  4. Blink Camera System
Blink Camera System
blink xtcamera
407 Beiträge 63 Kommentatoren 164.6k Aufrufe 65 Beobachtet
    @gurke258
    Gib mal die Langfassung von
    iob diag
    bekannt.
    Gurke258G Offline
    Gurke258G Offline
    Gurke258
    #361
    @thomas-braun sagte in Blink Camera System:
    @gurke258
    iob diag
    bekannt.
    Copy text starting here:
    			v.2023-10-10
       Static hostname: HomePi
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Installation: 		native
    Kernel: 		aarch64
    Userland: 		arm64
    Timezone: 		Europe/Berlin (CET, +0100)
    User-ID: 		1000
    X-Server: 		true
    Boot Target: 		graphical.target
    Pending OS-Updates: 	0
    Pending iob updates: 	0
    Nodejs-Installation: 	/usr/bin/nodejs 	v18.18.2
    			/usr/local/bin/node 		v18.13.0
    			/usr/local/bin/npm 		8.19.3
    			/usr/local/bin/npx 		8.19.3
    			/usr/local/bin/corepack 	0.15.2
    Recommended versions are nodejs 18.18.2 and npm 9.8.1
    *** nodejs is NOT correctly installed ***
    Wrong installation path detected. This needs to be fixed.
    Please check
    for more information on how to fix these errors.
    MEMORY:
    Mem:            3.8G        2.0G        484M         69M        1.3G        1.6G
    Swap:            99M          0B         99M
    Total:          3.9G        2.0G        584M
    Active iob-Instances: 	27
    Active repo(s): stable
    ioBroker Core: 		js-controller 		5.0.12
    			admin 			6.12.0
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : HomePi                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.web.0                    : web                   : HomePi                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects: 		15766
    States: 		13659
    Size of iob-Database:
    15M	/opt/iobroker/iobroker-data/objects.jsonl
    18M	/opt/iobroker/iobroker-data/states.jsonl
    Er sagt immer noch das es nicht korrekt installiert wurde :/
      @gurke258
      Die Readme hast du gelesen?
      BREAKING CHANGE WARNING: As of 0.22.0 the library uses asyncio which will break any user scripts used prior to this version. Please see the updated examples below and the blinkapp.py or blinksync.py examples in the blinkapp/ directory for examples on how to migrate.
      Quelle: https://github.com/fronzbot/blinkpy
      Gurke258G Offline
      Gurke258G Offline
      Gurke258
      #362
      @gurke258
      Hatte ich gelesen und getestet aber auch da nen fehler bekommen. Deswegen wollte ich die alte Version mal testen
      Thomas BraunT PischleuderP Dr. BakteriusD 4 Antworten Letzte Antwort
      • Gurke258G Gurke258
        @gurke258
        #363
        @gurke258
        Schalt den DESKTOP aus.
        Und nodejs ist noch falsch installiert.
        iob nodejs-update
        Da dann die Pfade reparieren lassen.
          @gurke258
          #364
          @gurke258
          Das war auch nicht die Langfassung.
          Also nochmal, nachdem nodejs repariert ist.
          Gurke258G 1 Antwort Letzte Antwort
            @gurke258
            PischleuderP Offline
            Pischleuder
            #365
            @gurke258
            Moin,
            die Frage ist, was willst Du noch mit dem alten script ? Das wird so nicht mehr funktionieren, da sich die syntax zum einloggen etc. etwas verändert hat.
            Nutze doch einfach das homebridge plugin, sofern Du die Anlage scharf oder unscharf schalten möchtest.
            Gruss
            • PischleuderP Pischleuder
              @gurke258
              Moin,
              Gruss
              Gurke258G Offline
              Gurke258G Offline
              Gurke258
              #366
              @pischleuder sagte in Blink Camera System:
              @gurke258
              Moin,
              Gruss
              Ja mit dem Homebridge funktioniert es bei mir nicht mehr :/ Keine ahnung warum :/
              PischleuderP 1 Antwort Letzte Antwort
                @gurke258
                Moin,
                Gruss
                Pischleuder
                schrieb am zuletzt editiert von Pischleuder
                #367
                @gurke258
                welches npm Modul hast Du denn in der Homebridge Instanz eingegeben ?
