  4. Test Adapter HeatingControl v3.xx
    1.6k
  • Weihnachtsangebot 2025! 🎄
    2.1k
heating
3.2k Beiträge 238 Kommentatoren 2.1m Aufrufe 205 Watching
  • M MyMeyer
    @Rene_HM Schau hier bin jetzt ein paar Minuten wieder Online mit WLan und es passiert nichts. Die Temperatur geht nicht hoch.
    heatingcontrol.0 2020-02-09 16:47:26.433 debug (23152) ### state change already handled: true / true /// heatingcontrol.0.Present / heatingcontrol.0.Present
    heatingcontrol.0 2020-02-09 16:47:26.433 debug (23152) ### handle state change heatingcontrol.0.Present {"val":true,"ack":true,"ts":1581263246431,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1581263036403}
    heatingcontrol.0 2020-02-09 16:47:26.432 debug (23152) ### state change already handled: true / true /// heatingcontrol.0.Present / heatingcontrol.0.Present
    heatingcontrol.0 2020-02-09 16:47:26.430 debug (23152) ### handle state change heatingcontrol.0.Present {"val":true,"ack":false,"ts":1581263246427,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1581263036403}
    heatingcontrol.0 2020-02-09 16:45:35.976 debug (23152) system.adapter.admin.0: logging false
    heatingcontrol.0 2020-02-09 16:45:07.290 debug (23152) system.adapter.admin.0: logging true
    heatingcontrol.0 2020-02-09 16:43:56.411 debug (23152) ### state change already handled: true / true /// heatingcontrol.0.Present / heatingcontrol.0.Present
    heatingcontrol.0 2020-02-09 16:43:56.411 debug (23152) ### handle state change heatingcontrol.0.Present {"val":true,"ack":true,"ts":1581263036410,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1581263036403}
    heatingcontrol.0 2020-02-09 16:43:56.411 debug (23152) ### all StateChange handled
    heatingcontrol.0 2020-02-09 16:43:56.409 debug (23152) ### state change already handled: true / true /// heatingcontrol.0.Present / heatingcontrol.0.Present
    heatingcontrol.0 2020-02-09 16:43:56.409 debug (23152) ### handle state change heatingcontrol.0.Present {"val":true,"ack":true,"ts":1581263036407,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1581263036403}
    heatingcontrol.0 2020-02-09 16:43:56.409 debug (23152) ### heatingcontrol.0.Present true 1
    heatingcontrol.0 2020-02-09 16:43:56.407 debug (23152) ### handle state change heatingcontrol.0.Present {"val":true,"ack":false,"ts":1581263036403,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1581263036403}
    Rene_HMR Offline
    Rene_HMR Offline
    Rene_HM
    #841
    @MyMeyer zeige uns bitte mal, wie du im admin den present-Datenpunkt konfiguriert hast.
    Außerdem: wie sieht der Datenpunkt, den du abfragen willst, im Object-Tree aus?
    Ich denke, dass der Typ des present-Datentypes nicht passt (bool oder number)
    • Rene_HMR Rene_HM
      @Semie1 sagte in Test Adapter HeatingControl v0.3.x:
      Aber irgendwie läuft nix was mach ich falsch oder ha
      Was geht denn nicht? Die Konfiguration sieht soweit gut aus... hast du dann die Profile (z.Bsp. über die vis) entsprechend eingestellt?
      Semie1S Offline
      Semie1S Offline
      Semie1
      #842
      @Rene_HM
      das ist es ja weiß nicht genau was ich alles einstellen muss
      • W Offline
        W Offline
        webseb79
        #843
        ich benutze zur Zeit das Heizungsscript V2 und wie ich gelesen habe wird es nicht mehr gepflegt und weiter entwickelt.
        Ich habe als Hardware KNX Raumthermostate und Stellantriebe.
        Sind KNX Komponenten mit dem Adapter ansprechbar wie im Script und wenn nicht, ist es geplant die zu integrieren?
