  3. Cloud Dienste
  4. Iobroker.alexa2 v0.4+
618 Beiträge 95 Kommentatoren 215.5k Aufrufe 9 Beobachtet
  • apollon77A Offline
    #361
    Ok der Fehler sollte nicht kommen. Aber trage doch mal bitte deinen usernamen und Passwort ein. Ist der Fehler dann weg bzw die Ausgabe eine andere?
    Gesendet vom Handy …
      mrMuppet
      #362
      Hier ist das log mit eingetragenen credetials.
      undefined2018-09-27 21:26:04.815 - info: host.iobroker_v1 object change system.adapter.alexa2.0
      2018-09-27 21:26:04.836 - info: host.iobroker_v1 instance system.adapter.alexa2.0 started with pid 79213
      2018-09-27 21:26:05.700 - info: alexa2.0 starting. Version 1.1.0 in /usr/local/www/iobroker/node_modules/iobroker.alexa2, node: v6.14.4
      2018-09-27 21:26:06.676 - error: alexa2.0 uncaught exception: Cannot read property 'options' of undefined
      2018-09-27 21:26:06.677 - error: alexa2.0 TypeError: Cannot read property 'options' of undefined
      at request (/usr/local/www/iobroker/node_modules/iobroker.alexa2/node_modules/alexa-cookie2/alexa-cookie.js:236:71)
      at ClientRequest. (/usr/local/www/iobroker/node_modules/iobroker.alexa2/node_modules/alexa-cookie2/alexa-cookie.js:114:24)
      at emitOne (events.js:96:13)
      at ClientRequest.emit (events.js:188:7)
      at TLSSocket.socketErrorListener (_http_client.js:314:9)
      at TLSSocket.emit (events.js:188:7)
      at emitErrorNT (net.js:1290:8)
      at _combinedTickCallback (internal/process/next_tick.js:80:11)
      at process._tickCallback (internal/process/next_tick.js:104:9)
      2018-09-27 21:26:06.678 - warn: alexa2.0 Exception: TypeError: Cannot read property 'options' of undefined
      2018-09-27 21:26:06.684 - error: alexa2.0 uncaught exception: Cannot read property 'options' of undefined
      2018-09-27 21:26:06.684 - error: alexa2.0 TypeError: Cannot read property 'options' of undefined
      at TLSSocket.socketCloseListener (_http_client.js:290:9)
      at emitOne (events.js:101:20)
      at _handle.close (net.js:509:12)
      at TCP.done [as _onclose] (_tls_wrap.js:332:7)
      2018-09-27 21:26:06.684 - warn: alexa2.0 Exception: TypeError: Cannot read property 'options' of undefined
      2018-09-27 21:26:06.740 - error: Caught by controller[0]: TypeError: Cannot read property 'options' of undefined
      2018-09-27 21:26:06.741 - error: Caught by controller[0]: at request (/usr/local/www/iobroker/node_modules/iobroker.alexa2/node_modules/alexa-cookie2/alexa-cookie.js:236:71)
      2018-09-27 21:26:06.741 - error: Caught by controller[0]: at ClientRequest. (/usr/local/www/iobroker/node_modules/iobroker.alexa2/node_modules/alexa-cookie2/alexa-cookie.js:114:24)
      2018-09-27 21:26:06.742 - error: Caught by controller[0]: at emitOne (events.js:96:13)
      2018-09-27 21:26:06.742 - error: Caught by controller[0]: at ClientRequest.emit (events.js:188:7)
      2018-09-27 21:26:06.742 - error: Caught by controller[0]: at TLSSocket.socketErrorListener (_http_client.js:314:9)
      2018-09-27 21:26:06.742 - error: Caught by controller[0]: at TLSSocket.emit (events.js:188:7)
      2018-09-27 21:26:06.742 - error: Caught by controller[0]: at emitErrorNT (net.js:1290:8)
      2018-09-27 21:26:06.742 - error: Caught by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:80:11)
      2018-09-27 21:26:06.742 - error: Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:104:9)
      2018-09-27 21:26:06.742 - error: Caught by controller[1]: TypeError: Cannot read property 'options' of undefined
      2018-09-27 21:26:06.742 - error: Caught by controller[1]: at request (/usr/local/www/iobroker/node_modules/iobroker.alexa2/node_modules/alexa-cookie2/alexa-cookie.js:236:71)
      2018-09-27 21:26:06.742 - error: Caught by controller[1]: at ClientRequest. (/usr/local/www/iobroker/node_modules/iobroker.alexa2/node_modules/alexa-cookie2/alexa-cookie.js:114:24)
      2018-09-27 21:26:06.742 - error: Caught by controller[1]: at emitOne (events.js:96:13)
      2018-09-27 21:26:06.742 - error: Caught by controller[1]: at ClientRequest.emit (events.js:188:7)
      2018-09-27 21:26:06.742 - error: Caught by controller[1]: at TLSSocket.socketCloseListener (_http_client.js:290:9)
      2018-09-27 21:26:06.742 - error: Caught by controller[1]: at emitOne (events.js:101:20)
      2018-09-27 21:26:06.742 - error: Caught by controller[1]: at TLSSocket.emit (events.js:188:7)
      2018-09-27 21:26:06.742 - error: Caught by controller[1]: at _handle.close (net.js:509:12)
      2018-09-27 21:26:06.742 - error: Caught by controller[1]: at TCP.done [as _onclose] (_tls_wrap.js:332:7)
      2018-09-27 21:26:06.742 - error: host.iobroker_v1 instance system.adapter.alexa2.0 terminated with code 0 (OK)
      2018-09-27 21:26:06.742 - info: host.iobroker_v1 Restart adapter system.adapter.alexa2.0 because enabled
      2018-09-27 21:26:11.213 - info: host.iobroker_v1 object change system.adapter.alexa2.0
      Edit: also mit Email&PW aber ohne Cookie…
      ioBroker auf NUC (Celeron mit Ubuntu-Server)
      Homematic, HMIP, Hue, Unifi, Plex, Nest, Roborock, Google Assistant
        mrMuppet
        #363
        Könnt ihr da die Probleme erkennen? Was kann ich tun?
        Gesendet von meinem ONEPLUS A3003 mit Tapatalk
          #364
          Ich muss reinschauen was da passiert. Komisch
          • lobomauL Offline
            lobomauL Offline
            lobomau
            #365
            Bei mir läuft der Adapter leider nicht ganz rund. Wenn ich bei Spotify etwas abspielen lassen möchte, läuft er keine 2 sec. und geht wieder auf Pause. Egal ob in der Handy-App Play gedrückt wird oder über den alexa2-Adapter. Dieser Fehler ist nicht permanent. Schalte ich den Alexa2-Adapter aus funktioniert Spotify normal.
