  4. Test Adapter wireless-mbus v0.10.x
    5.8k
mbuswirelesswm-buswmbus
576 Beiträge 69 Kommentatoren 248.6k Aufrufe 55 Beobachtet
  • M Michi_Pi
    @gerald123 ja, der key ist leer, brauch da keinen.
    hier meine Einstellungen
    gerald123
    #201
    @michi_pi
    Ich habe genau die gleichen Einstellungen auf meinem Testsystem eingestellt, leider bekomme ich keine Verbindung zum Wasserzähler.
    Im Log ist nach dem Starten folgendes und dann kommt nichts mehr:
    2022-03-01 17:14:12.865 - info: host.raspberrypi "system.adapter.wireless-mbus.0" enabled
    2022-03-01 17:14:12.967 - info: host.raspberrypi instance system.adapter.wireless-mbus.0 started with pid 3008
    2022-03-01 17:14:16.102 - warn: wireless-mbus.0 (3008) Object wireless-mbus.0.info.rawdata is invalid: Default value has to be type "string" but received type "boolean"
    2022-03-01 17:14:16.110 - warn: wireless-mbus.0 (3008) This object will not be created in future versions. Please report this to the developer.
    2022-03-01 17:14:16.145 - info: wireless-mbus.0 (3008) starting. Version 0.7.7 (non-npm: lvogt/ioBroker.wireless-mbus#32679a612e4f3c02184035bd12d7fcaad4840ff1) in /opt/iobroker/node_modules/iobroker.wireless-mbus, node: v14.19.0, js-controller: 4.0.15
    2022-03-01 17:18:56.607 - error: host.raspberrypi Caught by controller[0]: <--- Last few GCs --->
    2022-03-01 17:18:56.607 - error: host.raspberrypi Caught by controller[0]: [3008:0x4a1cd40] 277506 ms: Scavenge 229.5 (231.8) -> 228.6 (231.8) MB, 11.5 / 0.0 ms (average mu = 0.183, current mu = 0.146) task
    2022-03-01 17:18:56.608 - error: host.raspberrypi Caught by controller[0]: [3008:0x4a1cd40] 277660 ms: Scavenge 229.4 (231.8) -> 228.6 (232.0) MB, 14.3 / 0.0 ms (average mu = 0.183, current mu = 0.146) task
    2022-03-01 17:18:56.611 - error: host.raspberrypi Caught by controller[0]: [3008:0x4a1cd40] 277800 ms: Scavenge 229.4 (232.0) -> 228.7 (232.0) MB, 4.3 / 0.0 ms (average mu = 0.183, current mu = 0.146) task
    2022-03-01 17:18:56.612 - error: host.raspberrypi Caught by controller[0]: <--- JS stacktrace --->
    2022-03-01 17:18:56.613 - error: host.raspberrypi Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
    2022-03-01 17:18:56.614 - warn: host.raspberrypi instance system.adapter.wireless-mbus.0 terminated due to SIGABRT
    2022-03-01 17:18:56.614 - info: host.raspberrypi instance system.adapter.wireless-mbus.0 terminated with code NaN ()
    2022-03-01 17:18:56.615 - info: host.raspberrypi Restart adapter system.adapter.wireless-mbus.0 because enabled
    2022-03-01 17:19:26.671 - info: host.raspberrypi instance system.adapter.wireless-mbus.0 started with pid 3042
    2022-03-01 17:19:29.393 - warn: wireless-mbus.0 (3042) Object wireless-mbus.0.info.rawdata is invalid: Default value has to be type "string" but received type "boolean"
    2022-03-01 17:19:29.402 - warn: wireless-mbus.0 (3042) This object will not be created in future versions. Please report this to the developer.
    2022-03-01 17:19:29.432 - info: wireless-mbus.0 (3042) starting. Version 0.7.7 (non-npm: lvogt/ioBroker.wireless-mbus#32679a612e4f3c02184035bd12d7fcaad4840ff1) in /opt/iobroker/node_modules/iobroker.wireless-mbus, node: v14.19.0, js-controller: 4.0.15
    Synology 918+ 4GB; ioBroker auf RPI4; Zigbee; Sonoff
    M L 2 Antworten Letzte Antwort
    • G gerald123
      @michi_pi
      Michi_Pi
      #202
      @gerald123 bin da auch nicht so fit, aber nach deinem Log denk ich hast du mit dem Speicher ein Problem.
