  4. Windows Dienst lässt sich nicht mehr starten
    5.6k
windows dienstnode.js
54 Beiträge 4 Kommentatoren 8.3k Aufrufe 4 Beobachtet
  • A aleks-83
    Was mir gerade noch aufgefallen ist bei der Neueinrichtung:
    Als er alle Adapter aus der Migration installiert hatte, habe ich per admin Adapter gesagt er soll alle Adapter updaten.
    Dann hat er versucht NPM upzugraden.
    Das ging schief.
    ... Hier wurden Adapter geupdatet ...
    Adapter "xs1" is not installed.
    Adapter "yahka" is not installed.
    Adapter "yamaha" is not installed.
    Adapter "yeelight-2" is not installed.
    Adapter "yr" is not installed.
    Adapter "zigbee" is not installed.
    Adapter "zont" is not installed.
    Adapter "zwave" is not installed.
    Adapter "zwave2" is not installed.
    Update js-controller from @1.5.14 to @2.0.29
    2019-10-14 20:36:35.125 - warn: host.NUC(NUCmaster) instance system.adapter.web.0 terminated due to SIGTERM
    2019-10-14 20:36:35.125 - info: host.NUC(NUCmaster) instance system.adapter.web.0 terminated with code null ()
    2019-10-14 20:36:37.511 - info: host.NUC(NUCmaster) instance system.adapter.web.0 started with pid 6360
    2019-10-14 20:36:38.566 - info: iobroker NPM version: 6.9.0
    2019-10-14 20:36:38.566 - info: iobroker npm install iobroker.js-controller@2.0.29 --unsafe-perm --production --save --prefix "D:/ioBroker/NUCmaster" (System call)
    2019-10-14 20:36:39.571 - info: web.0 starting. Version 2.4.5 in D:/ioBroker/NUCmaster/node_modules/iobroker.web, node: v10.16.3
    2019-10-14 20:36:41.833 - info: web.0 socket.io server listening on port 8083
    2019-10-14 20:36:41.838 - info: web.0 http server listening on port 8083
    2019-10-14 20:37:33.190 - info: iobroker gyp
    2019-10-14 20:37:33.191 - info: iobroker ERR!
    2019-10-14 20:37:33.193 - info: iobroker
    2019-10-14 20:37:33.199 - info: iobroker build error
    2019-10-14 20:37:33.200 - info: iobroker
    2019-10-14 20:37:33.229 - info: iobroker gyp ERR! stack Error: `C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe` failed with exit code: 1gyp ERR! stack at ChildProcess.onExit (D:\ioBroker\NUCmaster\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:262:23)
    gyp ERR! stack at ChildProcess.emit (events.js:198:13)
    gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
    gyp ERR! System Windows_NT 10.0.18362
    2019-10-14 20:37:33.235 - info: iobroker gyp ERR! command "D:\\ioBroker\\NUCmaster\\nodejs\\node.exe" "D:\\ioBroker\\NUCmaster\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"gyp
    2019-10-14 20:37:33.237 - info: iobroker ERR!
    2019-10-14 20:37:33.241 - info: iobroker cwd D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller\node_modules\unix-dgramgyp ERR!
    2019-10-14 20:37:33.242 - info: iobroker node -v v10.16.3gyp ERR! node-gyp -v v3.8.0
    gyp ERR! not ok
    2019-10-14 20:38:12.125 - info: iobroker npm
    2019-10-14 20:38:12.126 - info: iobroker
    2019-10-14 20:38:12.130 - info: iobroker WARN
    2019-10-14 20:38:12.133 - info: iobroker
    2019-10-14 20:38:12.140 - info: iobroker optional
    2019-10-14 20:38:12.144 - info: iobroker SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.1 (node_modules\iobroker.js-controller\node_modules\fsevents):
    2019-10-14 20:38:12.165 - info: iobroker npm
    2019-10-14 20:38:12.176 - info: iobroker
    2019-10-14 20:38:12.180 - info: iobroker WARN
    2019-10-14 20:38:12.181 - info: iobroker
    2019-10-14 20:38:12.182 - info: iobroker notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
    2019-10-14 20:38:12.183 - info: iobroker npm
    2019-10-14 20:38:12.187 - info: iobroker WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.2 (node_modules\iobroker.js-controller\node_modules\unix-dgram):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.2 install: `node-gyp rebuild`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    2019-10-14 20:38:12.256 - info: iobroker Host "NUC(NUCmaster)" (win32) updated
    2019-10-14 20:38:12.256 - info: iobroker Starting node restart.js
    2019-10-14 20:38:12.343 - info: iobroker exit 0
    2019-10-14 20:39:43.348 - info: host.NUC(NUCmaster) Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
    Kann es sein dass er das beim letzten Update auch versucht hat, und mir die Zeile mit dem mkdir zerschossen hat?
