  4. MQTT Bluetooth BLE Anwesenheitserkennung mit ESP32
242 Beiträge 26 Kommentatoren 57.5k Aufrufe 32 Beobachtet
  • amg_666A amg_666
    @giuseppes
    Der tuts bei mir leider auch nicht. ESP32 geflasht, wlan und mqtt einstellungen eingegeben, soweit alles gut, aber dann bei Neustart des esp:
    [23:45:21]rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    [23:45:21]configsip: 0, SPIWP:0xee
    [23:45:21]clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
    [23:45:21]mode:DIO, clock div:2
    [23:45:22]load:0x3fff0018,len:4
    [23:45:22]load:0x3fff001c,len:1044
    [23:45:22]load:0x40078000,len:8896
    [23:45:22]load:0x40080400,len:5828
    [23:45:22]entry 0x400806ac
    [23:45:22]Connecting to WiFi (F0:08:D1:D8:0A:04)...
    [23:45:24]Connecting to WiFi SSID 'WLAN-772776'...............192.168.2.182
    [23:45:24]Version:     v2.0.26
    [23:45:24]IP address:   192.168.2.182
    [23:45:24]DNS address:  192.168.2.1
    [23:45:24]Hostname:     espresense-arbeitszimmer
    [23:45:24]Room:         Arbeitszimmer
    [23:45:25]Max Distance: 16.00
    [23:45:25]Telemetry:    enabled
    [23:45:25]Rooms:        enabled
    [23:45:25]Devices:      enabled
    [23:45:25]Discovery:    disabled
    [23:45:25]PIR Sensor:   disabled
    [23:45:25]Radar Sensor: disabled
    [23:45:25]Query:
    [23:45:25]Include:
    [23:45:25]Exclude:
    [23:45:25]Connecting to MQTT 192.168.2.23 1883
    [23:45:29]0 New   | MAC: f54207d89c63, ID: mifit:f54207d89c63
    [23:45:30]E (8070) task_wdt: Task watchdog got triggered. The following tasks did not reset the watchdog in time:
    [23:45:30]E (8070) task_wdt:  - IDLE0 (CPU 0)
    [23:45:30]E (8070) task_wdt: Tasks currently running:
    [23:45:30]E (8070) task_wdt: CPU 0: BLE Scan
    [23:45:30]E (8070) task_wdt: CPU 1: IDLE1
    [23:45:30]E (8070) task_wdt: Aborting.
    [23:45:30]abort() was called at PC 0x4018b210 on core 0
    [23:45:30]
    [23:45:30]ELF file SHA256: 0000000000000000
    [23:45:30]
    [23:45:32]Backtrace: 0x4008f658:0x3ffbfee0 0x4008f8d5:0x3ffbff00 0x4018b210:0x3ffbff20 0x4008dd01:0x3ffbff40 0x4000bfed:0x3ffde350 0x40091a59:0x3ffde360 0x40093c4f:0x3ffde380 0x400943fb:0x3ffde3a0 0x40081e6e:0x3ffde3c0 0x40086bd5:0x3ffde3e0 0x4000bec7:0x3ffde400 0x401a9e65:0x3ffde420 0x400d3029:0x3ffde440 0x400d7355:0x3ffde460 0x400908e6:0x3ffde4e0
    [23:45:32]
    [23:45:32]Rebooting...
    Zu der "Task watchdog got triggered." gibts zwar diverse Treffer bei google, ich hab aber nix gefunden was mir weiterhilft
    M Online
    M Online
    mrjeschke
    schrieb am zuletzt editiert von mrjeschke
    #114
    @amg_666
    Nimm mal die v2.0.25. Die v2.0.26 hat wahrscheinlich einen Bug.
    Und automatische Updates deaktivieren.
    • M mrjeschke
      @amg_666
      amg_666A Offline
      amg_666A Offline
      amg_666
      #115
      @maik-0 ich befürchte, dass der esp eine Macke hat. Mit der v2.0.25 komme ich nicht ins WLAN
      [11:12:48]rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
      [11:12:48]configsip: 0, SPIWP:0xee
      [11:12:48]clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
      [11:12:48]mode:DIO, clock div:2
      [11:12:48]load:0x3fff0018,len:4
      [11:12:48]load:0x3fff001c,len:1044
      [11:12:49]load:0x40078000,len:8896
      [11:12:49]load:0x40080400,len:5828
      [11:12:49]entry 0x400806ac
      [11:12:49]Connecting to WiFi (F0:08:D1:D8:0A:04)...
