  4. MQTT Bluetooth BLE Anwesenheitserkennung mit ESP32
    5.1k
242 Beiträge 26 Kommentatoren 55.6k Aufrufe 32 Beobachtet
  • B Banis
    ich bekomme es leider nicht hin den Sketch zu kompilieren. Bei Kompilieren erhalte ich immer folgende Fehlermeldung:
    Arduino: 1.8.19 (Windows 10), Board: "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, None"
    C:\Users\Andy\Downloads\1603999752128-mqtt_anwesenheit_ota.ino\mqtt_anwesenheit_ota\mqtt_anwesenheit_ota.ino: In function 'void setup()':
    mqtt_anwesenheit_ota:226:8: error: 'class PubSubClient' has no member named 'set_server'
       mqtt.set_server(MQTT_server, MQTT_port); // MQTT Port einstellen
    mqtt_anwesenheit_ota:228:29: error: no matching function for call to 'PubSubClient::connect(String&)'
       if (mqtt.connect(MQTT_Name))
    In file included from C:\Users\Andy\Downloads\1603999752128-mqtt_anwesenheit_ota.ino\mqtt_anwesenheit_ota\mqtt_anwesenheit_ota.ino:34:0:
    C:\Users\Andy\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:112:12: note: candidate: boolean PubSubClient::connect(const char*)
        boolean connect(const char* id);
    C:\Users\Andy\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:112:12: note:   no known conversion for argument 1 from 'String' to 'const char*'
    C:\Users\Andy\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:113:12: note: candidate: boolean PubSubClient::connect(const char*, const char*, const char*)
        boolean connect(const char* id, const char* user, const char* pass);
    C:\Users\Andy\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:113:12: note:   candidate expects 3 arguments, 1 provided
    C:\Users\Andy\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:114:12: note: candidate: boolean PubSubClient::connect(const char*, const char*, uint8_t, boolean, const char*)
        boolean connect(const char* id, const char* willTopic, uint8_t willQos, boolean willRetain, const char* willMessage);
    C:\Users\Andy\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:114:12: note:   candidate expects 5 arguments, 1 provided
    C:\Users\Andy\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:115:12: note: candidate: boolean PubSubClient::connect(const char*, const char*, const char*, const char*, uint8_t, boolean, const char*)
        boolean connect(const char* id, const char* user, const char* pass, const char* willTopic, uint8_t willQos, boolean willRetain, const char* willMessage);
    C:\Users\Andy\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:115:12: note:   candidate expects 7 arguments, 1 provided
    mqtt_anwesenheit_ota:231:18: error: 'MQTT' has not been declared
         mqtt.publish(MQTT::Publish("hallo", MQTT_Name).set_qos(QoS)); // im Topic hallo Präsenzmelder Name schreiben
    C:\Users\Andy\Downloads\1603999752128-mqtt_anwesenheit_ota.ino\mqtt_anwesenheit_ota\mqtt_anwesenheit_ota.ino: In function 'void loop()':
    mqtt_anwesenheit_ota:271:16: error: 'MQTT' has not been declared
       mqtt.publish(MQTT::Publish(MQTT_Name, NachrichtJSON).set_qos(QoS)); // JSON per MQTT senden
    mqtt_anwesenheit_ota:283:27: error: no matching function for call to 'PubSubClient::connect(String&)'
         mqtt.connect(MQTT_Name);
    Mehrere Bibliotheken wurden für "WiFi.h" gefunden
     Benutzt: C:\Users\Andy\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\libraries\WiFi
     Nicht benutzt: C:\Program Files (x86)\Arduino\libraries\WiFi
    exit status 1
    Weiß jemand was ich hier machen kann?
    GiuseppeS
    #121
    @banis
    Wozu überhaupt noch diesen Sketch verwenden? Espresense funktioniert ganz gut.
    B S 2 Antworten Letzte Antwort
    • G GiuseppeS
      @banis
      Banis
      #122
      @giuseppes Super vielen Dank das funktioniert mit Espresense ja mega einfach.
