  4. [Linux Shell-Skript] WLAN-Wetterstation
linuxshell-scriptwetterstationwlan-wetterstation
5.8k Beiträge 156 Kommentatoren 4.6m Aufrufe 137 Beobachtet
  • BoronsbruderB Boronsbruder
    @SBorg
    2021-11-01 01:03:00.017 - debug: javascript.0 (2938) sendTo "query" to system.adapter.influxdb.0 from system.adapter.javascript.0: select * FROM "0_userdata.0.Wetterstation.Aussentemperatur" WHERE time >= 1604185200000000000 AND time <= 1606777199000000000; select * FROM "0_userdata.0.Wetterstation.Wind_max" WHERE time >= 1604185200000000000 AND time <= 1606777199000000000; select * FROM "0_userdata.0.Wetterstation.Regen_Tag" WHERE time >= 1604185200000000000 AND time <= 1606777199000000000
    2021-11-01 01:03:00.086 - warn: javascript.0 (2938) You are assigning a string to the state "0_userdata.0.Statistik.Wetter.Data.2021.10" which expects a object. Please fix your code to use a object or change the state type to string. This warning might become an error in future versions.
    2021-11-01 01:03:00.091 - warn: javascript.0 (2938) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1439:20)
    2021-11-01 01:03:00.092 - warn: javascript.0 (2938) at Immediate._onImmediate (script.js.common.Wetterstation_Statistik:346:169)
    2021-11-01 01:03:00.092 - warn: javascript.0 (2938) at processImmediate (internal/timers.js:463:21)
    2021-11-01 01:03:00.093 - info: javascript.0 (2938) Could not parse value for id 0_userdata.0.Statistik.Wetter.Data.2021.10 into object: Unexpected end of JSON input
    2021-11-01 01:03:00.095 - info: javascript.0 (2938) Could not parse value for id 0_userdata.0.Statistik.Wetter.Data.2021.10 into object: Unexpected end of JSON input
    Schreit dein Statistikskript bei mir rum 🤣
    SBorgS Offline
    SBorgS Offline
    SBorg
    #3061
    @boronsbruder Zum Glück nur einmalig am Monats ersten ;)
    Zumindest ließt er korrekt die Vorjahres-Monatswerte ein und speichert die aktuellen ab.
    Trotzdem sollte das natürlich nicht sein, gerade in der Hinsicht wie lange der falsche Typ noch toleriert wird...
    Ich muss das mal in einer ruhigen Minute (=also nie 😁 ) simulieren, denn jetzt einfach den Typ ändern führt bestimmt an anderer Stelle wieder zu Problemen...
    LG SBorg ( SBorg auf GitHub)
    V 1 Antwort Letzte Antwort
    • SBorgS SBorg
      V Offline
      V Offline
      viper4iob
      #3062
      @sborg
      Danke für das letzte Update.
