  4. Forecast.solar mit dem Systeminfo Adapter
systeminfosolarjson
188 Beiträge 15 Kommentatoren 39.3k Aufrufe 16 Beobachtet
  • GlasfaserG Glasfaser
    @martybr
    Habe schon lange den dritten String , versuche mal hiermit
    //10 Juni 2021 .. Glasfaser Änderung auf 3 Strings
    /* read solar forecasts for 2 different orientations
    Author : gargano
    Display in VIS : use JSON Chart from Scrounger
    Version 1.0.1
    Last Update 16.3.2021
    Change history :
    1.0.1 / 16.3.2021   :   use setStateAsync(myUrl.mySolarJSON.. to avoid time conflicts
                            dp's are now saved in '0_userdata.0.'
                            use variables for setting lat, lon, color..
    const prefix = 'javascript.0.';
    const SolarJSON1            = prefix+"SolarForecast.JSON1";
    const SolarJSON2            = prefix+"SolarForecast.JSON2";
    const SolarJSON3            = prefix+"SolarForecast.JSON3";
    const SolarJSONAll1         = prefix+"SolarForecast.JSONAll1";
    const SolarJSONAll2         = prefix+"SolarForecast.JSONAll2";
    const SolarJSONAll3         = prefix+"SolarForecast.JSONAll3";
    const SolarJSONGraphAll1    = prefix+"SolarForecast.JSONGraphAll1";
    const SolarJSONGraphAll2    = prefix+"SolarForecast.JSONGraphAll2";
    const SolarJSONGraphAll3    = prefix+"SolarForecast.JSONGraphAll3";
    const SolarJSONTable        = prefix+"SolarForecast.JSONTable";
    const SolarJSONGraph        = prefix+"SolarForecast.JSONGraph";
    const createStateList = [
        {name :SolarJSON1, type:"string", role : "value"},
        {name :SolarJSON2, type:"string", role : "value"},
        {name :SolarJSON3, type:"string", role : "value"},
        {name :SolarJSONAll1, type:"string", role : "value"},
        {name :SolarJSONAll2, type:"string", role : "value"},
        {name :SolarJSONAll3, type:"string", role : "value"},
        {name :SolarJSONGraphAll1, type:"string", role : "value"},
        {name :SolarJSONGraphAll2, type:"string", role : "value"},
        {name :SolarJSONGraphAll3, type:"string", role : "value"},
        {name :SolarJSONTable, type:"string", role : "value"},
        {name :SolarJSONGraph, type:"string", role : "value"}
    // create states if not exists
    async function createMyState(item) {
        if (!existsState(item.name)) {
        await createStateAsync(item.name, {
                type: item.type,
                min: 0,
                def: 0,
                role: item.role
    async function makeMyStateList (array) {
        // map array to promises
        const promises = array.map(createMyState);
        await Promise.all(promises);
    var mySchedule = '3 1 * * *';
    async function main () {
        await makeMyStateList(createStateList);
        schedule(mySchedule, getSolar );
        getSolar();
    main();
    // set logging = true for logging
    const logging = true;
    /* https://api.forecast.solar/estimate/:lat/:lon/:dec/:az/:kwp
    lat - latitude of location, -90 (south) … 90 (north)
    lon - longitude of location, -180 (west) … 180 (east)
    dec - plane declination, 0 (horizontal) … 90 (vertical)
    az - plane azimuth, -180 … 180 (-180 = north, -90 = east, 0 = south, 90 = west, 180 = north)
    kwp - installed modules power in kilo watt
    https://api.forecast.solar/estimate/51.38501/6.74986/35/90/2.240'
    // set lat and lon for the destination
    const lat = 'xx.xxxxx'
    const lon = 'x.xxxxx'
    const forcastUrl = 'https://api.forecast.solar';
    // if use the api key remove '//' and insert '//' in front of const api = '';
    //const api = '/xxxxxxxxxxxxxxxx;
    // else
    const api = '';
    const declination = ['30','30','4'];
    const azimuth = ['-90','90','90'];
    const kwp = ['x.xx','x.xx','x.xx'];
    var options1 = {url: forcastUrl+api+'/estimate/'+lat+'/'+lon+'/'+declination[0]+'/'+azimuth[0]+'/'+kwp[0], method: 'GET', headers: { 'User-Agent': 'request' }};
    var options2 = {url: forcastUrl+api+'/estimate/'+lat+'/'+lon+'/'+declination[1]+'/'+azimuth[1]+'/'+kwp[1], method: 'GET', headers: { 'User-Agent': 'request' }};
