    1.0k
    6.1k
7.5k Beiträge 335 Kommentatoren 11.5m Aufrufe 254 Beobachtet
  • L lonsimbt
    @simatec
    Mit der 0.8.3 sind meine Rollläden heute abend nicht runtergefahren. Im LOG findet sich folgender Fehler:
    2020-07-06 22:00:00.001 - debug: shuttercontrol.0 (23873) calculate astrodata ...
    2020-07-06 22:00:00.002 - debug: shuttercontrol.0 (23873) Sun Azimut: 311.5°
    2020-07-06 22:00:00.002 - debug: shuttercontrol.0 (23873) Sun Elevation: -2.1°
    2020-07-06 22:00:00.011 - debug: shuttercontrol.0 (23873) we are in summer time
    2020-07-06 22:00:00.016 - error: shuttercontrol.0 (23873) uncaught exception: Cannot read property 'error' of undefined
    2020-07-06 22:00:00.016 - error: shuttercontrol.0 (23873) TypeError: Cannot read property 'error' of undefined
    at IsSummerTime (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/isSummerTime.js:40:21)
    at IsSummerTime (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/isSummerTime.js:42:5)
    at Job.job (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/shutterDownLiving.js:51:21)
    at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/schedule.js:173:10)
    at /opt/iobroker/node_modules/node-schedule/lib/schedule.js:552:11
    at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/schedule.js:510:7)
    at listOnTimeout (internal/timers.js:549:17)
    at processTimers (internal/timers.js:492:7)
    2020-07-06 22:00:00.016 - info: shuttercontrol.0 (23873) cleaned everything up...
    2020-07-06 22:00:00.039 - info: shuttercontrol.0 (23873) terminating
    2020-07-06 22:00:00.041 - debug: shuttercontrol.0 (23873) Plugin sentry destroyed
    2020-07-06 22:00:00.041 - info: shuttercontrol.0 (23873) Terminated (NO_ERROR): Without reason
    2020-07-06 22:00:00.491 - error: host.iobroker Caught by controller[0]: TypeError: Cannot read property 'error' of undefined
    2020-07-06 22:00:00.491 - error: host.iobroker Caught by controller[0]: at IsSummerTime (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/isSummerTime.js:40:21)
    2020-07-06 22:00:00.491 - error: host.iobroker Caught by controller[0]: at IsSummerTime (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/isSummerTime.js:42:5)
    2020-07-06 22:00:00.491 - error: host.iobroker Caught by controller[0]: at Job.job (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/shutterDownLiving.js:51:21)
    2020-07-06 22:00:00.492 - error: host.iobroker Caught by controller[0]: at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/schedule.js:173:10)
    2020-07-06 22:00:00.492 - error: host.iobroker Caught by controller[0]: at /opt/iobroker/node_modules/node-schedule/lib/schedule.js:552:11
    2020-07-06 22:00:00.492 - error: host.iobroker Caught by controller[0]: at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/schedule.js:510:7)
    2020-07-06 22:00:00.492 - error: host.iobroker Caught by controller[0]: at listOnTimeout (internal/timers.js:549:17)
    2020-07-06 22:00:00.492 - error: host.iobroker Caught by controller[0]: at processTimers (internal/timers.js:492:7)
    2020-07-06 22:00:00.492 - error: host.iobroker instance system.adapter.shuttercontrol.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    Gruß Marco
    simatecS Online
    simatecS Online
    simatec
    #2161
    @lonsimbt
    Die 0.8.3 ist auch noch nicht offiziell und hat noch Bugs.
    Bitte folgt dem Rat und installiert nur nach Aufforderung vom GitHub
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    • J Ja.rod
      Hallos zusammen,
      Seht ihr eine Möglichkeit das Fahren von zwei bestimmten Rollos kurzzeitig zu blockieren? Die beiden Rollos im Wohnzimmer sollen zwar immer regulär nach unten fahren, manchmal möchten wir aber trotzdem, dass sie für genau diesen Abend oben bleiben und später von uns manuell nach unten gefahren werden. Ist praktisch ähnlich wie die Aussperrfunktion, die ich schon dafür nutze, finde ich aber nicht optimal.
      Ja.rod
      Ja.rod
      #2162
      Ich möchte es nochmal aufgreifen, hat jemand eine Idee wie ich das lösen könnte?
      @Ja-rod sagte in Test Adapter shuttercontrol v0.8.x:
      Hallos zusammen,
      Ja.rod
      • coyoteC coyote
        @LJSven Hm ok, dann wäre vllt mal noch ein Log ganz hilfreich. Meine fahren mit den Einstellungen ohne Probleme hoch/runter und auch in den Sonnenschutz.
        LJSven
        #2163
        @coyote sagte in Test Adapter shuttercontrol v0.8.x:
        Hier ist der Lock - wie man sieht wurde heute morgen um 07:13 Uhr bei "autoLIVING" von false auf true gestellt - im Log taucht das aber nicht auf, was mich vermuten lässt, daß der Wert nicht überprüft wird?!
        shuttercontrol.0	2020-07-07 07:17:42.163	debug	(28378) insidetemperature changed: linkeddevices.0.Temperatur.EG.EG_Whz_Temperatur.temperature Value: 23.66
        shuttercontrol.0	2020-07-07 07:15:00.017	debug	(28378) Sun Elevation: 14.3°
        shuttercontrol.0	2020-07-07 07:15:00.016	debug	(28378) Sun Azimut: 71.5°
        shuttercontrol.0	2020-07-07 07:15:00.015	debug	(28378) calculate astrodata ...
        shuttercontrol.0	2020-07-07 07:13:56.999	debug	(28378) late down at 22:15
        shuttercontrol.0	2020-07-07 07:13:56.997	debug	(28378) Shutdown shutters sleep area: 20:00 debug 6
        shuttercontrol.0	2020-07-07 07:13:56.995	debug	(28378) shutterDownLiving
        shuttercontrol.0	2020-07-07 07:13:56.994	debug	(28378) Shutdown shutters living area: 22:23 debug 7
        shuttercontrol.0	2020-07-07 07:13:56.994	debug	(28378) yes, IsEarlier : 22:23 22:30
        shuttercontrol.0	2020-07-07 07:13:56.993	debug	(28378) check IsEarlier : 22:23 22:30
        shuttercontrol.0	2020-07-07 07:13:56.993	debug	(28378) check IsLater : 22:23 22:30
        shuttercontrol.0	2020-07-07 07:13:56.991	debug	(28378) Starting up shutters sleep area: 06:00 debug 8
        shuttercontrol.0	2020-07-07 07:13:56.990	debug	(28378) yes, IsEarlier : 05:27 06:00
        shuttercontrol.0	2020-07-07 07:13:56.990	debug	(28378) check IsEarlier : 05:27 06:00
        shuttercontrol.0	2020-07-07 07:13:56.990	debug	(28378) check IsEqual : 05:27 09:30
        shuttercontrol.0	2020-07-07 07:13:56.989	debug	(28378) check IsEqual : 06:00 09:30
        shuttercontrol.0	2020-07-07 07:13:56.989	debug	(28378) check IsLater : 05:27 06:00
        shuttercontrol.0	2020-07-07 07:13:56.989	debug	(28378) check IsLater : 05:27 09:30
        shuttercontrol.0	2020-07-07 07:13:56.985	debug	(28378) Starting up shutters living area: 06:30 debug 8
        shuttercontrol.0	2020-07-07 07:13:56.984	debug	(28378) yes, IsEarlier : 05:27 06:30
        shuttercontrol.0	2020-07-07 07:13:56.984	debug	(28378) check IsEarlier : 05:27 06:30
        shuttercontrol.0	2020-07-07 07:13:56.984	debug	(28378) check IsEqual : 05:27 09:00
        shuttercontrol.0	2020-07-07 07:13:56.984	debug	(28378) check IsEqual : 06:30 09:00
        shuttercontrol.0	2020-07-07 07:13:56.983	debug	(28378) check IsLater : 05:27 06:30
        shuttercontrol.0	2020-07-07 07:13:56.983	debug	(28378) check IsLater : 05:27 09:00
        shuttercontrol.0	2020-07-07 07:13:56.972	debug	(28378) Shutdown shutters Sunset area: 22:23
        shuttercontrol.0	2020-07-07 07:13:56.971	debug	(28378) Starting up shutters Sunrise area: 05:27
        shuttercontrol.0	2020-07-07 07:13:56.971	debug	(28378) Shutdown shutters GoldenHour area: 21:29
        shuttercontrol.0	2020-07-07 07:13:56.971	debug	(28378) Starting up shutters GoldenHour area: 06:21
        shuttercontrol.0	2020-07-07 07:13:56.970	debug	(28378) Sunset today: 21:53
        shuttercontrol.0	2020-07-07 07:13:56.969	debug	(28378) Sunrise today: 05:22
        shuttercontrol.0	2020-07-07 07:13:56.969	debug	(28378) current day: 2
        shuttercontrol.0	2020-07-07 07:13:56.968	debug	(28378) goldenHour today: 20:59
        shuttercontrol.0	2020-07-07 07:13:56.967	debug	(28378) goldenHourEnd today: 06:16
        shuttercontrol.0	2020-07-07 07:13:56.966	debug	(28378) calculate astrodata ...
