  4. FHEM
  • Neuer Blogbeitrag: KI in ioBroker, vom Helfer im Admin bis zum eigenen Smart Assistant
  • Neues Video: Der KI-Assistent im ioBroker Admin
FHEM
49 Beiträge 11 Kommentatoren 17.3k Aufrufe
  • H
    H
    Holliwyoming
    #41
    Hallo
    Mit welchen Widget in I/O Broker kann ich einen normalen Ausgang in Fhem (on/off) testen
    Gruss Holli
    • H
      H
      Holliwyoming
      #42
      Hallo
      Und hier das Rollo
      "Arg":"Tim_Rollo1",
      "Results": [
      "Name":"Tim_Rollo1",
      "PossibleSets":" config raw reset:noArg settings ",
      "PossibleAttrs":"verbose:0,1,2,3,4,5 room group comment:textField-long alias eventMap userReadings:textField-long autoReadConfig:atstartup,always,never configReadRetries do_not_notify:0,1 ignore:1,0 dummy:1,0 showtime:1,0 serialNr model:HMW_Generic,HMW_IO_12_Sw14_DR,HMW_IO_12_FM,HMW_Sen_SC_12_FM,HMW_LC_Bl1_DR,HMW_IO_12_Sw7_DR,HMW_LC_Dim1L_DR,HMW_LC_Sw2_DR,HMW_Sen_SC_12_DR,HMW_IO_4_FM,HMW_IO_SR_FM subType stateFormat firmwareVersion setList event-min-interval event-aggregator IODev event-on-change-reading event-on-update-reading cmdIcon devStateIcon devStateStyle icon sortby webCmd widgetOverride userattr",
      "Internals": {
      "DEF": "0000EA87",
      "FW_VERSION": "3.06",
      "FailedConfigReads": "0",
      "MODEL": "HMW_LC_Bl1_DR",
      "NAME": "Tim_Rollo1",
      "NR": "183",
      "STATE": "ACK",
      "TYPE": "HM485",
      "channel_01": "Tim_Rollo1_Ab",
      "channel_02": "Tim_Rollo1_Auf",
      "channel_03": "Tim_Rollo1_Motor",
      "peer_act_0": "channel_01 → Tim_Rollo1_Motor",
      "peer_act_1": "channel_02 → Tim_Rollo1_Motor",
      "peer_sen_0": "channel_03 ← Tim_Rollo1_Ab",
      "peer_sen_1": "channel_03 ← Tim_Rollo1_Auf"
      "Readings": {
      "R-central_address": { "Value":"00000001", "Time":"2016-08-13 08:26:48" },
      "R-logging_time": { "Value":"2.00", "Time":"2016-08-13 08:26:48" },
      "configStatus": { "Value":"OK", "Time":"2016-08-13 08:26:48" },
      "state": { "Value":"ACK", "Time":"2016-08-13 08:26:48" }
      "Attributes": {
      "IODev": "HM485_LAN",
      "firmwareVersion": "3.06",
      "model": "HMW_LC_Bl1_DR",
      "room": "HM485,Tim",
      "serialNr": "leq1182362"
      "totalResultsReturned":1
      Gruss Holli
      • H
        H
        Holliwyoming
        #43
        Hallo
        Ein Raumthermostat wäre auch noch Interessant
        "Arg":"TH_Tim_1",
        "Results": [
        "Name":"TH_Tim_1",