      Ist dein Arbeitsspeicher voll? Welche Plattform nutzt du?
      G 1 Antwort Letzte Antwort
      • M Michi_Pi
        gerald123
        #203
        @michi_pi
        Habe das Testsystem auf einem Raspi PI3+ aufgesetzt.
        Es läuft nur IoBroker mit diesem Adapter
          Michi_Pi
          #204
          @gerald123 hab mal nach dem Fehler im Forum gesucht, das Problem haben wohl schon mehrere gehabt.
          Hast du alles aktuell? Das System updaten hat wohl bei den meisten das Problem behoben.
          Musst mal suchen.
          • M Michi_Pi
            Musst mal suchen.
            gerald123
            #205
            @michi_pi
            Ich werd nochmals ein Update machen, mal schaun obs hilft
            Danke schon mal für deine Unterstützung
            • G gerald123
              @michi_pi
              gerald123
              #206
              Leider haben die Update´s nicht geholfen.
              Kann es sein das ein PI 3B+ für diesen Adapter nicht ausreicht?
              • G gerald123
                Michi_Pi
                #207
                @gerald123 doch reicht aus, der läuft auch bei mir auf einen 3b+
                Kann dir dabei leider nicht helfen.
                • M Michi_Pi
                  gerald123
                  #208
                  @michi_pi
                  Ich hätte da noch eine Frage, auf welchem Betriebssystem hast du deinen IoBroker laufen.
                  Vielleicht hat es mit damit zutuen das es bei mir nicht funktioniert.
                  • G gerald123
                    @michi_pi
                    Michi_Pi
                    #209
                    @gerald123 hab raspbian drauf.
                    • H Offline
                      HKF8770
                      #210
                      Bekomme gerade den folgenden Fehler.
                      Meien datenpunkte habe ich, sprich die Verbindung Gerät über IM871A-USB zu meinem Rasberry steht. Hat einer eine Idee?
                      Freddy
                      hg6806H 1 Antwort Letzte Antwort
                      • H HKF8770
                        hg6806H Offline
                        hg6806H Offline
                        hg6806
                        #211
                        @kiste01
                        Läuft es mittlerweile bei dir?
                        Ich frage weil ich genau die gleiche Konstellation habe.
                        Und zwar lese ich den Zähler über wmbusmeters aus.
                        https://forum.iobroker.net/topic/38893/wasserzähler-funk-868-auslesen/191?_=1646905996483
                        War ein ziemlich Krampf bis das lief, gerade wenn man sich mit Linux nicht so auskennt.
                        Problem ist halt immer, wenn man das System neu aufsetzt, muss das dann auch neu aufsetzen.
                        Deswegen sieht das mit dem w-mbus Adapter ja schon einfacher aus und würde es damit auch mal versuchen.
                          MartyBr
                          #212
                          Hallo, ich habe den HYDRUS 2 eingebaut bekommen und versuche den Zählerstand mit dem W-MBUS Adapter auszulesen. Der Adapter läuft und zeigt auch meinen Zähler an.
                          Nun habe ich Wasser Nord (Berliner Umland) angeschrieben mit der Bitte, mir den AES Key mitzuteilen. Das war leider erfolglos.
                          Gibt es hier in dem Forum einen TN, der den HYDRUS schon erfolgreich auslesen konnte?
                          Martin
                          Intel NUCs mit Proxmox / Iobroker als VM unter Debian
                          Raspeberry mit USB Leseköpfen für Smartmeter
                          Homematic und Homematic IP
                          • hg6806H hg6806
                            @kiste01
                            HKF8770
                            #213
                            @hg6806 Hallo, also bei mir läuft es mittlerweile. Ich hab im Log immer noch den Fehler Unknown VIFExt 0x13 aber die Daten kommen. 906b1c3b-dd75-496d-89ee-46f40d908c0e-image.png
                            Hast du eine Idee was der Fehler Unknown VIFExt 0x13 ist?
                            Freddy
                            • H HKF8770
                              HKF8770
                              #214
                              @hkf8770 5b50b76d-95d8-474a-8db1-383aa44cfc78-image.png Kommt einer mit den Fehlern klar und hat einen Tip?
