  4. Forecast.solar mit dem Systeminfo Adapter
systeminfosolarjson
188 Beiträge 15 Kommentatoren 39.3k Aufrufe 16 Beobachtet
  • M MartyBr
    Danke, hat funktioniert und die Werte kommen
    Ich setze hier das komplette (finale Script) für drei Strings rein:
    /* read solar forecasts for 3 different orientations
     Author : gargano
     Display in VIS : use JSON Chart from Scrounger
     Version 1.0.1
     Last Update 16.3.2021
     Change history :
     1.0.1 / 16.3.2021   :   use setStateAsync(myUrl.mySolarJSON.. to avoid time conflicts
                             dp's are now saved in '0_userdata.0.'
                             use variables for setting lat, lon, color..
    1.0.2  / 21.11.2021  :   Umbau auf 3 Strings
    const prefix = 'javascript.2.';
    const SolarJSON1            = prefix+"SolarForecast1.JSON1";
    const SolarJSON2            = prefix+"SolarForecast1.JSON2";
    const SolarJSON3            = prefix+"SolarForecast1.JSON3";
    const SolarJSONAll1         = prefix+"SolarForecast1.JSONAll1";
    const SolarJSONAll2         = prefix+"SolarForecast1.JSONAll2";
    const SolarJSONAll3         = prefix+"SolarForecast1.JSONAll3";
    const SolarJSONGraphAll1    = prefix+"SolarForecast1.JSONGraphAll1";
    const SolarJSONGraphAll2    = prefix+"SolarForecast1.JSONGraphAll2";
    const SolarJSONGraphAll3    = prefix+"SolarForecast1.JSONGraphAll3";
    const SolarJSONTable        = prefix+"SolarForecast1.JSONTable";
    const SolarJSONGraph        = prefix+"SolarForecast1.JSONGraph";
    const createStateList = [
        {name :SolarJSON1, type:"string", role : "value"},
        {name :SolarJSON2, type:"string", role : "value"},
        {name :SolarJSON3, type:"string", role : "value"},
        {name :SolarJSONAll1, type:"string", role : "value"},
        {name :SolarJSONAll2, type:"string", role : "value"},
        {name :SolarJSONAll3, type:"string", role : "value"},
        {name :SolarJSONGraphAll1, type:"string", role : "value"},
        {name :SolarJSONGraphAll2, type:"string", role : "value"},
        {name :SolarJSONGraphAll3, type:"string", role : "value"},
        {name :SolarJSONTable, type:"string", role : "value"},
        {name :SolarJSONGraph, type:"string", role : "value"}
    // create states if not exists
     async function createMyState(item) {
         if (!existsState(item.name)) {
         await createStateAsync(item.name, {
                 type: item.type,
                 min: 0,
                 def: 0,
                 role: item.role
     async function makeMyStateList (array) {
         // map array to promises
         const promises = array.map(createMyState);
         await Promise.all(promises);
     var mySchedule = '0,30 * * * *';
     async function main () {
         await makeMyStateList(createStateList);
         schedule(mySchedule, getSolar );
         getSolar();
     main();
     // set logging = true for logging
     const logging = true;
     var request = require('request');
     /* https://api.forecast.solar/estimate/:lat/:lon/:dec/:az/:kwp
     lat - latitude of location, -90 (south) … 90 (north)
     lon - longitude of location, -180 (west) … 180 (east)
     dec - plane declination, 0 (horizontal) … 90 (vertical)
     az - plane azimuth, -180 … 180 (-180 = north, -90 = east, 0 = south, 90 = west, 180 = north)
     kwp - installed modules power in kilo watt
     // set lat and lon for the destination
     const lat = '52.xxxx'
     const lon = '13.yyyy'
     const forcastUrl = 'https://api.forecast.solar';
     // if use the api key remove '//' and insert '//' in front of const api = '';
     //const api = '/xxxxxxxxxxxxxxxx';
     // else
    const api = '';
     const declination = ['25','25','25'];
     const azimuth = ['-90','0','90'];
     const kwp = ['7.7','6.15','7.7'];
     var options1 = {url: forcastUrl+api+'/estimate/'+lat+'/'+lon+'/'+declination[0]+'/'+azimuth[0]+'/'+kwp[0], method: 'GET', headers: { 'User-Agent': 'request' }};
     var options2 = {url: forcastUrl+api+'/estimate/'+lat+'/'+lon+'/'+declination[1]+'/'+azimuth[1]+'/'+kwp[1], method: 'GET', headers: { 'User-Agent': 'request' }};