            Ich habe gerade rausbekommen wie ich den Fehler (zeitweise) wegbekomme. Ich sage Alexa, dass sie einen Radiosender spielen soll. Danach ist alles wieder normal und Spotify kann abgespielt werden. Ein Alexa2-Adapter Neustart bewirkt hingegen nichts.
            Das wird irgendwann wieder kommen. Ich beobachte mal.
            Es läuft alexa 1.1.0 und ich habe keinen spotify-Adapter installiert.
            Vielleicht sagt das log auch etwas aus:
            alexa2.0 2018-09-29 11:00:44.762 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgressStr: {"val":"02:00","ack":true,"ts":1538211644753,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":153821
            alexa2.0 2018-09-29 11:00:44.762 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgress: {"val":120,"ack":true,"ts":1538211644751,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211644751
            alexa2.0 2018-09-29 11:00:44.761 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgressPercent: {"val":72,"ack":true,"ts":1538211644746,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211
            alexa2.0 2018-09-29 11:00:42.757 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgressStr: {"val":"01:58","ack":true,"ts":1538211642752,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":153821
            alexa2.0 2018-09-29 11:00:42.754 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgress: {"val":118,"ack":true,"ts":1538211642749,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211642749
            alexa2.0 2018-09-29 11:00:42.750 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgressPercent: {"val":71,"ack":true,"ts":1538211642745,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211
            alexa2.0 2018-09-29 11:00:40.756 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgressStr: {"val":"01:56","ack":true,"ts":1538211640749,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":153821
            alexa2.0 2018-09-29 11:00:40.751 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgress: {"val":116,"ack":true,"ts":1538211640746,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211640746
            alexa2.0 2018-09-29 11:00:40.747 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgressPercent: {"val":69,"ack":true,"ts":1538211640741,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211
            alexa2.0 2018-09-29 11:00:38.772 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgressStr: {"val":"01:54","ack":true,"ts":1538211638752,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":153821
            alexa2.0 2018-09-29 11:00:38.770 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgress: {"val":114,"ack":true,"ts":1538211638750,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211638750
            alexa2.0 2018-09-29 11:00:38.751 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgressPercent: {"val":68,"ack":true,"ts":1538211638746,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211
            alexa2.0 2018-09-29 11:00:36.750 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgressStr: {"val":"01:52","ack":true,"ts":1538211636745,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":153821
            alexa2.0 2018-09-29 11:00:36.747 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgress: {"val":112,"ack":true,"ts":1538211636742,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211636742
            alexa2.0 2018-09-29 11:00:36.743 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgressPercent: {"val":67,"ack":true,"ts":1538211636737,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211
            alexa2.0 2018-09-29 11:00:36.298 debug State changed alexa2.0.History.json: {"val":"{"name":"Wohnzimmer","serialNumber":"G090LV03701205NB","summary":"alexa spiele eins live","creationTime":1538211618292,"status":"SUCCESS"
            alexa2.0 2018-09-29 11:00:36.298 debug State changed alexa2.0.History.cardJson: {"val":"","ack":true,"ts":1538211636252,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1536422903445}
            alexa2.0 2018-09-29 11:00:36.298 debug State changed alexa2.0.History.cardContent: {"val":"","ack":true,"ts":1538211636251,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1535176160045}
            alexa2.0 2018-09-29 11:00:36.297 debug State changed alexa2.0.History.domainApplicationname: {"val":"","ack":true,"ts":1538211636251,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1535195487412}
            alexa2.0 2018-09-29 11:00:36.297 debug State changed alexa2.0.History.domainApplicationId: {"val":"","ack":true,"ts":1538211636250,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1536423951420}
            alexa2.0 2018-09-29 11:00:36.297 debug State changed alexa2.0.History.creationTime: {"val":1538211618292,"ack":true,"ts":1538211636250,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211636250}
            alexa2.0 2018-09-29 11:00:36.297 debug State changed alexa2.0.History.status: {"val":"SUCCESS","ack":true,"ts":1538211636249,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538204958547}
            alexa2.0 2018-09-29 11:00:36.297 debug State changed alexa2.0.History.summary: {"val":"alexa spiele eins live","ack":true,"ts":1538211636249,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211636249}
            alexa2.0 2018-09-29 11:00:36.297 debug State changed alexa2.0.History.serialNumber: {"val":"G090LV03701205NB","ack":true,"ts":1538211636248,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211636248}
            alexa2.0 2018-09-29 11:00:36.297 debug State changed alexa2.0.History.name: {"val":"Wohnzimmer","ack":true,"ts":1538211636248,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211636248}
            alexa2.0 2018-09-29 11:00:36.297 debug State changed alexa2.0.History.json: {"val":"{"name":"Matthias's 2nd Virtual Device","serialNumber":"1f262f5b515b482a9561c3fa4d2f2246","summary":"wann gefriert wasser","creationTime":153
            alexa2.0 2018-09-29 11:00:36.297 debug State changed alexa2.0.History.cardJson: {"val":"","ack":true,"ts":1538211636247,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1536422903445}
            alexa2.0 2018-09-29 11:00:36.297 debug State changed alexa2.0.History.cardContent: {"val":"","ack":true,"ts":1538211636246,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1535176160045}
            alexa2.0 2018-09-29 11:00:36.297 debug State changed alexa2.0.History.domainApplicationname: {"val":"","ack":true,"ts":1538211636245,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1535195487412}
            alexa2.0 2018-09-29 11:00:36.296 debug State changed alexa2.0.History.domainApplicationId: {"val":"","ack":true,"ts":1538211636245,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1536423951420}
