  4. Windows Dienst lässt sich nicht mehr starten
    6.4k
windows dienstnode.js
54 Beiträge 4 Kommentatoren 8.4k Aufrufe 4 Beobachtet
  • sigi234S sigi234
    Hm, bei mir kommt immer das im err.Log
    Cannot parse "/Adapter_Icons/vis-views.json
    Cannot parse "/Bilder/vis-views.json
    Cannot parse "/Meine_Icons/vis-views.json
    Cannot parse "/Mond/vis-views.json
    Cannot parse "/Netzwerk/vis-views.json
    Cannot parse "/Radiosender/vis-views.json
    Cannot parse "/Sigi/vis-views.json
    Cannot parse "/Sonstige/vis-views.json
    Cannot parse "/Staubsauger/vis-views.json
    Cannot parse "/Tankstellen_logos/vis-views.json
    StabilostickS Offline
    Stabilostick
    @sigi234
    need ... more ... input. Welcher Adapter?
    • StabilostickS Stabilostick
      @sigi234
      sigi234S Online
      sigi234S Online
      @Stabilostick sagte in Windows Dienst lässt sich nicht mehr starten:
      @sigi234
      Cannot parse "/VIS/vis-views.json
      Cannot parse "/Wetter_HD/vis-views.json
      Cannot parse "/Wettericons/vis-views.json
      Cannot parse "/fire/vis-views.json
      (node:6428) UnhandledPromiseRejectionWarning: FirebaseError: 5 NOT_FOUND: No document to update: projects/iobroker-iogo/databases/(default)/documents/users/A4JRhBHOt8Q3xR8SjK7Q3hW2U8K2/adapters/system_adapter_js-controller
          at new FirestoreError (C:\Program Files\iobroker\Test\node_modules\iobroker.iogo\node_modules\@firebase\firestore\dist\index.node.cjs.js:354:28)
          at ClientDuplexStream.<anonymous> (C:\Program Files\iobroker\Test\node_modules\iobroker.iogo\node_modules\@firebase\firestore\dist\index.node.cjs.js:22313:19)
          at ClientDuplexStream.emit (events.js:198:13)
          at ClientDuplexStream._emitStatusIfDone (C:\Program Files\iobroker\Test\node_modules\iobroker.iogo\node_modules\grpc\src\client.js:234:12)
          at ClientDuplexStream._receiveStatus (C:\Program Files\iobroker\Test\node_modules\iobroker.iogo\node_modules\grpc\src\client.js:211:8)
          at Object.onReceiveStatus (C:\Program Files\iobroker\Test\node_modules\iobroker.iogo\node_modules\grpc\src\client_interceptors.js:1306:15)
          at InterceptingListener._callNext (C:\Program Files\iobroker\Test\node_modules\iobroker.iogo\node_modules\grpc\src\client_interceptors.js:568:42)
          at InterceptingListener.onReceiveStatus (C:\Program Files\iobroker\Test\node_modules\iobroker.iogo\node_modules\grpc\src\client_interceptors.js:618:8)
          at C:\Program Files\iobroker\Test\node_modules\iobroker.iogo\node_modules\grpc\src\client_interceptors.js:1123:18
      (node:6428) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 4)
      (node:6428) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 5)
      (node:6428) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 6)
      { Error [ERR_UNHANDLED_ERROR]: Unhandled error. ('1811161726216929086534298f17edb7')
          at MerossCloud.emit (events.js:187:17)
          at MerossCloudDevice.devices.(anonymous function).on (C:\Program Files\iobroker\Test\node_modules\iobroker.meross\node_modules\meross-cloud\index.js:126:30)
          at MerossCloudDevice.emit (events.js:203:15)
          at MqttClient.client.on (C:\Program Files\iobroker\Test\node_modules\iobroker.meross\node_modules\meross-cloud\index.js:249:18)
          at MqttClient.emit (events.js:198:13)
          at TLSSocket.handleTLSerrors (C:\Program Files\iobroker\Test\node_modules\iobroker.meross\node_modules\mqtt\lib\connect\tls.js:26:18)
          at TLSSocket.emit (events.js:203:15)
          at emitErrorNT (internal/streams/destroy.js:91:8)
          at emitErrorAndCloseNT (internal/streams/destroy.js:59:3)
          at process._tickCallback (internal/process/next_tick.js:63:19) context: '1811161726216929086534298f17edb7' }
      StabilostickS 1 Antwort Letzte Antwort
        @aleks-83 sagte in Windows Dienst lässt sich nicht mehr starten:
        Ich habe gerade nochmal den Dienst gestartet und die Logfiles angesehen.
        Da muss wohl nochmal TeamViewer ran.... Du hast noch die Nummer?
        aleks-83
        Schreibe dir im Chat.
        = Dell Optiplex Micro - 10GB RAM - 200GB SSD - Debian VM =
        = Node.js v20.19.6 = NPM 10.8.2 = JS Controller 7.0.7 =
        Ubiquiti UAP-AC-LR - UAP-AC-Lite - Synology DS716+II - Fritz!Box 7490
        Glasfaser 400
          aleks-83
          OK, also @Stabilostick hat sich meinen NUC mal angesehen.
          Vielen Dank nochmal dafür !
          Der Dienst wird wohl korrekt gestartet, aber direkt wieder beendet weil ioBroker die logfile nicht erstellen kann.
          Laut Error Log versucht der ioBroker ein log zu erstellen mit dem Namen:
          D:\ioBroker\NUC\log\iobroker..yyyy-10-Mo.10/14\
          Wobei NUC der Instanzen-Namen ist.
          Alles hinter iobroker. macht aber irgendiwe keinen Sinn und steht auch so nicht in meiner ioBroker Konfig.
          Wie sich das bei mir eingeschlichen hat, kann ich mir nicht erklären.
          Das Ende vom Lied ist halt ne Neuinstallation.
          Aber diese geht ja wirklich einfach und automatisiert dank dem Windows Installer.
          Glasfaser 400
          • A aleks-83
            aleks-83
            schrieb am zuletzt editiert von aleks-83
            Was mir gerade noch aufgefallen ist bei der Neueinrichtung:
            Als er alle Adapter aus der Migration installiert hatte, habe ich per admin Adapter gesagt er soll alle Adapter updaten.
