  4. [Aufruf] Neuer Adapter ioBroker.tuya (WLAN devices Tuya Smart Life und andere)
547 Beiträge 97 Kommentatoren 209.6k Aufrufe 20 Beobachtet
    madd268hotmail.de
    #121
    <code>tuya.0 new Shema added for product type HPiNfakVX1Z9hWsO. Please send next line from logfile on disk to developer!
    2018-11-14 21:43:04.500 - info: tuya.0 {"schema":"[{\"mode\":\"rw\",\"code\":\"switch_on\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power3\",\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"countdown\",\"name\":\"延迟\",\"property\":{\"unit\":\"秒\",\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":2,\"type\":\"obj\",\"passive\":true,\"desc\":\"\"},{\"mode\":\"ro\",\"code\":\"add_ele\",\"name\":\"电量\",\"property\":{\"unit\":\"度\",\"min\":0,\"max\":500000,\"scale\":3,\"step\":100,\"type\":\"value\"},\"id\":3,\"type\":\"obj\",\"desc\":\"上报的为放大100倍之后的值,即上报56,实际值为0.56度\"},{\"mode\":\"ro\",\"code\":\"cur_current\",\"name\":\"电流\",\"property\":{\"unit\":\"mA\",\"min\":0,\"max\":30000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":4,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"ro\",\"code\":\"cur_power\",\"name\":\"功率\",\"property\":{\"unit\":\"W\",\"min\":0,\"max\":50000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":5,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"ro\",\"code\":\"cur_voltage\",\"name\":\"电压\",\"property\":{\"unit\":\"V\",\"min\":0,\"max\":2500,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":6,\"type\":\"obj\",\"desc\":\"\"}]","schemaExt":"[]"}
    2018-11-14 21:43:04.501 - info: tuya.0 new Shema added for product type n8iVBAPLFKAAAszH. Please send next line from logfile on disk to developer!
    2018-11-14 21:43:04.501 - info: tuya.0 {"schema":"[{\"mode\":\"rw\",\"code\":\"switch_on\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power2\",\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"countdown\",\"name\":\"倒计时\",\"property\":{\"unit\":\"秒\",\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"iconname\":\"icon-dp_time\",\"id\":2,\"type\":\"obj\",\"passive\":true,\"desc\":\"\"}]","schemaExt":"[{\"id\":2,\"inputType\":\"\"}]"}
    2018-11-14 21:43:04.502 - info: tuya.0 new Shema added for product type ocNB89IgPygEpdnE. Please send next line from logfile on disk to developer!
    2018-11-14 21:43:04.502 - info: tuya.0 {"schema":"[{\"mode\":\"ro\",\"code\":\"switch\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"id\":101,\"type\":\"obj\",\"desc\":\"上报门窗开关状态\"},{\"mode\":\"ro\",\"code\":\"TamperedAlarm\",\"name\":\"防拆报警\",\"property\":{\"type\":\"bool\"},\"id\":102,\"type\":\"obj\",\"desc\":\"mcu 上报拆除信息\"},{\"mode\":\"ro\",\"code\":\"Battery\",\"name\":\"电池电量\",\"property\":{\"unit\":\"%\",\"min\":0,\"max\":100,\"scale\":0,\"step\":10,\"type\":\"value\"},\"id\":103,\"type\":\"obj\",\"desc\":\"mcu 上报电池电量信息\"},{\"mode\":\"ro\",\"code\":\"state\",\"name\":\"状态\",\"property\":{\"type\":\"bool\"},\"id\":105,\"type\":\"obj\",\"desc\":\"上报产品是“休眠”还是“离线”\"}]","schemaExt":"[]"}
    2018-11-14 21:43:04.502 - info: tuya.0 new Shema added for product type PUyaDrOGMhJfCExd. Please send next line from logfile on disk to developer!
