  4. IoBroker.phantomjs
    5.1k
IoBroker.phantomjs
148 Beiträge 32 Kommentatoren 33.5k Aufrufe 19 Beobachtet
  • H Offline
    homecineplexx
    #41
    hallo
    hat jemand eine idee, warum ich den adapter nicht installieren kann?
    RPI 3B+
    Node.js v8.14.0
    NPM 6.4.1
    Raspbian GNU/Linux 9
    Linux version 4.14.79-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1159 SMP Sun Nov 4 17:50:20 GMT 2018
    $ ./iobroker add phantomjs  --host RPI_Slave1
    NPM version: 6.4.1
    npm install iobroker.phantomjs --production --save --prefix "/opt/iobroker" (System call)
    Unexpected platform or architecture: linux/armIt seems there is no binary available for your platform/architecture
    Try to install PhantomJS globally
    npm WARN svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm ERR! code ELIFECYCLEnpm ERR! errno 1
    npm ERR! phantomjs-prebuilt@2.1.16 install: `node install.js`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the phantomjs-prebuilt@2.1.16 install script.
    npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR!     /home/iobroker/.npm/_logs/2019-01-10T16_32_48_343Z-debug.log
    host.RPI_Master install adapter phantomjs
    NPM version: 6.4.1npm install iobroker.phantomjs --production --save --prefix "/opt/iobroker" (System call)
    npm
    npm
    npm ERR! phantomjs-prebuilt@2.1.16 install: `node install.js`npm ERR! Exit status 1
    npm ERR! npm ERR! Failed at the phantomjs-prebuilt@2.1.16 install script.
    npm ERR!     /home/iobroker/.npm/_logs/2019-01-10T16_33_39_525Z-debug.log
    NPM version: 6.4.1
    npm
    npm ERR! errno 1npm
    npm ERR!
    npm ERR!
     Failed at the phantomjs-prebuilt@2.1.16 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-01-10T16_34_29_877Z-debug.log
    ERROR: host.RPI_Master Cannot install phantomjs
    ERROR: process exited with code 13
    • H Offline
      homecineplexx
      #42
      also ich hab jetzt testweise auf meinem windows pc iobroker und phantomjs aufgesetzt, aber so richtig funktioniert das nicht mit dem snapshot oder?
      hier der testcode
      function testSomething () {
          sendTo('phantomjs.0', 'send', {
              url: 'http://192.168.1.2:8081/#tab-instances',
              output: 'chrk-test.png',
              width: 1000,
              height: 800,
             renderTime: 20000,
             online: true
          }, function (result) {
              console.log(result.error + ' ' + result.output);
      testSomething();
      und als anhang 2 fotos (hier werden scheinbar nicht alle daten/bilder geladen)
      • H holgerwolf
        Bitteschön:
        jensus11
        #43
        @holgerwolf
        Hi, wie hast du die Punkte output, width usw. da hinzugefügt?
        Bei mir fehlen die. Schaut so aus.
        • J Offline
          jensus11
          #44
          Habe es hinbekommen mit den Punkten.
          So sieht mein Blockly jetzt aus.
          Leider erhalte ich dann folgende Error Meldung.
          {"killed":false,"code":1,"signal":null,"cmd":"/opt/iobroker/node_modules/iobroker.phantomjs/node_modules/phantomjs-prebuilt/lib/phantom/bin/phantomjs /opt/iobroker/node_modules/iobroker.phantomjs/lib/
          Was ist damit gemeint?
          • chucky666C chucky666
            Hallo zusammen
            Kann mir einer per Blocky erklären wie ich das Foto per Telegram verschicke ?
