  4. Forecast.solar mit dem Systeminfo Adapter
systeminfosolarjson
188 Beiträge 15 Kommentatoren 39.3k Aufrufe 16 Beobachtet
  • M MartyBr
    @jb_sullivan sagte in Forecast.solar mit dem Systeminfo Adapter:
        /* read solar forecasts for 2 different orientations        Author : gargano        Display in VIS : use JSON Chart from Scrounger        Version 1.0.1        Last Update 16.3.2021        Change history :        1.0.1 / 16.3.2021   :   use setStateAsync(myUrl.mySolarJSON.. to avoid time conflicts        dp's are now saved in '0_userdata.0.'        use variables for setting lat, lon, color..        */        const prefix = 'javascript.0.';        const SolarJSON1            = prefix+"SolarForecast.JSON1";        const SolarJSON2            = prefix+"SolarForecast.JSON2";        const SolarJSONAll1         = prefix+"SolarForecast.JSONAll1";        const SolarJSONAll2         = prefix+"SolarForecast.JSONAll2";        const SolarJSONGraphAll1    = prefix+"SolarForecast.JSONGraphAll1";        const SolarJSONGraphAll2    = prefix+"SolarForecast.JSONGraphAll2";        const SolarJSONTable        = prefix+"SolarForecast.JSONTable";        const SolarJSONGraph        = prefix+"SolarForecast.JSONGraph";        const createStateList = [        {name :SolarJSON1, type:"string", role : "value"},        {name :SolarJSON2, type:"string", role : "value"},        {name :SolarJSONAll1, type:"string", role : "value"},        {name :SolarJSONAll2, type:"string", role : "value"},        {name :SolarJSONGraphAll1, type:"string", role : "value"},        {name :SolarJSONGraphAll2, type:"string", role : "value"},        {name :SolarJSONTable, type:"string", role : "value"},        {name :SolarJSONGraph, type:"string", role : "value"}        ]        // create states if not exists        async function createMyState(item) {        if (!existsState(item.name)) {        await createStateAsync(item.name, {        type: item.type,        min: 0,        def: 0,        role: item.role        });        }        }        async function makeMyStateList (array) {        // map array to promises        const promises = array.map(createMyState);        await Promise.all(promises);        }        var mySchedule = '0,30 * * * *';        async function main () {        await makeMyStateList(createStateList);        schedule(mySchedule, getSolar );        getSolar();        }        main();        // set logging = true for logging        const logging = true;        var request = require('request');        /* https://api.forecast.solar/estimate/:lat/:lon/:dec/:az/:kwp        lat - latitude of location, -90 (south) … 90 (north)        lon - longitude of location, -180 (west) … 180 (east)        dec - plane declination, 0 (horizontal) … 90 (vertical)        az - plane azimuth, -180 … 180 (-180 = north, -90 = east, 0 = south, 90 = west, 180 = north)        kwp - installed modules power in kilo watt        */        // set lat and lon for the destination        const lat = 'xx.yyyy'        const lon = 'xx.yyy'        const forcastUrl = 'https://api.forecast.solar';        // if use the api key remove '//' and insert '//' in front of const api = '';        //const api = '/xxxxxxxxxxxxxxxx;        // else        const api = '/xxxxxxxxxx';        const declination = ['40','40'];        const azimuth = ['-90','90'];        const kwp = ['7.26','2.64'];        var options1 = {url: forcastUrl+api+'/estimate/'+lat+'/'+lon+'/'+declination[0]+'/'+azimuth[0]+'/'+kwp[0], method: 'GET', headers: { 'User-Agent': 'request' }};        var options2 = {url: forcastUrl+api+'/estimate/'+lat+'/'+lon+'/'+declination[1]+'/'+azimuth[1]+'/'+kwp[1], method: 'GET', headers: { 'User-Agent': 'request' }};        const legendTest = ["West","Ost"];        const graphColor = ["blue","red"];        const datalabelColor = ["lightblue","lightblue"];        const tooltip_AppendText= " Watt";        var urls = [        {myUrl:options1,mySolarJSON:SolarJSON1,mySolarJSONAll:SolarJSONAll1,mySolarJSONGraphAll:SolarJSONGraphAll1},        {myUrl:options2,mySolarJSON:SolarJSON2,mySolarJSONAll:SolarJSONAll2,mySolarJSONGraphAll:SolarJSONGraphAll2}        ]        // handle the request : convert the result to table and graph        function myAsyncRequest(myUrl) {        log('Request '+myUrl.myUrl.url);        return new Promise((resolve, reject) => {        request(myUrl.myUrl.url, async function(error, response, body) {        if (!error && response.statusCode == 200) {        if (logging) console.log ('body : '+body);        let watts = JSON.parse(body).result.watts;        setState(myUrl.mySolarJSONAll, JSON.stringify(watts), true);        let table = [];        for(let time in watts) {        let entry = {};        entry.Uhrzeit = time;        entry.Leistung = watts[time];        table.push(entry);        }        if (logging) console.log ('JSON: '+myUrl.mySolarJSON);        await setStateAsync(myUrl.mySolarJSON, JSON.stringify(table), true);        // make GraphTable        let graphTimeData = [];        for(let time in watts) {        let graphEntry ={};        graphEntry.t = Date.parse(time);        graphEntry.y = watts[time];        graphTimeData.push(graphEntry);        }        var graph = {};        var graphData ={};        var graphAllData = [];        graphData.data = graphTimeData;        graphAllData.push(graphData);        graph.graphs=graphAllData;        setState(myUrl.mySolarJSONGraphAll, JSON.stringify(graph), true);        resolve (body);        } else        reject(new Error("Could not load " + myUrl.myUrl.url+' Error '+error +'Status '+ response.statusCode));        });        })        }        // summarize the single watts results to table and graph        function makeTable () {        if (logging) console.log ('MakeTable');        let watts1 = JSON.parse(getState(SolarJSON1).val);        let watts2 = JSON.parse(getState(SolarJSON2).val);        if (logging) console.log ('Items: '+watts1.length);        let table = [];        let axisLabels = [];        // make table        for(var n=0;n<watts1.length;n++) {        let entry = {};        entry.Uhrzeit = watts1[n].Uhrzeit;        entry.Leistung1 = watts1[n].Leistung;        entry.Leistung2 = watts2[n].Leistung;        entry.Summe = watts1[n].Leistung + watts2[n].Leistung;        table.push(entry);        }        // prepare data for graph        let graphTimeData1 = [];        for(var n=0;n<watts1.length;n++) {        graphTimeData1.push(watts1[n].Leistung);        let time = watts1[n].Uhrzeit.substr(11,5);        axisLabels.push(time);        }        let graphTimeData2 = [];        for(var n=0;n<watts2.length;n++) {        graphTimeData2.push(watts2[n].Leistung);        }        // make total graph        var graph = {};        var graphAllData = [];        var graphData = {"tooltip_AppendText":  tooltip_AppendText,"legendText": legendTest[0],"yAxis_id": 1,"type": "bar","displayOrder": 2,"barIsStacked": true,"color":graphColor[0],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[0],"datalabel_fontSize":10};        graphData.data = graphTimeData1;        graphAllData.push(graphData);        graphData = {"tooltip_AppendText": tooltip_AppendText,"legendText": legendTest[1],"yAxis_id": 1,"type": "bar","displayOrder": 1,"barIsStacked": true,"color":graphColor[1],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[1],"datalabel_fontSize":10};        graphData.data = graphTimeData2;        graphAllData.push(graphData);        graph.graphs=graphAllData;        graph.axisLabels =  axisLabels;        setState(SolarJSONTable, JSON.stringify(table), true);        setState(SolarJSONGraph, JSON.stringify(graph), true);        }        // get the requests        async function getSolar() {        let promises = urls.map(myAsyncRequest);        await Promise.all(promises)        .then(function(bodys) {        if (logging) console.log("All url loaded");        makeTable();        })        .catch(error => {        console.log('Error : '+error)        })        }
    Hallo, ich versuche gerade den Code auf drei Strings umzubauen. Leider kommen immer wieder Fehler. Ich bin ein Javascript Neuling, daher hier die Bitte um Prüfung und Reparatur des Codes.