            Dann hat er versucht NPM upzugraden.
            Das ging schief.
            ... Hier wurden Adapter geupdatet ...
            Adapter "xs1" is not installed.
            Adapter "yahka" is not installed.
            Adapter "yamaha" is not installed.
            Adapter "yeelight-2" is not installed.
            Adapter "yr" is not installed.
            Adapter "zigbee" is not installed.
            Adapter "zont" is not installed.
            Adapter "zwave" is not installed.
            Adapter "zwave2" is not installed.
            Update js-controller from @1.5.14 to @2.0.29
            2019-10-14 20:36:35.125 - warn: host.NUC(NUCmaster) instance system.adapter.web.0 terminated due to SIGTERM
            2019-10-14 20:36:35.125 - info: host.NUC(NUCmaster) instance system.adapter.web.0 terminated with code null ()
            2019-10-14 20:36:37.511 - info: host.NUC(NUCmaster) instance system.adapter.web.0 started with pid 6360
            2019-10-14 20:36:38.566 - info: iobroker NPM version: 6.9.0
            2019-10-14 20:36:38.566 - info: iobroker npm install iobroker.js-controller@2.0.29 --unsafe-perm --production --save --prefix "D:/ioBroker/NUCmaster" (System call)
            2019-10-14 20:36:39.571 - info: web.0 starting. Version 2.4.5 in D:/ioBroker/NUCmaster/node_modules/iobroker.web, node: v10.16.3
            2019-10-14 20:36:41.833 - info: web.0 socket.io server listening on port 8083
            2019-10-14 20:36:41.838 - info: web.0 http server listening on port 8083
            2019-10-14 20:37:33.190 - info: iobroker gyp
            2019-10-14 20:37:33.191 - info: iobroker ERR!
            2019-10-14 20:37:33.193 - info: iobroker
            2019-10-14 20:37:33.199 - info: iobroker build error
            2019-10-14 20:37:33.200 - info: iobroker
            2019-10-14 20:37:33.229 - info: iobroker gyp ERR! stack Error: `C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe` failed with exit code: 1gyp ERR! stack at ChildProcess.onExit (D:\ioBroker\NUCmaster\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:262:23)
            gyp ERR! stack at ChildProcess.emit (events.js:198:13)
            gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
            gyp ERR! System Windows_NT 10.0.18362
            2019-10-14 20:37:33.235 - info: iobroker gyp ERR! command "D:\\ioBroker\\NUCmaster\\nodejs\\node.exe" "D:\\ioBroker\\NUCmaster\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"gyp
            2019-10-14 20:37:33.237 - info: iobroker ERR!
            2019-10-14 20:37:33.241 - info: iobroker cwd D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller\node_modules\unix-dgramgyp ERR!
            2019-10-14 20:37:33.242 - info: iobroker node -v v10.16.3gyp ERR! node-gyp -v v3.8.0
            gyp ERR! not ok
            2019-10-14 20:38:12.125 - info: iobroker npm
            2019-10-14 20:38:12.126 - info: iobroker
            2019-10-14 20:38:12.130 - info: iobroker WARN
            2019-10-14 20:38:12.133 - info: iobroker
            2019-10-14 20:38:12.140 - info: iobroker optional
            2019-10-14 20:38:12.144 - info: iobroker SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.1 (node_modules\iobroker.js-controller\node_modules\fsevents):
            2019-10-14 20:38:12.165 - info: iobroker npm
            2019-10-14 20:38:12.176 - info: iobroker
            2019-10-14 20:38:12.180 - info: iobroker WARN
            2019-10-14 20:38:12.181 - info: iobroker
            2019-10-14 20:38:12.182 - info: iobroker notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
            2019-10-14 20:38:12.183 - info: iobroker npm
            2019-10-14 20:38:12.187 - info: iobroker WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.2 (node_modules\iobroker.js-controller\node_modules\unix-dgram):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.2 install: `node-gyp rebuild`
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
            2019-10-14 20:38:12.256 - info: iobroker Host "NUC(NUCmaster)" (win32) updated
            2019-10-14 20:38:12.256 - info: iobroker Starting node restart.js
            2019-10-14 20:38:12.343 - info: iobroker exit 0
            2019-10-14 20:39:43.348 - info: host.NUC(NUCmaster) Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
            Kann es sein dass er das beim letzten Update auch versucht hat, und mir die Zeile mit dem mkdir zerschossen hat?
            Ich habe den NUC jetzt aber schon neu gestartet.
            Der Dienst startet noch ganz normal.
            Dann werde ich den button "Alle Adapter updaten" erst mal meiden.
            EDIT:
            Der Admin zeigt mir aber an ich hätte die 2.0.29
            Glasfaser 400
            StabilostickS A 2 Antworten Letzte Antwort
            • A aleks-83
              Das ging schief.
              gyp ERR! not ok
              EDIT:
              Stabilostick
              schrieb am zuletzt editiert von Stabilostick
              Das ging schief.
              Nein, hat er nicht.
              Du hast den neuesten js-controller installiert aus Latest. Dabei ist der Buildvorgang für die optionale Komponente "unix-dgram", die sowieso nur auf Linux funktioniert, fehlgeschlagen. "fsevents" braucht es nur auf Apple-Rechnern. Also alles kein Problem und kein Grund zur Sorge:
              Das ist das Wichtige am Ende. 0 = alles Ok.
              • sigi234S sigi234
                @sigi234
                Stabilostick
                @sigi234
                Ich fürchte, da bin ich raus. Firebase, iogo und Meross kenne ich nicht. Gehört das wirklich zum Thema "Windows Dienst lässt sich nicht starten", das hier besprochen wird?
                  @sigi234
                  sigi234S Online
                  sigi234S Online
                  @sigi234
                  Erledigt.
                    Das ging schief.
                    Nein, hat er nicht.
                    aleks-83
                    @Stabilostick
                    Sorry, ich meinte nicht NPM updaten sondern den JS Controller.