      Im Syslog ist es jetzt ruhig und der Datentyp des Batteriedatenpunkts vom DP50 passt jetzt auch 👍
      • SBorgS Offline
        SBorgS Offline
        SBorg
        #3063
        Da keine offensichtlichen Fehler zu verzeichnen sind und wetter.com anscheinend auch keine Zeitumstellung ihres Servers vornimmt und weiterhin pauschal eine Stunde abzieht:
        Neues Release des Wetterstation WLAN-Skriptes auf GitHub V2.10.0
        • ~ Bugfix Option '--data' bei Ecowitt-Protokoll
        • ~ Passkey bei Nutzung des Ecowitt-Protokolls maskieren
        • + logging des Datenstrings der Wetterstation in eine Datei
        • + Unterstützung für DP40/WH32 (bzw. WH26) Sensor
        • + Unterstützung für DP300/WS68 Sensor
        • + Unterstützung für WH31 (bzw. WH25) Sensor
        • + netcat-/Success-Meldungen im Syslog entfernt
        • + Patch Sommer-/Winterzeit für wetter.com
        Wie immer zu finden im GitHub
        Update-Routine:
        • wetterstation.sh und wetterstation.sub ersetzen
        • wetterstation.js muss ebenfalls im JavaScript-Adapter ersetzt und einmalig ausgeführt werden (neue Datenpunkte der Batteriestände für die neuen Sensoren; kann ggf. entfallen falls man diese nicht nutzt/später mal nutzen möchte)
        • ./ws_updater.sh --patch im Installationsverzeichnis ausführen
        • nun mittels systemctl restart wetterstation den Service neu starten
        Mutige können auch mal direkt den Updater probieren ;) 👍
        Im Installationsverzeichnis ausführen: bash <(curl -s https://raw.githubusercontent.com/SBorg2014/WLAN-Wetterstation/master/ws_updater.sh)
        Wer bereits die letzte Beta-Version der V2.10.0 nutzt sollte ggf. trotzdem updaten (hier genügt der Tausch der "sub" und "sh" und den Service neu zu starten). Das Beta-Release ist mit dieser Release-Version nicht identisch. Beim Beta-Release fehlt der Patch für die Sommer-/Winterzeit bei wetter.com
        • NegaleinN Offline
          NegaleinN Offline
          Negalein
          #3064
          @sborg sagte in [Linux Shell-Skript] WLAN-Wetterstation:
          zeigt mir einen Fehler
          dietpi@DietPi:/home/iobroker$ ./ws_updater.sh --patch
           │   WS-Updater V2.10.0  │
           Soll die wetterstation.conf nun auf eine neue Version gepatcht werden? [J/N]: J
           Lege Sicherungskopie der wetterstation.conf an...
           Patche wetterstation.conf auf V2.10.0 ...
          ./ws_updater.sh: Zeile 248: patch: Kommando nicht gefunden.
           Fertig...
           Eventuelle Zusatzsensoren DP300/WS68, DP40/WH32 oder WH25/WH31 müssen eingetragen werden!
          ° Fixer ---> iob fix
          • NashraN Offline
            NashraN Offline
            Nashra
            Most Active Forum Testing
            #3065
            Moin, alles sauber 👍
            root@ioBroker:/home/iobroker# ./ws_updater.sh --patch
             Soll die wetterstation.conf nun auf eine neue Version gepatcht werden? [J/N]: j
            patching file ./wetterstation.conf
            Hunk #1 succeeded at 1 with fuzz 2.
             Fertig...
            Link nach Github ist gut 😁 👍
            Gruß Ralf
            Mir egal, wer Dein Vater ist! Wenn ich hier angel, wird nicht übers Wasser gelaufen!!
            • NegaleinN Negalein
               Fertig...
              SBorgS Offline
              SBorgS Offline
              SBorg
              schrieb am zuletzt editiert von SBorg
              #3066
              @negalein sagte in [Linux Shell-Skript] WLAN-Wetterstation:
              Auf deinem DietPi ist mal so gar nichts installiert... ;)
              Muss ich also auch noch prüfen.
              Nachinstallieren:
              sudo apt install patch
              • NashraN Nashra
                 Fertig...
                SBorgS Offline
                SBorgS Offline
                SBorg
                #3067
                @nashra sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                So langsam wird es 😂
                NashraN 1 Antwort Letzte Antwort
                • SBorgS SBorg
                  NashraN Offline
                  NashraN Offline
                  Nashra
                  schrieb am zuletzt editiert von Nashra
                  #3068
                  Jow und hier hatte ich mich verlesen worauf meine Frau lachen mußte
                  Hunk #1 succeeded at 1 with furz 2.
                  Brauch ne neue Brille 😂
                  Gruß Ralf
                  • SBorgS SBorg
                    Nachinstallieren:
                    NegaleinN Offline
                    NegaleinN Offline
                    Negalein
                    #3069
                    da hast du recht 😂
                    ist nur die 0815 Variante ;)
                    Nachinstallieren
                    Ahhh, auf das hätt ich auch selber kommen müssen
                    • Rene55R Offline
                      Rene55R Offline
                      Rene55
                      #3070
                      @SBorg Muss ich, auch wenn ich die aktuellsten Files im Verzeichnis habe, den ./ws_updater.sh --patch laufen lassen? Was macht der genau?
