  4. node.js zerschossen
node.js zerschossen
node
55 Beiträge 7 Kommentatoren 4.7k Aufrufe 5 Beobachtet
  • T toki1973
    @toki1973 [link text](```
    pi@ioBroker-Pi:~ $ iobroker status
    iobroker is not running
    Objects type: file
    States  type: file
    pi@ioBroker-Pi:~ $ iobroker restart
    pi@ioBroker-Pi:~ $ obroker status
    -bash: obroker: Kommando nicht gefunden.
    events.js:183
          throw er; // Unhandled 'error' event
    Error: listen EADDRINUSE 127.0.0.1:9001
        at Server.setupListenHandle [as _listen2] (net.js:1360:14)
        at listenInCluster (net.js:1401:12)
        at doListen (net.js:1510:7)
        at _combinedTickCallback (internal/process/next_tick.js:142:11)
        at process._tickCallback (internal/process/next_tick.js:181:9)
    iobroker is running
    Objects type: file
    States  type: file
    pi@ioBroker-Pi:~ $ iobroker list instances
     Cannot parse /opt/iobroker/iobroker-data/objects.json: RangeError: Array buffer allocation failed
     Cannot parse /opt/iobroker/iobroker-data/objects.json.bak: RangeError: Array buffer allocation failed
    <--- Last few GCs --->
    [5906:0x3289b08]    90566 ms: Mark-sweep 7.0 (10.5) -> 7.0 (10.5) MB, 748.1 / 37.2 ms  allocation failure GC in old space requested
    [5906:0x3289b08]    90689 ms: Mark-sweep 7.0 (10.5) -> 7.0 (10.5) MB, 100.3 / 0.1 ms  last resort GC in old space requested
    [5906:0x3289b08]    91368 ms: Mark-sweep 7.0 (10.5) -> 7.0 (10.5) MB, 678.5 / 20.9 ms  last resort GC in old space requested
    <--- JS stacktrace --->
    ==== JS stack trace =========================================
    Security context: 0x38716201 <JSObject>
        1: toString [buffer.js:611] [bytecode=0x3d4be78d offset=31](this=0x4530dfe9 <Uint8Array map = 0x2eb25789>,encoding=0x3b88417d <undefined>,start=0x3b88417d <undefined>,end=0x3b88417d <undefined>)
        2: arguments adaptor frame: 0->3
        3: __construct(aka __construct) [/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemServer.js:144] [bytecode=0x3f504b9d offset=112](this=0x3b...
    FATAL ERROR: CALL_AND_RETRY_LAST Allocation failed - JavaScript heap out of memory
    /usr/bin/iobroker: Zeile 8:  5898 Abgebrochen             sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js $@
    sigi234S Online
    sigi234S Online
    sigi234
    @toki1973 sagte in node.js zerschossen:
    Wo hast du den Host installiert? Hardware
    Immer Daten sichern!
      toki1973
      Raspberry 3
      NUC, PROXMOX, Grafana, Influx, Unify
        toki1973
        Hat denn wirklich keiner noch Ideen was ich prüfen kann. Der WEb-Adapter auf 8082 ist erreichbar. Admin.0 ist enabled und verwendet den Port 8081.
        Tortzdem ist die Admin Oberfläche nicht erreichbar.
        • T toki1973
          crunchipC Offline
          crunchipC Offline
          @toki1973 hab was altes gefunden, ein Link von @sigi234 aus alten Zeiten, kann man nur leider nicht mehr öffnen
          vllt stimmt etwas mit deinem TCP Port nicht?
            tombox
            Es geht sicher schneller wenn du mit Etcher die SD Karte neukopierst und dann ioBroker und node neu installierst. Wenn du kein Backup hast vorher den Ordner iobroker-data kopieren.
            • PeoplesP Offline
              PeoplesP Offline
              Peoples
              schrieb am zuletzt editiert von Peoples
              Du kannst das Backup (minimal) auch über die Konsole anstoßen, dieses dann wegsichern, dein System neu installieren (manuel oder ein fertiges Image) und dann dein Backup über Konsole oder Adapter wieder zurückspielen. Der Fehler sollte dann weg sein, da beim Rückspielen eines minimalen (normalen) Backups alle Adapter (die im Stable Repository) neu installiert werden.
              Was Alles in Allem ca. 30 Minuten dauert bestimmt schneller als ewig zu suchen
              • PeoplesP Peoples
                toki1973
                Backups habe ich über BackItUp Adapter erstellt. Meint ihr mit neu Installation das Installation Image auf die Karte zu installieren?
