  4. Netatmo?
    6.6k
Netatmo?
140 Beiträge 52 Kommentatoren 46.9k Aufrufe 12 Beobachtet
    rascal
    #101
    hier das gleiche, auch gut im Moment
    • N Offline
      N Offline
      Nanouk
      #102
      Moin,
      hier auch das Problem.
      Ging gestern mal kurzzeitig, aber seit gestern Abend wieder rot.
      Gruß Nanouk
      • SchubiS Offline
        SchubiS Offline
        Schubi
        #103
        Gibts schon Neuigkeiten - hab seit kurzem auch den Fehler!
        netatmo.0	2018-12-03 19:49:00.565	info	terminating
        netatmo.0	2018-12-03 19:49:00.528	info	cleaned everything up...
        netatmo.0	2018-12-03 19:49:00.526	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
        netatmo.0	2018-12-03 19:49:00.526	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
        netatmo.0	2018-12-03 19:49:00.526	error	at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-bind/index.js:21:15)
        netatmo.0	2018-12-03 19:49:00.526	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
        netatmo.0	2018-12-03 19:49:00.526	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
        netatmo.0	2018-12-03 19:49:00.526	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:51:17)
        netatmo.0	2018-12-03 19:49:00.526	error	at handleModule (/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:63:27)
        netatmo.0	2018-12-03 19:49:00.526	error	at Array.forEach (native)
        netatmo.0	2018-12-03 19:49:00.526	error	at /opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:84:21
        netatmo.0	2018-12-03 19:49:00.526	error	at handleWind (/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:656:42)
        netatmo.0	2018-12-03 19:49:00.526	error	TypeError: Cannot read property 'WindStrength' of undefined
        netatmo.0	2018-12-03 19:49:00.524	error	uncaught exception: Cannot read property 'WindStrength' of undefined
        netatmo.0	2018-12-03 19:48:59.157	info	starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.netatmo, node: v6.13.1</anonymous></anonymous>
        / Synology DS716+ / Logitech Harmony Ultimate / Netatmo / ESP8266 / RPi 3 / 4* Möller Easy 820 / Lupusec XT2 Plus /
          rascal
          #104
          bei mir scheint der Fehler nicht mehr aufzutreten
          • SchubiS Offline
            SchubiS Offline
            Schubi
            #105
            Was hast du geändert?
            Hast du einen Windsensor? (Ich hab keinen)
              rascal
              #106
              ich habe die Version von Github direkt installiert, jetzt läuft Version 1.3.1
              Ich habe einen Windsensor, Regensensor und Außentemp Sensor.
              • SchubiS Offline
                SchubiS Offline
                Schubi
                #107
                Ich Probier auch mal direkt von GitHub.
                Hab aber jetzt auch schon die 1.3.1
                Nach der Fehlermeldung könnte ein Problem der nicht vorhandene Wert des Windmessers sein :roll:
                • SchubiS Offline
                  SchubiS Offline
                  Schubi
                  #108
                  Also bringt auch nix geht noch immer nicht :-(
                  Mir kommt vor allem diese Meldung komisch vor:
                    rascal
                    #109
                    ich hatte die selbe Meldung, warte ein bisschen, vielleicht verschwindet es bei dir auch von alleine
                    • SchubiS Offline
                      SchubiS Offline
                      Schubi
                      #110
                      :lol: Es läuft :lol:
                      Habe folgendes gemacht:
                      Ein Freund hat ebenfalls eine Netatmo Station - und hatte darauf Zugriff - die Datenpunkte meiner und seiner Station wurden immer angezeigt.
                      Er hat das Teil aber schon länger nicht mehr in Betrieb - un die Werte blieben immer leer (- mich hat das nicht weiters gekümmert)
                      Bei dieser Station gab es auch einen Windmesser
                      :idea: Nun hab ich auf der Netatmo Hompage den Zugang zu seiner Station in meinem Konto glöscht - und siehe da - es geht wieder!
