  4. Test js-controller v2.0.x (GitHub)
    5.8k
js-controller
1.0k Beiträge 48 Kommentatoren 419.8k Aufrufe 35 Beobachtet
  • coyoteC Offline
    coyoteC Offline
    coyote
    #521
    @apollon77 nochmal kurz ins Log geschaut, also es war wohl bei allen Adapter, ich hänge das Stück vom Log mal an, irgendwann ist dann alles gut...
    Log.txt
    apollon77A 2 Antworten Letzte Antwort
    • S sven12
      @apollon77
      Nicht wirklich viel mehr Infos.....
      iobroker@iobroker-host:/opt/iobroker$ node node_modules/iobroker.shelly/shelly.js --force --logs
      2019-10-04 20:27:32.109  - error: shelly.0 (22205) shelly.0 invalid process id scenario 22181 vs. 22205. Stopping
      2019-10-04 20:27:44.707  - warn: shelly.0 (22205) Got terminate signal. Checking desired PID: 0 vs own PID 22205
      2019-10-04 20:27:44.742  - warn: shelly.0 (22205) Got terminate signal. Checking desired PID: 22651 vs own PID 22205
      2019-10-04 20:28:17.631  - warn: shelly.0 (22205) Got terminate signal. Checking desired PID: 0 vs own PID 22205
      2019-10-04 20:28:17.640  - warn: shelly.0 (22205) Got terminate signal. Checking desired PID: 23570 vs own PID 22205
      2019-10-04 20:28:49.488  - warn: shelly.0 (22205) Got terminate signal. Checking desired PID: 0 vs own PID 22205
      2019-10-04 20:28:49.499  - warn: shelly.0 (22205) Got terminate signal. Checking desired PID: 24494 vs own PID 22205
      2019-10-04 20:29:21.317  - warn: shelly.0 (22205) Got terminate signal. Checking desired PID: 0 vs own PID 22205
      2019-10-04 20:29:21.328  - warn: shelly.0 (22205) Got terminate signal. Checking desired PID: 25431 vs own PID 22205
      2019-10-04 20:29:21.486  - info: shelly.0 (22205) Got terminate signal TERMINATE_YOURSELF
      2019-10-04 20:29:28.431  - warn: shelly.0 (22205) Got terminate signal. Checking desired PID: 0 vs own PID 22205
      2019-10-04 20:29:28.442  - warn: shelly.0 (22205) Got terminate signal. Checking desired PID: 25668 vs own PID 22205
      2019-10-04 20:30:00.174  - warn: shelly.0 (22205) Got terminate signal. Checking desired PID: 0 vs own PID 22205
      2019-10-04 20:30:00.186  - warn: shelly.0 (22205) Got terminate signal. Checking desired PID: 26586 vs own PID 22205
      2019-10-04 20:30:36.686  - warn: shelly.0 (22205) Got terminate signal. Checking desired PID: 0 vs own PID 22205
      2019-10-04 20:30:36.697  - warn: shelly.0 (22205) Got terminate signal. Checking desired PID: 27752 vs own PID 22205
      iobroker Log
      2019-10-04 20:29:22.826  - error: shelly.0 (25431) adapter disabled
      2019-10-04 20:29:22.880  - warn: shelly.0 (25431) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
      2019-10-04 20:29:22.898  - info: host.iobroker-host instance system.adapter.shelly.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
      2019-10-04 20:29:23.686  - info: mqtt.0 (27417) Client [WetterStation] connected with secret 1570213763685_8509
      2019-10-04 20:29:23.713  - info: mqtt.0 (27417) Client [WetterStation] subscribes on "mqtt.0.WetterStation"
      2019-10-04 20:29:23.713  - info: mqtt.0 (27417) Client [WetterStation] publishOnSubscribe
      2019-10-04 20:29:24.429  - info: host.iobroker-host instance system.adapter.poolcontroller.0 terminated with code 0 (NO_ERROR)
      2019-10-04 20:29:28.427  - info: host.iobroker-host "system.adapter.shelly.0" enabled
      2019-10-04 20:29:28.443  - info: host.iobroker-host instance system.adapter.shelly.0 started with pid 25668