    Ich habe den NUC jetzt aber schon neu gestartet.
    Der Dienst startet noch ganz normal.
    Dann werde ich den button "Alle Adapter updaten" erst mal meiden.
    EDIT:
    Der Admin zeigt mir aber an ich hätte die 2.0.29
    aleks-83
    schrieb am zuletzt editiert von aleks-83
    #41
    @aleks-83 sagte in Windows Dienst lässt sich nicht mehr starten:
    Dann hat er den JS Controller geupdatet
    Es wird aktuell übrigens immer noch der JSC mit geupdatet wenn ich auf "alle Adapter updaten" klicke.
    Bin vorher aber auf das stable repository gewechselt.
    Admin ist 3.6.10
    JS 2.0.39
    = Dell Optiplex Micro - 10GB RAM - 200GB SSD - Debian VM =
    = Node.js v20.19.6 = NPM 10.8.2 = JS Controller 7.0.7 =
    Ubiquiti UAP-AC-LR - UAP-AC-Lite - Synology DS716+II - Fritz!Box 7490
    Glasfaser 400
      aleks-83
      #42
      Und wieder habe ich einen Komplett Ausfall 😞
      Dienst startet nicht mehr seit dem großen Win10 Update.
      Cannot parse "/snapshots/vis-views.json
      Cannot read property 'stopping' of undefined
      TypeError: Cannot read property 'stopping' of undefined
          at cleanAutoSubscribes (D:\ioBroker\NUC\node_modules\iobroker.js-controller\main.js:2938:47)
          at objects.getObjectView (D:\ioBroker\NUC\node_modules\iobroker.js-controller\main.js:796:31)
          at Immediate.callback.function.setImmediate (D:\ioBroker\NUC\node_modules\iobroker.js-controller\lib\objects\objectsInMemFileDB.js:1950:62)
          at runCallback (timers.js:705:18)
          at tryOnImmediate (timers.js:676:5)
          at processImmediate (timers.js:658:5)
      internal/modules/cjs/loader.js:638
          throw err;
      Error: Cannot find module '@iobroker/plugin-base'
          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
          at Function.Module._load (internal/modules/cjs/loader.js:562:25)
          at Module.require (internal/modules/cjs/loader.js:692:17)
          at require (internal/modules/cjs/helpers.js:25:18)
          at Object.<anonymous> (D:\ioBroker\NUC\node_modules\iobroker.js-controller\lib\adapter.js:32:27)
          at Module._compile (internal/modules/cjs/loader.js:778:30)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
          at Module.load (internal/modules/cjs/loader.js:653:32)
          at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
          at Function.Module._load (internal/modules/cjs/loader.js:585:3)
          throw err;
      Error: Cannot find module 'has'
          at Object.<anonymous> (D:\ioBroker\NUC\node_modules\node.extend\lib\extend.js:13:11)
          throw err;
      Error: Cannot find module 'D:\ioBroker\NUC\node_modules\iobroker.js-controller\controller.js'
          at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
          at startup (internal/bootstrap/node.js:283:19)
          at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
          throw err;
          throw err;
          throw err;
          throw err;
          throw err;
          throw err;
          throw err;
          throw err;
          throw err;
          throw err;
          throw err;
          throw err;
      2020-07-06 17:54:59,257 DEBUG - Starting ServiceWrapper in the CLI mode
      2020-07-06 17:54:59,784 INFO  - Starting the service with id 'iobroker(NUC)'
      2020-07-06 17:55:00,211 INFO  - Starting ServiceWrapper in the service mode
      2020-07-06 17:55:00,246 DEBUG - Completed. Exit code is 0