                    Im Ankündigungsthread stand ja dass man Systeme die per Windows Installer erstellt wurden, nicht per npm updaten soll, deshalb hatte ich Sorge dass da was ungewollt gestartet ist. Gerade auch weil ich gestern erst alles neu aufgesetzt habe (mit Migration).
                    Also kann ich davon ausgehen dass der JS 2.0.29 bei mir jetzt läuft?
                    Oder wirds nur falsch angezeigt? Also dass noch der 1.5.14 installiert ist?
                    Glasfaser 400
                      aleks-83
                      Komplettausfall #2
                      Jetzt hat der Dienst des ioBroker plötzlich nach der Deinstallation des "mobile" Adapters gestoppt, und lässt sich nicht mehr starten.
                      iobroker log während des Absturzes:
                      2019-10-16 07:45:06.764  - info: host.NUC(NUCmaster) iobroker del mobile.0
                      2019-10-16 07:45:08.910  - info: host.NUC(NUCmaster) iobroker Delete adapter "mobile.0"
                      2019-10-16 07:45:08.941  - info: host.NUC(NUCmaster) iobroker host.NUC(NUCmaster) Counted 1 instances of mobile.0
                      2019-10-16 07:45:11.870  - info: host.NUC(NUCmaster) iobroker host.NUC(NUCmaster) Deleting 1 object(s).
                      2019-10-16 07:45:11.894  - info: host.NUC(NUCmaster) object deleted system.adapter.mobile.0
                      2019-10-16 07:45:11.896  - info: lovelace.0 (9380) object system.adapter.mobile.0 deleted
                      2019-10-16 07:45:12.921  - info: host.NUC(NUCmaster) iobroker exit 0
                      2019-10-16 07:45:27.747  - info: host.NUC(NUCmaster) iobroker del mobile
                      2019-10-16 07:45:29.418  - info: host.NUC(NUCmaster) iobroker Delete adapter "mobile"
                      2019-10-16 07:45:29.474  - info: host.NUC(NUCmaster) iobroker host.NUC(NUCmaster) Counted 1 adapter for mobile
                      2019-10-16 07:45:29.554  - info: host.NUC(NUCmaster) iobroker host.NUC(NUCmaster) Counted 1 states of system.adapter.mobile
                      2019-10-16 07:45:29.871  - info: lovelace.0 (9380) object mobile deleted
                      2019-10-16 07:45:29.883  - info: lovelace.0 (9380) object mobile.admin deleted
                      2019-10-16 07:45:29.895  - info: lovelace.0 (9380) object system.adapter.mobile.upload deleted
                      2019-10-16 07:45:29.904  - info: lovelace.0 (9380) object system.adapter.mobile deleted
                      2019-10-16 07:45:29.886  - info: host.NUC(NUCmaster) iobroker host.NUC(NUCmaster) Deleting 2 object(s).
                      2019-10-16 07:45:29.909  - info: host.NUC(NUCmaster) iobroker npm uninstall iobroker.mobile --silent --save --prefix "D:/ioBroker/NUCmaster" (System call)
                      2019-10-16 07:45:30.860  - error: host.NUC(NUCmaster) Cannot write files: D:\ioBroker\NUCmaster\iobroker-data\files\mobile\_data.json: ENOENT: no such file or directory, open 'D:\ioBroker\NUCmaster\iobroker-data\files\mobile\_data.json'
                      2019-10-16 07:45:30.861  - error: host.NUC(NUCmaster) Cannot write files: D:\ioBroker\NUCmaster\iobroker-data\files\mobile.admin\_data.json: ENOENT: no such file or directory, open 'D:\ioBroker\NUCmaster\iobroker-data\files\mobile.admin\_data.json'
                      2019-10-16 07:45:53.665  - info: geofency.0 (11084) adapter geofency received webhook from device Steffi with values: name: KiGa, entry: 0
                      2019-10-16 07:47:04.872  - error: host.NUC(NUCmaster) Objects 127.0.0.1:59186 (Init=false) Redis error:Error: Invalid Chunk: parse failed
                      2019-10-16 07:47:04.874  - error: host.NUC(NUCmaster) States 127.0.0.1:59187 (Init=false) Redis error:Error: Invalid Chunk: parse failed
                      2019-10-16 07:47:05.682  - error: host.NUC(NUCmaster) Objects 127.0.0.1:59191 (Init=false) Redis error:Error: Invalid Chunk: parse failed
                      2019-10-16 07:47:05.850  - error: host.NUC(NUCmaster) States 127.0.0.1:59192 (Init=false) Redis error:Error: Invalid Chunk: parse failed
                      2019-10-16 07:47:08.643  - info: host.NUC(NUCmaster) iobroker events.js:174
                           throw e
                      2019-10-16 07:47:08.644  - info: host.NUC(NUCmaster) iobroker r; // Unhandled 'error' event
                      Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
                         at Server.setupListenHandle [as _listen2] (net.js:1279:14)
                         at listenInCluster (net.js:1327:12)
                         at doListen (net.js:1460:7)
                      Emitted 'error' event at:
                         at emitErrorNT (net.js:1306:8)
                      2019-10-16 07:48:28.872  - error: host.NUC(NUCmaster) uncaught exception: ENOENT: no such file or directory, open 'D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller\lib/../io-package.json'
                      2019-10-16 07:48:28.907  - info: ping.0 (11592) Got terminate signal TERMINATE_YOURSELF
                      2019-10-16 07:48:28.930  - info: geofency.0 (11084) Got terminate signal TERMINATE_YOURSELF
                      2019-10-16 07:48:28.926  - info: backitup.0 (8420) Got terminate signal TERMINATE_YOURSELF
                      2019-10-16 07:48:28.935  - info: enigma2.0 (6524) Got terminate signal TERMINATE_YOURSELF
                      2019-10-16 07:48:28.945  - info: javascript.0 (8992) Got terminate signal TERMINATE_YOURSELF
                      2019-10-16 07:48:29.007  - info: enigma2.1 (2716) Got terminate signal TERMINATE_YOURSELF
                      2019-10-16 07:48:29.019  - info: email.0 (9008) Got terminate signal TERMINATE_YOURSELF
                      2019-10-16 07:48:29.016  - info: text2command.0 (5956) Got terminate signal TERMINATE_YOURSELF
                      2019-10-16 07:48:29.023  - info: telegram.0 (5972) Got terminate signal TERMINATE_YOURSELF
                      2019-10-16 07:48:29.025  - info: iot.0 (8428) Got terminate signal TERMINATE_YOURSELF
                      2019-10-16 07:48:29.020  - info: pushover.0 (8276) Got terminate signal TERMINATE_YOURSELF
                      2019-10-16 07:48:29.028  - info: lovelace.0 (9380) Got terminate signal TERMINATE_YOURSELF
