  4. Windows Dienst lässt sich nicht mehr starten
    5.6k
windows dienstnode.js
54 Beiträge 4 Kommentatoren 8.3k Aufrufe 4 Beobachtet
  • sigi234S sigi234
    @Stabilostick sagte in Windows Dienst lässt sich nicht mehr starten:
    @sigi234
    need ... more ... input. Welcher Adapter?
    Cannot parse "/Adapter_Icons/vis-views.json
    Cannot parse "/Bilder/vis-views.json
    Cannot parse "/Meine_Icons/vis-views.json
    Cannot parse "/Mond/vis-views.json
    Cannot parse "/Netzwerk/vis-views.json
    Cannot parse "/Radiosender/vis-views.json
    Cannot parse "/Sonstige/vis-views.json
    Cannot parse "/Staubsauger/vis-views.json
    Cannot parse "/Tankstellen_logos/vis-views.json
    Cannot parse "/VIS/vis-views.json
    Cannot parse "/Wetter_HD/vis-views.json
    Cannot parse "/Wettericons/vis-views.json
    Cannot parse "/fire/vis-views.json
    (node:6428) UnhandledPromiseRejectionWarning: FirebaseError: 5 NOT_FOUND: No document to update: projects/iobroker-iogo/databases/(default)/documents/users/A4JRhBHOt8Q3xR8SjK7Q3hW2U8K2/adapters/system_adapter_js-controller
        at new FirestoreError (C:\Program Files\iobroker\Test\node_modules\iobroker.iogo\node_modules\@firebase\firestore\dist\index.node.cjs.js:354:28)
        at ClientDuplexStream.<anonymous> (C:\Program Files\iobroker\Test\node_modules\iobroker.iogo\node_modules\@firebase\firestore\dist\index.node.cjs.js:22313:19)
        at ClientDuplexStream.emit (events.js:198:13)
        at ClientDuplexStream._emitStatusIfDone (C:\Program Files\iobroker\Test\node_modules\iobroker.iogo\node_modules\grpc\src\client.js:234:12)
        at ClientDuplexStream._receiveStatus (C:\Program Files\iobroker\Test\node_modules\iobroker.iogo\node_modules\grpc\src\client.js:211:8)
        at Object.onReceiveStatus (C:\Program Files\iobroker\Test\node_modules\iobroker.iogo\node_modules\grpc\src\client_interceptors.js:1306:15)
        at InterceptingListener._callNext (C:\Program Files\iobroker\Test\node_modules\iobroker.iogo\node_modules\grpc\src\client_interceptors.js:568:42)
        at InterceptingListener.onReceiveStatus (C:\Program Files\iobroker\Test\node_modules\iobroker.iogo\node_modules\grpc\src\client_interceptors.js:618:8)
        at C:\Program Files\iobroker\Test\node_modules\iobroker.iogo\node_modules\grpc\src\client_interceptors.js:1123:18
    (node:6428) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 4)
    (node:6428) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 5)
    (node:6428) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 6)
    { Error [ERR_UNHANDLED_ERROR]: Unhandled error. ('1811161726216929086534298f17edb7')
        at MerossCloud.emit (events.js:187:17)
        at MerossCloudDevice.devices.(anonymous function).on (C:\Program Files\iobroker\Test\node_modules\iobroker.meross\node_modules\meross-cloud\index.js:126:30)
        at MerossCloudDevice.emit (events.js:203:15)
        at MqttClient.client.on (C:\Program Files\iobroker\Test\node_modules\iobroker.meross\node_modules\meross-cloud\index.js:249:18)
        at MqttClient.emit (events.js:198:13)
        at TLSSocket.handleTLSerrors (C:\Program Files\iobroker\Test\node_modules\iobroker.meross\node_modules\mqtt\lib\connect\tls.js:26:18)
        at TLSSocket.emit (events.js:203:15)
        at emitErrorNT (internal/streams/destroy.js:91:8)
        at emitErrorAndCloseNT (internal/streams/destroy.js:59:3)
        at process._tickCallback (internal/process/next_tick.js:63:19) context: '1811161726216929086534298f17edb7' }
    StabilostickS Offline
    Stabilostick
    schrieb am zuletzt editiert von Stabilostick
    @sigi234
    Ich fürchte, da bin ich raus. Firebase, iogo und Meross kenne ich nicht. Gehört das wirklich zum Thema "Windows Dienst lässt sich nicht starten", das hier besprochen wird?
    • StabilostickS Stabilostick
      @sigi234
      sigi234S Online
      sigi234S Online
      sigi234
      @sigi234
      Erledigt.
      Immer Daten sichern!
        @aleks-83 sagte in Windows Dienst lässt sich nicht mehr starten:
        Dann hat er versucht NPM upzugraden.
        Das ging schief.
        Nein, hat er nicht.
        Du hast den neuesten js-controller installiert aus Latest. Dabei ist der Buildvorgang für die optionale Komponente "unix-dgram", die sowieso nur auf Linux funktioniert, fehlgeschlagen. "fsevents" braucht es nur auf Apple-Rechnern. Also alles kein Problem und kein Grund zur Sorge:
        2019-10-14 20:38:12.182 - info: iobroker notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
        2019-10-14 20:38:12.187 - info: iobroker WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.2 (node_modules\iobroker.js-controller\node_modules\unix-dgram)
        2019-10-14 20:38:12.343 - info: iobroker exit 0
        Das ist das Wichtige am Ende. 0 = alles Ok.
        aleks-83
        @Stabilostick
        Sorry, ich meinte nicht NPM updaten sondern den JS Controller.
