  4. Netatmo?
    6.6k
Netatmo?
140 Beiträge 52 Kommentatoren 46.9k Aufrufe 12 Beobachtet
  • R Offline
    rascal
    #93
    ich habe über github die version 1.3.1 installiert, selber Fehler :(
    • integer63I Offline
      integer63I Offline
      integer63
      #94
      … mal gaaaaanz vorsichtig - scheint wieder zu gehen :?
      • R Offline
        rascal
        #95
        Hier auch…. weiß der Teufel....
        • R Offline
          rascal
          #96
          Rate mal… selbes Problem wie gestern
          netatmo.0	2018-11-21 16:20:49.445	info	terminating
          netatmo.0	2018-11-21 16:20:49.410	info	cleaned everything up...
          netatmo.0	2018-11-21 16:20:49.409	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
          netatmo.0	2018-11-21 16:20:49.409	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
          netatmo.0	2018-11-21 16:20:49.409	error	at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
          netatmo.0	2018-11-21 16:20:49.409	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
          netatmo.0	2018-11-21 16:20:49.409	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
          netatmo.0	2018-11-21 16:20:49.409	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:51:17)
          netatmo.0	2018-11-21 16:20:49.409	error	at handleModule (/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:63:27)
          netatmo.0	2018-11-21 16:20:49.409	error	at Array.forEach (<anonymous>)
          netatmo.0	2018-11-21 16:20:49.409	error	at /opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:84:21
          netatmo.0	2018-11-21 16:20:49.409	error	at handleWind (/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:656:43)
          netatmo.0	2018-11-21 16:20:49.409	error	TypeError: Cannot read property 'WindStrength' of undefined
          netatmo.0	2018-11-21 16:20:49.409	error	uncaught exception: Cannot read property 'WindStrength' of undefined
          netatmo.0	2018-11-21 16:20:48.572	info	starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.netatmo, node: v8.10.0
          netatmo.0	2018-11-21 16:20:48.430	info	States connected to redis: 0.0.0.0:6379
          host.Mastermind	2018-11-21 16:20:46.409	info	instance system.adapter.netatmo.0 started with pid 16245
          hue.0	2018-11-21 16:20:21.759	info	final lightState for Philips_hue_1.Stehlampe_Wohnzimmer:{"bri":0,"on":false,"level":0}
          host.Mastermind	2018-11-21 16:20:16.392	info	Restart adapter system.adapter.netatmo.0 because enabled
          host.Mastermind	2018-11-21 16:20:16.391	error	instance system.adapter.netatmo.0 terminated with code 0 (OK)
          Caught	2018-11-21 16:20:16.391	error	by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
          Caught	2018-11-21 16:20:16.391	error	by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
          Caught	2018-11-21 16:20:16.391	error	by controller[0]: at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
          Caught	2018-11-21 16:20:16.391	error	by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
          Caught	2018-11-21 16:20:16.391	error	by controller[0]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
          Caught	2018-11-21 16:20:16.391	error	by controller[0]: at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:51:17)
          Caught	2018-11-21 16:20:16.391	error	by controller[0]: at handleModule (/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:63:27)
          Caught	2018-11-21 16:20:16.391	error	by controller[0]: at Array.forEach (<anonymous>)
          Caught	2018-11-21 16:20:16.391	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:84:21
          Caught	2018-11-21 16:20:16.391	error	by controller[0]: at handleWind (/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:656:43)
          Caught	2018-11-21 16:20:16.391	error	by controller[0]: TypeError: Cannot read property 'WindStrength' of undefined
          netatmo.0	2018-11-21 16:20:16.340	info	cleaned everything up...</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous>
            integer63I Offline
            integer63
            #97
            Jup, ich auch :-(
            Kann ja eigentlich nur am Netatmo Service/Server selbst liegen, oder?
            • R Offline
              rascal
              #98
              Möglich, ich kann mich aber bei Netatmo in meinen Account einloggen und es sieht soweit alles normal aus
                integer63I Offline
                integer63
                #99
                Ja, bei mir auch, aber ich glaube für die ioBroker Abfragen wird eine anderer Service (API) angesprochen.
                  integer63I Offline
                  integer63
                  #100
                  Momentan wieder keine Fehlermeldungen mehr und Instanz wieder "grün" … echt nervig
                  • R Offline
                    rascal
                    #101
                    hier das gleiche, auch gut im Moment
                    • N Offline
                      N Offline
                      Nanouk
                      #102
                      Moin,
                      hier auch das Problem.
                      Ging gestern mal kurzzeitig, aber seit gestern Abend wieder rot.
                      Gruß Nanouk
                      • SchubiS Offline
                        SchubiS Offline
                        Schubi
                        #103
                        Gibts schon Neuigkeiten - hab seit kurzem auch den Fehler!
                        netatmo.0	2018-12-03 19:49:00.565	info	terminating
                        netatmo.0	2018-12-03 19:49:00.528	info	cleaned everything up...