    Hier der angepasste Code:
     Author : gargano
     Version 1.0.1
     Change history :
    1.0.2  / 21.11.2021  :   Umbau auf 3 Strings
    const prefix = 'javascript.2.';
    const SolarJSON1            = prefix+"SolarForecast1.JSON1";
    const SolarJSON2            = prefix+"SolarForecast1.JSON2";
    const SolarJSON3            = prefix+"SolarForecast1.JSON3";
    const SolarJSONAll1         = prefix+"SolarForecast1.JSONAll1";
    const SolarJSONAll2         = prefix+"SolarForecast1.JSONAll2";
    const SolarJSONAll3         = prefix+"SolarForecast1.JSONAll3";
    const SolarJSONGraphAll1    = prefix+"SolarForecast1.JSONGraphAll1";
    const SolarJSONGraphAll2    = prefix+"SolarForecast1.JSONGraphAll2";
    const SolarJSONGraphAll3    = prefix+"SolarForecast1.JSONGraphAll3";
    const SolarJSONTable        = prefix+"SolarForecast1.JSONTable";
    const SolarJSONGraph        = prefix+"SolarForecast1.JSONGraph";
        {name :SolarJSON3, type:"string", role : "value"},
        {name :SolarJSONAll3, type:"string", role : "value"},
        {name :SolarJSONGraphAll3, type:"string", role : "value"},
                 type: item.type,
                 min: 0,
                 def: 0,
                 role: item.role
         getSolar();
     main();
     const lat = '52.xxxx'
     const lon = '13.yyyy'
     // else
     // const api = '/xxxxxxxxxx';
     const declination = ['25','25','25'];
     const azimuth = ['-90','0','90'];
     const kwp = ['7.7','6.15','7.7'];
     var options3 = {url: forcastUrl+api+'/estimate/'+lat+'/'+lon+'/'+declination[2]+'/'+azimuth[2]+'/'+kwp[2], method: 'GET', headers: { 'User-Agent': 'request' }};
     var urls = [
       {myUrl:options2,mySolarJSON:SolarJSON2,mySolarJSONAll:SolarJSONAll2,mySolarJSONGraphAll:SolarJSONGraphAll2},
       {myUrl:options3,mySolarJSON:SolarJSON3,mySolarJSONAll:SolarJSONAll3,mySolarJSONGraphAll:SolarJSONGraphAll3}
                 let table = [];
                         let entry = {};
                         table.push(entry);
                 // make GraphTable
                         let graphEntry ={};
                 var graph = {};
                 var graphData ={};
                 resolve (body);
             } else
         let watts3 = JSON.parse(getState(SolarJSON3).val);
         let table = [];
         // make table
                 let entry = {};
                 entry.Leistung3 = watts3[n].Leistung;
                 entry.Summe = watts1[n].Leistung + watts2[n].Leistung + watts3[n].Leistung;
                 table.push(entry);
     	let graphTimeData3 = [];
         for(var n=0;n<watts3.length;n++) {
        		graphTimeData3.push(watts3[n].Leistung);
         // make total graph
         var graph = {};
        graphData = {"tooltip_AppendText": tooltip_AppendText,"legendText": legendTest[2],"yAxis_id": 1,"type": "bar","displayOrder": 1,"barIsStacked": true,"color":graphColor[1],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[2],"datalabel_fontSize":10};
        graphData.data = graphTimeData3;
     // get the requests
             makeTable();
         .catch(error => {
    Hier die Fehlermeldung im Script-Editor:
    10:36:03.969	error	javascript.2 (555) script.js.Photovoltaik.Forecast-Solar1: ReferenceError: api is not defined
    10:36:03.969	error	javascript.2 (555) at script.js.Photovoltaik.Forecast-Solar1:99:34
    10:36:03.969	error	javascript.2 (555) at script.js.Photovoltaik.Forecast-Solar1:230:3
    10:36:03.971	error	javascript.2 (555) script.js.Photovoltaik.Forecast-Solar1: TypeError: Cannot read property 'map' of undefined
    10:36:03.971	error	javascript.2 (555) at getSolar (script.js.Photovoltaik.Forecast-Solar1:219:25)
    10:36:03.971	error	javascript.2 (555) at main (script.js.Photovoltaik.Forecast-Solar1:65:6)
    10:36:07.871	info	javascript.2 (555) Stop script script.js.Photovoltaik.Forecast-Solar1
    JoergH
    #175
    @martybr Wozu? Installiere einfach mehrere Instanzen...
    • J JoergH
      MartyBr
      #176
      @joergh
      Das kann man auch machen. Aber dann fehlen die summierten Werte.
