  4. Windows Dienst lässt sich nicht mehr starten
    6.4k
windows dienstnode.js
54 Beiträge 4 Kommentatoren 8.4k Aufrufe 4 Beobachtet
    aleks-83
    schrieb am zuletzt editiert von aleks-83
    Komplettausfall #2
    Jetzt hat der Dienst des ioBroker plötzlich nach der Deinstallation des "mobile" Adapters gestoppt, und lässt sich nicht mehr starten.
    iobroker log während des Absturzes:
    2019-10-16 07:45:06.764  - info: host.NUC(NUCmaster) iobroker del mobile.0
    2019-10-16 07:45:08.910  - info: host.NUC(NUCmaster) iobroker Delete adapter "mobile.0"
    2019-10-16 07:45:08.941  - info: host.NUC(NUCmaster) iobroker host.NUC(NUCmaster) Counted 1 instances of mobile.0
    2019-10-16 07:45:11.870  - info: host.NUC(NUCmaster) iobroker host.NUC(NUCmaster) Deleting 1 object(s).
    2019-10-16 07:45:11.894  - info: host.NUC(NUCmaster) object deleted system.adapter.mobile.0
    2019-10-16 07:45:11.896  - info: lovelace.0 (9380) object system.adapter.mobile.0 deleted
    2019-10-16 07:45:12.921  - info: host.NUC(NUCmaster) iobroker exit 0
    2019-10-16 07:45:27.747  - info: host.NUC(NUCmaster) iobroker del mobile
    2019-10-16 07:45:29.418  - info: host.NUC(NUCmaster) iobroker Delete adapter "mobile"
    2019-10-16 07:45:29.474  - info: host.NUC(NUCmaster) iobroker host.NUC(NUCmaster) Counted 1 adapter for mobile
    2019-10-16 07:45:29.554  - info: host.NUC(NUCmaster) iobroker host.NUC(NUCmaster) Counted 1 states of system.adapter.mobile
    2019-10-16 07:45:29.871  - info: lovelace.0 (9380) object mobile deleted
    2019-10-16 07:45:29.883  - info: lovelace.0 (9380) object mobile.admin deleted
    2019-10-16 07:45:29.895  - info: lovelace.0 (9380) object system.adapter.mobile.upload deleted
    2019-10-16 07:45:29.904  - info: lovelace.0 (9380) object system.adapter.mobile deleted
    2019-10-16 07:45:29.886  - info: host.NUC(NUCmaster) iobroker host.NUC(NUCmaster) Deleting 2 object(s).
    2019-10-16 07:45:29.909  - info: host.NUC(NUCmaster) iobroker npm uninstall iobroker.mobile --silent --save --prefix "D:/ioBroker/NUCmaster" (System call)
    2019-10-16 07:45:30.860  - error: host.NUC(NUCmaster) Cannot write files: D:\ioBroker\NUCmaster\iobroker-data\files\mobile\_data.json: ENOENT: no such file or directory, open 'D:\ioBroker\NUCmaster\iobroker-data\files\mobile\_data.json'
    2019-10-16 07:45:30.861  - error: host.NUC(NUCmaster) Cannot write files: D:\ioBroker\NUCmaster\iobroker-data\files\mobile.admin\_data.json: ENOENT: no such file or directory, open 'D:\ioBroker\NUCmaster\iobroker-data\files\mobile.admin\_data.json'
    2019-10-16 07:45:53.665  - info: geofency.0 (11084) adapter geofency received webhook from device Steffi with values: name: KiGa, entry: 0
    2019-10-16 07:47:04.872  - error: host.NUC(NUCmaster) Objects 127.0.0.1:59186 (Init=false) Redis error:Error: Invalid Chunk: parse failed
    2019-10-16 07:47:04.874  - error: host.NUC(NUCmaster) States 127.0.0.1:59187 (Init=false) Redis error:Error: Invalid Chunk: parse failed
    2019-10-16 07:47:05.682  - error: host.NUC(NUCmaster) Objects 127.0.0.1:59191 (Init=false) Redis error:Error: Invalid Chunk: parse failed
    2019-10-16 07:47:05.850  - error: host.NUC(NUCmaster) States 127.0.0.1:59192 (Init=false) Redis error:Error: Invalid Chunk: parse failed
    2019-10-16 07:47:08.643  - info: host.NUC(NUCmaster) iobroker events.js:174
         throw e
    2019-10-16 07:47:08.644  - info: host.NUC(NUCmaster) iobroker r; // Unhandled 'error' event
    Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
       at Server.setupListenHandle [as _listen2] (net.js:1279:14)
       at listenInCluster (net.js:1327:12)
       at doListen (net.js:1460:7)
       at process._tickCallback (internal/process/next_tick.js:63:19)
    Emitted 'error' event at:
       at emitErrorNT (net.js:1306:8)
    2019-10-16 07:48:28.872  - error: host.NUC(NUCmaster) uncaught exception: ENOENT: no such file or directory, open 'D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller\lib/../io-package.json'
    2019-10-16 07:48:28.907  - info: ping.0 (11592) Got terminate signal TERMINATE_YOURSELF
    2019-10-16 07:48:28.930  - info: geofency.0 (11084) Got terminate signal TERMINATE_YOURSELF
    2019-10-16 07:48:28.926  - info: backitup.0 (8420) Got terminate signal TERMINATE_YOURSELF
    2019-10-16 07:48:28.935  - info: enigma2.0 (6524) Got terminate signal TERMINATE_YOURSELF
    2019-10-16 07:48:28.945  - info: javascript.0 (8992) Got terminate signal TERMINATE_YOURSELF
    2019-10-16 07:48:29.007  - info: enigma2.1 (2716) Got terminate signal TERMINATE_YOURSELF
    2019-10-16 07:48:29.019  - info: email.0 (9008) Got terminate signal TERMINATE_YOURSELF
    2019-10-16 07:48:29.016  - info: text2command.0 (5956) Got terminate signal TERMINATE_YOURSELF
    2019-10-16 07:48:29.023  - info: telegram.0 (5972) Got terminate signal TERMINATE_YOURSELF
    2019-10-16 07:48:29.025  - info: iot.0 (8428) Got terminate signal TERMINATE_YOURSELF
    2019-10-16 07:48:29.020  - info: pushover.0 (8276) Got terminate signal TERMINATE_YOURSELF
    2019-10-16 07:48:29.028  - info: lovelace.0 (9380) Got terminate signal TERMINATE_YOURSELF
    2019-10-16 07:48:29.042  - info: hue-extended.0 (8700) Got terminate signal TERMINATE_YOURSELF
    2019-10-16 07:48:29.046  - info: web.0 (10252) Got terminate signal TERMINATE_YOURSELF
