  4. [gelöst]Aktualisieren von Objekten und scripten
objekte
107 Beiträge 6 Kommentatoren 11.9k Aufrufe 6 Beobachtet
  • A Alero
    @foxriver76
    Also
    Fenster geschlossen
    Auszug log rpc2:
    Fenster steht aber noch auf true
    mama mia schreibt der viel.
    das steht im Log:
    "0000D8A99BCEF5":{"Name":"TFK_Fensterkontakt_Buero_rechts","Interface":"HmIP-RF"},
    "0000D8A99BCEF5:0":{"Name":"TFK_Fensterkontakt_Buero_rechts%3A0","Interface":"HmIP-RF"},
    "0000D8A99BCEF5:1":{"Name":"TFK_Fensterkontakt_Buero_rechts%3A1","Interface":"HmIP-RF"},
    "0000D8A99BCEF5:2":{"Name":"HMIP-SWDO%200000D8A99BCEF5%3A2","Interface":"HmIP-RF"},
    hier noch was aus dem Log:
    [/s"HmIP-RF.0000D8A99BCEF5%3A0.CONFIG_PENDING":false,
    "HmIP-RF.0000D8A99BCEF5%3A0.DUTY_CYCLE":false,
    "HmIP-RF.0000D8A99BCEF5%3A0.ERROR_CODE":0,
    "HmIP-RF.0000D8A99BCEF5%3A0.LOW_BAT":false,
    "HmIP-RF.0000D8A99BCEF5%3A0.OPERATING_VOLTAGE":1.300000,
    "HmIP-RF.0000D8A99BCEF5%3A0.OPERATING_VOLTAGE_STATUS":0,
    "HmIP-RF.0000D8A99BCEF5%3A0.RSSI_DEVICE":189,
    "HmIP-RF.0000D8A99BCEF5%3A0.RSSI_PEER":0,
    "HmIP-RF.0000D8A99BCEF5%3A0.SABOTAGE":false,
    "HmIP-RF.0000D8A99BCEF5%3A0.UNREACH":false,
    "HmIP-RF.0000D8A99BCEF5%3A0.UPDATE_PENDING":false,
    "HmIP-RF.0000D8A99BCEF5%3A1.STATE":1,
    "5128":{"Name":"AL-0000D8A99BCEF5%3A0.CONFIG_PENDING","AlState":0,"AlOccurrenceTime":"1970-01-01 01:00:00","LastTriggerTime":"2019-06-14 16:55:12","Operations":5,"AlTriggerDP":5127,"Parent":5126},
    "5135":{"Name":"AL-0000D8A99BCEF5%3A0.LOW_BAT","AlState":0,"AlOccurrenceTime":"1970-01-01 01:00:00","LastTriggerTime":"2019-06-14 16:55:12","Operations":5,"AlTriggerDP":5134,"Parent":5126},
    "5143":{"Name":"AL-0000D8A99BCEF5%3A0.SABOTAGE","AlState":0,"AlOccurrenceTime":"1970-01-01 01:00:00","LastTriggerTime":"2019-06-14 16:55:12","Operations":5,"AlTriggerDP":5142,"Parent":5126},
    "5147":{"Name":"AL-0000D8A99BCEF5%3A0.UNREACH","AlState":0,"AlOccurrenceTime":"1970-01-01 01:00:00","LastTriggerTime":"2019-06-14 16:55:12","Operations":5,"AlTriggerDP":5146,"Parent":5126},
    "5151":{"Name":"AL-0000D8A99BCEF5%3A0.UPDATE_PENDING","AlState":0,"AlOccurrenceTime":"1970-01-01 01:00:00","LastTriggerTime":"1970-01-01 01:00:00","Operations":5,"AlTriggerDP":5150,"Parent":5126},
    "0000D8A99BCEF5:2":{"Name":"HMIP-SWDO%200000D8A99BCEF5%3A2","Interface":"HmIP-RF"},]
    A10ccurrenttime 1970????? ist das mein Problem?
    foxriver76F Offline
    foxriver76F Offline
    foxriver76
    schrieb am zuletzt editiert von foxriver76
    #101
    @Alero Sende mal bitte den Logausschnitt ab Start der Instanz von hm-rpc.2, ändere dann mal einen Aktor (z. B. Fenster öffnen, dass über HMIP überwacht wird) . Hm-RPC ist das interessante, der Logausschnitt scheint hm-rega zu zeigen.