                        netatmo.0	2018-12-03 19:49:00.526	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
                        netatmo.0	2018-12-03 19:49:00.526	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
                        netatmo.0	2018-12-03 19:49:00.526	error	at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-bind/index.js:21:15)
                        netatmo.0	2018-12-03 19:49:00.526	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
                        netatmo.0	2018-12-03 19:49:00.526	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
                        netatmo.0	2018-12-03 19:49:00.526	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:51:17)
                        netatmo.0	2018-12-03 19:49:00.526	error	at handleModule (/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:63:27)
                        netatmo.0	2018-12-03 19:49:00.526	error	at Array.forEach (native)
                        netatmo.0	2018-12-03 19:49:00.526	error	at /opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:84:21
                        netatmo.0	2018-12-03 19:49:00.526	error	at handleWind (/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:656:42)
                        netatmo.0	2018-12-03 19:49:00.526	error	TypeError: Cannot read property 'WindStrength' of undefined
                        netatmo.0	2018-12-03 19:49:00.524	error	uncaught exception: Cannot read property 'WindStrength' of undefined
                        netatmo.0	2018-12-03 19:48:59.157	info	starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.netatmo, node: v6.13.1</anonymous></anonymous>
                        / Synology DS716+ / Logitech Harmony Ultimate / Netatmo / ESP8266 / RPi 3 / 4* Möller Easy 820 / Lupusec XT2 Plus /
                        • R Offline
                          rascal
                          #104
                          bei mir scheint der Fehler nicht mehr aufzutreten
                          • SchubiS Offline
                            SchubiS Offline
                            Schubi
                            #105
                            Was hast du geändert?
                            Hast du einen Windsensor? (Ich hab keinen)
                            • R Offline
                              rascal
                              #106
                              ich habe die Version von Github direkt installiert, jetzt läuft Version 1.3.1
                              Ich habe einen Windsensor, Regensensor und Außentemp Sensor.
                              • SchubiS Offline
                                SchubiS Offline
                                Schubi
                                #107
                                Ich Probier auch mal direkt von GitHub.
                                Hab aber jetzt auch schon die 1.3.1
                                Nach der Fehlermeldung könnte ein Problem der nicht vorhandene Wert des Windmessers sein :roll:
                                • SchubiS Offline
                                  SchubiS Offline
                                  Schubi
                                  #108
                                  Also bringt auch nix geht noch immer nicht :-(
                                  Mir kommt vor allem diese Meldung komisch vor:
                                  • R Offline
                                    rascal
                                    #109
                                    ich hatte die selbe Meldung, warte ein bisschen, vielleicht verschwindet es bei dir auch von alleine
                                    • SchubiS Offline
                                      SchubiS Offline
                                      Schubi
                                      #110
                                      :lol: Es läuft :lol:
                                      Habe folgendes gemacht:
                                      Ein Freund hat ebenfalls eine Netatmo Station - und hatte darauf Zugriff - die Datenpunkte meiner und seiner Station wurden immer angezeigt.
                                      Er hat das Teil aber schon länger nicht mehr in Betrieb - un die Werte blieben immer leer (- mich hat das nicht weiters gekümmert)
                                      Bei dieser Station gab es auch einen Windmesser
                                      :idea: Nun hab ich auf der Netatmo Hompage den Zugang zu seiner Station in meinem Konto glöscht - und siehe da - es geht wieder!
                                      Vielleicht wärs jetzt auch ohne dieser Maßnahme gegangen - einen Versuch is es wert.
                                      Hoffe die Info kann noch jemand brauchen.
                                      LG Schubi
                                        bullrin
                                        #111
                                        Bei mir macht der Netamo Adapter leider nichts. Er legt keine neuen Objekte an. Die Zugsangsdaten sind korrekt.
                                        Ich habe in meinem Netatmo Account eine Wetterstation aus der Nachbarschaft als Favorit markiert.
                                        Ich hab den Adapter auch schon paar mal neu gestartet, hat nichts gebracht. Installiert ist 1.3.1
                                        Das einzige was im Log auftaucht ist:
                                        netatmo.0	2019-01-02 01:53:33.800	info	starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.netatmo, node: v8.14.0
                                        netatmo.0	2019-01-02 01:53:33.642	info	States connected to redis: 127.0.0.1:6379
                                        Rpi 3 + Razberry Modul
                                        Philips Hue
                                          thommy99
                                          #112
                                          Ursache für: uncaught exception: Cannot read property 'WindStrength' of undefined
                                          Windmesser nicht erreichbar. (Batterien / Empfang)
                                          Sobald Windmesser wieder online,
                                          läuft auch die Netatmo-Instanz wieder.
                                          Vielleicht macht jemand ein Issue auf GIthub.
                                          HAbe keinen Github Account.
                                          Holger76H 1 Antwort Letzte Antwort
