  4. Windows Steuerung
    5.8k
Windows Steuerung
windows
178 Beiträge 36 Kommentatoren 69.3k Aufrufe 40 Beobachtet
  • liv-in-skyL Offline
    liv-in-skyL Offline
    liv-in-sky
    #61
    versuche mal das - bei mir gehts - in blockly importieren !
      <variables>
        <variable type="" id="0pe!D9m|DQ0n2vS{pc^L">i</variable>
        <variable type="" id="IAIZZNEg)FEHn(.QqghV">curly</variable>
        <variable type="" id="9y]DS@|@Bk_.|#S~9?`Z">result</variable>
        <variable type="undefined" id="timeout">timeout</variable>
      </variables>
      <block type="on_ext" id="#Ua9Q^]Tk`C.~BXLBK~i" x="188" y="88">
        <value name="OID0">
          <shadow type="field_oid" id="*^SU@bJ`LfXLD:8TSg=6">
            <field name="oid">javascript.1.GetAdmin.chk</field>
          </shadow>
        </value>
        <statement name="STATEMENT">
          <block type="variables_set" id="/bC!@nXBob[Lh6!kVdx=">
            <field name="VAR" id="IAIZZNEg)FEHn(.QqghV" variabletype="">curly</field>
            <value name="VALUE">
              <block type="text_join" id="#05!$CXXh9(tA1f]lzmc">
                <value name="ADD0">
                  <block type="text" id="fYMXe;OE*KC}sSC5tjA$">
                    <field name="TEXT">curl "http://192.168.178.36:8585/?chk=</field>
                  </block>
                </value>
                <value name="ADD1">
                  <block type="get_value" id="#_;FY?:{NT3OMs%Bi4oO">
                    <field name="OID">javascript.1.GetAdmin.chk</field>
                  </block>
                </value>
                <value name="ADD2">
                  <block type="text" id="YY`yunwF?raQc;tVM~B,">
                    <field name="TEXT">"</field>
                  </block>
                </value>
              </block>
            </value>
            <next>
              <block type="exec" id="eSJpXB=73vc).D9Q)|[-">
                <mutation with_statement="true"></mutation>
                <field name="WITH_STATEMENT">TRUE</field>
                <field name="LOG"></field>
                <value name="COMMAND">
                  <shadow type="text" id="^hQJf(G00rYsUyb-)lCL">
                  </shadow>
                  <block type="variables_get" id="vKQP4@tnNu-3,Q]f(2x;">
                  </block>
                </value>
                  <block type="control" id="XBOz5lk(8G!`+$uX*U)L">
                    <mutation delay_input="true"></mutation>
                    <field name="OID">javascript.1.GetAdmin.singleprocess</field>
                    <field name="DELAY_MS">1000</field>
                    <field name="UNIT">ms</field>
                      <block type="variables_get" id="jPNU,YG#ZJnce)*MW2Cz">
                        <field name="VAR" id="9y]DS@|@Bk_.|#S~9?`Z" variabletype="">result</field>
                      </block>
                    </value>
                    <next>
                      <block type="timeouts_settimeout" id="4B5ok$v)19CRt3;9Dru/">
                        <field name="DELAY">1000</field>
                          <block type="procedures_callcustomnoreturn" id="zbf*lGC7X0$qd^(T(9|A">
                            <mutation name="etwas tun2">
                              <arg name="i"></arg>
                            </mutation>
                            <value name="ARG0">
                              <block type="variables_get" id="!,=a4X?*2*@4;HAUI_S;">
                              </block>
                            </value>
                          </block>
                        </statement>
                      </block>
                    </next>
                  </block>
                </statement>
              </block>
            </next>
          </block>
        </statement>
      </block>
      <block type="procedures_defcustomnoreturn" id="t.a?5b7s^$L%nOYdazMf" x="238" y="538">
        <mutation statements="false">
          <arg name="i" varid="0pe!D9m|DQ0n2vS{pc^L"></arg>
        </mutation>
        <field name="NAME">etwas tun2</field>
        <field name="SCRIPT">dmFyIHJlID0gLy4rPHA+KFthLXpdKyk8XC9wPi4rL2c7DQogICAgIGkgPSAgICBpLnJlcGxhY2UocmUsICAnJDEnKTsNCiAgDQogICAgbG9nKGkpOw0KICAgIHNldFN0YXRlKCJqYXZhc2NyaXB0LjEuR2V0QWRtaW4uc2luZ2xlcHJvY2VzcyIvKkNsb3VkSGVscCovLCBpKTsNCiAgICBpZiAoaSAhPSAidHJ1ZSIpIHtyZXN1bHQgPSAiZmFsc2UiO30=</field>
      </block>
    </xml>
      liv-in-skyL Offline
      liv-in-sky
      #62
      sieht so aus :
      ach ja - den steuere single process mit result kannst du deaktivieren und den timeout mal auf 500ms setzen - musst du ausprobieren, wie "kurz" er sein darf - wird ja über netzwerk gearbeitet
      • M Micro1959
        ich habe mal das GetAdmin herunter geladen.