        "PossibleSets":"assignHmKey clear:readings,trigger,register,oldRegs,rssi,msgEvents,attack,all deviceRename fwUpdate getConfig getRegRaw getSerial inhibit:on,off raw regBulk regSet reset sysTime unpair",
        "PossibleAttrs":"verbose:0,1,2,3,4,5 room group comment:textField-long alias eventMap userReadings:textField-long do_not_notify:1,0 showtime:1,0 rawToReadable unit expert:0_defReg,1_allReg,2_defReg+raw,3_allReg+raw,4_off,8_templ+default,12_templOnly,251_anything param actAutoTry:0_off,1_on aesCommReq:1,0 ignore:1,0 dummy:1,0 IODev IOList IOgrp rssiLog:1,0 actCycle hmKey hmKey2 hmKey3 serialNr firmware .stc .devInfo actStatus autoReadReg:0_off,1_restart,2_pon-restart,3_onChange,4_reqStatus,5_readMissing,8_stateOnly burstAccess:0_off,1_auto msgRepeat hmProtocolEvents:0_off,1_dump,2_dumpFull,3_dumpTrigger aesKey:5,4,3,2,1,0 repPeers peerIDs tempListTmpl levelRange levelMap event-on-change-reading event-on-update-reading event-aggregator event-min-interval stateFormat model:ASH550,ASH550I,CCU-FHEM,CMM,DORMA_BRC-H,DORMA_RC-H,DORMA_atent,HM-CC-RT-DN,HM-CC-RT-DN-BoM,HM-CC-SCD,HM-CC-TC,HM-CC-VD,HM-Dis-TD-T,HM-Dis-WM55,HM-ES-PMSw1-DR,HM-ES-PMSw1-Pl,HM-ES-PMSw1-Pl-DN-R1,HM-ES-PMSw1-Pl-DN-R2,HM-ES-PMSw1-Pl-DN-R3,HM-ES-PMSw1-Pl-DN-R4,HM-ES-PMSw1-Pl-DN-R5,HM-ES-PMSw1-SM,HM-ES-TX-WM,HM-LC-BL1-FM,HM-LC-BL1-PB-FM,HM-LC-BL1-SM,HM-LC-Bl1-FM-2,HM-LC-Bl1-SM-2,HM-LC-Bl1PBU-FM,HM-LC-DDC1-PCB,HM-LC-DIM1L-CV,HM-LC-DIM1L-PL,HM-LC-DIM1T-CV,HM-LC-DIM1T-FM,HM-LC-DIM1T-PL,HM-LC-DIM2L-CV,HM-LC-DIM2L-SM,HM-LC-DIM2T-SM,HM-LC-Dim1L-CV-2,HM-LC-Dim1L-CV-644,HM-LC-Dim1L-Pl-2,HM-LC-Dim1L-Pl-3,HM-LC-Dim1L-Pl-644,HM-LC-Dim1PWM-CV,HM-LC-Dim1PWM-CV-2,HM-LC-Dim1T-CV-2,HM-LC-Dim1T-CV-644,HM-LC-Dim1T-FM-2,HM-LC-Dim1T-FM-644,HM-LC-Dim1T-FM-LF,HM-LC-Dim1T-Pl-2,HM-LC-Dim1T-Pl-3,HM-LC-Dim1T-Pl-644,HM-LC-Dim1TPBU-FM,HM-LC-Dim1TPBU-FM-2,HM-LC-Dim2L-SM-2,HM-LC-Dim2L-SM-644,HM-LC-Dim2T-SM,HM-LC-Dim2T-SM-2,HM-LC-RGBW-WM,HM-LC-SW1-BA-PCB,HM-LC-SW1-FM,HM-LC-SW1-PB-FM,HM-LC-SW1-PL,HM-LC-SW1-PL-OM54,HM-LC-SW1-PL2,HM-LC-SW1-SM,HM-LC-SW1-SM-ATMEGA168,HM-LC-SW2-DR,HM-LC-SW2-FM,HM-LC-SW2-PB-FM,HM-LC-SW2-SM,HM-LC-SW4-BA-PCB,HM-LC-SW4-DR,HM-LC-SW4-PCB,HM-LC-SW4-SM,HM-LC-SW4-SM-ATMEGA168,HM-LC-SW4-WM,HM-LC-Sw1-DR,HM-LC-Sw1-FM-2,HM-LC-Sw1-Pl-3,HM-LC-Sw1-Pl-CT-R1,HM-LC-Sw1-Pl-CT-R2,HM-LC-Sw1-Pl-CT-R3,HM-LC-Sw1-Pl-CT-R4,HM-LC-Sw1-Pl-CT-R5,HM-LC-Sw1-Pl-DN-R1,HM-LC-Sw1-Pl-DN-R2,HM-LC-Sw1-Pl-DN-R3,HM-LC-Sw1-Pl-DN-R4,HM-LC-Sw1-Pl-DN-R5,HM-LC-Sw1-SM-2,HM-LC-Sw1PBU-FM,HM-LC-Sw2-DR-2,HM-LC-Sw2-FM-2,HM-LC-Sw2PBU-FM,HM-LC-Sw4-DR-2,HM-LC-Sw4-PCB-2,HM-LC-Sw4-SM-2,HM-LC-Sw4-WM-2,HM-MOD-Em-8,HM-MOD-Re-8,HM-OU-CF-PL,HM-OU-CFM-PL,HM-OU-CFM-TW,HM-OU-CM-PCB,HM-OU-LED16,HM-PB-2-FM,HM-PB-2-WM,HM-PB-2-WM55,HM-PB-2-WM55-2,HM-PB-4-WM,HM-PB-4DIS-WM,HM-PB-4DIS-WM-2,HM-PB-6-WM55,HM-PBI-4-FM,HM-RC-12,HM-RC-12-B,HM-RC-12-SW,HM-RC-19,HM-RC-19-B,HM-RC-19-SW,HM-RC-2-PBU-FM,HM-RC-4,HM-RC-4-2,HM-RC-4-3,HM-RC-4-3-D,HM-RC-4-B,HM-RC-8,HM-RC-Dis-H-x-EU,HM-RC-KEY3,HM-RC-KEY3-B,HM-RC-Key4-2,HM-RC-Key4-3,HM-RC-P1,HM-RC-SEC3,HM-RC-SEC3-B,HM-RC-Sec4-2,HM-RC-Sec4-3,HM-SCI-3-FM,HM-SEC-KEY,HM-SEC-KEY-O,HM-SEC-KEY-S,HM-SEC-MDIR,HM-SEC-MDIR-2,HM-SEC-MDIR-3,HM-SEC-RHS,HM-SEC-RHS-2,HM-SEC-SC,HM-SEC-SC-2,HM-SEC-SCo,HM-SEC-SD,HM-SEC-SD-2,HM-SEC-SFA-SM,HM-SEC-TIS,HM-SEC-WDS,HM-SEC-WDS-2,HM-SEC-WIN,HM-SEN-EP,HM-SEN-MDIR-SM,HM-SWI-3-FM,HM-Sec-Cen,HM-Sec-Sir-WM,HM-Sen-DB-PCB,HM-Sen-LI-O,HM-Sen-MDIR-O,HM-Sen-MDIR-O-2,HM-Sen-MDIR-WM55,HM-Sen-RD-O,HM-Sen-Wa-Od,HM-Sys-sRP-Pl,HM-TC-IT-WM-W-EU,HM-WDC7000,HM-WDS10-TH-O,HM-WDS100-C6-O,HM-WDS100-C6-O-2,HM-WDS20-TH-O,HM-WDS30-OT2-SM,HM-WDS30-OT2-SM-2,HM-WDS30-T-O,HM-WDS40-TH-I,HM-WDS40-TH-I-2,HM-WS550,HM-WS550LCB,HM-WS550LCW,HM-WS550Tech,IS-WDS-TH-OD-S-R3,KFM-Display,KFM-Sensor,KS550,KS550LC,KS550TECH,KS888,OLIGO-smart-iq-HM,PS-Th-Sens,PS-switch,ROTO_ZEL-STG-RM-DWT-10,ROTO_ZEL-STG-RM-FDK,ROTO_ZEL-STG-RM-FEP-230V,ROTO_ZEL-STG-RM-FSA,ROTO_ZEL-STG-RM-FST-UP4,ROTO_ZEL-STG-RM-FWT,ROTO_ZEL-STG-RM-FZS,ROTO_ZEL-STG-RM-FZS-2,ROTO_ZEL-STG-RM-HS-4,ROTO_ZEL-STG-RM-WT-2,Roto_ZEL-STG-RM-FFK,Roto_ZEL-STG-RM-FSS-UP3,S550IA,Schueco_263-130,Schueco_263-131,Schueco_263-132,Schueco_263-133,Schueco_263-134,Schueco_263-135,Schueco_263-144,Schueco_263-145,Schueco_263-146,Schueco_263-147,Schueco_263-155,Schueco_263-157,Schueco_263-158,Schueco_263-160,Schueco_263-162,Schueco_263-167,Schueco_263-xxx,SensoTimer-ST-6,WDF-solar,WS888 subType:AlarmControl,KFM100,THSensor,blindActuator,blindActuatorSol,dimmer,keyMatic,motionAndBtn,motionDetector,outputUnit,powerMeter,powerSensor,pushButton,remote,repeater,rgb,senBright,sensRain,sensor,singleButton,siren,smokeDetector,swi,switch,thermostat,threeStateSensor,timer,tipTronic,virtual,winMatic cmdIcon devStateIcon devStateStyle icon sortby webCmd widgetOverride userattr",
        "Internals": {
        "CFGFN": "",
        "DEF": "3AE4DB",
        "HMLAN1_MSGCNT": "69",
        "HMLAN1_RAWMSG": "E3AE4DB,0000,001D602C,FF,FFB3,8E84703AE4DB00000000EC3E",
        "HMLAN1_RSSI": "-77",
        "HMLAN1_TIME": "2016-08-15 21:51:19",
        "LASTInputDev": "HMLAN1",
        "MSGCNT": "69",
        "NAME": "TH_Tim_1",