      Vielleicht kann hier auch jemand den Fehler finden. Ich teste ja das Script und benutze hier den Public-Zugang, daher auch keine API. Das ist so im Script beschrieben, dass bei einem solchen Zugang const api auskommentiert werden soll.
      Die anderen Fehlermeldungen kann ich nicht interpretieren.
      Martin
      Homematic und Homematic IP
      • M MartyBr
        @joergh
        #177
        @martybr sagte: bei einem solchen Zugang const api auskommentiert werden soll.
        Nicht auskommentieren, sondern einen Leerstring zuweisen. Zeile 93:
        const api = '';
          const api = '';
          MartyBr
          #178
          Danke, hat funktioniert und die Werte kommen
          Ich setze hier das komplette (finale Script) für drei Strings rein:
          /* read solar forecasts for 3 different orientations
           Author : gargano
           Version 1.0.1
           Change history :
                       type: item.type,
                       min: 0,
                       def: 0,
                       role: item.role
               getSolar();
           main();
           //const api = '/xxxxxxxxxxxxxxxx';
           // else
          const api = '';
           var urls = [
                       let table = [];
                               let entry = {};
                               table.push(entry);
                       // make GraphTable
                               let graphEntry ={};
                       var graph = {};
                       var graphData ={};
                       resolve (body);
                   } else
               let table = [];
               // make table
                       let entry = {};
                       table.push(entry);
               // make total graph
               var graph = {};
           // get the requests
                   makeTable();
               .catch(error => {
          Martin
          • M MartyBr
             Author : gargano
             Version 1.0.1
             Change history :
                         type: item.type,
                         min: 0,
                         def: 0,
                         role: item.role
                 getSolar();
             main();
             // else
            const api = '';
             var urls = [
                         let table = [];
                                 let entry = {};
                                 table.push(entry);
                         // make GraphTable
                                 let graphEntry ={};
                         var graph = {};
                         var graphData ={};
                         resolve (body);
                     } else
                 let table = [];
                 // make table
                         let entry = {};
                         table.push(entry);
                 // make total graph
                 var graph = {};
             // get the requests
                     makeTable();
                 .catch(error => {
            MartyBr
            #179
            @martybr
            Die Daten des dritten Strings fehlen in dem DP SolarJSINGraph. Ich warte mal bis morgen ab, ob das Script die Daten noch integriert.
            Martin
            • M MartyBr
              @martybr
              GlasfaserG Offline
              GlasfaserG Offline
              #180
              @martybr
              Habe schon lange den dritten String , versuche mal hiermit
              //10 Juni 2021 .. Glasfaser Änderung auf 3 Strings
              Author : gargano
              Version 1.0.1
              Change history :
              const SolarJSON3            = prefix+"SolarForecast.JSON3";
              const SolarJSONAll3         = prefix+"SolarForecast.JSONAll3";
              const SolarJSONGraphAll3    = prefix+"SolarForecast.JSONGraphAll3";
                          type: item.type,
                          min: 0,
                          def: 0,
                          role: item.role
              var mySchedule = '3 1 * * *';
                  getSolar();
              main();
              https://api.forecast.solar/estimate/51.38501/6.74986/35/90/2.240'
              const lat = 'xx.xxxxx'
              const lon = 'x.xxxxx'
              // else
              const api = '';
              const declination = ['30','30','4'];
              const azimuth = ['-90','90','90'];
              const kwp = ['x.xx','x.xx','x.xx'];
              const legendTest = ["Ost","West","West_Carport"];
              const graphColor = ["red","green","blue"];
              const datalabelColor = ["lightgreen","lightblue","lightred"];
              var urls = [
                          let table = [];
                                  let entry = {};
                                  table.push(entry);
                          // make GraphTable
                                  let graphEntry ={};
                          var graph = {};
                          var graphData ={};
                          resolve (body);
                      } else
                  let table = [];
                  // make table
                          let entry = {};
                          table.push(entry);
                  // make total graph
                  var graph = {};