                      Ich habe gerade mal den Link probiert - bringt bei mir "Version bereits aktuell". Die Dateien sind vom 25.10., können eigentlich den Weather-Patch noch nicht enthalten.
                      Host: Fujitsu Intel(R) Pentium(R) CPU G4560T, 32 GB RAM, Proxmox 8.x + lxc Ubuntu 22.04
                      ioBroker (8 GB RAM) Node.js: 20.19.1, NPM: 10.8.2, js-Controller: 7.0.6, Admin: 7.6.3
                      Wetterstation: Froggit WH3000SE V1.6.6
                      • NashraN Nashra
                        SBorgS Offline
                        SBorgS Offline
                        SBorg
                        #3071
                        ...oder weniger Bohnensuppe essen 💩
                        Wald, Bäume, und so... 😇
                        Macht aber nix, man kann ja nicht alles wissen bzw. sehen, und eben eine neue Version hochgeladen, die nun prüft ob 'patch' installiert ist. Also alles wird gut 😊
                        • Rene55R Rene55
                          SBorgS Offline
                          SBorgS Offline
                          SBorg
                          #3072
                          @rene55 Nein, brauchst du nicht. Es passiert aber auch nichts wenn man es trotzdem versucht. Dann kommt eben besagte Meldung "Version bereits aktuell".
                          Im Grunde ist das System so aufgebaut:
                          • sh = das eigentliche Programm
                          • sub = enthält eigene Befehle/Funktionen für die sh
                          • conf = die User spezifischen Einstellungen
                          "sh" und "sub" enthält nichts vom User, kann also einfach ausgetauscht werden. Dies galt Anfangs auch für die "conf". Eine handvoll Einträge wieder übernehmen war schnell erledigt (aber schon da nicht gerade komfortabel). Mit der Zeit, und gerade seit OpenSenseMap und Windy, wäre das aber echt k*cke alles jedes mal neu einzutragen. Daraus entstand der "ws_updater".
                          Der kann nun
                          • das Projekt komplett installieren
                          • den Service dazu einrichten
                          • das Update auf die aktuelle Release-Version durchführen (Beta aus Sicherheitsgründen weiter nur händisch)
                          • und die "conf" patchen
                          Du willst bspw. von V2.9.0 auf V2.10.0 updaten und hast die "sh", "sub" und den "ws_updater" ersetzt, dann fehlen dir aber die Änderungen in der "conf" von V2.9.0 (eigentlich V2.8.0, denn eine V2.9.0-conf gab es nicht ;) ) --> V2.10.0
                          Genau das macht die Option "--patch". Im konkreten Fall die Versionsnummer der "conf" auf V2.10.0 ändern, den Kommentar und den logging-Parameter hinzufügen und die (mögliche) Anzahl der drei neuen Sensoren in der Liste der Sensoren ergänzen.
                          XxJooOX 1 Antwort Letzte Antwort
                          • SBorgS SBorg
                            Der kann nun
                            XxJooOX Offline
                            XxJooOX Offline
                            XxJooO
                            schrieb am zuletzt editiert von XxJooO
                            #3073
                            @sborg ,
                            eigentlich suche ich Jemanden mit ausreichend guten Javascript-Kenntnissen, der mir bei meinem Problem kurz helfen kann:
                            Meine Station gibt hin und wieder unplausible Werte ab, wie z.B. "Aussenfeuchtigkeit" ist -9999%. Diese Werte werden dann in die influxDB geschrieben und führen dann zu hässlichen Grafiken. Ich habe nun einiges zusammen gesucht und das folgende Script geschrieben. Insgesamt sind 5 Wertereihen betroffen.