      2019-10-04 20:29:29.142  - debug: shelly.0 (25668) Redis Objects: Use Redis connection: 0.0.0.0:9001
      2019-10-04 20:29:29.184  - debug: shelly.0 (25668) objectDB connected
      2019-10-04 20:29:29.186  - debug: shelly.0 (25668) Redis States: Use Redis connection: 0.0.0.0:9000
      2019-10-04 20:29:29.188  - debug: shelly.0 (25668) Objects connected to redis: 0.0.0.0:9001
      2019-10-04 20:29:29.192  - debug: shelly.0 (25668) statesDB connected
      2019-10-04 20:29:29.205  - debug: shelly.0 (25668) States connected to redis: 0.0.0.0:9000
      2019-10-04 20:29:29.969  - info: shelly.0 (25668) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.16.1
      2019-10-04 20:29:30.041  - info: shelly.0 (25668) Stating Shelly adapter in CoAP modus.
      2019-10-04 20:29:30.162  - info: host.iobroker-host instance system.adapter.shelly.0 terminated with code 0 (NO_ERROR)
      2019-10-04 20:29:30.163  - info: host.iobroker-host Restart adapter system.adapter.shelly.0 because enabled
      #522
      @sven12 Ok, dann bitte vorher die nroamellaufende shelly instanz stoppen und erst dann an der Kommandozeile ausführen. Doppelt laufen geht kaputt ggf
      • coyoteC coyote
        Log.txt
        #523
        @coyote Bitte sei mal etwas grösszügiger mit dem Anfang des Logs ... direkt da zu starten wo die Fehler kommen ist da nicht sehr hilfreich weil irgendwas muss die ja verursachen ... bedeutet: Bitte noch etwas Log von davor
        coyoteC 1 Antwort Letzte Antwort
        • apollon77A apollon77
          sven12
          #524
          @apollon77
          Wenn ich den Adapter im Admin gestoppt habe, kommt auf der Konsole das hier:
          2019-10-04 20:45:07.776  - error: shelly.0 (20885) adapter disabled
          2019-10-04 20:45:07.779  - info: shelly.0 (20885) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.16.1
          2019-10-04 20:45:07.841  - info: shelly.0 (20885) Stating Shelly adapter in CoAP modus.
          Exception: Error: addMembership EADDRINUSE/Error: addMembership EADDRINUSE
          2019-10-04 20:45:07.960  - error: shelly.0 (20885) Exception: Error: addMembership EADDRINUSE
          2019-10-04 20:45:07.961  - info: shelly.0 (20885) Closing Adapter
          • S sven12
            @apollon77
            #525
            @sven12 Kann es sein das da irgendwie noch eine Instanz läuft? Schau al mit "ps auxww|grep shelly"
              sven12
              #526
              @apollon77 sagte in [Aufruf] js-controller 2.0 Beta Test:
              iobroker@iobroker-host:/opt/iobroker$ ps auxww|grep shelly
              iobroker 26889  0.0  0.0  12780   928 pts/3    S+   20:48   0:00 grep shelly
              2019-10-04 20:48:48.376  - error: shelly.0 (27548) shelly.0 invalid process id scenario 25918 vs. 27548. Stopping
                coyoteC Offline
                coyoteC Offline
                coyote
                #527
                @apollon77 sorry, klar macht vllt mehr Sinn...
                Hier mal ab Start von iobroker bis Anfang der Warnings:
                Log.txt
                Übrigens habe ich noch ein kleines Problem, es gibt ein Unifi Script von liv-in-the-sky, dass schreibt ein html file nach /opt/iobroker/iobroker-data/files/iqontrol/htmlclients.html
                Die Datei ist auch definitiv dort vorhanden und wird auch stetig geändert, nur wird sie mir jetzt nach der Umstellung in iQontrol nicht mehr angezeigt und iQontrol sagt, nicht vorhanden.