        shuttercontrol.0	2020-07-07 07:13:56.966	debug	(28378) shutterDriveCalc
        shuttercontrol.0	2020-07-07 07:13:56.960	debug	(28378) Auto Living is: true
        shuttercontrol.0	2020-07-07 07:13:44.015	debug	(28378) late down at 22:15
        shuttercontrol.0	2020-07-07 07:13:44.013	debug	(28378) Shutdown shutters sleep area: 20:00 debug 6
        shuttercontrol.0	2020-07-07 07:13:44.010	debug	(28378) shutterDownLiving
        shuttercontrol.0	2020-07-07 07:13:44.009	debug	(28378) Shutdown shutters living area: 22:23 debug 7
        shuttercontrol.0	2020-07-07 07:13:44.008	debug	(28378) yes, IsEarlier : 22:23 22:30
        shuttercontrol.0	2020-07-07 07:13:44.008	debug	(28378) check IsEarlier : 22:23 22:30
        shuttercontrol.0	2020-07-07 07:13:44.007	debug	(28378) check IsLater : 22:23 22:30
        shuttercontrol.0	2020-07-07 07:13:44.005	debug	(28378) Starting up shutters sleep area: 06:00 debug 8
        shuttercontrol.0	2020-07-07 07:13:44.004	debug	(28378) yes, IsEarlier : 05:27 06:00
        shuttercontrol.0	2020-07-07 07:13:44.003	debug	(28378) check IsEarlier : 05:27 06:00
        shuttercontrol.0	2020-07-07 07:13:44.003	debug	(28378) check IsEqual : 05:27 09:30
        shuttercontrol.0	2020-07-07 07:13:44.003	debug	(28378) check IsEqual : 06:00 09:30
        shuttercontrol.0	2020-07-07 07:13:44.002	debug	(28378) check IsLater : 05:27 06:00
        shuttercontrol.0	2020-07-07 07:13:44.001	debug	(28378) check IsLater : 05:27 09:30
        shuttercontrol.0	2020-07-07 07:13:43.998	debug	(28378) Starting up shutters living area: 06:30 debug 8
        shuttercontrol.0	2020-07-07 07:13:43.997	debug	(28378) yes, IsEarlier : 05:27 06:30
        shuttercontrol.0	2020-07-07 07:13:43.996	debug	(28378) check IsEarlier : 05:27 06:30
        shuttercontrol.0	2020-07-07 07:13:43.996	debug	(28378) check IsEqual : 05:27 09:00
        shuttercontrol.0	2020-07-07 07:13:43.996	debug	(28378) check IsEqual : 06:30 09:00
        shuttercontrol.0	2020-07-07 07:13:43.995	debug	(28378) check IsLater : 05:27 06:30
        shuttercontrol.0	2020-07-07 07:13:43.994	debug	(28378) check IsLater : 05:27 09:00
        shuttercontrol.0	2020-07-07 07:13:43.981	debug	(28378) Shutdown shutters Sunset area: 22:23
        shuttercontrol.0	2020-07-07 07:13:43.981	debug	(28378) Starting up shutters Sunrise area: 05:27
        shuttercontrol.0	2020-07-07 07:13:43.980	debug	(28378) Shutdown shutters GoldenHour area: 21:29
        shuttercontrol.0	2020-07-07 07:13:43.980	debug	(28378) Starting up shutters GoldenHour area: 06:21
        shuttercontrol.0	2020-07-07 07:13:43.979	debug	(28378) Sunset today: 21:53
        shuttercontrol.0	2020-07-07 07:13:43.978	debug	(28378) Sunrise today: 05:22
        shuttercontrol.0	2020-07-07 07:13:43.977	debug	(28378) current day: 2
        shuttercontrol.0	2020-07-07 07:13:43.976	debug	(28378) goldenHour today: 20:59
        shuttercontrol.0	2020-07-07 07:13:43.976	debug	(28378) goldenHourEnd today: 06:16
        shuttercontrol.0	2020-07-07 07:13:43.975	debug	(28378) calculate astrodata ...
        shuttercontrol.0	2020-07-07 07:13:43.974	debug	(28378) shutterDriveCalc
        shuttercontrol.0	2020-07-07 07:13:43.969	debug	(28378) Auto Living is: false
        shuttercontrol.0	2020-07-07 07:13:33.622	debug	(28378) late down at 22:15
        shuttercontrol.0	2020-07-07 07:13:33.619	debug	(28378) Shutdown shutters sleep area: 20:00 debug 6
        shuttercontrol.0	2020-07-07 07:13:33.603	debug	(28378) shutterDownLiving
        shuttercontrol.0	2020-07-07 07:13:33.602	debug	(28378) Shutdown shutters living area: 22:23 debug 7
        shuttercontrol.0	2020-07-07 07:13:33.601	debug	(28378) yes, IsEarlier : 22:23 22:30
        shuttercontrol.0	2020-07-07 07:13:33.600	debug	(28378) check IsEarlier : 22:23 22:30
        shuttercontrol.0	2020-07-07 07:13:33.599	debug	(28378) check IsLater : 22:23 22:30
        shuttercontrol.0	2020-07-07 07:13:33.595	debug	(28378) Starting up shutters sleep area: 06:00 debug 8
        shuttercontrol.0	2020-07-07 07:13:33.593	debug	(28378) yes, IsEarlier : 05:27 06:00
        shuttercontrol.0	2020-07-07 07:13:33.593	debug	(28378) check IsEarlier : 05:27 06:00
        shuttercontrol.0	2020-07-07 07:13:33.592	debug	(28378) check IsEqual : 05:27 09:30
        shuttercontrol.0	2020-07-07 07:13:33.592	debug	(28378) check IsEqual : 06:00 09:30
        shuttercontrol.0	2020-07-07 07:13:33.591	debug	(28378) check IsLater : 05:27 06:00
        shuttercontrol.0	2020-07-07 07:13:33.590	debug	(28378) check IsLater : 05:27 09:30
        shuttercontrol.0	2020-07-07 07:13:33.577	debug	(28378) Starting up shutters living area: 06:30 debug 8
        shuttercontrol.0	2020-07-07 07:13:33.576	debug	(28378) yes, IsEarlier : 05:27 06:30
        shuttercontrol.0	2020-07-07 07:13:33.575	debug	(28378) check IsEarlier : 05:27 06:30
        shuttercontrol.0	2020-07-07 07:13:33.575	debug	(28378) check IsEqual : 05:27 09:00
        shuttercontrol.0	2020-07-07 07:13:33.573	debug	(28378) check IsEqual : 06:30 09:00
        shuttercontrol.0	2020-07-07 07:13:33.572	debug	(28378) check IsLater : 05:27 06:30
        shuttercontrol.0	2020-07-07 07:13:33.571	debug	(28378) check IsLater : 05:27 09:00
        shuttercontrol.0	2020-07-07 07:13:33.545	debug	(28378) Shutdown shutters Sunset area: 22:23
        shuttercontrol.0	2020-07-07 07:13:33.544	debug	(28378) Starting up shutters Sunrise area: 05:27
        shuttercontrol.0	2020-07-07 07:13:33.543	debug	(28378) Shutdown shutters GoldenHour area: 21:29
        shuttercontrol.0	2020-07-07 07:13:33.543	debug	(28378) Starting up shutters GoldenHour area: 06:21
        shuttercontrol.0	2020-07-07 07:13:33.541	debug	(28378) Sunset today: 21:53
        shuttercontrol.0	2020-07-07 07:13:33.540	debug	(28378) Sunrise today: 05:22
        shuttercontrol.0	2020-07-07 07:13:33.538	debug	(28378) current day: 2
        shuttercontrol.0	2020-07-07 07:13:33.536	debug	(28378) goldenHour today: 20:59
        shuttercontrol.0	2020-07-07 07:13:33.535	debug	(28378) goldenHourEnd today: 06:16
        shuttercontrol.0	2020-07-07 07:13:33.534	debug	(28378) calculate astrodata ...