                Es sollte homebridge-blink-for-home@3.9.2 dort stehen und die Instanz im Wrapper Modus
                starten.
                in der Konfig dann so:
                "description": "Add configuration for your accessories or platforms according to the docs of the plugins.",
                "accessories": [],
                "platforms": [
                "name": "Blink",
                "username": "Email-Adresse",
                "password": "Dein Passwort",
                "pin": "Deine Pin",
                "platform": "Blink"
                  @gurke258
                  Dr. BakteriusD Offline
                  Dr. Bakterius
                  #368
                  @gurke258 sagte in Blink Camera System:
                  Die alte blinkpy-Version vor dem breaking change? Die kann man mit sudo pip install blinkpy==0.21.0 installieren. Musste ich auch machen, weil ich das Skript auf die v0.22.0 nicht angepasst bekommen habe.
                  @Thomas-Braun: Gibt es für die Erstellung einer Bildaufnahme eine funktionierende Vorlage? Dann würde ich es vielleicht noch einmal mit der neuen Version testen.
                  Meine 'bild.py' für v0.21.0 sieht so aus:
                  import requests
                  from blinkpy.blinkpy import Blink
                  from blinkpy.auth import Auth
                  from blinkpy.camera import BlinkCamera
                  blink = Blink()
                  auth = Auth({"username": "******", "password": "*******"}, no_prompt=True)
                  blink.auth = auth
                  blink.start()
                  auth.send_auth_key(blink, "******")
                  blink.setup_post_verify()
                  bild = '/opt/iobroker/blink.jpg'
                  for name, camera in blink.cameras.items(): print(name), print(camera.attributes)
                  camera = blink.cameras['Eingangstuere']
                  camera.snap_picture()
                  blink.refresh()
                  camera.image_to_file(bild)
                  Thomas BraunT Gurke258G PischleuderP 3 Antworten Letzte Antwort
                    @gurke258
                    starten.
                    "accessories": [],
                    "platforms": [
                    "name": "Blink",
                    "pin": "Deine Pin",
                    "platform": "Blink"
                    Gurke258G Offline
                    Gurke258G Offline
                    Gurke258
                    schrieb am zuletzt editiert von Gurke258
                    #369
                    @gurke258
                    starten.
                    "accessories": [],
                    "platforms": [
                    "name": "Blink",
                    "pin": "Deine Pin",
                    "platform": "Blink"
                    So habe ich es jetzt eingestellt aber ich bekomme in der Config folgende Meldung:
                    Either the "platform" or "accessory" property must be set
                    EDIT: Okay ich denke ich habe es hinbekommen!.. Ist aber sehr träge im Vergleich zu vorher. :/
                      import requests
                      blink = Blink()
                      blink.auth = auth
                      blink.start()
                      blink.refresh()
                      #370
                      @dr-bakterius sagte in Blink Camera System:
                      Keine Ahnung. Ich hab keine Blink Camera im Einsatz.
                        @gurke258
                        Gurke258G Offline
                        Gurke258G Offline
                        Gurke258
                        #371
                        @gurke258
                        Sorry. Hier bitte :)
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                        Model		: Raspberry Pi 4 Model B Rev 1.1
                        Docker          : false
                        Virtualization  : none
                        Kernel          : aarch64
                        Userland        : arm64
                        Systemuptime and Load:
                         10:25:29 up  5:25,  2 users,  load average: 1.50, 1.40, 1.31
                        CPU threads: 4
                        *** RASPBERRY THROTTLING ***
                        Current issues:
                        Previously detected issues:
                        *** Time and Time Zones ***
                                       Local time: Sun 2023-11-05 10:25:29 CET
                                   Universal time: Sun 2023-11-05 09:25:29 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        *** User and Groups ***
                        pi
                        /home/pi
                        pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                        *** X-Server-Setup ***
                        X-Server: 	true
                        Desktop: 	LXDE-pi
                        Terminal: 	x11
                        *** MEMORY ***
                        Mem:            3.8G        2.3G        505M        164M        965M        1.2G
                        Swap:            99M          0B         99M
                        Total:          3.9G        2.3G        605M
                                 3794 M total memory
                                 2323 M used memory
                                 2886 M active memory
                                   65 M inactive memory
                                  504 M free memory
                                    9 M buffer memory
                                  956 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        oom events: 0
                        lifetime oom required: 0 Mbytes
                        total time in oom handler: 0 ms
                        max time spent in oom handler: 0 ms
                        *** FAILED SERVICES ***
                        0 loaded units listed.