                      2019-10-16 07:48:29.042  - info: hue-extended.0 (8700) Got terminate signal TERMINATE_YOURSELF
                      2019-10-16 07:48:29.046  - info: web.0 (10252) Got terminate signal TERMINATE_YOURSELF
                      2019-10-16 07:48:29.100  - info: sonos.0 (8728) Got terminate signal TERMINATE_YOURSELF
                      2019-10-16 07:48:28.874  - error: host.NUC(NUCmaster) Error: ENOENT: no such file or directory, open 'D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller\lib/../io-package.json'
                         at Object.openSync (fs.js:443:3)
                         at Object.readFileSync (fs.js:343:35)
                         at Object.getInstalledInfo (D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller\lib\tools.js:533:37)
                         at objects.getObjectView (D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller\main.js:1763:42)
                         at Immediate.callback.function.setImmediate (D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller\lib\objects\objectsInMemFileDB.js:1813:62)
                         at runCallback (timers.js:705:18)
                         at tryOnImmediate (timers.js:676:5)
                         at processImmediate (timers.js:658:5)
                      2019-10-16 07:48:28.876  - info: host.NUC(NUCmaster) stopInstance system.adapter.admin.0
                      2019-10-16 07:48:28.876  - info: host.NUC(NUCmaster) stopInstance system.adapter.discovery.0
                      2019-10-16 07:48:28.876  - info: host.NUC(NUCmaster) stopInstance system.adapter.history.0
                      2019-10-16 07:48:28.876  - info: host.NUC(NUCmaster) stopInstance system.adapter.tr-064.0
                      2019-10-16 07:48:28.877  - info: host.NUC(NUCmaster) stopInstance system.adapter.vis.0
                      2019-10-16 07:48:28.877  - info: host.NUC(NUCmaster) stopInstance system.adapter.ping.0
                      2019-10-16 07:48:28.877  - info: host.NUC(NUCmaster) stopInstance system.adapter.ical.0
                      2019-10-16 07:48:28.877  - info: host.NUC(NUCmaster) stopInstance canceled schedule system.adapter.ical.0
                      2019-10-16 07:48:28.877  - info: host.NUC(NUCmaster) stopInstance system.adapter.ical.1
                      2019-10-16 07:48:28.878  - info: host.NUC(NUCmaster) stopInstance canceled schedule system.adapter.ical.1
                      2019-10-16 07:48:28.878  - info: host.NUC(NUCmaster) stopInstance system.adapter.hue.0
                      2019-10-16 07:48:28.878  - info: host.NUC(NUCmaster) stopInstance system.adapter.denon.0
                      2019-10-16 07:48:28.878  - info: host.NUC(NUCmaster) stopInstance system.adapter.vis-fancyswitch.0
                      2019-10-16 07:48:28.878  - info: host.NUC(NUCmaster) stopInstance system.adapter.harmony.0
                      2019-10-16 07:48:28.879  - info: host.NUC(NUCmaster) stopInstance system.adapter.vis-timeandweather.0
                      2019-10-16 07:48:28.879  - info: host.NUC(NUCmaster) stopInstance system.adapter.firetv.0
                      2019-10-16 07:48:28.879  - info: host.NUC(NUCmaster) stopInstance system.adapter.vis-hqwidgets.0
                      2019-10-16 07:48:28.879  - info: host.NUC(NUCmaster) stopInstance system.adapter.vis-colorpicker.0
                      2019-10-16 07:48:28.879  - info: host.NUC(NUCmaster) stopInstance system.adapter.backitup.0
                      2019-10-16 07:48:28.879  - info: host.NUC(NUCmaster) stopInstance system.adapter.geofency.0
                      2019-10-16 07:48:28.880  - info: host.NUC(NUCmaster) stopInstance system.adapter.enigma2.0
                      2019-10-16 07:48:28.880  - info: host.NUC(NUCmaster) stopInstance system.adapter.vis-metro.0
                      2019-10-16 07:48:28.880  - info: host.NUC(NUCmaster) stopInstance system.adapter.mihome-vacuum.0
                      2019-10-16 07:48:28.880  - info: host.NUC(NUCmaster) stopInstance system.adapter.vis-canvas-gauges.0
                      2019-10-16 07:48:28.880  - info: host.NUC(NUCmaster) stopInstance system.adapter.unifi.0
                      2019-10-16 07:48:28.880  - info: host.NUC(NUCmaster) stopInstance system.adapter.stiebel-isg.0
                      2019-10-16 07:48:28.880  - info: host.NUC(NUCmaster) stopInstance system.adapter.terminal.0
                      2019-10-16 07:48:28.880  - info: host.NUC(NUCmaster) stopInstance system.adapter.alexa2.0
                      2019-10-16 07:48:28.881  - info: host.NUC(NUCmaster) stopInstance system.adapter.vis-google-fonts.0
                      2019-10-16 07:48:28.881  - info: host.NUC(NUCmaster) stopInstance system.adapter.vis-players.0
                      2019-10-16 07:48:28.881  - info: host.NUC(NUCmaster) stopInstance system.adapter.scenes.0
                      2019-10-16 07:48:28.881  - info: host.NUC(NUCmaster) stopInstance system.adapter.vis-bars.0
                      2019-10-16 07:48:28.882  - info: host.NUC(NUCmaster) stopInstance system.adapter.tankerkoenig.0
                      2019-10-16 07:48:28.882  - info: host.NUC(NUCmaster) stopInstance system.adapter.javascript.0
                      2019-10-16 07:48:28.882  - info: host.NUC(NUCmaster) stopInstance system.adapter.fritzdect.0
                      2019-10-16 07:48:28.883  - info: host.NUC(NUCmaster) stopInstance system.adapter.info.0
                      2019-10-16 07:48:28.883  - info: host.NUC(NUCmaster) stopInstance system.adapter.vis-rgraph.0
                      2019-10-16 07:48:28.883  - info: host.NUC(NUCmaster) stopInstance system.adapter.gruenbeck.0
                      2019-10-16 07:48:28.883  - info: host.NUC(NUCmaster) stopInstance system.adapter.fullybrowser.0
                      2019-10-16 07:48:28.884  - info: host.NUC(NUCmaster) stopInstance system.adapter.enigma2.1
                      2019-10-16 07:48:28.884  - info: host.NUC(NUCmaster) stopInstance system.adapter.text2command.0
                      2019-10-16 07:48:28.884  - info: host.NUC(NUCmaster) stopInstance system.adapter.email.0
                      2019-10-16 07:48:28.884  - info: host.NUC(NUCmaster) stopInstance system.adapter.pushover.0
                      2019-10-16 07:48:28.885  - info: host.NUC(NUCmaster) stopInstance system.adapter.telegram.0