      [11:13:43]Connecting to WiFi SSID 'WLAN-772776'.........................................................................................................................................................................................................................................................................................................................................................................ets Jun  8 2016 00:22:57
      [11:13:43]
      [11:13:43]rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
      [11:13:43]configsip: 0, SPIWP:0xee
      [11:13:44]clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
      [11:13:44]mode:DIO, clock div:2
      [11:13:44]load:0x3fff0018,len:4
      [11:13:44]load:0x3fff001c,len:1044
      [11:13:44]load:0x40078000,len:8896
      [11:13:44]load:0x40080400,len:5828
      [11:13:44]entry 0x400806ac
      [11:13:44]Connecting to WiFi (F0:08:D1:D8:0A:04)...
      [11:14:44]Connecting to WiFi SSID 'WLAN-772776'................................................................................................................................................................................................................................................................................................................................................................................................................ failed.
      [11:14:44]Starting access point for configuration portal.
      [11:14:44]SSID: 'espresense-arbeitszimmer'
      [11:14:44]IP: 192.168.4.1
      [11:16:19][E][WiFiClient.cpp:395] write(): fail on fd 56, errno: 104, "Connection reset by peer"
      Die Einstellungen habe ich mehrfach überprüft, PAsswort für WLAN und mqtt-Einstellungen sind korrekt.
      • amg_666A Offline
        amg_666A Offline
        amg_666
        schrieb am zuletzt editiert von amg_666
        #116
        Ich muss nochmal fragen: Neue ESP bestellt, geflasht, läuft.
        .Ich hab jetzt einen ESP im Netz, der erkennt auch mein Mi Band:
        Das Mi Band sehe ich jetzt auch in den Objekten, soweit alles gut. Wenn ich jetzt weitere BT devices habe, wie kann ich dann bestimmte devices explizit als "excluded" eintragen?
        G 1 Antwort Letzte Antwort
        • amg_666A amg_666
          GiuseppeS
          #117
          @amg_666
          Exclude müsste von der Firmware espresense umgesetzt werden. Das ist bis jetzt noch nicht geschehen. Hatte mal ein Issue dazu auf github gesehen. Das solltest du verfolgen.
          • G GiuseppeS
            @amg_666
            amg_666A Offline
            amg_666A Offline
            amg_666
            #118
            @giuseppes sagte in MQTT Bluetooth BLE Anwesenheitserkennung mit ESP32:
            Danke für die Info.
            ich hab jetzt nmoch ein Problem bzw eine Frage: Zum Testen habe ich 3 ESP geflasht und die in 3 Etagen angeschlossen. Final soll das mal so fein werden, dass ich den Raum einer Person (respektive des Devices) mitbekomme und dann individuell Licht/Musik etc steuern kann.
            Samsung Smartphone: Quasselt regelmäßig mit den ESPs, ich werte die Entfernungen aus und die niedrigste Entfernung ist dann die Etage wo das Handy grade ist. Funktioniert ohne Probleme (na ja fast, die Entfernungsermittlung ist schon ziemlich ungenau, aber im großen und ganzen ok).
            Fitnessband (mi 3 Band): Das hatte ich gestern getestet und auch da wurden die Datenpunkte der ESP regelmäßig upgedatet. Heute morgen war da "Funkstille" (im wahrsten Sinne des Wortes). Ich hab dann mal die ESP resettet, den mqtt Adapter neu gestartet und irgendwann liefs wieder gut. Jetzt ist wieder Stillstand und es wird nichts upgedatet.
            Sind diese einfachen Fitnessbänder so unzuverlässig oder woran kann das liegen? Das Samsung ist fröhlich am aktualisieren...
            • amg_666A amg_666
              Danke für die Info.
              GiuseppeS
              #119
              @amg_666
              Ich verwendete zu Testzwecken mein miband5 bzw 6 und da gab es nie Probleme, wie du sie beschreibst. Grundsätzlich wurde immer gesendet. Über mehrere Wochen hatte ich teilweise getestet.