     var options3 = {url: forcastUrl+api+'/estimate/'+lat+'/'+lon+'/'+declination[2]+'/'+azimuth[2]+'/'+kwp[2], method: 'GET', headers: { 'User-Agent': 'request' }};
     const legendTest = ["West","Ost"];
     const graphColor = ["blue","red"];
     const datalabelColor = ["lightblue","lightblue"];
     const tooltip_AppendText= " Watt";
     var urls = [
       {myUrl:options1,mySolarJSON:SolarJSON1,mySolarJSONAll:SolarJSONAll1,mySolarJSONGraphAll:SolarJSONGraphAll1},
       {myUrl:options2,mySolarJSON:SolarJSON2,mySolarJSONAll:SolarJSONAll2,mySolarJSONGraphAll:SolarJSONGraphAll2},
       {myUrl:options3,mySolarJSON:SolarJSON3,mySolarJSONAll:SolarJSONAll3,mySolarJSONGraphAll:SolarJSONGraphAll3}
     // handle the request : convert the result to table and graph
     function myAsyncRequest(myUrl) {
       log('Request '+myUrl.myUrl.url);
       return new Promise((resolve, reject) => {
          request(myUrl.myUrl.url, async function(error, response, body) {
             if (!error && response.statusCode == 200) {
                 if (logging) console.log ('body : '+body);
                 let watts = JSON.parse(body).result.watts;
                 setState(myUrl.mySolarJSONAll, JSON.stringify(watts), true);
                 let table = [];
                 for(let time in watts) {
                         let entry = {};
                         entry.Uhrzeit = time;
                         entry.Leistung = watts[time];
                         table.push(entry);
                 if (logging) console.log ('JSON: '+myUrl.mySolarJSON);
                 await setStateAsync(myUrl.mySolarJSON, JSON.stringify(table), true);
                 // make GraphTable
                 let graphTimeData = [];
                         let graphEntry ={};
                         graphEntry.t = Date.parse(time);
                         graphEntry.y = watts[time];
                         graphTimeData.push(graphEntry);
                 var graph = {};
                 var graphData ={};
                 var graphAllData = [];
                 graphData.data = graphTimeData;
                 graphAllData.push(graphData);
                 graph.graphs=graphAllData;
                 setState(myUrl.mySolarJSONGraphAll, JSON.stringify(graph), true);
                 resolve (body);
             } else
                 reject(new Error("Could not load " + myUrl.myUrl.url+' Error '+error +'Status '+ response.statusCode));
     // summarize the single watts results to table and graph
     function makeTable () {
         if (logging) console.log ('MakeTable');
         let watts1 = JSON.parse(getState(SolarJSON1).val);
         let watts2 = JSON.parse(getState(SolarJSON2).val);
         let watts3 = JSON.parse(getState(SolarJSON3).val);
         if (logging) console.log ('Items: '+watts1.length);
         let table = [];
     	let axisLabels = [];
         // make table
         for(var n=0;n<watts1.length;n++) {
                 let entry = {};
                 entry.Uhrzeit = watts1[n].Uhrzeit;
                 entry.Leistung1 = watts1[n].Leistung;
                 entry.Leistung2 = watts2[n].Leistung;
                 entry.Leistung3 = watts3[n].Leistung;
                 entry.Summe = watts1[n].Leistung + watts2[n].Leistung + watts3[n].Leistung;
                 table.push(entry);
         // prepare data for graph
     	let graphTimeData1 = [];
         	graphTimeData1.push(watts1[n].Leistung);
             let time = watts1[n].Uhrzeit.substr(11,5);
             axisLabels.push(time);
     	let graphTimeData2 = [];
         for(var n=0;n<watts2.length;n++) {
        		graphTimeData2.push(watts2[n].Leistung);
     	let graphTimeData3 = [];
         for(var n=0;n<watts3.length;n++) {
        		graphTimeData3.push(watts3[n].Leistung);
         // make total graph
         var graph = {};
         var graphData = {"tooltip_AppendText":  tooltip_AppendText,"legendText": legendTest[0],"yAxis_id": 1,"type": "bar","displayOrder": 2,"barIsStacked": true,"color":graphColor[0],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[0],"datalabel_fontSize":10};
        graphData.data = graphTimeData1;