    2019-10-16 07:48:29.100  - info: sonos.0 (8728) Got terminate signal TERMINATE_YOURSELF
    2019-10-16 07:48:28.874  - error: host.NUC(NUCmaster) Error: ENOENT: no such file or directory, open 'D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller\lib/../io-package.json'
       at Object.openSync (fs.js:443:3)
       at Object.readFileSync (fs.js:343:35)
       at Object.getInstalledInfo (D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller\lib\tools.js:533:37)
       at objects.getObjectView (D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller\main.js:1763:42)
       at Immediate.callback.function.setImmediate (D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller\lib\objects\objectsInMemFileDB.js:1813:62)
       at runCallback (timers.js:705:18)
       at tryOnImmediate (timers.js:676:5)
       at processImmediate (timers.js:658:5)
    2019-10-16 07:48:28.876  - info: host.NUC(NUCmaster) stopInstance system.adapter.admin.0
    2019-10-16 07:48:28.876  - info: host.NUC(NUCmaster) stopInstance system.adapter.discovery.0
    2019-10-16 07:48:28.876  - info: host.NUC(NUCmaster) stopInstance system.adapter.history.0
    2019-10-16 07:48:28.876  - info: host.NUC(NUCmaster) stopInstance system.adapter.tr-064.0
    2019-10-16 07:48:28.877  - info: host.NUC(NUCmaster) stopInstance system.adapter.vis.0
    2019-10-16 07:48:28.877  - info: host.NUC(NUCmaster) stopInstance system.adapter.ping.0
    2019-10-16 07:48:28.877  - info: host.NUC(NUCmaster) stopInstance system.adapter.ical.0
    2019-10-16 07:48:28.877  - info: host.NUC(NUCmaster) stopInstance canceled schedule system.adapter.ical.0
    2019-10-16 07:48:28.877  - info: host.NUC(NUCmaster) stopInstance system.adapter.ical.1
    2019-10-16 07:48:28.878  - info: host.NUC(NUCmaster) stopInstance canceled schedule system.adapter.ical.1
    2019-10-16 07:48:28.878  - info: host.NUC(NUCmaster) stopInstance system.adapter.hue.0
    2019-10-16 07:48:28.878  - info: host.NUC(NUCmaster) stopInstance system.adapter.denon.0
    2019-10-16 07:48:28.878  - info: host.NUC(NUCmaster) stopInstance system.adapter.vis-fancyswitch.0
    2019-10-16 07:48:28.878  - info: host.NUC(NUCmaster) stopInstance system.adapter.harmony.0
    2019-10-16 07:48:28.879  - info: host.NUC(NUCmaster) stopInstance system.adapter.vis-timeandweather.0
    2019-10-16 07:48:28.879  - info: host.NUC(NUCmaster) stopInstance system.adapter.firetv.0
    2019-10-16 07:48:28.879  - info: host.NUC(NUCmaster) stopInstance system.adapter.vis-hqwidgets.0
    2019-10-16 07:48:28.879  - info: host.NUC(NUCmaster) stopInstance system.adapter.vis-colorpicker.0
    2019-10-16 07:48:28.879  - info: host.NUC(NUCmaster) stopInstance system.adapter.backitup.0
    2019-10-16 07:48:28.879  - info: host.NUC(NUCmaster) stopInstance system.adapter.geofency.0
    2019-10-16 07:48:28.880  - info: host.NUC(NUCmaster) stopInstance system.adapter.enigma2.0
    2019-10-16 07:48:28.880  - info: host.NUC(NUCmaster) stopInstance system.adapter.vis-metro.0
    2019-10-16 07:48:28.880  - info: host.NUC(NUCmaster) stopInstance system.adapter.mihome-vacuum.0
    2019-10-16 07:48:28.880  - info: host.NUC(NUCmaster) stopInstance system.adapter.vis-canvas-gauges.0
    2019-10-16 07:48:28.880  - info: host.NUC(NUCmaster) stopInstance system.adapter.unifi.0
    2019-10-16 07:48:28.880  - info: host.NUC(NUCmaster) stopInstance system.adapter.stiebel-isg.0
    2019-10-16 07:48:28.880  - info: host.NUC(NUCmaster) stopInstance system.adapter.terminal.0
    2019-10-16 07:48:28.880  - info: host.NUC(NUCmaster) stopInstance system.adapter.alexa2.0
    2019-10-16 07:48:28.881  - info: host.NUC(NUCmaster) stopInstance system.adapter.vis-google-fonts.0
    2019-10-16 07:48:28.881  - info: host.NUC(NUCmaster) stopInstance system.adapter.vis-players.0
    2019-10-16 07:48:28.881  - info: host.NUC(NUCmaster) stopInstance system.adapter.scenes.0
    2019-10-16 07:48:28.881  - info: host.NUC(NUCmaster) stopInstance system.adapter.vis-bars.0
    2019-10-16 07:48:28.882  - info: host.NUC(NUCmaster) stopInstance system.adapter.tankerkoenig.0
    2019-10-16 07:48:28.882  - info: host.NUC(NUCmaster) stopInstance system.adapter.javascript.0
    2019-10-16 07:48:28.882  - info: host.NUC(NUCmaster) stopInstance system.adapter.fritzdect.0
    2019-10-16 07:48:28.883  - info: host.NUC(NUCmaster) stopInstance system.adapter.info.0
    2019-10-16 07:48:28.883  - info: host.NUC(NUCmaster) stopInstance system.adapter.vis-rgraph.0
    2019-10-16 07:48:28.883  - info: host.NUC(NUCmaster) stopInstance system.adapter.gruenbeck.0
    2019-10-16 07:48:28.883  - info: host.NUC(NUCmaster) stopInstance system.adapter.fullybrowser.0
    2019-10-16 07:48:28.884  - info: host.NUC(NUCmaster) stopInstance system.adapter.enigma2.1
    2019-10-16 07:48:28.884  - info: host.NUC(NUCmaster) stopInstance system.adapter.text2command.0
    2019-10-16 07:48:28.884  - info: host.NUC(NUCmaster) stopInstance system.adapter.email.0
    2019-10-16 07:48:28.884  - info: host.NUC(NUCmaster) stopInstance system.adapter.pushover.0
    2019-10-16 07:48:28.885  - info: host.NUC(NUCmaster) stopInstance system.adapter.telegram.0
    2019-10-16 07:48:28.885  - info: host.NUC(NUCmaster) stopInstance system.adapter.iot.0
    2019-10-16 07:48:28.885  - info: host.NUC(NUCmaster) stopInstance system.adapter.smartmeter.0
    2019-10-16 07:48:28.885  - info: host.NUC(NUCmaster) stopInstance system.adapter.lovelace.0
