  4. [Neuer Adapter] Life360
    6.4k
adapterlife360geopositionpräsenzmelder
708 Beiträge 85 Kommentatoren 273.9k Aufrufe 70 Beobachtet
  • CKMartensC Offline
    CKMartensC Offline
    CKMartens
    schrieb am zuletzt editiert von CKMartens
    #501
    @bananajoe Hast Du das Problem lösen können. Bei mir zeigt er seit heute um 08:30 den gleichen Fehler gleiche an.
    @MiGoller Ich habe den Adapter testweise komplett deinstalliert und neu installiert, was aber keine Änderung gebracht hat.
    Hier das Debug-Log
    2023-12-20 16:05:33.433 - debug: life360.0 (78741) Objects client ready ... initialize now
    2023-12-20 16:05:33.718 - debug: life360.0 (78741) Objects create System PubSub Client
    2023-12-20 16:05:33.718 - debug: life360.0 (78741) Objects create User PubSub Client
    2023-12-20 16:05:33.854 - debug: life360.0 (78741) Objects client initialize lua scripts
    2023-12-20 16:05:33.858 - debug: life360.0 (78741) Objects connected to redis: 127.0.0.1:9001
    2023-12-20 16:05:33.958 - debug: life360.0 (78741) Redis States: Use Redis connection: 127.0.0.1:9000
    2023-12-20 16:05:33.988 - debug: life360.0 (78741) States create System PubSub Client
    2023-12-20 16:05:33.989 - debug: life360.0 (78741) States create User PubSub Client
    2023-12-20 16:05:34.091 - debug: life360.0 (78741) States connected to redis: 127.0.0.1:9000
    2023-12-20 16:05:34.319 - info: life360.0 (78741) starting. Version 0.2.21 (non-npm: MiGoller/ioBroker.life360#888e08024c2d93d86aa6eb74f281c574dce86c42) in /opt/iobroker/node_modules/iobroker.life360, node: v18.17.1, js-controller: 5.0.17
    2023-12-20 16:05:34.339 - debug: life360.0 (78741) Fetching Life360 cloud data ...
    2023-12-20 16:05:34.341 - debug: life360.0 (78741) Not authenticated against Life360. Will try to connect ...
    2023-12-20 16:05:34.341 - debug: life360.0 (78741) Connecting to Life360 service ...
    2023-12-20 16:05:34.351 - info: life360.0 (78741) Polling enabled every 60 seconds.
    2023-12-20 16:05:34.518 - error: life360.0 (78741) Connection established but failed to authenticate. Check your credentials!
    2023-12-20 16:05:34.519 - debug: life360.0 (78741) Auth tokens deleted.
    2023-12-20 16:05:34.521 - info: life360.0 (78741) Waiting for online operations to finish ...
    2023-12-20 16:05:34.524 - debug: life360.0 (78741) Not authenticated against Life360. Will try to connect ...
    2023-12-20 16:05:34.524 - debug: life360.0 (78741) Connecting to Life360 service ...
    2023-12-20 16:05:34.611 - error: life360.0 (78741) Connection established but failed to authenticate. Check your credentials!
    2023-12-20 16:05:34.612 - debug: life360.0 (78741) Auth tokens deleted.
    2023-12-20 16:05:34.613 - info: life360.0 (78741) Waiting for online operations to finish ...
    2023-12-20 16:05:34.614 - debug: life360.0 (78741) Not authenticated against Life360. Will try to connect ...
    2023-12-20 16:05:34.614 - debug: life360.0 (78741) Connecting to Life360 service ...
    2023-12-20 16:05:34.693 - error: life360.0 (78741) Connection established but failed to authenticate. Check your credentials!
    2023-12-20 16:05:34.693 - debug: life360.0 (78741) Auth tokens deleted.
    2023-12-20 16:05:34.694 - info: life360.0 (78741) Waiting for online operations to finish ...
    2023-12-20 16:05:34.696 - debug: life360.0 (78741) Not authenticated against Life360. Will try to connect ...
    2023-12-20 16:05:34.696 - debug: life360.0 (78741) Connecting to Life360 service ...
    2023-12-20 16:05:34.765 - error: life360.0 (78741) Connection established but failed to authenticate. Check your credentials!
    2023-12-20 16:05:34.765 - debug: life360.0 (78741) Auth tokens deleted.
    2023-12-20 16:05:34.767 - info: life360.0 (78741) Waiting for online operations to finish ...
    2023-12-20 16:05:34.767 - debug: life360.0 (78741) Not authenticated against Life360. Will try to connect ...
    2023-12-20 16:05:34.767 - debug: life360.0 (78741) Connecting to Life360 service ...
    2023-12-20 16:05:34.841 - error: life360.0 (78741) Connection established but failed to authenticate. Check your credentials!
    2023-12-20 16:05:34.842 - debug: life360.0 (78741) Auth tokens deleted.
    2023-12-20 16:05:34.843 - info: life360.0 (78741) Waiting for online operations to finish ...
    2023-12-20 16:05:34.843 - debug: life360.0 (78741) Not authenticated against Life360. Will try to connect ...