      ### Offenbar letzter erfolgreicher Start !? ###
      2020-07-06 17:55:00,261 INFO  - Starting "D:\ioBroker\NUC\nodejs\node.exe" "D:\ioBroker\NUC\node_modules\iobroker.js-controller\controller.js"
      2020-07-06 17:55:00,315 INFO  - Started process 30008
      2020-07-06 17:55:00,333 DEBUG - Forwarding logs of the process System.Diagnostics.Process (node) to winsw.TimeBasedRollingLogAppender
      2020-07-06 17:55:10,989 INFO  - Starting ServiceWrapper in the service mode
      2020-07-06 17:55:11,039 INFO  - Starting "D:\ioBroker\NUC\nodejs\node.exe" "D:\ioBroker\NUC\node_modules\iobroker.js-controller\controller.js"
      2020-07-06 17:55:11,078 INFO  - Started process 29664
      2020-07-06 17:55:11,095 DEBUG - Forwarding logs of the process System.Diagnostics.Process (node) to winsw.TimeBasedRollingLogAppender
      2020-07-06 17:55:31,631 INFO  - Starting ServiceWrapper in the service mode
      2020-07-06 17:55:31,687 INFO  - Starting "D:\ioBroker\NUC\nodejs\node.exe" "D:\ioBroker\NUC\node_modules\iobroker.js-controller\controller.js"
      2020-07-06 17:55:31,724 INFO  - Started process 30568
      2020-07-06 17:55:31,742 DEBUG - Forwarding logs of the process System.Diagnostics.Process (node) to winsw.TimeBasedRollingLogAppender
      2020-07-06 19:09:45,860 INFO  - Starting ServiceWrapper in the service mode
      2020-07-06 19:09:45,924 INFO  - Starting "D:\ioBroker\NUC\nodejs\node.exe" "D:\ioBroker\NUC\node_modules\iobroker.js-controller\controller.js"
      2020-07-06 19:09:46,000 INFO  - Started process 2528
      2020-07-06 19:09:46,008 DEBUG - Forwarding logs of the process System.Diagnostics.Process (node) to winsw.TimeBasedRollingLogAppender
      2020-07-06 19:09:57,012 INFO  - Starting ServiceWrapper in the service mode
      2020-07-06 19:09:57,058 INFO  - Starting "D:\ioBroker\NUC\nodejs\node.exe" "D:\ioBroker\NUC\node_modules\iobroker.js-controller\controller.js"
      2020-07-06 19:09:57,110 INFO  - Started process 2780
      Glasfaser 400
      • A aleks-83
            throw err;
            throw err;
            throw err;
            throw err;
            throw err;
            throw err;
            throw err;
            throw err;
            throw err;
            throw err;
            throw err;
            throw err;
            throw err;
            throw err;
            throw err;
        apollon77A Online
        apollon77A Online
        #43
        @aleks-83 Scheinbar fehlen da wieder module ... Keine ahnung ... hat das Windows Update vllt irgend wie die Node.js Installation bzw Da dinge kaputt gemacht?
        Auf jeder fall ist der ganz oben genannte Fehler "stoping of undefined" im 3.xer Controller spätestens gefixt
          aleks-83
          #44
          Funktioniert denn deine genannte Methode noch unter Windows auf den 3er JS upzugraden?
          Hatte ich iwo mal in einem Thread gelesen... Finde es nicht mehr.
          Zur Info:
          Habe testweise mal ioBroker im Ubuntu SubSystem unter Win10 installiert.
          Lief soweit fehlerfrei durch.
          Jetzt versuche ich noch meine iobroker-data zu migrieren.
          Hierfür installiere ich direkt unter Win10 nochmal eine neue ioB Instanz, speichere mir alle Adapter Einstellungen, Skripte und Visualisierungen und lade sie dann in den neuen Ubuntu ioB rein.
          Glasfaser 400
            aleks-83
            #45
            ich bins nochmal.