    var options3 = {url: forcastUrl+api+'/estimate/'+lat+'/'+lon+'/'+declination[2]+'/'+azimuth[2]+'/'+kwp[2], method: 'GET', headers: { 'User-Agent': 'request' }};
    const legendTest = ["Ost","West","West_Carport"];
    const graphColor = ["red","green","blue"];
    const datalabelColor = ["lightgreen","lightblue","lightred"];
    const tooltip_AppendText= " Watt";
    var urls = [
      {myUrl:options1,mySolarJSON:SolarJSON1,mySolarJSONAll:SolarJSONAll1,mySolarJSONGraphAll:SolarJSONGraphAll1},
      {myUrl:options2,mySolarJSON:SolarJSON2,mySolarJSONAll:SolarJSONAll2,mySolarJSONGraphAll:SolarJSONGraphAll2},
      {myUrl:options3,mySolarJSON:SolarJSON3,mySolarJSONAll:SolarJSONAll3,mySolarJSONGraphAll:SolarJSONGraphAll3}
    // handle the request : convert the result to table and graph
    function myAsyncRequest(myUrl) {
      log('Request '+myUrl.myUrl.url);
      return new Promise((resolve, reject) => {
         request(myUrl.myUrl.url, async function(error, response, body) {
            if (!error && response.statusCode == 200) {
                if (logging) console.log ('body : '+body);
                let watts = JSON.parse(body).result.watts;
                setState(myUrl.mySolarJSONAll, JSON.stringify(watts), true);
                let table = [];
                for(let time in watts) {
                        let entry = {};
                        entry.Uhrzeit = time;
                        entry.Leistung = watts[time];
                        table.push(entry);
                if (logging) console.log ('JSON: '+myUrl.mySolarJSON);
                await setStateAsync(myUrl.mySolarJSON, JSON.stringify(table), true);
                // make GraphTable
                let graphTimeData = [];
                        let graphEntry ={};
                        graphEntry.t = Date.parse(time);
                        graphEntry.y = watts[time];
                        graphTimeData.push(graphEntry);
                var graph = {};
                var graphData ={};
                var graphAllData = [];
                graphData.data = graphTimeData;
                graphAllData.push(graphData);
                graph.graphs=graphAllData;
                setState(myUrl.mySolarJSONGraphAll, JSON.stringify(graph), true);
                resolve (body);
            } else
                reject(new Error("Could not load " + myUrl.myUrl.url+' Error '+error +'Status '+ response.statusCode));
    // summarize the single watts results to table and graph
    function makeTable () {
        if (logging) console.log ('MakeTable');
        let watts1 = JSON.parse(getState(SolarJSON1).val);
        let watts2 = JSON.parse(getState(SolarJSON2).val);
        let watts3 = JSON.parse(getState(SolarJSON3).val);
        if (logging) console.log ('Items: '+watts1.length);
        let table = [];
    	let axisLabels = [];
        // make table
        for(var n=0;n<watts1.length;n++) {
                let entry = {};
                entry.Uhrzeit = watts1[n].Uhrzeit;
                entry.Leistung1 = watts1[n].Leistung;
                entry.Leistung2 = watts2[n].Leistung;
                entry.Leistung3 = watts3[n].Leistung;
                entry.Summe = watts1[n].Leistung + watts2[n].Leistung + watts3[n].Leistung;
                table.push(entry);
        // prepare data for graph
    	let graphTimeData1 = [];
        	graphTimeData1.push(watts1[n].Leistung);
            let time = watts1[n].Uhrzeit.substr(11,5);
            axisLabels.push(time);
    	let graphTimeData2 = [];
        for(var n=0;n<watts2.length;n++) {
       		graphTimeData2.push(watts2[n].Leistung);
        let graphTimeData3 = [];
        for(var n=0;n<watts3.length;n++) {
       		graphTimeData3.push(watts3[n].Leistung);
        // make total graph
        var graph = {};
        var graphData = {"tooltip_AppendText":  tooltip_AppendText,"legendText": legendTest[0],"yAxis_id": 1,"type": "bar","displayOrder": 1,"barIsStacked": true,"color":graphColor[0],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[0],"datalabel_fontSize":10};