            alexa2.0 2018-09-29 11:00:36.296 debug State changed alexa2.0.History.creationTime: {"val":1538211357873,"ack":true,"ts":1538211636244,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211636244}
            alexa2.0 2018-09-29 11:00:36.296 debug State changed alexa2.0.History.status: {"val":"SUCCESS","ack":true,"ts":1538211636244,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538204958547}
            alexa2.0 2018-09-29 11:00:36.296 debug State changed alexa2.0.History.summary: {"val":"wann gefriert wasser","ack":true,"ts":1538211636243,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538208302585}
            alexa2.0 2018-09-29 11:00:36.292 debug State changed alexa2.0.History.serialNumber: {"val":"1f262f5b515b482a9561c3fa4d2f2246","ack":true,"ts":1538211636242,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":153820830258
            alexa2.0 2018-09-29 11:00:36.244 debug State changed alexa2.0.History.name: {"val":"Matthias's 2nd Virtual Device","ack":true,"ts":1538211636240,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538208302575}
            alexa2.0 2018-09-29 11:00:36.224 debug Alexa-Remote: Response: {"activities":[{"disambiguationId":null,"activityStatus":"SUCCESS","creationTimestamp":1538211618292,"description":"{"summary":"alexa spiele eins live","firstUtteranceId
            alexa2.0 2018-09-29 11:00:35.964 debug Alexa-Remote: Sending Request with {"host":"alexa.amazon.de","path":"/api/activities?startTime=&size=3&offset=1","method":"GET","timeout":10000,"headers":{}}
            alexa2.0 2018-09-29 11:00:35.963 debug Alexa-Remote: No authentication check needed (time elapsed 311611)
            alexa2.0 2018-09-29 11:00:34.763 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgressStr: {"val":"01:50","ack":true,"ts":1538211634753,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":153821
            alexa2.0 2018-09-29 11:00:34.763 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgress: {"val":110,"ack":true,"ts":1538211634752,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211634752
            alexa2.0 2018-09-29 11:00:34.754 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgressPercent: {"val":66,"ack":true,"ts":1538211634748,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211
            alexa2.0 2018-09-29 11:00:32.750 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgressStr: {"val":"01:48","ack":true,"ts":1538211632740,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":153821
            alexa2.0 2018-09-29 11:00:32.741 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgress: {"val":108,"ack":true,"ts":1538211632737,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211632737
            alexa2.0 2018-09-29 11:00:32.738 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgressPercent: {"val":65,"ack":true,"ts":1538211632733,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211
            alexa2.0 2018-09-29 11:00:30.748 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgressStr: {"val":"01:46","ack":true,"ts":1538211630741,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":153821
            alexa2.0 2018-09-29 11:00:30.743 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgress: {"val":106,"ack":true,"ts":1538211630738,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211630738
            alexa2.0 2018-09-29 11:00:30.736 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgressPercent: {"val":63,"ack":true,"ts":1538211630730,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211
            alexa2.0 2018-09-29 11:00:28.738 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgressStr: {"val":"01:44","ack":true,"ts":1538211628733,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":153821
            alexa2.0 2018-09-29 11:00:28.735 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgress: {"val":104,"ack":true,"ts":1538211628730,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211628730
            alexa2.0 2018-09-29 11:00:28.732 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgressPercent: {"val":62,"ack":true,"ts":1538211628726,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211
            alexa2.0 2018-09-29 11:00:26.737 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgressStr: {"val":"01:42","ack":true,"ts":1538211626729,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":153821
            alexa2.0 2018-09-29 11:00:26.734 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgress: {"val":102,"ack":true,"ts":1538211626726,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211626726
            alexa2.0 2018-09-29 11:00:26.727 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgressPercent: {"val":61,"ack":true,"ts":1538211626722,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211
            alexa2.0 2018-09-29 11:00:24.735 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgressStr: {"val":"01:40","ack":true,"ts":1538211624728,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":153821
            alexa2.0 2018-09-29 11:00:24.730 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgress: {"val":100,"ack":true,"ts":1538211624724,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211624724
            alexa2.0 2018-09-29 11:00:24.726 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgressPercent: {"val":60,"ack":true,"ts":1538211624718,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211
            alexa2.0 2018-09-29 11:00:22.729 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgressStr: {"val":"01:38","ack":true,"ts":1538211622724,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":153821
            alexa2.0 2018-09-29 11:00:22.726 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgress: {"val":98,"ack":true,"ts":1538211622721,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211622721}
            alexa2.0 2018-09-29 11:00:22.722 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgressPercent: {"val":59,"ack":true,"ts":1538211622715,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211
            alexa2.0 2018-09-29 11:00:20.728 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgressStr: {"val":"01:36","ack":true,"ts":1538211620722,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":153821
            alexa2.0 2018-09-29 11:00:20.724 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgress: {"val":96,"ack":true,"ts":1538211620718,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211620718}
            alexa2.0 2018-09-29 11:00:20.719 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgressPercent: {"val":57,"ack":true,"ts":1538211620712,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211