            Weil ich das gleiche Problem wieder habe.
            Und zwar richte ich mir gerade einen neuen Host ein. (Lenovo Tiny M73)
            Dieser läuft mit Win 10 und ich habe ioBroker nach dem Workaround von P-A-L-A-D-I-N installiert.
            Ich habe die alte ioBroker Instanz vom NUC migriert.
            Dieser lief mit Node.js v12.22.1, NPM 6.14.12, JS Controller 3.3.10.
            Soweit ist auch alles gestartet und alle Adapter haben sich installiert.
            Alles lief super, auch meine vis und alle Skripte.
            Nach einem Neustart des Rechners startet der ioBroker Dienst aber nicht mehr.
            Hier die beiden entscheidenden Logfiles:
            ERROR addMembership: Error: addMembership EADDRNOTAVAIL
            internal/modules/cjs/loader.js:960
              throw err;
            Error: Cannot find module 'D:\Programme\ioBroker\node_modules\node-windows\lib\wrapper.js'
                at Function.Module._resolveFilename (internal/modules/cjs/loader.js:957:15)
                at Function.Module._load (internal/modules/cjs/loader.js:840:27)
                at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:74:12)
                at internal/main/run_main_module.js:18:47 {
              code: 'MODULE_NOT_FOUND',
              requireStack: []
              throw err;
              requireStack: []
              throw err;
              requireStack: []
              throw err;
              requireStack: []
              throw err;
              requireStack: []
              throw err;
              requireStack: []
            Dort tauch hauptsächlich eine Zeile immer wieder auf:
            Und hier noch das wrapper log:
            2021-10-26 19:18:48 - Starting C:\Program Files\nodejs\node.exe  --harmony D:\Programme\ioBroker\node_modules\node-windows\lib\wrapper.js --file D:\Programme\ioBroker\controller.js --log "ioBroker wrapper" --grow 0.25 --wait 1 --maxrestarts 3 --abortonerror n --stopparentfirst undefined
            2021-10-26 19:18:48 - Started 2304
            2021-10-26 19:26:31 - Stopping iobroker.exe
            2021-10-26 19:26:31 - ProcessKill 2304
            2021-10-26 19:26:31 - Shutdown exception
            Message:Der Computer wird heruntergefahren.
            Stacktrace:   bei System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo)
               bei System.Management.ManagementScope.InitializeGuts(Object o)
               bei System.Management.ManagementScope.Initialize()
               bei System.Management.ManagementObjectSearcher.Initialize()
               bei System.Management.ManagementObjectSearcher.Get()
               bei winsw.WrapperService.GetChildPids(Int32 pid)
               bei winsw.WrapperService.StopProcessAndChildren(Int32 pid)
               bei winsw.WrapperService.StopIt()
               bei winsw.WrapperService.OnShutdown()
            2021-10-26 19:27:09 - Starting C:\Program Files\nodejs\node.exe  --harmony D:\Programme\ioBroker\node_modules\node-windows\lib\wrapper.js --file D:\Programme\ioBroker\controller.js --log "ioBroker wrapper" --grow 0.25 --wait 1 --maxrestarts 3 --abortonerror n --stopparentfirst undefined
            2021-10-26 19:27:09 - Started 4668
            2021-10-26 20:16:59 - Stopping iobroker.exe
            2021-10-26 20:16:59 - ProcessKill 4668
            2021-10-26 20:16:59 - Found child process: 4676 Name: conhost.exe
            2021-10-26 20:16:59 - Found child process: 4920 Name: node.exe
            2021-10-26 20:16:59 - Stopping process 4676
            2021-10-26 20:16:59 - Send SIGINT 4676
            2021-10-26 20:16:59 - SIGINT to 4676 failed - Killing as fallback
            2021-10-26 20:16:59 - Found child process: 10540 Name: node.exe
            2021-10-26 20:16:59 - Found child process: 4544 Name: node.exe
            2021-10-26 20:16:59 - Found child process: 10548 Name: conhost.exe
            2021-10-26 20:16:59 - Stopping process 10548
            2021-10-26 20:16:59 - Send SIGINT 10548