        Im Ankündigungsthread stand ja dass man Systeme die per Windows Installer erstellt wurden, nicht per npm updaten soll, deshalb hatte ich Sorge dass da was ungewollt gestartet ist. Gerade auch weil ich gestern erst alles neu aufgesetzt habe (mit Migration).
        Also kann ich davon ausgehen dass der JS 2.0.29 bei mir jetzt läuft?
        Oder wirds nur falsch angezeigt? Also dass noch der 1.5.14 installiert ist?
        = Dell Optiplex Micro - 10GB RAM - 200GB SSD - Debian VM =
        = Node.js v20.19.6 = NPM 10.8.2 = JS Controller 7.0.7 =
        Ubiquiti UAP-AC-LR - UAP-AC-Lite - Synology DS716+II - Fritz!Box 7490
        Glasfaser 400
          aleks-83
          schrieb am zuletzt editiert von aleks-83
          Komplettausfall #2
          Jetzt hat der Dienst des ioBroker plötzlich nach der Deinstallation des "mobile" Adapters gestoppt, und lässt sich nicht mehr starten.
          iobroker log während des Absturzes:
          2019-10-16 07:45:06.764  - info: host.NUC(NUCmaster) iobroker del mobile.0
          2019-10-16 07:45:08.910  - info: host.NUC(NUCmaster) iobroker Delete adapter "mobile.0"
          2019-10-16 07:45:08.941  - info: host.NUC(NUCmaster) iobroker host.NUC(NUCmaster) Counted 1 instances of mobile.0
          2019-10-16 07:45:11.870  - info: host.NUC(NUCmaster) iobroker host.NUC(NUCmaster) Deleting 1 object(s).
          2019-10-16 07:45:11.894  - info: host.NUC(NUCmaster) object deleted system.adapter.mobile.0
          2019-10-16 07:45:11.896  - info: lovelace.0 (9380) object system.adapter.mobile.0 deleted
          2019-10-16 07:45:12.921  - info: host.NUC(NUCmaster) iobroker exit 0
          2019-10-16 07:45:27.747  - info: host.NUC(NUCmaster) iobroker del mobile
          2019-10-16 07:45:29.418  - info: host.NUC(NUCmaster) iobroker Delete adapter "mobile"
          2019-10-16 07:45:29.474  - info: host.NUC(NUCmaster) iobroker host.NUC(NUCmaster) Counted 1 adapter for mobile
          2019-10-16 07:45:29.554  - info: host.NUC(NUCmaster) iobroker host.NUC(NUCmaster) Counted 1 states of system.adapter.mobile
          2019-10-16 07:45:29.871  - info: lovelace.0 (9380) object mobile deleted
          2019-10-16 07:45:29.883  - info: lovelace.0 (9380) object mobile.admin deleted
          2019-10-16 07:45:29.895  - info: lovelace.0 (9380) object system.adapter.mobile.upload deleted
          2019-10-16 07:45:29.904  - info: lovelace.0 (9380) object system.adapter.mobile deleted
          2019-10-16 07:45:29.886  - info: host.NUC(NUCmaster) iobroker host.NUC(NUCmaster) Deleting 2 object(s).
          2019-10-16 07:45:29.909  - info: host.NUC(NUCmaster) iobroker npm uninstall iobroker.mobile --silent --save --prefix "D:/ioBroker/NUCmaster" (System call)
          2019-10-16 07:45:30.860  - error: host.NUC(NUCmaster) Cannot write files: D:\ioBroker\NUCmaster\iobroker-data\files\mobile\_data.json: ENOENT: no such file or directory, open 'D:\ioBroker\NUCmaster\iobroker-data\files\mobile\_data.json'
          2019-10-16 07:45:30.861  - error: host.NUC(NUCmaster) Cannot write files: D:\ioBroker\NUCmaster\iobroker-data\files\mobile.admin\_data.json: ENOENT: no such file or directory, open 'D:\ioBroker\NUCmaster\iobroker-data\files\mobile.admin\_data.json'
          2019-10-16 07:45:53.665  - info: geofency.0 (11084) adapter geofency received webhook from device Steffi with values: name: KiGa, entry: 0
          2019-10-16 07:47:04.872  - error: host.NUC(NUCmaster) Objects 127.0.0.1:59186 (Init=false) Redis error:Error: Invalid Chunk: parse failed
          2019-10-16 07:47:04.874  - error: host.NUC(NUCmaster) States 127.0.0.1:59187 (Init=false) Redis error:Error: Invalid Chunk: parse failed
          2019-10-16 07:47:05.682  - error: host.NUC(NUCmaster) Objects 127.0.0.1:59191 (Init=false) Redis error:Error: Invalid Chunk: parse failed
          2019-10-16 07:47:05.850  - error: host.NUC(NUCmaster) States 127.0.0.1:59192 (Init=false) Redis error:Error: Invalid Chunk: parse failed
          2019-10-16 07:47:08.643  - info: host.NUC(NUCmaster) iobroker events.js:174
               throw e
          2019-10-16 07:47:08.644  - info: host.NUC(NUCmaster) iobroker r; // Unhandled 'error' event
          Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
             at Server.setupListenHandle [as _listen2] (net.js:1279:14)
             at listenInCluster (net.js:1327:12)
             at doListen (net.js:1460:7)
          Emitted 'error' event at:
             at emitErrorNT (net.js:1306:8)
          2019-10-16 07:48:28.872  - error: host.NUC(NUCmaster) uncaught exception: ENOENT: no such file or directory, open 'D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller\lib/../io-package.json'
          2019-10-16 07:48:28.907  - info: ping.0 (11592) Got terminate signal TERMINATE_YOURSELF
          2019-10-16 07:48:28.930  - info: geofency.0 (11084) Got terminate signal TERMINATE_YOURSELF
          2019-10-16 07:48:28.926  - info: backitup.0 (8420) Got terminate signal TERMINATE_YOURSELF
          2019-10-16 07:48:28.935  - info: enigma2.0 (6524) Got terminate signal TERMINATE_YOURSELF
          2019-10-16 07:48:28.945  - info: javascript.0 (8992) Got terminate signal TERMINATE_YOURSELF
          2019-10-16 07:48:29.007  - info: enigma2.1 (2716) Got terminate signal TERMINATE_YOURSELF
          2019-10-16 07:48:29.019  - info: email.0 (9008) Got terminate signal TERMINATE_YOURSELF