        Danke im voraus
        Sebastian
        P 1 Antwort Letzte Antwort
        • W webseb79
          Danke im voraus
          Sebastian
          Pittini
          #844
          @webseb79 sagte in Test Adapter HeatingControl v0.3.x:
          Danke im voraus
          Sebastian
          Alles was mit dem Skript funktioniert hat, sollte auch mit dem Adapter funktionieren. Die entsprechenden Datenpunkte sind ja offenbar vorhanden, sonst liefe ja das Script nicht. Kannst doch einfach mal das Skript stoppen und den Adapter mit einem Raum testen, nicht so zaghaft ;).
          W 1 Antwort Letzte Antwort
          • Rene_HMR Rene_HM
            MyMeyer
            schrieb am zuletzt editiert von MyMeyer
            #845
            @Rene_HM
            1x
            und noch eins...
            MyMeyer
            >>> Hardware: Intel I5 mit ****Debian ProxMox OS: Debian **** <<< >>> Network with UniFi <<<
            >>> HomeMatic CCU-2 (Wired und Funk) / Philips HUE / Echo.DOT / Echo.SHOW / Xiaomi Smart-Home / Xiaomi Robot Vacuum Cleaner / Synology DS 918+ / Shelly 1&2 <<<
            • M MyMeyer
              @Rene_HM
              1x
              und noch eins...
              Pittini
              #846
              @MyMeyer Nein nein nein, das wird so sicher in die Hose gehen. Du baust Zirkelbezüge auf. Die ganzen Datenpunkte dürfen nicht auf die Adapterdatenpunkte verweisen, sondern auf Deine oder leer lassen. So z.B.:
              Und im Raw sollteste mal schon gar nix ändern. Ich empfehle dringend rtfm hier
              • P Pittini
                Danke im voraus
                Sebastian
                W Offline
                W Offline
                webseb79
                #847
                @Pittini
                hab auf dich gehört und war mal mutig.
                Installation lief ohne Probleme durch.
                Einstellungen sind ähnlich dem Script...also auch einfach zu handhaben.
                Profil ist angelegt und reagiert auf Änderung der Zeit und der Temperatur.
                Sollwert wird auch zum Thermostat übertragen.
                Sensoren der Fenster (KNX) sind auch angelegt und der Fensterstatus reagiert auch auf Änderung.
                Nun zum Problem... WindowIsOpen Status geht auf true aber die Solltemperatur am Thermostat ändert sich nicht.
                Man kann ja keine Temperaturabsenkung in Grad einstellen, nur relativ , absolut und kein absenken. Was hat das zu bedeuten?
                Ansonsten kann ich nur sagen das es top Arbeit ist.
                Sebastian
                Rene_HMR 1 Antwort Letzte Antwort
                • W webseb79
                  @Pittini
                  Sebastian
                  Rene_HMR Offline
                  Rene_HMR Offline
                  Rene_HM
                  schrieb am zuletzt editiert von Rene_HM
                  #848
                  Das ist nur die Voreinstellung. Die absolute oder relative Absenkung findest du im Object-Baum, wo du auch das Profil eingestellt hast...
                  • W Offline
                    W Offline
                    webseb79
                    #849
                    Danke.
                    Ich habe es gerade auch gesehen, blind wie ich bin.
                    • W Offline
                      W Offline
                      webseb79
                      #850
                      Kannst du mir noch den Unterschied von absolut und relativ absenken erklären?
                      Ich verstehe das so...ich habe einen Sollwert von 18 Grad und bei 7Grad absolut hätte ich 7 Grad Sollwert erwartet und bei 7Grad relativ 11 Grad.
                      Bei absolut zeigt er mir aber 10 Grad an und relativ 11Grad die passen.
                      Gibt es da eine Untergrenze?
                      • W webseb79
                        Rene_HMR Offline
                        Rene_HMR Offline
                        Rene_HM
                        #851
                        Ja, als Option einstellbar im Admin. Die Mindesttemperatur ist dann wieder im Profil pro Raum.... Wenn man diese Option ausschaltet, arbeitet der Adapter genau wie du oben beschrieben hast.
                        • V Offline
                          V Offline
                          Voltage
                          #852
                          Mahlzeit.
                          Ich habe jetzt soweit die Profile am laufen, ebenfalls die Temperaturabsenkung mittels diverser Fenstersensoren.