    Rega scheint korrekt zu arbeiten, die 1970er Timestamps sind aus der CCU, heißt einfach nur dass sich da noch nie was geändert hat. Gerade bei den Alarmmeldungen ist das öfters mal.
    Videotutorials & mehr
    A 1 Antwort Letzte Antwort
    • foxriver76F foxriver76
      Alero
      #102
      @foxriver76
      hier das Log. Zum Schluss werden alle dann noch aufgezählt.:
      hm-rega.0 2019-06-16 07:21:16.816 debug <-- {"INT0000004":{"Name":"Bad_Fenster_und_Heizung","Interface":"VirtualDevices"}, "INT0000004:0":{"Name":"Bad_Fenster_und_Heizung%3A0","Interface":"VirtualDevices"}, "INT0000004:1":{"Name":"Bad_Fen
      hm-rega.0 2019-06-16 07:21:16.764 debug --> !# devices.fn 1.4 !# !# Dieses Homematic-Script gibt eine Liste aller Geraete/Ka
      hm-rega.0 2019-06-16 07:21:16.761 debug --> devices.fn
      hm-rpc.2 2019-06-16 07:21:15.593 info new HmIP devices/channels after filter: 0
      hm-rpc.2 2019-06-16 07:21:15.579 info xmlrpc <- newDevices 384
      hm-rpc.2 2019-06-16 07:21:15.265 info xmlrpc -> 0 devices
      hm-rpc.2 2019-06-16 07:21:15.245 info xmlrpc <- listDevices ["hm-rpc.2"]
      hm-rega.0 2019-06-16 07:21:07.738 debug <-- {"11266":{"Name":"Alarm%20Aktivieren","TypeName":"PROGRAM","PrgInfo":"", "Active":true,"Timestamp":"1970-01-01 01:00:00"}, "10222":{"Name":"Alarm_erkannt_Buero","TypeName":"PROGRAM","PrgInfo":"",
      hm-rega.0 2019-06-16 07:21:07.729 debug --> !# programs.fn 1.3 !# Dieses Script gibt eine Liste der Programme als JSON Strin
      hm-rega.0 2019-06-16 07:21:07.678 debug <-- {"1236":[false,"1970-01-01 01:00:00"], "950":[true,"2019-06-14 18:38:04"], "10176":[0,"2019-06-14 18:38:03"], "10179":[false,"2019-06-14 18:38:11"], "10177":[false,"2019-06-14 18:38:11"], "10
      hm-rega.0 2019-06-16 07:21:07.662 debug --> !# polling.fn 1.2 !# !# Dieses Script gibt die Werte aller Systemvariablen als J
      hm-rega.0 2019-06-16 07:21:07.661 debug --> programs.fn
      hm-rega.0 2019-06-16 07:21:07.660 debug --> polling.fn
      hm-rpc.2 2019-06-16 07:21:07.466 debug PING ok
      hm-rpc.2 2019-06-16 07:21:07.452 debug Send PING...
