  4. Javascript install error
8 Beiträge 3 Kommentatoren 1.4k Aufrufe
    Soukai
    Hallo!
    ich hab probleme javascript zu installieren und bekomme folgende meldung und weiß nicht weiter:
    root@raspberrypi:/opt/iobroker# npm install iobroker.javascript
    (node:2361) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpd                       ir() instead.
    npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coff                       eescript" (no hyphen)
    npm ERR! Error: Method Not Allowed
    npm ERR!     at errorResponse (/usr/share/npm/lib/cache/add-named.js:260:10)
    npm ERR!     at /usr/share/npm/lib/cache/add-named.js:203:12
    npm ERR!     at saved (/usr/share/npm/node_modules/npm-registry-client/lib/get.j                       s:167:7)
    npm ERR!     at FSReqWrap.oncomplete (fs.js:135:15)
    npm ERR! If you need help, you may report this *entire* log,
    npm ERR! including the npm and node versions, at:
    npm ERR!     <http: github.com/npm/issues="">npm ERR! System Linux 4.14.72-v7+
    npm ERR! command "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.javascript"
    npm ERR! cwd /opt/iobroker
    npm ERR! node -v v8.11.1
    npm ERR! npm -v 1.4.21
    npm ERR! code E405
    npm ERR!
    npm ERR! Additional logging details can be found in:
    npm ERR!     /opt/iobroker/npm-debug.log
    npm ERR! not ok code 0</http:>
    Was tun?
    Vielen Dank!
    Chris
    • DutchmanD Offline
      DutchmanD Offline
      Dutchman
      Warum per npm ? Was passiert bei:
      iobroker add javascript
        Soukai
        Per iobroker gehts auch nicht. Durch deinen Befehl leider auch nicht…
        root@raspberrypi:~# iobroker add javascript
        (node:1476) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
        NPM version: 1.4.21
        npm install iobroker.javascript --production --save --prefix "/opt/iobroker" (System call)
        (node:1490) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
        npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
        npm ERR!     at saved (/usr/share/npm/node_modules/npm-registry-client/lib/get.js:167:7)
        npm ERR! command "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.javascript" "--production" "--save" "--prefix" "/opt/iobroker"
        npm ERR! cwd /root
        npm ERR! code E405
        npm ERR!
        npm ERR!     /root/npm-debug.log
        host.raspberrypi create instance javascript
        host.raspberrypi error: reading io-package.json Error: ENOENT: no such file or directory, open 'null/io-package.json'</http:>
        • DutchmanD Offline
          DutchmanD Offline
          Dutchman
          Npm Version 1.4????
          Was sagt
          node -v
          npm -v
            Soukai
            root@raspberrypi:~# node -v
            v8.11.1
            root@raspberrypi:~# npm -v
            1.4.21
            (node:1777) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
            root@raspberrypi:~#
            • paul53P Offline
              NPM v1.4.21 ist schon sehr alt. Update besser auf Version 4.
              npm install -g npm@4
              npm -v
              • DutchmanD Offline
                DutchmanD Offline
                Dutchman
                Und weil npm zu alt ist geht die Installation auch nicht
                  Soukai
                  hat nun geklappt, nach paar errors. er sagt mir nun es gibt ein update. Ist es empfehlenswert auf 6.x upzudaten?