                  var graphData = {"tooltip_AppendText":  tooltip_AppendText,"legendText": legendTest[0],"yAxis_id": 1,"type": "bar","displayOrder": 1,"barIsStacked": true,"color":graphColor[0],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[0],"datalabel_fontSize":10};
              	graphData = {"tooltip_AppendText": tooltip_AppendText,"legendText": legendTest[1],"yAxis_id": 1,"type": "bar","displayOrder": 3,"barIsStacked": true,"color":graphColor[1],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[1],"datalabel_fontSize":10};
                  graphData = {"tooltip_AppendText": tooltip_AppendText,"legendText": legendTest[2],"yAxis_id": 1,"type": "bar","displayOrder": 2,"barIsStacked": true,"color":graphColor[2],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[2],"datalabel_fontSize":10};
              // get the requests
                      makeTable();
                  .catch(error => {
              • GlasfaserG Glasfaser
                @martybr
                Author : gargano
                Version 1.0.1
                Change history :
                            type: item.type,
                            min: 0,
                            def: 0,
                            role: item.role
                    getSolar();
                main();
                // else
                const api = '';
                var urls = [
                            let table = [];
                                    let entry = {};
                                    table.push(entry);
                            // make GraphTable
                                    let graphEntry ={};
                            var graph = {};
                            var graphData ={};
                            resolve (body);
                        } else
                    let table = [];
                    // make table
                            let entry = {};
                            table.push(entry);
                    // make total graph
                    var graph = {};
                // get the requests
                        makeTable();
                    .catch(error => {
                MartyBr
                #181
                @glasfaser
                Super, klappt. Alle Strings in dem JSON! Ganz herzlichen Dank.
                Martin
                  Tigger66
                  #182
                  Ein Hallo in die Runde
                  und eine Frage an die Nutzer dieses Adapters. Ich hab das Problem, das ich bei den Einstellungen in den Instanzen, eigentlich keine Einstellmöglichkeit habe. Bei mir erscheint: "This adapter version has no support for "Admin 4" configuration. Please switch to "Admin 5" UI or downgrade to an older version (see changelog for details). "
                  Ich habe aber die Admin Version 5.3.8 installiert. Hat jemand eine Idee woran dass liegen kann? Danke für Eure Unterstützung...
                  • T Tigger66
                    GlasfaserG Offline
                    GlasfaserG Offline
                    #183
                    @tigger66 sagte in Forecast.solar mit dem Systeminfo Adapter:
                    ... das wäre dann hier ...
                    https://forum.iobroker.net/topic/45315/test-pv-forecast-adapter
                      Tigger66
                      #184
                      ...da habe ich wohl nicht richtig gelesen...danke für den Hinweis...
                      • chriz77C Offline
                        chriz77C Offline
                        chriz77
                        #185
                        wäre es möglich, die "Adjust forecast" von Forecast.solar einzubauen? Hat jemand damit Erfahrung? Werden die Prognosen damit besser?
                        Viele Grüße
                        Chris
                        EddeE 1 Antwort Letzte Antwort
                        • chriz77C chriz77
                          Viele Grüße
                          Chris
                          EddeE Offline
                          EddeE Offline
                          Edde
                          #186
                          Hallo zusammen.
                          Ich wüsste gerne wie Ihr die Vorhersage für eine 2 String Anlage wählen würdet.
                          Ich habe 24 PV Module Richtung osten und weitere 14 Richtung Westen. Alle zusammen liefern etwa 16kw Peak mit einem 11kw Wechselrichter.
                          Wie müsste ich nun meine Api erstellen bzw. Mit welchem Azimuth? Die zwei String Auflösung findet dann erst im Adapter statt? Ich mochte natürlich eine theoretische Gesamtprognose für die gesamte Anlage über den Tag verteilt bekommen.
                          Screenshot_20240312-045834.png Screenshot_20240312-045853.png Screenshot_20240312-045958~2.png
                          • JB_SullivanJ Offline
                            JB_Sullivan
                            #187
                            @Gargano
                            Da du der Ersteller des Java Skriptes bist eine Frage:
                            Ich habe aktuell den JavaSkript Adapter auf 8.7.5 aktualisiert.
                            Als Meldung bekomme ich seit dem für dein Forecast Skript die folgende Meldung. Gibt es schon eine neuere Version die auf httpGet oder axios aufsetzt?
                            javascript.0
                            8144	2024-07-28 13:17:45.887	warn	script.js.Solar.SolarForcast: request package is deprecated - please use httpGet (or a stable lib like axios) instead!
