  4. Test Adapter OpenLigaDB
adapteropenligadbtest
716 Beiträge 59 Kommentatoren 232.5k Aufrufe 52 Beobachtet
  • S stefande
    @skokarl sagte in Test Adapter OpenLigaDB v0.0.x:
    nur die Icons Trend sehe ich in der Tabelle nicht.
    Hast du das neue Widget genommen und den Haken bei showtrend gesetzt?
    skokarl
    schrieb am zuletzt editiert von skokarl
    #281
    @stefande
    Haken übersehen .... gucke nachher nochmal
    edit: das Problem sitzt immer davor 😬
    • M Online
      M Online
      michihorn
      #282
      Hallo
      hab gerade auf die neuen Widgets umgestellt, Table 3 ist ok, GameDay zeigt im "edit" alles an, in der Runtime Ansicht nichts.
      Kann jemand mal das Widget laden?
      [{"tpl":"tplOLiDBGameDay","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","maxicon":"25","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"allmatches_oid":"openligadb.0.bl1.2019.allmatches","currgameday_oid":"openligadb.0.bl1.2019.currgameday","showgameday":"{javascript.0.BVB.Spieltag_anzeigen}","shortname":true,"showgoals":false,"showweekday":true},"style":{"left":"926px","top":"260px","z-index":"70"},"widgetSet":"openligadb"}]
      Michael
      • M michihorn
        Hallo
        Michael
        OliverIOO Offline
        OliverIOO Offline
        OliverIO
        #283
        @michihorn sagte in Test Adapter OpenLigaDB v0.0.x:
        Was steht bei dir im datenpunkt javascript.0.BVB.Spieltag_anzeigen drin.
        Meine Adapter und Widgets
        Links im Profil
        M S 2 Antworten Letzte Antwort
        • OliverIOO OliverIO
          M Online
          M Online
          michihorn
          #284
          @OliverIO Ich habe den EIntrag entfernt bleibt aber trotzdem in der Runtime Ansicht leer
          • M michihorn
            M Online
            M Online
            michihorn
            #285
            Ohh sorry die View hat etwas länger gebraucht um sich zu aktualisieren
              skokarl
              #286
              @OliverIO
              Du machst alles richtig ..... 😁
                Neue Version 0.11.0
                Hier gibt es ein größeres Update.
                Die letzten Wünsche wurden umgesetzt.
                Ich bitte um rege Rückmeldung von euren Tests.
                die Dokumentation ist noch nicht mit den neuen widgets und Funktionen erweitert worden.
                Was ist hier alles neues enthalten:
                • Aufgrund von Rückwärtskompatibilität gibt es nun ein neues widgets namens Table 3. Bitte alle umstellen, da ich die alten tables (1 und 2) nach und nach löschen werden. table 1 gibt nun direkt einen Hinweis aus
                • Bei table 3 kann man nun die Tabelle für einen bestimmten Spieltag berechnen lassen
                • Weiterhin kann man die Berechnung auf eine bestimmte Anzahl von Spieltagen begrenzen (Beispiel: Tabelle für Spieltag 10, aber nur für die letzten 5 Spieltage, also Tag 6-10). Gibt man bei Speiltag nichts ein, dann wird automatisch vom aktuellen Spieltag ausgegangen. Gibt man in lastgamecount nichts ein, dann werden alle bis dahin aufgelaufene spieltage in die Berechnung einbezogen.
                • Die Tabelle kann nun optional mit Trendindikatoren (up,down, level) angezeigt werden. Wem meine grafiken nicht gefallen, kann links zu eigenen konfigurieren.
                • Erweiterung des widgets tabelle. Über den Modus kann nun eingestellt werden, ob diese nur für die Vorrunde (round1) oder nur Rückrunde (round2) angezeigt werden soll.