                            Influx wird aufgefordert:
                            • erstelle eine neue Wertereihe, nimm dabei alle Werte aus der alten Reihe , die größer oder kleiner als ein bestimmter Wert sind und schreibe diese in die neue Reihe
                            • lösch die alte Reihe
                            • schreib die Werte aus der neuen Reihe in die Reihe mit dem alten Namen
                            • lösch die neue Reihe
                            Wenn ich die Schritte einzeln als Script ausführen lasse, dann funktioniert das. In meinem Script aber kommt es zu einem Absturz von influx. Was könnte ich ändern, um das Script lauffähig zu bekommen?
                            Vielen Dank
                            XxJooO
                            main();
                            function main () {
                                console.log("Korrigiere Aussenfeuchtigkeit")
                                sendTo('influxdb.0', 'query', 'SELECT * INTO iobroker.global."0_userdata.0.Wetterstation.Aussenfeuchtigkeit_clean" FROM iobroker.global."0_userdata.0.Wetterstation.Aussenfeuchtigkeit" WHERE value>0 GROUP BY *');
                                sendTo('influxdb.0', 'query', 'DROP measurement "0_userdata.0.Wetterstation.Aussenfeuchtigkeit"');
                                sendTo('influxdb.0', 'query', 'SELECT * INTO "0_userdata.0.Wetterstation.Aussenfeuchtigkeit" FROM "0_userdata.0.Wetterstation.Aussenfeuchtigkeit_clean" GROUP BY *');
                                sendTo('influxdb.0', 'query', 'DROP SERIES FROM "0_userdata.0.Wetterstation.Aussenfeuchtigkeit_clean"');
                                console.log("Korrigiere Aussentemperatur")
                                sendTo('influxdb.0', 'query', 'SELECT * INTO iobroker.global."0_userdata.0.Wetterstation.Aussentemperatur_clean" FROM iobroker.global."0_userdata.0.Wetterstation.Aussentemperatur" WHERE value>-50 GROUP BY *');
                                sendTo('influxdb.0', 'query', 'DROP measurement "0_userdata.0.Wetterstation.Aussentemperatur"');
                                sendTo('influxdb.0', 'query', 'SELECT * INTO "0_userdata.0.Wetterstation.Aussentemperatur" FROM "0_userdata.0.Wetterstation.Aussentemperatur_clean" GROUP BY *');
                                sendTo('influxdb.0', 'query', 'DROP SERIES FROM "0_userdata.0.Wetterstation.Aussentemperatur_clean"');
                                console.log("Korrigiere Regen_Tag")
                                sendTo('influxdb.0', 'query', 'SELECT * INTO iobroker.global."0_userdata.0.Wetterstation.Regen_Tag_clean" FROM iobroker.global."0_userdata.0.Wetterstation.Regen_Tag" WHERE value<30 GROUP BY *');
                                sendTo('influxdb.0', 'query', 'DROP measurement "0_userdata.0.Wetterstation.Regen_Tag"');
                                sendTo('influxdb.0', 'query', 'SELECT * INTO "0_userdata.0.Wetterstation.Regen_Tag" FROM "0_userdata.0.Wetterstation.Regen_Tag_clean" GROUP BY *');
                                sendTo('influxdb.0', 'query', 'DROP SERIES FROM "0_userdata.0.Wetterstation.Regen_Tag_clean"');
                                console.log("Korrigiere Sonnenstrahlung")
                                sendTo('influxdb.0', 'query', 'SELECT * INTO iobroker.global."0_userdata.0.Wetterstation.Sonnenstrahlung_clean" FROM iobroker.global."0_userdata.0.Wetterstation.Sonnenstrahlung" WHERE value>0 GROUP BY *');
                                sendTo('influxdb.0', 'query', 'DROP measurement "0_userdata.0.Wetterstation.Sonnenstrahlung"');
                                sendTo('influxdb.0', 'query', 'SELECT * INTO "0_userdata.0.Wetterstation.Sonnenstrahlung" FROM "0_userdata.0.Wetterstation.Sonnenstrahlung_clean" GROUP BY *');