                            GarganoG 1 Antwort Letzte Antwort
                            • JB_SullivanJ JB_Sullivan
                              @Gargano
                              javascript.0
                              GarganoG Offline
                              GarganoG Offline
                              Gargano
                              schrieb am zuletzt editiert von Gargano
                              #188
                              @jb_sullivan Hier der Code mit axios:
                              getSolar() ist die eigentliche Funktion.
                              Es gibt auch einen Adapter, der aus dem Script hervorging
                              hier der Adapter
                              // Test mit VS Code Extension
                              Author : gargano
                              Version 1.1.0
                              Last Update 13.3.2022
                              Change history :
                              use axios
                              const prefix = '0_userdata.0.';
                              const idSolarJSON1        = prefix+"SolarForecast3.SuedOst.JSON";
                              const idSolarJSON2        = prefix+"SolarForecast3.Dach.JSON";
                              const idSolarJSON3        = prefix+"SolarForecast3.SuedWest.JSON";
                              const idSolarToday1       = prefix+"SolarForecast3.SuedOst.Today";
                              const idSolarToday2       = prefix+"SolarForecast3.Dach.Today";
                              const idSolarToday3       = prefix+"SolarForecast3.SuedWest.Today";
                              const idSolarTomorrow1    = prefix+"SolarForecast3.SuedOst.Tomorrow";
                              const idSolarTomorrow2    = prefix+"SolarForecast3.Dach.Tomorrow";
                              const idSolarPanelTomorrow= prefix+"SolarForecast3.Solar.Tomorrow";
                              const idSolarPanelToDay   = prefix+"SolarForecast3.Solar.ToDay";
                              const idSolarTomorrow3    = prefix+"SolarForecast3.SuedWest.Tomorrow";
                              const idSolarJSONTable    = prefix+"SolarForecast3.JSONTable";
                              const idSolarJSONGraph    = prefix+"SolarForecast3.JSONGraph";
                              const idSolarDachJSONGraph    = prefix+"SolarForecast3.Dach.JSONGraph";
                                  {name :idSolarJSON1, type:"string", role : "value"},
                                  {name :idSolarJSON2, type:"string", role : "value"},
                                  {name :idSolarJSON3, type:"string", role : "value"},
                                  {name :idSolarToday1, type:"number", role : "value"},
                                  {name :idSolarToday2, type:"number", role : "value"},
                                  {name :idSolarToday3, type:"number", role : "value"},
                                  {name :idSolarTomorrow1, type:"number", role : "value"},
                                  {name :idSolarTomorrow2, type:"number", role : "value"},
                                  {name :idSolarTomorrow3, type:"number", role : "value"},
                                  {name :idSolarPanelTomorrow, type:"number", role : "value"},
                                  {name :idSolarPanelToDay, type:"number", role : "value"},
                                  {name :idSolarJSONTable, type:"string", role : "value"},
                                  {name :idSolarJSONGraph, type:"string", role : "value"},
                                  {name :idSolarDachJSONGraph, type:"string", role : "value"}
                                          type: item.type,
                                          min: 0,
                                          def: 0,
                                          role: item.role
                                  getSolar();
                              main();
                              // define axios and url
                              const axios = require('axios');
                              const lat = myLat;      // defined in global
                              const long = myLon;     // defined in global
                              const url = 'https://api.forecast.solar/estimate/';
                              // Fenster Wohnzimmer
                              var url1 = url+lat+'/'+long+'/90/-30/1';
                              // Dach
                              var url2 = url+lat+'/'+long+'/35/60/6.2';
                              // Fenster Küche / Schlafzimmer
                              var url3 = url+lat+'/'+long+'/90/60/1';
                              const legendTest = ["Wohn","Dach","Küche"];
                              const graphColor = ["red","green","yellow"];
                              const datalabelColor = ["lightgreen","lightblue","lightblue"];
                              const tooltipAppendText= " kWh";
                              var solarJson1;
                              var solarJson2;
                              var solarJson3;
                              var solarJsons = [solarJson1,solarJson2,solarJson3];
                              const idSolarJSONS = [idSolarJSON1,idSolarJSON2,idSolarJSON3]
                              const idSolarToDayS = [idSolarToday1,idSolarToday2,idSolarToday3]
                              const idSolarTomorrowS = [idSolarTomorrow1,idSolarTomorrow2,idSolarTomorrow3]