                        *** FILESYSTEM ***
                        /dev/root      ext4       29G   14G   15G  48% /
                        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                        tmpfs          tmpfs     1.9G   20M  1.9G   2% /dev/shm
                        tmpfs          tmpfs     759M  976K  758M   1% /run
                        /dev/mmcblk0p1 vfat      253M   31M  222M  13% /boot
                        tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
                        [Sun Nov  5 05:00:23 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=DC:A6:32:63:9E:04 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=0f229ca1-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                        [Sun Nov  5 05:00:24 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                        [Sun Nov  5 05:00:24 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                        [Sun Nov  5 05:00:26 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                        Show mounted filesystems \(real ones only\):
                        TARGET  SOURCE         FSTYPE OPTIONS
                        /       /dev/mmcblk0p2 ext4   rw,noatime
                        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                        /var:
                        5.4G	/var/
                        3.1G	/var/log/journal/c82d6a18bd344322b99e963f9b19b8e6
                        3.1G	/var/log
                        1.8G	/var/cache/apt
                        Archived and active journals take up 3.0G in the file system.
                        /opt/iobroker/backups:
                        106M	/opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        668M	/opt/iobroker/iobroker-data/
                        498M	/opt/iobroker/iobroker-data/files
                        98M	/opt/iobroker/iobroker-data/files/vis-2-beta
                        72M	/opt/iobroker/iobroker-data/files/telegram.admin
                        71M	/opt/iobroker/iobroker-data/node-red/node_modules
                        35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                        21M	/opt/iobroker/iobroker-data/objects.jsonl
                        21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
                        19M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
                        18M	/opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
                        USB-Devices by-id:
                        USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
                        find: '/dev/serial/by-id/': No such file or directory
                        *** NodeJS-Installation ***
                        /usr/bin/node 		v18.18.2
                        /usr/bin/npm 		9.8.1
                        /usr/bin/npx 		9.8.1
                        /usr/bin/corepack 	0.19.0
                        nodejs:
                          Installed: 18.18.2-1nodesource1
                          Candidate: 18.18.2-1nodesource1
                          Version table:
                         *** 18.18.2-1nodesource1 1001
                                500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                                100 /var/lib/dpkg/status
                             18.18.1-1nodesource1 1001
                             18.18.0-1nodesource1 1001
                             18.17.1-1nodesource1 1001
                             18.17.0-1nodesource1 1001
                             18.16.1-1nodesource1 1001
                             18.16.0-1nodesource1 1001
                             18.15.0-1nodesource1 1001
                             18.14.2-1nodesource1 1001
                             18.14.1-1nodesource1 1001
                             18.14.0-1nodesource1 1001
                             18.13.0-1nodesource1 1001
                             18.12.0-1nodesource1 1001
                             18.11.0-1nodesource1 1001
                             18.10.0-1nodesource1 1001
                             18.9.1-1nodesource1 1001
                             18.9.0-1nodesource1 1001
                             18.8.0-1nodesource1 1001
                             18.7.0-1nodesource1 1001
                             18.6.0-1nodesource1 1001
                             18.5.0-1nodesource1 1001
                             18.4.0-1nodesource1 1001
                             18.3.0-1nodesource1 1001
                             18.2.0-1nodesource1 1001
                             18.1.0-1nodesource1 1001
                             18.0.0-1nodesource1 1001
                             12.22.12~dfsg-1~deb11u4 500
                                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                        No problems detected
                        Errors in npm tree:
                        *** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Core adapters versions
                        js-controller: 	5.0.12
                        admin: 		6.12.0
                        javascript: 	7.1.4
                        Adapters from github: 	0
                        Adapter State
                        + system.adapter.alexa2.0                 : alexa2                : HomePi                                   -  enabled
                        + system.adapter.backitup.0               : backitup              : HomePi                                   -  enabled
                        + system.adapter.bring.0                  : bring                 : HomePi                                   -  enabled
                          system.adapter.coronavirus-statistics.0 : coronavirus-statistics: HomePi                                   -  enabled
                          system.adapter.daswetter.0              : daswetter             : HomePi                                   -  enabled
                          system.adapter.devices.0                : devices               : HomePi                                   - disabled
                        + system.adapter.discovergy.0             : discovergy            : HomePi                                   -  enabled
                        + system.adapter.discovery.0              : discovery             : HomePi                                   -  enabled
                          system.adapter.dwd.0                    : dwd                   : HomePi                                   -  enabled
                        + system.adapter.ham.0                    : ham                   : HomePi                                   -  enabled
