  4. Fehler bei Update Javascript Adapter auf 4.3.3
javascript adapter
5 Beiträge 2 Kommentatoren 784 Aufrufe 2 Beobachtet
    spaceduck
    muss mich mal an euch wenden weil ich nicht weiterkomme... Ich wollte gerade den Javascript Adapter von 4.3.2 auf 4.3.3 updaten. Folgende Fehlermeldung:
    899 warn enoent ENOENT: no such file or directory, open '/volume1/opt/iobroker/node_modules/mailparser-mit/package.json'
    900 verbose enoent This is related to npm not being able to find a file.
    901 warn enoent ENOENT: no such file or directory, open '/volume1/opt/iobroker/node_modules/iobroker.node-red/node_modules/utf7/package.json'
    902 verbose enoent This is related to npm not being able to find a file.
    903 verbose stack Error: EACCES: permission denied, unlink '/volume1/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc'
    904 verbose cwd /volume1/opt/iobroker
    905 verbose Linux 4.15.0-66-generic
    906 verbose argv "/usr/bin/node" "/usr/local/bin/npm" "install" "iobroker.javascript@4.3.3" "--loglevel" "error" "--production" "--save" "--prefix" "/volume1/opt/iobroker"
    907 verbose node v10.17.0
    908 verbose npm  v6.10.0
    909 error path /volume1/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc
    910 error code EACCES
    911 error errno -13
    912 error syscall unlink
    913 error Error: EACCES: permission denied, unlink '/volume1/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc'
    913 error  { [Error: EACCES: permission denied, unlink '/volume1/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc']
    913 error   cause:
    913 error    { Error: EACCES: permission denied, unlink '/volume1/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc'
    913 error      errno: -13,
    913 error      code: 'EACCES',
    913 error      syscall: 'unlink',
    913 error      path:
    913 error       '/volume1/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc' },
    913 error   stack:
    913 error    'Error: EACCES: permission denied, unlink \'/volume1/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc\'',
    913 error   path:
    913 error    '/volume1/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc',
    913 error   parent: 'iobroker.javascript' }
    914 error The operation was rejected by your operating system.
    914 error It is likely you do not have the permissions to access this file as the current user
    914 error
    914 error If you believe this might be a permissions issue, please double-check the
    914 error permissions of the file and its containing directories, or try running
    914 error the command again as root/Administrator (though this is not recommended).
    915 verbose exit [ -13, true ]
    Folgendes ist zum log zu sagen:
    1. '/volume1/opt/iobroker/node_modules/mailparser-mit/package.json' & '/volume1/opt/iobroker/node_modules/iobroker.node-red/node_modules/utf7/package.json' sind nicht vorhanden, ja richtig, aber auch in meinen alten Backups nicht...
    2. permission denied, unlink '/volume1/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc' ist bei mir ein link auf ../typescript/bin/tsc - permissions sind 777
    Ich komm nicht weiter, kann mir jemand erklären was da schiefläuft?
    Hier noch meine Config falls es hilft:
    Betriebssystem: linux
    Architektur: x64
    CPUs: 2
    Geschwindigkeit: 2065 MHz
    Modell: Intel(R) Celeron(R) CPU G1610T @ 2.30GHz
    RAM: 3.81 GB
    Node.js: v10.17.0
    NPM: 6.10.0
    HP Gen8 16GB / Ubuntu Server 20.04 LTS - Nein, ein Server braucht keine GUI…;-)
    • sigi234S sigi234
      @spaceduck sagte in Fehler bei Update Javascript Adapter auf 4.3.3:
      Jepp lief drüber, hat aber keine Änderung gebracht
      Neustart?
      Was kommt bei:
      cd..iobroker
      iobroker list instances
      node -v
      nodejs -v
      npm -v
      spaceduck
      Habe es gerade selbst hinbekommen, ein
      "chmod -R 777 /volume1/opt/iobroker/node_modules/iobroker.javascript/"
      hats gelöst, da war doch noch ein permission problem...
      Danke trotzdem!
      • S spaceduck
        911 error errno -13
        913 error   cause:
        913 error      path:
        913 error   stack:
        913 error   path:
        914 error
        Architektur: x64
        CPUs: 2
        RAM: 3.81 GB
        Node.js: v10.17.0
        NPM: 6.10.0
        sigi234S Online
        sigi234S Online
        sigi234
        @spaceduck
        Schon mal den Fixer angewandt?
        https://forum.iobroker.net/topic/20211/iobroker-installation-fixer-beta-verfügbar
        Immer Daten sichern!
          spaceduck
          • S spaceduck
            sigi234S Online
            sigi234S Online
            sigi234
            Neustart?
            Was kommt bei:
            cd..iobroker
            node -v
            nodejs -v
            npm -v
            • sigi234S sigi234
              Neustart?
              Was kommt bei:
              cd..iobroker
              node -v
              nodejs -v
              npm -v
              spaceduck
              Danke trotzdem!
