  4. Einfach mal zeigen will….. :-) - Teil 3
    5.3k
visvisualisierungvisualizationvis editor
813 Beiträge 155 Kommentatoren 400.8k Aufrufe 157 Beobachtet
  • K Kuddel
    @ro75 vielen Dank für die Bilder etc.
    Ich habe selber parallel angefangen. Die vier Grafiken haben ich schon hinbekommen
    Beim Skript für das Widget, läuft aber noch irgendetwas schief
    javascript.0	2023-11-08 13:58:17.896	error	at processImmediate (node:internal/timers:466:21)
    javascript.0	2023-11-08 13:58:17.896	error	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8462:62)
    javascript.0	2023-11-08 13:58:17.896	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
    javascript.0	2023-11-08 13:58:17.896	error	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
    javascript.0	2023-11-08 13:58:17.896	error	at Object.<anonymous> (script.js.java.abfragen.pihole_diagramme:11:25)
    javascript.0	2023-11-08 13:58:17.896	error	Error in callback: ReferenceError: moment is not defined
    Skript
    const pihole_1_data = 'pi-hole.0.overTimeData10mins.domains_over_time.data-table';
    if(!existsState('0_userdata.0.PiHole-Diagramme.PiHole-1-Diagramm')){
       createState('0_userdata.0.PiHole-Diagramme.PiHole-1-Diagramm', "[]", {read: true, write: true, desc: "JSON String", type: "string", def: "[]"});
    on(pihole_1_data, function(dp) {
       let ConsumList = [];
       var text = dp.state.val.split(',');
       for (let i = 0; i <= text.length-1; i++) {
           let startTime = moment((text[i].split(':')[0].replace('"','').replace('"','').replace('[{',''))*1000);
           ConsumList.push({
               label: startTime.format('HH:mm').replace('Invalid date',''),
               value: parseFloat(text[i].split(':')[1]),
               valueColor: '#ffffff'
       setState('0_userdata.0.PiHole-Diagramme.PiHole-1-Diagramm', JSON.stringify(ConsumList), true);
       ConsumList = [];
    Muss ich bzgl. "moment" noch was in der Javascript Adapter Konfig ergänzen?
    Ro75R Online
    Ro75R Online
    Ro75
    #761
    @kuddel genau, muss rein
    K 1 Antwort Letzte Antwort
    • Ro75R Ro75
      Kuddel
      #762
      @ro75 hmm, komisch. Ist schon eingetragen. Habe den Eintrag mal entfernt, die Instanz neu gestartet und "moment" wieder eingetragen.
      Der Fehler kommt trotzdem noch.
      Ro75R 1 Antwort Letzte Antwort
      • K Kuddel
        Ro75R Online
        Ro75R Online
        Ro75
        #763
        @kuddel zeig Mal bitte
        • Ro75R Ro75
          Kuddel
          #764
          @ro75
          • K Kuddel
            @ro75
            Ro75R Online
            Ro75R Online
            Ro75
            #765
            @kuddel füge Mal ganz am Anfang ein
            const moment = require('moment');
            Ro75.
            • Ro75R Ro75
              Ro75.
              Kuddel
              #766
              @ro75 sagte in Einfach mal zeigen will….. :-) - Teil 3:
              Ro75.
              Super, jetzt läuft es
              • FlexerF Offline
                FlexerF Offline
                Flexer
                #767
                Habe heute mal mit Vis2 angefangen. Es wird eine neue Vis fürs Handy. Hier einfach mal zwei Screenshots.
                Ist alles noch work in progress
                Grüße
                Unterm Strich ist alles besser.
                Ja, voll geil hier!
                • FlexerF Flexer
                  Grüße
                  NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  #768
                  @flexer sagte in Einfach mal zeigen will….. :-) - Teil 3:
                  Hab dir im Chat geschrieben, da ich dachte das ist der Vis-2 Thread. ;)
                  Hier nochmal öffentlich. :)
                  Hast du für Vis-1 auch eine Unifi-View?
                  VIS-2 ist mir noch zu buggie. ;)
                  ° Fixer ---> iob fix
                  FlexerF 1 Antwort Letzte Antwort
                  • NegaleinN Negalein
                    FlexerF Offline
                    FlexerF Offline
                    Flexer
                    #769
                    @negalein Hast du Telegram? Kann dir mal was schicken was ich früher mal gebaut habe. Ist uralt aber so in der Art plane ich es wieder
                    Ja, voll geil hier!