                Ein Etcher Backup werden ich dann auch mal machen
                PeoplesP 1 Antwort Letzte Antwort
                • T toki1973
                  PeoplesP Offline
                  PeoplesP Offline
                  Peoples
                  @toki1973
                  1. Backups auf einen externen Datenträger wegsichern.
                  2. Einfach ein neues SD-Image von Iobroker.net laden, dieses dann auf deine SD mit bspw. Etcher.
                  3. IoBroker sollte perfekt anlaufen
                  4. Backup wieder auf die SD unter /opt/iobroker/backups/ kopieren
                  5. Backup zurückspielen Konsole oder Adapter
                  Dann solltest du wieder ein laufendes System haben da wie ich schon sagte beim Zurückspielen eines Minimalen die Adapter neu installiert werden
                    toki1973
                    Okay Danke euch. Dann installiere ich mal die SD Karte neu und schaue was sich retten läßt:)
                    • PeoplesP Offline
                      PeoplesP Offline
                      Peoples
                      Viel Erfolg!
                      • PeoplesP Peoples
                        Viel Erfolg!
                        toki1973
                        @Peoples Danke
                        So die Grundinstallation läuft :) Nur bekomme ich über BackitUp nicht die Auswahl für meine Backups auf der NAS angezeigt.
                        Muss ich das manuell auf den PI kopieren und dann über "lokal" laden? Wie geht das? Wie unterscheiden sich minimal und komplett Backups? Was nehmen?
                        • PeoplesP Offline
                          PeoplesP Offline
                          Peoples
                          Also ich würde (immer) für einen Restore ein lokal auf dem pi liegendes Backup nutzen, was jedoch nicht sein muss.
                          Nimm ein Minimales, dort werden alle Adapter neu installiert von der Repo und nur deine Einstellungen zurück gespielt.
                          Das Komplette spielt den ganzen ordner iobroker zurück mit allen Fehlern sofern vorhanden. Also nutz das nicht. Wird in der nächsten Zeit eh vom Adapter entfernt.
                          sigi234S T 2 Antworten Letzte Antwort
                          • PeoplesP Peoples
                            sigi234S Online
                            sigi234S Online
                            sigi234
                            @Peoples sagte in node.js zerschossen:
                            Da bin ich nicht traurig.
                            • sigi234S sigi234
                              PeoplesP Offline
                              PeoplesP Offline
                              Peoples
                              @sigi234
                              Naja wenn man es richtig benutzt hat wars nicht schlecht zum sichern von eigenen Dateien die im Iobroker-Verzeichnis lagen. Aber es macht mehr Probleme als dass es Nutzen hat
                              • PeoplesP Peoples
                                @sigi234
                                sigi234S Online
                                sigi234S Online
                                sigi234
                                Eben deshalb, habe Windows und sichere nur die iobroker-data
                                • PeoplesP Peoples
                                  toki1973
                                  schrieb am zuletzt editiert von toki1973
                                  @Peoples
                                  Und wie bekomme ich das minmal.xxx.tar file auf den PI über die Konsole kopiert? Und wohin dort?
                                  Enthält das Minimal dann Scripte, Zigbee, Adapter und Objekte?
                                  PeoplesP sigi234S 2 Antworten Letzte Antwort
                                  • T toki1973
                                    @Peoples
                                    PeoplesP Offline
                                    PeoplesP Offline
                                    Peoples
                                    @toki1973
                                    Ja alles da: Views, Scripte, Adapter (sofern nicht in der latest Repo).
                                    Wenn du eine aktive Verbindung zu deiner nas hast dann wähle doch unter wiederherstellen mal das letzte minimal Backup aus das dir dort gelistet wird und versuche es zu restoren.
                                    Wenn du es lokal haben willst kannst du es zum Beispiel mit Winscp (sofern du Windows benutzt) kopieren und zwar in das Verzeichnis /opt/iobroker/backups/
                                    • T toki1973
                                      @Peoples
                                      sigi234S Online
                                      sigi234S Online
                                      sigi234
                                      @Peoples
                                      https://forum.iobroker.net/topic/26148/gelöst-iobroker-wiederherstellung-mit-backitup
                                      • PeoplesP Peoples
                                        @toki1973
                                        toki1973
                                        @Peoples
                                        "Wenn du eine aktive Verbindung zu deiner nas hast dann wähle doch unter wiederherstellen mal das letzte minimal Backup aus das dir dort gelistet wird und versuche es zu restoren."
                                        Da wird nichts gefunden. Über den Windows Filer sehe ich sie. CIFS und SMB1 sollte ja passen.
                                        • T toki1973
                                          @Peoples
                                          PeoplesP Offline
                                          PeoplesP Offline
                                          Peoples
                                          @toki1973
                                          Wenn du magst können wir das auch gerne via Teamviewer machen.
                                          Oder du kopierst es von deiner Nas auf den Pc und spielst es eben über Winscp auf den iob