        shuttercontrol.0	2020-07-07 07:13:33.532	debug	(28378) shutterDriveCalc
        shuttercontrol.0	2020-07-07 07:12:40.938	debug	(28378) system.adapter.admin.0: logging true
        shuttercontrol.0	2020-07-07 07:12:31.740	debug	(28378) system.adapter.admin.0: logging false
        shuttercontrol.0	2020-07-07 07:11:11.929	debug	(28378) late down at 22:15
        shuttercontrol.0	2020-07-07 07:11:11.925	debug	(28378) Shutdown shutters sleep area: 20:00 debug 6
        shuttercontrol.0	2020-07-07 07:11:11.920	debug	(28378) shutterDownLiving
        shuttercontrol.0	2020-07-07 07:11:11.919	debug	(28378) Shutdown shutters living area: 22:23 debug 7
        shuttercontrol.0	2020-07-07 07:11:11.918	debug	(28378) yes, IsEarlier : 22:23 22:30
        shuttercontrol.0	2020-07-07 07:11:11.918	debug	(28378) check IsEarlier : 22:23 22:30
        shuttercontrol.0	2020-07-07 07:11:11.917	debug	(28378) check IsLater : 22:23 22:30
        shuttercontrol.0	2020-07-07 07:11:11.913	debug	(28378) Starting up shutters sleep area: 06:00 debug 8
        shuttercontrol.0	2020-07-07 07:11:11.912	debug	(28378) yes, IsEarlier : 05:27 06:00
        shuttercontrol.0	2020-07-07 07:11:11.911	debug	(28378) check IsEarlier : 05:27 06:00
        shuttercontrol.0	2020-07-07 07:11:11.911	debug	(28378) check IsEqual : 05:27 09:30
        shuttercontrol.0	2020-07-07 07:11:11.910	debug	(28378) check IsEqual : 06:00 09:30
        shuttercontrol.0	2020-07-07 07:11:11.910	debug	(28378) check IsLater : 05:27 06:00
        shuttercontrol.0	2020-07-07 07:11:11.909	debug	(28378) check IsLater : 05:27 09:30
        shuttercontrol.0	2020-07-07 07:11:11.900	debug	(28378) Starting up shutters living area: 06:30 debug 8
        shuttercontrol.0	2020-07-07 07:11:11.899	debug	(28378) yes, IsEarlier : 05:27 06:30
        shuttercontrol.0	2020-07-07 07:11:11.898	debug	(28378) check IsEarlier : 05:27 06:30
        shuttercontrol.0	2020-07-07 07:11:11.897	debug	(28378) check IsEqual : 05:27 09:00
        shuttercontrol.0	2020-07-07 07:11:11.895	debug	(28378) check IsEqual : 06:30 09:00
        shuttercontrol.0	2020-07-07 07:11:11.894	debug	(28378) check IsLater : 05:27 06:30
        shuttercontrol.0	2020-07-07 07:11:11.893	debug	(28378) check IsLater : 05:27 09:00
        shuttercontrol.0	2020-07-07 07:11:11.868	debug	(28378) Shutdown shutters Sunset area: 22:23
        shuttercontrol.0	2020-07-07 07:11:11.867	debug	(28378) Starting up shutters Sunrise area: 05:27
        shuttercontrol.0	2020-07-07 07:11:11.866	debug	(28378) Shutdown shutters GoldenHour area: 21:29
        shuttercontrol.0	2020-07-07 07:11:11.865	debug	(28378) Starting up shutters GoldenHour area: 06:21
        shuttercontrol.0	2020-07-07 07:11:11.863	debug	(28378) Sunset today: 21:53
        shuttercontrol.0	2020-07-07 07:11:11.862	debug	(28378) Sunrise today: 05:22
        shuttercontrol.0	2020-07-07 07:11:11.861	debug	(28378) current day: 2
        shuttercontrol.0	2020-07-07 07:11:11.860	debug	(28378) goldenHour today: 20:59
        shuttercontrol.0	2020-07-07 07:11:11.858	debug	(28378) goldenHourEnd today: 06:16
        shuttercontrol.0	2020-07-07 07:11:11.858	debug	(28378) calculate astrodata ...
        shuttercontrol.0	2020-07-07 07:11:11.856	debug	(28378) shutterDriveCalc
        shuttercontrol.0	2020-07-07 07:11:11.846	debug	(28378) Auto Living is: true
        shuttercontrol.0	2020-07-07 07:10:19.307	debug	(28378) late down at 22:15
        shuttercontrol.0	2020-07-07 07:10:19.304	debug	(28378) Shutdown shutters sleep area: 20:00 debug 6
        shuttercontrol.0	2020-07-07 07:10:19.298	debug	(28378) shutterDownLiving
        shuttercontrol.0	2020-07-07 07:10:19.298	debug	(28378) Shutdown shutters living area: 22:23 debug 7
        shuttercontrol.0	2020-07-07 07:10:19.297	debug	(28378) yes, IsEarlier : 22:23 22:30
        shuttercontrol.0	2020-07-07 07:10:19.297	debug	(28378) check IsEarlier : 22:23 22:30
        shuttercontrol.0	2020-07-07 07:10:19.296	debug	(28378) check IsLater : 22:23 22:30
        shuttercontrol.0	2020-07-07 07:10:19.291	debug	(28378) Starting up shutters sleep area: 06:00 debug 8
        shuttercontrol.0	2020-07-07 07:10:19.291	debug	(28378) yes, IsEarlier : 05:27 06:00
        shuttercontrol.0	2020-07-07 07:10:19.290	debug	(28378) check IsEarlier : 05:27 06:00
        shuttercontrol.0	2020-07-07 07:10:19.289	debug	(28378) check IsEqual : 05:27 09:30
        shuttercontrol.0	2020-07-07 07:10:19.289	debug	(28378) check IsEqual : 06:00 09:30
        shuttercontrol.0	2020-07-07 07:10:19.288	debug	(28378) check IsLater : 05:27 06:00
        shuttercontrol.0	2020-07-07 07:10:19.288	debug	(28378) check IsLater : 05:27 09:30
        shuttercontrol.0	2020-07-07 07:10:19.282	debug	(28378) Starting up shutters living area: 06:30 debug 8
        shuttercontrol.0	2020-07-07 07:10:19.281	debug	(28378) yes, IsEarlier : 05:27 06:30
        shuttercontrol.0	2020-07-07 07:10:19.280	debug	(28378) check IsEarlier : 05:27 06:30
        shuttercontrol.0	2020-07-07 07:10:19.280	debug	(28378) check IsEqual : 05:27 09:00
        shuttercontrol.0	2020-07-07 07:10:19.279	debug	(28378) check IsEqual : 06:30 09:00
        shuttercontrol.0	2020-07-07 07:10:19.279	debug	(28378) check IsLater : 05:27 06:30
        shuttercontrol.0	2020-07-07 07:10:19.278	debug	(28378) check IsLater : 05:27 09:00
        shuttercontrol.0	2020-07-07 07:10:19.253	debug	(28378) Shutdown shutters Sunset area: 22:23
        shuttercontrol.0	2020-07-07 07:10:19.252	debug	(28378) Starting up shutters Sunrise area: 05:27
        shuttercontrol.0	2020-07-07 07:10:19.252	debug	(28378) Shutdown shutters GoldenHour area: 21:29
        shuttercontrol.0	2020-07-07 07:10:19.251	debug	(28378) Starting up shutters GoldenHour area: 06:21
        shuttercontrol.0	2020-07-07 07:10:19.250	debug	(28378) Sunset today: 21:53
        shuttercontrol.0	2020-07-07 07:10:19.249	debug	(28378) Sunrise today: 05:22
        shuttercontrol.0	2020-07-07 07:10:19.249	debug	(28378) current day: 2
        shuttercontrol.0	2020-07-07 07:10:19.248	debug	(28378) goldenHour today: 20:59
        shuttercontrol.0	2020-07-07 07:10:19.247	debug	(28378) goldenHourEnd today: 06:16
        shuttercontrol.0	2020-07-07 07:10:19.246	debug	(28378) calculate astrodata ...