                          Wie bekomme ich es denn jetzt hin, dass mein Homematic Thermostat die Ist-Temperatur meines Xiaomi-Temp-Sensors übernimmt, sprich so lange heizt bis dort die gefoderte Temperatur ansteht?
                          Ich habe gedacht, dass es so funktionieren wird:
                          Ich habe diverse Wege ausprobiert, denke selbst wenn es durch Zufall dann mal klappt wäre es besser ich würde einfach verstehen was ich tue. Hat jemand die STeuerung über ein externen Temperaturfühler bei sich am laufen?
                          Z 1 Antwort Letzte Antwort
                          • V Voltage
                            Mahlzeit.
                            Z Offline
                            Z Offline
                            zahnheinrich
                            #853
                            @Voltage
                            Sollte so gehen.
                            Thermostate aber auf manuell einstellen, nicht auf auto
                            MfG Ulrich
                            V 1 Antwort Letzte Antwort
                            • Z zahnheinrich
                              @Voltage
                              Sollte so gehen.
                              V Offline
                              V Offline
                              Voltage
                              schrieb am zuletzt editiert von Voltage
                              #854
                              @zahnheinrich
                              Hey. Danke für die Antwort. Ich habe es noch weiter probiert, hänge mal noch ne Menge Fotos an die evtl auch so dem ein oder anderem helfen könnten und damit hier jemand meinen Fehler besser finden kann.
                              Problem ist, dass das Homematic Thermostat voll aufdreht - siehe Bilder.
                              Hier steht unter OID-Zielwert "hm-rpc.2.000A1709A64373.1.SET_POINT_TEMPERATURE". Den anderen Wert kann man komplett ablesen
                              Na die Reihenfolge der Bilder ist jetzt nicht so toll, sorry. Auf jedenfall sieht man, dass er die 22,5 Grad weiter gibt, aber trotz das am Sensor 22,73 Grad sind voll aufdreht.
                              • V Voltage
                                @zahnheinrich
                                Z Offline
                                Z Offline
                                zahnheinrich
                                schrieb am zuletzt editiert von zahnheinrich
                                #855
                                @Voltage
                                Ich habe den Adapter so verstanden:
                                Für ein und den selben Regler steht nie was unter Thermostat UND Aktor/ Sensor.
                                Ich würde den Eintrag unter Thermostat löschen, da du zwei getrennte Geräte als Sensor und Aktor benutzt.
                                Edit: Kommando zurück! Du musst den Sensor/Aktor löschen, den Thermostate so lassen.
                                Der Aktor steuert nur einen abgesetzten Aktor mit on/off. Daher auch die volle Ventilöffnung.
                                MfG Ulrich
                                Rene_HMR V 2 Antworten Letzte Antwort
                                • P Pittini
                                  MyMeyer
                                  #856
                                  @Pittini Jau .. :-) Das war es ...jetzt läuft es korrekt .Fehler gefunden prima :+1:
                                  MyMeyer
                                  • Z zahnheinrich
                                    @Voltage
                                    Rene_HMR Offline
                                    Rene_HMR Offline
                                    Rene_HM
                                    #857
                                    @zahnheinrich sagte in Test Adapter HeatingControl v0.3.x:
                                    so ist es richtig...
                                    • J Offline
                                      Jens Lattwesen
                                      #858
                                      Moin,
                                      Frage zu den Profilen: Es gibt 3 Möglichkeiten.
                                      Wie lege ich es am besten an, wenn ich bspw. für 1 Raum (Mo-Fr, Sa-So) brauchen, für einen anderen aber jeden Tage getrennt?
                                      Weiter noch die Frage, wie ich es anstelle, dass ich einen Raum lediglich nach Anwesenheit steuere?
                                      Thx
                                      • Rene_HMR Rene_HM
                                        @iobroker_Alex sagte in Adapter: HeatingControl:
                                        Hallo nochmal,
                                        ich habe noch ein paar Fragen und Anregungen:
                                        1. Wo wird der Datenpunkt zu den Feiertagen abgebildet?
                                          Ist es einer von diesen:
                                          heatingcontrol.0.PublicHolidyToday
                                          heatingcontrol.0.HolidayPresent
                                        heatingcontrol.0.PublicHolidyToday sagt, dass heute Feiertag ist. Der Wert kann von einem externen Adapter oder script autoamtisch belegt werden, wenn im admin der Pfad entweder zum Feiertags-Adapter oder zu einem anderen beliebigen Datenpunkt konfiguriert wird.
