  4. Test Adapter ioBroker.backitup v3.1.x
    1.0k
    6.1k
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 2.7m Aufrufe 113 Beobachtet
  • simatecS simatec
    @BoehserWolf
    Bitte poste mal den Debuglog von Backitup
    BoehserWolf
    #681
    @simatec Gerade manuell ausgeführt. Der Datenpunkt steht weiterhin auf false.
    backitup.0	2020-09-20 12:42:51.127	debug	(32749) system.adapter.admin.0: logging true
    backitup.0	2020-09-20 12:41:47.829	debug	(32749) system.adapter.admin.0: logging false
    backitup.0	2020-09-20 12:41:22.662	debug	(32749) system.adapter.admin.0: logging true
    backitup.0	2020-09-20 12:41:11.453	debug	(32749) [iobroker] exec: done
    backitup.0	2020-09-20 12:41:11.452	debug	(32749) [iobroker] exec: done
    backitup.0	2020-09-20 12:41:11.452	debug	(32749) [iobroker/history] backitup.0.history.json
    backitup.0	2020-09-20 12:41:11.452	debug	(32749) [iobroker/history] backitup.0.history.html
    backitup.0	2020-09-20 12:41:11.446	debug	(32749) [iobroker/clean] done
    backitup.0	2020-09-20 12:41:11.445	debug	(32749) [iobroker/iobroker] done
    backitup.0	2020-09-20 12:41:10.435	debug	(32749) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2020_09_20-12_41_07_iobroker_wald_backupiobroker.tar.gz
    backitup.0	2020-09-20 12:41:08.875	debug	(32749) system.adapter.admin.0: logging false
    backitup.0	2020-09-20 12:41:08.480	debug	(32749) [iobroker/iobroker] host.iobroker 5414 objects saved
    backitup.0	2020-09-20 12:41:08.471	debug	(32749) [iobroker/iobroker] host.iobroker 4997 states saved
    backitup.0	2020-09-20 12:41:07.300	debug	(32749) Backup has started ...
    backitup.0	2020-09-20 12:40:19.566	debug	(32749) No backup file was found
    backitup.0	2020-09-20 12:40:19.565	debug	(32749) [ccu] 10 30 01 */3 * *
    backitup.0	2020-09-20 12:40:19.564	info	(32749) [ccu] backup was activated at 01:30 every 3 day(s)
    backitup.0	2020-09-20 12:40:19.563	debug	(32749) [iobroker] 10 30 03 */1 * *
    backitup.0	2020-09-20 12:40:19.558	info	(32749) [iobroker] backup was activated at 03:30 every 1 day(s)
    backitup.0	2020-09-20 12:40:19.540	info	(32749) starting. Version 1.6.7 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.22.1, js-controller: 3.1.6
    backitup.0	2020-09-20 12:40:19.535	info	(32749) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    backitup.0	2020-09-20 12:40:19.533	debug	(32749) Plugin sentry Initialize Plugin (enabled=true)
    backitup.0	2020-09-20 12:40:19.275	debug	(32749) statesDB connected
    backitup.0	2020-09-20 12:40:19.275	debug	(32749) States connected to redis: 127.0.0.1:9000
    backitup.0	2020-09-20 12:40:19.273	debug	(32749) States create System PubSub Client
    backitup.0	2020-09-20 12:40:19.272	debug	(32749) States create User PubSub Client
    backitup.0	2020-09-20 12:40:19.270	debug	(32749) Redis States: Use Redis connection: 127.0.0.1:9000
    backitup.0	2020-09-20 12:40:19.269	debug	(32749) objectDB connected
    backitup.0	2020-09-20 12:40:19.267	debug	(32749) Objects connected to redis: 127.0.0.1:9001
    backitup.0	2020-09-20 12:40:19.263	debug	(32749) Objects client initialize lua scripts
    backitup.0	2020-09-20 12:40:19.263	debug	(32749) Objects create User PubSub Client
    backitup.0	2020-09-20 12:40:19.263	debug	(32749) Objects create System PubSub Client
    backitup.0	2020-09-20 12:40:19.261	debug	(32749) Objects client ready ... initialize now
    backitup.0	2020-09-20 12:40:19.249	debug	(32749) Redis Objects: Use Redis connection: 127.0.0.1:9001
    • L Offline
      ltsalvatore
      #682
      hallo zusammen,
      kurze frage..