                • Neues Widget für die Torschützen (goalgetter) mit Sortierfunktion nach Name oder Toren. Da die zugrundeliegenden Namensangaben grauenhaft sind, habe ich versucht die nach Vornamen und Nachnamen zu normalisieren. Fehler dazu bitte melden. Besser noch, die Daten bei openligadb korrigieren. Weiterhin habe ich das gefühl, das die Daten bei openligadb nicht vollständig sind.
                • Neues widget Kreuztabelle (pivottable): Hier werden alle Ergebnisse der Mannschaften in Kreuztabellenform dargestellt.
                bommel_030
                schrieb am zuletzt editiert von bommel_030
                #287
                @OliverIO
                Bei dem Spieltag steige ich wohl besser auf Hallen-Halma oder so um... Soll ja auch spannend sein...
                Hab das Update eingespielt und die Widgets mal aktualisiert. Was mir dabei aufgefallen ist:
                • Kann man der goalgetter Tabelle Überschriften spendieren?
                • Ein Higlight eines (oder mehrerer ?!?) Favoriten wäre nett. (Eigentlich egal, meine werden da eh nie auftauchen :-P)
                • Die Kreuztabelle wird nach dem aktuellen bzw. gewähltem Spieltag aufgebaut. Schön wäre es diese alpahbetisch zu sortieren und als Sahnehäubchen den Favoritenverein ganz oben.
                • Bei den alten Widgets konnte ich den Spieltag über ein Binding in der VIS direkt ändern. Beim Spieltag funktioniert das auch weiterhin noch, bei der neuen Kreuztabelle und dem aktuellen tabellenwidget muss ich erst ein reload durchführen.
                Anonsten vielen Dank für die super Arbeit!
                Edit:
                Wenn ich in der Torschützenliste die Anzahl der angezeigten Torschützen über ein Binding anspreche
                {0_userdata.0.Fontane.VIS.Bundesliga.anzahl_goalgetter}
                ist das Widget im Editor leer. In der Runtime wird die Liste angezeigt und reagiert auch ohne reload auf eine Änderung der Anzahl.
                Ist das ein Bug oder bin ich der Bug?
                S OliverIOO 2 Antworten Letzte Antwort
                • B bommel_030
                  @OliverIO
                  Edit:
                  stimezo
                  Forum Testing
                  #288
                  @bommel_030 sagte in Test Adapter OpenLigaDB v0.0.x:
                  Du bist der Bug :-)
                  Bindings werden nur in der Runtime angezeigt.
                  Christian
                    mumurik
                    #289
                    @OliverIO
                    bekomme nach Installation folgende Fehlermeldung beim Versuch den Adapter auf einem Iobroker-Slave zu starten:
                    Der Adapter bleibt rot.
                    Auf dem Iobroker-Master funktioniert dagegen alles einwandfrei...keine Fehlermeldung im Log und wird grün.
                    • M mumurik
                      @OliverIO
                      OliverIOO Offline
                      OliverIOO Offline
                      OliverIO
                      #290
                      @mumurik zu master slave Installationen habe ich null Ahnung.
                      ich habe keine besondere Anforderung an Admin, außer evtl dass darüber die Konfiguration des Adapters erfolgt. warum das auf einem Slave nicht funktioniert weiß ich nicht. ich glaube da musst du mal bei den master-slave Spezialisten nachfragen. wenn es dann eine Anforderung gibt, die ich noch beachten muss, dann gerne. Aktuell ist mir keine bekannt.
                      Links im Profil
                        Saschag
                        #291
                        Super Adapter! Danke OliverIO
                        Bei mir wird im Editor die nächsten Spiele vom Fav. angezeigt und im RunTime nicht.
                        Nutze „View in View“ kann dies damit zusammen hängen oder hat jemand eine Idee?
                        • S Saschag
                          Saschag
                          #292
                          Fehler gefunden😂 falsches Binding 🤨
                          • B bommel_030
                            @OliverIO
                            Edit:
                            OliverIOO Offline
                            OliverIOO Offline
                            OliverIO
                            #293
                            @bommel_030
                            Ich melde mich mal kurz dazwischen.