     	graphData = {"tooltip_AppendText": tooltip_AppendText,"legendText": legendTest[1],"yAxis_id": 1,"type": "bar","displayOrder": 1,"barIsStacked": true,"color":graphColor[1],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[1],"datalabel_fontSize":10};
        graphData.data = graphTimeData2;
        graphData = {"tooltip_AppendText": tooltip_AppendText,"legendText": legendTest[2],"yAxis_id": 1,"type": "bar","displayOrder": 1,"barIsStacked": true,"color":graphColor[1],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[2],"datalabel_fontSize":10};
        graphData.data = graphTimeData3;
     	 graph.axisLabels =  axisLabels;
         setState(SolarJSONTable, JSON.stringify(table), true);
         setState(SolarJSONGraph, JSON.stringify(graph), true);
     // get the requests
     async function getSolar() {
        let promises = urls.map(myAsyncRequest);
         .then(function(bodys) {
             if (logging) console.log("All url loaded");
             makeTable();
         .catch(error => {
             console.log('Error : '+error)
    MartyBr
    #179
    @martybr
    Die Daten des dritten Strings fehlen in dem DP SolarJSINGraph. Ich warte mal bis morgen ab, ob das Script die Daten noch integriert.
    Martin
    Homematic und Homematic IP
    • M MartyBr
      @martybr
      GlasfaserG Offline
      GlasfaserG Offline
      #180
      @martybr
      Habe schon lange den dritten String , versuche mal hiermit
      //10 Juni 2021 .. Glasfaser Änderung auf 3 Strings
      /* read solar forecasts for 2 different orientations
      Author : gargano
      Version 1.0.1
      Change history :
      const prefix = 'javascript.0.';
      const SolarJSON1            = prefix+"SolarForecast.JSON1";
      const SolarJSON2            = prefix+"SolarForecast.JSON2";
      const SolarJSON3            = prefix+"SolarForecast.JSON3";
      const SolarJSONAll1         = prefix+"SolarForecast.JSONAll1";
      const SolarJSONAll2         = prefix+"SolarForecast.JSONAll2";
      const SolarJSONAll3         = prefix+"SolarForecast.JSONAll3";
      const SolarJSONGraphAll1    = prefix+"SolarForecast.JSONGraphAll1";
      const SolarJSONGraphAll2    = prefix+"SolarForecast.JSONGraphAll2";
      const SolarJSONGraphAll3    = prefix+"SolarForecast.JSONGraphAll3";
      const SolarJSONTable        = prefix+"SolarForecast.JSONTable";
      const SolarJSONGraph        = prefix+"SolarForecast.JSONGraph";
                  type: item.type,
                  min: 0,
                  def: 0,
                  role: item.role
      var mySchedule = '3 1 * * *';
          getSolar();
      main();
      https://api.forecast.solar/estimate/51.38501/6.74986/35/90/2.240'
      const lat = 'xx.xxxxx'
      const lon = 'x.xxxxx'
      //const api = '/xxxxxxxxxxxxxxxx;
      // else
      const api = '';
      const declination = ['30','30','4'];
      const azimuth = ['-90','90','90'];
      const kwp = ['x.xx','x.xx','x.xx'];
      const legendTest = ["Ost","West","West_Carport"];
      const graphColor = ["red","green","blue"];
      const datalabelColor = ["lightgreen","lightblue","lightred"];
      var urls = [
                  let table = [];
                          let entry = {};
                          table.push(entry);
                  // make GraphTable
                          let graphEntry ={};
                  var graph = {};
                  var graphData ={};
                  resolve (body);
              } else
          let table = [];
          // make table
                  let entry = {};
                  table.push(entry);
          // make total graph
          var graph = {};
          var graphData = {"tooltip_AppendText":  tooltip_AppendText,"legendText": legendTest[0],"yAxis_id": 1,"type": "bar","displayOrder": 1,"barIsStacked": true,"color":graphColor[0],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[0],"datalabel_fontSize":10};
      	graphData = {"tooltip_AppendText": tooltip_AppendText,"legendText": legendTest[1],"yAxis_id": 1,"type": "bar","displayOrder": 3,"barIsStacked": true,"color":graphColor[1],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[1],"datalabel_fontSize":10};