            Gesendet von iPad mit Tapatalk Pro
            cvidalC Offline
            cvidalC Offline
            cvidal
            Forum Testing
            #45
            @chucky666 sagte in IoBroker.phantomjs:
            Hallo zusammen
            Bist du schon weitergekommen? Ich bekomme das Bild wohl abgespeichert aber bei mir hackt auch das Bild per Telegram zu versenden.
            chucky666C 1 Antwort Letzte Antwort
            • cvidalC cvidal
              Hallo zusammen
              chucky666C Offline
              chucky666C Offline
              chucky666
              #46
              @cvidal sagte in IoBroker.phantomjs:
              Hallo zusammen
              Das Problem hatte ich auch , ich habe es erstmal pausiert
                ratte-rizzo
                #47
                Moin
                Auf meinem Nuc mit Debian wollte ich den PhantomJS adapter installieren, was auch problemlos geklappt hat. Beim Starten des Beispiel-Skriptes gibts aber nur folgende Fehlermeldung:
                2020-02-08 18:28:56.728 - error: phantomjs.0 (11391) {"killed":false,"code":1,"signal":null,"cmd":"/opt/iobroker/node_modules/phantomjs-prebuilt/lib/phantom/bin/phantomjs /opt/iobroker/node_modules/iobroker.phantomjs/lib/rasterize.js --url http://google.com --output \"/opt/iobroker/node_modules/iobroker.phantomjs/image.png\" --width 300 --height 200 --timeout 10000"}
                Hat jemand eine Idee für die Fehlersuche?
                Dank & Gruß
                Daniel
                J 1 Antwort Letzte Antwort
                  PatrickFro
                  #48
                  @apollon77 @Bluefox
                  Moin
                  Ich versuche auf einem Raspi 4 den Adapter zu installieren, funktioniert leider nicht. Sowohl von Github als normale Installation habe ich versucht. Abbruch erfolgt immer mit folgender Meldung:
                  $ ./iobroker url "https://github.com/ioBroker/ioBroker.phantomjs"
                  install https://github.com/ioBroker/ioBroker.phantomjs/tarball/36433ed1245baad15f93e2b74b4b9f66eaf9a1bf
                  NPM version: 6.13.4
                  npm install https://github.com/ioBroker/ioBroker.phantomjs/tarball/36433ed1245baad15f93e2b74b4b9f66eaf9a1bf --loglevel error --prefix "/opt/iobroker" (System call)
                  Unexpected platform or architecture: linux/armIt seems there is no binary available for your platform/architectureTry to install PhantomJS globally
                  npm ERR! errno 1npm ERR! phantomjs-prebuilt@2.1.16 install: `node install.js`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the phantomjs-prebuilt@2.1.16 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                  npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-03-17T07_33_20_311Z-debug.log
                  ERROR: host.raspberrypi Cannot install https://github.com/ioBroker/ioBroker.phantomjs/tarball/36433ed1245baad15f93e2b74b4b9f66eaf9a1bf: 1
                  • P PatrickFro
                    @apollon77 @Bluefox
                    Moin
                    NPM version: 6.13.4
                    #49
                    @PatrickFro Ja, das liegt daran das phantomjs und raspis sich nicht wirklich mögen ... Da musst Du mal Googeln - es gibt da Wege, aber alle manuell.
                    P 1 Antwort Letzte Antwort
                    • apollon77A apollon77
                      PatrickFro
                      #50
                      @apollon77 Danke. Da meine Fähigkeiten bzw. das Zutrauen in meine Fähigkeiten dies betreffend nicht passen, werd ich mal andere Wege suchen.
                      • R ratte-rizzo
                        Moin
                        Dank & Gruß
                        Daniel
                        jupp78
                        #51
                        @ratte-rizzo
                        Moin,
                        wahrscheinlich ist Debian Buster installiert. Die openssl.cnf ist hier so verändert, daß PhantomJS nicht läuft.
                        Lösung war auf einer russischen Seite:
                        Die Datei /etc/ssl/openssl.cnf öffnen und
                        #ssl_conf = ssl_sect
                        auskommentieren. Befindet sich ziemlich am Ende der Datei.
                        Bei mir funktioniert PhantomJS anschließend tadellos.
                        Vielleicht hilft es.
                        Gruß,
                        de Jupp
                        • OliverIOO Offline
                          OliverIOO Offline
                          OliverIO
                          #52
                          die fehlermeldung ist aber eine andere.
                          Wenn so eine Fehlermeldung kommt
                          Dann muss npm das packet kompilieren. Dafür sind dann die entsprechenden Tools nicht installiert oder dem prozess fehlen die entsprechende Rechte.