        Auf einem Rechner mit Kaspersky konnte ich es entpacken und starten.
        Auf einem anderen Rechner mit Avira meckert das Antivirenprogramm und sagt, es hätte den BDS/Hupigon.Gen Tronjaner gefunden.
        Jetzt bin ich verunsichert, ob ich das überhaupt installieren soll.
        Kann jemand etwas dazu sagen?
        LG aus Münster
        Volker
        bahnuhrB Online
        bahnuhrB Online
        bahnuhr
        #63
        @Micro1959 sagte in Windows Steuerung:
        Wollte das mal ausprobieren.
        Mein Antivir meckert auch.
        Also hab ichs dann gelassen.
        Danke.
        • wendy2702W Online
          wendy2702W Online
          wendy2702
          #64
          Mehr oder weniger alle Antiviren Programme meckern wenn man Programme oder Tools nutzt die eine direkte Windows Steuerung ermöglichen.
          • wendy2702W wendy2702
            bahnuhrB Online
            bahnuhrB Online
            bahnuhr
            #65
            @wendy2702 sagte in Windows Steuerung:
            Kann ich so nicht bestätigen bzw. nachvollziehen.
            Habe einige Programme die Windows steuern (z.B. Ultramon).
            Und bei keinem meckert Antivir.
            Danke.
            • wendy2702W Online
              wendy2702W Online
              wendy2702
              #66
              Nur mal kurz gelesen was Ultramon ist/macht.
              Ist mit GetAdmin und dessen Funktionen nicht wirklich vergleichbar.
              Wenn ihr aber Angst habt ist es ok wenn ihr GetAdmin nicht nutzt.
              • Q Offline
                Q Offline
                Qlink
                #67
                @liv-in-sky
                ich hätte am WE mal probiert deinen Vorschlag nachzubauen.
                Sieht aktuell so bei mir aus:
                Ich musste den Initialtrigger umbauen(bei Erkennung einer Bewegung vorm Tablet), weil das Script sonst nicht auslöst ...
                Und das Ergebnis sieht so aus:
                Allerdings kann ich das Blockly Script zu 100% nachvollziehen. Das ist mir ein wenig zu hoch.
                Auch sieht das Ergebnis nicht anders aus als bei der Erstversion weiter oben.
                Wie hilft mir das neue Script die Werte verarbeiten zu können ?
                Ich steh hier irgendwie auf dem Schlauch... ☹
                • Q Qlink
                  @liv-in-sky
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  liv-in-sky
                  #68
                  @Qlink
                  hi - das ist ja schon ein wenig her - muss mich wieder eindenken
                  ist das das ziel ?
                  siehe Blockly.
                  • Ich wecke das Display meines Win10 Rechners auf, wenn eine Bewegung erkannt wird.
                  • Ich prüfe ob Chrome läuft -> wenn ja, dann nur Display einschalten -> wenn nein, dann Chrome mit VIS starten und Display einschalten
                  • Ich schalte das Display nach 1min automatisch wieder aus.
                  • Ich prüfe ob VLC läuft, wenn ja, dann Display nicht automatisch nach 1min ausschalten -> wenn nein, dann Display nach 1 min ausschalten
                  Dazu brauche ich permanent den Status ob Chrome und/oder VLC laufen ...
                  • Q Qlink
                    @liv-in-sky
                    liv-in-skyL Offline
                    liv-in-skyL Offline
                    liv-in-sky
                    #69
                    @Qlink
                    das obere blockly script ist nur dazu da, die abfrage zu machen, ob chrome läuft. dazu muss in den punkt chk "chrome" stehen
                    mehr macht das script nicht
                    um nun die handlungen ablaufen zu lassen, die du bei z.b.bewegung wünscht, muss du ein script herumbauen - also bitte wieder chk im trigger definieren und nicht die bewegung
                    • Q Offline
                      Q Offline
                      Qlink
                      schrieb am zuletzt editiert von Qlink
                      #70
                      chkChrome bleibt bei mir wie im Screenshot zu sehen ist, aber immer leer ...
                      deswegen läuft das script auch nicht wenn ich den trigger auf chkChrome setze...
                      nur singleprocess wird mit der html Ausgabe von GetAdmin befüllt ...
                      • Q Qlink
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        liv-in-sky
                        #71
                        @Qlink du hast gar keinen datenpunkt chk - also wähle mal im trigger chkchrome in deinem blockly aus
                        anschliessend schreibe direkt in den objekten mal "chrome" in den datenpunkt chkchrome
                        dann müßte im singleprocess etwas stehen
                        erstmal die abfrage ans laufen bringen - danach machen wir das mit der bewegung
                        • Q Offline
                          Q Offline
                          Qlink
                          #72
                          wenn ich chrome in den DP reinschreibe, dann fügt er das Wort bei dem singleprocess Ergebnis hinzu:
                          chromechrome.exe ...
                          • Q Qlink
                            liv-in-skyL Offline
                            liv-in-skyL Offline
                            liv-in-sky
                            #73
                            @Qlink
                            immerhin eine reaktion !