        shuttercontrol.0	2020-07-07 07:10:19.244	debug	(28378) shutterDriveCalc
        shuttercontrol.0	2020-07-07 07:10:19.237	debug	(28378) Auto Living is: false
        shuttercontrol.0	2020-07-07 07:10:05.487	debug	(28378) late down at 22:15
        shuttercontrol.0	2020-07-07 07:10:05.483	debug	(28378) Shutdown shutters sleep area: 20:00 debug 6
        shuttercontrol.0	2020-07-07 07:10:05.477	debug	(28378) shutterDownLiving
        shuttercontrol.0	2020-07-07 07:10:05.476	debug	(28378) Shutdown shutters living area: 22:23 debug 7
        shuttercontrol.0	2020-07-07 07:10:05.475	debug	(28378) yes, IsEarlier : 22:23 22:30
        shuttercontrol.0	2020-07-07 07:10:05.474	debug	(28378) check IsEarlier : 22:23 22:30
        shuttercontrol.0	2020-07-07 07:10:05.473	debug	(28378) check IsLater : 22:23 22:30
        shuttercontrol.0	2020-07-07 07:10:05.469	debug	(28378) Starting up shutters sleep area: 06:00 debug 8
        shuttercontrol.0	2020-07-07 07:10:05.468	debug	(28378) yes, IsEarlier : 05:27 06:00
        shuttercontrol.0	2020-07-07 07:10:05.467	debug	(28378) check IsEarlier : 05:27 06:00
        shuttercontrol.0	2020-07-07 07:10:05.467	debug	(28378) check IsEqual : 05:27 09:30
        shuttercontrol.0	2020-07-07 07:10:05.466	debug	(28378) check IsEqual : 06:00 09:30
        shuttercontrol.0	2020-07-07 07:10:05.465	debug	(28378) check IsLater : 05:27 06:00
        shuttercontrol.0	2020-07-07 07:10:05.464	debug	(28378) check IsLater : 05:27 09:30
        shuttercontrol.0	2020-07-07 07:10:05.455	debug	(28378) Starting up shutters living area: 06:30 debug 8
        shuttercontrol.0	2020-07-07 07:10:05.454	debug	(28378) yes, IsEarlier : 05:27 06:30
        shuttercontrol.0	2020-07-07 07:10:05.453	debug	(28378) check IsEarlier : 05:27 06:30
        shuttercontrol.0	2020-07-07 07:10:05.452	debug	(28378) check IsEqual : 05:27 09:00
        shuttercontrol.0	2020-07-07 07:10:05.451	debug	(28378) check IsEqual : 06:30 09:00
        shuttercontrol.0	2020-07-07 07:10:05.450	debug	(28378) check IsLater : 05:27 06:30
        shuttercontrol.0	2020-07-07 07:10:05.449	debug	(28378) check IsLater : 05:27 09:00
        shuttercontrol.0	2020-07-07 07:10:05.408	debug	(28378) Shutdown shutters Sunset area: 22:23
        shuttercontrol.0	2020-07-07 07:10:05.406	debug	(28378) Starting up shutters Sunrise area: 05:27
        shuttercontrol.0	2020-07-07 07:10:05.405	debug	(28378) Shutdown shutters GoldenHour area: 21:29
        shuttercontrol.0	2020-07-07 07:10:05.404	debug	(28378) Starting up shutters GoldenHour area: 06:21
        shuttercontrol.0	2020-07-07 07:10:05.399	debug	(28378) Sunset today: 21:53
        shuttercontrol.0	2020-07-07 07:10:05.397	debug	(28378) Sunrise today: 05:22
        shuttercontrol.0	2020-07-07 07:10:05.395	debug	(28378) current day: 2
        shuttercontrol.0	2020-07-07 07:10:05.394	debug	(28378) goldenHour today: 20:59
        shuttercontrol.0	2020-07-07 07:10:05.391	debug	(28378) goldenHourEnd today: 06:16
        shuttercontrol.0	2020-07-07 07:10:05.389	debug	(28378) calculate astrodata ...
        shuttercontrol.0	2020-07-07 07:10:05.383	debug	(28378) shutterDriveCalc
        shuttercontrol.0	2020-07-07 07:10:05.375	debug	(28378) 222
        shuttercontrol.0	2020-07-07 07:10:04.496	debug	(28378) got HolidayDP false
        shuttercontrol.0	2020-07-07 07:10:04.370	debug	(28378) checking HolidayDP
        shuttercontrol.0	2020-07-07 07:10:04.359	debug	(28378) 1111
        shuttercontrol.0	2020-07-07 07:10:02.406	debug	(28378) save current height: 0% from EG_Kueche_Rollade_Fenster
        shuttercontrol.0	2020-07-07 07:10:02.405	debug	(28378) save current height: 0% from EG_Kueche_Rollade_Tuer
        shuttercontrol.0	2020-07-07 07:10:02.405	debug	(28378) save current height: 0% from EG_Whz_Rollade_Terrasse_ls
        shuttercontrol.0	2020-07-07 07:10:02.405	debug	(28378) save current height: 0% from EG_Whz_Rollade_Terrasse_rs
        shuttercontrol.0	2020-07-07 07:10:02.404	debug	(28378) save current height: 0% from EG_Whz_Rollade_Fenster
        shuttercontrol.0	2020-07-07 07:10:02.404	debug	(28378) save current height: 0% from EG_HWR_Rollade_Tuer
        shuttercontrol.0	2020-07-07 07:10:02.403	debug	(28378) save current height: 0% from EG_HWR_Rollade_Fenster
        shuttercontrol.0	2020-07-07 07:10:02.402	debug	(28378) save current height: 0% from EG_GaesteWC_Rollade
        shuttercontrol.0	2020-07-07 07:10:02.378	debug	(28378) Shutter State: linkeddevices.0.Shutter.EG.EG_Kueche_Rollade_Fenster.Position
        shuttercontrol.0	2020-07-07 07:10:02.377	debug	(28378) Shutter State: linkeddevices.0.Shutter.EG.EG_Kueche_Rollade_Tuer.Position
        shuttercontrol.0	2020-07-07 07:10:02.376	debug	(28378) Shutter State: linkeddevices.0.Shutter.EG.EG_Whz_Rollade_Terrasse_ls.Position
        shuttercontrol.0	2020-07-07 07:10:02.375	debug	(28378) Shutter State: linkeddevices.0.Shutter.EG.EG_Whz_Rollade_Terrasse_rs.Position
        shuttercontrol.0	2020-07-07 07:10:02.374	debug	(28378) Shutter State: linkeddevices.0.Shutter.EG.EG_Whz_Rollade_Fenster.Position
        shuttercontrol.0	2020-07-07 07:10:02.373	debug	(28378) Shutter State: linkeddevices.0.Shutter.EG.EG_HWR_Rollade_Tuer.Position
        shuttercontrol.0	2020-07-07 07:10:02.372	debug	(28378) Shutter State: linkeddevices.0.Shutter.EG.EG_HWR_Rollade_Fenster.Position
        shuttercontrol.0	2020-07-07 07:10:02.371	debug	(28378) Shutter State: linkeddevices.0.Shutter.EG.EG_GaesteWC_Rollade.Position
        shuttercontrol.0	2020-07-07 07:10:02.369	debug	(28378) trigger for outside temperature: linkeddevices.0.Temperatur.Aussen.Aussen_Temperatur_Sensor.temperature
        shuttercontrol.0	2020-07-07 07:10:02.368	debug	(28378) trigger for inside temperature: linkeddevices.0.Temperatur.EG.EG_Whz_Temperatur.temperature
        shuttercontrol.0	2020-07-07 07:10:02.366	debug	(28378) trigger for shuttercontrol: linkeddevices.0.Sensoren.EG.EG_Küche_Fensterkontakt.open
        shuttercontrol.0	2020-07-07 07:10:02.365	debug	(28378) trigger for shuttercontrol: linkeddevices.0.Sensoren.EG.EG_Küche_Türkontakt.open
        shuttercontrol.0	2020-07-07 07:10:02.364	debug	(28378) trigger for shuttercontrol: linkeddevices.0.Sensoren.EG.EG_Whz_Türkontakt.open
        shuttercontrol.0	2020-07-07 07:10:02.363	debug	(28378) trigger for shuttercontrol: linkeddevices.0.Sensoren.EG.EG_Esszimmer_Fensterkontakt_rs.open
        shuttercontrol.0	2020-07-07 07:10:02.362	debug	(28378) trigger for shuttercontrol: linkeddevices.0.Sensoren.EG.EG_HWR_Türkontakt.open
        shuttercontrol.0	2020-07-07 07:10:02.361	debug	(28378) trigger for shuttercontrol: linkeddevices.0.Sensoren.EG.EG_HWR_Fensterkontakt.open
        shuttercontrol.0	2020-07-07 07:10:02.359	debug	(28378) trigger for shuttercontrol: linkeddevices.0.Sensoren.EG.EG_GästeWC_Fensterkontakt.open
        Oder sehe ich das falsch?
