  4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
    6.8k
audiid.3myaudiseatskodaskoda connectvolkswagenvw idwe connectwecharge
3.8k Beiträge 463 Kommentatoren 2.3m Aufrufe 410 Beobachtet
  • M Online
    M Online
    mischelle
    schrieb zuletzt editiert von
    #3761
    ich hab gerade die 0.9.10 installiert bei Tibber angemeldet und auf der Tibber-API nen Client angelegt und die UserID und Secret in die Adaptereinstellungen übertragen. das ganze einige Male immer wieder neu, ohne Erfolg.
    hier das LOG:
    2026-08-25 11:48:48.083 - info: vw-connect.0 (1049150) starting. Version 0.9.10 (non-npm: ta2k/ioBroker.vw-connect) in /opt/iobroker/node_modules/iobroker.vw-connect, node: v22.23.0, js-controller: 7.2.2
    2026-08-25 11:48:48.138 - info: vw-connect.0 (1049150) Trying EU Data Act portal (optional 15-min data source, brand=VOLKSWAGEN_PASSENGER_CARS)
    2026-08-25 11:48:48.233 - info: vw-connect.0 (1049150) Trying Tibber Data API bridge (optional vehicle source)
    2026-08-25 11:48:48.235 - info: vw-connect.0 (1049150) VW ID: classic BFF login unavailable (VW disabled the device_code grant on 2026-08-18). Using the EU Data Act portal as the only data source. See README -> 'EU Data Act portal'.
    2026-08-25 11:48:48.688 - info: vw-connect.0 (1049150) Tibber: 1 device(s) on account
    2026-08-25 11:48:49.295 - info: vw-connect.0 (1049150) EU Data Act portal not available: EU Data Act portal not yet authorised for this account: the VW Identity consent screen is blocking the login. Open https://eu-data-act.drivesomethinggreater.com/ in a browser, log in with the same credentials, click Allow on the consent screen, and finish the portal-side setup (vehicle linking + continuous data request).
    2026-08-25 11:48:49.296 - info: vw-connect.0 (1049150) EU Data Act is the 15-min portal data source. To enable it, log in once at https://eu-data-act.drivesomethinggreater.com/, link your vehicle and configure a continuous 15-minute data request.
    2026-08-25 11:48:49.297 - warn: vw-connect.0 (1049150) VW ID: EU Data Act setup failed (EU Data Act portal not yet authorised for this account: the VW Identity consent screen is blocking the login. Open https://eu-data-act.drivesomethinggreater.com/ in a browser, log in with the same credentials, click Allow on the consent screen, and finish the portal-side setup (vehicle linking + continuous data request).). Will restart adapter in 30 min.
    GaspodeG 1 Antwort Letzte Antwort
      Sneak-L8
      #3762
      Hast Du mal probiert, was in der Meldung steht? Also ein mal bei VW einloggen und die Einwilligung abnicken?
      • M Online
        M Online
        mischelle
        schrieb zuletzt editiert von mischelle
        #3763
        ich wollte ja nicht mit EU Data Act einloggen sondern mit Tibber.
        und oben wird gemelet, dass mit der V 0.9.10 vom 18.8. Tibber wieder geht.
        ist das nicht so?
        • M mischelle
          hier das LOG:
          GaspodeG Online
          GaspodeG Online
          Gaspode
          #3764
          @mischelle sagte:
          Das Tibber Login hat ja anscheinend auch geklappt:
          @mischelle sagte:
          Was steht den bei den Adapter-Objekten? Ich hab jetzt aber nie Tibber ohne EU Data Act Daten versucht abzuholen, evtl. ist das ein Problem?
          @mischelle sagte:
          Wieso wieder? Meines Wissens ging das seit Einführung immer.
          • M Online
            M Online
            mischelle
            #3765
            Anscheinend ging tibber eine zeitlang vor 0.9.10 nicht 🤷
            ich probier mal die EU Data Act identifikation für VW.
            • M Online
              M Online
              mischelle
              #3766
              👍 Danke für deine Hartnäckigkeit :-)
              das funktioniert. volle Anmeldung und kopplung vom Fahrzeug mit EU Data Act UND Tibber.
              dann kann man Tibber verwenden.