    2019-10-16 07:48:28.888  - info: host.NUC(NUCmaster) stopInstance system.adapter.upnp.0
    2019-10-16 07:48:28.888  - info: host.NUC(NUCmaster) stopInstance system.adapter.mihome.0
    2019-10-16 07:48:28.888  - info: host.NUC(NUCmaster) stopInstance system.adapter.weatherunderground.0
    2019-10-16 07:48:28.888  - info: host.NUC(NUCmaster) stopInstance canceled schedule system.adapter.weatherunderground.0
    2019-10-16 07:48:28.889  - info: host.NUC(NUCmaster) stopInstance system.adapter.fakeroku.0
    2019-10-16 07:48:28.889  - info: host.NUC(NUCmaster) stopInstance system.adapter.hue-extended.0
    2019-10-16 07:48:28.889  - info: host.NUC(NUCmaster) stopInstance system.adapter.web.0
    2019-10-16 07:48:28.889  - info: host.NUC(NUCmaster) stopInstance system.adapter.socketio.0
    2019-10-16 07:48:28.889  - info: host.NUC(NUCmaster) stopInstance system.adapter.sonos.0
    2019-10-16 07:48:28.889  - info: host.NUC(NUCmaster) stopInstance system.adapter.dwd.0
    2019-10-16 07:48:28.890  - info: host.NUC(NUCmaster) stopInstance canceled schedule system.adapter.dwd.0
    2019-10-16 07:48:28.890  - info: host.NUC(NUCmaster) iobroker _restart
    2019-10-16 07:48:28.901  - info: host.NUC(NUCmaster) stopInstance system.adapter.admin.0 send kill signal
    2019-10-16 07:48:28.904  - info: host.NUC(NUCmaster) stopInstance system.adapter.tr-064.0 send kill signal
    2019-10-16 07:48:28.907  - info: host.NUC(NUCmaster) stopInstance system.adapter.ping.0 send kill signal
    2019-10-16 07:48:28.915  - info: host.NUC(NUCmaster) stopInstance system.adapter.hue.0 send kill signal
    2019-10-16 07:48:28.918  - info: host.NUC(NUCmaster) stopInstance system.adapter.harmony.0 send kill signal
    2019-10-16 07:48:28.925  - info: host.NUC(NUCmaster) stopInstance system.adapter.backitup.0 send kill signal
    2019-10-16 07:48:28.930  - info: host.NUC(NUCmaster) stopInstance system.adapter.geofency.0 send kill signal
    2019-10-16 07:48:28.934  - info: host.NUC(NUCmaster) stopInstance system.adapter.enigma2.0 send kill signal
    2019-10-16 07:48:28.936  - info: host.NUC(NUCmaster) stopInstance system.adapter.alexa2.0 send kill signal
    2019-10-16 07:48:28.940  - info: host.NUC(NUCmaster) stopInstance system.adapter.tankerkoenig.0 send kill signal
    2019-10-16 07:48:28.944  - info: host.NUC(NUCmaster) stopInstance system.adapter.javascript.0 send kill signal
    2019-10-16 07:48:28.947  - info: host.NUC(NUCmaster) stopInstance system.adapter.fritzdect.0 send kill signal
    2019-10-16 07:48:28.951  - info: host.NUC(NUCmaster) stopInstance system.adapter.info.0 send kill signal
    2019-10-16 07:48:28.952  - info: host.NUC(NUCmaster) stopInstance system.adapter.gruenbeck.0 send kill signal
    2019-10-16 07:48:29.002  - info: host.NUC(NUCmaster) stopInstance system.adapter.fullybrowser.0 send kill signal
    2019-10-16 07:48:29.005  - info: host.NUC(NUCmaster) stopInstance system.adapter.enigma2.1 send kill signal
    2019-10-16 07:48:29.015  - info: host.NUC(NUCmaster) stopInstance system.adapter.text2command.0 send kill signal
    2019-10-16 07:48:29.017  - info: host.NUC(NUCmaster) stopInstance system.adapter.email.0 send kill signal
    2019-10-16 07:48:29.019  - info: host.NUC(NUCmaster) stopInstance system.adapter.pushover.0 send kill signal
    2019-10-16 07:48:29.021  - info: host.NUC(NUCmaster) stopInstance system.adapter.telegram.0 send kill signal
    2019-10-16 07:48:29.023  - info: host.NUC(NUCmaster) stopInstance system.adapter.iot.0 send kill signal
    2019-10-16 07:48:29.026  - info: host.NUC(NUCmaster) stopInstance system.adapter.lovelace.0 send kill signal
    2019-10-16 07:48:29.028  - info: host.NUC(NUCmaster) stopInstance system.adapter.upnp.0 send kill signal
    2019-10-16 07:48:29.030  - info: host.NUC(NUCmaster) stopInstance system.adapter.mihome.0 send kill signal
    2019-10-16 07:48:29.037  - info: host.NUC(NUCmaster) stopInstance system.adapter.fakeroku.0 send kill signal
    2019-10-16 07:48:29.040  - info: host.NUC(NUCmaster) stopInstance system.adapter.hue-extended.0 send kill signal
    2019-10-16 07:48:29.044  - info: host.NUC(NUCmaster) stopInstance system.adapter.web.0 send kill signal
    2019-10-16 07:48:29.046  - info: host.NUC(NUCmaster) stopInstance system.adapter.socketio.0 send kill signal
    2019-10-16 07:48:29.054  - info: host.NUC(NUCmaster) stopInstance system.adapter.sonos.0 send kill signal
    2019-10-16 07:48:28.946  - ( Hier wurden alle Skripte gestoppt )
    2019-10-16 07:48:29.141  - info: javascript.0 (8992) terminating
    2019-10-16 07:48:29.142  - info: javascript.0 (8992) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2019-10-16 07:48:29.320  - info: host.NUC(NUCmaster) instance system.adapter.geofency.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
    2019-10-16 07:48:29.323  - info: host.NUC(NUCmaster) instance system.adapter.harmony.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
    2019-10-16 07:48:29.326  - info: host.NUC(NUCmaster) instance system.adapter.tr-064.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
    2019-10-16 07:48:29.413  - info: ping.0 (11592) terminating
    2019-10-16 07:48:29.414  - info: ping.0 (11592) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2019-10-16 07:48:29.431  - info: backitup.0 (8420) terminating