            alexa2.0 2018-09-29 11:00:18.722 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgressStr: {"val":"01:34","ack":true,"ts":1538211618716,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":153821
            alexa2.0 2018-09-29 11:00:18.719 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgress: {"val":94,"ack":true,"ts":1538211618713,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211618713}
            alexa2.0 2018-09-29 11:00:18.717 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgressPercent: {"val":56,"ack":true,"ts":1538211618709,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211
            alexa2.0 2018-09-29 11:00:18.251 debug State changed alexa2.0.Echo-Devices.1f262f5b515b482a9561c3fa4d2f2246.Player.mediaProgressPercent: {"val":0,"ack":true,"ts":1538211618219,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admi
            alexa2.0 2018-09-29 11:00:18.251 debug State changed alexa2.0.Echo-Devices.1f262f5b515b482a9561c3fa4d2f2246.Player.mediaProgressStr: {"val":"0","ack":true,"ts":1538211618218,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin"
            alexa2.0 2018-09-29 11:00:18.251 debug State changed alexa2.0.Echo-Devices.1f262f5b515b482a9561c3fa4d2f2123.Player.mediaProgress: {"val":0,"ack":true,"ts":1538211618217,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc"
            alexa2.0 2018-09-29 11:00:18.251 debug State changed alexa2.0.Echo-Devices.1f262f5b515b482a9561c3fa4d2f2123.Player.mediaLengthStr: {"val":"0","ack":true,"ts":1538211618216,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","
            alexa2.0 2018-09-29 11:00:18.251 debug State changed alexa2.0.Echo-Devices.1f262f5b515b482a9561c3fa4d2f2123.Player.mediaLength: {"val":"","ack":true,"ts":1538211618215,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":
            alexa2.0 2018-09-29 11:00:18.251 debug State changed alexa2.0.Echo-Devices.1f262f5b515b482a9561c3fa4d2f2123.Player.miniArtUrl: {"val":"","ack":true,"ts":1538211618214,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1
            alexa2.0 2018-09-29 11:00:18.251 debug State changed alexa2.0.Echo-Devices.1f262f5b515b482a9561c3fa4d2f2123.Player.mainArtUrl: {"val":"","ack":true,"ts":1538211618213,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1
            alexa2.0 2018-09-29 11:00:18.251 debug State changed alexa2.0.Echo-Devices.1f262f5b515b482a9561c3fa4d2f2123.Player.currentAlbum: {"val":"","ack":true,"ts":1538211618212,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc"
            alexa2.0 2018-09-29 11:00:18.251 debug State changed alexa2.0.Echo-Devices.1f262f5b515b482a9561c3fa4d2f2123.Player.currentArtist: {"val":"","ack":true,"ts":1538211618211,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc
            alexa2.0 2018-09-29 11:00:18.251 debug State changed alexa2.0.Echo-Devices.1f262f5b515b482a9561c3fa4d2f2123.Player.currentTitle: {"val":"","ack":true,"ts":1538211618209,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc"
            alexa2.0 2018-09-29 11:00:18.250 debug State changed alexa2.0.Echo-Devices.1f262f5b515b482a9561c3fa4d2f2123.Player.providerName: {"val":"","ack":true,"ts":1538211618208,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc"
            alexa2.0 2018-09-29 11:00:18.249 debug State changed alexa2.0.Echo-Devices.1f262f5b515b482a9561c3fa4d2f2123.Player.service: {"val":"","ack":true,"ts":1538211618207,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1535
            alexa2.0 2018-09-29 11:00:18.248 debug State changed alexa2.0.Echo-Devices.1f262f5b515b482a9561c3fa4d2f2123.Player.radioStationId: {"val":"","ack":true,"ts":1538211618206,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","l
            alexa2.0 2018-09-29 11:00:18.241 debug State changed alexa2.0.Echo-Devices.1f262f5b515b482a9561c3fa4d2f2123.Player.providerId: {"val":"","ack":true,"ts":1538211618204,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1
            alexa2.0 2018-09-29 11:00:18.209 debug State changed alexa2.0.Echo-Devices.1f262f5b515b482a9561c3fa4d2f2123.Player.muted: {"val":false,"ack":true,"ts":1538211618201,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":153
            alexa2.0 2018-09-29 11:00:18.209 debug State changed alexa2.0.Echo-Devices.1f262f5b515b482a9561c3fa4d2f2123.Player.imageURL: {"val":"","ack":true,"ts":1538211618194,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":153
            alexa2.0 2018-09-29 11:00:18.209 debug State changed alexa2.0.Echo-Devices.1f262f5b515b482a9561c3fa4d2f2123.Player.currentState: {"val":false,"ack":true,"ts":1538211618193,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","
            alexa2.0 2018-09-29 11:00:18.209 debug State changed alexa2.0.Echo-Devices.1f262f5b515b482a9561c3fa4d2f2123.Player.contentType: {"val":"","ack":true,"ts":1538211618191,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":
            alexa2.0 2018-09-29 11:00:18.208 debug State changed alexa2.0.Echo-Devices.1f262f5b515b482a9561c3fa4d2f2123.Player.controlPlay: {"val":false,"ack":true,"ts":1538211618190,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","l
            alexa2.0 2018-09-29 11:00:18.195 debug State changed alexa2.0.Echo-Devices.1f262f5b515b482a9561c3fa4d2f2123.Player.controlPause: {"val":false,"ack":true,"ts":1538211618187,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","
            alexa2.0 2018-09-29 11:00:18.195 debug State changed alexa2.0.Echo-Devices.1f262f5b515b482a9561c3fa4d2f2123.Player.volume: {"val":0,"ack":true,"ts":1538211618181,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":153591
            alexa2.0 2018-09-29 11:00:18.191 debug Alexa-Remote: Response: {"message":"Device is not connected/initialized: deviceSerialNumber=1f262f5b515b482a9561c3fa4d2f2246, deviceType=A1X7HJX9QL16M5"}
            alexa2.0 2018-09-29 11:00:17.623 debug Alexa-Remote: Sending Request with {"host":"alexa.amazon.de","path":"/api/media/state?deviceSerialNumber=1f262f5b515b482a9561c3fa4d2f2246&deviceType=A1X7HJX9QL16M5&screenWidth=1392&
            =1538211617618","m
            alexa2.0 2018-09-29 11:00:17.623 debug Alexa-Remote: No authentication check needed (time elapsed 293271)
            alexa2.0 2018-09-29 11:00:17.622 debug Alexa-Remote: Response: {"playerInfo":{"hint":null,"infoText":null,"isPlayingInLemur":false,"lemurVolume":null,"lyrics":null,"mainArt":null,"mediaId":null,"miniArt":null,"miniInfoText":null,"playbackS
            alexa2.0 2018-09-29 11:00:17.127 debug State changed alexa2.0.Echo-Devices.4a449897ac5a4dae8fe5fd9debe3b9eb.Player.mediaProgressPercent: {"val":0,"ack":true,"ts":1538211617087,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admi