                        + system.adapter.hm-rega.0                : hm-rega               : HomePi                                   -  enabled
                        + system.adapter.hm-rpc.0                 : hm-rpc                : HomePi                                   -  enabled, port: 18701
                        + system.adapter.hm-rpc.1                 : hm-rpc                : HomePi                                   -  enabled, port: 12001
                          system.adapter.ical.0                   : ical                  : HomePi                                   -  enabled
                          system.adapter.ical.1                   : ical                  : HomePi                                   -  enabled
                          system.adapter.icons-material-svg.0     : icons-material-svg    : HomePi                                   -  enabled
                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : HomePi                                   - disabled
                          system.adapter.influxdb.0               : influxdb              : HomePi                                   - disabled, port: 8086
                        + system.adapter.info.0                   : info                  : HomePi                                   -  enabled
                        + system.adapter.iot.0                    : iot                   : HomePi                                   -  enabled
                        + system.adapter.javascript.0             : javascript            : HomePi                                   -  enabled
                        + system.adapter.netatmo.0                : netatmo               : HomePi                                   -  enabled
                        + system.adapter.nina.0                   : nina                  : HomePi                                   -  enabled
                        + system.adapter.node-red.0               : node-red              : HomePi                                   -  enabled, port: 1880, bind: 192.168.178.79
                        + system.adapter.ping.0                   : ping                  : HomePi                                   -  enabled
                        + system.adapter.rpi2.0                   : rpi2                  : HomePi                                   -  enabled
                        + system.adapter.smartthings.0            : smartthings           : HomePi                                   -  enabled
                          system.adapter.spotify-premium.0        : spotify-premium       : HomePi                                   - disabled
                        + system.adapter.synology.0               : synology              : HomePi                                   -  enabled, port: 5001
                          system.adapter.systeminfo.0             : systeminfo            : HomePi                                   - disabled
                          system.adapter.tankerkoenig.0           : tankerkoenig          : HomePi                                   - disabled
                        + system.adapter.telegram.0               : telegram              : HomePi                                   -  enabled, port: 8443, bind: 0.0.0.0
                        + system.adapter.text2command.0           : text2command          : HomePi                                   -  enabled
                        + system.adapter.trashschedule.0          : trashschedule         : HomePi                                   -  enabled
                        + system.adapter.tuya.0                   : tuya                  : HomePi                                   -  enabled
                          system.adapter.vis-2-beta.0             : vis-2-beta            : HomePi                                   - disabled
                          system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : HomePi                                   -  enabled
                          system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : HomePi                                   -  enabled
                          system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: HomePi                                   -  enabled
                          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : HomePi                                   -  enabled
                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : HomePi                                   - disabled
                          system.adapter.vis-icontwo.0            : vis-icontwo           : HomePi                                   - disabled
                        + system.adapter.vis-inventwo.0           : vis-inventwo          : HomePi                                   -  enabled
                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : HomePi                                   - disabled
                          system.adapter.vis-keyboard.0           : vis-keyboard          : HomePi                                   - disabled
                          system.adapter.vis-material-advanced.0  : vis-material-advanced : HomePi                                   - disabled
                          system.adapter.vis-metro.0              : vis-metro             : HomePi                                   - disabled
                          system.adapter.vis-rgraph.0             : vis-rgraph            : HomePi                                   -  enabled
                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : HomePi                                   - disabled
                          system.adapter.vis.0                    : vis                   : HomePi                                   -  enabled
                        + instance is alive
                        ioBroker-Repositories
                        Installed ioBroker-Instances
                        Used repository: stable
                        Adapter    "adguard"      : 0.0.8    , installed 0.0.8
                        Adapter    "admin"        : 6.12.0   , installed 6.12.0
                        Adapter    "alexa2"       : 3.25.5   , installed 3.25.5
                        Adapter    "backitup"     : 2.8.7    , installed 2.8.7
                        Adapter    "bring"        : 1.8.4    , installed 1.8.4
                        Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
                        Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                        Adapter    "devices"      : 1.1.5    , installed 1.1.5
                        Adapter    "discovergy"   : 0.5.8    , installed 0.5.8
                        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                        Adapter    "ham"          : 5.3.1    , installed 5.3.1