    2019-10-16 07:48:29.439  - info: enigma2.0 (6524) terminating
    2019-10-16 07:48:29.511  - info: enigma2.1 (2716) terminating
    2019-10-16 07:48:29.521  - info: email.0 (9008) terminating
    2019-10-16 07:48:29.523  - info: text2command.0 (5956) terminating
    2019-10-16 07:48:29.522  - info: email.0 (9008) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2019-10-16 07:48:29.527  - info: pushover.0 (8276) terminating
    2019-10-16 07:48:29.532  - info: telegram.0 (5972) terminating
    2019-10-16 07:48:29.533  - info: telegram.0 (5972) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2019-10-16 07:48:29.663  - info: host.NUC(NUCmaster) instance system.adapter.fritzdect.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
    2019-10-16 07:48:29.665  - info: host.NUC(NUCmaster) instance system.adapter.hue.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
    2019-10-16 07:48:29.666  - info: host.NUC(NUCmaster) instance system.adapter.alexa2.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
    2019-10-16 07:48:29.668  - info: host.NUC(NUCmaster) instance system.adapter.hue-extended.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
    2019-10-16 07:48:29.670  - info: host.NUC(NUCmaster) instance system.adapter.socketio.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
    2019-10-16 07:48:29.671  - info: host.NUC(NUCmaster) instance system.adapter.fakeroku.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
    2019-10-16 07:48:29.673  - info: host.NUC(NUCmaster) instance system.adapter.lovelace.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
    2019-10-16 07:48:29.674  - info: host.NUC(NUCmaster) instance system.adapter.upnp.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
    2019-10-16 07:48:29.676  - info: host.NUC(NUCmaster) instance system.adapter.info.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
    2019-10-16 07:48:29.677  - info: host.NUC(NUCmaster) instance system.adapter.sonos.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
    2019-10-16 07:48:29.679  - info: host.NUC(NUCmaster) instance system.adapter.mihome.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
    2019-10-16 07:48:29.680  - info: host.NUC(NUCmaster) instance system.adapter.iot.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
    2019-10-16 07:48:29.682  - info: host.NUC(NUCmaster) instance system.adapter.gruenbeck.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
    2019-10-16 07:48:29.683  - info: host.NUC(NUCmaster) instance system.adapter.web.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
    2019-10-16 07:48:29.685  - info: host.NUC(NUCmaster) instance system.adapter.fullybrowser.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
    2019-10-16 07:48:29.739  - error: host.NUC(NUCmaster) iobroker internal/modules/cjs/loader.js:638
       throw err;
    Error: Cannot find module 'D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller\iobroker.js'
       at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
       at Function.Module._load (internal/modules/cjs/loader.js:562:25)
       at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
       at startup (internal/bootstrap/node.js:283:19)
       at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3)
    2019-10-16 07:48:29.766  - info: host.NUC(NUCmaster) iobroker exit 1
    2019-10-16 07:48:30.073  - info: host.NUC(NUCmaster) instance system.adapter.admin.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
    2019-10-16 07:48:30.075  - info: host.NUC(NUCmaster) instance system.adapter.javascript.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
    2019-10-16 07:48:30.076  - info: host.NUC(NUCmaster) instance system.adapter.ping.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
    2019-10-16 07:48:30.076  - info: host.NUC(NUCmaster) instance system.adapter.enigma2.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
    2019-10-16 07:48:30.077  - info: host.NUC(NUCmaster) instance system.adapter.backitup.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
    2019-10-16 07:48:30.078  - info: host.NUC(NUCmaster) instance system.adapter.tankerkoenig.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
    2019-10-16 07:48:30.078  - info: host.NUC(NUCmaster) instance system.adapter.enigma2.1 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
    2019-10-16 07:48:30.079  - info: host.NUC(NUCmaster) instance system.adapter.email.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
    2019-10-16 07:48:30.079  - info: host.NUC(NUCmaster) instance system.adapter.text2command.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
    2019-10-16 07:48:30.080  - info: host.NUC(NUCmaster) instance system.adapter.pushover.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
    2019-10-16 07:48:30.080  - info: host.NUC(NUCmaster) instance system.adapter.telegram.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
    2019-10-16 07:48:31.235  - info: host.NUC(NUCmaster) stopInstance timeout "2000 system.adapter.history.0 killing pid  8360
    2019-10-16 07:48:31.270  - warn: host.NUC(NUCmaster) instance system.adapter.history.0 terminated due to SIGTERM
    2019-10-16 07:48:31.271  - info: host.NUC(NUCmaster) instance system.adapter.history.0 terminated with code null ()
    2019-10-16 07:48:31.271  - info: host.NUC(NUCmaster) All instances are stopped.
