  4. [Problem] Dream btw. Enigma2 Adapter
739 Beiträge 82 Kommentatoren 287.7k Aufrufe 15 Beobachtet
  • J Offline
    Jan1
    #421
    Der Pi hängt im LAN und alles andere hat eine sehr gute Verbindung zur Dream. Polling auf 15s ändert nur das Intervall der Zahnräder an der Dream :lol:
    host.raspberrypi	2018-10-29 16:42:17.221	info	Restart adapter system.adapter.enigma2.0 because enabled
    host.raspberrypi	2018-10-29 16:42:17.221	error	instance system.adapter.enigma2.0 terminated with code 6 (uncaught exception)
    host.raspberrypi	2018-10-29 16:42:17.220	error	Caught by controller[0]: at Timer.listOnTimeout (timers.js:290:5) errno: -24, code: 'EMFILE', syscall: 'uv_resident_set_memory' }
    host.raspberrypi	2018-10-29 16:42:17.220	error	Caught by controller[0]: at tryOnTimeout (timers.js:323:5)
    host.raspberrypi	2018-10-29 16:42:17.220	error	Caught by controller[0]: at ontimeout (timers.js:498:11)
    host.raspberrypi	2018-10-29 16:42:17.220	error	Caught by controller[0]: at Timeout.reportStatus [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5006:27)
    host.raspberrypi	2018-10-29 16:42:17.220	error	Caught by controller[0]: at process.memoryUsage (internal/process.js:99:5)
    host.raspberrypi	2018-10-29 16:42:17.219	error	Caught by controller[0]: { Error: EMFILE: too many open files, uv_resident_set_memory
    enigma2.0	2018-10-29 16:42:15.452	error	Error: EMFILE: too many open files, uv_resident_set_memory at process.memoryUsage (internal/process.js:99:5) at Timeout.reportStatus [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-con
    enigma2.0	2018-10-29 16:42:15.451	error	uncaught exception: EMFILE: too many open files, uv_resident_set_memory
    enigma2.0	2018-10-29 16:42:14.071	info	enigma2: 192.168.100.15:84 ist nicht erreichbar!
    enigma2.0	2018-10-29 16:42:13.548	info	enigma2 Verbunden!
    enigma2.0	2018-10-29 16:42:10.925	info	enigma2: 192.168.100.15:84 ist nicht erreichbar!
    enigma2.0	2018-10-29 16:42:00.744	info	enigma2 Verbunden!
    enigma2.0	2018-10-29 16:42:00.448	info	starting Timercheck every null ms
    enigma2.0	2018-10-29 16:42:00.441	info	starting Polling every 15000 ms
    enigma2.0	2018-10-29 16:42:00.409	info	starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.enigma2, node: v8.12.0
    • Matten MattenM Offline
      Matten Matten
      #422
      sonst erteinmal auf V 1.0.0 zurück tanzen :roll:
      viewtopic.php?f=17&t=1739&start=400
      ioBroker auf Beelink mit WIN10 home|CCU3 (Raspberrymatic)|Neato BotVac D3|HYPERION Ambilight auf RPI3 und RPI ZeroW|HA-Bridge|Milight LED|Nodered&Redmatic|VU Duo2 & Solo se V2
      • J Offline
        Jan1
        #423
        Wie geschrieben, die alte 0.7… lief eigentlich. Für die neueren Versionen wird da Button Script nicht mehr benötigt, oder?
          Matten Matten
          #424
          @Jan1:
          Vielleicht liegt es auch irgendwie am auslesen der Timer…
            Matten Matten
            #425
            @Jan1:
            Wie geschrieben, die alte 0.7… lief eigentlich. Für die neueren Versionen wird da Button Script nicht mehr benötigt, oder? `
            ab 1.0.0. benötigt man kein Button Script mehr.
            Probiere mal bitte die 1.0.0 aus, da ist die Timer geschichte noch nicht mit drin.
            • J Offline
              Jan1
              #426
              Wenn ich das zip entpacke und \node_modules kopiere, lässt sich das nicht uploaden und eine Instanz kann ich auch nicht anlegen. Hast bitte ein Github Link dafür?
                Matten Matten
                #427
                @Jan1:
                Wenn ich das zip entpacke und \node_modules kopiere, lässt sich das nicht uploaden und eine Instanz kann ich auch nicht anlegen. Hast bitte ein Github Link dafür? `
                hast du den Ordner io<u>B</u>roker.enigma2 in io<u>b</u>roker.enigma2 umbenannt?