        graphData.data = graphTimeData1;
    	graphData = {"tooltip_AppendText": tooltip_AppendText,"legendText": legendTest[1],"yAxis_id": 1,"type": "bar","displayOrder": 3,"barIsStacked": true,"color":graphColor[1],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[1],"datalabel_fontSize":10};
        graphData.data = graphTimeData2;
        graphData = {"tooltip_AppendText": tooltip_AppendText,"legendText": legendTest[2],"yAxis_id": 1,"type": "bar","displayOrder": 2,"barIsStacked": true,"color":graphColor[2],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[2],"datalabel_fontSize":10};
        graphData.data = graphTimeData3;
    	graph.axisLabels =  axisLabels;
        setState(SolarJSONTable, JSON.stringify(table), true);
        setState(SolarJSONGraph, JSON.stringify(graph), true);
    // get the requests
    async function getSolar() {
       let promises = urls.map(myAsyncRequest);
        .then(function(bodys) {
            if (logging) console.log("All url loaded");
            makeTable();
        .catch(error => {
            console.log('Error : '+error)
    MartyBr
    #181
    @glasfaser
    Super, klappt. Alle Strings in dem JSON! Ganz herzlichen Dank.
    Martin
    Intel NUCs mit Proxmox / Iobroker als VM unter Debian
    Raspeberry mit USB Leseköpfen für Smartmeter
    Homematic und Homematic IP
      Tigger66
      #182
      Ein Hallo in die Runde
      und eine Frage an die Nutzer dieses Adapters. Ich hab das Problem, das ich bei den Einstellungen in den Instanzen, eigentlich keine Einstellmöglichkeit habe. Bei mir erscheint: "This adapter version has no support for "Admin 4" configuration. Please switch to "Admin 5" UI or downgrade to an older version (see changelog for details). "
      Ich habe aber die Admin Version 5.3.8 installiert. Hat jemand eine Idee woran dass liegen kann? Danke für Eure Unterstützung...
      • T Tigger66
        GlasfaserG Offline
        GlasfaserG Offline
        Glasfaser
        #183
        @tigger66 sagte in Forecast.solar mit dem Systeminfo Adapter:
        ... das wäre dann hier ...
        https://forum.iobroker.net/topic/45315/test-pv-forecast-adapter
          Tigger66
          #184
          ...da habe ich wohl nicht richtig gelesen...danke für den Hinweis...
          • chriz77C Offline
            chriz77C Offline
            chriz77
            #185
            wäre es möglich, die "Adjust forecast" von Forecast.solar einzubauen? Hat jemand damit Erfahrung? Werden die Prognosen damit besser?
            Viele Grüße
            Chris
            EddeE 1 Antwort Letzte Antwort
            • chriz77C chriz77
              Viele Grüße
              Chris
              EddeE Offline
              EddeE Offline
              Edde
              #186
              Hallo zusammen.
              Ich wüsste gerne wie Ihr die Vorhersage für eine 2 String Anlage wählen würdet.
              Ich habe 24 PV Module Richtung osten und weitere 14 Richtung Westen. Alle zusammen liefern etwa 16kw Peak mit einem 11kw Wechselrichter.
              Wie müsste ich nun meine Api erstellen bzw. Mit welchem Azimuth? Die zwei String Auflösung findet dann erst im Adapter statt? Ich mochte natürlich eine theoretische Gesamtprognose für die gesamte Anlage über den Tag verteilt bekommen.
              Screenshot_20240312-045834.png Screenshot_20240312-045853.png Screenshot_20240312-045958~2.png
              • JB_SullivanJ Offline
                JB_Sullivan
                #187
                @Gargano
                Da du der Ersteller des Java Skriptes bist eine Frage:
                Ich habe aktuell den JavaSkript Adapter auf 8.7.5 aktualisiert.
                Als Meldung bekomme ich seit dem für dein Forecast Skript die folgende Meldung. Gibt es schon eine neuere Version die auf httpGet oder axios aufsetzt?
                javascript.0
                8144	2024-07-28 13:17:45.887	warn	script.js.Solar.SolarForcast: request package is deprecated - please use httpGet (or a stable lib like axios) instead!