    2019-10-16 07:48:31.441  - info: host.NUC(NUCmaster) terminated
    Windows Dienste beim Versuch den Dienst zu starten:
    ioBroker.wrapper.log beim Versuch den Dienst zu starten:
    2019-10-16 08:12:24,317 INFO  - Starting ServiceWrapper in the service mode
    2019-10-16 08:12:24,368 INFO  - Starting "D:\ioBroker\NUCmaster\nodejs\node.exe" "D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller\controller.js"
    2019-10-16 08:12:24,375 INFO  - Starting "D:\ioBroker\NUCmaster\nodejs\node.exe" "D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller\controller.js"
    2019-10-16 08:12:24,418 INFO  - Started process 5864
    2019-10-16 08:12:24,430 DEBUG - Forwarding logs of the process System.Diagnostics.Process (node) to winsw.RollingSizeTimeLogAppender
    iobroker.err.log beim Versuch den Dienst zu starten:
    Error: Cannot find module 'D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller\controller.js'
    = Dell Optiplex Micro - 10GB RAM - 200GB SSD - Debian VM =
    = Node.js v20.19.6 = NPM 10.8.2 = JS Controller 7.0.7 =
    Ubiquiti UAP-AC-LR - UAP-AC-Lite - Synology DS716+II - Fritz!Box 7490
    Glasfaser 400
    • A aleks-83
      Komplettausfall #2
           throw e
         throw err;
      @aleks-83 hm ... da hat npm was kaputt gemacht. Bitte js Controller wieder Manuel installieren.
        aleks-83
        schrieb am zuletzt editiert von Stabilostick
        OK, wie mache ich das unter Windows?
        Das Update auf 2.0.29 ist ja eh "versehentlich" passiert durch den button "alle Adapter updaten".
        Kann ich dann jetzt erst wieder zurück zu 1.5.14?
        Glasfaser 400
        StabilostickS 1 Antwort Letzte Antwort
        • A aleks-83
          StabilostickS Offline
          Stabilostick
          @aleks-83
          Kann es sein, dass Du in der ioBroker Konfiguration vor der Migration diesen auf „latest“ stehen hattest? Das würde die Installation von 2.0.29 erklären.
          Ist die Datei „ D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller\controller.js“ vorhanden?
          • StabilostickS Stabilostick
            @aleks-83
            aleks-83
            @Stabilostick sagte in Windows Dienst lässt sich nicht mehr starten:
            @aleks-83
            Ja, hatte ich.
            Soll ich nochmal neu migrieren?
            Und sobald der Admin startet, direkt als erstes auf "stable" stellen?
            Nein, es gibt den Ordner "iobroker.js-controller" nicht.
            Glasfaser 400
            • A aleks-83
              @aleks-83
              Ja, hatte ich.
              Stabilostick
              @aleks-83 sagte in Windows Dienst lässt sich nicht mehr starten:
              Wau. Na dann mache mal die Kommandozeile der Instanz über das Startmenü auf und führe aus:
              npm install iobroker.js-controller@latest --production
              Was passiert da dann?
                aleks-83
                Er scheint was installiert zu haben.
                Sind aber auch viele ERR Meldungen dabei:
                D:\ioBroker\NUCmaster>npm install iobroker.js-controller@latest --production
                > iobroker.js-controller@2.0.29 preinstall D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller
                > node lib/preinstallCheck.js
                NPM version: 6.9.0
                > authenticate-pam@1.0.2 install D:\ioBroker\NUCmaster\node_modules\authenticate-pam
                > node-gyp rebuild
                D:\ioBroker\NUCmaster\node_modules\authenticate-pam>if not defined npm_config_node_gyp (node "D:\ioBroker\NUCmaster\nodejs\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin\\..\..\node_modules\node-gyp\bin\node-gyp.js" rebuild )  else (node "D:\ioBroker\NUCmaster\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" rebuild )
                Die Projekte in dieser Projektmappe werden nacheinander erstellt. Um eine parallele Erstellung zu ermöglichen, müssen Sie den Schalter "/m" hinzufügen.
                 authenticate_pam.cc
                 win_delay_load_hook.cc
                d:\iobroker\nucmaster\node_modules\authenticate-pam\authenticate_pam.cc(24): fatal error C1083: Datei (Include) kann nicht geöffnet werden: "uni
                std.h": No such file or directory [D:\ioBroker\NUCmaster\node_modules\authenticate-pam\build\authenticate_pam.vcxproj]
                gyp ERR! build error
                gyp ERR! stack Error: `C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe` failed with exit code: 1
                gyp ERR! stack     at ChildProcess.onExit (D:\ioBroker\NUCmaster\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:262:23)
                gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
                gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                gyp ERR! System Windows_NT 10.0.18362
                gyp ERR! command "D:\\ioBroker\\NUCmaster\\nodejs\\node.exe" "D:\\ioBroker\\NUCmaster\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
                gyp ERR! cwd D:\ioBroker\NUCmaster\node_modules\authenticate-pam
                gyp ERR! node -v v10.16.3
                gyp ERR! node-gyp -v v3.8.0
                gyp ERR! not ok
                > serialport@6.2.2 install D:\ioBroker\NUCmaster\node_modules\iobroker.discovery\node_modules\serialport
                > prebuild-install || node-gyp rebuild
                > unix-dgram@2.0.2 install D:\ioBroker\NUCmaster\node_modules\unix-dgram
                > node-gyp rebuild
                D:\ioBroker\NUCmaster\node_modules\unix-dgram>if not defined npm_config_node_gyp (node "D:\ioBroker\NUCmaster\nodejs\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin\\..\..\node_modules\node-gyp\bin\node-gyp.js" rebuild )  else (node "D:\ioBroker\NUCmaster\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" rebuild )
                 unix_dgram.cc
                d:\iobroker\nucmaster\node_modules\unix-dgram\src\unix_dgram.cc(9): fatal error C1083: Datei (Include) kann nicht geöffnet werden: "unistd.h": N
                o such file or directory [D:\ioBroker\NUCmaster\node_modules\unix-dgram\build\unix_dgram.vcxproj]
                gyp ERR! cwd D:\ioBroker\NUCmaster\node_modules\unix-dgram
                gyp ERR! not ok
                > ursa-optional@0.9.10 install D:\ioBroker\NUCmaster\node_modules\ursa-optional
                > node rebuild.js
                > diskusage@1.1.3 install D:\ioBroker\NUCmaster\node_modules\diskusage
                > node-gyp rebuild
                D:\ioBroker\NUCmaster\node_modules\diskusage>if not defined npm_config_node_gyp (node "D:\ioBroker\NUCmaster\nodejs\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin\\..\..\node_modules\node-gyp\bin\node-gyp.js" rebuild )  else (node "D:\ioBroker\NUCmaster\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" rebuild )
                 main.cpp
                 diskusage_win.cpp
                    Bibliothek "D:\ioBroker\NUCmaster\node_modules\diskusage\build\Release\diskusage.lib" und Objekt "D:\ioBroker\NUCmaster\node_modules\diskus
                 age\build\Release\diskusage.exp" werden erstellt.