                • J Offline
                  Jan1
                  #428
                  Na das musst erst mal sehen, bringt aber auch nur Fehler im Log. Allerdings bleibt der Adapter dann auch aus und startet nicht dauern neu.
                  host.raspberrypi	2018-10-29 17:21:40.319	info	Restart adapter system.adapter.enigma2.0 because enabled
                  host.raspberrypi	2018-10-29 17:21:40.319	error	instance system.adapter.enigma2.0 terminated with code 0 (OK)
                  host.raspberrypi	2018-10-29 17:21:40.319	error	Caught by controller[0]: at SAXParser.write (/opt/iobroker/node_modules/sax/lib/sax.js:1436:13)
                  host.raspberrypi	2018-10-29 17:21:40.319	error	Caught by controller[0]: at closeTag (/opt/iobroker/node_modules/sax/lib/sax.js:889:7)
                  host.raspberrypi	2018-10-29 17:21:40.319	error	Caught by controller[0]: at emitNode (/opt/iobroker/node_modules/sax/lib/sax.js:629:5)
                  host.raspberrypi	2018-10-29 17:21:40.319	error	Caught by controller[0]: at emit (/opt/iobroker/node_modules/sax/lib/sax.js:624:35)
                  host.raspberrypi	2018-10-29 17:21:40.319	error	Caught by controller[0]: at SAXParser.onclosetag (/opt/iobroker/node_modules/xml2js/lib/parser.js:261:26)
                  host.raspberrypi	2018-10-29 17:21:40.318	error	Caught by controller[0]: at Parser.emit (events.js:211:7)
                  host.raspberrypi	2018-10-29 17:21:40.318	error	Caught by controller[0]: at emitOne (events.js:116:13)
                  host.raspberrypi	2018-10-29 17:21:40.318	error	Caught by controller[0]: at Parser. <anonymous>(/opt/iobroker/node_modules/xml2js/lib/parser.js:303:18)
                  host.raspberrypi	2018-10-29 17:21:40.318	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:203:21
                  host.raspberrypi	2018-10-29 17:21:40.317	error	Caught by controller[0]: at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:322:86)
                  host.raspberrypi	2018-10-29 17:21:40.316	error	Caught by controller[0]: TypeError: Cannot read property '1' of undefined
                  enigma2.0	2018-10-29 17:21:39.858	error	TypeError: Cannot read property '1' of undefined at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:322:86) at /opt/iobroker/node_modules/iobroker.enigma2/enigm
                  enigma2.0	2018-10-29 17:21:39.857	error	uncaught exception: Cannot read property '1' of undefined</anonymous>
                    Matten Matten
                    #429
                    @Jan1:
                    ok da muss ich noch mal schauen…
                    • J Offline
                      Jan1
                      #430
                      Wenn's bei anderen läuft, mach Dir wegen mir keine Mühe. Wollte eh nur was probieren und das hätte mit dem Adapter etwas leichter und zuverlässiger funktionieren können als über den Harmony, da es übers LAN läuft und nicht über IR.
                        Matten Matten
                        #431
                        @Jan1:
                        Wenn's bei anderen läuft, mach Dir wegen mir keine Mühe. Wollte eh nur was probieren und das hätte mit dem Adapter etwas leichter und zuverlässiger funktionieren können als über den Harmony, da es übers LAN läuft und nicht über IR. `
                        3476_iobroker.enigma2-master_v0.4.3.zip
                        müsste die letzte version mit dem Buttonscript sein. wenn du das damit noch einmal versuchen möchtest
                        Matten Matten
                        • J Offline
                          Jan1
                          #432
                          OK danke, werd dann nochmal ein Versuch starte ;)
                          Diese Version läuft bei mir einwandfrei, da verträgt sich wohl was bei der neuen mit dem aktuellen Dream OS was nicht.
                          • ? Offline
                            #433
                            Nö, hier drei 525 Combo mit aktuellem DreamOS.
                            Läuft perfekt.
                              Turbo
                              #434
                              Ich hatte auch den Fehler mit Code 22 beim deinstallieren. Der Adapter startete bei mir auch laufend und hängte das gesamte System auf…
                              Habe danach in den Objekten den Ordner enigma2.0 gelöscht, admin neu gestartet und die 1.1.1 nochmal installiert - jetzt läufts.