                • JB_SullivanJ JB_Sullivan
                  @Gargano
                  javascript.0
                  GarganoG Offline
                  GarganoG Offline
                  Gargano
                  schrieb am zuletzt editiert von Gargano
                  #188
                  @jb_sullivan Hier der Code mit axios:
                  getSolar() ist die eigentliche Funktion.
                  Es gibt auch einen Adapter, der aus dem Script hervorging
                  hier der Adapter
                  // Test mit VS Code Extension
                  /* read solar forecasts for 3 different orientations
                  Author : gargano
                  Version 1.1.0
                  Last Update 13.3.2022
                  Change history :
                  use axios
                  const prefix = '0_userdata.0.';
                  const idSolarJSON1        = prefix+"SolarForecast3.SuedOst.JSON";
                  const idSolarJSON2        = prefix+"SolarForecast3.Dach.JSON";
                  const idSolarJSON3        = prefix+"SolarForecast3.SuedWest.JSON";
                  const idSolarToday1       = prefix+"SolarForecast3.SuedOst.Today";
                  const idSolarToday2       = prefix+"SolarForecast3.Dach.Today";
                  const idSolarToday3       = prefix+"SolarForecast3.SuedWest.Today";
                  const idSolarTomorrow1    = prefix+"SolarForecast3.SuedOst.Tomorrow";
                  const idSolarTomorrow2    = prefix+"SolarForecast3.Dach.Tomorrow";
                  const idSolarPanelTomorrow= prefix+"SolarForecast3.Solar.Tomorrow";
                  const idSolarPanelToDay   = prefix+"SolarForecast3.Solar.ToDay";
                  const idSolarTomorrow3    = prefix+"SolarForecast3.SuedWest.Tomorrow";
                  const idSolarJSONTable    = prefix+"SolarForecast3.JSONTable";
                  const idSolarJSONGraph    = prefix+"SolarForecast3.JSONGraph";
                  const idSolarDachJSONGraph    = prefix+"SolarForecast3.Dach.JSONGraph";
                      {name :idSolarJSON1, type:"string", role : "value"},
                      {name :idSolarJSON2, type:"string", role : "value"},
                      {name :idSolarJSON3, type:"string", role : "value"},
                      {name :idSolarToday1, type:"number", role : "value"},
                      {name :idSolarToday2, type:"number", role : "value"},
                      {name :idSolarToday3, type:"number", role : "value"},
                      {name :idSolarTomorrow1, type:"number", role : "value"},
                      {name :idSolarTomorrow2, type:"number", role : "value"},
                      {name :idSolarTomorrow3, type:"number", role : "value"},
                      {name :idSolarPanelTomorrow, type:"number", role : "value"},
                      {name :idSolarPanelToDay, type:"number", role : "value"},
                      {name :idSolarJSONTable, type:"string", role : "value"},
                      {name :idSolarJSONGraph, type:"string", role : "value"},
                      {name :idSolarDachJSONGraph, type:"string", role : "value"}
                              type: item.type,
                              min: 0,
                              def: 0,
                              role: item.role
                      getSolar();
                  main();
                  // define axios and url
                  const axios = require('axios');
                  const lat = myLat;      // defined in global
                  const long = myLon;     // defined in global
                  const url = 'https://api.forecast.solar/estimate/';
                  // Fenster Wohnzimmer
                  var url1 = url+lat+'/'+long+'/90/-30/1';
                  // Dach
                  var url2 = url+lat+'/'+long+'/35/60/6.2';
                  // Fenster Küche / Schlafzimmer
                  var url3 = url+lat+'/'+long+'/90/60/1';
                  const legendTest = ["Wohn","Dach","Küche"];
                  const graphColor = ["red","green","yellow"];
                  const datalabelColor = ["lightgreen","lightblue","lightblue"];
                  const tooltipAppendText= " kWh";
                  var solarJson1;
                  var solarJson2;
                  var solarJson3;
                  var solarJsons = [solarJson1,solarJson2,solarJson3];
                  const idSolarJSONS = [idSolarJSON1,idSolarJSON2,idSolarJSON3]
                  const idSolarToDayS = [idSolarToday1,idSolarToday2,idSolarToday3]
                  const idSolarTomorrowS = [idSolarTomorrow1,idSolarTomorrow2,idSolarTomorrow3]
                  const mySchedule ='{"time":{"start":"03:00","end":"23:00","mode":"hours","interval":1},"period":{"days":1}}'