      hm-rpc.2 2019-06-16 07:21:07.452 debug [KEEPALIVE] Check if connection is alive
      hm-rpc.0 2019-06-16 07:20:52.840 info xmlrpc -> 90 devices
      hm-rpc.0 2019-06-16 07:20:52.827 info xmlrpc <- listDevices ["hm-rpc.0"]
      hm-rpc.0 2019-06-16 07:20:52.816 info xmlrpc <- system.listMethods ["hm-rpc.0"]
      hm-rega.0 2019-06-16 07:20:40.814 debug <-- {"INT0000004":{"Name":"Bad_Fenster_und_Heizung","Interface":"VirtualDevices"}, "INT0000004:0":{"Name":"Bad_Fenster_und_Heizung%3A0","Interface":"VirtualDevices"}, "INT0000004:1":{"Name":"Bad_Fen
      hm-rega.0 2019-06-16 07:20:40.765 debug --> !# devices.fn 1.4 !# !# Dieses Homematic-Script gibt eine Liste aller Geraete/Ka
      hm-rega.0 2019-06-16 07:20:40.761 debug --> devices.fn
      hm-rpc.2 2019-06-16 07:20:39.604 info new HmIP devices/channels after filter: 0
      hm-rpc.2 2019-06-16 07:20:39.596 info xmlrpc <- newDevices 384
      hm-rpc.2 2019-06-16 07:20:39.280 info xmlrpc -> 0 devices
      hm-rpc.2 2019-06-16 07:20:39.269 info xmlrpc <- listDevices ["hm-rpc.2"]
      hm-rega.0 2019-06-16 07:20:37.750 debug <-- {"11266":{"Name":"Alarm%20Aktivieren","TypeName":"PROGRAM","PrgInfo":"", "Active":true,"Timestamp":"1970-01-01 01:00:00"}, "10222":{"Name":"Alarm_erkannt_Buero","TypeName":"PROGRAM","PrgInfo":"",
      hm-rega.0 2019-06-16 07:20:37.736 debug --> !# programs.fn 1.3 !# Dieses Script gibt eine Liste der Programme als JSON Strin
      hm-rega.0 2019-06-16 07:20:37.685 debug <-- {"1236":[false,"1970-01-01 01:00:00"], "950":[true,"2019-06-14 18:38:04"], "10176":[0,"2019-06-14 18:38:03"], "10179":[false,"2019-06-14 18:38:11"], "10177":[false,"2019-06-14 18:38:11"], "10
      hm-rega.0 2019-06-16 07:20:37.665 debug --> !# polling.fn 1.2 !# !# Dieses Script gibt die Werte aller Systemvariablen als J
      hm-rega.0 2019-06-16 07:20:37.661 debug --> programs.fn
      hm-rega.0 2019-06-16 07:20:37.660 debug --> polling.fn
      hm-rpc.0 2019-06-16 07:20:18.094 info xmlrpc -> 90 devices
      hm-rpc.0 2019-06-16 07:20:18.078 info xmlrpc <- listDevices ["hm-rpc.0"]
      hm-rpc.0 2019-06-16 07:20:18.074 info xmlrpc <- system.listMethods ["hm-rpc.0"]
      hm-rega.0 2019-06-16 07:20:07.745 debug <-- {"11266":{"Name":"Alarm%20Aktivieren","TypeName":"PROGRAM","PrgInfo":"", "Active":true,"Timestamp":"1970-01-01 01:00:00"}, "10222":{"Name":"Alarm_erkannt_Buero","TypeName":"PROGRAM","PrgInfo":"",
      hm-rega.0 2019-06-16 07:20:07.733 debug --> !# programs.fn 1.3 !# Dieses Script gibt eine Liste der Programme als JSON Strin
      hm-rega.0 2019-06-16 07:20:07.682 debug <-- {"1236":[false,"1970-01-01 01:00:00"], "950":[true,"2019-06-14 18:38:04"], "10176":[0,"2019-06-14 18:38:03"], "10179":[false,"2019-06-14 18:38:11"], "10177":[false,"2019-06-14 18:38:11"], "10
      hm-rega.0 2019-06-16 07:20:07.661 debug --> !# polling.fn 1.2 !# !# Dieses Script gibt die Werte aller Systemvariablen als J
      hm-rega.0 2019-06-16 07:20:07.659 debug --> programs.fn
      hm-rega.0 2019-06-16 07:20:07.658 debug --> polling.fn
      hm-rega.0 2019-06-16 07:20:05.492 debug <-- {"INT0000004":{"Name":"Bad_Fenster_und_Heizung","Interface":"VirtualDevices"}, "INT0000004:0":{"Name":"Bad_Fenster_und_Heizung%3A0","Interface":"VirtualDevices"}, "INT0000004:1":{"Name":"Bad_Fen