                              const mySchedule ='{"time":{"start":"03:00","end":"23:00","mode":"hours","interval":1},"period":{"days":1}}'
                              async function makeResponse (thisResponse,thisIDSolarJSON,idx,thisIDSolarToDay,thisIDSolarTomorrow) {
                                  // handle success
                                  var datetoday = new Date();
                                  var datetomorrow = new Date(datetoday.getTime()+(1000 * 60 * 60 * 24 * 1)); // übermorgen wäre dann am Ende eine 2 anstatt 1
                                  let today = formatDate(datetoday, 'YYYY-MM-DD');
                                  let tomorrow = formatDate(datetomorrow, 'YYYY-MM-DD');
                                  var watts = thisResponse.data.result.watts;
                                  if (logging) log ('Watts '+JSON.stringify(watts));
                                  let table = [];
                                          let entry = {};
                                          table.push(entry);
                                  let kWhToDay = thisResponse.data.result.watt_hours_day[today]/1000;
                                  let kWhTomorrow = thisResponse.data.result.watt_hours_day[tomorrow]/1000;
                                  solarJsons[idx] = JSON.stringify(table);
                                  await setStateAsync(thisIDSolarJSON, JSON.stringify(table), true);
                                  await setStateAsync(thisIDSolarToDay, kWhToDay, true);
                                  await setStateAsync(thisIDSolarTomorrow, kWhTomorrow, true);
                              async function makeTable () {
                                  if (logging) log ('MakeTable');
                                  let watts1 = JSON.parse(solarJsons[0]);
                                  let watts2 = JSON.parse(solarJsons[1]);
                                  let watts3 = JSON.parse(solarJsons[2]);
                                  if (logging) log ('Items: '+watts1.length);
                                  let table = [];
                                  // make table
                                          let entry = {};
                                          entry.Summe = watts1[n].Leistung + watts2[n].Leistung+ watts3[n].Leistung;
                                          table.push(entry);
                                  // make total graph
                                  var graph = {};
                                  var graphData = {"tooltip_AppendText":tooltipAppendText,"legendText": legendTest[0],"yAxis_id": 1,"type": "bar","displayOrder": 1,"barIsStacked": true,"color":graphColor[0],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[0],"datalabel_fontSize":10};
                              	graphData = {"tooltip_AppendText": tooltipAppendText,"legendText": legendTest[1],"yAxis_id": 1,"type": "bar","displayOrder": 2,"barIsStacked": true,"color":graphColor[1],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[1],"datalabel_fontSize":10};
                                  graphData = {"tooltip_AppendText": tooltipAppendText,"legendText": legendTest[2],"yAxis_id": 1,"type": "bar","displayOrder": 3,"barIsStacked": true,"color":graphColor[2],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[2],"datalabel_fontSize":10};
                                  setState(idSolarJSONTable, JSON.stringify(table), true);
                                  setState(idSolarJSONGraph, JSON.stringify(graph), true);
                                   // make Dach graph
                                  var graph = {};
                                  var graphData = {"tooltip_AppendText":tooltipAppendText,"legendText": legendTest[1],"yAxis_id": 1,"type": "bar","displayOrder": 1,"barIsStacked": true,"color":graphColor[0],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[0],"datalabel_fontSize":10};
                                  setState(idSolarDachJSONGraph, JSON.stringify(graph), true);
                                  const request1 = axios.get(url1);
                                  const request2 = axios.get(url2);
                                  const request3 = axios.get(url3);
                                  let requests = [request1,request2,request3];
                                  await axios
                                      .all(requests)
                                      .then (axios.spread(async (...responses) =>  {
                                          // use/access the results
                                          for (var n=0;n<responses.length;n++) {
                                              if (logging) console.log(responses[n].data);
                                              await makeResponse (responses[n],idSolarJSONS[n],n,idSolarToDayS[n],idSolarTomorrowS[n]);
                                          await makeTable();
                                          let vDachToDay = parseFloat(((await getStateAsync(idSolarToday2)).val).toFixed(2));
                                          setState(idSolarPanelToDay,vDachToDay);
                                          let vDachTomorrow = parseFloat(((await getStateAsync(idSolarTomorrow2)).val).toFixed(2));
                                          setState(idSolarPanelTomorrow,vDachTomorrow);
                                      .catch(errors => {
                                          // react on errors.
                                          console.log(errors)