        • L LJSven
          simatecS Online
          simatecS Online
          simatec
          #2164
          @LJSven sagte in Test Adapter shuttercontrol v0.8.x:
          Wieso taucht das nicht auf? Es wird sofort neu berechnet ...
          L 1 Antwort Letzte Antwort
          • simatecS simatec
            LJSven
            #2165
            @simatec sagte in Test Adapter shuttercontrol v0.8.x:
            Okay! Habe ich übersehen! Sorry! Rollladen fahren aber nicht, wenn der Wert von false auf true wechselt.
            • L LJSven
              simatecS Online
              simatecS Online
              simatec
              #2166
              @LJSven
              Das hatte ich doch gestern schon erklärt und steht auch in der Doku. Die Rolläden fahren nach der eingestellten zeit.
              Der Trigger gibt nur die Fahrt frei oder halt nicht, wenn er auf false steht!!
              • simatecS simatec
                @LJSven
                LJSven
                #2167
                @LJSven
                Übersehe ich es wieder, oder zeigt er nicht an, daß AUTO LIVING auf false steht?
                shuttercontrol.0	2020-07-07 08:15:00.004	debug	(28378) Sun Azimut: 82.7°
                shuttercontrol.0	2020-07-07 08:15:00.003	debug	(28378) calculate astrodata ...
                shuttercontrol.0	2020-07-07 08:13:46.650	debug	(28378) late down at 22:15
                shuttercontrol.0	2020-07-07 08:13:46.648	debug	(28378) Shutdown shutters sleep area: 20:00 debug 6
                shuttercontrol.0	2020-07-07 08:13:46.645	debug	(28378) shutterDownLiving
                shuttercontrol.0	2020-07-07 08:13:46.645	debug	(28378) Shutdown shutters living area: 22:23 debug 7
                shuttercontrol.0	2020-07-07 08:13:46.644	debug	(28378) yes, IsEarlier : 22:23 22:30
                shuttercontrol.0	2020-07-07 08:13:46.643	debug	(28378) check IsEarlier : 22:23 22:30
                shuttercontrol.0	2020-07-07 08:13:46.643	debug	(28378) check IsLater : 22:23 22:30
                shuttercontrol.0	2020-07-07 08:13:46.640	debug	(28378) Starting up shutters sleep area: 06:00 debug 8
                shuttercontrol.0	2020-07-07 08:13:46.639	debug	(28378) yes, IsEarlier : 05:27 06:00
                shuttercontrol.0	2020-07-07 08:13:46.639	debug	(28378) check IsEarlier : 05:27 06:00
                shuttercontrol.0	2020-07-07 08:13:46.638	debug	(28378) check IsEqual : 05:27 09:30
                shuttercontrol.0	2020-07-07 08:13:46.638	debug	(28378) check IsEqual : 06:00 09:30
                shuttercontrol.0	2020-07-07 08:13:46.637	debug	(28378) check IsLater : 05:27 06:00
                shuttercontrol.0	2020-07-07 08:13:46.636	debug	(28378) check IsLater : 05:27 09:30
                shuttercontrol.0	2020-07-07 08:13:46.630	debug	(28378) Starting up shutters living area: 06:30 debug 8
                shuttercontrol.0	2020-07-07 08:13:46.629	debug	(28378) yes, IsEarlier : 05:27 06:30
                shuttercontrol.0	2020-07-07 08:13:46.627	debug	(28378) check IsEarlier : 05:27 06:30
                shuttercontrol.0	2020-07-07 08:13:46.626	debug	(28378) check IsEqual : 05:27 09:00
                shuttercontrol.0	2020-07-07 08:13:46.624	debug	(28378) check IsEqual : 06:30 09:00
                shuttercontrol.0	2020-07-07 08:13:46.622	debug	(28378) check IsLater : 05:27 06:30
                shuttercontrol.0	2020-07-07 08:13:46.621	debug	(28378) check IsLater : 05:27 09:00
                shuttercontrol.0	2020-07-07 08:13:46.608	debug	(28378) Shutdown shutters Sunset area: 22:23
                shuttercontrol.0	2020-07-07 08:13:46.608	debug	(28378) Starting up shutters Sunrise area: 05:27
                shuttercontrol.0	2020-07-07 08:13:46.607	debug	(28378) Shutdown shutters GoldenHour area: 21:29
                shuttercontrol.0	2020-07-07 08:13:46.606	debug	(28378) Starting up shutters GoldenHour area: 06:21
                shuttercontrol.0	2020-07-07 08:13:46.605	debug	(28378) Sunset today: 21:53
                shuttercontrol.0	2020-07-07 08:13:46.604	debug	(28378) Sunrise today: 05:22
                shuttercontrol.0	2020-07-07 08:13:46.603	debug	(28378) current day: 2
                shuttercontrol.0	2020-07-07 08:13:46.602	debug	(28378) goldenHour today: 20:59
                shuttercontrol.0	2020-07-07 08:13:46.601	debug	(28378) goldenHourEnd today: 06:16
                shuttercontrol.0	2020-07-07 08:13:46.600	debug	(28378) calculate astrodata ...
                shuttercontrol.0	2020-07-07 08:13:46.599	debug	(28378) shutterDriveCalc
                shuttercontrol.0	2020-07-07 08:13:22.908	debug	(28378) system.adapter.admin.0: logging true
                • tobasiumT Offline
                  tobasiumT Offline
                  tobasium
                  #2168
                  @simatec Guten Morgen, also ich habe jetzt nochmal getestet mit der 0.8.2 der Rolladen Küche fährt morgens nicht in den Sonnenschutz, wen ich den Adapter downgrade auf die 0.8.0 fährt er sofort in den Sonnenschutz. ich teste nun weiter um ein besseres Bild abzugeben.
                  • L LJSven
                    @LJSven
                    simatecS Online
                    simatecS Online
                    simatec
                    #2169
                    @LJSven
                    Was willst du mir damit sagen? Es wurde neu berechnet!!!
                    • tobasiumT tobasium
                      simatecS Online
                      simatecS Online
                      simatec
                      #2170
                      @tobasium
                      Zeige mal bitte deinen Log, wenn die eigentlich in Sonnenschutz gehen sollten und zeige mal die Config des Rollladens, der in Sonnenschutz gehen sollte
                      tobasiumT 1 Antwort Letzte Antwort
                      • simatecS simatec
                        @LJSven
                        LJSven
                        schrieb am zuletzt editiert von LJSven
                        #2171
                        @LJSven
                        Alles klar! Ich denke wir belassen es dabei!
                        @simatec Vollen Respekt für deinen Einsatz, allerdings habe ich den Eindruck, daß du mit mir fertig bist / was auch die diversen Ausrufezeichen zeigen.
                        Für mich ist die Doku nicht "eindeutig" - sonst hätte ich diese Fragen nicht gestellt. Die Frage ist eigentlich einfach - ich verstehe. Ich verstehe den Sinn von WOHNBEREICH AUTO nicht, egal ob true oder false, die Rollläden werden morgens nicht gefahren.