              • G GiuseppeS
                @amg_666
                Banis
                #120
                ich bekomme es leider nicht hin den Sketch zu kompilieren. Bei Kompilieren erhalte ich immer folgende Fehlermeldung:
                Arduino: 1.8.19 (Windows 10), Board: "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, None"
                C:\Users\Andy\Downloads\1603999752128-mqtt_anwesenheit_ota.ino\mqtt_anwesenheit_ota\mqtt_anwesenheit_ota.ino: In function 'void setup()':
                mqtt_anwesenheit_ota:226:8: error: 'class PubSubClient' has no member named 'set_server'
                   mqtt.set_server(MQTT_server, MQTT_port); // MQTT Port einstellen
                mqtt_anwesenheit_ota:228:29: error: no matching function for call to 'PubSubClient::connect(String&)'
                   if (mqtt.connect(MQTT_Name))
                In file included from C:\Users\Andy\Downloads\1603999752128-mqtt_anwesenheit_ota.ino\mqtt_anwesenheit_ota\mqtt_anwesenheit_ota.ino:34:0:
                C:\Users\Andy\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:112:12: note: candidate: boolean PubSubClient::connect(const char*)
                    boolean connect(const char* id);
                C:\Users\Andy\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:112:12: note:   no known conversion for argument 1 from 'String' to 'const char*'
                C:\Users\Andy\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:113:12: note: candidate: boolean PubSubClient::connect(const char*, const char*, const char*)
                    boolean connect(const char* id, const char* user, const char* pass);
                C:\Users\Andy\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:113:12: note:   candidate expects 3 arguments, 1 provided
                C:\Users\Andy\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:114:12: note: candidate: boolean PubSubClient::connect(const char*, const char*, uint8_t, boolean, const char*)
                    boolean connect(const char* id, const char* willTopic, uint8_t willQos, boolean willRetain, const char* willMessage);
                C:\Users\Andy\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:114:12: note:   candidate expects 5 arguments, 1 provided
                C:\Users\Andy\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:115:12: note: candidate: boolean PubSubClient::connect(const char*, const char*, const char*, const char*, uint8_t, boolean, const char*)
                    boolean connect(const char* id, const char* user, const char* pass, const char* willTopic, uint8_t willQos, boolean willRetain, const char* willMessage);
                C:\Users\Andy\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:115:12: note:   candidate expects 7 arguments, 1 provided
                mqtt_anwesenheit_ota:231:18: error: 'MQTT' has not been declared
                     mqtt.publish(MQTT::Publish("hallo", MQTT_Name).set_qos(QoS)); // im Topic hallo Präsenzmelder Name schreiben
                C:\Users\Andy\Downloads\1603999752128-mqtt_anwesenheit_ota.ino\mqtt_anwesenheit_ota\mqtt_anwesenheit_ota.ino: In function 'void loop()':
                mqtt_anwesenheit_ota:271:16: error: 'MQTT' has not been declared
                   mqtt.publish(MQTT::Publish(MQTT_Name, NachrichtJSON).set_qos(QoS)); // JSON per MQTT senden
                mqtt_anwesenheit_ota:283:27: error: no matching function for call to 'PubSubClient::connect(String&)'
                     mqtt.connect(MQTT_Name);
                Mehrere Bibliotheken wurden für "WiFi.h" gefunden
                 Benutzt: C:\Users\Andy\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\libraries\WiFi
                 Nicht benutzt: C:\Program Files (x86)\Arduino\libraries\WiFi
                exit status 1
                Weiß jemand was ich hier machen kann?
                • B Banis
                  exit status 1
                  GiuseppeS
                  #121
                  @banis
                  Wozu überhaupt noch diesen Sketch verwenden? Espresense funktioniert ganz gut.
                  B S 2 Antworten Letzte Antwort
                  • G GiuseppeS
                    @banis
                    Banis
                    #122
                    @giuseppes Super vielen Dank das funktioniert mit Espresense ja mega einfach.
                    • G Offline
                      Grace13
                      #123
                      Welche Hardware nutzt ihr? Bzw welchen ESP32 sollte man denn kaufen? Bin von den verschiedenen Varianten auf Aliexpress etwas irritiert..
                      amg_666A OpenSourceNomadO 2 Antworten Letzte Antwort
                      • G Grace13
                        amg_666A Offline
                        amg_666A Offline
                        amg_666
                        #124
                        @grace13 Also bei mir läuft es mittlerweile ganz gut und ich benutze D1Mini von A-Z Delivery. Die sind da nicht sooo viel teurer als "beim Chinesen" und du hast kürzere Lieferzeiten und Garantie, bzw die sind eh sehr kulant.