            alexa2.0 2018-09-29 11:00:17.127 debug State changed alexa2.0.Echo-Devices.4a449897ac5a4dae8fe5fd9debe3b9eb.Player.mediaProgressStr: {"val":"0","ack":true,"ts":1538211617086,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin"
            alexa2.0 2018-09-29 11:00:17.126 debug State changed alexa2.0.Echo-Devices.4a449897ac5a4dae8fe5fd9debe3b9eb.Player.mediaProgress: {"val":0,"ack":true,"ts":1538211617084,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc"
            alexa2.0 2018-09-29 11:00:17.126 debug State changed alexa2.0.Echo-Devices.4a449897ac5a4dae8fe5fd9debe3b9eb.Player.mediaLengthStr: {"val":"0","ack":true,"ts":1538211617083,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","
            alexa2.0 2018-09-29 11:00:17.126 debug State changed alexa2.0.Echo-Devices.4a449897ac5a4dae8fe5fd9debe3b9eb.Player.mediaLength: {"val":"","ack":true,"ts":1538211617082,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":
            alexa2.0 2018-09-29 11:00:17.126 debug State changed alexa2.0.Echo-Devices.4a449897ac5a4dae8fe5fd9debe3b9eb.Player.miniArtUrl: {"val":"","ack":true,"ts":1538211617081,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1
            alexa2.0 2018-09-29 11:00:17.126 debug State changed alexa2.0.Echo-Devices.4a449897ac5a4dae8fe5fd9debe3b9eb.Player.mainArtUrl: {"val":"","ack":true,"ts":1538211617080,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1
            alexa2.0 2018-09-29 11:00:17.126 debug State changed alexa2.0.Echo-Devices.4a449897ac5a4dae8fe5fd9debe3b9eb.Player.currentAlbum: {"val":"","ack":true,"ts":1538211617079,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc"
            alexa2.0 2018-09-29 11:00:17.126 debug State changed alexa2.0.Echo-Devices.4a449897ac5a4dae8fe5fd9debe3b9eb.Player.currentArtist: {"val":"","ack":true,"ts":1538211617078,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc
            alexa2.0 2018-09-29 11:00:17.126 debug State changed alexa2.0.Echo-Devices.4a449897ac5a4dae8fe5fd9debe3b9eb.Player.currentTitle: {"val":"","ack":true,"ts":1538211617076,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc"
            alexa2.0 2018-09-29 11:00:17.126 debug State changed alexa2.0.Echo-Devices.4a449897ac5a4dae8fe5fd9debe3b9eb.Player.providerName: {"val":"","ack":true,"ts":1538211617075,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc"
            alexa2.0 2018-09-29 11:00:17.126 debug State changed alexa2.0.Echo-Devices.4a449897ac5a4dae8fe5fd9debe3b9eb.Player.service: {"val":"","ack":true,"ts":1538211617074,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1535
            alexa2.0 2018-09-29 11:00:17.126 debug State changed alexa2.0.Echo-Devices.4a449897ac5a4dae8fe5fd9debe3b9eb.Player.radioStationId: {"val":"","ack":true,"ts":1538211617073,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","l
            alexa2.0 2018-09-29 11:00:17.126 debug State changed alexa2.0.Echo-Devices.4a449897ac5a4dae8fe5fd9debe3b9eb.Player.providerId: {"val":"","ack":true,"ts":1538211617072,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1
            alexa2.0 2018-09-29 11:00:17.125 debug State changed alexa2.0.Echo-Devices.4a449897ac5a4dae8fe5fd9debe3b9eb.Player.muted: {"val":false,"ack":true,"ts":1538211617070,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":153
            alexa2.0 2018-09-29 11:00:17.125 debug State changed alexa2.0.Echo-Devices.4a449897ac5a4dae8fe5fd9debe3b9eb.Player.imageURL: {"val":"","ack":true,"ts":1538211617069,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":153
            alexa2.0 2018-09-29 11:00:17.125 debug State changed alexa2.0.Echo-Devices.4a449897ac5a4dae8fe5fd9debe3b9eb.Player.currentState: {"val":false,"ack":true,"ts":1538211617068,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","
            alexa2.0 2018-09-29 11:00:17.125 debug State changed alexa2.0.Echo-Devices.4a449897ac5a4dae8fe5fd9debe3b9eb.Player.contentType: {"val":"","ack":true,"ts":1538211617066,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":
            alexa2.0 2018-09-29 11:00:17.069 debug State changed alexa2.0.Echo-Devices.4a449897ac5a4dae8fe5fd9debe3b9eb.Player.controlPlay: {"val":false,"ack":true,"ts":1538211617063,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","l
            alexa2.0 2018-09-29 11:00:17.065 debug State changed alexa2.0.Echo-Devices.4a449897ac5a4dae8fe5fd9debe3b9eb.Player.controlPause: {"val":false,"ack":true,"ts":1538211617057,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","
            alexa2.0 2018-09-29 11:00:17.065 debug State changed alexa2.0.Echo-Devices.4a449897ac5a4dae8fe5fd9debe3b123.Player.volume: {"val":0,"ack":true,"ts":1538211617048,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":153591
            alexa2.0 2018-09-29 11:00:17.065 debug Alexa-Remote: Sending Request with {"host":"alexa.amazon.de","path":"/api/np/player?deviceSerialNumber=1f262f5b515b482a9561c3fa4d2f2123&deviceType=A1X7HJX9QL16M5&screenWidth=1392&=1538211617050","met
            alexa2.0 2018-09-29 11:00:17.065 debug Alexa-Remote: No authentication check needed (time elapsed 292704)
            alexa2.0 2018-09-29 11:00:17.064 debug Alexa-Remote: Response: {"message":"Device is not connected/initialized: deviceSerialNumber=4a449897ac5a4dae8fe5fd9debe3b9eb, deviceType=A1X7HJX9QL16M5"}
            alexa2.0 2018-09-29 11:00:16.722 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgressStr: {"val":"01:32","ack":true,"ts":1538211616713,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":153821
            alexa2.0 2018-09-29 11:00:16.721 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgress: {"val":92,"ack":true,"ts":1538211616710,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211616710}
            alexa2.0 2018-09-29 11:00:16.712 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgressPercent: {"val":55,"ack":true,"ts":1538211616707,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211
            alexa2.0 2018-09-29 11:00:16.484 debug Alexa-Remote: Sending Request with {"host":"alexa.amazon.de","path":"/api/media/state?deviceSerialNumber=4a449897ac5a4dae8fe5fd9debe3b123&deviceType=A1X7HJX9QL16M5&screenWidth=1392&
            =1538211616439","m
            alexa2.0 2018-09-29 11:00:16.484 debug Alexa-Remote: No authentication check needed (time elapsed 292093)
            alexa2.0 2018-09-29 11:00:16.483 debug Alexa-Remote: Response: {"playerInfo":{"hint":null,"infoText":null,"isPlayingInLemur":false,"lemurVolume":null,"lyrics":null,"mainArt":null,"mediaId":null,"miniArt":null,"miniInfoText":null,"playbackS
            alexa2.0 2018-09-29 11:00:15.950 debug State changed alexa2.0.Echo-Devices.417037741c204ce89cf785746068c2e3.Player.mediaProgressPercent: {"val":0,"ack":true,"ts":1538211615928,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admi