      hm-rega.0 2019-06-16 07:20:05.440 debug --> !# devices.fn 1.4 !# !# Dieses Homematic-Script gibt eine Liste aller Geraete/Ka
      hm-rega.0 2019-06-16 07:20:05.439 debug --> devices.fn
      hm-rpc.2 2019-06-16 07:20:04.292 info new HmIP devices/channels after filter: 0
      hm-rpc.2 2019-06-16 07:20:04.279 info xmlrpc <- newDevices 384
      hm-rpc.2 2019-06-16 07:20:03.953 info xmlrpc -> 0 devices
      hm-rpc.2 2019-06-16 07:20:03.934 info xmlrpc <- listDevices ["hm-rpc.2"]
      debug BidCoS-RF:50":{"Name":"HM-RCV-50%20BidCoS-RF%3A50","Interface":"BidCos-RF"}}
      debug BidCoS-RF:49":{"Name":"HM-RCV-50%20BidCoS-RF%3A49","Interface":"BidCos-RF"},
      debug BidCoS-RF:48":{"Name":"HM-RCV-50%20BidCoS-RF%3A48","Interface":"BidCos-RF"},
      debug BidCoS-RF:47":{"Name":"HM-RCV-50%20BidCoS-RF%3A47","Interface":"BidCos-RF"},
      Ich habe in der CCu mal ins log geschaut. Da ist der CUXD sehr aktiv. Vom HMIP (RCP.2) sehe ich da nichts. M.M nach sollte aber auch er kommunizierne. Ich vermute fast es liegt an der CCU3.
      Bin die nächsten Tage unterwegs. Daher kann ich nicht immer direkt antworeten oder was senden.
      Versuche zwischendurch reinzuschauen. Melde mich wieder.
      Vielen Dank für die Unterstützung.
      Alero
      • A Alero
        @foxriver76
        Alero
        foxriver76F Offline
        foxriver76F Offline
        foxriver76
        #103
        @Alero und hast du während dem log Ausschnitt auch mal ein Sensor betätigt? da kommt gar nix zurück. Magst du mir mal die Konfig Screenshots von hm-rpc.2 unbearbeitet/unzensiert senden, gerne auch per PN.
          Alero
          schrieb am zuletzt editiert von Alero
          #104
          @foxriver76
          Hi, ja hab ich. Objekt Haustür was closed. Dann geöffnet. Nix passiert. Erst nach Neustart von rega. War Objekt auf Open.
          Im Log der ccu3 habe ich auch nix gefunden. Ich vermute fast das der Fehler an der ccu3 liegt.
          Melde mich wenn ich wieder daheim bin.
          Gruss
          Alero
          • A Alero
            @foxriver76
            Gruss
            Alero
            Alero
            #105
            @foxriver76
            Hi , wie kann ich dir ne PN schicken?
            Gruss
            Alero
            • A Alero
              @foxriver76
              Gruss
              Alero
              sigi234S Online
              sigi234S Online
              sigi234
              #106
              @Alero
              Klicke den User an, dann die 3 Punkte, Chat
              Immer Daten sichern!
                Alero
                #107
                erst einmal vielen Dank für eure Hilfe.
                Ich glaube ich habe den Fehler gefunden. Bei Scripten habe ich es noch nicht getestet, danke aber das es auch geht.
                Ich habe, aus Spass, die Adapter getauscht.
                Im Einsatz sind bei mir RPC.0 =RFD, RPC.1=CuxD und RPC.2 HomematicIP.
                Nun habe ich CuxD und Homematic getauscht. Vorher aber die Dienste gestoppt und alle Objekte gelöscht damit sie neu angelegt werden. Dannach habe ich RPC.1 und RPC.2 einfach mal getauscht. So das RPC1 jetzt Homematicip ,und RPC.2 jetzt CuxD ist.
                Seit gestern abend werden alle Objekte (fFensterkontakt, Schalter usw. ) aktualisiert.
                P.S. Klingt komisch , ist aber so. ;-)
                Alero