                                sendTo('influxdb.0', 'query', 'DROP SERIES FROM "0_userdata.0.Wetterstation.Sonnenstrahlung_clean"');
                                console.log("Korrigiere Wind_max")
                                sendTo('influxdb.0', 'query', 'SELECT * INTO iobroker.global."0_userdata.0.Wetterstation.Wind_max_clean" FROM iobroker.global."0_userdata.0.Wetterstation.Wind_max" WHERE value>0 GROUP BY *');
                                sendTo('influxdb.0', 'query', 'DROP measurement "0_userdata.0.Wetterstation.Wind_max"');
                                sendTo('influxdb.0', 'query', 'SELECT * INTO "0_userdata.0.Wetterstation.Wind_max" FROM "0_userdata.0.Wetterstation.Wind_max_clean" GROUP BY *');
                                sendTo('influxdb.0', 'query', 'DROP SERIES FROM "0_userdata.0.Wetterstation.Wind_max_clean"');
                            ioBroker auf Intel NUC - Homematic CCU3/pivCCU auf Raspi 3B+
                            Rene55R SBorgS 2 Antworten Letzte Antwort
                            • XxJooOX XxJooO
                              @sborg ,
                              Vielen Dank
                              XxJooO
                              main();
                              function main () {
                              Rene55R Offline
                              Rene55R Offline
                              Rene55
                              #3074
                              @SBorg Danke für die Erklärung. Dann hab ich (wahrscheinlich) alles sauber. Ich hatte bisher immer die Dateien in ein Verzeichnis gelegt, die handvoll eigener Parameter in der .conf geändert und dann einen Container erstellt. Ok, bei der .conf muss man dann ein bisschen aufpassen. Ich werd den updater beim nächsten Versionssprung mal testen. Dann sehe ich vielleicht auch mal ein Hunk #1 succeeded at 1 with furz 2. Danke nochmals - auch bei der wenigen freien Zeit - für das Script und die schnellen Antworten.
                              LG Rainer
                              • XxJooOX XxJooO
                                @sborg ,
                                Vielen Dank
                                XxJooO
                                main();
                                function main () {
                                SBorgS Offline
                                SBorgS Offline
                                SBorg
                                #3075
                                @xxjooo Das ist ein "simples" (aber nicht einfaches) Timeing - Problem. Während der eine sendTo noch arbeitet und die InfluxDB beschäftigt, feuert JS schon den nächsten Befehl ab. Um sicher zugehen, dass er fertig ist könnte man nun eine "Denkpause" von bspw. 1 Sekunde einfügen. Dann bekommst du aber das nächste Timeing-Problem, denn dann ist er noch mit der Abarbeitung dieses Datenpakets beschäftigt, während schon das nächste ansteht.
                                Falls mehrere das Problem haben/hätten, könnte ich auch eine interne Unterdrückung/Begrenzung einbauen wie Temperatur nur von -99°C bis +99°C
                                Das ist aber Zeitverschwendung (im Sinne von Ressourcenverschwendung des Systems) wenn es sonst keiner hat. Ich prüfe dann die Messwerte, obwohl sie zu 99.999% immer richtig sind. Ich hatte in nun bald 2 Jahren keinen einzigen Ausreißer zu verzeichnen.
                                Ich habe es eben mal spaßeshalber gegen gerechnet: das wären bei rund 60(!) Millionen Messwerten und dabei nur 5 Korrekturen trotzdem 12 Millionen zusätzliche Berechnungen für fast nix an Nutzen, zumindest für euch (du mal ausgenommen ;) ). IMO nicht der beste Weg.
                                Ich hätte aber eine andere, recht einfache Idee: die Werte erst gar nicht in die Influx gelangen zu lassen.