          graphData = {"tooltip_AppendText": tooltip_AppendText,"legendText": legendTest[2],"yAxis_id": 1,"type": "bar","displayOrder": 2,"barIsStacked": true,"color":graphColor[2],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[2],"datalabel_fontSize":10};
      // get the requests
              makeTable();
          .catch(error => {
      • GlasfaserG Glasfaser
        @martybr
        Author : gargano
        Version 1.0.1
        Change history :
                    type: item.type,
                    min: 0,
                    def: 0,
                    role: item.role
            getSolar();
        main();
        // else
        const api = '';
        var urls = [
                    let table = [];
                            let entry = {};
                            table.push(entry);
                    // make GraphTable
                            let graphEntry ={};
                    var graph = {};
                    var graphData ={};
                    resolve (body);
                } else
            let table = [];
            // make table
                    let entry = {};
                    table.push(entry);
            // make total graph
            var graph = {};
        // get the requests
                makeTable();
            .catch(error => {
        MartyBr
        #181
        @glasfaser
        Super, klappt. Alle Strings in dem JSON! Ganz herzlichen Dank.
        Martin
          Tigger66
          #182
          Ein Hallo in die Runde
          und eine Frage an die Nutzer dieses Adapters. Ich hab das Problem, das ich bei den Einstellungen in den Instanzen, eigentlich keine Einstellmöglichkeit habe. Bei mir erscheint: "This adapter version has no support for "Admin 4" configuration. Please switch to "Admin 5" UI or downgrade to an older version (see changelog for details). "
          Ich habe aber die Admin Version 5.3.8 installiert. Hat jemand eine Idee woran dass liegen kann? Danke für Eure Unterstützung...
          • T Tigger66
            GlasfaserG Offline
            GlasfaserG Offline
            #183
            @tigger66 sagte in Forecast.solar mit dem Systeminfo Adapter:
            ... das wäre dann hier ...
            https://forum.iobroker.net/topic/45315/test-pv-forecast-adapter
              Tigger66
              #184
              ...da habe ich wohl nicht richtig gelesen...danke für den Hinweis...
              • chriz77C Offline
                chriz77C Offline
                chriz77
                #185
                wäre es möglich, die "Adjust forecast" von Forecast.solar einzubauen? Hat jemand damit Erfahrung? Werden die Prognosen damit besser?
                Viele Grüße
                Chris
                EddeE 1 Antwort Letzte Antwort
                • chriz77C chriz77
                  Viele Grüße
                  Chris
                  EddeE Offline
                  EddeE Offline
                  Edde
                  #186
                  Hallo zusammen.
                  Ich wüsste gerne wie Ihr die Vorhersage für eine 2 String Anlage wählen würdet.
                  Ich habe 24 PV Module Richtung osten und weitere 14 Richtung Westen. Alle zusammen liefern etwa 16kw Peak mit einem 11kw Wechselrichter.
                  Wie müsste ich nun meine Api erstellen bzw. Mit welchem Azimuth? Die zwei String Auflösung findet dann erst im Adapter statt? Ich mochte natürlich eine theoretische Gesamtprognose für die gesamte Anlage über den Tag verteilt bekommen.
                  Screenshot_20240312-045834.png Screenshot_20240312-045853.png Screenshot_20240312-045958~2.png
                  • JB_SullivanJ Offline
                    JB_Sullivan
                    #187
                    @Gargano
                    Da du der Ersteller des Java Skriptes bist eine Frage:
                    Ich habe aktuell den JavaSkript Adapter auf 8.7.5 aktualisiert.
                    Als Meldung bekomme ich seit dem für dein Forecast Skript die folgende Meldung. Gibt es schon eine neuere Version die auf httpGet oder axios aufsetzt?
                    javascript.0
                    8144	2024-07-28 13:17:45.887	warn	script.js.Solar.SolarForcast: request package is deprecated - please use httpGet (or a stable lib like axios) instead!