    2018-11-14 21:43:04.503 - info: tuya.0 {"schema":"[{\"mode\":\"rw\",\"code\":\"switch_on\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power\",\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"countdown\",\"name\":\"倒计时\",\"property\":{\"unit\":\"秒\",\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":2,\"type\":\"obj\",\"passive\":true,\"desc\":\"\"},{\"mode\":\"ro\",\"code\":\"add_ele\",\"name\":\"增加电量\",\"property\":{\"unit\":\"度\",\"min\":0,\"max\":50000,\"scale\":3,\"step\":100,\"type\":\"value\"},\"id\":3,\"trigger\":\"direct\",\"type\":\"obj\",\"desc\":\"上报的为放大1000倍之后的值,即上报56,实际值为0.056度\"},{\"mode\":\"ro\",\"code\":\"cur_current\",\"name\":\"当前电流\",\"property\":{\"unit\":\"mA\",\"min\":0,\"max\":30000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":4,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"ro\",\"code\":\"cur_power\",\"name\":\"当前功率\",\"property\":{\"unit\":\"W\",\"min\":0,\"max\":50000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":5,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"ro\",\"code\":\"cur_voltage\",\"name\":\"当前电压\",\"property\":{\"unit\":\"V\",\"min\":0,\"max\":2500,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":6,\"type\":\"obj\",\"desc\":\"\"}]","schemaExt":"[{\"id\":2,\"inputType\":\"\"},{\"id\":3,\"inputType\":\"\"},{\"id\":4,\"inputType\":\"\"},{\"id\":5,\"inputType\":\"\"},{\"id\":6,\"inputType\":\"\"}]"}</code>
      RKBroker
      #122
      Mal wieder etwas neues:
      <code>2018-11-15 23:56:34.240  - [32minfo[39m: tuya.0 new Shema added for product type r15JnoGqWPM4PPtl. Please send next line from logfile on disk to developer!
      2018-11-15 23:56:34.240  - [32minfo[39m: tuya.0 {"schema":"[{\"mode\":\"rw\",\"code\":\"switch_1\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power2\",\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"countdown\",\"name\":\"倒计时\",\"property\":{\"unit\":\"秒\",\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"iconname\":\"icon-dp_time2\",\"id\":11,\"type\":\"obj\",\"desc\":\"可根据产品实际倒计时功能修改。\"}]","schemaExt":"[]"}[/code]</code>
        rewenode
        #123
        und noch einer:
        3fach Steckdosenleiste mit 4er USB
        https://de.aliexpress.com/item/Smart-Wi … 4c4djD7d7L
        <code>2018-11-16 00:28:39.644 - info: tuya.0 new Shema added for product type JtCDjzmKcUNKEBzO. Please send next line from logfile on disk to developer!
        2018-11-16 00:28:39.645 - info: tuya.0 {"schema":"[{\"mode\":\"rw\",\"code\":\"switch_s1\",\"name\":\"开关1\",\"property\":{\"type\":\"bool\"},\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"switch_s2\",\"name\":\"开关 2\",\"property\":{\"type\":\"bool\"},\"id\":2,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"switch_s3\",\"name\":\"开关 3\",\"property\":{\"type\":\"bool\"},\"id\":3,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"switch_usb1\",\"name\":\"USB\",\"property\":{\"type\":\"bool\"},\"id\":4,\"type\":\"obj\",\"desc\":\"switch_s4修改为switch_usb1\"}]","schemaExt":"[]"}[/code]</code>
        • apollon77A Offline
          #124
          Danke, sind jetzt alle in der 1.0.4 drin.
          • sigi234S Online
            sigi234S Online
            sigi234
            #125
            Hallo Apollon77,
            Nächste Woche bekomme ich wieder ein Spielzeug für die Weihnachtsbeleuchtung…...
            Ich hoffe sie funktioniert mit deinen Adapter. :)
            Heute bekommen, Funktioniert!
            Immer Daten sichern!