                              Freddy
                              • H HKF8770
                                hg6806H Offline
                                hg6806H Offline
                                hg6806
                                #215
                                @hkf8770
                                Hast du auch einen iPerl Sensus und nanoCUL?
                                • G gerald123
                                  @michi_pi
                                  lvogt
                                  #216
                                  in letzter Zeit hatte ich nicht so viel Zeit. Ich versuche mal eine Runde Antwort zu verteilen:
                                  @gerald123 said in Test Adapter wireless-mbus v0.7.x:
                                  Da sieht für mich auch nach irgendeinem grundsätzlichen Hardware oder ioBroker Problem aus. Da kann ich glaube ich nicht weiterhelfen. Aber ein Pi 3B+ sollte auf jeden Fall reichen...
                                  @hkf8770 said in Test Adapter wireless-mbus v0.7.x:
                                  Das heißt, dass der Adapter nicht "alle Details" des Telegramms auswerten konnte. Evtl. ist das auch nicht wirklich wichtig. Könnte aber auch tatsächlich zu falschen Werten führen. Kommt darauf was der Hersteller da in einem (vermutlich nicht standard-konformen) VIFE verpackt hat.
                                  Wenn du mir mal mit Hilfe des Debug-Logs einen Auszug der auch das ganze Telegramm enthält zukommen lässt kann ich evtl. versuchen daran was zu machen. Natürlich alles ohne Garantie.
                                  Dass die Fehlermeldung kontinuierlich im Log auftaucht ist natürlich nicht so gut. Da muss ich mal grundsätzlich noch etwas dran drehen wie geloggt wird.
                                  @martybr said in Test Adapter wireless-mbus v0.7.x:
                                  Ob der HYDRUS 2 (mit AES Key) was brauchbares liefert weiß ich nicht genau (mein Tipp wäre, ja), aber ich kann mich nur nochmal wiederholen, ohne AES Key geht gar nichts.
                                  @damian-kazimierczak said in Test Adapter wireless-mbus v0.7.x:
                                  Was denkst du über M-BUS S?
                                  Das ist ein (Kabel)M-Bus Master. Was hat das mit WM-Bus und insbesondere mit diesem Adapter zu tun?
                                  • hg6806H Offline
                                    hg6806H Offline
                                    hg6806
                                    schrieb am zuletzt editiert von hg6806
                                    #217
                                    So, ich hatte das mal mit den nanoCUL und iPerl Sensus gestartet, leider bekomme ich keine Daten.
                                    Ich habe das wmbusmeter Zeug gestoppt, der Stick wurde von dem Adapter auch erkannt.
                                    AES Schlüssel ist eingegeben. Baudrate 9600 gesetzt
                                    Hier die Log Ausgabe:
                                    wireless-mbus.0	2022-03-19 08:44:51.683	info	(16651) starting. Version 0.7.7 in /opt/iobroker/node_modules/iobroker.wireless-mbus, node: v14.19.0, js-controller: 4.0.18
                                    wireless-mbus.0	2022-03-19 08:44:51.647	warn	(16651) This object will not be created in future versions. Please report this to the developer.
                                    wireless-mbus.0	2022-03-19 08:44:51.642	warn	(16651) Object wireless-mbus.0.info.rawdata is invalid: Default value has to be type "string" but received type "boolean"
                                    Hat jemand eine Idee?
                                    L 1 Antwort Letzte Antwort
                                    • hg6806H hg6806
                                      lvogt
                                      #218
                                      @hg6806
                                      Ich denke die Kommunikation zum Stick klappt nicht. Stell das Logging für den Adapter mal auf Debug. Dann gibts vermutlich mehr Hinweise
                                      • L lvogt
                                        gerald123
                                        #219
                                        @lvogt
                                        Hab jetzt nochmals alles neu aufgesetzt, leider immer mit dem gleichen Ergebnis .
                                        Werde dann hier noch weiter mitlesen, vielleicht gibt es ja noch Infos wo es bei mir scheitert.
                                        L hg6806H 2 Antworten Letzte Antwort
                                        • G gerald123
                                          @lvogt
                                          lvogt
                                          #220
                                          @gerald123
                                          Nur mal zur Sicherheit: Dein Logauszug war auf debug Level? Falls nicht, bitte mal noch prüfen ob es damit ein paar mehr Ausgaben gibt.