                    GarganoG 1 Antwort Letzte Antwort
                    • JB_SullivanJ JB_Sullivan
                      @Gargano
                      javascript.0
                      GarganoG Offline
                      GarganoG Offline
                      Gargano
                      schrieb am zuletzt editiert von Gargano
                      #188
                      @jb_sullivan Hier der Code mit axios:
                      getSolar() ist die eigentliche Funktion.
                      Es gibt auch einen Adapter, der aus dem Script hervorging
                      hier der Adapter
                      // Test mit VS Code Extension
                      Author : gargano
                      Version 1.1.0
                      Last Update 13.3.2022
                      Change history :
                      use axios
                      const prefix = '0_userdata.0.';
                      const idSolarJSON1        = prefix+"SolarForecast3.SuedOst.JSON";
                      const idSolarJSON2        = prefix+"SolarForecast3.Dach.JSON";
                      const idSolarJSON3        = prefix+"SolarForecast3.SuedWest.JSON";
                      const idSolarToday1       = prefix+"SolarForecast3.SuedOst.Today";
                      const idSolarToday2       = prefix+"SolarForecast3.Dach.Today";
                      const idSolarToday3       = prefix+"SolarForecast3.SuedWest.Today";
                      const idSolarTomorrow1    = prefix+"SolarForecast3.SuedOst.Tomorrow";
                      const idSolarTomorrow2    = prefix+"SolarForecast3.Dach.Tomorrow";
                      const idSolarPanelTomorrow= prefix+"SolarForecast3.Solar.Tomorrow";
                      const idSolarPanelToDay   = prefix+"SolarForecast3.Solar.ToDay";
                      const idSolarTomorrow3    = prefix+"SolarForecast3.SuedWest.Tomorrow";
                      const idSolarJSONTable    = prefix+"SolarForecast3.JSONTable";
                      const idSolarJSONGraph    = prefix+"SolarForecast3.JSONGraph";
                      const idSolarDachJSONGraph    = prefix+"SolarForecast3.Dach.JSONGraph";
                          {name :idSolarJSON1, type:"string", role : "value"},
                          {name :idSolarJSON2, type:"string", role : "value"},
                          {name :idSolarJSON3, type:"string", role : "value"},
                          {name :idSolarToday1, type:"number", role : "value"},
                          {name :idSolarToday2, type:"number", role : "value"},
                          {name :idSolarToday3, type:"number", role : "value"},
                          {name :idSolarTomorrow1, type:"number", role : "value"},
                          {name :idSolarTomorrow2, type:"number", role : "value"},
                          {name :idSolarTomorrow3, type:"number", role : "value"},
                          {name :idSolarPanelTomorrow, type:"number", role : "value"},
                          {name :idSolarPanelToDay, type:"number", role : "value"},
                          {name :idSolarJSONTable, type:"string", role : "value"},
                          {name :idSolarJSONGraph, type:"string", role : "value"},
                          {name :idSolarDachJSONGraph, type:"string", role : "value"}
                                  type: item.type,
                                  min: 0,
                                  def: 0,
                                  role: item.role
                          getSolar();
                      main();
                      // define axios and url
                      const axios = require('axios');
                      const lat = myLat;      // defined in global
                      const long = myLon;     // defined in global
                      const url = 'https://api.forecast.solar/estimate/';
                      // Fenster Wohnzimmer
                      var url1 = url+lat+'/'+long+'/90/-30/1';
                      // Dach
                      var url2 = url+lat+'/'+long+'/35/60/6.2';
                      // Fenster Küche / Schlafzimmer
                      var url3 = url+lat+'/'+long+'/90/60/1';
                      const legendTest = ["Wohn","Dach","Küche"];
                      const graphColor = ["red","green","yellow"];
                      const datalabelColor = ["lightgreen","lightblue","lightblue"];
                      const tooltipAppendText= " kWh";
                      var solarJson1;
                      var solarJson2;
                      var solarJson3;
                      var solarJsons = [solarJson1,solarJson2,solarJson3];
                      const idSolarJSONS = [idSolarJSON1,idSolarJSON2,idSolarJSON3]
                      const idSolarToDayS = [idSolarToday1,idSolarToday2,idSolarToday3]
                      const idSolarTomorrowS = [idSolarTomorrow1,idSolarTomorrow2,idSolarTomorrow3]
                      const mySchedule ='{"time":{"start":"03:00","end":"23:00","mode":"hours","interval":1},"period":{"days":1}}'
