  4. INFO / ACHTUNG : Zwave-Adapter
info
64 Beiträge 20 Kommentatoren 14.7k Aufrufe 15 Beobachtet
  • G Offline
    gery80
    #41
    danke hat funktioniert
    • F Offline
      fisch
      schrieb am zuletzt editiert von fisch
      #42
      hi @all
      kann mir jemand sagen was das genau beduetet?
      Inkludieren klappt ohne Probleme aber, sobald ich schalten will kommt das:
      zwave.0	2019-08-15 21:01:41.841	debug	node3: timeout
      zwave.0	2019-08-15 21:01:31.841	debug	node3: timeout
      zwave.0	2019-08-15 21:01:21.840	debug	node3: timeout
      zwave.0	2019-08-15 21:01:18.294	debug	system.adapter.admin.0: logging true
      zwave.0	2019-08-15 21:01:13.925	debug	setState for: nodeID=3: comClass=98: index=0: instance=1: value=true
      zwave.0	2019-08-15 21:01:13.925	debug	stateChange zwave.0.NODE3.DOOR_LOCK.Locked_1 set {"val":true,"ack":false,"ts":1565895673921,"q":0,"from":"system.adapter.node-red.0","user":"system.user.admin","lc":1565895673700}
      zwave.0	2019-08-15 21:01:13.782	debug	setState for: nodeID=3: comClass=98: index=0: instance=1: value=true
      zwave.0	2019-08-15 21:01:13.782	debug	stateChange zwave.0.NODE3.DOOR_LOCK.Locked_1 set {"val":true,"ack":false,"ts":1565895673779,"q":0,"from":"system.adapter.node-red.0","user":"system.user.admin","lc":1565895673700}
      zwave.0	2019-08-15 21:01:13.705	debug	setState for: nodeID=3: comClass=98: index=0: instance=1: value=true
      zwave.0	2019-08-15 21:01:13.704	debug	stateChange zwave.0.NODE3.DOOR_LOCK.Locked_1 set {"val":true,"ack":false,"ts":1565895673700,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1565895673700}
      zwave.0	2019-08-15 21:01:11.839	debug	setState for: nodeID=3: comClass=98: index=0: instance=1: value=false
      zwave.0	2019-08-15 21:01:11.838	debug	stateChange zwave.0.NODE3.DOOR_LOCK.Locked_1 set {"val":false,"ack":false,"ts":1565895671836,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1565891882149}
      zwave.0	2019-08-15 21:01:09.012	debug	system.adapter.admin.0: logging false
      zwave.0	2019-08-15 21:00:44.352	debug	system.adapter.admin.0: logging true
      zwave.0	2019-08-15 20:59:55.980	debug	fixing zwave buttons to use common.role "switch" instead of "button"
      zwave.0	2019-08-15 20:59:55.976	info	Scan completed
      zwave.0	2019-08-15 20:59:55.970	info	Update zwave.0.NODE3
      zwave.0	2019-08-15 20:59:55.970	info	node ready nodeID: 3, nodeInfo: {"manufacturer":"Poly-control","manufacturerid":"0x010e","product":"Danalock V3 BTZE","producttype":"0x0009","productid":"0x0001","type":"Door Lock Keypad","name":"","
      zwave.0	2019-08-15 20:59:55.969	debug
      • F fisch
        hi @all
        arteckA Offline
        arteckA Offline
        arteck
        #43
        @fisch sagte in INFO / ACHTUNG : Zwave-Adapter:
        NODE3
        scheint nicht erreichbar zu sein
        • snadorS Offline
          snadorS Offline
          snador
          #44
          Wie ist denn so der allgemeine Stand des Adapters. Ich frage weil mich das Thema Central Scene interessiert und mein NodOn Octane noch nicht funktioniert... Kommt da was oder sollte schon gehen?
          Danke für die Info!
          C 1 Antwort Letzte Antwort
          • MichaM Offline
            MichaM Offline
            Micha
            schrieb am zuletzt editiert von Micha
            #45
            Schließe mich dem Vorredner mal an.
            Die zwave Installation schlägt fehl auf einen Raspberry 4 mit dem iobroker Image pi_vccu 20190723_buster.
            Gibt es dafür schon eine Lösung?
            @AlCalzone
            Edit
            Fehlermeldung beim hinzufügen der Instanz
            $ ./iobroker add zwave --host raspberrypi
            host.raspberrypi install adapter zwave
            npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.zwave"
            npm
            WARN
            checkPermissions
            Missing write access to /opt/iobroker/node_modules/iobroker.zwave
            npm
            ERR! path
            /opt/iobroker/node_modules/iobroker.zwavenpm ERR! code
            EACCESnpm ERR!
            errno -13npm ERR!
            syscall access
            npm
            ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.zwave'npm ERR! { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.zwave']
            npm ERR! stack:
            npm ERR!
            'Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.zwave'',npm ERR! errno: -13,
            npm ERR! code: 'EACCES',
            npm ERR! syscall: 'access',
            npm ERR! path: '/opt/iobroker/node_modules/iobroker.zwave' }
            npm ERR!
            npm ERR! The operation was rejected by your operating system.
            npm ERR! It is likely you do not have the permissions to access this file as the current user
            npm ERR!
            npm ERR! If you believe this might be a permissions issue, please double-check the
            npm ERR! permissions of the file and its containing directories, or try running
            npm
            ERR! the command again as root/Administrator (though this is not recommended).
            npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2019-09-16T19_50_09_155Z-debug.log
            Cannot install iobroker.zwave: 243
            VG Micha
            • eumatsE Offline
              eumatsE Offline
              eumats
              schrieb am zuletzt editiert von eumats
              #46
              Mit „permission denied“ steht doch um Log schon ziemlich genau was nicht stimmt...
              Mein Vorschlag: Den Fixer laufen lassen (wenn unbekannt, dann Forumsuche) und noch mal versuchen...
              MichaM 1 Antwort Letzte Antwort
              • snadorS snador
                Danke für die Info!
                cburghardt
                #47
                @snador Central Scene wird mittlerweile von openzwave vernünftig unterstützt. Ob es auch mit dem Adapter funktioniert, werde ich demnächst mal testen.
                • eumatsE eumats
                  MichaM Offline
                  MichaM Offline
                  Micha
                  #48
                  @eumats said in INFO / ACHTUNG : Zwave-Adapter:
                  Vielen Dank für den Suchvorschlag.
                  Ich habe sowohl den fix durchgeführt als auch das Forum durchsucht. Das es hier was mit den Rechten zu tun hat sehe ich auch.
                  Selbst wenn ich den Befehl in der Konsole als Admin eingebe kommt der gleiche Fehler.
                  Grundsätzlich geht es hier um ein Installationsproblem unter Buster.
                  Wie oben empfohlen habe ich den zwave per
                  npm i iobroker.zwave installiert und dann mit
                  Iobroker upload zwave eingespielt.
                  Dann auch den npm audit fix ausgeführt und über das UI dann die Instanz installieren wollen.
                  Laut Anzeige ist zwave auch installiert aber keine Instanz.
                  Iobroker add zwave bringt auch nichts außer den Fehler.
                  VG Micha
                  • MichaM Micha
                    VG Micha
                    AlCalzoneA Offline
                    AlCalzoneA Offline
                    AlCalzone
                    #49
                    @Micha npm audit fix != fixer
                    Führe den fixer nochmal aus und probiere dann eine Instanz hinzuzufügen.
                    Warum sudo böse ist: https://forum.iobroker.net/post/17109
                    • MichaM Offline
                      MichaM Offline
                      Micha
                      #50
                      Hallo @AlCalzone ,
                      leider führt auch dieser Weg nicht zu dem gewünschten Erfolg.
                      Habe nochmals ein frisches Image genommen und wollte den Zwave Adapter installieren.
                      Die Installation auf der UI von Iobroker endet mit folgenden Fehler.
                      Fertig mit Fehler: fs.js:114 throw err; ^ Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.zwave/iob_npm.done' at Object.openSync (fs.js:443:3) at Object.writeFileSync (fs.js:1194:35) at ChildProcess.child.on (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2938:20) at ChildProcess.emit (events.js:198:13) at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                      der Fixer endet mit folgenden Fehler.
                      pi@raspberrypi:/opt/iobroker $ sudo npm audit fix != fixer
                      npm ERR! code ELOCKVERIFY
                      npm ERR! Errors were found in your package-lock.json, run npm install to fix them.
                      npm ERR! Missing: iobroker.b-control-em@^0.2.1
                      npm ERR! Missing: iobroker.node-red@^1.9.0
                      npm ERR! /root/.npm/_logs/2019-09-29T11_47_52_769Z-debug.log
                      Komme da irgendwie nicht weiter.
                      auf dem Raspi 3B läuft der Adapter.
                      Hast du noch ne Idee für mich ?
                      VG Micha
                      arteckA AlCalzoneA 2 Antworten Letzte Antwort
                      • MichaM Micha
                        Hallo @AlCalzone ,
                        VG Micha
                        arteckA Offline
                        arteckA Offline
                        arteck
                        #51
                        @Micha welche js-controller version hast du ??
                        • MichaM Micha
                          Hallo @AlCalzone ,
                          VG Micha
                          AlCalzoneA Offline
                          AlCalzoneA Offline
                          AlCalzone
                          #52
                          @Micha sagte in INFO / ACHTUNG : Zwave-Adapter:
                          Das ist kein Befehl. Das sollte heißen dass npm audit fix NICHT der Fixer ist, von dem überall gesprochen wird. Der Fixer wird wie folgt ausgeführt, sollte aber auf einer frischen Installation nicht nötig sein:
                            slax
                            schrieb am zuletzt editiert von slax
                            #53
                            nachdem Update auf Version 1.6.3 läuft der Zwave-Adapter nun nicht mehr.
                            Fehler im Log ist folgender:
                            Error: Cannot find module '/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/lib/../build/Release/openzwave_shared.node' at Function.Module._resolveFilename (module.js:548:15
                            uncaught exception: Cannot find module '/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/lib/../build/Release/openzwave_shared.node'
                            Den "Fixer"sowie nachfolgenden Code habe ich laufen lassen, jedoch ohne Erfolg.
