  4. EPOLL Fehler
EPOLL Fehler
epoll fehler adapter installie
5 Beiträge 2 Kommentatoren 501 Aufrufe 3 Beobachtet
    deta
    seit einer weile , bekomme ich beim Updaten der Adapter immer wieder die Info,
    das irgendwas mit dem epol nicht stimmt.
    make: *** [Release/obj.target/epoll/src/epoll.o] Error 1
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
    gyp ERR! System Linux 4.4.182-rockchip64
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/epoll
    gyp ERR! node -v v10.16.3
    gyp ERR! node-gyp -v v3.8.0
    gyp ERR! not ok
    Was ist das epoll? Woher kommt das?
    Wie kann ich das wieder reperieren? Ohne alles zu zerlegen?
    cu Deta
    • D deta
      gyp ERR! not ok
      cu Deta
      crunchipC Offline
      crunchipC Offline
      @deta https://www.npmjs.com/package/epoll
        deta
        Mh keine Mail bekommen gehabt, das was geantwortet war!
        So hab ich mal gemacht. Aber es kommen Fehler:
        root@rock:~# cd /opt/iobroker/
        root@rock:/opt/iobroker# npm install epoll
        epoll@0.1.22 install /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll
        node-gyp rebuild
        make: Entering directory '/opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/build'
          CXX(target) Release/obj.target/epoll/src/epoll.o
        In file included from ../../nan/nan.h:192:0,
                         from ../src/epoll.cc:15:
        ../../nan/nan_maybe_43_inl.h: In function ‘Nan::Maybe<bool> Nan::ForceSet(v8::Local<v8::Object>, v8::Local<v8::Value>, v8::Local<v8::Value>, v8::PropertyAttribute)’:
        ../../nan/nan_maybe_43_inl.h:112:15: error: ‘class v8::Object’ has no member named ‘ForceSet’
           return obj->ForceSet(isolate->GetCurrentContext(), key, value, attribs);
        In file included from ../src/epoll.cc:15:0:
        ../../nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’:
        ../../nan/nan.h:835:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                 v8::Isolate::GetCurrent(), target, func, argc, argv);
        In file included from ../src/epoll.cc:12:0:
        /root/.node-gyp/10.16.3/include/node/node.h:177:50: note: declared here
                         NODE_EXTERN v8::Local<v8::Value> MakeCallback(
        /root/.node-gyp/10.16.3/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’
             __attribute__((deprecated(message))) declarator
        ../../nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’:
        ../../nan/nan.h:850:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                 v8::Isolate::GetCurrent(), target, symbol, argc, argv);
        /root/.node-gyp/10.16.3/include/node/node.h:170:50: note: declared here
        ../../nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’:
        ../../nan/nan.h:865:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                 v8::Isolate::GetCurrent(), target, method, argc, argv);
        /root/.node-gyp/10.16.3/include/node/node.h:163:50: note: declared here
        ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::Callback::Call_(v8::Isolate*, v8::Local<v8::Object>, int, v8::Local<v8::Value>*) const’:
        ../../nan/nan.h:1479:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
        ../src/epoll.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Epoll::Add(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/epoll.cc:210:44: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
           int err = epoll->Add(info[0]->Int32Value(), info[1]->Int32Value());
        In file included from /root/.node-gyp/10.16.3/include/node/v8.h:26:0,
                         from ../src/epoll.cc:11:
        /root/.node-gyp/10.16.3/include/node/v8.h:2478:46: note: declared here
           V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
        /root/.node-gyp/10.16.3/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
           declarator __attribute__((deprecated(message)))
        ../src/epoll.cc:210:67: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
        ../src/epoll.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Epoll::Modify(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/epoll.cc:230:47: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
           int err = epoll->Modify(info[0]->Int32Value(), info[1]->Int32Value());
        ../src/epoll.cc:230:70: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
        ../src/epoll.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Epoll::Remove(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/epoll.cc:247:47: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
           int err = epoll->Remove(info[0]->Int32Value());
        epoll.target.mk:101: recipe for target 'Release/obj.target/epoll/src/epoll.o' failed
        make: Leaving directory '/opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/build'
        gyp ERR! cwd /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll
        gyp ERR! not ok
        > epoll@2.0.10 install /opt/iobroker/node_modules/epoll
        > node-gyp rebuild
        make: Entering directory '/opt/iobroker/node_modules/epoll/build'
          SOLINK_MODULE(target) Release/obj.target/epoll.node
          COPY Release/epoll.node
        make: Leaving directory '/opt/iobroker/node_modules/epoll/build'
        npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/@abandonware/.noble.DELETE/package.json'
        npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/unix-dgram/package.json'
        npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: epoll@0.1.22 (node_modules/rpi-gpio/node_modules/epoll):
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: epoll@0.1.22 install: `node-gyp rebuild`
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
        + epoll@2.0.10
        added 2 packages from 9 contributors and audited 18819 packages in 122.789s
        found 79 vulnerabilities (42 low, 4 moderate, 33 high)
          run `npm audit fix` to fix them, or `npm audit` for details
        Mh.
        cu Deta
          deta
          Hab ich gemacht schon.
          Leider immer noch der Fehler, gerade wieder einen Adapter aktualliesiert.
          gyp ERR! stack Error: make failed with exit code: 2
          • D deta
            crunchipC Offline
            crunchipC Offline
            @deta soweit ich weiss, ist das epoll für gpio´s zuständig, falls du nichts über gpio schaltest, könntest du es deinstallieren.