            2021-10-26 20:16:59 - SIGINT to 10548 failed - Killing as fallback
            2021-10-26 20:16:59 - Stopping process 10540
            2021-10-26 20:16:59 - Send SIGINT 10540
            2021-10-26 20:16:59 - SIGINT to 10540 failed - Killing as fallback
            2021-10-26 20:16:59 - Found child process: 4516 Name: conhost.exe
            2021-10-26 20:16:59 - Stopping process 4516
            2021-10-26 20:16:59 - Send SIGINT 4516
            2021-10-26 20:16:59 - SIGINT to 4516 failed - Killing as fallback
            2021-10-26 20:16:59 - Stopping process 4544
            2021-10-26 20:16:59 - Send SIGINT 4544
            2021-10-26 20:16:59 - SIGINT to 4544 failed - Killing as fallback
            2021-10-26 20:16:59 - Stopping process 4920
            2021-10-26 20:16:59 - Send SIGINT 4920
            2021-10-26 20:16:59 - SIGINT to 4920 failed - Killing as fallback
            2021-10-26 20:16:59 - Stopping process 4668
            2021-10-26 20:16:59 - Send SIGINT 4668
            2021-10-26 20:16:59 - SIGINT to 4668 failed - Killing as fallback
            2021-10-26 20:16:59 - Finished iobroker.exe
            2021-10-26 20:35:21 - Starting C:\Program Files\nodejs\node.exe  --harmony D:\Programme\ioBroker\node_modules\node-windows\lib\wrapper.js --file D:\Programme\ioBroker\controller.js --log "ioBroker wrapper" --grow 0.25 --wait 1 --maxrestarts 3 --abortonerror n --stopparentfirst undefined
            2021-10-26 20:35:21 - Started 5364
            2021-10-26 21:29:39 - Stopping iobroker.exe
            2021-10-26 21:29:39 - ProcessKill 5364
            2021-10-26 21:29:39 - Shutdown exception
            Message:Klasse nicht registriert
            2021-10-26 21:32:10 - Starting C:\Program Files\nodejs\node.exe  --harmony D:\Programme\ioBroker\node_modules\node-windows\lib\wrapper.js --file D:\Programme\ioBroker\controller.js --log "ioBroker wrapper" --grow 0.25 --wait 1 --maxrestarts 3 --abortonerror n --stopparentfirst undefined
            2021-10-26 21:32:10 - Started 1596
            2021-10-26 21:33:57 - Starting C:\Program Files\nodejs\node.exe  --harmony D:\Programme\ioBroker\node_modules\node-windows\lib\wrapper.js --file D:\Programme\ioBroker\controller.js --log "ioBroker wrapper" --grow 0.25 --wait 1 --maxrestarts 3 --abortonerror n --stopparentfirst undefined
            2021-10-26 21:33:57 - Started 5300
            2021-10-26 21:34:10 - Starting C:\Program Files\nodejs\node.exe  --harmony D:\Programme\ioBroker\node_modules\node-windows\lib\wrapper.js --file D:\Programme\ioBroker\controller.js --log "ioBroker wrapper" --grow 0.25 --wait 1 --maxrestarts 3 --abortonerror n --stopparentfirst undefined
            2021-10-26 21:34:10 - Started 6004
            2021-10-26 21:36:03 - Starting C:\Program Files\nodejs\node.exe  --harmony D:\Programme\ioBroker\node_modules\node-windows\lib\wrapper.js --file D:\Programme\ioBroker\controller.js --log "ioBroker wrapper" --grow 0.25 --wait 1 --maxrestarts 3 --abortonerror n --stopparentfirst undefined
            2021-10-26 21:36:03 - Started 4704
            2021-10-26 21:38:13 - Starting C:\Program Files\nodejs\node.exe  --harmony D:\Programme\ioBroker\node_modules\node-windows\lib\wrapper.js --file D:\Programme\ioBroker\controller.js --log "ioBroker wrapper" --grow 0.25 --wait 1 --maxrestarts 3 --abortonerror n --stopparentfirst undefined
            2021-10-26 21:38:13 - Started 4636
            2021-10-26 21:38:49 - Starting C:\Program Files\nodejs\node.exe  --harmony D:\Programme\ioBroker\node_modules\node-windows\lib\wrapper.js --file D:\Programme\ioBroker\controller.js --log "ioBroker wrapper" --grow 0.25 --wait 1 --maxrestarts 3 --abortonerror n --stopparentfirst undefined
            2021-10-26 21:38:49 - Started 11348
            node -v = v12.16.3
            npm -v = 6.14.4
            EDIT:
            Link zum Workaround korrigiert
            Glasfaser 400
            • A aleks-83
              ich bins nochmal.