                          Deswegen könnte man zuvor mal folgendes probieren:
                          sudo npm install -g phantomjs
                          das installiert zunächst nicht den adapter, sondern die Bibliothek, die der Adapter benötigt. Wenn das dann erfolgreich passiert ist, dann kann man nochmal probieren den Adapter in iobroker zu installieren.
                          Meine Adapter und Widgets
                          Links im Profil
                          R 1 Antwort Letzte Antwort
                          • OliverIOO OliverIO
                            ratte-rizzo
                            #53
                            @OliverIO
                            Hervorragend, das hats gelöst!
                            Dankeschön!
                            • NegaleinN Offline
                              NegaleinN Offline
                              Negalein
                              #54
                              Hallo
                              Ich möchte mit dem Adapter ein .png eines Grafana-Dashboards erstellen.
                              Dazu hab ich das Blockly von @holgerwolf nachgebaut.
                                <block type="schedule" id="*qZet(W7v?U_yLeQA|c3" x="213" y="38">
                                  <field name="SCHEDULE">*/5 * * * *</field>
                                  <statement name="STATEMENT">
                                    <block type="sendto_custom" id="(8Qa:{svVFnC{xMV)S%R">
                                      <mutation xmlns="http://www.w3.org/1999/xhtml" items="url,output,width,high,rendertime" with_statement="false"></mutation>
                                      <field name="INSTANCE">phantomjs.0</field>
                                      <field name="COMMAND">send</field>
                                      <field name="LOG"></field>
                                      <field name="WITH_STATEMENT">FALSE</field>
                                      <value name="ARG0">
                                        <shadow type="text" id="=N=}Y@wOHqX7jz1NEb6N">
                                          <field name="TEXT">http://10.0.1.22:32544/d/oNYohoEZk/wetterstation?orgId=1&amp;refresh=1m&amp;kiosk</field>
                                        </shadow>
                                      </value>
                                      <value name="ARG1">
                                        <shadow type="text" id="Ex1%T=Eca0lEc{1~*eD3">
                                          <field name="TEXT">wetter.png</field>
                                        </shadow>
                                      </value>
                                      <value name="ARG2">
                                        <shadow type="text" id="2[)0[jVDAY$[@zd~y`nf">
                                          <field name="TEXT">800</field>
                                        </shadow>
                                      </value>
                                      <value name="ARG3">
                                        <shadow type="text" id="T@tgj{AFUcXgH9|0A!*;">
                                          <field name="TEXT">600</field>
                                        </shadow>
                                      </value>
                                      <value name="ARG4">
                                        <shadow type="text" id="H0EnAmUp;[/Y0KeM#2je">
                                          <field name="TEXT">10000</field>
                                        </shadow>
                                      </value>
                                      <next>
                                        <block type="exec" id="=n,w~lE1+uuw%TQ:VJ|=">
                                          <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="false"></mutation>
                                          <field name="LOG">log</field>
                                          <value name="COMMAND">
                                            <shadow type="text" id="Ur.*Qi8vA(oEiHFh+PSe">
                                              <field name="TEXT">wput -nc /opt/iobroker/node_modules/iobroker.phantomjs/boden-ext.png ftp://user:password@www37.world4you.com</field>
                                            </shadow>
                                          </value>
                                        </block>
                                      </next>
                                    </block>
                                  </statement>
                                </block>
                              </xml>
                              Leider wird kein Bild gespeichert.
                              Bekomme folgenden Errir.
                              2020-07-15 17:10:00.515  - info: phantomjs.0 (2841) Create 800px*undefinedpx in undefinedms - "http://10.0.1.22:32544/d/oNYohoEZk/wetterstation?orgId=1&refresh=1m&kiosk" => "/opt/iobroker/node_modules/iobroker.phantomjs/wetter.png"
                              2020-07-15 17:10:00.527  - info: javascript.0 (595) script.js.common.Wetter_to_FTP: exec: wput -nc /opt/iobroker/node_modules/iobroker.phantomjs/boden-ext.png ftp://user:password@www37.world4you.com
                              2020-07-15 17:10:00.596  - error: phantomjs.0 (2841) {"killed":false,"code":127,"signal":null,"cmd":"/opt/iobroker/node_modules/phantomjs-prebuilt/lib/phantom/bin/phantomjs /opt/iobroker/node_modules/iobroker.phantomjs/lib/rasterize.js --url http://10.0.1.22:32544/d/oNYohoEZk/wetterstation?orgId=1&refresh=1m&kiosk --output \"/opt/iobroker/node_modules/iobroker.phantomjs/wetter.png\" --width 800 --high 600 --rendertime 10000"}
                              Kann mir da wer weiterhelfen?