          2019-10-16 07:48:29.016  - info: text2command.0 (5956) Got terminate signal TERMINATE_YOURSELF
          2019-10-16 07:48:29.023  - info: telegram.0 (5972) Got terminate signal TERMINATE_YOURSELF
          2019-10-16 07:48:29.025  - info: iot.0 (8428) Got terminate signal TERMINATE_YOURSELF
          2019-10-16 07:48:29.020  - info: pushover.0 (8276) Got terminate signal TERMINATE_YOURSELF
          2019-10-16 07:48:29.028  - info: lovelace.0 (9380) Got terminate signal TERMINATE_YOURSELF
          2019-10-16 07:48:29.042  - info: hue-extended.0 (8700) Got terminate signal TERMINATE_YOURSELF
          2019-10-16 07:48:29.046  - info: web.0 (10252) Got terminate signal TERMINATE_YOURSELF
          2019-10-16 07:48:29.100  - info: sonos.0 (8728) Got terminate signal TERMINATE_YOURSELF
          2019-10-16 07:48:28.874  - error: host.NUC(NUCmaster) Error: ENOENT: no such file or directory, open 'D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller\lib/../io-package.json'
             at Object.openSync (fs.js:443:3)
             at Object.readFileSync (fs.js:343:35)
             at Object.getInstalledInfo (D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller\lib\tools.js:533:37)
             at objects.getObjectView (D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller\main.js:1763:42)
             at Immediate.callback.function.setImmediate (D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller\lib\objects\objectsInMemFileDB.js:1813:62)
             at runCallback (timers.js:705:18)
             at tryOnImmediate (timers.js:676:5)
             at processImmediate (timers.js:658:5)
          2019-10-16 07:48:28.876  - info: host.NUC(NUCmaster) stopInstance system.adapter.admin.0
          2019-10-16 07:48:28.876  - info: host.NUC(NUCmaster) stopInstance system.adapter.discovery.0
          2019-10-16 07:48:28.876  - info: host.NUC(NUCmaster) stopInstance system.adapter.history.0
          2019-10-16 07:48:28.876  - info: host.NUC(NUCmaster) stopInstance system.adapter.tr-064.0
          2019-10-16 07:48:28.877  - info: host.NUC(NUCmaster) stopInstance system.adapter.vis.0
          2019-10-16 07:48:28.877  - info: host.NUC(NUCmaster) stopInstance system.adapter.ping.0
          2019-10-16 07:48:28.877  - info: host.NUC(NUCmaster) stopInstance system.adapter.ical.0
          2019-10-16 07:48:28.877  - info: host.NUC(NUCmaster) stopInstance canceled schedule system.adapter.ical.0
          2019-10-16 07:48:28.877  - info: host.NUC(NUCmaster) stopInstance system.adapter.ical.1
          2019-10-16 07:48:28.878  - info: host.NUC(NUCmaster) stopInstance canceled schedule system.adapter.ical.1
          2019-10-16 07:48:28.878  - info: host.NUC(NUCmaster) stopInstance system.adapter.hue.0
          2019-10-16 07:48:28.878  - info: host.NUC(NUCmaster) stopInstance system.adapter.denon.0
          2019-10-16 07:48:28.878  - info: host.NUC(NUCmaster) stopInstance system.adapter.vis-fancyswitch.0
          2019-10-16 07:48:28.878  - info: host.NUC(NUCmaster) stopInstance system.adapter.harmony.0
          2019-10-16 07:48:28.879  - info: host.NUC(NUCmaster) stopInstance system.adapter.vis-timeandweather.0
          2019-10-16 07:48:28.879  - info: host.NUC(NUCmaster) stopInstance system.adapter.firetv.0
          2019-10-16 07:48:28.879  - info: host.NUC(NUCmaster) stopInstance system.adapter.vis-hqwidgets.0
          2019-10-16 07:48:28.879  - info: host.NUC(NUCmaster) stopInstance system.adapter.vis-colorpicker.0
          2019-10-16 07:48:28.879  - info: host.NUC(NUCmaster) stopInstance system.adapter.backitup.0
          2019-10-16 07:48:28.879  - info: host.NUC(NUCmaster) stopInstance system.adapter.geofency.0
          2019-10-16 07:48:28.880  - info: host.NUC(NUCmaster) stopInstance system.adapter.enigma2.0
          2019-10-16 07:48:28.880  - info: host.NUC(NUCmaster) stopInstance system.adapter.vis-metro.0
          2019-10-16 07:48:28.880  - info: host.NUC(NUCmaster) stopInstance system.adapter.mihome-vacuum.0
          2019-10-16 07:48:28.880  - info: host.NUC(NUCmaster) stopInstance system.adapter.vis-canvas-gauges.0
          2019-10-16 07:48:28.880  - info: host.NUC(NUCmaster) stopInstance system.adapter.unifi.0
          2019-10-16 07:48:28.880  - info: host.NUC(NUCmaster) stopInstance system.adapter.stiebel-isg.0
          2019-10-16 07:48:28.880  - info: host.NUC(NUCmaster) stopInstance system.adapter.terminal.0
          2019-10-16 07:48:28.880  - info: host.NUC(NUCmaster) stopInstance system.adapter.alexa2.0
          2019-10-16 07:48:28.881  - info: host.NUC(NUCmaster) stopInstance system.adapter.vis-google-fonts.0
          2019-10-16 07:48:28.881  - info: host.NUC(NUCmaster) stopInstance system.adapter.vis-players.0
          2019-10-16 07:48:28.881  - info: host.NUC(NUCmaster) stopInstance system.adapter.scenes.0
          2019-10-16 07:48:28.881  - info: host.NUC(NUCmaster) stopInstance system.adapter.vis-bars.0
          2019-10-16 07:48:28.882  - info: host.NUC(NUCmaster) stopInstance system.adapter.tankerkoenig.0
          2019-10-16 07:48:28.882  - info: host.NUC(NUCmaster) stopInstance system.adapter.javascript.0
          2019-10-16 07:48:28.882  - info: host.NUC(NUCmaster) stopInstance system.adapter.fritzdect.0
          2019-10-16 07:48:28.883  - info: host.NUC(NUCmaster) stopInstance system.adapter.info.0
          2019-10-16 07:48:28.883  - info: host.NUC(NUCmaster) stopInstance system.adapter.vis-rgraph.0