                      async function makeResponse (thisResponse,thisIDSolarJSON,idx,thisIDSolarToDay,thisIDSolarTomorrow) {
                          // handle success
                          var datetoday = new Date();
                          var datetomorrow = new Date(datetoday.getTime()+(1000 * 60 * 60 * 24 * 1)); // übermorgen wäre dann am Ende eine 2 anstatt 1
                          let today = formatDate(datetoday, 'YYYY-MM-DD');
                          let tomorrow = formatDate(datetomorrow, 'YYYY-MM-DD');
                          var watts = thisResponse.data.result.watts;
                          if (logging) log ('Watts '+JSON.stringify(watts));
                          let table = [];
                                  let entry = {};
                                  table.push(entry);
                          let kWhToDay = thisResponse.data.result.watt_hours_day[today]/1000;
                          let kWhTomorrow = thisResponse.data.result.watt_hours_day[tomorrow]/1000;
                          solarJsons[idx] = JSON.stringify(table);
                          await setStateAsync(thisIDSolarJSON, JSON.stringify(table), true);
                          await setStateAsync(thisIDSolarToDay, kWhToDay, true);
                          await setStateAsync(thisIDSolarTomorrow, kWhTomorrow, true);
                      async function makeTable () {
                          if (logging) log ('MakeTable');
                          let watts1 = JSON.parse(solarJsons[0]);
                          let watts2 = JSON.parse(solarJsons[1]);
                          let watts3 = JSON.parse(solarJsons[2]);
                          if (logging) log ('Items: '+watts1.length);
                          let table = [];
                          // make table
                                  let entry = {};
                                  entry.Summe = watts1[n].Leistung + watts2[n].Leistung+ watts3[n].Leistung;
                                  table.push(entry);
                          // make total graph
                          var graph = {};
                          var graphData = {"tooltip_AppendText":tooltipAppendText,"legendText": legendTest[0],"yAxis_id": 1,"type": "bar","displayOrder": 1,"barIsStacked": true,"color":graphColor[0],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[0],"datalabel_fontSize":10};
                      	graphData = {"tooltip_AppendText": tooltipAppendText,"legendText": legendTest[1],"yAxis_id": 1,"type": "bar","displayOrder": 2,"barIsStacked": true,"color":graphColor[1],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[1],"datalabel_fontSize":10};
                          graphData = {"tooltip_AppendText": tooltipAppendText,"legendText": legendTest[2],"yAxis_id": 1,"type": "bar","displayOrder": 3,"barIsStacked": true,"color":graphColor[2],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[2],"datalabel_fontSize":10};
                          setState(idSolarJSONTable, JSON.stringify(table), true);
                          setState(idSolarJSONGraph, JSON.stringify(graph), true);
                           // make Dach graph
                          var graph = {};
                          var graphData = {"tooltip_AppendText":tooltipAppendText,"legendText": legendTest[1],"yAxis_id": 1,"type": "bar","displayOrder": 1,"barIsStacked": true,"color":graphColor[0],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[0],"datalabel_fontSize":10};
                          setState(idSolarDachJSONGraph, JSON.stringify(graph), true);
                          const request1 = axios.get(url1);
                          const request2 = axios.get(url2);
                          const request3 = axios.get(url3);
                          let requests = [request1,request2,request3];
                          await axios
                              .all(requests)
                              .then (axios.spread(async (...responses) =>  {
                                  // use/access the results
                                  for (var n=0;n<responses.length;n++) {
                                      if (logging) console.log(responses[n].data);
                                      await makeResponse (responses[n],idSolarJSONS[n],n,idSolarToDayS[n],idSolarTomorrowS[n]);
                                  await makeTable();
                                  let vDachToDay = parseFloat(((await getStateAsync(idSolarToday2)).val).toFixed(2));
                                  setState(idSolarPanelToDay,vDachToDay);
                                  let vDachTomorrow = parseFloat(((await getStateAsync(idSolarTomorrow2)).val).toFixed(2));
                                  setState(idSolarPanelTomorrow,vDachTomorrow);
                              .catch(errors => {
                                  // react on errors.
                                  console.log(errors)