      mir wurde empfohlen, mein anliegen in diesem thread zu posten...
      ich bin aktuell auf der version 0.1.6 von dem whatsapp-cmb.0 adapter und wollte den adapter benutzen um mich benachrichtigen zu lassen, wenn backitup kein backup erstellen konnte.
      in dem whatsapp-cmb.0 habe ich soweit alles eingerichtet wie auf dem bild unten zu sehen incl. des api keys, welches ich per whatsapp bekommen hatte.
      in dem backitup.0 adapter habe ich soweit auch alles aktiviert
      doch leider kommt nichts bei mir an..mittlerweile sind schon ein paar stündchen vergangen...
      wenn ich eine test nachricht verschicke über
      https://api.callmebot.com/whatsapp.php?phone=[phone_number]&text=[message]&apikey=[your_apikey]
      funktioniert es einwandfrei...
      kann es sein, dass der backtitup adapter das noch nicht sauber integriert hat bzw. in der aktuellesten version 1.6.7 ein problem hat?
      • L ltsalvatore
        hallo zusammen,
        kurze frage..
        simatecS Offline
        simatecS Offline
        simatec
        #683
        @ltsalvatore sagte in Test Adapter Backitup v1.6.x:
        Da du in den Einstellungen das Häkchen "Benachrichtigung nur bei Fehlern" aktiv hast, kommt auch nur eine Meldung bei Fehlern.
        • Besuche meine Github Seite
        • HowTo Restore ioBroker
        L 1 Antwort Letzte Antwort
        • simatecS simatec
          ltsalvatore
          schrieb am zuletzt editiert von ltsalvatore
          #684
          @simatec sagte in Test Adapter Backitup v1.6.x:
          hi simatec
          ich habe sowohl mit als auch ohne dieser option getestet.
          ich habe auch absichtlich ein fehler in den einstellungen gesetzt um entsprechend ein fehler zu simulieren.
          • L ltsalvatore
            hi simatec
            simatecS Offline
            simatecS Offline
            simatec
            #685
            @ltsalvatore
            Dann teste, ob deine Einstellungen im Whatsapp Adapter korrekt sind und schicke dir Testnachrichten aus iobroker (Blockly oder Javascript)
            Backitup verwendet am Ende die gleichen Funktionen ...
            Ansonsten bitte debuglog schicken
            • simatecS simatec
              @ltsalvatore
              ltsalvatore
              #686
              @ltsalvatore
              hi simatec,
              über blockly und objekt "send message" funktioniert es einwandfrei.
              ich habe dann diverse male getestet und es scheint wohl tatsächlich daran zu liegen, was man beim backitup adapter als benachrichtigungsstil auswählt.
              wenn ich "kurze benachrichtigungen" wähle, dann kommen die messages sofort an.
              wähle ich stattdessen "lange benachrichtigungen" kommt nichts an...
              mir reicht im endeffekt die kurze benachrichtigung vollkommen aus... sollte sich doch jemand das ganze noch mal im detail anschauen wollen hier das log file:
              whatsapp-cmb.0	2020-09-22 22:56:19.396	debug	(29603) system.adapter.admin.0: logging true
              whatsapp-cmb.0	2020-09-22 22:53:27.906	debug	(29603) system.adapter.admin.0: logging false
              whatsapp-cmb.0	2020-09-22 22:50:24.653	debug	(29603) <p>Message to: +491799700000<p>Text to send: BackItUp:%0AEin neues iobroker Backup wurde am 22. September 2020 um 22:50 Uhr erstellt.<p><b>Message queued.</b> You will receive it in a few sec
              whatsapp-cmb.0	2020-09-22 22:50:24.388	debug	(29603) Call https://api.callmebot.com/whatsapp.php?phone=+491799700000&text=BackItUp%3A%0AEin%20neues%20iobroker%20Backup%20wurde%20am%2022.%20September%202020%20um%2022%3A50%20Uhr%20erstellt.&apike
              whatsapp-cmb.0	2020-09-22 22:50:24.388	info	Ein neues iobroker Backup wurde am 22. September 2020 um 22:50 Uhr erstellt. to +491799700000
              whatsapp-cmb.0	2020-09-22 22:50:24.388	info	(29603) Send BackItUp:
              whatsapp-cmb.0	2020-09-22 22:48:55.316	debug	(29603) system.adapter.admin.0: logging true
              whatsapp-cmb.0	2020-09-22 22:48:41.649	debug	(29603) system.adapter.admin.0: logging false