          2019-10-16 07:48:28.883  - info: host.NUC(NUCmaster) stopInstance system.adapter.gruenbeck.0
          2019-10-16 07:48:28.883  - info: host.NUC(NUCmaster) stopInstance system.adapter.fullybrowser.0
          2019-10-16 07:48:28.884  - info: host.NUC(NUCmaster) stopInstance system.adapter.enigma2.1
          2019-10-16 07:48:28.884  - info: host.NUC(NUCmaster) stopInstance system.adapter.text2command.0
          2019-10-16 07:48:28.884  - info: host.NUC(NUCmaster) stopInstance system.adapter.email.0
          2019-10-16 07:48:28.884  - info: host.NUC(NUCmaster) stopInstance system.adapter.pushover.0
          2019-10-16 07:48:28.885  - info: host.NUC(NUCmaster) stopInstance system.adapter.telegram.0
          2019-10-16 07:48:28.885  - info: host.NUC(NUCmaster) stopInstance system.adapter.iot.0
          2019-10-16 07:48:28.885  - info: host.NUC(NUCmaster) stopInstance system.adapter.smartmeter.0
          2019-10-16 07:48:28.885  - info: host.NUC(NUCmaster) stopInstance system.adapter.lovelace.0
          2019-10-16 07:48:28.888  - info: host.NUC(NUCmaster) stopInstance system.adapter.upnp.0
          2019-10-16 07:48:28.888  - info: host.NUC(NUCmaster) stopInstance system.adapter.mihome.0
          2019-10-16 07:48:28.888  - info: host.NUC(NUCmaster) stopInstance system.adapter.weatherunderground.0
          2019-10-16 07:48:28.888  - info: host.NUC(NUCmaster) stopInstance canceled schedule system.adapter.weatherunderground.0
          2019-10-16 07:48:28.889  - info: host.NUC(NUCmaster) stopInstance system.adapter.fakeroku.0
          2019-10-16 07:48:28.889  - info: host.NUC(NUCmaster) stopInstance system.adapter.hue-extended.0
          2019-10-16 07:48:28.889  - info: host.NUC(NUCmaster) stopInstance system.adapter.web.0
          2019-10-16 07:48:28.889  - info: host.NUC(NUCmaster) stopInstance system.adapter.socketio.0
          2019-10-16 07:48:28.889  - info: host.NUC(NUCmaster) stopInstance system.adapter.sonos.0
          2019-10-16 07:48:28.889  - info: host.NUC(NUCmaster) stopInstance system.adapter.dwd.0
          2019-10-16 07:48:28.890  - info: host.NUC(NUCmaster) stopInstance canceled schedule system.adapter.dwd.0
          2019-10-16 07:48:28.890  - info: host.NUC(NUCmaster) iobroker _restart
          2019-10-16 07:48:28.901  - info: host.NUC(NUCmaster) stopInstance system.adapter.admin.0 send kill signal
          2019-10-16 07:48:28.904  - info: host.NUC(NUCmaster) stopInstance system.adapter.tr-064.0 send kill signal
          2019-10-16 07:48:28.907  - info: host.NUC(NUCmaster) stopInstance system.adapter.ping.0 send kill signal
          2019-10-16 07:48:28.915  - info: host.NUC(NUCmaster) stopInstance system.adapter.hue.0 send kill signal
          2019-10-16 07:48:28.918  - info: host.NUC(NUCmaster) stopInstance system.adapter.harmony.0 send kill signal
          2019-10-16 07:48:28.925  - info: host.NUC(NUCmaster) stopInstance system.adapter.backitup.0 send kill signal
          2019-10-16 07:48:28.930  - info: host.NUC(NUCmaster) stopInstance system.adapter.geofency.0 send kill signal
          2019-10-16 07:48:28.934  - info: host.NUC(NUCmaster) stopInstance system.adapter.enigma2.0 send kill signal
          2019-10-16 07:48:28.936  - info: host.NUC(NUCmaster) stopInstance system.adapter.alexa2.0 send kill signal
          2019-10-16 07:48:28.940  - info: host.NUC(NUCmaster) stopInstance system.adapter.tankerkoenig.0 send kill signal
          2019-10-16 07:48:28.944  - info: host.NUC(NUCmaster) stopInstance system.adapter.javascript.0 send kill signal
          2019-10-16 07:48:28.947  - info: host.NUC(NUCmaster) stopInstance system.adapter.fritzdect.0 send kill signal
          2019-10-16 07:48:28.951  - info: host.NUC(NUCmaster) stopInstance system.adapter.info.0 send kill signal
          2019-10-16 07:48:28.952  - info: host.NUC(NUCmaster) stopInstance system.adapter.gruenbeck.0 send kill signal
          2019-10-16 07:48:29.002  - info: host.NUC(NUCmaster) stopInstance system.adapter.fullybrowser.0 send kill signal
          2019-10-16 07:48:29.005  - info: host.NUC(NUCmaster) stopInstance system.adapter.enigma2.1 send kill signal
          2019-10-16 07:48:29.015  - info: host.NUC(NUCmaster) stopInstance system.adapter.text2command.0 send kill signal
          2019-10-16 07:48:29.017  - info: host.NUC(NUCmaster) stopInstance system.adapter.email.0 send kill signal
          2019-10-16 07:48:29.019  - info: host.NUC(NUCmaster) stopInstance system.adapter.pushover.0 send kill signal
          2019-10-16 07:48:29.021  - info: host.NUC(NUCmaster) stopInstance system.adapter.telegram.0 send kill signal
          2019-10-16 07:48:29.023  - info: host.NUC(NUCmaster) stopInstance system.adapter.iot.0 send kill signal
          2019-10-16 07:48:29.026  - info: host.NUC(NUCmaster) stopInstance system.adapter.lovelace.0 send kill signal
          2019-10-16 07:48:29.028  - info: host.NUC(NUCmaster) stopInstance system.adapter.upnp.0 send kill signal
          2019-10-16 07:48:29.030  - info: host.NUC(NUCmaster) stopInstance system.adapter.mihome.0 send kill signal
          2019-10-16 07:48:29.037  - info: host.NUC(NUCmaster) stopInstance system.adapter.fakeroku.0 send kill signal
          2019-10-16 07:48:29.040  - info: host.NUC(NUCmaster) stopInstance system.adapter.hue-extended.0 send kill signal
