  4. OPC Adapter
    6.4k
OPC Adapter
48 Beiträge 17 Kommentatoren 11.9k Aufrufe 15 Beobachtet
    @kargelino Bitte Konsolentext als TEXT (in CodeTags) posten. Dann kann man das auch lesen und durchsuchen.
    Kargelino
    schrieb am zuletzt editiert von Kargelino
    @thomas-braun Tschuldige
    Konsole:
    ubuntu@ubuntu:/opt/iobroker$ sudo npm i iobroker.opcua@0.4.1
    [..................] / loadDep:jsonwebtoken: sill removeObsoleteDep removing humanize@0.0.9 from the tree        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darw        in","arch":"any"} (current: {"os":"linux","arch":"arm64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperatur        e-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: want        ed {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
    + iobroker.opcua@0.4.1
    updated 1 package in 952.849s
    37 packages are looking for funding
      run `npm fund` for details
    ubuntu@ubuntu:/opt/iobroker$ iob a opcua
    host.ubuntu create instance opcua
    host.ubuntu object opcua.0.info.event created
    host.ubuntu object opcua.0.info created
    host.ubuntu object system.adapter.opcua.0.logLevel created
    host.ubuntu object system.adapter.opcua.0.sigKill created
    host.ubuntu object system.adapter.opcua.0.eventLoopLag created
    host.ubuntu object system.adapter.opcua.0.outputCount created
    host.ubuntu object system.adapter.opcua.0.inputCount created
    host.ubuntu object system.adapter.opcua.0.uptime created
    host.ubuntu object system.adapter.opcua.0.memRss created
    host.ubuntu object system.adapter.opcua.0.memHeapTotal created
    host.ubuntu object system.adapter.opcua.0.memHeapUsed created
    host.ubuntu object system.adapter.opcua.0.cputime created
    host.ubuntu object system.adapter.opcua.0.cpu created
    host.ubuntu object system.adapter.opcua.0.compactMode created
    host.ubuntu object system.adapter.opcua.0.connected created
    host.ubuntu object system.adapter.opcua.0.alive created
    host.ubuntu object system.adapter.opcua.0 created
    Lg Max
    • K Kargelino
      Konsole:
      Lg Max
      @kargelino sagte in OPC Adapter:
      Davon abgesehen sehe ich da keine Fehler.
      npm wird NICHT per sudo eingeleitet, jedenfalls nicht im ioBroker-Kontext.
      iobroker stop
      iobroker fix
      iobroker start
      npm sollte eh nicht verwendet werden. So geht es richtig (für Adapter die auch im Repo liegen):
      iobroker install adaptername
      K 1 Antwort Letzte Antwort
        iobroker stop
        iobroker fix
        iobroker start
        Kargelino
        @thomas-braun Danke für die schnelle Antwort. Der Install Befehl hat leider auch keine Besserung gebracht. Noch immer keine index.html Seite zum Konfigurieren.
        LG
        • K Kargelino
          LG
          @kargelino
          cd /opt/iobroker
          npm install iobroker.opcua
          iobroker add opcua --host ubuntu
          Funktioniert hier.
          • timk1981T timk1981
            @Bluefox leider ist noch in Problem aufgetaucht, das ich nicht umgehen kann. Ich kann zwar alle Variablen lesen aber ich kann keine einzige variable schreiben.
            Benötigt man da erst die Lizenz für den OPC UA Client vom IoBroker? Der Server selber läuft auf einer B&R SPS.
            Auf den UaExpert geht es in beide Seiten.
            Kennt das Problem jemand?
            Danke im Voraus.
            Schöne grüße,
            Tim
            U Offline
            U Offline
            utechm
            @timk1981 said in OPC Adapter:
            Danke im Voraus.
            Schöne grüße,
            Tim
            Hallo, da es zu dieser Frage noch keine Antwort gibt, möchte ich das Thema noch einmal aufgreifen:
            Ich stehe gerade vor dem selben Problem, lesender Zugriff auf die Variablen eines HMI Touchpanel ist möglich, schreiben jedoch nicht. Mit UaExpert funktioniert lesen und schreiben. Habe das ganze auch noch mit einer CODESYS SPS auf einem Raspberry getestet, selbes Problem, auch nur lesender Zugriff möglich.
            Ebenfalls würde mich das auch noch nicht beantwortete Thema mit der Lizenz installieren, wo und wie bekomme ich diese und was kostet sie? Wenn man dem Link in der Instanz folgt gibt es auf der IoBroker Seite nirgends eine Lizenz für OPC UA.
