  4. [gelöst] Adapter - Parser / Wartezeiten auslesen
parser adapter
53 Beiträge 5 Kommentatoren 5.4k Aufrufe 5 Beobachtet
    Alexxx2005
    #41
    Ah so ist's richtig :-)
    var cacheSelector = $('state[id=parser.0.*]');
    var cacheSelector = $('[id=parser.0.*]');
    schedule( "*/03 * * * * *",  function () {
    var sortArr=[];
    var htmlString ="<table><tr><td>Bahn   </td><td>Wartezeit   </td><td>   </td></tr>";
    //console.log(cacheSelector);
    var counter =0;
    cacheSelector.each(function(id, i) {
    counter = counter+1
    var devicename = getObject(id).common.name;
    var ip = id.replace(/_/g, ".");
    var ip = ip.replace(/parser.0./g, "");
    // log(id + " : " + devicename + " : " + ip );
    var devicenameName=devicename;
    devicename="Park.Wartezeit"+counter.toString()+".BahnName";
    createState(devicename, 'empty', { name: 'Name der Bahn', desc: '', type: 'string', role: '',read: true, write: true });
    setStateDelayed(devicename, devicenameName, 800);
    devicename="Park.Wartezeit"+counter.toString()+".Bahn";
    setStateDelayed(devicename, ip, 800);
    createState('empty', { name: 'Bahn', desc: '', type: 'string', role: '',read: true, write: true });
    var wert2 = getState(id).val;
    var wert1 = getState(id).val;
    if (wert2) wert2 = "✅";
    if (!wert2) wert2= "❌";
    let help = [ip,wert1,wert2];
    sortArr.push(help);
    //log(sortArr[0]);
    function numSort(a, b) {
     return parseInt(b[1]) - parseInt(a[1]);
    sortArr.sort(numSort);
          for (var i=0; i<sortArr.length;i++) {
              htmlString=htmlString+"<tr><td>" + sortArr[i][0] + "   </td><td>" + sortArr[i][1] + "   </td><td>" + sortArr[i][2] +  "</td></tr>";
    //htmlString=htmlString.concat("<tr><td>" + devicenameName + "   </td><td>" + ip + "   </td><td>" + wert1 + "</td></tr>");
    //log(counter);
    createState('Park.StringHTML', 0, {name: 'StringHTML', desc: '', type: 'string', role: '',read: true, write: true });
    createState('Park.Anzahl', 0, { name: 'Anzahl', desc: 'Anzahl der Geräte', type: 'number', unit: '', min: '0', max: '255', role: '',read: true, write: true });
    setStateDelayed('Park.Anzahl', counter, 800);
    setStateDelayed('Park.StringHTML', htmlString.concat("</table>"), 800);
    • A Alexxx2005
      var sortArr=[];
      var counter =0;
      counter = counter+1
      sortArr.push(help);
      //log(sortArr[0]);
      //log(counter);
      liv-in-skyL Offline
      liv-in-skyL Offline
      liv-in-sky
      #42
      @Alexxx2005
      ok neuer test
      schedule( "*/20 * * * * *", function () {
      var sortArr=[];
      var htmlString ="<table><tr><td>Bahn </td><td>Wartezeit </td><td> </td><td>&ensp;&ensp;&ensp;</td><td>Bahn &ensp;&ensp;&ensp;</td><td>Wartezeit </td><td> </td></tr>";/*+
                             "<tr>&ensp;<td></td><td></td><td></td><td></td><td></td><td></td></tr>" */;
      var counter =0;
      counter = counter+1
      createState(devicename,'empty', { name: 'Bahn', desc: '', type: 'string', role: '',read: true, write: true });
      var wert1;
      var wert2;
      if ( getState(id).val==null) {wert1= "🔒"; wert2="999999";}
      else {
           if (wert1) wert1 = "✅";
           if (!wert1) wert1= "❌";
      let help = [ip,wert2,wert1];
      sortArr.push(help);
      return parseInt(a[1]) - parseInt(b[1]);
         if (sortArr[i][1]!="999999") {
         if(i%2==0) {htmlString=htmlString+"<tr><td>" + sortArr[i][0] + "</td><td>&ensp;&ensp;&ensp;" + sortArr[i][1] + "&ensp;&ensp;&ensp;</td><td>" + sortArr[i][2]+"&ensp;&ensp;&ensp;"+"<td>&ensp;&ensp;&ensp;</td>" ;}// +"</td>"         + " <td>"        + " </td><td>"   + "</td></tr>";}
         else{htmlString=htmlString+      "<td>" + sortArr[i][0]  + " </td><td>&ensp;&ensp;&ensp;"   + sortArr[i][1]  + "&ensp;&ensp;&ensp;</td><td>"   + sortArr[i][2] + "</td></tr>"}}
         else{
             if(i%2==0) {htmlString=htmlString+"<tr><td>" + sortArr[i][0] + "</td><td>&ensp;&ensp;&ensp;" + "out" + "&ensp;&ensp;&ensp;</td><td>" + sortArr[i][2]+"&ensp;&ensp;&ensp;" ;}// +"</td>"         + " <td>"        + " </td><td>"   + "</td></tr>";}
         else{htmlString=htmlString+      "<td>" + sortArr[i][0]  + " </td><td>&ensp;&ensp;&ensp;"   + "out"  + "&ensp;&ensp;&ensp;</td><td>"   + sortArr[i][2] + "</td></tr>"}
      //log(counter);
      ich habe mal versucht, das ganze in 2 tabellen nebeneinander darzustellen - weiß nicht ob das gefällt ?