                 Code wird generiert.
                 All 262 functions were compiled because no usable IPDB/IOBJ from previous compilation was found.
                 Codegenerierung ist abgeschlossen.
                 diskusage.vcxproj -> D:\ioBroker\NUCmaster\node_modules\diskusage\build\Release\\diskusage.node
                > iobroker.js-controller@2.0.29 install D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller
                > node iobroker.js setup first
                > acme-v2@1.8.5 postinstall D:\ioBroker\NUCmaster\node_modules\acme-v2
                > node scripts/postinstall
                👉  Do you rely on Greenlock?  👈
                👉               (or ACME.js)  👈
                Hey! Let's Encrypt will STOP WORKING with Greenlock and ACME.js at the end of Oct 2019.
                WITHOUT YOUR HELP we won't get the next release out in time.
                If Greenlock (or ACME.js) has saved you time and money, and taken stress out of your life,
                or you just love it, please reach out to return the favor today:
                SAVE GREENLOCK / ACME.js:
                https://indiegogo.com/at/greenlock
                npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/common@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
                npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/core@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.1 (node_modules\fsevents):
                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules\osx-temperature-sensor):
                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules\authenticate-pam):
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuild`
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.2 (node_modules\unix-dgram):
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.2 install: `node-gyp rebuild`
                + iobroker.js-controller@2.0.29
                added 207 packages from 214 contributors, removed 74 packages, updated 3 packages, moved 10 packages and audited 1566 packages in 117.15s
                found 12 vulnerabilities (9 low, 3 high)
                 run `npm audit fix` to fix them, or `npm audit` for details
                Läuft wieder alles.
                Glasfaser 400
                • A aleks-83
                  NPM version: 6.9.0
                  > node-gyp rebuild
                   authenticate_pam.cc
                  gyp ERR! not ok
                  > node-gyp rebuild
                   unix_dgram.cc
                  gyp ERR! not ok
                  > node rebuild.js
                  > node-gyp rebuild
                   main.cpp
                   diskusage_win.cpp
                  👉               (or ACME.js)  👈
                  Läuft wieder alles.
                  Stabilostick
                  @aleks-83
                  npm install @angular/common@
                  npm install @angular/core@
                  Sieht aber schon einmal trotz der Meldungen gut aus. Bist freiwilliger Betatester, weil Du Dein System auf „latest“ stehen hast. 👌 🤗
                    aleks-83
                    OK, habe ich durchgeführt.
                    D:\ioBroker\NUCmaster>npm install @angular/common@
                    > node-gyp rebuild
                      authenticate_pam.cc
                    gyp ERR! not ok
                    > node-gyp rebuild
                      unix_dgram.cc
                    gyp ERR! not ok
                    npm WARN @angular/common@8.2.11 requires a peer of rxjs@^6.4.0 but none is installed. You must install peer dependencies yourself.
                    npm WARN @angular/common@8.2.11 requires a peer of @angular/core@8.2.11 but none is installed. You must install peer dependencies yourself.
                    + @angular/common@8.2.11
                    added 2 packages from 2 contributors and audited 1568 packages in 303.548s
                      run `np
                    [/s]m audit fix` to fix them, or `npm audit` for details
                    D:\ioBroker\NUCmaster>npm install @angular/core@
                    > node-gyp rebuild
                      authenticate_pam.cc
                    gyp ERR! not ok
                    > node-gyp rebuild
                      unix_dgram.cc
                    gyp ERR! not ok
                    npm WARN @angular/core@8.2.11 requires a peer of rxjs@^6.4.0 but none is installed. You must install peer dependencies yourself.
                    npm WARN @angular/core@8.2.11 requires a peer of zone.js@~0.9.1 but none is installed. You must install peer dependencies yourself.
                    + @angular/core@8.2.11
                    added 1 package from 1 contributor and audited 1570 packages in 70.735s
                    @Stabilostick
                    Bist freiwilliger Betatester, weil Du Dein System auf „latest“ stehen hast. 👍🏻🤗
                    "Freiwillig", ja 😂
                    Eigentlich möchte ich nur dass es wieder (rund) läuft... 🤕
                    Glasfaser 400
                      aleks-83
                      Wie kann ich denn bitte wieder zurück zum JS 1.5.14 downgraden?
                      Mit dem 2.x habe ich immer wieder mal Probleme.
                      Bin jetzt bei 2.0.38.
                      Admin 3.6.10
                      Javascript 4.3.1
                      Aktuell zeigt mir der Javasript Adapter an dass die Instanz deaktiviert wäre, obwohl sie grün ist.
                      Als ich gerade mal den Moment beobachtet habe wo die Instanz angeblich in deaktiviert gewechsel hat, erschien im Log die Debug Zeile:
                      (10140) sendTo "loadTypings" to system.adapter.admin.0 from system.adapter.javascript.0
                      Glasfaser 400
                      StabilostickS apollon77A 2 Antworten Letzte Antwort
                      • A aleks-83
                        Admin 3.6.10
                        Javascript 4.3.1
                        Stabilostick
                        @aleks-83
                        Downgrade über den 1.5.14‘er Installer und Migration in neue Instanz. Vorher ggf. das Repository im Admin von latest nach stable (=default) umstellen.
                        • A aleks-83
                          Admin 3.6.10
                          Javascript 4.3.1
                          @aleks-83 JavaScript macht so einige Dinge ggf hintendran. Die Anzeige "Instanz ist deaktiviert" hat nichts mit dem js.controller zu tun. Da hat Javascript irgendwie noch nicht alle Daten. Das "loadTypings" bedeutet zB das der Editor erst mal Typinformationen lädt ... das kann kurz dauern ... geduld bitte, es gibst(gab dazu ein JavaScrtiot Issue, und nicht gleich controller downgraden.
                          ... und "immer mal wieder" gern detaillieren ...
                          • StabilostickS Offline
                            Stabilostick
                            @aleks-83
                            Js-Controller 2.0 wird bald stable. Ich stimme @apollon77 zu, lieber die Probleme zu suchen und zu beheben, als downzugraden.
                              aleks-83
                              Ich möchte ja eigentlich auch beim 2.x bleiben.
                              In den letzten Wochen häufen sich bei mir aber die Probleme.
                              Es muss ja nicht am JS 2.x selbst liegen.