          2019-10-16 07:48:29.044  - info: host.NUC(NUCmaster) stopInstance system.adapter.web.0 send kill signal
          2019-10-16 07:48:29.046  - info: host.NUC(NUCmaster) stopInstance system.adapter.socketio.0 send kill signal
          2019-10-16 07:48:29.054  - info: host.NUC(NUCmaster) stopInstance system.adapter.sonos.0 send kill signal
          2019-10-16 07:48:28.946  - ( Hier wurden alle Skripte gestoppt )
          2019-10-16 07:48:29.141  - info: javascript.0 (8992) terminating
          2019-10-16 07:48:29.142  - info: javascript.0 (8992) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2019-10-16 07:48:29.320  - info: host.NUC(NUCmaster) instance system.adapter.geofency.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
          2019-10-16 07:48:29.323  - info: host.NUC(NUCmaster) instance system.adapter.harmony.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
          2019-10-16 07:48:29.326  - info: host.NUC(NUCmaster) instance system.adapter.tr-064.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
          2019-10-16 07:48:29.413  - info: ping.0 (11592) terminating
          2019-10-16 07:48:29.414  - info: ping.0 (11592) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2019-10-16 07:48:29.431  - info: backitup.0 (8420) terminating
          2019-10-16 07:48:29.439  - info: enigma2.0 (6524) terminating
          2019-10-16 07:48:29.511  - info: enigma2.1 (2716) terminating
          2019-10-16 07:48:29.521  - info: email.0 (9008) terminating
          2019-10-16 07:48:29.523  - info: text2command.0 (5956) terminating
          2019-10-16 07:48:29.522  - info: email.0 (9008) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2019-10-16 07:48:29.527  - info: pushover.0 (8276) terminating
          2019-10-16 07:48:29.532  - info: telegram.0 (5972) terminating
          2019-10-16 07:48:29.533  - info: telegram.0 (5972) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2019-10-16 07:48:29.663  - info: host.NUC(NUCmaster) instance system.adapter.fritzdect.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
          2019-10-16 07:48:29.665  - info: host.NUC(NUCmaster) instance system.adapter.hue.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
          2019-10-16 07:48:29.666  - info: host.NUC(NUCmaster) instance system.adapter.alexa2.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
          2019-10-16 07:48:29.668  - info: host.NUC(NUCmaster) instance system.adapter.hue-extended.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
          2019-10-16 07:48:29.670  - info: host.NUC(NUCmaster) instance system.adapter.socketio.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
          2019-10-16 07:48:29.671  - info: host.NUC(NUCmaster) instance system.adapter.fakeroku.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
          2019-10-16 07:48:29.673  - info: host.NUC(NUCmaster) instance system.adapter.lovelace.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
          2019-10-16 07:48:29.674  - info: host.NUC(NUCmaster) instance system.adapter.upnp.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
          2019-10-16 07:48:29.676  - info: host.NUC(NUCmaster) instance system.adapter.info.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
          2019-10-16 07:48:29.677  - info: host.NUC(NUCmaster) instance system.adapter.sonos.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
          2019-10-16 07:48:29.679  - info: host.NUC(NUCmaster) instance system.adapter.mihome.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
          2019-10-16 07:48:29.680  - info: host.NUC(NUCmaster) instance system.adapter.iot.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
          2019-10-16 07:48:29.682  - info: host.NUC(NUCmaster) instance system.adapter.gruenbeck.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
          2019-10-16 07:48:29.683  - info: host.NUC(NUCmaster) instance system.adapter.web.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
          2019-10-16 07:48:29.685  - info: host.NUC(NUCmaster) instance system.adapter.fullybrowser.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
          2019-10-16 07:48:29.739  - error: host.NUC(NUCmaster) iobroker internal/modules/cjs/loader.js:638
             throw err;
          Error: Cannot find module 'D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller\iobroker.js'
             at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
             at Function.Module._load (internal/modules/cjs/loader.js:562:25)
             at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
             at startup (internal/bootstrap/node.js:283:19)
             at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3)
          2019-10-16 07:48:29.766  - info: host.NUC(NUCmaster) iobroker exit 1
          2019-10-16 07:48:30.073  - info: host.NUC(NUCmaster) instance system.adapter.admin.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
          2019-10-16 07:48:30.075  - info: host.NUC(NUCmaster) instance system.adapter.javascript.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
          2019-10-16 07:48:30.076  - info: host.NUC(NUCmaster) instance system.adapter.ping.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
          2019-10-16 07:48:30.076  - info: host.NUC(NUCmaster) instance system.adapter.enigma2.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