                        • L LJSven
                          @LJSven
                          simatecS Online
                          simatecS Online
                          simatec
                          schrieb am zuletzt editiert von simatec
                          #2172
                          @LJSven
                          Nein alles gut ... Es wurde lediglich hier einiges doppelt und dreifach erklärt.
                          Wenn deine Rollläden nicht fahren, poste mal bitte die Config der betroffenen Rollläden als json hier.
                          Du kannst dir die Config im Menü über die Pfeiltasten runterladen.
                          Was alledings alles auch etwas wirr war, waren deine Aussagen mit dem Bewegungsmelder, der irgendwie nun garnicht mehr Thema ist.
                          Gut wäre, wenn du mal ganz genau schreibst, was du eigentlich genau vor hast.
                          Aus dem verlauf werde ich nicht schlau
                          • simatecS simatec
                            @tobasium
                            tobasiumT Offline
                            tobasiumT Offline
                            tobasium
                            schrieb am zuletzt editiert von tobasium
                            #2173
                            @simatec
                            Folgendes passiert um 6 Uhr wen der Rolladen hoch fährt unter 0.8.2 sieht denk ich gut aus:
                            2020-07-07 06:00:10.022 - info: shuttercontrol.0 (20933) #15 Set ID: Küche Rolladen value: 100%
                            2020-07-07 06:00:10.023 - debug: shuttercontrol.0 (20933) shutterUpLiving #3 Küche Rolladen old height: 30% new height: 100%
                            2020-07-07 06:00:10.028 - debug: shuttercontrol.0 (20933) Shutter state changed: Küche Rolladen old value = 30 new value = 100
                            2020-07-07 06:00:10.028 - debug: shuttercontrol.0 (20933) Küche Rolladen Old value = 30. New value = 100. automatic is active
                            2020-07-07 06:00:10.662 - debug: shuttercontrol.0 (20933) Shutter state changed: Küche Rolladen old value = 30 new value = 30
                            2020-07-07 06:00:10.663 - debug: shuttercontrol.0 (20933) Küche Rolladen drived manually to 100%. Old value = 30. New value = 30. Possibility to activate sunprotect enabled.
                            2020-07-07 06:00:11.412 - debug: shuttercontrol.0 (20933) Shutter state changed: KJ-Fenster old value = 100 new value = 30
                            2020-07-07 06:00:11.413 - debug: shuttercontrol.0 (20933) KJ-Fenster drived manually to 100%. Old value = 100. New value = 30. Possibility to activate sunprotect enabled.
                            Also normal fährt er hier um ca. 6.50Uhr
                            2020-07-07 06:50:00.004 - debug: shuttercontrol.0 (20933) calculate astrodata ...
                            2020-07-07 06:50:00.005 - debug: shuttercontrol.0 (20933) Sun Azimut: 67.9°
                            2020-07-07 06:50:00.005 - debug: shuttercontrol.0 (20933) Sun Elevation: 10.8°
                            2020-07-07 06:50:02.011 - debug: shuttercontrol.0 (20933) Schlafzimmer Rolladen level conversion is enabled
                            2020-07-07 06:50:02.012 - debug: shuttercontrol.0 (20933) Küche Rolladen level conversion is enabled
                            2020-07-07 06:50:02.012 - debug: shuttercontrol.0 (20933) Wohnzimmer Fenster level conversion is enabled
                            2020-07-07 06:50:02.013 - debug: shuttercontrol.0 (20933) WZJ-Fenster level conversion is enabled
                            2020-07-07 06:50:02.013 - debug: shuttercontrol.0 (20933) WZJ-Türe level conversion is enabled
                            2020-07-07 06:50:12.015 - debug: shuttercontrol.0 (20933) Küche Rolladen: Check basis for sunprotect. Height:100 > HeightDownSun: 55 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
                            Jetzt habe ich um ca 8:30Uhr ein downgrade auf 0.8.0 gemacht dann passiert folgendes, er löst innerhalb 1-2min aus:
                            2020-07-07 08:30:12.039 - debug: shuttercontrol.0 (3467) Küche Rolladen: Check basis for sunprotect. Height:100 > HeightDownSun: 55 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
                            2020-07-07 08:30:12.042 - debug: shuttercontrol.0 (3467) Sunprotect for Küche Rolladen is active
                            2020-07-07 08:30:12.043 - debug: shuttercontrol.0 (3467) RangeMinus: -20 < 85.6RangePlus: 120 > 85.6
                            2020-07-07 08:30:12.043 - info: shuttercontrol.0 (3467) Set ID: Küche Rolladen value: 55%
                            2020-07-07 08:30:12.045 - debug: shuttercontrol.0 (3467) Sunprotect Küche Rolladen old height: 100% new height: 55%
                            2020-07-07 08:30:12.095 - debug: shuttercontrol.0 (3467) Shutter state changed: Küche Rolladen old value = 100 new value = 55
                            2020-07-07 08:30:12.199 - info: host.iobroker instance system.adapter.coronavirus-statistics.0 started with pid 4819
                            2020-07-07 08:30:12.531 - debug: shuttercontrol.0 (3467) Shutter state changed: Küche Rolladen old value = 100 new value = 100
                            2020-07-07 08:30:12.532 - debug: shuttercontrol.0 (3467) Küche Rolladen drived manually to 100%. Old value = 100. New value = 100. Possibility to activate sunprotect enabled.
                            2020-07-07 08:30:19.722 - debug: shuttercontrol.0 (3467) Shutter state changed: Küche Rolladen old value = 100 new value = 55
                            Habe jetzt im Anschluss wieder die 0.8.2 drauf gemacht, da ich denke das er hier den Sonnenschutz wieder hoch fährt. Im gleichen Zug kann ich die andere Wohnseite die gegen ca. 13 Uhr auslösen sollte testen.
                            simatecS fischi87F 2 Antworten Letzte Antwort
                            • simatecS simatec
                              @LJSven
                              LJSven
                              #2174
                              @simatec Okay! Ich schreibe jetzt mal mein Anliegen! Danke!
                              Ich möchte, daß meine gesamten Rollläden am Abend nach dem Sonnenuntergang herunter gefahren werden. Am nächsten Morgen, wenn ich zum ersten mal die Küche betrete (da ist ein Bewegungsmelder verbaut), sollen die Rollläden wieder hochfahren. Die Rollläden sollen NICHT zum Sonnenaufgang hochfahren, sondern erst wenn ich in die Küche komme.
                              Daher habe ich gedacht, daß die WOHNBEREICH AUTOMATIK hier zum tragen kommt. Ich verstehe das als eine Art Anwesenheit (wie es auch im Adapter beschrieben ist.)
                              Wenn ich die Rollläden nur auf WOHNBEREICH stelle, fahren sie pünktlich um 06:30 Uhr hoch (ohne das jemand in der Küche war.), weil der Sonnenaufgang vor der Zeit (05:.. Uhr) war.