                              ° Fixer ---> iob fix
                              H 1 Antwort Letzte Antwort
                              • NegaleinN Negalein
                                Hallo
                                        <value name="ARG0">
                                          </shadow>
                                        </value>
                                        <value name="ARG1">
                                          </shadow>
                                        </value>
                                        <value name="ARG2">
                                          </shadow>
                                        </value>
                                        <value name="ARG3">
                                          </shadow>
                                        </value>
                                        <value name="ARG4">
                                          </shadow>
                                        </value>
                                        <next>
                                              </shadow>
                                            </value>
                                          </block>
                                        </next>
                                      </block>
                                    </statement>
                                  </block>
                                </xml>
                                holgerwolf
                                schrieb am zuletzt editiert von holgerwolf
                                #55
                                @Negalein Lösche mal schnell deine ftp Zugangsdaten aus dem Log oben... Blödsinn, sorry
                                • H holgerwolf
                                  NegaleinN Offline
                                  NegaleinN Offline
                                  Negalein
                                  #56
                                  @holgerwolf sagte in IoBroker.phantomjs:
                                  sorry
                                  Kein Problem.
                                  Kannst du dir denken, was der Fehler ist?
                                  H ? 2 Antworten Letzte Antwort
                                    sorry
                                    Kein Problem.
                                    holgerwolf
                                    #57
                                    @Negalein Der erste Aufruf im Log sieht schon falsch aus. Bei mir steht da:
                                    Create 1200px*800px in 10000ms - "http://192.168.178.63:8082/vis/index.html#Wetter_Ext" => "/opt/iobroker/node_modules/iobroker.phantomjs/wetter-ext.png"
                                    Irgendwie werde die Werte aus deinem Blockly nicht übernommen. Vergessen das Blockly nach einer Änderung abzuspeichern? Schau dir mal den Javascript Code dazu an.
                                    • H holgerwolf
                                      NegaleinN Offline
                                      NegaleinN Offline
                                      Negalein
                                      #58
                                      hmmm, komisch
                                      Eigegeben sind sie richtig.
                                      Nein, eigentlich nicht.
                                      schedule("*/5 * * * *", function () {
                                        sendTo("phantomjs.0", "send", {
                                           "url": 'http://10.0.1.22:32544/d/oNYohoEZk/wetterstation?orgId=1&refresh=1m&kiosk',
                                           "output": 'wetter.png',
                                           "width": '800',
                                           "high": '600',
                                           "rendertime": '10000'
                                        exec('wput -nc /opt/iobroker/node_modules/iobroker.phantomjs/boden-ext.png ftp://user:password@www37.world4you.com');
                                        console.log("exec: " + 'wput -nc /opt/iobroker/node_modules/iobroker.phantomjs/boden-ext.png ftp://user:password@www37.world4you.com');
                                      Hää, wo kommt da im JS-Code jetzt das boden-ext.pngher?
                                      H F 2 Antworten Letzte Antwort
                                        hmmm, komisch
                                             "width": '800',
                                             "high": '600',
                                        holgerwolf
                                        #59
                                        boden-ext.png heißt das Bild bei mir. Da passt der wput Befehl bei dir nicht. Du speicherst "wetter.png" willst dann aber "boden-ext.png" übertragen. Vergessen anzupassen ;-)
                                        • H holgerwolf
                                          NegaleinN Offline
                                          NegaleinN Offline
                                          Negalein
                                          #60
                                          Ja, das war der Teil, den ich von dir kopiert habe. Ahhhhh, dummer Fehler.
                                          Habs jetzt geändert. Meld mich in 5 Min. wieder obs geklappt hat.