        "NR": "227",
        "STATE": "CMDs_done",
        "TYPE": "CUL_HM",
        "channel_01": "HM_3AE4DB_Weather",
        "channel_02": "HM_3AE4DB_Climate",
        "channel_03": "HM_3AE4DB_WindowRec",
        "channel_06": "HM_3AE4DB_remote",
        "channel_07": "HM_3AE4DB_SwitchTr",
        "lastMsg": "No:8E - t:70 s:3AE4DB d:000000 00EC3E",
        "protLastRcv": "2016-08-15 21:51:19",
        "protSnd": "59 last_at:2016-08-15 21:49:34",
        "protState": "CMDs_done",
        "rssi_at_HMLAN1": "avg:-70.69 min:-78 max:-65 lst:-77 cnt:69 "
        "Readings": {
        "Activity": { "Value":"alive", "Time":"2016-08-15 21:49:14" },
        "CommandAccepted": { "Value":"yes", "Time":"2016-08-15 21:49:19" },
        "D-firmware": { "Value":"1.2", "Time":"2016-08-15 21:49:09" },
        "D-serialNr": { "Value":"MEQ0476401", "Time":"2016-08-15 21:49:09" },
        "PairedTo": { "Value":"0x0E0070", "Time":"2016-08-15 21:49:19" },
        "R-burstRx": { "Value":"on", "Time":"2016-08-15 21:49:19" },
        "R-cyclicInfoMsg": { "Value":"on", "Time":"2016-08-15 21:49:19" },
        "R-cyclicInfoMsgDis": { "Value":"0", "Time":"2016-08-15 21:49:19" },
        "R-pairCentral": { "Value":"0x0E0070", "Time":"2016-08-15 21:49:19" },
        "RegL_00.": { "Value":" 01:01 02:01 09:01 0A:0E 0B:00 0C:70 0F:00 11:00 12:16 16:01 18:00 19:00 1A:00 00:00", "Time":"2016-08-15 21:49:19" },
        "RegL_07.": { "Value":"", "Time":"2016-08-15 21:51:11" },
        "battery": { "Value":"ok", "Time":"2016-08-15 21:51:09" },
        "batteryLevel": { "Value":"3", "Time":"2016-08-15 21:51:09" },
        "desired-temp": { "Value":"24.0", "Time":"2016-08-15 21:51:09" },
        "measured-temp": { "Value":"23.6", "Time":"2016-08-15 21:51:09" },
        "state": { "Value":"CMDs_done", "Time":"2016-08-15 21:49:34" },
        "time-request": { "Value":"-", "Time":"2016-08-15 21:49:15" }
        "Attributes": {
        "IODev": "HMLAN1",
        "actCycle": "000:10",
        "actStatus": "alive",
        "autoReadReg": "4_reqStatus",
        "expert": "2_raw",
        "firmware": "1.2",
        "model": "HM-TC-IT-WM-W-EU",
        "msgRepeat": "1",
        "room": "CUL_HM,Tim",
        "serialNr": "MEQ0476401",
        "subType": "thermostat",
        "webCmd": "getConfig:clear msgEvents"
        Gruss Holli
        • H
          H
          Holliwyoming
          #44
          Hallo
          Also heute Abend einige Sachen getestet
          Rolladen Steuerung funktioniert einwandfrei (up down)