            Würde mich freuen wenn es zu diesen zwei Themen mittlerweile Neuigkeiten gibt ;)
            ****Homematic CCU2 mit 25 Geräten am RS485 Bus und Funksensoren/ Aktoren für die Heizung, Temperaturmessung und Fernbedienungen. IoBroker auf Linux Server, mehrere Anbindungen per MQTT für Sensoren, Relaiskarten, IOs ***
            H 1 Antwort Letzte Antwort
            • U utechm
              Danke im Voraus.
              Schöne grüße,
              Tim
              hgpiepel
              @utechm gibt es hierzu schon eine Lösung. Ich stehe auch vor dem selben Problem. Überall ist meiner Meinung nach schreiben und lesen freigegeben aber die im Broker gesetzten Werten kommen nicht beim OPC Server an. Gab es hierzu noch einen Ansatz?
              • O Offline
                O Offline
                onweb
                Welche Lizenz funktioniert mit dem OPC Adapter?
                Oder gibt es dafür eine spezielle Lizenz, aber wo findet man diese dann?
                Mr. BurnsM 1 Antwort Letzte Antwort
                • O onweb
                  Mr. BurnsM Offline
                  Mr. BurnsM Offline
                  Mr. Burns
                  würde mich auch interessieren!
                  Wie teuer ist diese Lizenz, ist diese dann noch begrenzt (Variablen, Verbindungen etc.)?
                  Woher bezieht man sie?
                  Gibt es eine Dokumentation?
                  OPC UA ist ja schon eine Standart-Kommunikationsschnittstelle. Besonders in Verbindung mit Industrie 4.0 läuft sie mir immer wieder über den Weg. Ist also erst mal für industrielle Anwendungen aber je mehr Geräte über diesen Standart kommunizieren, wird es auch für uns Privatanwender interessant.
                  • L Offline
                    Lollo79
                    melde auch Interesse an evtl. dann auch im Kommerziellen Einsatz wenn es vom Chef als Abgenommen angesehen wird.
                    TheBamT 1 Antwort Letzte Antwort
                    • L Lollo79
                      TheBamT Offline
                      TheBamT Offline
                      TheBam
                      @lollo79
                      Den Adapter gibt es befindet sich im Beta Repository. Lässt sich auch installieren und eine licenz kann man auch kaufen.
                      • TheBamT Offline
                        TheBamT Offline
                        TheBam
                        @mr-burns
                        https://iobroker.net/www/pricing
                        Hier kannst du die Preise für die licenz einsehen. Wie gesagt Adapter ist im Beta Repository zu finden.
                        • TheBamT TheBam
                          @mr-burns
                          Mr. BurnsM Offline
                          Mr. BurnsM Offline
                          Mr. Burns
                          @thebam Hey, Danke für die Antwort. Bei den Preisen (Privat) bin ich raus.
                          Ich kann mir vorstellen, dass das auch für den kommerziellen Einsatz etwas hoch gegriffen ist (120€-600€).
                          Siemens fragt sich für die große OPC UA Lizenz 340€ (Listenpreis, den bezahlt ja keiner) und das ist nicht Beta.
                          Bei TIA läßt sich der OPC UA Server auch ohne Lizenz komplett nutzen...komerziell macht das natürlich niemand aber im Privaten bereich kann ich mir das schon vorstellen.
                          Ich brauch das Modul zum Glück nicht, hätte es aber mal ausprobiert.
                          • Mr. BurnsM Mr. Burns
                            TheBamT Offline
                            TheBamT Offline
                            TheBam
                            @mr-burns kannst ja mal bei bluefox bzw. iobroker.net anfragen ob es da auch eine möglichkeit für privat gibt quasie wie bei der vis so eine 30 euro licenz oder so
                            • TheBamT TheBam
                              Mr. BurnsM Offline
                              Mr. BurnsM Offline
                              Mr. Burns
                              @thebam Das stimmt, das könnte ich machen. Aber ich hab gar kein echtes Interesse und möchte nicht um den Preis feilschen. Ich wollte dem Entwickler nur ein feedback geben (arbeite ab und an mit OPC UA Servern und Clients)
                              • BluefoxB Bluefox
                                @opcuaneeded
                                Hallo, opcua client funktioniert, aber man kann nur 10 Variablen binden. Für mehr Variablen braucht man kommerzielle Lizenz.
                                Pat
                                @bluefox
                                Hallo
                                Wollte kein neues Thema aufmachen.
                                Also die Installation funktioniert wie hier beschrieben. Soweit alles gut.
                                cd /opt/iobroker
                                iob a opcua
                                Es wäre cool wenn der Adapter ein wenig weiter entwickelt wird was das Anlagen von Datenstrikturen betrifft und das Schreiben von variablen.