                      Vielleicht wärs jetzt auch ohne dieser Maßnahme gegangen - einen Versuch is es wert.
                      Hoffe die Info kann noch jemand brauchen.
                      LG Schubi
                        bullrin
                        #111
                        Bei mir macht der Netamo Adapter leider nichts. Er legt keine neuen Objekte an. Die Zugsangsdaten sind korrekt.
                        Ich habe in meinem Netatmo Account eine Wetterstation aus der Nachbarschaft als Favorit markiert.
                        Ich hab den Adapter auch schon paar mal neu gestartet, hat nichts gebracht. Installiert ist 1.3.1
                        Das einzige was im Log auftaucht ist:
                        netatmo.0	2019-01-02 01:53:33.800	info	starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.netatmo, node: v8.14.0
                        netatmo.0	2019-01-02 01:53:33.642	info	States connected to redis: 127.0.0.1:6379
                        Rpi 3 + Razberry Modul
                        Philips Hue
                          thommy99
                          #112
                          Ursache für: uncaught exception: Cannot read property 'WindStrength' of undefined
                          Windmesser nicht erreichbar. (Batterien / Empfang)
                          Sobald Windmesser wieder online,
                          läuft auch die Netatmo-Instanz wieder.
                          Vielleicht macht jemand ein Issue auf GIthub.
                          HAbe keinen Github Account.
                          Holger76H 1 Antwort Letzte Antwort
                          • K Offline
                            ktsalti
                            #113
                            Ist es mit dem Adapter auch möglich öffentliche Stationen auszulesen? Ich habe keine Station, aber dafür ist in der Nähe eine.
                            Vielen Dank vorab!
                            Gruß Marcus
                              Stuti
                              #114
                              ich habe das Problem, dass ich über die History aus "rain" einen anderen Wert errechne als der Wert aus den letzten 24h ist.
                              Hier mal ein Beispiel von heute.
                              Log Iobroker history:
                              Export der Netatmo Seite:
                              Hat noch jemand dieses Problem? So kann ich leider keinen schönen Auswertungen in Grafana machen.
                              Es sieht so aus, als wenn es immer genau doppelt geloggt wird.
                              Vielen Dank
                              Ralf
                              NUC i5 mit Proxmox - KVM für ioBroker
                              Rest in Docker. z.B. KNXD, Pi-Hole, MySQL, Grafana, PostgreSQL, Wiki.js, Prometheus, Loki.
                              KNX mit GIRA Homeserver, aber auch Shelly´s und Zigbee
                              • O Offline
                                O Offline
                                OrcaOfTheSeas
                                #115
                                Moin zusammen,
                                ist es möglich den Windmesser und / oder den Regenmesser von Netatmo auch ohne die Wetterstation an IObroker zu betreiben?
                                Ich möchte, wenn möglich, nur den Regenmesser und den Windmesser an IObroker einbinden. Wenn ich das richtig sehe verwaltet die Wetterstation den Regen-und Windmesser, IObroker greift auf das Netatmo-Konto der Wetterstation zu und somit ist diese Vorraussetzung um die beiden Sensoren an IObroker zu betreiben. Sehe ich das richtig?
                                SuFu und Forum habe ich bereits bemüht.
                                Christoph
                                Dr. BakteriusD 1 Antwort Letzte Antwort
                                • O OrcaOfTheSeas
                                  Moin zusammen,
                                  Christoph
                                  Dr. BakteriusD Offline
                                  Dr. Bakterius
                                  #116
                                  @OrcaOfTheSeas sagte in Netatmo?:
                                  Genau, ohne dem Hauptgerät geht das nicht. Das Hauptgerät ist per WLAN mit dem Netatmo-Server verbunden über den ioBroker die Daten bezieht. Die Zusatzmodule kommunizieren über 868 MHz mit der Hauptstation.
