  4. Netatmo?
    6.6k
Netatmo?
140 Beiträge 52 Kommentatoren 46.9k Aufrufe 12 Beobachtet
  • R Offline
    rascal
    #91
    ich habe seit neuestem ein Problem mit dem Adapter, er hat bis jetzt monatelang problemlos funktioniert.
    hier die Fehlermeldung im iobroker Log:
    host.Mastermind	2018-11-20 16:05:05.054	info	Restart adapter system.adapter.netatmo.0 because enabled
    host.Mastermind	2018-11-20 16:05:05.054	error	instance system.adapter.netatmo.0 terminated with code 0 (OK)
    host.Mastermind	2018-11-20 16:05:05.054	error	Caught by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
    host.Mastermind	2018-11-20 16:05:05.054	error	Caught by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
    host.Mastermind	2018-11-20 16:05:05.054	error	Caught by controller[0]: at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
    host.Mastermind	2018-11-20 16:05:05.054	error	Caught by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
    host.Mastermind	2018-11-20 16:05:05.054	error	Caught by controller[0]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
    host.Mastermind	2018-11-20 16:05:05.053	error	Caught by controller[0]: at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:51:17)
    host.Mastermind	2018-11-20 16:05:05.053	error	Caught by controller[0]: at handleModule (/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:63:27)
    host.Mastermind	2018-11-20 16:05:05.053	error	Caught by controller[0]: at Array.forEach (<anonymous>)
    host.Mastermind	2018-11-20 16:05:05.053	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:84:21
    host.Mastermind	2018-11-20 16:05:05.053	error	Caught by controller[0]: at handleWind (/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:656:43)
    host.Mastermind	2018-11-20 16:05:05.053	error	Caught by controller[0]: TypeError: Cannot read property 'WindStrength' of undefined
    netatmo.0	2018-11-20 16:05:04.090	info	starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.netatmo, node: v8.10.0
    host.Mastermind	2018-11-20 16:05:01.976	info	instance system.adapter.netatmo.0 started with pid 14763
    host.Mastermind	2018-11-20 16:04:31.958	info	Restart adapter system.adapter.netatmo.0 because enabled</anonymous></anonymous></anonymous>
    ist das schon bekannt?
    • integer63I Offline
      integer63I Offline
      integer63
      #92
      Hab ich seit 15:30 auch :-(
      <code>2018-11-20 15:30:48.167  - [31merror[39m: netatmo.0 uncaught exception: Cannot read property 'WindStrength' of undefined
      2018-11-20 15:30:48.167  - [31merror[39m: netatmo.0 TypeError: Cannot read property 'WindStrength' of undefined
          at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
      2018-11-20 15:30:48.168  - [32minfo[39m: netatmo.0 cleaned everything up...
      2018-11-20 15:30:48.173  - [32minfo[39m: netatmo.0 terminating[/code]</anonymous></anonymous></anonymous></code>
      • R Offline
        rascal
        #93
        ich habe über github die version 1.3.1 installiert, selber Fehler :(
          integer63I Offline
          integer63
          #94
          … mal gaaaaanz vorsichtig - scheint wieder zu gehen :?
          • R Offline
            rascal
            #95
            Hier auch…. weiß der Teufel....
            • R Offline
              rascal
              #96
              Rate mal… selbes Problem wie gestern
              netatmo.0	2018-11-21 16:20:49.445	info	terminating
              netatmo.0	2018-11-21 16:20:49.410	info	cleaned everything up...
              netatmo.0	2018-11-21 16:20:49.409	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
              netatmo.0	2018-11-21 16:20:49.409	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
              netatmo.0	2018-11-21 16:20:49.409	error	at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
              netatmo.0	2018-11-21 16:20:49.409	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
              netatmo.0	2018-11-21 16:20:49.409	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
              netatmo.0	2018-11-21 16:20:49.409	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:51:17)
              netatmo.0	2018-11-21 16:20:49.409	error	at handleModule (/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:63:27)
              netatmo.0	2018-11-21 16:20:49.409	error	at Array.forEach (<anonymous>)
              netatmo.0	2018-11-21 16:20:49.409	error	at /opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:84:21
              netatmo.0	2018-11-21 16:20:49.409	error	at handleWind (/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:656:43)
              netatmo.0	2018-11-21 16:20:49.409	error	TypeError: Cannot read property 'WindStrength' of undefined
              netatmo.0	2018-11-21 16:20:49.409	error	uncaught exception: Cannot read property 'WindStrength' of undefined
              netatmo.0	2018-11-21 16:20:48.572	info	starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.netatmo, node: v8.10.0
              netatmo.0	2018-11-21 16:20:48.430	info	States connected to redis: 0.0.0.0:6379
              host.Mastermind	2018-11-21 16:20:46.409	info	instance system.adapter.netatmo.0 started with pid 16245
              hue.0	2018-11-21 16:20:21.759	info	final lightState for Philips_hue_1.Stehlampe_Wohnzimmer:{"bri":0,"on":false,"level":0}
              host.Mastermind	2018-11-21 16:20:16.392	info	Restart adapter system.adapter.netatmo.0 because enabled
              host.Mastermind	2018-11-21 16:20:16.391	error	instance system.adapter.netatmo.0 terminated with code 0 (OK)
              Caught	2018-11-21 16:20:16.391	error	by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
              Caught	2018-11-21 16:20:16.391	error	by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
              Caught	2018-11-21 16:20:16.391	error	by controller[0]: at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
              Caught	2018-11-21 16:20:16.391	error	by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
              Caught	2018-11-21 16:20:16.391	error	by controller[0]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
              Caught	2018-11-21 16:20:16.391	error	by controller[0]: at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:51:17)
              Caught	2018-11-21 16:20:16.391	error	by controller[0]: at handleModule (/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:63:27)
              Caught	2018-11-21 16:20:16.391	error	by controller[0]: at Array.forEach (<anonymous>)
              Caught	2018-11-21 16:20:16.391	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:84:21
              Caught	2018-11-21 16:20:16.391	error	by controller[0]: at handleWind (/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:656:43)
              Caught	2018-11-21 16:20:16.391	error	by controller[0]: TypeError: Cannot read property 'WindStrength' of undefined
              netatmo.0	2018-11-21 16:20:16.340	info	cleaned everything up...</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous>
                integer63I Offline
                integer63
                #97
                Jup, ich auch :-(
                Kann ja eigentlich nur am Netatmo Service/Server selbst liegen, oder?