              whatsapp-cmb.0	2020-09-22 22:47:24.706	debug	(29603) <p>Message to: +491799700000<p>Text to send: BackItUp:%0AEin neues iobroker Backup wurde am 22. September 2020 um 22:47 Uhr erstellt, und unter //192.168.111.100/"prv\Salva\P1\Backups\Server\
              whatsapp-cmb.0	2020-09-22 22:47:24.504	debug	(29603) Call https://api.callmebot.com/whatsapp.php?phone=+491799700000&text=BackItUp%3A%0AEin%20neues%20iobroker%20Backup%20wurde%20am%2022.%20September%202020%20um%2022%3A47%20Uhr%20erstellt%2C%20u
              whatsapp-cmb.0	2020-09-22 22:47:24.504	info	Ein neues iobroker Backup wurde am 22. September 2020 um 22:47 Uhr erstellt, und unter //192.168.111.100/"prv\Salva\P1\Backups\Server\Smarthome\iobroker\minimal" gespeichert. to +491799700000
              whatsapp-cmb.0	2020-09-22 22:47:24.504	info	(29603) Send BackItUp:
              whatsapp-cmb.0	2020-09-22 22:44:24.815	debug	(29603) <p>Message to: +491799700000<p>Text to send: BackItUp:%0AEin neues iobroker Backup wurde am 22. September 2020 um 22:44 Uhr erstellt.<p><b>Message queued.</b> You will receive it in a few sec
              whatsapp-cmb.0	2020-09-22 22:44:24.502	debug	(29603) Call https://api.callmebot.com/whatsapp.php?phone=+491799700000&text=BackItUp%3A%0AEin%20neues%20iobroker%20Backup%20wurde%20am%2022.%20September%202020%20um%2022%3A44%20Uhr%20erstellt.&apike
              whatsapp-cmb.0	2020-09-22 22:44:24.502	info	Ein neues iobroker Backup wurde am 22. September 2020 um 22:44 Uhr erstellt. to +491799700000
              whatsapp-cmb.0	2020-09-22 22:44:24.502	info	(29603) Send BackItUp:
              whatsapp-cmb.0	2020-09-22 22:43:17.411	info	(29603) starting. Version 0.1.6 in /opt/iobroker/node_modules/iobroker.whatsapp-cmb, node: v10.21.0, js-controller: 3.1.6
              whatsapp-cmb.0	2020-09-22 22:43:16.954	debug	(29603) statesDB connected
              whatsapp-cmb.0	2020-09-22 22:43:16.954	debug	(29603) States connected to redis: 127.0.0.1:9000
              whatsapp-cmb.0	2020-09-22 22:43:16.950	debug	(29603) States create System PubSub Client
              whatsapp-cmb.0	2020-09-22 22:43:16.950	debug	(29603) States create User PubSub Client
              whatsapp-cmb.0	2020-09-22 22:43:16.947	debug	(29603) Redis States: Use Redis connection: 127.0.0.1:9000
              whatsapp-cmb.0	2020-09-22 22:43:16.946	debug	(29603) objectDB connected
              whatsapp-cmb.0	2020-09-22 22:43:16.944	debug	(29603) Objects connected to redis: 127.0.0.1:9001
              whatsapp-cmb.0	2020-09-22 22:43:16.939	debug	(29603) Objects client initialize lua scripts
              whatsapp-cmb.0	2020-09-22 22:43:16.939	debug	(29603) Objects create User PubSub Client
              whatsapp-cmb.0	2020-09-22 22:43:16.938	debug	(29603) Objects create System PubSub Client
              whatsapp-cmb.0	2020-09-22 22:43:16.937	debug	(29603) Objects client ready ... initialize now
              whatsapp-cmb.0	2020-09-22 22:43:16.921	debug	(29603) Redis Objects: Use Redis connection: 127.0.0.1:9001
              • L ltsalvatore
                @ltsalvatore
                hi simatec,
                simatecS Offline
                simatecS Offline
                simatec
                #687
                @ltsalvatore
                Schaue ich mir noch einmal an. Allerdings kann ich den Fehler nicht nachstellen, da auf meinem Dev-System "Lange Benachrichtigung" eingestellt ist und die Nachrichten sauber gesendet werden
                • B BoehserWolf
                  @simatec Morgen, setzte backitup in v1.6.7 ein. Wurde heute morgen mit einer Fehlermeldung beim Backup in diesem Datenpunkt begrüßt:
                  backitup.0.history.iobrokerLastTime
                  Meldung:
                  error: 20. September 2020 um 03:30 Uhr
                  Wenn ich allerdings auf Filesystem Ebene nachsehe scheint alles ok:
                  ls -la
                  total 96200
                  drwxrwxrwx+ 2 iobroker iobroker    4096 Sep 20 03:30 .