                    • D dos1973
                      so langsam ist wieder VIS Time... heute regnerisch draussen, und mein aktuelles VIS staubt schon ein...mal ein neuer Versuch.
                      Frederik BussF Offline
                      Frederik Buss
                      #770
                      @dos1973 Schönes Design... Eins interessiert mich: Wie hast Du die Graphen in die VIS eingebunden? Grafana oder was anderes? Ich habe seit kurzem ein 14" Touch Display am Raspi hängen und bin auch dabei die VIS etwas aufzupeppen...
                      • Frederik BussF Frederik Buss
                        dos1973
                        #771
                        @frederik-buss
                        hier habe ich es beschrieben: https://forum.iobroker.net/topic/23917/einfach-mal-zeigen-will-teil-3/722?_=1701952775588
                        W Frederik BussF 2 Antworten Letzte Antwort
                        • D dos1973
                          @frederik-buss
                          W Offline
                          W Offline
                          woupi
                          #772
                          @dos1973 sagte in Einfach mal zeigen will….. :-) - Teil 3:
                          @frederik-buss
                          Und das hat auch super funktioniert. Danke an dieser Stelle nochmal 😀
                          NUC10i3, Proxmox, VM Ubuntu iobroker, lxc ubuntu influxdb, grafana, lxc ubuntu SAE, lxc ubuntu MotionEye, WP Panasonic Jeisha 5kW mit Heishamon, Shelly 2.5 und 2pm Rolladensteuerung, OpenWB Wallbox
                          • D dos1973
                            @frederik-buss
                            Frederik Buss
                            #773
                            @dos1973 said in Einfach mal zeigen will….. :-) - Teil 3:
                            @frederik-buss
                            Sorry, gerade erst die Antwort gesehen. Ja, das habe ich gelesen, aber so wie es verstanden habe, bietet source analytix keine widgets, oder doch? Mir geht es hauptsächlich um das Widget... Die Daten kann ich über Grafana auch so anzeigen und täglich den Verbrauch wegzuschreiben ist auch nciht das Problem. Nur eben die Darstellung hat mir bei Dir sehr gut gefallen :)
                              @frederik-buss
                              dos1973
                              #774
                              @frederik-buss
                              Das ist das Barchart aus dem Material widegts von scrounger
                              Frederik BussF 1 Antwort Letzte Antwort
                              • D dos1973
                                @frederik-buss
                                Frederik Buss
                                #775
                                @dos1973 Das habe ich gesucht. Vielen Dank!
                                  Frederik Buss
                                  #776
                                  So, hier mal ein Zwischenstand meiner neuen Vis, die - wenn fertig - auf einem 14" Toch Monitor (Raspi) in der Küche das bisherige Tablet ersetzen wird. Vielen Dank an @dos1973 für die Inspiration, auch wenn mein Ansatz ein anderer Ist, habe ich doch einige grundsätzliche Überlegungen übernommen, z.B. den Wetter/Tagesabhängige Hintergrund..
                                  Anregungen und Kritik werden immer gerne angenommen.
                                  maximal1981M 1 Antwort Letzte Antwort
                                    maximal1981M Offline
                                    maximal1981
                                    #777
                                    @frederik-buss
                                    sieht hübsch aus, abgesehen von den Wassertropfen.
                                    Ist nicht mein Still
                                    • maximal1981M maximal1981
                                      @frederik-buss
                                      Frederik Buss
                                      schrieb am zuletzt editiert von Frederik Buss
                                      #778
                                      @maximal1981 Danke für das Feedback. Die Wassertropfen sind ja nur da, wenns regnet, Sonne wäre mir grad auch lieber ;) Aber stimmt schon, die sind sehr präsent... Sobald alle Views fertig sind, schaue ich mir die ganzen Wetter- Hintergrundbilder nochmal genauer an.
                                      So siehts dann ohne Regen aus
                                        dos1973
                                        #779
                                        @frederik-buss
                                        Ich finds klasse, danke fürs teilen.
                                        Wäre an deinen Wetter Bildern interessiert…
                                        • D dos1973
                                          @frederik-buss
                                          Frederik Buss
                                          #780
                                          @dos1973 Das Prinzip ist einfach eine Verknüpfung mit dem Accuweather Adapter. Ein HTML Widget (Inaktiv/Locked) mit der Background Eigenschaft:
                                          URL("/vis.0/main2/background2/{accuweather.0.Current.WeatherIcon}.png")
                                          Die Bilder im Verzeichnis spiegeln dann mittel Benennung das Wetter wieder, also 1.png = sonnig usw.