    2023-12-20 16:05:34.843 - debug: life360.0 (78741) Connecting to Life360 service ...
    2023-12-20 16:05:34.910 - error: life360.0 (78741) Connection established but failed to authenticate. Check your credentials!
    2023-12-20 16:05:34.910 - debug: life360.0 (78741) Auth tokens deleted.
    2023-12-20 16:05:34.911 - info: life360.0 (78741) Waiting for online operations to finish ...
    2023-12-20 16:05:34.912 - error: life360.0 (78741) Failed to connect or to login for 6 times. Aborting ...
    2023-12-20 16:05:34.912 - error: life360.0 (78741) Error: Error: Connection established but failed to authenticate. Check your credentials!
    2023-12-20 16:05:34.912 - debug: life360.0 (78741) Pushing cloud_data to callback function
    2023-12-20 16:05:34.913 - warn: life360.0 (78741) No data received from Life360 cloud services!
    2023-12-20 16:05:35.523 - debug: life360.0 (78741) Auth tokens deleted.
    2023-12-20 16:05:35.614 - debug: life360.0 (78741) Auth tokens deleted.
    2023-12-20 16:05:35.695 - debug: life360.0 (78741) Auth tokens deleted.
    2023-12-20 16:05:35.767 - debug: life360.0 (78741) Auth tokens deleted.
    2023-12-20 16:05:35.844 - debug: life360.0 (78741) Auth tokens deleted.
    2023-12-20 16:05:35.913 - debug: life360.0 (78741) Auth tokens deleted.
    Auf GitHub sind bereits mehrer Merldungen: https://github.com/MiGoller/ioBroker.life360/issues/83 und https://github.com/MiGoller/ioBroker.life360/issues/76
    • Merlin123M Offline
      Merlin123M Offline
      Merlin123
      #502
      @ckmartens Aktuell geht es bei mir auch nicht
      Beta-Tester
      • BananaJoeB Offline
        BananaJoeB Offline
        BananaJoe
        #503
        und bei mir auch nicht, ich stoppe mal den Adapter
        App funktioniert noch
        RababersaftR 1 Antwort Letzte Antwort
        • BananaJoeB BananaJoe
          RababersaftR Offline
          Rababersaft
          #504
          @bananajoe
          bei mir auch genau dieselben Fehlermeldungen...😑
          • KnallochseK Offline
            KnallochseK Offline
            Knallochse
            schrieb am zuletzt editiert von Knallochse
            #505
            Auf Github ist zu lesen, dass der Entwickler am Problem arbeitet.
            Ich kann aber sagen das @MiGoller immer Zeitnah Probleme am Adapter beseitigt hat. Gebt Ihm einfach Zeit. Er wird sich sicher melden, sobald es wieder geht.
            HM&HMIP über 100 Geräte + IoBroker auf DS918+ uvm.
            MiGollerM 1 Antwort Letzte Antwort
            • KnallochseK Knallochse
              MiGollerM Offline
              MiGollerM Offline
              MiGoller
              #506
              Hallo zusammen, bitte noch etwas Geduld. Ich gehe grad noch meinem regulärem Job nach. Heute Abend gibt es den nächsten Stand. Auf meinem Entwicklungs-Server läuft der Adapter wieder. Werde nachher das Release vorbereiten.
              ioBroker auf Intel Atom x5-Z8350 mit KNX, Gardena, Roomba, MQTT, Sonoff, Life360
              • MiGollerM MiGoller
                MiGollerM Offline
                MiGollerM Offline
                MiGoller
                schrieb am zuletzt editiert von MiGoller
                #507
                Update auf v0.2.22 steht per NPM oder über GitHub zur Verfügung. Ich drücke die Daumen... Euch und mir.
                V KnallochseK BananaJoeB 3 Antworten Letzte Antwort
                  V Offline
                  V Offline
                  Verblizz
                  #508
                  @migoller
                  läuft bei mir damit wieder, vielen Dank für Deinen Einsatz!
                  • V Verblizz
                    @migoller
                    Rababersaft
                    schrieb am zuletzt editiert von Rababersaft
                    #509
                    @verblizz
                    @migoller
                    dito, hier auch wieder 👍
                    Danke für den super schnellen Einsatz 😊
                      KnallochseK Offline
                      KnallochseK Offline
                      Knallochse
                      #510
                      @migoller Bei mir läuft es auch wieder. Vielen Dank für deinen hervorragenden Support.
                        BananaJoeB Offline
                        BananaJoeB Offline
                        BananaJoe
                        #511
                        @migoller Funktioniert! Was haben sie diesmal wieder böses geändert?
                          Sandy
                          schrieb am zuletzt editiert von Sandy
                          #512
                          bei mir funktioniert es auch wieder, danke :-)
                          LG Sandy
                            MiGollerM Offline
                            MiGollerM Offline
                            MiGoller
                            #513
                            @bananajoe , bei der Abfrage der API müssen nun ein paar Header gesetzt sein, die in der Vergangenheit wohl eher optional waren; bislang funktionierte es auch ohne. Der API-Request nutzt jetzt die Browser-Kennung von Android statt von iOS Geräten. In dem Zusammenhang greift dann eine neue URL für die Authentifizierung.