                            Es wird weiter gehen, ich denke ich komm nächste Woche dazu ein paar weitere Dinge umzusetzen.
                            Links im Profil
                            B 1 Antwort Letzte Antwort
                              @bommel_030
                              bommel_030
                              #294
                              @OliverIO
                              Kein Stress... Verzweifel gerade eh mal wieder an den CSS Anweisungen ;-)
                              Wenn du dann mal wieder weitermachst, kannst du beim "Games of Favorite"-Widget die Jahreszahl (optional) entfernen?
                              Für die aktuelle Saison kann ich mir durchaus merken wann das nächste Spiel ist und in der responsive Version auf dem Handy ist das nur unnötig mit scrollen verbunden.
                              • OliverIOO Offline
                                OliverIOO Offline
                                OliverIO
                                #295
                                Neue Version 0.11.1
                                Folgendes hat sich verändert:
                                • Das aktualisieren der widgets wurde repariert (hoffe ich, bitte testen, das war ein größerer eingriff)
                                • Die Torschützentabelle (goalgetters) hat nun Überschriften erhalten (Die Datenqualität ist aber immer noch schlecht), darüber hinaus kann man nun auch hier Favoriten wählen (mit Semikolon getrennt), sowie auch nur genau diese anzeigen lassen
                                • Das widget Kreuztabelle (pivottable) hat eine weitere Sortieroption nach Namen erhalten. Ausserdem kann man nun wählen, ob die Favoritenteams ganz oben angezeigt werden.
                                • Die Jahreszahl wurde bei einigen widgets aus dem Datum entfernt
                                Die widget Hilfe für die neuen widgets und Einstellungen fehlt noch immer :)
                                Links im Profil
                                  Neue Version 0.11.1
                                  bommel_030
                                  #296
                                  @OliverIO
                                  Hab mir das Update gerade mal angeschaut. Zum aktualisieren der Widgets kann ich noch nichts endgültiges sagen.
                                  Torschützenliste mit Highlight funktioniert. Ein Bug ist glaube ich noch drin. Wenn ich nach Toren sortiere und mir nur die Highlights anzeigen lasse ist die Liste leer.
                                  Gleiche Einstellung mit Sortierung Name funktioniert.
                                  Sortierung Kreuztabelle nach Name / Tabelle funktioniert auch, solange man nicht Favorit oben wählt. Dann kommt das raus:
                                  Nichts gegen Paderborn, aber die sind nicht Nr. 1 und Highlight ist farblich anders hervorgehoben.
                                  Jahreszahl, super, danke.
                                  • OliverIOO Offline
                                    OliverIOO Offline
                                    OliverIO
                                    #297
                                    Neue Version 0.11.2
                                    2 behobene Fehler bei dem Torschützen widget goalgetter und der Kreuztabelle pivottable
                                    Links im Profil
                                      bommel_030
                                      #298
                                      @OliverIO
                                      Goalgetter Widget funktioniert jetzt fehlerfrei.
                                      Sortierung der Kreuztabelle funktioniert jetzt dauerhaft, egal ob highlight on top aktiviert ist oder nicht.
                                      Highlight on top hat keine Auswirkungen bei mir. Alle Kombinationen Sortierung/Shortname/highlight durchprobiert.
                                      Der favorisierte Verein steht immer nur an seinem Platz laut Name / Tabellenstand.
                                      • OliverIOO Offline
                                        OliverIOO Offline
                                        OliverIO
                                        #299
                                        Neue Version 0.11.4
                                        • pivottable: Das Problem mit der fehlerhaften Sortierung wurde behoben (merke: der Index eines strings beginnt bei 0 und nicht bei 1)
                                        • pivottable: Ein Problem mit der Platznummerierung wurde behoben
                                        Links im Profil
                                          Neue Version 0.11.4
                                          bommel_030
                                          #300
                                          @OliverIO
                                          Sauber, mir sind keine "Fehler" mehr aufgefallen. Beruhigt mich, dass auch Profis die 0 mal unterschlagen ;-)