          2019-10-16 07:48:30.077  - info: host.NUC(NUCmaster) instance system.adapter.backitup.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
          2019-10-16 07:48:30.078  - info: host.NUC(NUCmaster) instance system.adapter.tankerkoenig.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
          2019-10-16 07:48:30.078  - info: host.NUC(NUCmaster) instance system.adapter.enigma2.1 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
          2019-10-16 07:48:30.079  - info: host.NUC(NUCmaster) instance system.adapter.email.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
          2019-10-16 07:48:30.079  - info: host.NUC(NUCmaster) instance system.adapter.text2command.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
          2019-10-16 07:48:30.080  - info: host.NUC(NUCmaster) instance system.adapter.pushover.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
          2019-10-16 07:48:30.080  - info: host.NUC(NUCmaster) instance system.adapter.telegram.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
          2019-10-16 07:48:31.235  - info: host.NUC(NUCmaster) stopInstance timeout "2000 system.adapter.history.0 killing pid  8360
          2019-10-16 07:48:31.270  - warn: host.NUC(NUCmaster) instance system.adapter.history.0 terminated due to SIGTERM
          2019-10-16 07:48:31.271  - info: host.NUC(NUCmaster) instance system.adapter.history.0 terminated with code null ()
          2019-10-16 07:48:31.271  - info: host.NUC(NUCmaster) All instances are stopped.
          2019-10-16 07:48:31.441  - info: host.NUC(NUCmaster) terminated
          Windows Dienste beim Versuch den Dienst zu starten:
          ioBroker.wrapper.log beim Versuch den Dienst zu starten:
          2019-10-16 08:12:24,317 INFO  - Starting ServiceWrapper in the service mode
          2019-10-16 08:12:24,368 INFO  - Starting "D:\ioBroker\NUCmaster\nodejs\node.exe" "D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller\controller.js"
          2019-10-16 08:12:24,375 INFO  - Starting "D:\ioBroker\NUCmaster\nodejs\node.exe" "D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller\controller.js"
          2019-10-16 08:12:24,418 INFO  - Started process 5864
          2019-10-16 08:12:24,430 DEBUG - Forwarding logs of the process System.Diagnostics.Process (node) to winsw.RollingSizeTimeLogAppender
          iobroker.err.log beim Versuch den Dienst zu starten:
          Error: Cannot find module 'D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller\controller.js'
          Glasfaser 400
          • A aleks-83
            Komplettausfall #2
                 throw e
               throw err;
            apollon77A Online
            apollon77A Online
            @aleks-83 hm ... da hat npm was kaputt gemacht. Bitte js Controller wieder Manuel installieren.
              aleks-83
              OK, wie mache ich das unter Windows?
              Das Update auf 2.0.29 ist ja eh "versehentlich" passiert durch den button "alle Adapter updaten".
              Kann ich dann jetzt erst wieder zurück zu 1.5.14?
              Glasfaser 400
              StabilostickS 1 Antwort Letzte Antwort
              • A aleks-83
                Stabilostick
                @aleks-83
                Kann es sein, dass Du in der ioBroker Konfiguration vor der Migration diesen auf „latest“ stehen hattest? Das würde die Installation von 2.0.29 erklären.
                Ist die Datei „ D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller\controller.js“ vorhanden?
                A 1 Antwort Letzte Antwort
                  @aleks-83
                  aleks-83
                  @aleks-83
                  Ja, hatte ich.
                  Soll ich nochmal neu migrieren?
                  Und sobald der Admin startet, direkt als erstes auf "stable" stellen?
                  Nein, es gibt den Ordner "iobroker.js-controller" nicht.
                  Glasfaser 400
                  • A aleks-83
                    @aleks-83
                    Ja, hatte ich.
                    Stabilostick
                    Wau. Na dann mache mal die Kommandozeile der Instanz über das Startmenü auf und führe aus:
                    npm install iobroker.js-controller@latest --production
                    Was passiert da dann?
                      aleks-83
                      Er scheint was installiert zu haben.
                      Sind aber auch viele ERR Meldungen dabei:
                      D:\ioBroker\NUCmaster>npm install iobroker.js-controller@latest --production
                      > iobroker.js-controller@2.0.29 preinstall D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller
                      > node lib/preinstallCheck.js
                      NPM version: 6.9.0
                      > authenticate-pam@1.0.2 install D:\ioBroker\NUCmaster\node_modules\authenticate-pam
                      > node-gyp rebuild
                      D:\ioBroker\NUCmaster\node_modules\authenticate-pam>if not defined npm_config_node_gyp (node "D:\ioBroker\NUCmaster\nodejs\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin\\..\..\node_modules\node-gyp\bin\node-gyp.js" rebuild )  else (node "D:\ioBroker\NUCmaster\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" rebuild )
                      Die Projekte in dieser Projektmappe werden nacheinander erstellt. Um eine parallele Erstellung zu ermöglichen, müssen Sie den Schalter "/m" hinzufügen.