                            Life360 scheint aber schon eine neue Version der API vorzubereiten. Zumindest bei iOS Geräten werden basierend auf der eindeutigen Device-ID mittels https://launchdarkly.com/ Einstellungen übermittelt. Hatte ich vorher auch noch nicht bei Life360 gesehen.
                            Langweilig wird es nicht damit. Life360 "schützt" den Service mit einer Closed-Source-API.
                            • S Sandy
                              LG Sandy
                              Rababersaft
                              #514
                              @sandy
                              Bei den Adaptern auf extern... (also die Katze 😻 ) und Life360 auswählen, Installieren/Updaten und freuen... 👌
                              • PischleuderP Offline
                                Pischleuder
                                #515
                                Guten Morgen,
                                nachdem es mit der Version 0..2.22 zunächst zwei Tage fehlerfrei funktionierte, ist seit heute wieder Schluss - bei Euch auch ?
                                Frohe Weihnachten Euch allen !
                                  michael 1975
                                  #516
                                  Guten Morgen bei mir geht seit heute auch nichts mehr.
                                  Gruß Michael
                                    MrDisaster04
                                    #517
                                    Guten Morgen,
                                    kann ich bestätigen bei mir geht es seit heute Morgen auch nicht mehr.
                                    Frohe Weihnachten noch.
                                    Thomas
                                    CKMartensC 1 Antwort Letzte Antwort
                                    • M MrDisaster04
                                      Guten Morgen,
                                      Thomas
                                      CKMartensC Offline
                                      CKMartensC Offline
                                      CKMartens
                                      #518
                                      @mrdisaster04 Ja fing um 2:30 heut nacht an.
                                      2023-12-24 02:31:18.433 - error: life360.0 (129585) Connection established but failed to authenticate. Check your credentials!
                                      2023-12-24 02:31:18.438 - info: life360.0 (129585) Waiting for online operations to finish ...
                                      2023-12-24 02:31:18.438 - info: life360.0 (129585) Disconnected from Life360 cloud services.
                                      2023-12-24 02:31:18.680 - error: life360.0 (129585) Connection established but failed to authenticate. Check your credentials!
                                      2023-12-24 02:31:18.681 - info: life360.0 (129585) Waiting for online operations to finish ...
                                      2023-12-24 02:31:18.923 - error: life360.0 (129585) Connection established but failed to authenticate. Check your credentials!
                                      2023-12-24 02:31:18.924 - info: life360.0 (129585) Waiting for online operations to finish ...
                                      2023-12-24 02:31:19.270 - error: life360.0 (129585) Connection established but failed to authenticate. Check your credentials!
                                      2023-12-24 02:31:19.271 - info: life360.0 (129585) Waiting for online operations to finish ...
                                      2023-12-24 02:31:19.495 - error: life360.0 (129585) Connection established but failed to authenticate. Check your credentials!
                                      2023-12-24 02:31:19.497 - info: life360.0 (129585) Waiting for online operations to finish ...
                                      2023-12-24 02:31:19.732 - error: life360.0 (129585) Connection established but failed to authenticate. Check your credentials!
                                      2023-12-24 02:31:19.733 - info: life360.0 (129585) Waiting for online operations to finish ...
                                      2023-12-24 02:31:19.733 - error: life360.0 (129585) Failed to connect or to login for 6 times. Aborting ...
                                      2023-12-24 02:31:19.734 - error: life360.0 (129585) Error: Error: Connection established but failed to authenticate. Check your credentials!
                                      2023-12-24 02:31:19.734 - warn: life360.0 (129585) No data received from Life360 cloud services!
                                      • CKMartensC CKMartens
                                        MiGollerM Offline
                                        MiGollerM Offline
                                        MiGoller
                                        #519
                                        Guten Morgen zusammen, das ist ja eine Bescherung. Dier Störung behandeln wir in Github unter https://github.com/MiGoller/ioBroker.life360/issues/86 .
                                        Bislang kann ich den Fehler allerdings nicht nachstellen: Es läuft bei mir auf dem produktiven wie auch auf meinem Entwicklungsserver ohne Probleme. Das macht es mir grad schwierig, etwas zu tun. Bislang sieht es so aus, als würde auch das Neuinstallieren des Adapters nicht helfen, wenn das Problem aufgetreten ist.
                                        Ich versuche, einen einfachen Checker zu programmieren, mit dem Ihr die Funktionalität ohne den Adapter testen könnt. Das an Heiligabend... macht meine Family nicht happy.
                                          MiGollerM Offline
                                          MiGollerM Offline
                                          MiGoller
                                          #520
                                          Bei einem Benutzer war das Life360 Kennwort abgelaufen. Ist beim erneuten Anmelden in der mobilen App aufgefallen. Das neue Passwort im ioBroker eingetragen. und dann lief es wieder. Mal schauen, ob das ein Einzelfall ist.