      • G Offline
        Grace13
        #123
        Welche Hardware nutzt ihr? Bzw welchen ESP32 sollte man denn kaufen? Bin von den verschiedenen Varianten auf Aliexpress etwas irritiert..
        amg_666A OpenSourceNomadO 2 Antworten Letzte Antwort
        • G Grace13
          amg_666A Offline
          amg_666A Offline
          amg_666
          #124
          @grace13 Also bei mir läuft es mittlerweile ganz gut und ich benutze D1Mini von A-Z Delivery. Die sind da nicht sooo viel teurer als "beim Chinesen" und du hast kürzere Lieferzeiten und Garantie, bzw die sind eh sehr kulant.
          Link auf die Homepage
          Und wenn du dich da für den Newsletter einträgst kriegst du täglich irgendwelche Angebote, oft auch D1 Mini als Mehrfachpackung
          • G Grace13
            OpenSourceNomadO Offline
            OpenSourceNomad
            Most Active Gesperrt
            #125
            @grace13 said in MQTT Bluetooth BLE Anwesenheitserkennung mit ESP32:
            @amg_666 said in MQTT Bluetooth BLE Anwesenheitserkennung mit ESP32:
            Einziges Manko: Der gute D1 Mini hat einen esp82xx und keinen esp32. Sprich kein BLE an board und deswegen gänzlich ungeeignet für den gewünschten Einsatzzweck hier.
            • amg_666A Offline
              amg_666A Offline
              amg_666
              #126
              @opensourcenomad Sorry, dann hab ich den falschen verlinkt: "D1 Mini" Ausführung und auch in größerer Bauform
              • G Offline
                Grace13
                #127
                @amg_666 wurde mit ESPresense geflasht und funktioniert soweit, die Daten kommen am MQTT Adapter an. Ich hätte aber noch eine Frage.
                Meine Bluetooth Mac Adresse vom Handy habe ich in "Known BLE mac addresses" eingetragen.
                Im MQTT Adapter bekomme ich nun bestimmt über 20 Geräte angezeigt, allerdings ist keins mein Gerät. Wo liegt denn der Fehler?
                • OpenSourceNomadO Offline
                  OpenSourceNomad
                  #128
                  Mobilfunkdelefone neuerer Generationen, bzw. deren software randomisiert meist die mac Adressen der WLAN und Bluetooth interfaces (wenn diese passiv/nicht verbunden sind) um ein tracking für "Mitbewerber" zu erschweren.
                  Eventuell macht dir diese Funktion gerade das leben schwer? 🤔
                  G 1 Antwort Letzte Antwort
                  • OpenSourceNomadO OpenSourceNomad
                    Grace13
                    #129
                    @opensourcenomad hm okay, danke für die Info, dann werde ich es mal mit meiner galaxy watch versuchen.
                    OpenSourceNomadO 1 Antwort Letzte Antwort
                    • G Grace13
                      OpenSourceNomad
                      schrieb am zuletzt editiert von OpenSourceNomad
                      #130
                      danke für die Info
                      Hätte ja Ansporn sein können kurz 20 Sekunden Internetrecherche zu betreiben und z.B. folgendes, für Androiden gültiges, Wissen zu erlangen:
                      For devices running Android 10 or higher, the framework uses randomized MAC address by default. Users can enable or disable MAC randomization for individual networks through an option in the Network details screen in Settings, as shown in Figure 1. If a user disables MAC randomization for a network, the framework uses the factory MAC address (globally unique address).
                      Quelle: https://source.android.com/devices/tech/connect/wifi-mac-randomization-behavior
                      ..und wer genau liest sieht es geht nur um wifi 😬 ☝
                      • G GiuseppeS
                        @banis
                        Spezialtrick
                        #131
                        Hallo @giuseppes,
                        die Installation mit ESPresence funktioniert wirklich gut. Wie verarbeitest du die Werte aktuell weiter?
                        Nach langem hin und her denke ich, dass mir eine einfache Erkennung reichen würde, ob ein Gerät anwesend ist oder nicht.
                        LG
                        • S Spezialtrick
                          Hallo @giuseppes,
                          LG
                          GiuseppeS
                          #132
                          @spezialtrick
                          Ich habe das Thema Triangulation erstmal pausiert, weil mir die Werte zu stark streuen.
                          Ich habe ein esp32 im Schlafzimmer, eins in der Küche und eins neben der Couch im Wohnzimmer. Damit arbeite ich nun. Ohne viel drum herum, d.h. keine Skripte oder ähnliches, was noch viel verarbeitet. Wenn Distanz kleiner 2,5 Meter von einem esp32, dann bin ich genau da.
