  4. Node-Red
  5. [gelöst] Hue Bewegungsmelder probleme mit lux
    6.6k
9 Beiträge 3 Kommentatoren 1.2k Aufrufe 3 Beobachtet
    Torsten_MG
    Hallo, ich habe 2 Bewegungsmelder von Philips hue.
    Motion und Battery werden problemlos übertragen. Nur LUX klappt bei mir leider nicht.
    Kann da jemand weiterhelfen?
            "id": "a9bdd812.d66708",
            "type": "tab",
            "label": "Flow 1",
            "disabled": false,
            "info": ""
            "id": "3cddc4e4.0314fc",
            "type": "ioBroker out",
            "z": "a9bdd812.d66708",
            "name": "BWM Flur",
            "topic": "Hue-Sensor-Flur",
            "ack": "true",
            "autoCreate": "true",
            "x": 641,
            "y": 80,
            "wires": []
            "id": "91c192e1.5280a",
            "type": "function",
            "name": "Motion",
            "func": "var newMsg = { payload: msg.payload.motion };\nreturn newMsg;",
            "outputs": 1,
            "noerr": 0,
            "x": 374,
            "y": 79,
            "wires": [
                    "3cddc4e4.0314fc"
            "id": "dd6e07ca.2251c8",
            "type": "hue-motion",
            "name": "Flur Sensor",
            "bridge": "7e9e53cb.178d2c",
            "sensorid": "3",
            "x": 106,
            "y": 79,
            "wires": [
                    "91c192e1.5280a",
                    "d7b6b979.cde3f8",
                    "b9f74ec1.e2a9e"
            "id": "d758a409.245f68",
            "name": "BWM Balkon",
            "topic": "Hue-Sensor-Balkon",
            "ack": "true",
            "x": 655,
            "y": 413,
            "wires": []
            "id": "1bf3e2d1.ff9d8d",
            "type": "function",
            "name": "motion",
            "outputs": 1,
            "noerr": 0,
            "x": 384,
            "y": 412,
            "wires": [
                    "d758a409.245f68"
            "id": "b36a28b0.30eee8",
            "name": "Balkon Bewegungsmelder",
            "sensorid": "12",
            "x": 115,
            "y": 461,
            "wires": [
                    "1bf3e2d1.ff9d8d",
                    "284edda7.86fe22",
                    "d842c5c6.3c1d38"
            "id": "d7b6b979.cde3f8",
            "type": "function",
            "name": "Battery",
            "func": "var newMsg = { payload: msg.info.battery };\nreturn newMsg;",
            "outputs": 1,
            "noerr": 0,
            "x": 378,
            "y": 133,
            "wires": [
                    "4eb19cf3.3f9864"
            "id": "4eb19cf3.3f9864",
            "name": "Batterie BWM Flur",
            "topic": "Batterie-BWM-Flur",
            "ack": "true",
            "x": 669,
            "y": 133,
            "wires": []
            "id": "284edda7.86fe22",
            "type": "function",
            "name": "Battery",
            "outputs": 1,
            "noerr": 0,
            "x": 395,
            "y": 460,
            "wires": [
                    "f331bd30.806f8"
            "id": "f331bd30.806f8",
            "name": "Batterie BWM Balkon",
            "topic": "Batterie-BWM_Balkon",
            "ack": "true",
            "x": 688,
            "y": 459,
            "wires": []
            "id": "b9f74ec1.e2a9e",
            "type": "function",
            "name": "lux",
            "func": "var newMsg = { payload: msg.payload.lux };\nreturn newMsg;\n",
            "outputs": 1,
            "noerr": 0,
            "x": 372,
            "y": 186,
            "wires": [
                    "eeac0ca5.58dad"
            "id": "eeac0ca5.58dad",
            "name": "LUX-BWM-Flur",
            "topic": "LUX-BWM-Flur",
            "ack": "true",
            "x": 661,
            "y": 186,
            "wires": []
            "id": "d842c5c6.3c1d38",
            "type": "function",
            "name": "lux",
            "outputs": 1,
            "noerr": 0,
            "x": 384,
            "y": 365,
            "wires": [
                    "88abe831.c03c38"
            "id": "88abe831.c03c38",
            "name": "LUX-BWM-Balkon",
            "topic": "LUX-BWM-Balkon",
            "ack": "true",
            "x": 679,
            "y": 362,
            "wires": []
            "id": "7e9e53cb.178d2c",
            "type": "hue-bridge",
            "z": "",
            "name": "Philips hue",
            "bridge": "192.168.178.41",
            "key": "gelöscht; Homoran (Admin)",
            "interval": "1000"
    • sigi234S Online
      sigi234S Online
      sigi234
      Immer Daten sichern!
        Torsten_MG
        Vielen DANK!!
        • T Torsten_MG
          Vielen DANK!!
          sigi234S Online
          sigi234S Online
          sigi234
          @Torsten_MG
          Bitte sehr, du solltes den bridge key löschen.....
          • sigi234S sigi234
            @Torsten_MG
            @sigi234
            ich hoffe ich habe das jetzt gemacht
              @sigi234
              sigi234S Online
              sigi234S Online
              sigi234
              @Homoran
              Bist ja schneller als die Feuerwehr..........☺
              • sigi234S sigi234
                @Homoran
                @sigi234 🚒
                  Torsten_MG
                  Nochmals Danke ☺
                  • T Torsten_MG
                    Nochmals Danke ☺
                    sigi234S Online
                    sigi234S Online
                    sigi234
                    @Torsten_MG sagte in [gelöst] Hue Bewegungsmelder probleme mit lux:
                    Nochmals Danke ☺
                    Benutzt das Voting rechts unten im Beitrag wenn er euch geholfen hat.😉