                        Link auf die Homepage
                        Und wenn du dich da für den Newsletter einträgst kriegst du täglich irgendwelche Angebote, oft auch D1 Mini als Mehrfachpackung
                        • G Grace13
                          OpenSourceNomadO Offline
                          OpenSourceNomad
                          Most Active Gesperrt
                          #125
                          @grace13 said in MQTT Bluetooth BLE Anwesenheitserkennung mit ESP32:
                          @amg_666 said in MQTT Bluetooth BLE Anwesenheitserkennung mit ESP32:
                          Einziges Manko: Der gute D1 Mini hat einen esp82xx und keinen esp32. Sprich kein BLE an board und deswegen gänzlich ungeeignet für den gewünschten Einsatzzweck hier.
                          • amg_666A Offline
                            amg_666A Offline
                            amg_666
                            #126
                            @opensourcenomad Sorry, dann hab ich den falschen verlinkt: "D1 Mini" Ausführung und auch in größerer Bauform
                            • G Offline
                              Grace13
                              #127
                              @amg_666 wurde mit ESPresense geflasht und funktioniert soweit, die Daten kommen am MQTT Adapter an. Ich hätte aber noch eine Frage.
                              Meine Bluetooth Mac Adresse vom Handy habe ich in "Known BLE mac addresses" eingetragen.
                              Im MQTT Adapter bekomme ich nun bestimmt über 20 Geräte angezeigt, allerdings ist keins mein Gerät. Wo liegt denn der Fehler?
                              • OpenSourceNomadO Offline
                                OpenSourceNomad
                                #128
                                Mobilfunkdelefone neuerer Generationen, bzw. deren software randomisiert meist die mac Adressen der WLAN und Bluetooth interfaces (wenn diese passiv/nicht verbunden sind) um ein tracking für "Mitbewerber" zu erschweren.
                                Eventuell macht dir diese Funktion gerade das leben schwer? 🤔
                                • OpenSourceNomadO OpenSourceNomad
                                  Grace13
                                  #129
                                  @opensourcenomad hm okay, danke für die Info, dann werde ich es mal mit meiner galaxy watch versuchen.
                                  OpenSourceNomadO 1 Antwort Letzte Antwort
                                  • G Grace13
                                    OpenSourceNomad
                                    schrieb am zuletzt editiert von OpenSourceNomad
                                    #130
                                    danke für die Info
                                    Hätte ja Ansporn sein können kurz 20 Sekunden Internetrecherche zu betreiben und z.B. folgendes, für Androiden gültiges, Wissen zu erlangen:
                                    For devices running Android 10 or higher, the framework uses randomized MAC address by default. Users can enable or disable MAC randomization for individual networks through an option in the Network details screen in Settings, as shown in Figure 1. If a user disables MAC randomization for a network, the framework uses the factory MAC address (globally unique address).
                                    Quelle: https://source.android.com/devices/tech/connect/wifi-mac-randomization-behavior
                                    ..und wer genau liest sieht es geht nur um wifi 😬 ☝
                                    • G GiuseppeS
                                      @banis
                                      Spezialtrick
                                      #131
                                      Hallo @giuseppes,
                                      die Installation mit ESPresence funktioniert wirklich gut. Wie verarbeitest du die Werte aktuell weiter?
                                      Nach langem hin und her denke ich, dass mir eine einfache Erkennung reichen würde, ob ein Gerät anwesend ist oder nicht.
                                      LG
                                      • S Spezialtrick
                                        Hallo @giuseppes,
                                        LG
                                        GiuseppeS
                                        #132
                                        @spezialtrick
                                        Ich habe das Thema Triangulation erstmal pausiert, weil mir die Werte zu stark streuen.
                                        Ich habe ein esp32 im Schlafzimmer, eins in der Küche und eins neben der Couch im Wohnzimmer. Damit arbeite ich nun. Ohne viel drum herum, d.h. keine Skripte oder ähnliches, was noch viel verarbeitet. Wenn Distanz kleiner 2,5 Meter von einem esp32, dann bin ich genau da.
                                        G S amg_666A 3 Antworten Letzte Antwort
                                        • G GiuseppeS
                                          @spezialtrick
                                          Grace13
                                          #133
                                          @giuseppes wie verarbeitest du die Werte von ESPresense im IoBroker? Bzwe welchen Datenpunkt verwendest du? Bin etwas ratlos was bzw welchen Wert ich nutzen soll.