                              Vielleicht sind meine Adapter dann noch nicht alle damit kompatibel!?
                              Heute morgen hatte ich z.B. Probleme mit meinem Sonos Adapter dass er keine Geräte mehr steuern konnte mit der Meldung "Sonos "" not found".
                              Und der Fully Adapter zeigt den "fully alive" nur sporadisch an. Meistens false, manchmal null, manchmal true.
                              Glasfaser 400
                              • A aleks-83
                                @aleks-83 ggf bitte mal Adapter auf Loglevel Debug oder sogar "silly" stellen und dann log schicken von solchen vorkommnissen, Dann kann man schauen ob es Adapter oder controller ist.
                                Was ist "fully alive"?
                                • apollon77A apollon77
                                  aleks-83
                                  @apollon77 sagte in Windows Dienst lässt sich nicht mehr starten:
                                  Hab ihn jetzt mal auf "silly" stehen.
                                  Werde beobachten ob es jetzt nochmal auftritt.
                                  Du sagtest ja auf Github dass ein Neustart das Problem beheben sollte.
                                  Der Adapter hat jetzt natürlich neu gestartet durch das ändern des loglevels.
                                  Das ist der status ob der Fully Kiosk Browser auf dem Tablet ausgeführt wird und eine Verbindung zum Adapter hat.
                                  Glasfaser 400
                                  • A aleks-83
                                    Vermutung ... wenn es an Discovered kram liegt ... vllt war es mal kurz weg und wieder da ... Kenn mich mit Sonos nicht gut genug aus.
                                    Fully alive: ok, da habe ich keine idee. Hier Adapter-Issue anlegen
                                    • A aleks-83
                                      Was mir gerade noch aufgefallen ist bei der Neueinrichtung:
                                      Als er alle Adapter aus der Migration installiert hatte, habe ich per admin Adapter gesagt er soll alle Adapter updaten.
                                      Dann hat er versucht NPM upzugraden.
                                      Das ging schief.
                                      ... Hier wurden Adapter geupdatet ...
                                      Adapter "xs1" is not installed.
                                      Adapter "yahka" is not installed.
                                      Adapter "yamaha" is not installed.
                                      Adapter "yeelight-2" is not installed.
                                      Adapter "yr" is not installed.
                                      Adapter "zigbee" is not installed.
                                      Adapter "zont" is not installed.
                                      Adapter "zwave" is not installed.
                                      Adapter "zwave2" is not installed.
                                      Update js-controller from @1.5.14 to @2.0.29
                                      2019-10-14 20:36:35.125 - warn: host.NUC(NUCmaster) instance system.adapter.web.0 terminated due to SIGTERM
                                      2019-10-14 20:36:35.125 - info: host.NUC(NUCmaster) instance system.adapter.web.0 terminated with code null ()
                                      2019-10-14 20:36:37.511 - info: host.NUC(NUCmaster) instance system.adapter.web.0 started with pid 6360
                                      2019-10-14 20:36:38.566 - info: iobroker NPM version: 6.9.0
                                      2019-10-14 20:36:38.566 - info: iobroker npm install iobroker.js-controller@2.0.29 --unsafe-perm --production --save --prefix "D:/ioBroker/NUCmaster" (System call)
                                      2019-10-14 20:36:39.571 - info: web.0 starting. Version 2.4.5 in D:/ioBroker/NUCmaster/node_modules/iobroker.web, node: v10.16.3
                                      2019-10-14 20:36:41.833 - info: web.0 socket.io server listening on port 8083
                                      2019-10-14 20:36:41.838 - info: web.0 http server listening on port 8083
                                      2019-10-14 20:37:33.190 - info: iobroker gyp
                                      2019-10-14 20:37:33.191 - info: iobroker ERR!
                                      2019-10-14 20:37:33.193 - info: iobroker
                                      2019-10-14 20:37:33.199 - info: iobroker build error
                                      2019-10-14 20:37:33.200 - info: iobroker
                                      2019-10-14 20:37:33.229 - info: iobroker gyp ERR! stack Error: `C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe` failed with exit code: 1gyp ERR! stack at ChildProcess.onExit (D:\ioBroker\NUCmaster\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:262:23)
                                      2019-10-14 20:37:33.235 - info: iobroker gyp ERR! command "D:\\ioBroker\\NUCmaster\\nodejs\\node.exe" "D:\\ioBroker\\NUCmaster\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"gyp
                                      2019-10-14 20:37:33.237 - info: iobroker ERR!
                                      2019-10-14 20:37:33.241 - info: iobroker cwd D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller\node_modules\unix-dgramgyp ERR!
                                      2019-10-14 20:37:33.242 - info: iobroker node -v v10.16.3gyp ERR! node-gyp -v v3.8.0
                                      gyp ERR! not ok
                                      2019-10-14 20:38:12.125 - info: iobroker npm
                                      2019-10-14 20:38:12.126 - info: iobroker
                                      2019-10-14 20:38:12.130 - info: iobroker WARN
                                      2019-10-14 20:38:12.133 - info: iobroker
                                      2019-10-14 20:38:12.140 - info: iobroker optional
                                      2019-10-14 20:38:12.144 - info: iobroker SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.1 (node_modules\iobroker.js-controller\node_modules\fsevents):
                                      2019-10-14 20:38:12.165 - info: iobroker npm
                                      2019-10-14 20:38:12.176 - info: iobroker
                                      2019-10-14 20:38:12.180 - info: iobroker WARN
                                      2019-10-14 20:38:12.181 - info: iobroker
                                      2019-10-14 20:38:12.182 - info: iobroker notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
                                      2019-10-14 20:38:12.183 - info: iobroker npm
                                      2019-10-14 20:38:12.187 - info: iobroker WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.2 (node_modules\iobroker.js-controller\node_modules\unix-dgram):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.2 install: `node-gyp rebuild`
                                      2019-10-14 20:38:12.256 - info: iobroker Host "NUC(NUCmaster)" (win32) updated
                                      2019-10-14 20:38:12.256 - info: iobroker Starting node restart.js
                                      2019-10-14 20:38:12.343 - info: iobroker exit 0
                                      2019-10-14 20:39:43.348 - info: host.NUC(NUCmaster) Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
                                      Kann es sein dass er das beim letzten Update auch versucht hat, und mir die Zeile mit dem mkdir zerschossen hat?