                      2019-10-16 07:48:28.885  - info: host.NUC(NUCmaster) stopInstance system.adapter.iot.0
                      2019-10-16 07:48:28.885  - info: host.NUC(NUCmaster) stopInstance system.adapter.smartmeter.0
                      2019-10-16 07:48:28.885  - info: host.NUC(NUCmaster) stopInstance system.adapter.lovelace.0
                      2019-10-16 07:48:28.888  - info: host.NUC(NUCmaster) stopInstance system.adapter.upnp.0
                      2019-10-16 07:48:28.888  - info: host.NUC(NUCmaster) stopInstance system.adapter.mihome.0
                      2019-10-16 07:48:28.888  - info: host.NUC(NUCmaster) stopInstance system.adapter.weatherunderground.0
                      2019-10-16 07:48:28.888  - info: host.NUC(NUCmaster) stopInstance canceled schedule system.adapter.weatherunderground.0
                      2019-10-16 07:48:28.889  - info: host.NUC(NUCmaster) stopInstance system.adapter.fakeroku.0
                      2019-10-16 07:48:28.889  - info: host.NUC(NUCmaster) stopInstance system.adapter.hue-extended.0
                      2019-10-16 07:48:28.889  - info: host.NUC(NUCmaster) stopInstance system.adapter.web.0
                      2019-10-16 07:48:28.889  - info: host.NUC(NUCmaster) stopInstance system.adapter.socketio.0
                      2019-10-16 07:48:28.889  - info: host.NUC(NUCmaster) stopInstance system.adapter.sonos.0
                      2019-10-16 07:48:28.889  - info: host.NUC(NUCmaster) stopInstance system.adapter.dwd.0
                      2019-10-16 07:48:28.890  - info: host.NUC(NUCmaster) stopInstance canceled schedule system.adapter.dwd.0
                      2019-10-16 07:48:28.890  - info: host.NUC(NUCmaster) iobroker _restart
                      2019-10-16 07:48:28.901  - info: host.NUC(NUCmaster) stopInstance system.adapter.admin.0 send kill signal
                      2019-10-16 07:48:28.904  - info: host.NUC(NUCmaster) stopInstance system.adapter.tr-064.0 send kill signal
                      2019-10-16 07:48:28.907  - info: host.NUC(NUCmaster) stopInstance system.adapter.ping.0 send kill signal
                      2019-10-16 07:48:28.915  - info: host.NUC(NUCmaster) stopInstance system.adapter.hue.0 send kill signal
                      2019-10-16 07:48:28.918  - info: host.NUC(NUCmaster) stopInstance system.adapter.harmony.0 send kill signal
                      2019-10-16 07:48:28.925  - info: host.NUC(NUCmaster) stopInstance system.adapter.backitup.0 send kill signal
                      2019-10-16 07:48:28.930  - info: host.NUC(NUCmaster) stopInstance system.adapter.geofency.0 send kill signal
                      2019-10-16 07:48:28.934  - info: host.NUC(NUCmaster) stopInstance system.adapter.enigma2.0 send kill signal
                      2019-10-16 07:48:28.936  - info: host.NUC(NUCmaster) stopInstance system.adapter.alexa2.0 send kill signal
                      2019-10-16 07:48:28.940  - info: host.NUC(NUCmaster) stopInstance system.adapter.tankerkoenig.0 send kill signal
                      2019-10-16 07:48:28.944  - info: host.NUC(NUCmaster) stopInstance system.adapter.javascript.0 send kill signal
                      2019-10-16 07:48:28.947  - info: host.NUC(NUCmaster) stopInstance system.adapter.fritzdect.0 send kill signal
                      2019-10-16 07:48:28.951  - info: host.NUC(NUCmaster) stopInstance system.adapter.info.0 send kill signal
                      2019-10-16 07:48:28.952  - info: host.NUC(NUCmaster) stopInstance system.adapter.gruenbeck.0 send kill signal
                      2019-10-16 07:48:29.002  - info: host.NUC(NUCmaster) stopInstance system.adapter.fullybrowser.0 send kill signal
                      2019-10-16 07:48:29.005  - info: host.NUC(NUCmaster) stopInstance system.adapter.enigma2.1 send kill signal
                      2019-10-16 07:48:29.015  - info: host.NUC(NUCmaster) stopInstance system.adapter.text2command.0 send kill signal
                      2019-10-16 07:48:29.017  - info: host.NUC(NUCmaster) stopInstance system.adapter.email.0 send kill signal
                      2019-10-16 07:48:29.019  - info: host.NUC(NUCmaster) stopInstance system.adapter.pushover.0 send kill signal
                      2019-10-16 07:48:29.021  - info: host.NUC(NUCmaster) stopInstance system.adapter.telegram.0 send kill signal
                      2019-10-16 07:48:29.023  - info: host.NUC(NUCmaster) stopInstance system.adapter.iot.0 send kill signal
                      2019-10-16 07:48:29.026  - info: host.NUC(NUCmaster) stopInstance system.adapter.lovelace.0 send kill signal
                      2019-10-16 07:48:29.028  - info: host.NUC(NUCmaster) stopInstance system.adapter.upnp.0 send kill signal
                      2019-10-16 07:48:29.030  - info: host.NUC(NUCmaster) stopInstance system.adapter.mihome.0 send kill signal
                      2019-10-16 07:48:29.037  - info: host.NUC(NUCmaster) stopInstance system.adapter.fakeroku.0 send kill signal
                      2019-10-16 07:48:29.040  - info: host.NUC(NUCmaster) stopInstance system.adapter.hue-extended.0 send kill signal
                      2019-10-16 07:48:29.044  - info: host.NUC(NUCmaster) stopInstance system.adapter.web.0 send kill signal
                      2019-10-16 07:48:29.046  - info: host.NUC(NUCmaster) stopInstance system.adapter.socketio.0 send kill signal
                      2019-10-16 07:48:29.054  - info: host.NUC(NUCmaster) stopInstance system.adapter.sonos.0 send kill signal
                      2019-10-16 07:48:28.946  - ( Hier wurden alle Skripte gestoppt )
                      2019-10-16 07:48:29.141  - info: javascript.0 (8992) terminating
                      2019-10-16 07:48:29.142  - info: javascript.0 (8992) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2019-10-16 07:48:29.320  - info: host.NUC(NUCmaster) instance system.adapter.geofency.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                      2019-10-16 07:48:29.323  - info: host.NUC(NUCmaster) instance system.adapter.harmony.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                      2019-10-16 07:48:29.326  - info: host.NUC(NUCmaster) instance system.adapter.tr-064.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                      2019-10-16 07:48:29.413  - info: ping.0 (11592) terminating