                  drwxrwxrwx+ 8 iobroker iobroker    4096 Sep 19 10:05 ..
                  -rw-rw-rw-+ 1 iobroker iobroker 6842369 May  9 13:25 2020_05_09-13_25_34_backupiobroker.tar.gz
                  -rw-rw-rw-+ 1 iobroker iobroker 8210513 Jun 10 18:53 2020_06_10-18_53_46_backupiobroker.tar.gz
                  -rw-rw-rw-+ 1 iobroker iobroker 8298907 Jun 28 11:26 2020_06_28-11_26_20_backupiobroker.tar.gz
                  -rw-rw-rw-+ 1 iobroker iobroker 6645760 Sep  7 01:30 homematic_2020_09_07-01_30_22_3.51.6.20200229_backupiobroker.tar.sbk
                  -rw-rw-rw-+ 1 iobroker iobroker 6645760 Sep 10 01:30 homematic_2020_09_10-01_30_22_3.51.6.20200229_backupiobroker.tar.sbk
                  -rw-rw-rw-+ 1 iobroker iobroker 6645760 Sep 13 01:30 homematic_2020_09_13-01_30_22_3.51.6.20200229_backupiobroker.tar.sbk
                  -rw-rw-rw-+ 1 iobroker iobroker 6645760 Sep 16 01:30 homematic_2020_09_16-01_30_22_3.51.6.20200229_backupiobroker.tar.sbk
                  -rw-rw-rw-+ 1 iobroker iobroker 6645760 Sep 19 01:30 homematic_2020_09_19-01_30_22_3.51.6.20200229_backupiobroker.tar.sbk
                  -rw-rw-rw-+ 1 iobroker iobroker 8345290 Sep 16 03:30 iobroker_2020_09_16-03_30_10_iobroker_wald_backupiobroker.tar.gz
                  -rw-rw-rw-+ 1 iobroker iobroker 8345873 Sep 17 03:30 iobroker_2020_09_17-03_30_10_iobroker_wald_backupiobroker.tar.gz
                  -rw-rw-rw-+ 1 iobroker iobroker 8345298 Sep 18 03:30 iobroker_2020_09_18-03_30_10_iobroker_wald_backupiobroker.tar.gz
                  -rw-rw-rw-+ 1 iobroker iobroker 8449703 Sep 19 03:30 iobroker_2020_09_19-03_30_10_iobroker_wald_backupiobroker.tar.gz
                  -rw-rw-rw-+ 1 iobroker iobroker 8401710 Sep 20 03:30 iobroker_2020_09_20-03_30_10_iobroker_wald_backupiobroker.tar.gz
                  Das Archiv iobroker_2020_09_20-03_30_10_iobroker_wald_backupiobroker.tar.gz lässt sich entpacken und ist damit wohl i.O.
                  Eine Idee dazu?
                  Frank_y
                  #688
                  @BoehserWolf sagte in Test Adapter Backitup v1.6.x:
                  Meldung:
                  ls -la
                  total 96200
                  Eine Idee dazu?