                                      Ich habe den NUC jetzt aber schon neu gestartet.
                                      Der Dienst startet noch ganz normal.
                                      Dann werde ich den button "Alle Adapter updaten" erst mal meiden.
                                      EDIT:
                                      Der Admin zeigt mir aber an ich hätte die 2.0.29
                                      aleks-83
                                      Dann hat er den JS Controller geupdatet
                                      Es wird aktuell übrigens immer noch der JSC mit geupdatet wenn ich auf "alle Adapter updaten" klicke.
                                      Bin vorher aber auf das stable repository gewechselt.
                                      Admin ist 3.6.10
                                      JS 2.0.39
                                      Glasfaser 400
                                        aleks-83
                                        Und wieder habe ich einen Komplett Ausfall 😞
                                        Dienst startet nicht mehr seit dem großen Win10 Update.
                                        Cannot parse "/snapshots/vis-views.json
                                        Cannot read property 'stopping' of undefined
                                        TypeError: Cannot read property 'stopping' of undefined
                                            at cleanAutoSubscribes (D:\ioBroker\NUC\node_modules\iobroker.js-controller\main.js:2938:47)
                                            at objects.getObjectView (D:\ioBroker\NUC\node_modules\iobroker.js-controller\main.js:796:31)
                                            at Immediate.callback.function.setImmediate (D:\ioBroker\NUC\node_modules\iobroker.js-controller\lib\objects\objectsInMemFileDB.js:1950:62)
                                            throw err;
                                        Error: Cannot find module '@iobroker/plugin-base'
                                            at Module.require (internal/modules/cjs/loader.js:692:17)
                                            at require (internal/modules/cjs/helpers.js:25:18)
                                            at Object.<anonymous> (D:\ioBroker\NUC\node_modules\iobroker.js-controller\lib\adapter.js:32:27)
                                            at Module._compile (internal/modules/cjs/loader.js:778:30)
                                            at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                                            at Module.load (internal/modules/cjs/loader.js:653:32)
                                            at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                                            at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                                            throw err;
                                        Error: Cannot find module 'has'
                                            at Object.<anonymous> (D:\ioBroker\NUC\node_modules\node.extend\lib\extend.js:13:11)
                                            throw err;
                                        Error: Cannot find module 'D:\ioBroker\NUC\node_modules\iobroker.js-controller\controller.js'
                                            at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
                                            throw err;
                                            throw err;
                                            throw err;
                                            throw err;
                                            throw err;
                                            throw err;
                                            throw err;
                                            throw err;
                                            throw err;
                                            throw err;
                                            throw err;
                                            throw err;
                                        2020-07-06 17:54:59,257 DEBUG - Starting ServiceWrapper in the CLI mode
                                        2020-07-06 17:54:59,784 INFO  - Starting the service with id 'iobroker(NUC)'
                                        2020-07-06 17:55:00,211 INFO  - Starting ServiceWrapper in the service mode
                                        2020-07-06 17:55:00,246 DEBUG - Completed. Exit code is 0
                                        ### Offenbar letzter erfolgreicher Start !? ###
                                        2020-07-06 17:55:00,261 INFO  - Starting "D:\ioBroker\NUC\nodejs\node.exe" "D:\ioBroker\NUC\node_modules\iobroker.js-controller\controller.js"
                                        2020-07-06 17:55:00,315 INFO  - Started process 30008
                                        2020-07-06 17:55:00,333 DEBUG - Forwarding logs of the process System.Diagnostics.Process (node) to winsw.TimeBasedRollingLogAppender
                                        2020-07-06 17:55:10,989 INFO  - Starting ServiceWrapper in the service mode
                                        2020-07-06 17:55:11,039 INFO  - Starting "D:\ioBroker\NUC\nodejs\node.exe" "D:\ioBroker\NUC\node_modules\iobroker.js-controller\controller.js"
                                        2020-07-06 17:55:11,078 INFO  - Started process 29664
                                        2020-07-06 17:55:11,095 DEBUG - Forwarding logs of the process System.Diagnostics.Process (node) to winsw.TimeBasedRollingLogAppender
                                        2020-07-06 17:55:31,631 INFO  - Starting ServiceWrapper in the service mode
                                        2020-07-06 17:55:31,687 INFO  - Starting "D:\ioBroker\NUC\nodejs\node.exe" "D:\ioBroker\NUC\node_modules\iobroker.js-controller\controller.js"
                                        2020-07-06 17:55:31,724 INFO  - Started process 30568
                                        2020-07-06 17:55:31,742 DEBUG - Forwarding logs of the process System.Diagnostics.Process (node) to winsw.TimeBasedRollingLogAppender
                                        2020-07-06 19:09:45,860 INFO  - Starting ServiceWrapper in the service mode
                                        2020-07-06 19:09:45,924 INFO  - Starting "D:\ioBroker\NUC\nodejs\node.exe" "D:\ioBroker\NUC\node_modules\iobroker.js-controller\controller.js"
                                        2020-07-06 19:09:46,000 INFO  - Started process 2528
                                        2020-07-06 19:09:46,008 DEBUG - Forwarding logs of the process System.Diagnostics.Process (node) to winsw.TimeBasedRollingLogAppender
                                        2020-07-06 19:09:57,012 INFO  - Starting ServiceWrapper in the service mode
                                        2020-07-06 19:09:57,058 INFO  - Starting "D:\ioBroker\NUC\nodejs\node.exe" "D:\ioBroker\NUC\node_modules\iobroker.js-controller\controller.js"
                                        2020-07-06 19:09:57,110 INFO  - Started process 2780
                                        Glasfaser 400
                                        • A aleks-83
                                              throw err;
                                              throw err;
                                              throw err;
                                              throw err;
                                              throw err;
                                              throw err;
                                              throw err;
                                              throw err;
                                              throw err;
                                              throw err;
                                              throw err;
                                              throw err;
                                              throw err;
                                              throw err;
                                              throw err;
                                          @aleks-83 Scheinbar fehlen da wieder module ... Keine ahnung ... hat das Windows Update vllt irgend wie die Node.js Installation bzw Da dinge kaputt gemacht?
                                          Auf jeder fall ist der ganz oben genannte Fehler "stoping of undefined" im 3.xer Controller spätestens gefixt