                                  • O Offline
                                    O Offline
                                    Olivbus
                                    #117
                                    Gibt es eine Möglichkeit die Daten direkt von der Hauptstation auszulesen oder nur über den Netatmo Server. Ich habe festegestellt, dass die Datenübetragung manchmal über mehr als eine Stunde stockt und gehe davon aus dass dann gelegentlich Porbleme beim Server von Netatmo bestehen. Es wäre schön, wenn man die Daten direkt von der eigenen Station über den Umweg über den Netatmoserver auslesen könnte.
                                    • O Olivbus
                                      Dr. Bakterius
                                      #118
                                      @Olivbus Das würden sich viele wünschen - bzw. einen eigenen Server zu betreiben.
                                      • F Offline
                                        Fox1985
                                        #119
                                        Hallo Miteinander,
                                        ich habe da mal eine Frage, kann ich mit Hilfe des Adapters benachbarte (nicht eigene) Netamo Stationen auslesen?
                                        Vorher hatte ich es mal mit dem WU Adapter gemacht, dort sehe ich aber keine Netatmo Stationen mehr.
                                        Ich habe mich bei Netatmo registriert und auch die benachbarte Station als Favorit gespeichert.
                                        Unter Objekte wird aber leider kein Register angelegt.
                                        Kann mir bitte einer helfen.
                                        Viele Grüße
                                        F 1 Antwort Letzte Antwort
                                        • F Fox1985
                                          Hallo Miteinander,
                                          Viele Grüße
                                          Freakyno1
                                          schrieb am zuletzt editiert von Freakyno1
                                          #120
                                          wird dieser Adapter nicht mehr weiterentwickelt?
                                          Er funktioniert wohl nicht mehr, was sehr schade ist.
                                          Gruß Freakyno1
                                          host.raspberrypi	2020-08-13 17:57:35.086	info	Restart adapter system.adapter.netatmo.0 because enabled
                                          host.raspberrypi	2020-08-13 17:57:35.084	info	instance system.adapter.netatmo.0 terminated with code 0 (NO_ERROR)
                                          netatmo.0	2020-08-13 17:57:34.549	info	(21100) Terminated (NO_ERROR): Without reason
                                          netatmo.0	2020-08-13 17:57:34.546	info	(21100) terminating
                                          netatmo.0	2020-08-13 17:57:34.480	info	(21100) cleaned everything up...
                                          netatmo.0	2020-08-13 17:57:34.474	error	at endReadableNT (_stream_readable.js:1103:12)
                                          netatmo.0	2020-08-13 17:57:34.474	error	at IncomingMessage.emit (events.js:194:15)
                                          netatmo.0	2020-08-13 17:57:34.474	error	at Object.onceWrapper (events.js:277:13)
                                          netatmo.0	2020-08-13 17:57:34.474	error	at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1083:12)
                                          netatmo.0	2020-08-13 17:57:34.474	error	at Request.emit (events.js:189:13)
                                          netatmo.0	2020-08-13 17:57:34.474	error	at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1161:10)
                                          netatmo.0	2020-08-13 17:57:34.474	error	at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
                                          netatmo.0	2020-08-13 17:57:34.474	error	at netatmo.<anonymous> (/opt/iobroker/node_modules/iobroker.netatmo/netatmoLib.js:168:25)
                                          netatmo.0	2020-08-13 17:57:34.474	error	at netatmo.handleRequestError (/opt/iobroker/node_modules/iobroker.netatmo/netatmoLib.js:57:17)
                                          netatmo.0	2020-08-13 17:57:34.474	error	(21100) Error: Authenticate error: invalid_grant
                                          netatmo.0	2020-08-13 17:57:34.468	error	(21100) uncaught exception: Authenticate error: invalid_grant
                                          netatmo.0	2020-08-13 17:57:33.750	info	(21100) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.netatmo, node: v10.15.2, js-controller: 3.1.4
                                          O JohGreJ Hardy_56H 3 Antworten Letzte Antwort