                                Nehmen wir als Beispiel mal die Aussentemperatur (folgend AT genannt):
                                • du legst unter javascript/0_userdata.x.tempData (wo du die Daten halt liegen hast) einen neuen Datenpunkt AT an (Bsp.: javascript.0.tempData.Aussentemperatur) / die Einstellungen vom Original übernehmen
                                • in der "sub" (leider dann bei jedem Update weg) änderst du den Eintrag ab wo die AT gespeichert wird
                                     DP_TEMP_AUSSEN=${PRE_DP}.Aussentemperatur
                                     in
                                     DP_TEMP_AUSSEN=${PRE_DP}.tempData.Aussentemperatur
                                • Nun noch ein Blockly/Flow/JS mit Trigger bei Änderung auf "...tempData.Aussentemperatur" und "falls" Wert > -99 und Wert < 99 dann schreibe Wert in den originalen AT-Datenpunkt
                                Somit loggt Influx nur noch korrekte Werte und du kannst auch alles wie gehabt (zB. Statistik-Skript) weiter nutzen.
                                • Rene55R Rene55
                                  LG Rainer
                                  SBorgS Offline
                                  SBorgS Offline
                                  SBorg
                                  #3076
                                  @rene55 sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                                  Trotz aller Widrigkeiten immer gerne.
                                  Ich kann leider nur sagen:
                                  Lächle und sei froh, es könnte schlimmer kommen.
                                  Ich lächelte und ward froh, und es kam schlimmer...
                                  ...aber das lächeln verkneife ich mir trotz allem nicht 🙂
                                  • SBorgS SBorg
                                         in
                                    XxJooOX Offline
                                    XxJooOX Offline
                                    XxJooO
                                    #3077
                                    @sborg ,
                                    vielen Dank für diese Überlegungen. Dein Tipp wird die einfachste Lösung sein. Ich möchte Deine Zeit nicht übermäßig beanspruchen, aber noch eine kleine Nachfrage:
                                    Gibt influxDB keinen Rückwert, wenn eine angeforderte Operation abgeschlossen ist? Das mit dem Timing habe ich mir schon so gedacht. Aber der Rückwert des Aufrufes "sendto" ist "undefined". Man muss doch irgendwie eine Rückmeldung bekommen können?
                                    Danke!!!!
                                    XxJooO
                                    • XxJooOX XxJooO
                                      @sborg ,
                                      Danke!!!!
                                      XxJooO
                                      SBorgS Offline
                                      SBorgS Offline
                                      SBorg
                                      #3078
                                      @xxjooo sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                                      Das ist absolut kein Problem oder Thema, ich komme halt nur nicht immer gleich zu irgendwas, es kann halt etwas dauern und ab und an dauert es auch mal paar Tage bis ich hier wieder Online bin.
                                      Deswegen fragen, nur die Antwort/Lösung dauert halt uU. mal etwas ;)
                                      Kann ich dir so nicht beantworten, dass kommt auf den Influx-Adapter an. Wie hast du denn den Rückgabewert ermittelt? Per CallBack? Wenn da nichts kommt, ist da leider auch nix...
                                      sendTo('influxdb.0', 'query', 'DROP measurement "0_userdata.0.Wetterstation.Aussenfeuchtigkeit"', function (result) { console.log("Influx meldet " + result); });
                                      • SBorgS SBorg
                                        XxJooOX Offline
                                        XxJooOX Offline
                                        XxJooO
                                        #3079
                                        ergibt
                                        javascript.0
                                        2021-11-04 16:30:45.526	info	script.js.Datenpunkte_erstellen.influxdb_korrigieren_test: Influx meldet [object Object]
                                        funktioniert so also nicht.
                                        • XxJooOX XxJooO
                                          ergibt
                                          javascript.0
                                          SBorgS Offline
                                          SBorgS Offline
                                          SBorg
                                          #3080
                                          @xxjooo Es kommt nur mehr zurück als erwartet :)
                                          sendTo('influxdb.0', 'query', 'DROP measurement "0_userdata.0.Wetterstation.Aussenfeuchtigkeit"', function (result) { console.log("Influx meldet " + JSON.stringify(result)); });