                      2019-10-16 07:48:29.414  - info: ping.0 (11592) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2019-10-16 07:48:29.431  - info: backitup.0 (8420) terminating
                      2019-10-16 07:48:29.439  - info: enigma2.0 (6524) terminating
                      2019-10-16 07:48:29.511  - info: enigma2.1 (2716) terminating
                      2019-10-16 07:48:29.521  - info: email.0 (9008) terminating
                      2019-10-16 07:48:29.523  - info: text2command.0 (5956) terminating
                      2019-10-16 07:48:29.522  - info: email.0 (9008) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2019-10-16 07:48:29.527  - info: pushover.0 (8276) terminating
                      2019-10-16 07:48:29.532  - info: telegram.0 (5972) terminating
                      2019-10-16 07:48:29.533  - info: telegram.0 (5972) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2019-10-16 07:48:29.663  - info: host.NUC(NUCmaster) instance system.adapter.fritzdect.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                      2019-10-16 07:48:29.665  - info: host.NUC(NUCmaster) instance system.adapter.hue.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                      2019-10-16 07:48:29.666  - info: host.NUC(NUCmaster) instance system.adapter.alexa2.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                      2019-10-16 07:48:29.668  - info: host.NUC(NUCmaster) instance system.adapter.hue-extended.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                      2019-10-16 07:48:29.670  - info: host.NUC(NUCmaster) instance system.adapter.socketio.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                      2019-10-16 07:48:29.671  - info: host.NUC(NUCmaster) instance system.adapter.fakeroku.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                      2019-10-16 07:48:29.673  - info: host.NUC(NUCmaster) instance system.adapter.lovelace.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                      2019-10-16 07:48:29.674  - info: host.NUC(NUCmaster) instance system.adapter.upnp.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                      2019-10-16 07:48:29.676  - info: host.NUC(NUCmaster) instance system.adapter.info.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                      2019-10-16 07:48:29.677  - info: host.NUC(NUCmaster) instance system.adapter.sonos.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                      2019-10-16 07:48:29.679  - info: host.NUC(NUCmaster) instance system.adapter.mihome.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                      2019-10-16 07:48:29.680  - info: host.NUC(NUCmaster) instance system.adapter.iot.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                      2019-10-16 07:48:29.682  - info: host.NUC(NUCmaster) instance system.adapter.gruenbeck.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                      2019-10-16 07:48:29.683  - info: host.NUC(NUCmaster) instance system.adapter.web.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                      2019-10-16 07:48:29.685  - info: host.NUC(NUCmaster) instance system.adapter.fullybrowser.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                      2019-10-16 07:48:29.739  - error: host.NUC(NUCmaster) iobroker internal/modules/cjs/loader.js:638
                         throw err;
                      Error: Cannot find module 'D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller\iobroker.js'
                         at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                         at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                         at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
                         at startup (internal/bootstrap/node.js:283:19)
                         at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3)
                      2019-10-16 07:48:29.766  - info: host.NUC(NUCmaster) iobroker exit 1
                      2019-10-16 07:48:30.073  - info: host.NUC(NUCmaster) instance system.adapter.admin.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                      2019-10-16 07:48:30.075  - info: host.NUC(NUCmaster) instance system.adapter.javascript.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                      2019-10-16 07:48:30.076  - info: host.NUC(NUCmaster) instance system.adapter.ping.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                      2019-10-16 07:48:30.076  - info: host.NUC(NUCmaster) instance system.adapter.enigma2.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                      2019-10-16 07:48:30.077  - info: host.NUC(NUCmaster) instance system.adapter.backitup.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                      2019-10-16 07:48:30.078  - info: host.NUC(NUCmaster) instance system.adapter.tankerkoenig.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                      2019-10-16 07:48:30.078  - info: host.NUC(NUCmaster) instance system.adapter.enigma2.1 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                      2019-10-16 07:48:30.079  - info: host.NUC(NUCmaster) instance system.adapter.email.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                      2019-10-16 07:48:30.079  - info: host.NUC(NUCmaster) instance system.adapter.text2command.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                      2019-10-16 07:48:30.080  - info: host.NUC(NUCmaster) instance system.adapter.pushover.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                      2019-10-16 07:48:30.080  - info: host.NUC(NUCmaster) instance system.adapter.telegram.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                      2019-10-16 07:48:31.235  - info: host.NUC(NUCmaster) stopInstance timeout "2000 system.adapter.history.0 killing pid  8360
                      2019-10-16 07:48:31.270  - warn: host.NUC(NUCmaster) instance system.adapter.history.0 terminated due to SIGTERM
                      2019-10-16 07:48:31.271  - info: host.NUC(NUCmaster) instance system.adapter.history.0 terminated with code null ()
                      2019-10-16 07:48:31.271  - info: host.NUC(NUCmaster) All instances are stopped.