                            lösche im "erstelle text blockly" das "chrome" heraus - es soll nur chk= am ende stehen
                            somit kannst du auch vlc in den datenpunkt chkchrome schreiben und es wird dir gesagt, ob vlc true/false ist.
                            • Q Qlink
                              liv-in-skyL Offline
                              liv-in-skyL Offline
                              liv-in-sky
                              #74
                              @Qlink
                              testest du noch oder ist für heute schluss ?
                              • Q Offline
                                Q Offline
                                Qlink
                                #75
                                ja das klappt !
                                aber wie kann ich daraus ein Blockly mit einer Abfrage bauen ?
                                Mit "setze chk auf chrome" und "prüfe singleprocess auf true" ?
                                  liv-in-skyL Offline
                                  liv-in-sky
                                  #76
                                  ich hab mal etwas geschrieben
                                  zuerst wird vlc getestet- wenn vlc nicht läuft wird auch noch chrome getestet: wie machst du das mit dem monitor an-/abschalten - oder mit der minute warten oder eben ganz an. welchen befehl nutzt du da ?
                                  das txt file wäre für einen import, damit du das nicht alles abschreiben musst - du musst die singleprocess-/bewegungdatenpunkt e ändern - bei mir sind diese datenpunkte nicht da, wo deine sind. das script hat noch keine funktion, wenn keine bewegung da ist !
                                  und die ip adresse muss auch gändert werden
                                  script-for-blocklyimport.txt
                                  • Q Offline
                                    Q Offline
                                    Qlink
                                    #77
                                    @liv-in-sky
                                    Ich hätte die letzten Tage versucht auf Basis deines Vorschlags die Tabletsteuerung mit Blockly so umzusetzen, damit ich es auch nachvollziehen kann. Wenn es zu verschachtelt wird, blicke ich da leider nicht mehr durch, daher hab ich versucht es möglichst einfach zu halten und die Steuerung in verschiedene Blocklys zu unterteilen.
                                    Ich habe für meine 4 Programme(chrome, vlc, kodi, marineaquarium3), die ich abfrage, jeweils ein curl Blockly angelegt.
                                    Die anderen curl Blocklys haben dann chkvlc und vlcprocess usw. als Variablen.
                                    Das funktioniert soweit ganz gut.
                                    Dann gibt es noch das Hauptsteuerungsprogramm. Hier hab ich schon zig Varianten ausprobiert, aber ich bekomme es einfach nicht so hin wie ich gerne möchte ... :(
                                    Ich würde gerne folgendes Funktionalität haben:
                                    Wenn Bewegung erkannt, oder Tastendruck auf Kaminfeuer oder Tastendruck auf Aquarium -> Display ein & check ob eines der 4 Programme läuft
                                    Wenn keines der 4 Programme läuft -> starte Chrome mit "vismain"
                                    Wenn nur Chrome läuft -> Display nach 2min aus
                                    Wenn vlc oder kodi oder marineaquarium läuft -> Display nie ausschalten
                                    Das ganze sollte noch dazu möglichst wenig curl Abfragen zu GetAdmin verursachen, da sich bei mir GetAdmin sonst aufhängt ...
                                    Hier mein letzter Versuch, aber auch der funktioniert nur zum Teil:
                                    tablet.txt
                                    Wäre toll, wenn du mir einen besseren Weg zeigen könntest.
                                    Beste Grüße
                                    • Q Qlink
                                      @liv-in-sky
                                      tablet.txt
                                      Beste Grüße
                                      liv-in-skyL Offline
                                      liv-in-skyL Offline
                                      liv-in-sky
                                      #78
                                      @Qlink moin - bin noch am frühstücken
                                      bitte importiere mal dieses file und ändere die datenpunkte wieder - ich habe die alten bausteine darin gelassen - die kannst du löschen oder deaktivieren
                                      1. änderung. einmal der trigger ersetzt die ganzen "oder" abfragen
                                      2. änderung interval ersetzt durch einen 2 minütigen cron trigger
                                      3. änderung einen timeout2 der 17 sekunden wartet bis du alles gesteuert hast und anschliessend auswertet - ohne dieses warten wertest du etwas aus, was noch garnicht gesteuert wurde !!!
                                      später dann mehr - zum eigentlichen programm
                                      qlink1.txt
                                      • Q Offline
                                        Q Offline
                                        Qlink
                                        #79
                                        @liv-in-sky
                                        vielen Dank für deine Hilfe !
                                        Meintest du so ?
                                        Vorallem bei den ersten 3 Triggern bin ich mir nicht sicher. Sind die automatisch mit ODER zu betrachten ?
                                        liv-in-skyL thewhoboxT 2 Antworten Letzte Antwort
                                        • Q Qlink
                                          @liv-in-sky
                                          Meintest du so ?
                                          liv-in-skyL Offline
                                          liv-in-skyL Offline
                                          liv-in-sky
                                          #80
                                          @Qlink ja - bezug zu ODER frage
                                          mit einer debug node (an der richtigen stelle) kannst du du dann im log-tab deine schaltvorgänge im einzelnen beobachten und evtl. fehler korrigieren