              #126
              Gute Chancen ;-)
              Gesendet vom Handy …
              • ElzersharkE Offline
                ElzersharkE Offline
                Elzershark
                #127
                Die Steckdose funzt. Hab die installiert. Die müsste auch schon integriert sein, da ich kein neues schema bekomme
                https://www.youtube.com/c/Elzershark
                https://t.me/joinchat/BD87n3xMU0QzYmUy
                https://www.facebook.com/elzershark
                • sigi234S Online
                  sigi234S Online
                  sigi234
                  #128
                  COOL, mit Verbrauchswerte?
                    RKBroker
                    #129
                    Thr next one….
                    <code>2018-11-16 21:50:27.144  - [32minfo[39m: tuya.0 new Shema added for product type r15JnoGqWPM4PPtl. Please send next line from logfile on disk to developer!
                    2018-11-16 21:50:27.145  - [32minfo[39m: tuya.0 {"schema":"[{\"mode\":\"rw\",\"code\":\"switch_1\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power2\",\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"countdown\",\"name\":\"倒计时\",\"property\":{\"unit\":\"秒\",\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"iconname\":\"icon-dp_time2\",\"id\":11,\"type\":\"obj\",\"desc\":\"可根据产品实际倒计时功能修改。\"}]","schemaExt":"[]"}[/code]</code>
                    • FredFF Online
                      FredFF Online
                      FredF
                      Most Active Forum Testing
                      #130
                      Also ich möchte auch mal danke für diesen Adapter sagen…
                      Bisher hatte ich die Teckin SP22 Steckdosen mit Tasmota geflasht. Nachdem aber nun die neuen SP22 nicht mehr geschraubt sind, das öffnen sch... ist und wenn dann mal offen die Kabel so kurz sind, das man ohne die Platine auslöten nicht an den ESP kommt und dann noch Probleme beim flashen bekommt :x
                      Wenn man das mal mit dem Proxy geschnallt hat, ist mir der Tuya Adapter doch lieber.
                      Nur leider bekomme ich keine wh oder kwh aus der Teckin. Wenn das auch noch gehen würde... ;)
                        RKBroker
                        #131
                        Tja, die wh bzw. kwh darst du selber emitteln….
                        Vielleicht hat hier ja schon jemand eine Lösung dafür erstellt...
                          #132
                          Such mal im Forum da gab es Skripte für sowas … wobei auch um ehrlich zu sein, genau ists nicht. Die Tuya Geräte senden nur updates wenn sich der Wert mehr als X% geänder hat hab ich das gefühl ... also naja ...
                          • JB_SullivanJ Offline
                            JB_Sullivan
                            #133
                            Wollte nur mal fragen ob das Gerät funktionieren sollte? Der Button ist grün und es gibt auch keine Fehlermeldungen. Leider kann ich das LED Band ( https://www.amazon.com/Controller-Compa … B077S2Q1ZH ) nicht schalten oder in Farbe und Helligkeit ändern.