                            cd /opt/iobroker/node_modules/openzwave-shared
                            npm i --production
                            sudo -H npm i --production --unsafe-perm
                            Dabei erfolgte die Fehlermeldung:
                            ../src/utils.cc: In function ‘void OZW::populateValueId(v8::Local<v8::Object>&, OpenZWave::ValueID)’:
                            ../src/utils.cc:248:49: error: ‘OpenZWave::Value’ has not been declared
                               AddStringProp (nodeobj, type,      OpenZWave::Value::GetTypeNameFromEnum(value.GetType()));
                            ../src/utils.hpp:36:25: note: in definition of macro ‘AddStringProp’
                               Nan::New<v8::String>( PROPVALUE ).ToLocalChecked());
                            ../src/utils.cc:249:49: error: ‘OpenZWave::Value’ has not been declared
                               AddStringProp (nodeobj, genre,     OpenZWave::Value::GetGenreNameFromEnum(value.GetGenre()));
                            openzwave_shared.target.mk:122: die Regel für Ziel „Release/obj.target/openzwave_shared/src/utils.o“ scheiterte
                            make: *** [Release/obj.target/openzwave_shared/src/utils.o] Fehler 1
                            make: Verzeichnis „/opt/iobroker/node_modules/openzwave-shared/build“ wird verlassen
                            gyp ERR! build error
                            gyp ERR! stack Error: `make` failed with exit code: 2
                            gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
                            gyp ERR! stack     at emitTwo (events.js:126:13)
                            gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
                            gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
                            gyp ERR! System Linux 4.14.98-v7+
                            gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                            gyp ERR! cwd /opt/iobroker/node_modules/openzwave-shared
                            gyp ERR! node -v v8.16.0
                            gyp ERR! node-gyp -v v3.8.0
                            gyp ERR! not ok
                            npm ERR! code ELIFECYCLE
                            npm ERR! errno 1
                            npm ERR! openzwave-shared@1.4.8 install: `node-gyp rebuild`
                            npm ERR! Exit status 1
                            npm ERR!
                            npm ERR! Failed at the openzwave-shared@1.4.8 install script.
                            npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                            npm ERR!     /home/pi/.npm/_logs/2019-10-05T12_37_22_303Z-debug.log
                            Habt ihr vielleicht noch einen Tipp?
                            Slax
                            • kmxakK Offline
                              kmxakK Offline
                              kmxak
                              schrieb am zuletzt editiert von kmxak
                              #54
                              sudo ldconfig
                              hat bei mir geholfen
                              Gruß Alex
                              • S slax
                                npm i --production
                                gyp ERR! not ok
                                npm ERR! errno 1
                                npm ERR!
                                Slax
                                cburghardt
                                #55
                                @slax warum der separate npm Aufruf, der kann nicht stimmen.
                                Bitte ein sudo ldconfig ausführen bzw. ldconfig /usr/local/lib64 (je nach System)
                                • C cburghardt
                                  AlCalzoneA Offline
                                  AlCalzoneA Offline
                                  AlCalzone
                                  #56
                                  @cburghardt Doch kann möglicherweise Sinn machen, um die Installation der Dependency (openzwave-shared) neu anzustoßen.
                                    slax
                                    #57
                                    Ich konnte das Problem nicht direkt mit nachträglichen Installationen lösen.
                                    sudo ldconfig bzw. für lib64 hatten keinen direkten Erfolg.
                                    Nachdem ich das Image mit iobroker neu aufgespielt und den Zwave-Adapter installiert hatte, funktionierte es nach einem ldconfig wieder.
                                    Freue mich schon auf den Zwave2-Adapter :-)
                                    slax
                                      Bluelightcrew
                                      #58
                                      Ich hab seid dem update auf 1.6.3 probleme mit einer Steckdosenzwischenstecker.
                                      Sobald er eingesteckt ist bekomme ich folgende fehler meldungen:
                                      host.rock64	2019-10-21 22:57:57.675	warn	instance system.adapter.zwave.0 terminated due to SIGABRT
                                      host.rock64	2019-10-21 22:57:57.675	error	Caught by controller[1]: what(): Manager.cpp:1512 - InvalidValueIDError (101) Msg: Invalid ValueID passed to GetValueLabel
                                      host.rock64	2019-10-21 22:57:57.674	error	Caught by controller[0]: terminate called after throwing an instance of 'OpenZWave::OZWException'
                                      • B Bluelightcrew
                                        arteckA Offline
                                        arteckA Offline
                                        arteck
                                        #59
                                        @Bluelightcrew excludiere den mal und includuere den neu.. da haben sich paar Datenpunkte geändert
                                        B 1 Antwort Letzte Antwort
                                        • arteckA arteck
                                          Bluelightcrew
                                          #60
                                          @arteck
                                          Danke für den Tipp, hätte ich eigentlich auch selbst drauf kommen können. Probiere ich später mal aus.