          mit hqwidget
          Dimmer Steuerung funktioniert mit Einschränkungen
          Slider springt. Mein Eindruck hier gibt es ein zeitliches Problem
          mit der Rückmeldung aus Fhem
          Normale Lichtsteuerung (on,off,toggle) schalten geht
          Rückmeldung kommt im widget nicht an
          Raumthermostat Ist-Werte für Temperatur und Feuchtigkeit
          werden sauber übertragen und angezeigt im hqwidget
          Sollwert schreiben funktioniert sowohl im widget wie auch im ioBroker direkt nicht
          Gruss Holli
          • H
            H
            Holliwyoming
            #45
            Hallo
            Nachtrag Lichtsteuerung funktioniert einwandfrei
            Gruss Holli
            • J
              J
              jojoman3
              #46
              ich wollte das Plugin mal ausprobieren, bin aber darüber gestolpert, dass mein FHEM telnet port Passwort geschützt ist und ich in der Plugin Konfig keine Möglichkeit gefunden habe, dass PW mitzugeben.
              Ist es hier geplant, dass das Plugin das unterstützt?
              Grüße
              jojoman3
              • BluefoxB
                #47
                @jojoman3:
                Grüße
                jojoman3 `
                Wie schalte ich password ein?
                define tPort telnet 7072 global
                attr tPort SSL
                attr allowed_tPort allowed
                attr allowed_tPort validFor tPort
                attr allowed_tPort globalpassword mySecret
                macht bei mir nichts, obwohl ich von einer anderen Machine mich verbinde.
                Ich kann natürlich blind einbauen, dafür muss ich aber wissen, warum ganz am Anfang muss man 3 mal Enter drücken, nachdem die Verbindung aufgebaut ist?
                Und was ist mit "
                > ein Passwort, welches als allererster String eingegeben werden muss, nachdem die Verbindung aufgebaut wurde
                gemeint ist.
                Wirklich aller erster oder nach dem als man 3 mal Enter gedrückt hat?
                • Lenny.CBL
                  Lenny.CBL
                  Lenny.CB
                  #48
                  hallo BF,
                  da ja Z-wave unter IoB nicht so recht rockt, bin ich auch den Umweg über FHEM gegangen. Ich sage gleich dazu, habe von FHEM keine Ahnung!
                  Hier eins meiner Rollos (FIBARO Roller Shutter 2 / FGR-222)
                  Die ausgabe ist gezogen kurz nachdem ich das Gerät angelernt habe.