                        Adapter    "hid-community": 0.3.0    , installed 0.3.0
                        Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
                        Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                        Adapter    "ical"         : 1.13.3   , installed 1.13.3
                        Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
                        Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
                        Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                        Adapter    "info"         : 2.0.0    , installed 2.0.0
                        Adapter    "iot"          : 1.14.5   , installed 1.14.5
                        Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                        Controller "js-controller": 5.0.12   , installed 5.0.12
                        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                        Adapter    "nina"         : 0.0.25   , installed 0.0.25
                        Adapter    "node-red"     : 4.0.3    , installed 4.0.3
                        Adapter    "openweathermap": 0.3.9   , installed 0.3.9
                        Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
                        Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
                        Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                        Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
                        Adapter    "synology"     : 3.0.1    , installed 3.0.1
                        Adapter    "systeminfo"   : 1.1.0    , installed 1.1.0
                        Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
                        Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                        Adapter    "text2command" : 3.0.2    , installed 3.0.2
                        Adapter    "tibberlink"   : 1.4.1    , installed 1.4.1
                        Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                        Adapter    "tuya"         : 3.14.2   , installed 3.14.2
                        Adapter    "vis"          : 1.4.16   , installed 1.4.16
                        Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
                        Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
                        Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
                        Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                        Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
                        Adapter    "web"          : 6.1.4    , installed 6.1.2  [Updatable]
                        Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
                        Adapter    "withings"     : 0.0.13   , installed 0.0.13
                        Adapter    "ws"           : 2.5.5    , installed 2.5.5
                        Objects and States
                        Objects: 	15792
                        States: 	13665
                        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                        Hit:2 http://deb.debian.org/debian bullseye InRelease
                        Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                        Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                        Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                        Reading package lists...
                        Pending Updates: 0
                        *** Listening Ports ***
                        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15591      542/cupsd
                        tcp        0      0 192.168.178.79:18701    0.0.0.0:*               LISTEN      1001       280874     29233/io.hm-rpc.0
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       280609     29088/iobroker.js-c
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       280616     29088/iobroker.js-c
                        tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          16404      578/vncserver-x11-c
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13802      606/sshd: /usr/sbin
                        tcp        0      0 192.168.178.79:1880     0.0.0.0:*               LISTEN      1001       279873     29195/node-red
                        tcp        0      0 192.168.178.79:12001    0.0.0.0:*               LISTEN      1001       280923     29256/io.hm-rpc.1
                        tcp6       0      0 :::3310                 :::*                    LISTEN      115        15720      661/mariadbd
                        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15590      542/cupsd
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       278103     29109/io.admin.0
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       283724     29863/io.web.0
                        tcp6       0      0 :::5900                 :::*                    LISTEN      0          16403      578/vncserver-x11-c
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          13804      606/sshd: /usr/sbin
                        tcp6       0      0 :::80                   :::*                    LISTEN      0          16428      687/apache2
                        udp        0      0 0.0.0.0:53157           0.0.0.0:*                           108        14400      407/avahi-daemon: r
                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16455      485/dhcpcd
                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       279265     29478/io.tuya.0
                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       279266     29478/io.tuya.0
                        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          14572      666/cups-browsed
                        udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1000       303130     32252/chromium-brow
                        udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1000       303128     32252/chromium-brow
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14398      407/avahi-daemon: r
                        udp6       0      0 :::546                  :::*                                0          13950      485/dhcpcd
                        udp6       0      0 :::37916                :::*                                108        14401      407/avahi-daemon: r
                        udp6       0      0 :::5353                 :::*                                108        14399      407/avahi-daemon: r