                              Hier mal die Config ->
                                "_id": "system.adapter.shuttercontrol.0",
                                "common": {
                                  "name": "shuttercontrol",
                                  "version": "0.8.1",
                                  "title": "shuttercontrol",
                                  "authors": [
                                    "simatec <nais@gmx.net>"
                                  "contributors": [
                                    "Rene G. <info@rg-engineering.eu>"
                                  "keywords": [
                                    "ioBroker",
                                    "Smart Home",
                                    "home automation",
                                    "Rollladen",
                                    "Jalousie",
                                    "Rollladensteuerung"
                                  "license": "MIT",
                                  "platform": "Javascript/Node.js",
                                  "main": "main.js",
                                  "icon": "shuttercontrol.png",
                                  "enabled": true,
                                  "extIcon": "https://raw.githubusercontent.com/simatec/ioBroker.shuttercontrol/master/admin/shuttercontrol.png",
                                  "readme": "https://github.com/simatec/ioBroker.shuttercontrol/blob/master/README.md",
                                  "loglevel": "debug",
                                  "mode": "daemon",
                                  "type": "climate-control",
                                  "compact": true,
                                  "materialize": true,
                                  "stopBeforeUpdate": true,
                                  "plugins": {
                                    "sentry": {
                                      "dsn": "https://5f58df7167d846e3a90bae5414d4fc09@sentry.iobroker.net/62"
                                  "installedFrom": "iobroker.shuttercontrol@0.8.1",
                                  "installedVersion": "0.8.1",
                                  "host": "tinkerboardmaster"
                                "native": {
                                  "livingAutomatic": "livingSunriseSunset",
                                  "W_shutterDownLiving": "22:30",
                                  "W_shutterUpLivingMin": "06:30",
                                  "W_shutterUpLivingMax": "10:30",
                                  "driveDelayUpLiving": "25",
                                  "WE_shutterDownLiving": "22:30",
                                  "WE_shutterUpLivingMin": "06:30",
                                  "WE_shutterUpLivingMax": "10:30",
                                  "sleepAutomatic": "sleepSunriseSunset",
                                  "W_shutterDownSleep": "20:00",
                                  "W_shutterUpSleepMin": "06:00",
                                  "W_shutterUpSleepMax": "10:30",
                                  "driveDelayUpSleep": "10",
                                  "WE_shutterDownSleep": "21:00",
                                  "WE_shutterUpSleepMin": "06:00",
                                  "WE_shutterUpSleepMax": "10:30",
                                  "latitude": "52.08323425444124",
                                  "longitude": "6.990505053596324",
                                  "astroDelayUp": "5",
                                  "astroDelayDown": "30",
                                  "driveDelayUpAstro": "5",
                                  "sunProtEndElevation": "10",
                                  "HolidayDP": "0_userdata.0.Modi.Urlaubsmodus",
                                  "triggerAutoSleep": "",
                                  "triggerAutoLiving": "0_userdata.0.Einstellungen.EG_Rolladenautomatik_Shuttercontrol",
                                  "LateAllDown": true,
                                  "LateAllDownTime": "22:15",
                                  "SummerStart": "01.03.",
                                  "SummerEnd": "30.09.",
                                  "currentShutterState": true,
                                  "publicHolidays": false,
                                  "publicHolInstance": "",
                                  "heightDownSun": "40",
                                  "direction": "180",
                                  "type": "in- & outside temperature and direction",
                                  "directionRange": "50",
                                  "actualValueTemp": "linkeddevices.0.Temperatur.Aussen.Aussen_Temperatur_Sensor.temperature",
                                  "actualValueLight": "",
                                  "actualValueTempInside": "linkeddevices.0.Temperatur.EG.EG_Whz_Temperatur.temperature",
                                  "typeDown": "sunset",
                                  "typeUp": "living-auto",
                                  "triggerStateShutter": "false",
                                  "triggerChangeShutter": "upDown",
                                  "triggerDriveShutter": "15",
                                  "autoDriveShutter": "off",
                                  "heightDownShutter": "0",
                                  "heightUpShutter": "100",
                                  "triggerID": "linkeddevices.0.Sensoren.EG.EG_Whz_Türkontakt.open",
                                  "LateDown": true,
                                  "inSummerNotDown": false,
                                  "events": [
                                      "enabled": true,
                                      "shutterName": "EG_GaesteWC_Rollade",
                                      "name": "linkeddevices.0.Shutter.EG.EG_GaesteWC_Rollade.Position",
                                      "triggerID": "linkeddevices.0.Sensoren.EG.EG_GästeWC_Fensterkontakt.open",
                                      "type": "outside temperature and direction",
                                      "heightDownSun": "60",
                                      "direction": "0",
                                      "tempInside": "23",
                                      "tempSensor": "",
                                      "outsideTempSensor": "linkeddevices.0.Temperatur.Aussen.Aussen_Temperatur_Sensor.temperature",
                                      "tempOutside": "23",
                                      "lightSensor": "",
                                      "valueLight": "15",
                                      "heightUp": "100",
                                      "heightDown": "0",
                                      "triggerState": "false",
                                      "triggerDrive": "15",
                                      "triggerChange": "onlyUp",
                                      "elevation": "8",
                                      "autoDrive": "onlyUp",
                                      "hysteresisOutside": "5",
                                      "hysteresisInside": "5",
                                      "hysteresisLight": "5",
                                      "currentAction": "",
                                      "currentHeight": "",
                                      "oldHeight": "",
                                      "firstCompleteUp": "",
                                      "triggerHeight": "",
                                      "LateDown": true,
                                      "enabled": true,
                                      "shutterName": "EG_HWR_Rollade_Fenster",
                                      "name": "linkeddevices.0.Shutter.EG.EG_HWR_Rollade_Fenster.Position",
                                      "triggerID": "linkeddevices.0.Sensoren.EG.EG_HWR_Fensterkontakt.open",
                                      "direction": "0",
                                      "tempInside": "23",
                                      "tempSensor": "",
                                      "lightSensor": "",
                                      "valueLight": "15",
                                      "heightUp": "100",
                                      "heightDown": "0",
                                      "triggerChange": "upDown",
                                      "elevation": "8",
                                      "autoDrive": "off",
                                      "oldHeight": "",
                                      "LateDown": true,
                                      "enabled": true,
                                      "shutterName": "EG_HWR_Rollade_Tuer",
                                      "name": "linkeddevices.0.Shutter.EG.EG_HWR_Rollade_Tuer.Position",
                                      "triggerID": "linkeddevices.0.Sensoren.EG.EG_HWR_Türkontakt.open",
                                      "type": "off",
                                      "heightDownSun": "30",
                                      "direction": "270",
                                      "tempInside": "23",
                                      "tempSensor": "",
                                      "outsideTempSensor": "",
                                      "lightSensor": "",
                                      "valueLight": "15",
                                      "heightUp": "100",
                                      "heightDown": "0",
                                      "triggerDrive": "100",
                                      "elevation": "8",
                                      "autoDrive": "off",
                                      "oldHeight": "",
                                      "LateDown": true,
                                      "enabled": true,
                                      "shutterName": "EG_Whz_Rollade_Fenster",
                                      "name": "linkeddevices.0.Shutter.EG.EG_Whz_Rollade_Fenster.Position",
                                      "triggerID": "linkeddevices.0.Sensoren.EG.EG_Esszimmer_Fensterkontakt_rs.open",
                                      "direction": "270",
                                      "tempInside": "23",
                                      "tempSensor": "linkeddevices.0.Temperatur.EG.EG_Whz_Temperatur.temperature",
                                      "lightSensor": "",
                                      "valueLight": "15",
                                      "heightUp": "100",
                                      "heightDown": "0",
                                      "elevation": "8",
                                      "autoDrive": "off",
                                      "oldHeight": "",
                                      "LateDown": true,
                                      "enabled": true,
                                      "shutterName": "EG_Whz_Rollade_Terrasse_rs",
                                      "name": "linkeddevices.0.Shutter.EG.EG_Whz_Rollade_Terrasse_rs.Position",
                                      "direction": "180",
                                      "tempInside": "23",
                                      "lightSensor": "",
                                      "valueLight": "15",
                                      "heightUp": "100",
                                      "heightDown": "0",
                                      "elevation": "30",
                                      "autoDrive": "off",
                                      "oldHeight": "",
                                      "LateDown": true,
                                      "enabled": true,
                                      "shutterName": "EG_Whz_Rollade_Terrasse_ls",
                                      "name": "linkeddevices.0.Shutter.EG.EG_Whz_Rollade_Terrasse_ls.Position",
                                      "triggerID": "",
                                      "direction": "180",
                                      "tempInside": "23",
                                      "lightSensor": "",
                                      "valueLight": "15",
                                      "heightUp": "100",
                                      "heightDown": "0",
                                      "elevation": "30",
                                      "autoDrive": "off",
                                      "oldHeight": "",
                                      "LateDown": true,
                                      "enabled": true,
                                      "shutterName": "EG_Kueche_Rollade_Tuer",
                                      "name": "linkeddevices.0.Shutter.EG.EG_Kueche_Rollade_Tuer.Position",
                                      "triggerID": "linkeddevices.0.Sensoren.EG.EG_Küche_Türkontakt.open",
                                      "direction": "90",
                                      "tempInside": "23",
                                      "tempSensor": "",
                                      "lightSensor": "",
                                      "valueLight": "15",
                                      "heightUp": "100",
                                      "heightDown": "0",
                                      "elevation": "8",
                                      "autoDrive": "off",
                                      "oldHeight": "",
                                      "LateDown": true,
                                      "enabled": true,
                                      "shutterName": "EG_Kueche_Rollade_Fenster",
                                      "name": "linkeddevices.0.Shutter.EG.EG_Kueche_Rollade_Fenster.Position",
                                      "triggerID": "linkeddevices.0.Sensoren.EG.EG_Küche_Fensterkontakt.open",
                                      "direction": "0",
                                      "tempInside": "23",
                                      "tempSensor": "",
                                      "lightSensor": "",
                                      "valueLight": "15",
                                      "heightUp": "100",
                                      "heightDown": "0",
                                      "elevation": "8",
                                      "autoDrive": "off",
                                      "oldHeight": "",
                                      "LateDown": true,
                              Der Trigger
                              dieser DP wird auf TRUE gestellt, sobald ich die Küche morgens zwischen 06:30 - 10:30 Uhr betrete & wird nachts um 0:00 Uhr wieder auf FALSE gestellt. Das Blockly dazu ist hier ->
                                @simatec
                                simatecS Online
                                simatecS Online
                                simatec
                                #2175
                                @tobasium sagte in Test Adapter shuttercontrol v0.8.x:
                                2020-07-07 06:50:02.011 - debug: shuttercontrol.0 (20933) Schlafzimmer Rolladen level conversion is enabled 2020-07-07 06:50:02.012 - debug: shuttercontrol.0 (20933) Küche Rolladen level conversion is enabled
                                Ich sehe das Problem ...