                  Bei mir auch selber Effekt mit v1.6.7:
                  backitup.0.history.iobrokerLastTime "error: 23. September 2020 um 02:03 Uhr"
                  backitup.0.history.iobrokerSuccess "false"
                  json: [{"date":"23. September 2020 um 02:03 Uhr","name":"iobroker_2020_09_23-02_00_10_backupiobroker.tar.gz","type":"iobroker","storage":"Dropbox: Ja","filesize":"9MB","error":"none"},{"date":"21. September 2020 um 16:13 Uhr","name":"iobroker_2020_09_21-16_09_26_backupiobroker.tar.gz","type":"iobroker","storage":"Dropbox: Ja","filesize":"9MB","error":"none"},{"date":"21. September 2020 um 02:03 Uhr","name":"iobroker_2020_09_21-02_00_10_backupiobroker.tar.gz","type":"iobroker","storage":"Dropbox: Ja","filesize":"9MB","error":"none"},{"date":"19. September 2020 um 02:03 Uhr","name":"iobroker_2020_09_19-02_00_10_backupiobroker.tar.gz","type":"iobroker","storage":"Dropbox: Ja","filesize":"9MB","error":"none"},
                  laut json-Datenpunkt scheint alles in Ordnung zu sein. Die beiden anderen Datenpunkte zeigen einen Fehler. Datei ist auch auf Dropbox verfügbar.
                  Ich habe die iobrokerVM jetzt neu gestartet und schaue morgen noch einmal
                  F 1 Antwort Letzte Antwort
                  • F Frank_y
                    Meldung:
                    ls -la
                    total 96200
                    Eine Idee dazu?
                    Frank_y
                    #689
                    auch ein Systemneustart bringt keine Änderung
                    backitup.0.history.iobrokerLastTime und backitup.0.history.iobrokerSuccess zeigen einen Fehler an
                    json zeigt alles i.O. an.
                    Datei ist auf Dropbox vorhanden
                    • F Frank_y
                      simatecS Offline
                      simatecS Offline
                      simatec
                      #690
                      @Frank_y
                      Bitte führe iobroker fix aus und poste mal den Debuglog des Backupprozesses
                      • simatecS simatec
                        @Frank_y
                        Frank_y
                        #691
                        @simatec
                        fixer ausgeführt (curl -fsL https://iobroker.net/fix.sh | bash -)
                        • adapter auf debug gestellt
                        cron-job liefert folgendes LOG
                        backitup.0	2020-09-24 18:03:57.755	debug	(17894) system.adapter.admin.0: logging true
                        backitup.0	2020-09-24 18:03:29.468	debug	(17894) [iobroker/clean] delete /opt/iobroker/backups/redis_2020_09_21-16_09_34_backupiobroker.tar.gz
                        backitup.0	2020-09-24 18:03:29.462	debug	(17894) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2020_09_23-02_00_10_backupiobroker.tar.gz
                        backitup.0	2020-09-24 18:03:29.199	debug	(17894) [iobroker] exec: done
                        backitup.0	2020-09-24 18:03:29.190	debug	(17894) [iobroker] exec: done
                        backitup.0	2020-09-24 18:03:29.187	debug	(17894) [iobroker/history] backitup.0.history.json
                        backitup.0	2020-09-24 18:03:29.179	debug	(17894) [iobroker/history] backitup.0.history.html
                        backitup.0	2020-09-24 18:03:29.159	debug	(17894) [iobroker/clean] done
                        backitup.0	2020-09-24 18:03:29.151	debug	(17894) [iobroker/dropbox] done
                        backitup.0	2020-09-24 18:03:28.620	debug	(17894) [iobroker/dropbox] Dropbox: delete /backupDir/redis_2020_09_09-02_00_18_backupiobroker.tar.gz
                        backitup.0	2020-09-24 18:03:28.043	debug	(17894) [iobroker/dropbox] Dropbox: delete /backupDir/iobroker_2020_09_09-02_00_10_backupiobroker.tar.gz
                        backitup.0	2020-09-24 18:03:18.542	debug	(17894) [iobroker/dropbox] Dropbox: Copy redis_2020_09_24-18_00_17_backupiobroker.tar.gz...
                        backitup.0	2020-09-24 18:00:18.148	debug	(17894) [iobroker/dropbox] Dropbox: Copy iobroker_2020_09_24-18_00_10_backupiobroker.tar.gz...
                        backitup.0	2020-09-24 18:00:18.139	debug	(17894) [iobroker/redis] done
                        backitup.0	2020-09-24 18:00:17.974	debug	(17894) [iobroker/iobroker] done
                        backitup.0	2020-09-24 18:00:16.948	debug	(17894) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2020_09_24-18_00_10_backupiobroker.tar.gz
                        backitup.0	2020-09-24 18:00:12.747	debug	(17894) [iobroker/iobroker] host.iobrokerVM 4876 objects saved
                        ba[ckitup.0	2020-09-24 18:00:12.715	debug	(17894) [iobroker/iobroker] host.iobrokerVM 4042 states saved
                        backitup.0	2020-09-24 18:00:10.143	debug	(17894) Backup has started ...