                        2023-11-05 10:19:34.236  - info: ham.0 (32072) updateState Blink-Blink-Flur.Blink-Flur-Privacy-Mode.Name: value = Blink Flur Privacy Mode /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
                        2023-11-05 10:19:34.259  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-Flur.Blink-Flur-Privacy-Mode.Name {"val":"Blink Flur Privacy Mode","ack":true,"ts":1699175968047,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1693823092789}
                        2023-11-05 10:19:34.306  - info: ham.0 (32072) updateState Blink-Blink-Flur.Blink-Flur-Privacy-Mode.On: value = false /common= {"type":"boolean","read":true,"write":true,"role":"switch","name":"On","unit":""}
                        2023-11-05 10:19:34.334  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-Flur.Blink-Flur-Privacy-Mode.On {"val":false,"ack":true,"ts":1699175968067,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1693823092845}
                        2023-11-05 10:19:37.943  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":false,"ack":false,"ts":1699175977940,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1699175977940}
                        2023-11-05 10:19:41.270  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":false,"ack":true,"ts":1699175981267,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1699175977940}
                        2023-11-05 10:19:56.106  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":true,"ack":false,"ts":1699175996101,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1699175996101}
                        2023-11-05 10:19:56.129  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":true,"ack":true,"ts":1699175996125,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1699175996101}
                        2023-11-05 10:20:00.062  - info: host.HomePi instance system.adapter.dwd.0 started with pid 32168
                        2023-11-05 10:20:03.699  - info: dwd.0 (32168) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.12
                        2023-11-05 10:20:06.936  - info: dwd.0 (32168) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        2023-11-05 10:20:07.480  - info: host.HomePi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2023-11-05 10:20:36.192  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":false,"ack":false,"ts":1699176036188,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1699176036188}
                        2023-11-05 10:20:36.215  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":false,"ack":true,"ts":1699176036210,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1699176036188}
                        2023-11-05 10:20:41.279  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":true,"ack":false,"ts":1699176041276,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1699176041276}
                        2023-11-05 10:20:44.229  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":true,"ack":true,"ts":1699176044225,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1699176041276}
                        2023-11-05 10:20:53.611  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":false,"ack":false,"ts":1699176053606,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1699176053606}
                        2023-11-05 10:20:53.683  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":false,"ack":true,"ts":1699176053678,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1699176053606}
                        2023-11-05 10:21:32.141  - info: web.0 (29863) ==> Connected system.user.admin from ::ffff:192.168.178.79
                        2023-11-05 10:23:41.482  - info: admin.0 (29109) ==> Connected system.user.admin from ::ffff:192.168.178.123
                        2023-11-05 10:23:49.815  - info: admin.0 (29109) <== Disconnect system.user.admin from ::ffff:192.168.178.123
                        2023-11-05 10:25:00.062  - info: host.HomePi instance system.adapter.dwd.0 started with pid 32832
                        2023-11-05 10:25:03.554  - info: dwd.0 (32832) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.12
                        2023-11-05 10:25:06.028  - info: dwd.0 (32832) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        2023-11-05 10:25:06.573  - info: host.HomePi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        [/s]
                          import requests
                          blink = Blink()
                          blink.auth = auth
                          blink.start()
                          blink.refresh()
                          Gurke258G Offline
                          Gurke258G Offline
                          Gurke258
                          #372
                          @dr-bakterius
                          Da habe ich leider nach wie vor den selben Fehler...
                          from blinkpy.blinkpy import Blink ImportError: No module named blinkpy.blinkpy
                          Trotz dem 0.21.0 :(
                          Naja ich habe dank @Pischleuder erstmal ne Lösung und muss denke ich auch mal von bullseye auf Bookworm wechseln mim Pi4
                            import requests
                            blink = Blink()
                            blink.auth = auth
                            blink.start()
                            blink.refresh()
                            Pischleuder
                            #373
                            import requests
                            blink = Blink()
                            blink.auth = auth
                            blink.start()
                            blink.refresh()
                            Moin,
                            nein - ich hatte dieses script damals zusammengedängelt, mir aber nicht die Mühe gemacht, das auf die neue blinkpy umzusetzen, da es immer noch keinen livestream support geben wird.
                            Dr. BakteriusD 1 Antwort Letzte Antwort
                              import requests
                              blink = Blink()
                              blink.auth = auth
                              blink.start()
                              blink.refresh()
                              Moin,
                              Dr. Bakterius
                              #374
                              Verstehe. Allerdings haben alle die die aktuelle v0.22.0 installieren dann das Problem, dass das Skript nicht tut. Ich hatte zwar versucht es nach der Beschreibung auf Git-Hub anzupassen, bin aber gescheitert. Für meinen Zweck würde es schon reichen ein Bild aufzunehmen und am gewünschten Ort zu speichern. Livestream ist mit Batterie ohnehin eine weniger gute Idee und könnte ich ja immer noch mit der Blink-App haben.