                                Wenn man in den Einstellungen von dem Adapter ausgewählte daten wieder entfernen möchte schmiert der ganze Adapter ab. Wenn in einer Struktur 200 Variablen drin sind geht es schneller den Adapter zu löschen und neu zu machen. :D
                                Bei Strukturen kommt der Adapter auch nicht zurecht, da werden die Daten als JSON angezeigt.
                                Soweit ok man könnte das noch mit einen Skript sich selbst die Datenpunkte anlegen.
                                Jetzt zum aber es funktioniert das Schreiben der Daten nicht. (also in einer Struktur das Schreiben kann man den Wert ändern aber kommt nicht an)
                                Es wäre cool wenn der Adapter ein wenig verbessert wird. Gerade wenn man viel mit SPS macht ist UPC-UA echt der Hammer. Da UPC-UA Steuerungsneutral ist kann viele Sachen mit einander verbinden. Auch die anderen Adapter für Siemens und Beckhoff bräuchte man nicht mehr und könnte das System noch ein wenig sicherer machen. Da für diese Adapter die CPU´s recht weit offen sein müssen.
                                Also mir geht es Hauptsächlich um den Client Modus.
                                mcm1957M 2 Antworten Letzte Antwort
                                • P Pat
                                  @bluefox
                                  Hallo
                                  cd /opt/iobroker
                                  iob a opcua
                                  mcm1957M Offline
                                  mcm1957M Offline
                                  mcm1957
                                  @pat
                                  Eröffne bei Problemen / Fehlern oder Feature Request ein Issue im Adapter repository.
                                  Nur dort geht diese Info nicht unter.
                                  Support Repositoryverwaltung.
                                  LESEN - gute Forenbeitrage
                                  P 1 Antwort Letzte Antwort
                                  • P Pat
                                    @bluefox
                                    Hallo
                                    cd /opt/iobroker
                                    iob a opcua
                                    mcm1957M Offline
                                    mcm1957M Offline
                                    mcm1957
                                    @pat said in OPC Adapter:
                                    cd /opt/iobroker
                                    iob a opcua
                                    Nur ist das die "no risc no fun" variante. Warum installierst du nicht die im repository verfügbare Version? Nur weil es vor Jahren mal wer anders im Forum gepostet hat?
                                    Schau mal ins Repository. Letzte Release März 2024
                                    Bitte bei allen Fehlermeldunge die beteilgten Versionen angeben:
                                    Adapter
                                    js-controller
                                    Node
                                    O/S
                                    Und wenn es ein reproduzierbarer Fehler ist ein Issue im Adapter repository eröffnen.
                                    Dann erstell docjh ein konkretes Feature Issue im Adapter repository. Mit "ein wenig verbessert" fängt niemand was an.
                                    • mcm1957M mcm1957
                                      @pat
                                      Pat
                                      @mcm57 sagte in OPC Adapter:
                                      @pat
                                      Hast du recht kann ich erstmal machen!
                                      • mcm1957M mcm1957
                                        cd /opt/iobroker
                                        iob a opcua
                                        Adapter
                                        js-controller
                                        Node
                                        O/S
                                        Pat
                                        schrieb am zuletzt editiert von Pat
                                        cd /opt/iobroker
                                        iob a opcua
                                        Wenn man nicht so installiert bekommt man die Einstellungen vom Adapter nicht auf. Siehe Link.
                                        https://forum.iobroker.net/topic/35101/opc-ua-adapter/6?_=1712161556288
                                        Wenn man in Changelog guckt wurde nicht viel gemacht seid 2021.
                                        1.0.3 (2024-03-03)
                                        (bluefox) License changes to the free license (MIT)
                                        (bluefox) Minimum node.js version 16
                                        0.4.5 (2021-11-13)
                                        (bluefox) Implemented the writing of states in the client mode
                                        Adapter
                                        js-controller
                                        Node
                                        O/S
                                        • P Pat
                                          cd /opt/iobroker
                                          iob a opcua
                                          1.0.3 (2024-03-03)
                                          0.4.5 (2021-11-13)
                                          Adapter
                                          js-controller
                                          Node
                                          O/S
                                          mcm1957M Offline
                                          mcm1957M Offline
                                          mcm1957
                                          @pat
                                          Sorry, aber warum eine Installation von npm was anderes bewirken sioll als eine saubere Installation vom Latest Repository musst du mir erst mal erklären.
                                          Wenn die Installation aus dem Lates Repository aius irgendeinem Grund nicht funktioniert hat, solltes du ein Isse im Adapter Repository anlegen. Nur hier zu jammern entsprcoiht eher einer Mail ans Salzamt (https://de.wikipedia.org/wiki/Salzamt#„Salzamt“_im_heutigen_Sprachgebrauch).