            alexa2.0 2018-09-29 11:00:15.950 debug State changed alexa2.0.Echo-Devices.417037741c204ce89cf785746068c2e3.Player.mediaProgressStr: {"val":"0","ack":true,"ts":1538211615924,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin"
            alexa2.0 2018-09-29 11:00:15.950 debug State changed alexa2.0.Echo-Devices.417037741c204ce89cf785746068c2e3.Player.mediaProgress: {"val":0,"ack":true,"ts":1538211615912,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc"
            alexa2.0 2018-09-29 11:00:15.949 debug State changed alexa2.0.Echo-Devices.417037741c204ce89cf785746068c2e3.Player.mediaLengthStr: {"val":"0","ack":true,"ts":1538211615911,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","
            alexa2.0 2018-09-29 11:00:15.949 debug State changed alexa2.0.Echo-Devices.417037741c204ce89cf785746068c2e3.Player.mediaLength: {"val":"","ack":true,"ts":1538211615909,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":
            alexa2.0 2018-09-29 11:00:15.949 debug State changed alexa2.0.Echo-Devices.417037741c204ce89cf785746068c2e3.Player.miniArtUrl: {"val":"","ack":true,"ts":1538211615908,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1
            alexa2.0 2018-09-29 11:00:15.949 debug State changed alexa2.0.Echo-Devices.417037741c204ce89cf785746068c2e3.Player.mainArtUrl: {"val":"","ack":true,"ts":1538211615907,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1
            alexa2.0 2018-09-29 11:00:15.949 debug State changed alexa2.0.Echo-Devices.417037741c204ce89cf785746068c2e3.Player.currentAlbum: {"val":"","ack":true,"ts":1538211615906,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc"
            alexa2.0 2018-09-29 11:00:15.949 debug State changed alexa2.0.Echo-Devices.417037741c204ce89cf785746068c2e3.Player.currentArtist: {"val":"","ack":true,"ts":1538211615905,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc
            alexa2.0 2018-09-29 11:00:15.949 debug State changed alexa2.0.Echo-Devices.417037741c204ce89cf785746068c2e3.Player.currentTitle: {"val":"","ack":true,"ts":1538211615904,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc"
            alexa2.0 2018-09-29 11:00:15.949 debug State changed alexa2.0.Echo-Devices.417037741c204ce89cf785746068c2e3.Player.providerName: {"val":"","ack":true,"ts":1538211615903,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc"
            alexa2.0 2018-09-29 11:00:15.949 debug State changed alexa2.0.Echo-Devices.417037741c204ce89cf785746068c2e3.Player.service: {"val":"","ack":true,"ts":1538211615902,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1535
            alexa2.0 2018-09-29 11:00:15.949 debug State changed alexa2.0.Echo-Devices.417037741c204ce89cf785746068c2e3.Player.radioStationId: {"val":"","ack":true,"ts":1538211615901,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","l
            alexa2.0 2018-09-29 11:00:15.949 debug State changed alexa2.0.Echo-Devices.417037741c204ce89cf785746068c2e3.Player.providerId: {"val":"","ack":true,"ts":1538211615899,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1
            alexa2.0 2018-09-29 11:00:15.948 debug State changed alexa2.0.Echo-Devices.417037741c204ce89cf785746068c2e3.Player.muted: {"val":false,"ack":true,"ts":1538211615898,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":153
            alexa2.0 2018-09-29 11:00:15.948 debug State changed alexa2.0.Echo-Devices.417037741c204ce89cf785746068c2e3.Player.imageURL: {"val":"","ack":true,"ts":1538211615897,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":153
            alexa2.0 2018-09-29 11:00:15.948 debug State changed alexa2.0.Echo-Devices.417037741c204ce89cf785746068c2e3.Player.currentState: {"val":false,"ack":true,"ts":1538211615896,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","
            alexa2.0 2018-09-29 11:00:15.947 debug State changed alexa2.0.Echo-Devices.417037741c204ce89cf785746068c2e3.Player.contentType: {"val":"","ack":true,"ts":1538211615895,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":
            alexa2.0 2018-09-29 11:00:15.938 debug State changed alexa2.0.Echo-Devices.417037741c204ce89cf785746068c2e3.Player.controlPlay: {"val":false,"ack":true,"ts":1538211615894,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","l
            alexa2.0 2018-09-29 11:00:15.896 debug State changed alexa2.0.Echo-Devices.417037741c204ce89cf785746068c2e3.Player.controlPause: {"val":false,"ack":true,"ts":1538211615890,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","
            alexa2.0 2018-09-29 11:00:15.894 debug State changed alexa2.0.Echo-Devices.417037741c204ce89cf785746068c2e3.Player.controlRepeat: {"val":false,"ack":true,"ts":1538211615884,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin",
            alexa2.0 2018-09-29 11:00:15.893 debug State changed alexa2.0.Echo-Devices.417037741c204ce89cf785746068c2e3.Player.controlShuffle: {"val":false,"ack":true,"ts":1538211615876,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin"
            alexa2.0 2018-09-29 11:00:15.893 debug Alexa-Remote: Sending Request with {"host":"alexa.amazon.de","path":"/api/np/player?deviceSerialNumber=4a449897ac5a4dae8fe5fd9debe3b9eb&deviceType=A1X7HJX9QL16M5&screenWidth=1392&=1538211615877","met
            alexa2.0 2018-09-29 11:00:15.892 debug Alexa-Remote: No authentication check needed (time elapsed 291531)
            alexa2.0 2018-09-29 11:00:15.892 debug Alexa-Remote: Response: {"clientId":"Domain:Application:Music","contentId":null,"contentType":null,"currentState":"IDLE","imageURL":null,"isDisliked":false,"isLiked":false,"looping":false,"mediaOwnerC
            alexa2.0 2018-09-29 11:00:15.325 debug Alexa-Remote: Sending Request with {"host":"alexa.amazon.de","path":"/api/media/state?deviceSerialNumber=417037741c204ce89cf785746068c123&deviceType=A3C9PE6TNYLTCH&screenWidth=1392&
            =1538211615319","m
            alexa2.0 2018-09-29 11:00:15.325 debug Alexa-Remote: No authentication check needed (time elapsed 290973)
            alexa2.0 2018-09-29 11:00:15.324 debug Alexa-Remote: Response: {"playerInfo":{"hint":null,"infoText":null,"isPlayingInLemur":true,"lemurVolume":null,"lyrics":null,"mainArt":null,"mediaId":null,"miniArt":null,"miniInfoText":null,"playbackSo
            alexa2.0 2018-09-29 11:00:14.730 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgressStr: {"val":"01:30","ack":true,"ts":1538211614718,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":153821
            alexa2.0 2018-09-29 11:00:14.730 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgress: {"val":90,"ack":true,"ts":1538211614714,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211614714}