                • R Offline
                  rascal
                  #98
                  Möglich, ich kann mich aber bei Netatmo in meinen Account einloggen und es sieht soweit alles normal aus
                    integer63I Offline
                    integer63
                    #99
                    Ja, bei mir auch, aber ich glaube für die ioBroker Abfragen wird eine anderer Service (API) angesprochen.
                      integer63I Offline
                      integer63
                      #100
                      Momentan wieder keine Fehlermeldungen mehr und Instanz wieder "grün" … echt nervig
                      • R Offline
                        rascal
                        #101
                        hier das gleiche, auch gut im Moment
                        • N Offline
                          N Offline
                          Nanouk
                          #102
                          Moin,
                          hier auch das Problem.
                          Ging gestern mal kurzzeitig, aber seit gestern Abend wieder rot.
                          Gruß Nanouk
                          • SchubiS Offline
                            SchubiS Offline
                            Schubi
                            #103
                            Gibts schon Neuigkeiten - hab seit kurzem auch den Fehler!
                            netatmo.0	2018-12-03 19:49:00.565	info	terminating
                            netatmo.0	2018-12-03 19:49:00.528	info	cleaned everything up...
                            netatmo.0	2018-12-03 19:49:00.526	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
                            netatmo.0	2018-12-03 19:49:00.526	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
                            netatmo.0	2018-12-03 19:49:00.526	error	at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-bind/index.js:21:15)
                            netatmo.0	2018-12-03 19:49:00.526	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
                            netatmo.0	2018-12-03 19:49:00.526	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
                            netatmo.0	2018-12-03 19:49:00.526	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:51:17)
                            netatmo.0	2018-12-03 19:49:00.526	error	at handleModule (/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:63:27)
                            netatmo.0	2018-12-03 19:49:00.526	error	at Array.forEach (native)
                            netatmo.0	2018-12-03 19:49:00.526	error	at /opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:84:21
                            netatmo.0	2018-12-03 19:49:00.526	error	at handleWind (/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:656:42)
                            netatmo.0	2018-12-03 19:49:00.526	error	TypeError: Cannot read property 'WindStrength' of undefined
                            netatmo.0	2018-12-03 19:49:00.524	error	uncaught exception: Cannot read property 'WindStrength' of undefined
                            netatmo.0	2018-12-03 19:48:59.157	info	starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.netatmo, node: v6.13.1</anonymous></anonymous>
                            / Synology DS716+ / Logitech Harmony Ultimate / Netatmo / ESP8266 / RPi 3 / 4* Möller Easy 820 / Lupusec XT2 Plus /
                            • R Offline
                              rascal
                              #104
                              bei mir scheint der Fehler nicht mehr aufzutreten
                              • SchubiS Offline
                                SchubiS Offline
                                Schubi
                                #105
                                Was hast du geändert?
                                Hast du einen Windsensor? (Ich hab keinen)
                                • R Offline
                                  rascal
                                  #106
                                  ich habe die Version von Github direkt installiert, jetzt läuft Version 1.3.1
                                  Ich habe einen Windsensor, Regensensor und Außentemp Sensor.
                                  • SchubiS Offline
                                    SchubiS Offline
                                    Schubi
                                    #107
                                    Ich Probier auch mal direkt von GitHub.
                                    Hab aber jetzt auch schon die 1.3.1
                                    Nach der Fehlermeldung könnte ein Problem der nicht vorhandene Wert des Windmessers sein :roll:
                                    • SchubiS Offline
                                      SchubiS Offline
                                      Schubi
                                      #108
                                      Also bringt auch nix geht noch immer nicht :-(
                                      Mir kommt vor allem diese Meldung komisch vor:
                                      • R Offline
                                        rascal
                                        #109
                                        ich hatte die selbe Meldung, warte ein bisschen, vielleicht verschwindet es bei dir auch von alleine
                                        • SchubiS Offline
                                          SchubiS Offline
                                          Schubi
                                          #110
                                          :lol: Es läuft :lol:
                                          Habe folgendes gemacht:
                                          Ein Freund hat ebenfalls eine Netatmo Station - und hatte darauf Zugriff - die Datenpunkte meiner und seiner Station wurden immer angezeigt.
                                          Er hat das Teil aber schon länger nicht mehr in Betrieb - un die Werte blieben immer leer (- mich hat das nicht weiters gekümmert)
                                          Bei dieser Station gab es auch einen Windmesser
                                          :idea: Nun hab ich auf der Netatmo Hompage den Zugang zu seiner Station in meinem Konto glöscht - und siehe da - es geht wieder!
                                          Vielleicht wärs jetzt auch ohne dieser Maßnahme gegangen - einen Versuch is es wert.
                                          Hoffe die Info kann noch jemand brauchen.
                                          LG Schubi