                            ![](</s><ATTACHMENT 9724_2018-11-17_09_24_33-objects_-_iobroker.png )[attachment=0]~~2018-11-17 09_24_33-objects - ioBroker.png[/attachment]" />
                            tuya.0	2018-11-17 09:16:33.746	debug	stateChange tuya.0.002004582c3ae8066baa.10 {"val":"ffcb2c06ff1a1a1aff1affff1aff1aff1a1affff1a1a","ack":true,"ts":1542442593743,"q":0,"from":"system.adapter.tuya.0","lc":1542406943209}
                            tuya.0	2018-11-17 09:16:33.746	debug	redis pmessage io.tuya.0.* io.tuya.0.002004582c3ae8066baa.10 {"val":"ffcb2c06ff1a1a1aff1affff1aff1aff1a1affff1a1a","ack":true,"ts":1542442593743,"q":0,"from":"system.adapter.tuya.0","lc":154240694320
                            tuya.0	2018-11-17 09:16:33.739	debug	stateChange tuya.0.002004582c3ae8066baa.9 {"val":"ffff500105ff00","ack":true,"ts":1542442593733,"q":0,"from":"system.adapter.tuya.0","lc":1542406943198}
                            tuya.0	2018-11-17 09:16:33.739	debug	redis pmessage io.tuya.0.* io.tuya.0.002004582c3ae8066baa.9 {"val":"ffff500105ff00","ack":true,"ts":1542442593733,"q":0,"from":"system.adapter.tuya.0","lc":1542406943198}
                            tuya.0	2018-11-17 09:16:33.729	debug	stateChange tuya.0.002004582c3ae8066baa.8 {"val":"ffff8006ff000000ff000000ff00d9ffffd900f600ff","ack":true,"ts":1542442593723,"q":0,"from":"system.adapter.tuya.0","lc":1542406943188}
                            tuya.0	2018-11-17 09:16:33.729	debug	redis pmessage io.tuya.0.* io.tuya.0.002004582c3ae8066baa.8 {"val":"ffff8006ff000000ff000000ff00d9ffffd900f600ff","ack":true,"ts":1542442593723,"q":0,"from":"system.adapter.tuya.0","lc":1542406943188
                            tuya.0	2018-11-17 09:16:33.720	debug	stateChange tuya.0.002004582c3ae8066baa.7 {"val":"ffff500116ff00","ack":true,"ts":1542442593714,"q":0,"from":"system.adapter.tuya.0","lc":1542406943178}
                            tuya.0	2018-11-17 09:16:33.719	debug	redis pmessage io.tuya.0.* io.tuya.0.002004582c3ae8066baa.7 {"val":"ffff500116ff00","ack":true,"ts":1542442593714,"q":0,"from":"system.adapter.tuya.0","lc":1542406943178}
                            tuya.0	2018-11-17 09:16:33.710	debug	stateChange tuya.0.002004582c3ae8066baa.6 {"val":"3855b40168ffff","ack":true,"ts":1542442593704,"q":0,"from":"system.adapter.tuya.0","lc":1542406943168}
                            tuya.0	2018-11-17 09:16:33.709	debug	redis pmessage io.tuya.0.* io.tuya.0.002004582c3ae8066baa.6 {"val":"3855b40168ffff","ack":true,"ts":1542442593704,"q":0,"from":"system.adapter.tuya.0","lc":1542406943168}
                            tuya.0	2018-11-17 09:16:33.700	debug	stateChange tuya.0.002004582c3ae8066baa.5 {"val":"4dff000066ffff","ack":true,"ts":1542442593694,"q":0,"from":"system.adapter.tuya.0","lc":1542406943155}
                            tuya.0	2018-11-17 09:16:33.700	debug	redis pmessage io.tuya.0.* io.tuya.0.002004582c3ae8066baa.5 {"val":"4dff000066ffff","ack":true,"ts":1542442593694,"q":0,"from":"system.adapter.tuya.0","lc":1542406943155}
                            tuya.0	2018-11-17 09:16:33.692	debug	stateChange tuya.0.002004582c3ae8066baa.4 {"val":255,"ack":true,"ts":1542442593683,"q":0,"from":"system.adapter.tuya.0","lc":1542442383856}
                            tuya.0	2018-11-17 09:16:33.692	debug	redis pmessage io.tuya.0.* io.tuya.0.002004582c3ae8066baa.4 {"val":255,"ack":true,"ts":1542442593683,"q":0,"from":"system.adapter.tuya.0","lc":1542442383856}
                            tuya.0	2018-11-17 09:16:33.676	debug	stateChange tuya.0.002004582c3ae8066baa.3 {"val":25,"ack":true,"ts":1542442593672,"q":0,"from":"system.adapter.tuya.0","lc":1542406943135}
                            tuya.0	2018-11-17 09:16:33.676	debug	redis pmessage io.tuya.0.* io.tuya.0.002004582c3ae8066baa.3 {"val":25,"ack":true,"ts":1542442593672,"q":0,"from":"system.adapter.tuya.0","lc":1542406943135}