            alexa2.0 2018-09-29 11:00:14.727 debug State changed alexa2.0.Echo-Devices.G090LV03701205NB.Player.mediaProgressPercent: {"val":54,"ack":true,"ts":1538211614706,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538211
            alexa2.0 2018-09-29 11:00:14.324 debug State changed alexa2.0.Echo-Devices.G090LB09746509GM.Player.mediaProgressPercent: {"val":0,"ack":true,"ts":1538211614283,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":15380233
            alexa2.0 2018-09-29 11:00:14.324 debug State changed alexa2.0.Echo-Devices.G090LB09746509GM.Player.mediaProgressStr: {"val":"09:50","ack":true,"ts":1538211614282,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":153820
            alexa2.0 2018-09-29 11:00:14.324 debug State changed alexa2.0.Echo-Devices.G090LB09746509GM.Player.mediaProgress: {"val":590,"ack":true,"ts":1538211614281,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538204459932
            alexa2.0 2018-09-29 11:00:14.324 debug State changed alexa2.0.Echo-Devices.G090LB09746509GM.Player.mediaLengthStr: {"val":"0","ack":true,"ts":1538211614280,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":153802331797
            alexa2.0 2018-09-29 11:00:14.324 debug State changed alexa2.0.Echo-Devices.G090LB09746509GM.Player.mediaLength: {"val":"","ack":true,"ts":1538211614279,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538023317971}
            alexa2.0 2018-09-29 11:00:14.324 debug State changed alexa2.0.Echo-Devices.G090LB09746509GM.Player.miniArtUrl: {"val":"https://cdn-profiles.tunein.com/s25260/images/logoq.png","ack":true,"ts":1538211614279,"q":0,"from":"system.adapter.alex
            alexa2.0 2018-09-29 11:00:14.324 debug State changed alexa2.0.Echo-Devices.G090LB09746509GM.Player.mainArtUrl: {"val":"https://cdn-profiles.tunein.com/s25260/images/logoq.png","ack":true,"ts":1538211614278,"q":0,"from":"system.adapter.alex
            alexa2.0 2018-09-29 11:00:14.323 debug State changed alexa2.0.Echo-Devices.G090LB09746509GM.Player.currentAlbum: {"val":"","ack":true,"ts":1538211614277,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538023317968}
            alexa2.0 2018-09-29 11:00:14.323 debug State changed alexa2.0.Echo-Devices.G090LB09746509GM.Player.currentArtist: {"val":"Für den Sektor","ack":true,"ts":1538211614276,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":
            alexa2.0 2018-09-29 11:00:14.323 debug State changed alexa2.0.Echo-Devices.G090LB09746509GM.Player.currentTitle: {"val":"1 LIVE","ack":true,"ts":1538211614275,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":153810759
            alexa2.0 2018-09-29 11:00:14.323 debug State changed alexa2.0.Echo-Devices.G090LB09746509GM.Player.providerName: {"val":"TuneIn-Liveradio","ack":true,"ts":1538211614273,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc"
            alexa2.0 2018-09-29 11:00:14.323 debug State changed alexa2.0.Echo-Devices.G090LB09746509GM.Player.service: {"val":"TUNE_IN","ack":true,"ts":1538211614272,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538107591402
            alexa2.0 2018-09-29 11:00:14.323 debug State changed alexa2.0.Echo-Devices.G090LB09746509GM.Player.radioStationId: {"val":"s25260","ack":true,"ts":1538211614271,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538107
            alexa2.0 2018-09-29 11:00:14.323 debug State changed alexa2.0.Echo-Devices.G090LB09746509GM.Player.providerId: {"val":"TUNE_IN","ack":true,"ts":1538211614270,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538107591
            alexa2.0 2018-09-29 11:00:14.323 debug State changed alexa2.0.Echo-Devices.G090LB09746509GM.Player.muted: {"val":false,"ack":true,"ts":1538211614269,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1535308468957}
            alexa2.0 2018-09-29 11:00:14.323 debug State changed alexa2.0.Echo-Devices.G090LB09746509GM.Player.imageURL: {"val":"https://cdn-profiles.tunein.com/s25260/images/logoq.png","ack":true,"ts":1538211614268,"q":0,"from":"system.adapter.alexa2
            alexa2.0 2018-09-29 11:00:14.323 debug State changed alexa2.0.Echo-Devices.G090LB09746509GM.Player.currentState: {"val":false,"ack":true,"ts":1538211614267,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":153820445992
            alexa2.0 2018-09-29 11:00:14.323 debug State changed alexa2.0.Echo-Devices.G090LB09746509GM.Player.contentType: {"val":"LIVE_STATION","ack":true,"ts":1538211614266,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538
            alexa2.0 2018-09-29 11:00:14.323 debug State changed alexa2.0.Echo-Devices.G090LB09746509GM.Player.controlPlay: {"val":false,"ack":true,"ts":1538211614265,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538204459913
            alexa2.0 2018-09-29 11:00:14.322 debug State changed alexa2.0.Echo-Devices.G090LB09746509GM.Player.controlPause: {"val":true,"ack":true,"ts":1538211614263,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538204459912
            alexa2.0 2018-09-29 11:00:14.270 debug State changed alexa2.0.Echo-Devices.G090LB09746509GM.Player.controlRepeat: {"val":false,"ack":true,"ts":1538211614259,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":15351761594
            alexa2.0 2018-09-29 11:00:14.263 debug State changed alexa2.0.Echo-Devices.G090LB09746509GM.Player.controlShuffle: {"val":false,"ack":true,"ts":1538211614250,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1535176159
            alexa2.0 2018-09-29 11:00:14.263 debug State changed alexa2.0.Echo-Devices.G090LB09746509GM.Player.volume: {"val":27,"ack":true,"ts":1538211614242,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538200807866}
            alexa2.0 2018-09-29 11:00:14.263 debug Alexa-Remote: Sending Request with {"host":"alexa.amazon.de","path":"/api/np/player?deviceSerialNumber=417037741c204ce89cf785746068c2e3&deviceType=A3C9PE6TNYLTCH&screenWidth=1392&=1538211614244","met
            alexa2.0 2018-09-29 11:00:14.262 debug Alexa-Remote: No authentication check needed (time elapsed 289898)
            alexa2.0 2018-09-29 11:00:14.261 debug Alexa-Remote: Response: {"clientId":"Dee-Domain-Music","contentId":"s25260","contentType":"LIVE_STATION","currentState":"PAUSED","imageURL":"https://cdn-profiles.tunein.com/s25260/images/logoq.png","i
            alexa2.0 2018-09-29 11:00:13.926 debug Alexa-Remote: Sending Request with {"host":"alexa.amazon.de","path":"/api/media/state?deviceSerialNumber=G090LB0974650123&deviceType=A2M35JJZWCQOMZ&screenWidth=1392&
            =1538211613921","method":"GET","ti
            alexa2.0 2018-09-29 11:00:13.926 debug Alexa-Remote: No authentication check needed (time elapsed 289575)