                              Das Problem war, dass beim Installieren der 1.1.1 in den Einstellungen immer noch die Festplatten- und die Button-Script Auswahl vorhanden war - erst wenn die weg sind, läuft die 1.1.1
                              • J Offline
                                Jan1
                                #435
                                Kann man den Adapter nicht einfach über Github installieren, damit das sauber läuft?
                                • BBTownB Offline
                                  BBTownB Offline
                                  BBTown
                                  #436
                                  Ich habe die 1.0.0 und die die letzte Version ausprobiert und habe auch die Probleme, dass:
                                  • permanemte Log-Einträge, dass angeblich keine Verbindung besteht (default Poll 5 sek.)
                                  • der Adapter sich innerhalb kürzester Zeit mit 400 - 600 MB Speicher vollsaugt
                                  • bei mir ist es eine DM8000
                                  • alle Komponenten sind per LAN-Kable (mindesten 100 MBit) miteinander verbunden.
                                  • der WebClient über PC/Browser funktioniert seit jeher einwandfrei
                                  Was mir aufgefallen ist:
                                  ganz gleich was ich bei den Einstellungen für ein root Passwort eintrage, es wird immer eine Verbindung akzeptiert.
                                  Wird das LogIn nicht verifiziert?
                                  Oder wird jedes Passwort akzeptiert wenn für den Zugang über das WebInterface bzw. root gar kein Passwort vergeben wurde??
                                  ioBroker auf NUC (VM debian v13 (Trixie ), node v22.22.0 npm v10.9.4, js-controller v7.2.2 jsonl/jsonl / HomeMatic CCU-2 (Wired und Funk) / Philips HUE / echo.DOT / Broadlink RM pro / SONOS
                                  • N Offline
                                    N Offline
                                    NightWatcher
                                    #437
                                    Habe eben wieder einen neuen Pull Request gesetzt. Einiges an Code bereinigt und das Senderlogo steht jetzt als Base64 Image in einem Objekt zur Verfügung.
                                    Wago 750-881 - mit über 200 Ein- und Ausgängen, DMX512 Art-Net für Beleuchtung, 1-Wire für Umweltsensoren Aussen und Innen, ioBroker als Visualisierung
                                    • ? Offline
                                      #438
                                      Vielen Dank für Eure unermüdliche Arbeit an diesem Adapter.
                                      @ NightWatcher
                                      Was wirklich noch interessant wäre, ist das auslesen der Bouquets und speichern in Datenpunkte.
                                      Am besten auswählbar im Adapter welche Bouquets benutzt werden sollen.
                                      Vielleicht ist das ja eine Herausforderung für Dich :-)
                                      • N Offline
                                        N Offline
                                        NightWatcher
                                        #439
                                        Sollen die nur als Visuelle Datenpunkte dargestellt werden? Also dass du deine kompletten Sender visualisieren kannst?
                                        • ? Offline
                                          #440
                                          Das habe ich bereits mal vor einem Jahr gemacht.
                                          Allerdings war ich da noch etwas unbedarfter als heute bezüglich iobroker.
                                          Ich hatte das seinerzeit mal mit Scripten und Datenpunkten angelegt.
                                          Das funktioniert perfekt auf einer Box so wie ich das will.
                                          ABER, ich habe hier 5 Dreamboxen im Haus und dann ist das ne Mörder Arbeit.
                                          Also, lange Rede kurzer Sinn.
                                          Ja, ich möchte das auch für die anderen Boxen visualisieren.
                                          Schön wäre es wenn in jedem Datenpunkt der jeweilige Sender aus den Bouquets abelegt werden.
                                          Noch besser wäre es wenn die IP aus dem Adapter gleich mit dem jeweiligen WebIf Befehl zum umschalten verknüpft wäre.
                                          Also für SAT 1 HD z.B. so:
                                          http://192.168.123.5/web/zap?sRef=1:0:1 … 0000:0:0:0:
                                          Ich benutze hier das Originale WebIf der Dreambox.
                                          Da es noch ein OpenWebIf gibt denke ich aber das dort die Befehle zum umschalten gleich sind.
                                          Hier hatte @ mikiline schon mal etwas angemerkt.
                                          > [viewtopic.php?f=17&amp;t=1739&amp;start=380#p186819](https://forum.iobroker.net/viewtopic.php?f=17&amp;t=1739&amp;start=380#p186819)
                                          Du kannst ja mal schauen was möglich ist.
                                          So sieht das mit meiner Visualisierung auf der Wohnzimmerbox derzeit aus.
                                          Damit kann ich dann jeden Sender umschalten.