              Bleibt mir noch die Frage: was bringt mir die Tibber Verwendung ohne Stromvertrag mit Tibber? die Empfehlung für den VW-Adapter ist ja Tibber auch ohne Stromvertrag.
              kann ich so evtl. Daten auch schneller als 15 Minuten vom Auto abgreifen?
              madingM 1 Antwort Letzte Antwort
              • M mischelle
                madingM Offline
                madingM Offline
                mading
                schrieb zuletzt editiert von mading
                #3767
                @mischelle sagte:
                Lies doch mal bitte den ersten Post!
                • M Online
                  M Online
                  mischelle
                  #3768
                  meinen ersten oder den ersten im Thread? im allerersten Post von 5.Nov 2019 stehen drei Werte drin und ich glaube, dass das nach 7 Jahren nicht mehr aktuell sein kann.
                  in meinem Log steht drin, dass ich mit EU Data Act alle 15 Minuten Daten aktualisieren kann und meine Frage war ja, ob das mit Tibber schneller geht oder was sonst der Vorteil von Tibber ist.
                  • M mischelle
                    Samson71S Offline
                    Samson71S Offline
                    Samson71
                    #3769
                    @mischelle sagte:
                    Schon mal was davon gehört, dass man einen Eröffnungspost, insbesondere den eines Adapters, immer den aktuellen Gegebenheiten anpasst? So auch hier, denn es steht ja auch lesbar drin. Also weniger "glauben", sondern richtig lesen.
                    Markus
                    Bitte beachten:
                    • M Online
                      M Online
                      mischelle
                      #3770
                      ja. klar ihr seid ja alle so schlau. ich lese aber keine 3769 Posts durch wo 80% solche dämlichen Nullhilfen sind wie Eure Aussagen.
                      arteckA Samson71S HomoranH 3 Antworten Letzte Antwort
                      • M mischelle
                        arteckA Offline
                        arteckA Offline
                        arteck
                        schrieb zuletzt editiert von arteck
                        #3771
                        @mischelle
                        sachte mit den junegn Pferden..
                        DU willst Hilfe oder ? also wird von DIR auch erwartet dass DU dich zuerst damit beschäftigst..
                        also entspann dich
                        • M mischelle
                          Samson71S Offline
                          Samson71S Offline
                          Samson71
                          #3772
                          @mischelle sagte:
                          Du hast Dir hiermit gerade eine offizielle Verwarnung eingefangen für Dein ungebührliches Verhalten, bzw. die Beleidigung. Noch so ein Ding und es gibt (erstmal) eine Zeitsperre.
                          Markus
                          Bitte beachten:
                          • M mischelle
                            #3773
                            @mischelle sagte:
                            Nein!
                            Aber den ersten!
                            Und dort steht
                            @tombox sagte:
                            VW hat den klassischen App-Login für VW ID, CUPRA und SEAT abgeschaltet. Für diese Marken funktionieren nur noch zwei Wege — beide unten konfigurierbar, lassen sich auch parallel laufen:
                            EU Data Act Portal — kostenlos, läuft automatisch nach einmaliger Browser-Aktivierung im Portal, liefert ein detailliertes Datenpaket aber nur alle 15 Minuten und ist in der Praxis unzuverlässig: das Auto liefert nur Daten wenn es gerade aktiv ist (fahren, laden, Klima), parkende Autos erzeugen leere Datasets. Außerdem hat das Portal selbst öfter 5xx-Aussetzer.
                            Tibber Data API (empfohlen) — kostenlos, liefert aktuelle Werte (SoC, Reichweite, Lade-Status). Man muss kein Tibber-Stromkunde sein, nur einen Tibber-Account in der App anlegen. Beim Anlegen verlangt die App eine deutsche Adresse — die muss nicht korrekt sein, irgendeine plausible Straße/PLZ reicht. Dann das Fahrzeug in der App verbinden und einen OAuth-Client unter https://data-api.tibber.com/clients/manage registrieren (Details in der Adapter-UI).
                            Diese Info ist flammneu, dein Glaube
                            @mischelle sagte:
                            hat dir nicht geholfen.
                            Vor 7 Jahren gab es das alles nämlich noch nicht
                            Deine Reaktion ist nicht angebracht.