                       authenticate_pam.cc
                       win_delay_load_hook.cc
                      d:\iobroker\nucmaster\node_modules\authenticate-pam\authenticate_pam.cc(24): fatal error C1083: Datei (Include) kann nicht geöffnet werden: "uni
                      std.h": No such file or directory [D:\ioBroker\NUCmaster\node_modules\authenticate-pam\build\authenticate_pam.vcxproj]
                      gyp ERR! build error
                      gyp ERR! stack Error: `C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe` failed with exit code: 1
                      gyp ERR! stack     at ChildProcess.onExit (D:\ioBroker\NUCmaster\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:262:23)
                      gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
                      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                      gyp ERR! System Windows_NT 10.0.18362
                      gyp ERR! command "D:\\ioBroker\\NUCmaster\\nodejs\\node.exe" "D:\\ioBroker\\NUCmaster\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
                      gyp ERR! cwd D:\ioBroker\NUCmaster\node_modules\authenticate-pam
                      gyp ERR! node -v v10.16.3
                      gyp ERR! node-gyp -v v3.8.0
                      gyp ERR! not ok
                      > serialport@6.2.2 install D:\ioBroker\NUCmaster\node_modules\iobroker.discovery\node_modules\serialport
                      > prebuild-install || node-gyp rebuild
                      > unix-dgram@2.0.2 install D:\ioBroker\NUCmaster\node_modules\unix-dgram
                      > node-gyp rebuild
                      D:\ioBroker\NUCmaster\node_modules\unix-dgram>if not defined npm_config_node_gyp (node "D:\ioBroker\NUCmaster\nodejs\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin\\..\..\node_modules\node-gyp\bin\node-gyp.js" rebuild )  else (node "D:\ioBroker\NUCmaster\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" rebuild )
                       unix_dgram.cc
                      d:\iobroker\nucmaster\node_modules\unix-dgram\src\unix_dgram.cc(9): fatal error C1083: Datei (Include) kann nicht geöffnet werden: "unistd.h": N
                      o such file or directory [D:\ioBroker\NUCmaster\node_modules\unix-dgram\build\unix_dgram.vcxproj]
                      gyp ERR! cwd D:\ioBroker\NUCmaster\node_modules\unix-dgram
                      gyp ERR! not ok
                      > ursa-optional@0.9.10 install D:\ioBroker\NUCmaster\node_modules\ursa-optional
                      > node rebuild.js
                      > diskusage@1.1.3 install D:\ioBroker\NUCmaster\node_modules\diskusage
                      > node-gyp rebuild
                      D:\ioBroker\NUCmaster\node_modules\diskusage>if not defined npm_config_node_gyp (node "D:\ioBroker\NUCmaster\nodejs\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin\\..\..\node_modules\node-gyp\bin\node-gyp.js" rebuild )  else (node "D:\ioBroker\NUCmaster\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" rebuild )
                       main.cpp
                       diskusage_win.cpp
                          Bibliothek "D:\ioBroker\NUCmaster\node_modules\diskusage\build\Release\diskusage.lib" und Objekt "D:\ioBroker\NUCmaster\node_modules\diskus
                       age\build\Release\diskusage.exp" werden erstellt.
                       Code wird generiert.
                       All 262 functions were compiled because no usable IPDB/IOBJ from previous compilation was found.
                       Codegenerierung ist abgeschlossen.
                       diskusage.vcxproj -> D:\ioBroker\NUCmaster\node_modules\diskusage\build\Release\\diskusage.node
                      > iobroker.js-controller@2.0.29 install D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller
                      > node iobroker.js setup first
                      > acme-v2@1.8.5 postinstall D:\ioBroker\NUCmaster\node_modules\acme-v2
                      > node scripts/postinstall
                      👉  Do you rely on Greenlock?  👈
                      👉               (or ACME.js)  👈
                      Hey! Let's Encrypt will STOP WORKING with Greenlock and ACME.js at the end of Oct 2019.
                      WITHOUT YOUR HELP we won't get the next release out in time.
                      If Greenlock (or ACME.js) has saved you time and money, and taken stress out of your life,
                      or you just love it, please reach out to return the favor today:
                      SAVE GREENLOCK / ACME.js:
                      https://indiegogo.com/at/greenlock
                      npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/common@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
                      npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/core@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.1 (node_modules\fsevents):
                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules\osx-temperature-sensor):
                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules\authenticate-pam):
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuild`
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.2 (node_modules\unix-dgram):
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.2 install: `node-gyp rebuild`
                      + iobroker.js-controller@2.0.29
                      added 207 packages from 214 contributors, removed 74 packages, updated 3 packages, moved 10 packages and audited 1566 packages in 117.15s
                      found 12 vulnerabilities (9 low, 3 high)
                       run `npm audit fix` to fix them, or `npm audit` for details
                      Läuft wieder alles.
                      Glasfaser 400
                      • A aleks-83
                        NPM version: 6.9.0
                        > node-gyp rebuild
                         authenticate_pam.cc
                        gyp ERR! not ok
                        > node-gyp rebuild
                         unix_dgram.cc
                        gyp ERR! not ok
                        > node rebuild.js
                        > node-gyp rebuild
                         main.cpp
                         diskusage_win.cpp
                        👉               (or ACME.js)  👈
                        Läuft wieder alles.
                        Stabilostick
                        @aleks-83
                        npm install @angular/common@
                        npm install @angular/core@
                        Sieht aber schon einmal trotz der Meldungen gut aus. Bist freiwilliger Betatester, weil Du Dein System auf „latest“ stehen hast. 👌 🤗
                          aleks-83
                          OK, habe ich durchgeführt.