      A 1 Antwort Letzte Antwort
      • liv-in-skyL liv-in-sky
        @Alexxx2005
        ok neuer test
        var sortArr=[];
        var counter =0;
        counter = counter+1
        var wert1;
        var wert2;
        else {
        sortArr.push(help);
           else{
        //log(counter);
        Alexxx2005
        #43
        @liv-in-sky
        doch das ist super , sieht gut aus. Es zeigt bei mir nur die oberen drei rechten Spalten zu weit links an , es da noch ein kleiner Bug im "htmlstring" oder warum zeigt es die drei markierten Bahnen so an ?
        Grüße Alex
        HomoranH liv-in-skyL 3 Antworten Letzte Antwort
        • A Alexxx2005
          @liv-in-sky
          Grüße Alex
          #44
          @Alexxx2005 sagte in Adapter - Parser soll Wartezeiten auslesen:
          ich tippe darauf, dass es an dem Schloss - icon, resp. der dazugehörigen Formatierung liegt
          • A Alexxx2005
            @liv-in-sky
            Grüße Alex
            liv-in-skyL Offline
            liv-in-skyL Offline
            liv-in-sky
            #45
            @Alexxx2005 ich überprüfe nochmal - falls du was am script geändert hast, bitte wieder posten, damit ich damit arbeiten kann, sonst musst du wieder nachträglich ändern
            nur zur sicherheit - die werte stimmen alle ? es geht nur um die formatierung ?
            • A Alexxx2005
              @liv-in-sky
              Grüße Alex
              liv-in-skyL Offline
              liv-in-skyL Offline
              liv-in-sky
              #46
              @Alexxx2005 du kannst mal zum test das schloss mit einem haken austauschen und nachsehen, ob das problem bleibt - somit könnten wir das icon ausschließem ( @Homoran )
                Alexxx2005
                schrieb am zuletzt editiert von Alexxx2005
                #47
                @Homoran
                beim Haken oder X ist es gleich
                @liv-in-sky
                im Skript habe ich nur bei Zeile 54/55 das Wort "out" entfernt
                und die Sortierung (b und a) in Zeile 46 sonst ist alles genau gleich wie das
                wo du gepostet hast :-)
                Grüße Alex
                • A Alexxx2005
                  @Homoran
                  @liv-in-sky
                  Grüße Alex
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  liv-in-sky
                  #48
                  @Alexxx2005ok - teste gerade - komme schon auf die spur :-)
                    Alexxx2005
                    #49
                    @liv-in-sky
                    ja das denke ich mir , habe nun die Tage auch einiges gelernt, hilft mir dann auch wieder wo anders...
                    • A Alexxx2005
                      @Homoran
                      @liv-in-sky
                      Grüße Alex
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      liv-in-sky
                      #50
                      @Alexxx2005 tausche mal diesen block aus:
                         else{
                             if(i%2==0) {htmlString=htmlString+"<tr><td>" + sortArr[i][0] + "</td><td>&ensp;&ensp;&ensp;" + "" + "&ensp;&ensp;&ensp;</td><td>" + sortArr[i][2]+"&ensp;&ensp;&ensp;"+"<td>&ensp;&ensp;&ensp;" ;}// +"</td>"         + " <td>"        + " </td><td>"   + "</td></tr>";}
                         else{htmlString=htmlString+      "<td>"+ sortArr[i][0]  + " </td><td>&ensp;&ensp;&ensp;"   + ""  + "&ensp;&ensp;&ensp;</td><td>"   + sortArr[i][2] + "</td></tr>"}
                           else{
                        Alexxx2005
                        #51
                        @liv-in-sky
                        That's it 👏
                        Somit wäre es komplett :
                        var sortArr=[];
                        var counter =0;
                        counter = counter+1
                        var wert1;
                        var wert2;
                        else {
                        sortArr.push(help);
                          else{
                        //log(counter);
                        Danke nochmal für alles !
                        • A Alexxx2005
                          @liv-in-sky
                          That's it 👏
                          var sortArr=[];
                          var counter =0;
                          counter = counter+1
                          var wert1;
                          var wert2;
                          else {
                          sortArr.push(help);
                            else{
                          //log(counter);
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          liv-in-sky
                          #52
                          @Alexxx2005 gerne
                          schau mal in meine signatur - zum thread beenden
                            @Alexxx2005
                            nimm Badge[^>]*>(\d*) als RegEx für alle und verändere Num für die entsprechenden Bahnen von 0 bis 27
                            Alexxx2005
                            #53
                            @Homoran said in [gelöst] Adapter - Parser / Wartezeiten auslesen:
                            Badge[^>]>(\d)
                            Wenn ich "Heute geöffnet" auslesen möchte wie springe ich in eine Zweite Gruppe ?
                            Heute bis[^>]*>(\d*:)
                            ergibt "19" aber wie komme ich dann auf 19:00 ?
                            gibt es dazu eine Doku ?
                            Grüße Alex