                  Steuerung von IoB aus:
                  on/off –> komplett hoch oder runter
                  dim --> Zahl zwischen 0-99 (hier musste ich aber noch die "[" bei "states" löschen --> siehe Bild FHEM2.img)
                  JsonList2:
                  ! "Arg":"ZWave_SWITCH_MULTILEVEL_2",
                  ! "Results": [
                  ! "Name":"ZWave_SWITCH_MULTILEVEL_2",
                  ! "PossibleSets":"associationAdd associationDel configByte configDefault configLong configWord dim:slider,0,1,99 dimWithDuration mcaAdd mcaDel meterReset:noArg neighborUpdate:noArg off:noArg on:noArg powerlevel powerlevelTest protectionBytes protectionOff:noArg protectionOn:noArg protectionSeq:noArg returnRouteAdd returnRouteDel:noArg sceneActivate stop:noArg toggle on-till off-till off-for-timer intervals on-for-timer on-till-overnight blink off-till-overnight",
                  ! "PossibleAttrs":"alias comment:textField-long eventMap group room suppressReading userReadings:textField-long verbose:0,1,2,3,4,5 IODev WNMI_delay noWakeupForApplicationUpdate:1,0 classes do_not_notify:1,0 dummy:1,0 extendedAlarmReadings:0,1,2 ignore:1,0 noExplorerFrames:1,0 eventForRaw secure_classes showtime:1,0 vclasses zwaveRoute neighborListPos event-on-change-reading event-on-update-reading event-aggregator event-min-interval stateFormat:textField-long timestamp-on-change-reading cmdIcon devStateIcon devStateStyle icon sortby webCmd widgetOverride userattr",
                  ! "Internals": {
                  ! "DEF": "c003b538 2",
                  ! "LASTInputDev": "ZWDongle_0",
                  ! "MSGCNT": "22",
                  ! "NAME": "ZWave_SWITCH_MULTILEVEL_2",
                  ! "NR": "23",
                  ! "STATE": "dim 99",
                  ! "TYPE": "ZWave",
                  ! "ZWDongle_0_MSGCNT": "22",
                  ! "ZWDongle_0_RAWMSG": "000400020a320221440000001c0000",
                  ! "ZWDongle_0_TIME": "2016-10-03 12:27:08",
                  ! "ZWaveSubDevice": "no",
                  ! "homeId": "c003b538",
                  ! "isWakeUp": "",
                  ! "lastMsgSent": "1475489993.04154",
                  ! "nodeIdHex": "02"
                  ! "Readings": {
                  ! "energy": { "Value":" 0.28 kWh", "Time":"2016-10-03 12:27:08" },
                  ! "power": { "Value":"0.0 W", "Time":"2016-10-03 12:19:55" },
                  ! "reportedState": { "Value":"dim 99", "Time":"2016-10-03 12:19:55" },
                  ! "state": { "Value":"dim 99", "Time":"2016-10-03 12:19:55" },
                  ! "timeToAck": { "Value":"0.592", "Time":"2016-10-03 12:19:53" },
                  ! "transmit": { "Value":"OK", "Time":"2016-10-03 12:19:53" }
                  ! "Attributes": {
                  ! "IODev": "ZWDongle_0",
                  ! "classes": "MULTI_CHANNEL_ASSOCIATION MANUFACTURER_SPECIFIC VERSION CONFIGURATION ASSOCIATION POWERLEVEL METER SWITCH_MULTILEVEL SENSOR_MULTILEVEL SWITCH_BINARY MANUFACTURER_PROPRIETARY PROTECTION MARK METER SENSOR_MULTILEVEL MANUFACTURER_PROPRIETARY SCENE_ACTIVATION SWITCH_MULTILEVEL SWITCH_BINARY",
                  ! "room": "ZWave"
                  ! "totalResultsReturned":1
                  Kann noch anbieten:
                  FIBARO Universalsensor (FGBS-001)
                  AEOTEC Home Energy Meter (2nd Edition)
                  Grüße, Lenny…
                  • Lenny.CBL
                    Lenny.CBL
                    Lenny.CB
                    #49
                    Hallo Bluefox, sag mal, sprechen IoB und FHEM schon in beiden Richtungen miteinander?
                    mir ist heut Folgendes aufgefallen:
                    IoB:
                    "state" im Reiter "Objekte" setzen –> geht (0-99)
                    "state" über Adapter "Szenen" setzen --> geht (0-99)
                    "state" mit "jqui-mfd - Shutter + jqui Dialog" setzen --> geht (0-99)
                    Bei allen Aktionen die in <u>IoB</u> ausgelößt werden, aktualisiert sich FHEM.
                    FHEM:
                    Rollos hoch, runter und dazwischen –> geht
                    Bei allen Aktionen die in <u>FHEM</u> ausgelößt werden, aktualisiert sich IoB <u>nicht</u>.
                    am Rollo-Taster:
                    Bei allen Aktionen die am <u>Taster</u> ausgelößt werden, aktualisiert sich FHEM, aber IoB <u>nicht</u>.
                    Die "state´s" werden auch nach einem FHEM-Adapter-Neustart nicht aktualisiert.
                    Grüße, Lenny
                    84.1k
                    1.4m