                  async function makeResponse (thisResponse,thisIDSolarJSON,idx,thisIDSolarToDay,thisIDSolarTomorrow) {
                      // handle success
                      var datetoday = new Date();
                      var datetomorrow = new Date(datetoday.getTime()+(1000 * 60 * 60 * 24 * 1)); // übermorgen wäre dann am Ende eine 2 anstatt 1
                      let today = formatDate(datetoday, 'YYYY-MM-DD');
                      let tomorrow = formatDate(datetomorrow, 'YYYY-MM-DD');
                      var watts = thisResponse.data.result.watts;
                      if (logging) log ('Watts '+JSON.stringify(watts));
                      let table = [];
                              let entry = {};
                              table.push(entry);
                      let kWhToDay = thisResponse.data.result.watt_hours_day[today]/1000;
                      let kWhTomorrow = thisResponse.data.result.watt_hours_day[tomorrow]/1000;
                      solarJsons[idx] = JSON.stringify(table);
                      await setStateAsync(thisIDSolarJSON, JSON.stringify(table), true);
                      await setStateAsync(thisIDSolarToDay, kWhToDay, true);
                      await setStateAsync(thisIDSolarTomorrow, kWhTomorrow, true);
                  async function makeTable () {
                      if (logging) log ('MakeTable');
                      let watts1 = JSON.parse(solarJsons[0]);
                      let watts2 = JSON.parse(solarJsons[1]);
                      let watts3 = JSON.parse(solarJsons[2]);
                      if (logging) log ('Items: '+watts1.length);
                      let table = [];
                      // make table
                              let entry = {};
                              entry.Summe = watts1[n].Leistung + watts2[n].Leistung+ watts3[n].Leistung;
                              table.push(entry);
                      // make total graph
                      var graph = {};
                      var graphData = {"tooltip_AppendText":tooltipAppendText,"legendText": legendTest[0],"yAxis_id": 1,"type": "bar","displayOrder": 1,"barIsStacked": true,"color":graphColor[0],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[0],"datalabel_fontSize":10};
                  	graphData = {"tooltip_AppendText": tooltipAppendText,"legendText": legendTest[1],"yAxis_id": 1,"type": "bar","displayOrder": 2,"barIsStacked": true,"color":graphColor[1],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[1],"datalabel_fontSize":10};
                      graphData = {"tooltip_AppendText": tooltipAppendText,"legendText": legendTest[2],"yAxis_id": 1,"type": "bar","displayOrder": 3,"barIsStacked": true,"color":graphColor[2],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[2],"datalabel_fontSize":10};
                      setState(idSolarJSONTable, JSON.stringify(table), true);
                      setState(idSolarJSONGraph, JSON.stringify(graph), true);
                       // make Dach graph
                      var graph = {};
                      var graphData = {"tooltip_AppendText":tooltipAppendText,"legendText": legendTest[1],"yAxis_id": 1,"type": "bar","displayOrder": 1,"barIsStacked": true,"color":graphColor[0],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[0],"datalabel_fontSize":10};
                      setState(idSolarDachJSONGraph, JSON.stringify(graph), true);
                      const request1 = axios.get(url1);
                      const request2 = axios.get(url2);
                      const request3 = axios.get(url3);
                      let requests = [request1,request2,request3];
                      await axios
                          .all(requests)
                          .then (axios.spread(async (...responses) =>  {
                              // use/access the results
                              for (var n=0;n<responses.length;n++) {
                                  if (logging) console.log(responses[n].data);
                                  await makeResponse (responses[n],idSolarJSONS[n],n,idSolarToDayS[n],idSolarTomorrowS[n]);
                              await makeTable();
                              let vDachToDay = parseFloat(((await getStateAsync(idSolarToday2)).val).toFixed(2));
                              setState(idSolarPanelToDay,vDachToDay);
                              let vDachTomorrow = parseFloat(((await getStateAsync(idSolarTomorrow2)).val).toFixed(2));
                              setState(idSolarPanelTomorrow,vDachTomorrow);
                          .catch(errors => {
                              // react on errors.
                              console.log(errors)