            alexa2.0 2018-09-29 11:00:13.925 debug Alexa-Remote: Response: {"playerInfo":{"hint":null,"infoText":{"multiLineMode":false,"subText1":"Für den Sektor","subText2":null,"title":"1 LIVE"},"isPlayingInLemur":false,"lemurVolume":null,"lyrics":
            alexa2.0 2018-09-29 11:00:13.433 debug State changed alexa2.0.Echo-Devices.G090LF096503188E.Player.mediaProgressPercent: {"val":0,"ack":true,"ts":1538211613388,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":15382007
            alexa2.0 2018-09-29 11:00:13.433 debug State changed alexa2.0.Echo-Devices.G090LF096503188E.Player.mediaProgressStr: {"val":"0","ack":true,"ts":1538211613387,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538200723
            alexa2.0 2018-09-29 11:00:13.433 debug State changed alexa2.0.Echo-Devices.G090LF096503188E.Player.mediaProgress: {"val":0,"ack":true,"ts":1538211613386,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1538200723115}
            alexa2.0 2018-09-29 11:00:13.433 debug State changed alexa2.0.Echo-Devices.G090LF096503188E.Player.mediaLengthStr: {"val":"0","ack":true,"ts":1538211613385,"q":0,"from":"system.adapter.ale
            Host: NUC8i3 mit Proxmox:
            • Slave: Pi4
            • padrinoP Offline
              padrinoP Offline
              padrino
              #366
              sehe ich das richtig, "commands" wie "donotdisturb" und "goodmorning" kann man nur schreiben, nicht aber deren Status auslesen, bzw. deren Status wird nicht geändert wenn man das Kommando per Stimme gibt?
              Ich kann also nicht herausfinden, ob ein Echo im DND Modus ist, oder darauf reagieren, wenn der Echo den Befehl "Guten Morgen" von mir per Sprache erhält?
              CU,
              padrino
              • modmaxM Offline
                modmaxM Offline
                modmax
                #367
                Ja … bei mir ändert sich da nix,bis auf die History.
                Die meisten States sind nur da, um AN Alexa etwas zu sagen ...
                aber bis auf History NIX von Alexa zu erhalten.
                Bitte nicht schlagen, wenn ich da falsch liege ... :-)
                MfG Markus
                  mrMuppet
                  #368
                  @apollon77:
                  Ich muss reinschauen was da passiert. Komisch `
                  Es hat sich alles gelöst. Nachdem ich noch mal genauer rumprobiert habe, es immer wieder Netzwerkprobleme gab, ich alexa2 plötzlich nicht mehr neu runterladen konnte und auch ein neuer Jail plötzlich nicht mehr richtig installiert werden konnte, habe ich meinen FreeNAS (auf dem der Broker läuft) mal neu gestartet: und plötzlich rennt auch Alexa2 wieder. Also letztlich der Klassiker: "did you try turn off and on again?"
                  Trotzdem Danke euch.
                  • padrinoP Offline
                    padrinoP Offline
                    padrino
                    #369
                    ich lese immer wieder, dass der Adapter Dinge nicht kann, wenn die App sie nicht kann.
                    Da die App/Webseite den Status von "bitte nicht stören" anzeigen kann, sollte es dann nicht auch für den Adapter möglich, also programmierbar sein? :)
                    CU,
                    padrino
                      #370
                      Feature requests bitte als GitHub issues anlegen. Dann schaue ich gern bei Gelegenheit und Zeit mal rein
                        Blackeye
                        #371
                        ist es möglich einen Festen Einschlaftimer über den Adapter zu setzten?
                        Lars
                          Mr.X
                          #372
                          Habe gerade bei Mm um Angebot ein Ring doorbell 2 gekauft.
                          Weiß jemand ob der Alexa2 Adapter mitbekommt, dass jemand klingelt? So könnte man Dan mit Speck einfach auf dem Echo eine Ausgabe triggern.
                            Apropo
                            #373
                            Guten Morgen,
                            ich habe seit gestern einen weiteren Echo Dot. Er wurde auch anstandslos vom Alexa Adapter gefunden. Allerdings werden mir bei dem die ganzen Sachen wie Commands, Player usw. nicht angezeigt. Lediglich Info und der Online Status sind da (siehe Screenshot beim Schlafzimmer Dot).
                            Hat jemand eine Idee warum das so ist und wie ich die fehlenden Objekte bekommen kann?
                            Mfg, Apropo
                            • N Offline
                              N Offline
                              nathan1312
                              #374
                              @Apropo:
                              Guten Morgen,
                              Mfg, Apropo `
                              Hallo, schon mal die Seite aktualisiert? Oder den Adapter neu gestartet?
                              Gesendet von meinem SM-G950F mit Tapatalk
                                Apropo
                                #375
                                Seite aktualisiert hatte ich mehrmals. Auf Adapter neu starten kam ich nicht, weil er ja den Dot eigentlich auch ohne Neustart gefunden hatte.
                                Aber das wars! Nach einem Adapter Neustart ist alles da. Danke dir!
                                  #376
                                  Die vollständige Initialisierung der Geräte erfolgt nur beim Adapterstart. Auch wenn er neue Geräte ggf (unvollständig) anzeigt liegt nur daran das er ggf ein paar Infos bekommt und dann einfach schreibt. :-) Müsste man eigentlich besser abfangen
                                    Apropo
                                    #377
                                    Danke für die Info. Dann weiß ich in Zukunft bescheid ….
                                    • padrinoP Offline
                                      padrinoP Offline
                                      padrino
                                      #378
                                      commands/donotdisturb für Gruppen, wird zwar als Objekt angezeigt, funktioniert aber nicht, bzw. wird nicht unterstützt?
                                      CU,
                                      padrino
                                        #379
                                        Bitte GutHub Issue anlegen
                                          Blackeye
                                          #380
                                          bei mir funktioniert es über Blockly nicht den Datenpunkt alexa2.0.Echo-Devices.G2T0T00480440AMK.Info.name wieder als Ausgabegerät der Anfrage zu nutzen.
                                          Muss ich hier auf etwas achten?
                                          Lars