                throw err;
                requireStack: []
                throw err;
                requireStack: []
                throw err;
                requireStack: []
                throw err;
                requireStack: []
                throw err;
                requireStack: []
                throw err;
                requireStack: []
              node -v = v12.16.3
              npm -v = 6.14.4
              EDIT:
              sigi234S Online
              sigi234S Online
              sigi234
              #46
              @aleks-83
              Was steht in der Computerverwaltung bei Dienst bei dir?
              Was kommt bei iobroker list instances?
              Immer Daten sichern!
              A 1 Antwort Letzte Antwort
              • sigi234S sigi234
                @aleks-83
                aleks-83
                #47
                @sigi234
                Dienste:
                List instances:
                Wie kann er denn instances am laufen haben wenn ioB gar nicht gestartet ist? 😲
                Glasfaser 400
                • A aleks-83
                  @sigi234
                  Dienste:
                  List instances:
                  sigi234S Online
                  sigi234S Online
                  sigi234
                  #48
                  @aleks-83
                  Wenn du den Dienst startest kommt die Fehlermeldung?
                  • sigi234S sigi234
                    @aleks-83
                    aleks-83
                    #49
                    @sigi234
                    Ich habe gerade gesehen dass die Umgebungsvariablen die ich anhand des Workarounds angelegt hatte, nach dem Neustart des Rechners weg sind.
                    Ich habe sie nochmal hinzugefügt und neu gestartet. Jetzt sind sie noch vorhanden.
                    Glasfaser 400
                      aleks-83
                      #50
                      @Stabilostick hierzu hatten wir beiden mal eine TeamViewer Session glaube ich.
                      Sagt dir die neue Fehlermeldung etwas?
                      Glasfaser 400
                        aleks-83
                        #51
                        Rückmeldung:
                        ich habe nochmal den js.controller geupdatet
                        (npm i iobroker.js-controller@stable --ignore-scripts)
                        Dann habe ich ioBroker mittles Windows Installer installiert und meinen alten iobroker-data Ordner migriert.
                        Bis jetzt läuft alles und überlebt auch PC Neustarts...
                        Allerdings bin ich jetzt auf node.js 10.17.0...
                        Dann hoffe ich mal dass bei mir die Forums Anleitung zum node.js Update funktioniert...
                        Glasfaser 400
                        • A aleks-83
                          Rückmeldung:
                          sigi234S Online
                          sigi234S Online
                          sigi234
                          #52
                          Konsole: iobroker stop
                           Sicherung des Ordners: C:\Program Files\iobroker\deinhostname\nodejs auf dem Desktop
                           Download der benötigten Node.js Version unter https://nodejs.org als Archiv nicht als msi
                          Datei
                           Entpacken des Downloads und kopieren den Gesamten Ordners über den vorhandenen
                          C:\Program Files\iobroker\deinhostname\nodejs Ordner.
                           Kopiere aus der Sicherungskopie des Desktops die Datei nodevars.bat in den Ordner
                           Konsole: iobroker start
                          • sigi234S sigi234
                            Datei
                            aleks-83
                            #53
                            @sigi234
                            Danke für die Schnellanleitung.
                            So bin ich ja vorgegangen. (Siehe Link)
                            Bisher funtioniert noch alles.
                            ioBroker hat jetzt auch alle fehlenden Adapter nachgeladen.
                            Ich starte den Tiny gleich mal neu 😰
                            Glasfaser 400
                            • A aleks-83
                              @sigi234
                              aleks-83
                              #54
                              Problem gelöst.
                              Siehe Thread
                              Glasfaser 400