                                        heatingcontrol.0.HolidayPresent und heatingcontrol.0.Present sagen, dass keine Absenkung wegen Abwesenheit erfolgen sollen.
                                        Ich vermute es ist der PublicHoliday?! Wenn ja funktioniert es bei mir nicht. Mein Datenpunkt ist true und der PublicHoliday Datenpunkt ist false.
                                        Ich gehe davon aus, dass du deinen Datenpunkt im admin entsprechen konfigurier hast. Wenn du dann den Adapter im debug-Modus betreibst, solltest du ein log bekommen, dass genau dieser Datenpunkt "subscribed" ist. Wenn du dann den Datenpunkt toggelst, solltest du ebenfalls ein entsprechendes log bekommen. Ich schau mir das auch noch mal an... -> Der Wert wird in der aktuellen Version nicht übernommen...
                                        hier noch das issue im github
                                        https://github.com/rg-engineering/ioBroker.heatingcontrol/issues/18
                                        Wozu sind die anderen beiden Datenpunkte?
                                        1. Sehe ich es richtig, dass sich die Soll-Temperatur-Datenpunkte "bis" zu der angegeben Zeit beziehen? In meinem Beispiel habe ich nur 3 Perioden: 0 = 5 Uhr ; 1 = 8 Uhr und 2 = 12 Uhr. Es ist jetzt 16:23 Uhr und er zeigt mir im Datenpunkt CurrentTimePeriod an, dass Period 2 =12 Uhr zieht. Müsste hier nicht Period 0 des nächsten Tages ziehen oder wie ist die Logik?
                                        ja, dafür gibt es schon ein issue im github. Die Idee ist, dass man einen Zeitpunkt eingibt, ab dem die neue Temperatur gilt. Damit muss die Beschreibung nicht "bis" heißen sondern "ab". Das ändere ich noch...
                                        1. Wäre es möglich zwei Datenpunkte je Raum anzulegen in der man eine manuelle Temperatur für eine definierte Zeit einstellen kann?
                                        Ich wollte einen Datenpunkt einbauen, mit dem man einen manuelle Solltemperatur setzen kann. Das wäre dann bis zur nächsten "period" gültig. Einen Zeitraum anzugeben, wie lange die manuelle Temperatur gültig sein soll, ist schwieriger umzusetzen, (aber möglich). Ich mache dazu ein issue im github...
                                        https://github.com/rg-engineering/ioBroker.heatingcontrol/issues/15
                                        1. Wäre es möglich einen Datenpunkt je Raum anzulegen, der die Darstellung des aktuellen Parameters der die Temperatur beeinflusst z.B. Urlaub / Gäste / Fenster auf etc. anzeigt? So könnte man sehen warum er in dem Raum nicht die zeitliche "Soll-Temperatur" nimmt, sondern z.B. eine Absenkung vorgenommen hat...
                                        ja, habe ebenfalls ein issue angelegt:
                                        https://github.com/rg-engineering/ioBroker.heatingcontrol/issues/16
                                        Jens Lattwesen
                                        #859
                                        @Rene_HM
                                        Wie genau konfiguriere ich den Pfad (syntaxtechnisch?)
                                        • J Jens Lattwesen
                                          Moin,
                                          Thx
                                          Pittini
                                          #860
                                          @Jens-Lattwesen sagte in Test Adapter HeatingControl v0.3.x:
                                          Den kleinsten gemeinsamen Nenner nehmen, also jeden Tag getrennt. Könnte auch mit ner 2ten Instanz gehen aber da soll @Rene_HM was zu sagen.
                                          Das wiederum ist relativ easy. Alle Temps auf den gleichen Wert und dann über die Anwesenheit die Erhöhung/Verminderung einstellen. Oder mit nem 2ten Profil.
                                          J Rene_HMR 4 Antworten Letzte Antwort
                                          32.6k
                                          82.1k