                      2019-10-16 07:48:31.441  - info: host.NUC(NUCmaster) terminated
                      Windows Dienste beim Versuch den Dienst zu starten:
                      ioBroker.wrapper.log beim Versuch den Dienst zu starten:
                      2019-10-16 08:12:24,317 INFO  - Starting ServiceWrapper in the service mode
                      2019-10-16 08:12:24,368 INFO  - Starting "D:\ioBroker\NUCmaster\nodejs\node.exe" "D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller\controller.js"
                      2019-10-16 08:12:24,375 INFO  - Starting "D:\ioBroker\NUCmaster\nodejs\node.exe" "D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller\controller.js"
                      2019-10-16 08:12:24,418 INFO  - Started process 5864
                      2019-10-16 08:12:24,430 DEBUG - Forwarding logs of the process System.Diagnostics.Process (node) to winsw.RollingSizeTimeLogAppender
                      iobroker.err.log beim Versuch den Dienst zu starten:
                      Error: Cannot find module 'D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller\controller.js'
                      Glasfaser 400
                      • A aleks-83
                        Komplettausfall #2
                             throw e
                           throw err;
                        @aleks-83 hm ... da hat npm was kaputt gemacht. Bitte js Controller wieder Manuel installieren.
                          aleks-83
                          OK, wie mache ich das unter Windows?
                          Das Update auf 2.0.29 ist ja eh "versehentlich" passiert durch den button "alle Adapter updaten".
                          Kann ich dann jetzt erst wieder zurück zu 1.5.14?
                          Glasfaser 400
                          • A aleks-83
                            Stabilostick
                            @aleks-83
                            Kann es sein, dass Du in der ioBroker Konfiguration vor der Migration diesen auf „latest“ stehen hattest? Das würde die Installation von 2.0.29 erklären.
                            Ist die Datei „ D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller\controller.js“ vorhanden?
                              @aleks-83
                              aleks-83
                              @aleks-83
                              Ja, hatte ich.
                              Soll ich nochmal neu migrieren?
                              Und sobald der Admin startet, direkt als erstes auf "stable" stellen?
                              Nein, es gibt den Ordner "iobroker.js-controller" nicht.
                              Glasfaser 400
                              • A aleks-83
                                @aleks-83
                                Ja, hatte ich.
                                Stabilostick
                                Wau. Na dann mache mal die Kommandozeile der Instanz über das Startmenü auf und führe aus:
                                npm install iobroker.js-controller@latest --production
                                Was passiert da dann?
                                  aleks-83
                                  Er scheint was installiert zu haben.
                                  Sind aber auch viele ERR Meldungen dabei:
                                  D:\ioBroker\NUCmaster>npm install iobroker.js-controller@latest --production
                                  > iobroker.js-controller@2.0.29 preinstall D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller
                                  > node lib/preinstallCheck.js
                                  NPM version: 6.9.0
                                  > authenticate-pam@1.0.2 install D:\ioBroker\NUCmaster\node_modules\authenticate-pam
                                  > node-gyp rebuild
                                  D:\ioBroker\NUCmaster\node_modules\authenticate-pam>if not defined npm_config_node_gyp (node "D:\ioBroker\NUCmaster\nodejs\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin\\..\..\node_modules\node-gyp\bin\node-gyp.js" rebuild )  else (node "D:\ioBroker\NUCmaster\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" rebuild )
                                  Die Projekte in dieser Projektmappe werden nacheinander erstellt. Um eine parallele Erstellung zu ermöglichen, müssen Sie den Schalter "/m" hinzufügen.
                                   authenticate_pam.cc
                                   win_delay_load_hook.cc
                                  d:\iobroker\nucmaster\node_modules\authenticate-pam\authenticate_pam.cc(24): fatal error C1083: Datei (Include) kann nicht geöffnet werden: "uni
                                  std.h": No such file or directory [D:\ioBroker\NUCmaster\node_modules\authenticate-pam\build\authenticate_pam.vcxproj]
                                  gyp ERR! build error
                                  gyp ERR! cwd D:\ioBroker\NUCmaster\node_modules\authenticate-pam
                                  gyp ERR! node -v v10.16.3
                                  gyp ERR! not ok
                                  > serialport@6.2.2 install D:\ioBroker\NUCmaster\node_modules\iobroker.discovery\node_modules\serialport
                                  > prebuild-install || node-gyp rebuild
                                  > unix-dgram@2.0.2 install D:\ioBroker\NUCmaster\node_modules\unix-dgram
                                  > node-gyp rebuild
                                  D:\ioBroker\NUCmaster\node_modules\unix-dgram>if not defined npm_config_node_gyp (node "D:\ioBroker\NUCmaster\nodejs\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin\\..\..\node_modules\node-gyp\bin\node-gyp.js" rebuild )  else (node "D:\ioBroker\NUCmaster\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" rebuild )
                                   unix_dgram.cc
                                  d:\iobroker\nucmaster\node_modules\unix-dgram\src\unix_dgram.cc(9): fatal error C1083: Datei (Include) kann nicht geöffnet werden: "unistd.h": N
                                  o such file or directory [D:\ioBroker\NUCmaster\node_modules\unix-dgram\build\unix_dgram.vcxproj]
                                  gyp ERR! cwd D:\ioBroker\NUCmaster\node_modules\unix-dgram
                                  gyp ERR! not ok
                                  > ursa-optional@0.9.10 install D:\ioBroker\NUCmaster\node_modules\ursa-optional
                                  > node rebuild.js
                                  > diskusage@1.1.3 install D:\ioBroker\NUCmaster\node_modules\diskusage
                                  > node-gyp rebuild
                                  D:\ioBroker\NUCmaster\node_modules\diskusage>if not defined npm_config_node_gyp (node "D:\ioBroker\NUCmaster\nodejs\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin\\..\..\node_modules\node-gyp\bin\node-gyp.js" rebuild )  else (node "D:\ioBroker\NUCmaster\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" rebuild )
                                   main.cpp
                                   diskusage_win.cpp
                                      Bibliothek "D:\ioBroker\NUCmaster\node_modules\diskusage\build\Release\diskusage.lib" und Objekt "D:\ioBroker\NUCmaster\node_modules\diskus
                                   age\build\Release\diskusage.exp" werden erstellt.