                            tuya.0	2018-11-17 09:16:33.670	debug	stateChange tuya.0.002004582c3ae8066baa.2 {"val":"colour","ack":true,"ts":1542442593660,"q":0,"from":"system.adapter.tuya.0","lc":1542406943083}
                            tuya.0	2018-11-17 09:16:33.669	debug	redis pmessage io.tuya.0.* io.tuya.0.002004582c3ae8066baa.2 {"val":"colour","ack":true,"ts":1542442593660,"q":0,"from":"system.adapter.tuya.0","lc":1542406943083}
                            tuya.0	2018-11-17 09:16:33.656	debug	stateChange tuya.0.002004582c3ae8066baa.1 {"val":true,"ack":true,"ts":1542442593649,"q":0,"from":"system.adapter.tuya.0","lc":1542442022904}
                            tuya.0	2018-11-17 09:16:33.655	debug	redis pmessage io.tuya.0.* io.tuya.0.002004582c3ae8066baa.1 {"val":true,"ack":true,"ts":1542442593649,"q":0,"from":"system.adapter.tuya.0","lc":1542442022904}
                            tuya.0	2018-11-17 09:16:33.646	info	002004582c3ae8066baa: No schema exists, init basic states ...
                            tuya.0	2018-11-17 09:16:33.646	debug	002004582c3ae8066baa: Received data: {"1":true,"2":"colour","3":25,"4":255,"5":"4dff000066ffff","6":"3855b40168ffff","7":"ffff500116ff00","8":"ffff8006ff000000ff000000ff00d9ffffd900f600ff","9":"ffff50
                            tuya.0	2018-11-17 09:16:33.645	debug	stateChange tuya.0.info.connection {"val":true,"ack":true,"ts":1542442593619,"q":0,"from":"system.adapter.tuya.0","lc":1542442593619}
                            tuya.0	2018-11-17 09:16:33.644	debug	stateChange tuya.0.002004582c3ae8066baa.online {"val":true,"ack":true,"ts":1542442593618,"q":0,"from":"system.adapter.tuya.0","lc":1542442593618}
                            tuya.0	2018-11-17 09:16:33.644	debug	redis pmessage io.tuya.0.* io.tuya.0.info.connection {"val":true,"ack":true,"ts":1542442593619,"q":0,"from":"system.adapter.tuya.0","lc":1542442593619}
                            tuya.0	2018-11-17 09:16:33.643	debug	redis pmessage io.tuya.0.* io.tuya.0.002004582c3ae8066baa.online {"val":true,"ack":true,"ts":1542442593618,"q":0,"from":"system.adapter.tuya.0","lc":1542442593618}
                            tuya.0	2018-11-17 09:16:33.643	debug	connected set to true
                            tuya.0	2018-11-17 09:16:33.618	debug	002004582c3ae8066baa: Connected to device
                            tuya.0	2018-11-17 09:16:33.499	info	Discover for local Tuya devices on port 6666
                            tuya.0	2018-11-17 09:16:33.499	info	Existing devices initialized
                            tuya.0	2018-11-17 09:16:33.499	info	002004582c3ae8066baa: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
                            tuya.0	2018-11-17 09:16:33.498	info	002004582c3ae8066baa Init with IP=ist die richtige IP ;), Key=undefined
                            tuya.0	2018-11-17 09:16:33.446	debug	connected set to false
                            tuya.0	2018-11-17 09:16:33.446	debug	002004582c3ae8066baa: Create device objects if not exist
                            tuya.0	2018-11-17 09:16:33.446	debug	002004582c3ae8066baa: Schema found for fkdtoN22SCiwU9AA: null
                            tuya.0	2018-11-17 09:16:33.445	debug	init 1 known devices
                            tuya.0	2018-11-17 09:16:33.444	info	starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.tuya, node: v8.11.1
                              #134
                              naja die Meldung "no schema exist, init basic states" und "No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!" weisen darauf hin das Du keinen Sync mit der App gemacht hast. Damit zeigt er nur die aktuellen Werte an und eine Steuerung ist nicht möglich … steht genau alles da ...
