganze Zeit auf Temperatur gehalten?
                                      T J 2 Antworten Letzte Antwort
                                        Moin!
                                        timbo
                                        #339
                                        @grizzelbee Wir haben momentan erst ein Gerät im Adapter, ich habe mal den Biobroker neu gestartet und beobachte das Log weiter :) Falls die Meldung weiter auftaucht, melde ich mich.
                                        Danke & Gruß Timo
                                          Moin!
                                          JoergH
                                          #340
                                          @grizzelbee said in MieleCloudService Adapter:
                                          Naja, in der Regel schaltet meine Frau die Maschine morgens nach dem Frühstück ein und dann ist manchmal nicht genug Strom da, besonders nicht, wenn auch schon die E-Autos laden, also kommt es nicht zum Aufheizen, sondern er pausiert gleich, bis genug da ist. Dass er die Maschine immer heiß hält kann ich mir nicht vorstellen, habe es aber noch nicht getestet. Bisher ist es mir einmal gelungen sie auch wieder starten zu lassen, aber ich hatte einfach auch keine Zeit bisher um das richtig durch zu testen.