                                   Code wird generiert.
                                   All 262 functions were compiled because no usable IPDB/IOBJ from previous compilation was found.
                                   Codegenerierung ist abgeschlossen.
                                   diskusage.vcxproj -> D:\ioBroker\NUCmaster\node_modules\diskusage\build\Release\\diskusage.node
                                  > iobroker.js-controller@2.0.29 install D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller
                                  > node iobroker.js setup first
                                  > acme-v2@1.8.5 postinstall D:\ioBroker\NUCmaster\node_modules\acme-v2
                                  > node scripts/postinstall
                                  👉  Do you rely on Greenlock?  👈
                                  👉               (or ACME.js)  👈
                                  Hey! Let's Encrypt will STOP WORKING with Greenlock and ACME.js at the end of Oct 2019.
                                  WITHOUT YOUR HELP we won't get the next release out in time.
                                  If Greenlock (or ACME.js) has saved you time and money, and taken stress out of your life,
                                  or you just love it, please reach out to return the favor today:
                                  SAVE GREENLOCK / ACME.js:
                                  https://indiegogo.com/at/greenlock
                                  npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/common@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
                                  npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/core@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
                                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.1 (node_modules\fsevents):
                                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
                                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules\osx-temperature-sensor):
                                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
                                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules\authenticate-pam):
                                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuild`
                                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.2 (node_modules\unix-dgram):
                                  + iobroker.js-controller@2.0.29
                                  added 207 packages from 214 contributors, removed 74 packages, updated 3 packages, moved 10 packages and audited 1566 packages in 117.15s
                                  found 12 vulnerabilities (9 low, 3 high)
                                   run `npm audit fix` to fix them, or `npm audit` for details
                                  Läuft wieder alles.
                                  Glasfaser 400
                                  • A aleks-83
                                    NPM version: 6.9.0
                                    > node-gyp rebuild
                                     authenticate_pam.cc
                                    gyp ERR! not ok
                                    > node-gyp rebuild
                                     unix_dgram.cc
                                    gyp ERR! not ok
                                    > node rebuild.js
                                    > node-gyp rebuild
                                     main.cpp
                                     diskusage_win.cpp
                                    👉               (or ACME.js)  👈
                                    Läuft wieder alles.
                                    Stabilostick
                                    @aleks-83
                                    npm install @angular/common@
                                    npm install @angular/core@
                                    Sieht aber schon einmal trotz der Meldungen gut aus. Bist freiwilliger Betatester, weil Du Dein System auf „latest“ stehen hast. 👌 🤗
                                      aleks-83
                                      OK, habe ich durchgeführt.
                                      D:\ioBroker\NUCmaster>npm install @angular/common@
                                      > node-gyp rebuild
                                        authenticate_pam.cc
                                      gyp ERR! not ok
                                      > node-gyp rebuild
                                        unix_dgram.cc
                                      gyp ERR! not ok
                                      npm WARN @angular/common@8.2.11 requires a peer of rxjs@^6.4.0 but none is installed. You must install peer dependencies yourself.
                                      npm WARN @angular/common@8.2.11 requires a peer of @angular/core@8.2.11 but none is installed. You must install peer dependencies yourself.
                                      + @angular/common@8.2.11
                                      added 2 packages from 2 contributors and audited 1568 packages in 303.548s
                                        run `np
                                      [/s]m audit fix` to fix them, or `npm audit` for details
                                      D:\ioBroker\NUCmaster>npm install @angular/core@
                                      > node-gyp rebuild
                                        authenticate_pam.cc
                                      gyp ERR! not ok
                                      > node-gyp rebuild
                                        unix_dgram.cc
                                      gyp ERR! not ok
                                      npm WARN @angular/core@8.2.11 requires a peer of rxjs@^6.4.0 but none is installed. You must install peer dependencies yourself.
                                      npm WARN @angular/core@8.2.11 requires a peer of zone.js@~0.9.1 but none is installed. You must install peer dependencies yourself.
                                      + @angular/core@8.2.11
                                      added 1 package from 1 contributor and audited 1570 packages in 70.735s
                                      @Stabilostick
                                      Bist freiwilliger Betatester, weil Du Dein System auf „latest“ stehen hast. 👍🏻🤗
                                      "Freiwillig", ja 😂
                                      Eigentlich möchte ich nur dass es wieder (rund) läuft... 🤕
                                      Glasfaser 400
                                        aleks-83
                                        Wie kann ich denn bitte wieder zurück zum JS 1.5.14 downgraden?
                                        Mit dem 2.x habe ich immer wieder mal Probleme.
                                        Bin jetzt bei 2.0.38.
                                        Admin 3.6.10
                                        Javascript 4.3.1
                                        Aktuell zeigt mir der Javasript Adapter an dass die Instanz deaktiviert wäre, obwohl sie grün ist.
                                        Als ich gerade mal den Moment beobachtet habe wo die Instanz angeblich in deaktiviert gewechsel hat, erschien im Log die Debug Zeile:
                                        (10140) sendTo "loadTypings" to system.adapter.admin.0 from system.adapter.javascript.0
                                        Glasfaser 400
                                        StabilostickS apollon77A 2 Antworten Letzte Antwort
                                        • A aleks-83
                                          Admin 3.6.10
                                          Javascript 4.3.1
                                          Stabilostick
                                          @aleks-83
                                          Downgrade über den 1.5.14‘er Installer und Migration in neue Instanz. Vorher ggf. das Repository im Admin von latest nach stable (=default) umstellen.