                              Also: App Sync und das Gerät sollte funktionieren. Wenn Du nach dem Sync im Log noch eine Zeile mit der Schema Info findest dann senden dann kann ich es für alle anderen einbauen.
                                JB_Sullivan
                                #135
                                Ich habe den Sync 100%ig gemacht
                                Die App ist geschlossen, trotzdem bekommen ich nur mit gaaaaanz viel Glück einen Qr-Code (Wartezeit 1Std.) was vermutlich dann zu diesem Fehler lh führt
                                tuya.0	2018-11-17 19:24:14.947	error	at Module.require (module.js:596:17)
                                tuya.0	2018-11-17 19:24:14.947	error	at Function.Module._load (module.js:497:3)
                                tuya.0	2018-11-17 19:24:14.947	error	at tryModuleLoad (module.js:505:12)
                                tuya.0	2018-11-17 19:24:14.947	error	at Module.load (module.js:565:32)
                                tuya.0	2018-11-17 19:24:14.947	error	at Object.Module._extensions..js (module.js:663:10)
                                tuya.0	2018-11-17 19:24:14.947	error	at Module._compile (module.js:652:30)
                                tuya.0	2018-11-17 19:24:14.947	error	at Object. <anonymous>(/opt/iobroker/node_modules/brotli/compress.js:1:76)
                                tuya.0	2018-11-17 19:24:14.947	error	at require (internal/module.js:11:18)
                                tuya.0	2018-11-17 19:24:14.947	error	at Object. <anonymous>(/opt/iobroker/node_modules/brotli/build/encode.js:21:207)
                                tuya.0	2018-11-17 19:24:14.947	error	at new ArrayBuffer (<anonymous>)
                                tuya.0	2018-11-17 19:24:14.947	error	RangeError: Array buffer allocation failed
                                tuya.0	2018-11-17 19:24:14.947	error	pmessage messagebox.system.adapter.tuya.0 {"command":"startProxy","message":{"proxyPort":"8888","proxyWebPort":"8889"},"from":"system.adapter.admin.0","callback":{"message":{"proxyPort":"8888","proxy</anonymous></anonymous></anonymous>
                                Auf jeden Fall habe ich dann irgendwann einen QR Code erhalten und die ganze Prozedur gemäß Anleitung gemacht. Nach meiner Einschätzung ist das auch 100% so durchgelaufen. Darum ja auch meine Frage, weil ich mir die nicht Funktion des Adapters nicht so recht erklären konnte.
                                  #136
                                  Ja dann ist dein Speicher zu knapp. Der Proxy braucht leider (ist ja nur einmalig) eeeeeeiniges an ram.
                                  Im Zweifel einmal mal kurz ein paar Adapter beenden das mehr ram Frei ist. Wenn es dann geklappt hat Instanz neu starten um Speicherverbrauch wieder runter zu bekommen und dann alles wieder starten.
                                    RKBroker
                                    #137
                                    Mal eine Frage:
                                    Wie kann ich es verhindern, dass der Name eines Gerätes wieder durch Device0082…. ersetzt wird?
                                    Vielen Dank und Gruß
                                    Rüdiger
                                      #138
                                      Beim App Sync wird er aktuell immer überschrieben. Sonst sollte er an sich bestehen bleiben.
                                      Wann wird es denn überschrieben?
                                        RKBroker
                                        #139
                                        Genau DAS, habe ich noch nicht raus. Nach stoppen und starten der Instanze ist alles wieder da. Bei einem Relaod nicht immer.
                                          RKBroker
                                          #140
                                          Kann es sein, dass das passiert, wenn der freie Speicher unter 40% geht?