                                Pischleuder
                                #375
                                @dr-bakterius
                                ja, das Problem ist nur, dass Module benötigt werden, die in der aktuellen Python-Version (3.11) noch nicht enthalten sind und man kann diese nicht so ohne weiteres über pip nachladen. Lediglich als venv Variante. Der Aufwand ist derzeit zum Nutzen einfach zu hoch.
                                • Dr. BakteriusD Offline
                                  Dr. Bakterius
                                  #376
                                  Ich grabe diesen Thread aus aktuellem Anlass wieder aus.
                                  Seit irgendwann im April hat Blinkpy nicht mehr funktioniert, weil Amazon bei der Anmeldung etwas geändert hat und dadurch jedes Mal ein neuer 2FA Code gesendet wurde. Das wurde auch auf GitHub behandelt (https://github.com/fronzbot/blinkpy/issues/917). Inzwischen dürfte es eine Lösung geben die ich hier gerne zusammenfassen möchte. Vielleicht nützt es ja jemandem.
                                  Aktuell muss man folgende beiden Skripte von GitHub herunterladen und bei sich im Ordner /home/<user>/.local/lib/python3.11/site-packages/blinkpy ersetzen: auth.py und blinkpy.py.
                                  Man erstellt einmalig ein Skript (z.B. anmelden.py) mit folgendem Inhalt:
                                  import asyncio
                                  from aiohttp import ClientSession
                                  async def start():
                                      blink = Blink(session=ClientSession())
                                      # Can set no_prompt when initializing auth handler
                                      auth = Auth({"username": <your username>, "password": <your password>}, no_prompt=True)
                                      blink.auth = auth
                                      await blink.start()
                                      await blink.save("/opt/iobroker/blink_auth.json")
                                      return blink
                                  blink = asyncio.run(start())
                                  Wenn man dieses von der Console aufruft
                                  python3.11 anmelden.py
                                  , wird man nach seinen Anmeldedaten gefragt und erhält dann den 2FA Code welchen man angibt. Anschließend wird in /opt/iobroker die Datei blink_auth.json erstellt. Diese enthält die Anmeldedaten für künftige Abfragen. Danach kann man das Skript wenn man möchte wieder löschen.
                                  Um jetzt ein Bild abzufragen braucht man folgendes Skript:
                                  import asyncio
                                  from blinkpy.helpers.util import json_load
                                  async def start():
                                      blink = Blink()
                                      auth = Auth(await json_load("/opt/iobroker/blink_auth.json"))   # Anmeldeinformationen laden
                                      blink.auth = auth   # Anmeldeinformationen senden
                                      await blink.start()   # Verbindung starten
                                      camera = blink.cameras['<Kameraname>']   # Kameraname angeben
                                      await camera.snap_picture()   # Bild aufnehmen
                                      await blink.refresh()   # Daten vom Blink-Server abfragen
                                      await camera.image_to_file('/opt/iobroker/blink.jpg')   # Bild speichern
                                      return blink
                                  Leider ist es mir nicht gelungen das Skript mit exec (JS oder Blockly) wegen fehlender Berechtigung aufzurufen. Ich habe das dann mit dem Linux-Control Adapter gelöst.
                                  F D 2 Antworten Letzte Antwort
                                    import asyncio
                                    async def start():
                                        blink.auth = auth
                                        await blink.start()
                                        return blink
                                    import asyncio
                                    async def start():
                                        blink = Blink()
                                        return blink
                                    Flowski
                                    #377
                                    gibt es mittlerweile eine Möglichkeit auf die Bilder der Cam zuzugreifen??
                                    • F Flowski
                                      Dr. Bakterius
                                      #378
                                      @flowski Geht doch wie oben beschrieben.
                                      F 2 Antworten Letzte Antwort
                                        Flowski
                                        #379
                                        @dr-bakterius said in Blink Camera System:
                                        oh wow das habe ich wohl übersehen, bzw. inhaltlich garnicht wirklich begriffen, befinde mich noch in den Anfängen des ganzen... wie zuverlässig läuft das ganze? Sind die Bilder auch schnell verfügbar dass es auch Sinn macht?
                                        • F Flowski
                                          Dr. Bakterius
                                          #380
                                          @flowski Was ist schnell? Ich lasse mir die Bilder mit Pushover ans Handy schicken. Das dauert etwa 15 Sekunden. Der Verbinungsaufbau meiner Blink Outdoor dauert alleine schon 10-12 Sekunden.
                                          F 1 Antwort Letzte Antwort