                        backitup.0	2020-09-24 17:57:01.485	debug	(17894) system.adapter.admin.0: logging false
                        backitup.0	2020-09-24 17:55:42.772	debug	(17894) system.adapter.admin.0: logging true
                        backitup.0	2020-09-24 17:55:37.241	debug	(17894) system.adapter.admin.0: logging false[Link Text](Link Adresse)](Link Adresse)
                        Leider bleiben beide Datenpunkte fehlerhaft
                        Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
                        Hier gehts zur Hilfe.
                        • F Frank_y
                          @simatec
                          Frank_y
                          #692
                          @simatec
                          habe danach noch einmal manuell <jetzt sichern> angestoßen und dann bestätigen beide Datenpunkte das korrekte backup:
                          backitup.0.history.iobrokerLastTime 24. September 2020 um 18:10 Uhr
                          backitup.0.history.iobrokerSuccess true
                          das Log sieht genauso aus
                          ->es hat irgendetwas mit dem Cron-Job zu tun
                          • F Frank_y
                            @simatec
                            simatecS Offline
                            simatecS Offline
                            simatec
                            #693
                            @Frank_y
                            history wird nicht sauber beendet.
                            Hatten wir hier schonmal gehabt. ..
                            • Instanz löschen
                            • Adapter löschen
                            • iobroker neustarten
                            • backitup neu installieren und einrichten
                            Scheint so, als ob bei deinem Update was schief gelaufen ist
                            • simatecS simatec
                              @Frank_y
                              • Instanz löschen
                              • Adapter löschen
                              Frank_y
                              schrieb am zuletzt editiert von Frank_y
                              #694
                              @simatec
                              alles gemacht, gleiches Bild:
                              -manuelle Auslösung in Ordnung
                              -über den cron-job werden die Datenpunkte nicht richtig gesetzt
                              bin per Rollback wieder zurück zur v1.5.8....hier läuft alles einwandfrei durch, manuell und per cron
                              • F Frank_y
                                @simatec
                                simatecS Offline
                                simatecS Offline
                                simatec
                                #695
                                @Frank_y
                                Was steht bei der 1.6.7 in folgenden Objekt nach dem Backup?
                                backitup.0.output.line
                                Gib mir mal bitte den Inhalt ...
                                • simatecS simatec
                                  @Frank_y
                                  Frank_y
                                  #696
                                  @simatec
                                  [DEBUG] [clean] - delete /opt/iobroker/backups/redis_2020_09_09-02_00_18_backupiobroker.tar.gz
                                  • F Frank_y
                                    @simatec
                                    simatecS Offline
                                    simatecS Offline
                                    simatec
                                    #697
                                    @Frank_y
                                    Kann das sein, dass genau hier das Problem liegt?
                                    Laut deinem anderen Post, gibt es in dem Ordner kein Redis-Backup.
                                    Stimmen deine Rechte in dem Ordner backup
                                    • simatecS simatec
                                      @Frank_y
                                      Frank_y
                                      #698
                                      @simatec
                                      die Ordner-Berechtigungen sind in beiden Versionen gleich:
                                      v.1.5.8:
                                      v1.6.7:
                                      Wenn ich manuell starte funktioniert ja auch alles. Auch beim Cron-Job werden Backups erstellt. Nur die Rückmeldungen in den beiden Datenpunkt scheinen nicht korrekt
                                      • F Frank_y
                                        @simatec
                                        v.1.5.8:
                                        v1.6.7:
                                        simatecS Offline
                                        simatecS Offline
                                        simatec
                                        schrieb am zuletzt editiert von simatec
                                        #699
                                        @Frank_y
                                        Bei einem manuellen Backup werden keine alten Dateien gelöscht.
                                        Deshalb kommt der Fehler dort nicht.
                                        Zeige doch bitte mal den kompletten Inhalt deines Backup-Ordners ...
                                        • simatecS simatec
                                          @Frank_y
                                          Frank_y
                                          #700
                                          @simatec
                                          v1.5.8
                                          v.1.6.7
                                          Thomas BraunT simatecS 2 Antworten Letzte Antwort