                                Ab Version 0.8.1 gibt es eine Konvertierung, damit auch Rolläden von KNX etc. benutzt werden können.
                                Das ist bei dir enabled, was bei deinen Einstellungen nicht passt.
                                Ich habe es probiert zu fixen. Kannst du bitte mal die 0.8.3 vom github testen und berichten, ob der Fix bei dir korrket läuft?
                                tobasiumT 2 Antworten Letzte Antwort
                                • simatecS simatec
                                  tobasiumT Offline
                                  tobasiumT Offline
                                  tobasium
                                  #2176
                                  @simatec ich hab aktualisiert gebe dir Bescheid sobald die nächsten Rolladen laufen
                                  • L LJSven
                                      "common": {
                                        "version": "0.8.1",
                                        "authors": [
                                        "contributors": [
                                        "keywords": [
                                          "ioBroker",
                                          "Smart Home",
                                          "home automation",
                                          "Rollladen",
                                          "Jalousie",
                                        "license": "MIT",
                                        "main": "main.js",
                                        "enabled": true,
                                        "mode": "daemon",
                                        "compact": true,
                                        "plugins": {
                                          "sentry": {
                                      "native": {
                                        "direction": "180",
                                        "LateDown": true,
                                        "events": [
                                            "enabled": true,
                                            "direction": "0",
                                            "tempInside": "23",
                                            "tempSensor": "",
                                            "lightSensor": "",
                                            "valueLight": "15",
                                            "heightUp": "100",
                                            "heightDown": "0",
                                            "elevation": "8",
                                            "oldHeight": "",
                                            "LateDown": true,
                                            "enabled": true,
                                            "direction": "0",
                                            "tempInside": "23",
                                            "tempSensor": "",
                                            "lightSensor": "",
                                            "valueLight": "15",
                                            "heightUp": "100",
                                            "heightDown": "0",
                                            "elevation": "8",
                                            "autoDrive": "off",
                                            "oldHeight": "",
                                            "LateDown": true,
                                            "enabled": true,
                                            "type": "off",
                                            "direction": "270",
                                            "tempInside": "23",
                                            "tempSensor": "",
                                            "lightSensor": "",
                                            "valueLight": "15",
                                            "heightUp": "100",
                                            "heightDown": "0",
                                            "elevation": "8",
                                            "autoDrive": "off",
                                            "oldHeight": "",
                                            "LateDown": true,
                                            "enabled": true,
                                            "direction": "270",
                                            "tempInside": "23",
                                            "lightSensor": "",
                                            "valueLight": "15",
                                            "heightUp": "100",
                                            "heightDown": "0",
                                            "elevation": "8",
                                            "autoDrive": "off",
                                            "oldHeight": "",
                                            "LateDown": true,
                                            "enabled": true,
                                            "direction": "180",
                                            "tempInside": "23",
                                            "lightSensor": "",
                                            "valueLight": "15",
                                            "heightUp": "100",
                                            "heightDown": "0",
                                            "elevation": "30",
                                            "autoDrive": "off",
                                            "oldHeight": "",
                                            "LateDown": true,
                                            "enabled": true,
                                            "triggerID": "",
                                            "direction": "180",
                                            "tempInside": "23",
                                            "lightSensor": "",
                                            "valueLight": "15",
                                            "heightUp": "100",
                                            "heightDown": "0",
                                            "elevation": "30",
                                            "autoDrive": "off",
                                            "oldHeight": "",
                                            "LateDown": true,
                                            "enabled": true,
                                            "direction": "90",
                                            "tempInside": "23",
                                            "tempSensor": "",
                                            "lightSensor": "",
                                            "valueLight": "15",
                                            "heightUp": "100",
                                            "heightDown": "0",
                                            "elevation": "8",
                                            "autoDrive": "off",
                                            "oldHeight": "",
                                            "LateDown": true,
                                            "enabled": true,
                                            "direction": "0",
                                            "tempInside": "23",
                                            "tempSensor": "",
                                            "lightSensor": "",
                                            "valueLight": "15",
                                            "heightUp": "100",
                                            "heightDown": "0",
                                            "elevation": "8",
                                            "autoDrive": "off",
                                            "oldHeight": "",
                                            "LateDown": true,
                                    Der Trigger
                                    simatecS Online
                                    simatecS Online
                                    simatec
                                    #2177
                                    @LJSven
                                    OK das sollte ganz einfach gehen.
                                    Konfiguriere deine Rollläden so, dass das hochfahren auf "Aus" steht und nur runterfahren mit Sonnenuntergang aktiv ist.
                                    Dann schreibst du dir ein script in dem du den Button "shuttercontrol.0.control.openAll" betätigst, wenn dein Bewegungsmelder auslöst
                                    on({id: "ObjectID.deines.Bewegungsmelders", val: true}, function (obj) {
                                      var value = obj.state.val;
                                      setState("shuttercontrol.0.control.openAll"/*open all Shutter*/, true);
                                    • simatecS simatec
                                      @LJSven
                                      LJSven
                                      #2178
                                      @LJSven
                                      Das funktioniert - hatte ich gestern getestet, wobei ich sagen muss daß "shuttercontrol.0.control.openLiving" nicht funktioniert hat, obwohl die Jalousien dem Wohnbereich zugeordnet sind.
                                      Ist das jetzt ein Workaround bzw. was genau macht die Wohnbereich Automatik?
                                      Wenn ich das so umsetze, hätte ich das Problem, daß im Urlaub die Jalousien nicht nach oben gefahren werden, oder?
                                      • L LJSven
                                        @LJSven
                                        simatecS Online
                                        simatecS Online
                                        simatec
                                        #2179
                                        @LJSven
                                        Living funktioniert bei dir nicht, da deine Rollläden alle auf living-auto konfiguriert sind.
                                        linving-auto ist identisch zu living, mit dem kleine Unterschied, dass du über den Trigger die Automatik aussetzen kannst.
                                        Bei mir ist z.B. die Terrassentür beim unterfahren so konfiguriert.
                                        Diese fährt somit nur bei Abwesenheit runter, da ich den Trigger living-auto bei Abwesenheit auf true setze.
                                        Wenn ich das so umsetze, hätte ich das Problem, dass im Urlaub die Jalousien nicht nach oben gefahren werden, oder?
                                        Das ist richtig ... Du kannst aber auch das hochfahren als Wohnbereich konfigurieren und setzt dort eine Zeit, die nach dem aufstehen und Küche betreten liegt ... Das hängt von deinem Schlafverhalten ab.
                                        Das würde bedeuten, dass die Rollläden bei Auslösung des Bewegungsmelders hochfahren oder halt dann zur konfigurierten späteren Zeit.
                                        • simatecS simatec
                                          @LJSven
                                          LJSven
                                          #2180
                                          Das klingt am logischsten für mich! Wie funktioniert der Urlaubsdatenpunkt? Sehe zwar das man den setzen kann, aber verstehe nicht, was der genau macht?