                Muss in iQontrol der Pfad jetzt geändert werden oder woran kann das liegen?
                • S sven12
                  #528
                  @sven12 Un dläuft auf dem Slave vllt noch ein Prozess?
                  • coyoteC coyote
                    Log.txt
                    #529
                    @coyote Das bitte im iqontrol Thread besprechen. Userfiles wurden bei dem Adapter generell in einen andern Pfad verschoben. Und am Ende sind wir wieder bei "komische Wege an den unterstützten Standards vorbei ;-))
                    Das Skript sollte das mit "writeFile" korrekt im ioBroker-Storage ablegen und nicht an allem vorbei ;-) Aber wie gesagt: Thema am besten im iqontrol Thread besprechen
                      sven12
                      #530
                      @apollon77
                      Nein auf beiden läuft kein Prozess mehr...
                        coyoteC Offline
                        coyoteC Offline
                        coyote
                        #531
                        @apollon77 ok, dann werde ich das dort mal anschneiden.
                        Was ist mit den Warnings im Log? Ist da was zu erkennen warum die beim Start kamen? Oder einfach mal so lassen und sich freuen, dass jetzt alles läuft ;-)
                        • coyoteC coyote
                          Log.txt
                          #532
                          @coyote Wieviele Objekte/States hast Du? Siehst Du in ioBroker unter Tab "Objekte"
                            coyoteC Offline
                            coyoteC Offline
                            coyote
                            #533
                            @apollon77 sind ein paar ;-)
                            Objekte: 44287, Zustände: 40604
                            • coyoteC coyote
                              #534
                              @coyote Ok, I need to think about it ... I have a solution, but don't know if I want this ... https://github.com/ioBroker/ioBroker.js-controller/issues/487
                              • S sven12
                                @apollon77
                                #535
                                @sven12 Sehr strange ... wenn Meldungen wie bei deinem manuellen Log kommen bzw "addrinuse" dann nutzt irgendwas den Port. Magst Du mal einen Reboot versuchen?
                                  coyoteC Offline
                                  coyoteC Offline
                                  coyote
                                  #536
                                  @apollon77 alles klar, dann weiß ich Bescheid, sagen wir einfach ich habe zu viele States ;-)
                                  sigi234S apollon77A 2 Antworten Letzte Antwort
                                    sven12
                                    #537
                                    addrinuse
                                    Also das "addrinuse" kam ja nur weil die alte Instanz noch nicht sauber beendet war als ich die Instanz neu gestartet habe.
                                    Ich glaube das kann ich mittlerweile ausschließen. Habe einfach zu schnell den Adapter neu gestartet
                                    Die letzten Logs haben das ja auch nicht mehr angezeigt.... Ich glaube das ist nicht das Problem..
                                    Reboot geht heute nicht mehr.. Morgen evtl.
                                    • coyoteC coyote
                                      sigi234S Online
                                      sigi234S Online
                                      sigi234
                                      #538
                                      @coyote sagte in [Aufruf] js-controller 2.0 Beta Test:
                                      Sind nicht wenige. Ich habe 18500 😀
                                      Immer Daten sichern!
                                      • coyoteC coyote
                                        #539
                                        @coyote neee passt schon. Das ist Realität :-) Das könnte aktuell bei einem neustart oder neustart des sourceanalytics passieren bei dir, aber ich kläre es und wir finden eine Lösung.
                                          coyoteC Offline
                                          coyoteC Offline
                                          coyote
                                          #540
                                          @apollon77 OK. Ist halt über die Jahre bisschen was zusammen gekommen, aber genau dieses Zusammenspiel der verschiedenen Komponenten macht ioBroker ja so interessant 😀 👍