                          G S amg_666A 3 Antworten Letzte Antwort
                          • G GiuseppeS
                            @spezialtrick
                            Grace13
                            #133
                            @giuseppes wie verarbeitest du die Werte von ESPresense im IoBroker? Bzwe welchen Datenpunkt verwendest du? Bin etwas ratlos was bzw welchen Wert ich nutzen soll.
                            • G GiuseppeS
                              @spezialtrick
                              Spezialtrick
                              #134
                              @giuseppes
                              Vllt. eine blöde Frage, aber ich bin noch nicht so lange mit dem IOBroker befasst... Wie bekommst du die Werte aus dem JSON heraus bzw. wie könnte man sie in einem Skript weiterverarbeiten.
                              • G GiuseppeS
                                @spezialtrick
                                amg_666A Offline
                                amg_666A Offline
                                amg_666
                                #135
                                @giuseppes sagte in MQTT Bluetooth BLE Anwesenheitserkennung mit ESP32:
                                So wollte ich das eigentlich auch lösen. Problem: Ein ESP ist in einem Raum im OG und einer in einem Kellerraum. Wenn ich mich relativ schnell OG in den Keller begebe, dann wird zwar der Wert vom ESP im Keller aktualisiert (Distanz kleiner xx) aber der Wert im OG wird nicht aktualisiert (zu weit entfernt) und dann ist da auch die (alte) Distanz <xx. Irgendeine Idee, wie man da einen Lösungsansatz findet? Ich bin am überlegen ob ich die Zeitstempel mit auswerte, aber vielleicht gibts da ja noch ne andere Lösung...
                                • S Spezialtrick
                                  @giuseppes
                                  GiuseppeS
                                  #136
                                  @spezialtrick
                                  Ich verwende den Wert "distance" aus dem JSON
                                  • amg_666A amg_666
                                    GiuseppeS
                                    #137
                                    @amg_666
                                    Mir fällt auch nur ein, den Zeitstempel mit auszuwerten
                                    • G GiuseppeS
                                      @amg_666
                                      da.phreak
                                      #138
                                      Hier gibt's noch eine Firmware von mir zum Scannen von BLE Geräten:
                                      https://github.com/technyon/blescanner
                                      Ist ein Spin-off von meiner NUKI Firmware (https://forum.iobroker.net/topic/53754/nuki-hub), die auch scannen kann. Die Geräte werden über MQTT als CSV gemeldet. Javascript bzw. Typescript zum Parsen findet sich hier:
                                      https://forum.iobroker.net/topic/53754/nuki-hub/30
                                      Binaries sind auf Github vorhanden, diese müssen nur geflashed werden. Die Konfiguration von WiFi und MQTT erfolgt dann über Web-Interface.
                                      • U Offline
                                        U Offline
                                        Utze86
                                        #139
                                        Hi zusammen, ich bin neu hier im Forum und möchte mich dem Thema einmal anschließen. Den Thread zu lesen hat mich bereits wesentlich weiter gebracht. Ein paar Fragen tun sich mir allerdings auf.
                                        Ist bekannt ob das ganze Verfahren mit ESPresense auch auf dem Shelly 1 Plus funktioniert ohne dessen Funktion als Schalter zu beeinträchtigen? Der Shelly 1 Plus verfügt ja über einen ESP32. Für mich wäre das Ganze in sofern interessant, da ich mein Haus eh mit den Shellys ausstatten möchte. Dadurch könnte ich es mir ersparen die ganzen ESP's an diversen Steckdosen im Haus zu verteilen.
                                        Alternativ könnte ich mir eine Batterie- / Akkulösung für die ESP's vorstellen um die ESP's in Schränken und Schubladen unterzubringen. Hat hier jemand Erfahrung wie lange entsprechende Akkus/Batterien für die Anwesenheitserkennung mit dem ESP32 halten?
                                        Viele Grüße
                                        Utze86
                                        D G 2 Antworten Letzte Antwort
                                        • U Utze86
                                          Viele Grüße
                                          Utze86
                                          da.phreak
                                          #140
                                          @utze86 Das wird mit Batterien nicht funktionieren. Um sinnvoll Anwesenheitserkennung zu betreiben, kann der ESP nicht in den deep sleep gehen. Da sind Batterien ziemlich schnell leer.