                          D:\ioBroker\NUCmaster>npm install @angular/common@
                          > node-gyp rebuild
                            authenticate_pam.cc
                          gyp ERR! not ok
                          > node-gyp rebuild
                            unix_dgram.cc
                          gyp ERR! not ok
                          npm WARN @angular/common@8.2.11 requires a peer of rxjs@^6.4.0 but none is installed. You must install peer dependencies yourself.
                          npm WARN @angular/common@8.2.11 requires a peer of @angular/core@8.2.11 but none is installed. You must install peer dependencies yourself.
                          + @angular/common@8.2.11
                          added 2 packages from 2 contributors and audited 1568 packages in 303.548s
                            run `np
                          [/s]m audit fix` to fix them, or `npm audit` for details
                          D:\ioBroker\NUCmaster>npm install @angular/core@
                          > node-gyp rebuild
                            authenticate_pam.cc
                          gyp ERR! not ok
                          > node-gyp rebuild
                            unix_dgram.cc
                          gyp ERR! not ok
                          npm WARN @angular/core@8.2.11 requires a peer of rxjs@^6.4.0 but none is installed. You must install peer dependencies yourself.
                          npm WARN @angular/core@8.2.11 requires a peer of zone.js@~0.9.1 but none is installed. You must install peer dependencies yourself.
                          + @angular/core@8.2.11
                          added 1 package from 1 contributor and audited 1570 packages in 70.735s
                          @Stabilostick
                          Bist freiwilliger Betatester, weil Du Dein System auf „latest“ stehen hast. 👍🏻🤗
                          "Freiwillig", ja 😂
                          Eigentlich möchte ich nur dass es wieder (rund) läuft... 🤕
                          Glasfaser 400
                            aleks-83
                            Wie kann ich denn bitte wieder zurück zum JS 1.5.14 downgraden?
                            Mit dem 2.x habe ich immer wieder mal Probleme.
                            Bin jetzt bei 2.0.38.
                            Admin 3.6.10
                            Javascript 4.3.1
                            Aktuell zeigt mir der Javasript Adapter an dass die Instanz deaktiviert wäre, obwohl sie grün ist.
                            Als ich gerade mal den Moment beobachtet habe wo die Instanz angeblich in deaktiviert gewechsel hat, erschien im Log die Debug Zeile:
                            (10140) sendTo "loadTypings" to system.adapter.admin.0 from system.adapter.javascript.0
                            Glasfaser 400
                            StabilostickS apollon77A 2 Antworten Letzte Antwort
                            • A aleks-83
                              Admin 3.6.10
                              Javascript 4.3.1
                              Stabilostick
                              @aleks-83
                              Downgrade über den 1.5.14‘er Installer und Migration in neue Instanz. Vorher ggf. das Repository im Admin von latest nach stable (=default) umstellen.
                              • A aleks-83
                                Admin 3.6.10
                                Javascript 4.3.1
                                apollon77A Online
                                apollon77A Online
                                @aleks-83 JavaScript macht so einige Dinge ggf hintendran. Die Anzeige "Instanz ist deaktiviert" hat nichts mit dem js.controller zu tun. Da hat Javascript irgendwie noch nicht alle Daten. Das "loadTypings" bedeutet zB das der Editor erst mal Typinformationen lädt ... das kann kurz dauern ... geduld bitte, es gibst(gab dazu ein JavaScrtiot Issue, und nicht gleich controller downgraden.
                                ... und "immer mal wieder" gern detaillieren ...
                                • StabilostickS Offline
                                  Stabilostick
                                  @aleks-83
                                  Js-Controller 2.0 wird bald stable. Ich stimme @apollon77 zu, lieber die Probleme zu suchen und zu beheben, als downzugraden.
                                    aleks-83
                                    Ich möchte ja eigentlich auch beim 2.x bleiben.
                                    In den letzten Wochen häufen sich bei mir aber die Probleme.
                                    Es muss ja nicht am JS 2.x selbst liegen.
                                    Vielleicht sind meine Adapter dann noch nicht alle damit kompatibel!?
                                    Heute morgen hatte ich z.B. Probleme mit meinem Sonos Adapter dass er keine Geräte mehr steuern konnte mit der Meldung "Sonos "" not found".
                                    Und der Fully Adapter zeigt den "fully alive" nur sporadisch an. Meistens false, manchmal null, manchmal true.
                                    Glasfaser 400
                                    • A aleks-83
                                      apollon77A Online
                                      apollon77A Online
                                      @aleks-83 ggf bitte mal Adapter auf Loglevel Debug oder sogar "silly" stellen und dann log schicken von solchen vorkommnissen, Dann kann man schauen ob es Adapter oder controller ist.
                                      Was ist "fully alive"?
                                      • apollon77A apollon77
                                        aleks-83
                                        @apollon77 sagte in Windows Dienst lässt sich nicht mehr starten:
                                        Hab ihn jetzt mal auf "silly" stehen.
                                        Werde beobachten ob es jetzt nochmal auftritt.
                                        Du sagtest ja auf Github dass ein Neustart das Problem beheben sollte.
                                        Der Adapter hat jetzt natürlich neu gestartet durch das ändern des loglevels.
                                        Das ist der status ob der Fully Kiosk Browser auf dem Tablet ausgeführt wird und eine Verbindung zum Adapter hat.
                                        Glasfaser 400
                                        • A aleks-83
                                          apollon77A Online
                                          apollon77A Online
                                          Vermutung ... wenn es an Discovered kram liegt ... vllt war es mal kurz weg und wieder da ... Kenn mich mit Sonos nicht gut genug aus.
                                          Fully alive: ok, da habe ich keine idee. Hier Adapter-Issue anlegen
