  4. Netatmo?
    6.6k
Netatmo?
140 Beiträge 52 Kommentatoren 46.9k Aufrufe 12 Beobachtet
  • F Freakyno1
    wird dieser Adapter nicht mehr weiterentwickelt?
    Er funktioniert wohl nicht mehr, was sehr schade ist.
    Gruß Freakyno1
    host.raspberrypi	2020-08-13 17:57:35.086	info	Restart adapter system.adapter.netatmo.0 because enabled
    host.raspberrypi	2020-08-13 17:57:35.084	info	instance system.adapter.netatmo.0 terminated with code 0 (NO_ERROR)
    netatmo.0	2020-08-13 17:57:34.549	info	(21100) Terminated (NO_ERROR): Without reason
    netatmo.0	2020-08-13 17:57:34.546	info	(21100) terminating
    netatmo.0	2020-08-13 17:57:34.480	info	(21100) cleaned everything up...
    netatmo.0	2020-08-13 17:57:34.474	error	at endReadableNT (_stream_readable.js:1103:12)
    netatmo.0	2020-08-13 17:57:34.474	error	at IncomingMessage.emit (events.js:194:15)
    netatmo.0	2020-08-13 17:57:34.474	error	at Object.onceWrapper (events.js:277:13)
    netatmo.0	2020-08-13 17:57:34.474	error	at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1083:12)
    netatmo.0	2020-08-13 17:57:34.474	error	at Request.emit (events.js:189:13)
    netatmo.0	2020-08-13 17:57:34.474	error	at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1161:10)
    netatmo.0	2020-08-13 17:57:34.474	error	at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
    netatmo.0	2020-08-13 17:57:34.474	error	at netatmo.<anonymous> (/opt/iobroker/node_modules/iobroker.netatmo/netatmoLib.js:168:25)
    netatmo.0	2020-08-13 17:57:34.474	error	at netatmo.handleRequestError (/opt/iobroker/node_modules/iobroker.netatmo/netatmoLib.js:57:17)
    netatmo.0	2020-08-13 17:57:34.474	error	(21100) Error: Authenticate error: invalid_grant
    netatmo.0	2020-08-13 17:57:34.468	error	(21100) uncaught exception: Authenticate error: invalid_grant
    netatmo.0	2020-08-13 17:57:33.750	info	(21100) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.netatmo, node: v10.15.2, js-controller: 3.1.4
    O Offline
    O Offline
    Olivbus
    #121
    @Freakyno1 Bei mir funktioniert der Adapter einwandfrei.
    • F Freakyno1
      Gruß Freakyno1
      JohGreJ Offline
      JohGreJ Offline
      JohGre
      #122
      @Freakyno1
      das ist ein Problem bei der Anmeldung, deine Anmeldedaten passen?
      nuc i5: RaspberryMatic, ioBroker, pi-hole, SQL-Server, OMV-NAS, Influx-DB & Grafana, OpenHab, tasmoadmin
      • F Freakyno1
        Gruß Freakyno1
        Hardy_56H Offline
        Hardy_56H Offline
        Hardy_56
        #123
        @Freakyno1 Bei mir funktioniert der Adapter auch einwadfrei
        F 1 Antwort Letzte Antwort
        • Hardy_56H Hardy_56
          Freakyno1
          #124
          @Hardy_56
          Seltsam. Ich habe die Anmededaten mehrfach überprüft und den Adapter auch schon mehrfach neuinstalliert.
          In der App auf Android funktionieren die Anmededaten einwandfrei.
          Verstehe ich nicht. Ich starte nochmal alles von vorne.
          MfG Frekyno1
          • F Freakyno1
            @Hardy_56
            MfG Frekyno1
            Freakyno1
            #125
            Update:
            Ich habe den Adapter nun nochmals installiert und nun funktioniert er, aber erst, nachdem ich das Passwort geändert habe.
            Seltsam, aber egal. Hauptsache es funktioniert wieder.
            Danke für die Hilfe.
            Grüße Freakyno1
            • T thommy99
              Ursache für: uncaught exception: Cannot read property 'WindStrength' of undefined
              Windmesser nicht erreichbar. (Batterien / Empfang)
              Sobald Windmesser wieder online,
              läuft auch die Netatmo-Instanz wieder.
              Vielleicht macht jemand ein Issue auf GIthub.
              HAbe keinen Github Account.
              Holger76H Offline
              Holger76H Offline
              Holger76
              #126
              @thommy99 sagte in Netatmo?:
              das Problem hatte ich eben auch. Bin nun endlich dazu gekommen, meine Wetterstation incl Regen und Windmesser (bei Primeday geschossen) anzuschließen. Das war schon eine hürde, da es mit dem Handy absolut nicht klappen wollte. Dann halt über Laptop und Software, was ich von der Website geladen habe. Soweit so gut, der iobroker Adapter wollte dann erst nicht laufen. Später habe ich dann festgestellt, dass der Windmesser noch keine Daten geliefert hatte. Als es dann soweit war, lief auch der Adapter. Bin mal gespannt, ob die Daten nun wirklich brauchbar sind, für Jalousie usw.
              NUC12i7 -> Proxmox VM [ioBroker.Pro]+[InfluxDB/Grafana]+[AdGuard]+[ OpenCCU ]+[Conbee3] +[Graylog]+[Octopi]+[OpenClaw]
              NUC6CAYH (16GB) [Proxmox Backup Server]+[OMV]
              • Holger76H Holger76
                TomBo1969
                #127
                Moin zusammen,
                ich habe gestern die erste von meinen Netatmo Presence Kameras in Betrieb genommen und in den iobroker-Adapter eingebunden (Wetterstation hatte ich schon).
                Es funzt soweit, die Kamera wird erkannt, ich bekomme auch die URL zum Livebild/-stream geliefert, allerdings bleiben sämtliche Objekte unter "LastEventData" leer, obwohl im Log zu sehen ist, wenn ein Event ausgelöst wird.
                Ich möchte natürlich mit den Events Scripte triggern und stehe etwas auf dem Schlauch...
                Funktioniert bei Euch der Adapter (noch), gibt es Workarounds, was könnte ich probieren? Neustarts habe ich probiert, irgendwo habe ich gelesen, dass man nicht parallel in der Netatmo App angemeldet sein soll, hat aber nichts gebracht und wie gesagt, im Log wird das Event angezeigt, nur die Objekte fehlen mir.
                Wir der Adapter überhaupt noch gewartet? Im Github sind etliche Isssues teilweise seit Monaten unbeantwortet..
                Danke für Eure Untertützung!
                Beste Grüße, Tom
                O 1 Antwort Letzte Antwort
                • T TomBo1969
                  Moin zusammen,
                  Beste Grüße, Tom
                  O Abwesend
                  O Abwesend
                  oFbEQnpoLKKl6mbY5e13
                  #128
                  @tombo1969 sagte in Netatmo?:
                  Das trifft wohl auf fast alle Zefau-Adapter zu. Bei diesem Adapter sollte man außerdem die Daten nicht zu häufug neu laden lassen, da bei jeder State-Änderung auch alle Objekte neu geschrieben werden.
                  • O oFbEQnpoLKKl6mbY5e13
                    TomBo1969
                    #129
                    @ofbeqnpolkkl6mby5e13 said in Netatmo?:
                    Ich dachte, der Adapter wäre von @PArt ??
                    Meine Einstellungen: Daten erneut laden = 5 Minuten, Objekte bereinigen = 60 Minuten
                    • T TomBo1969
                      O Abwesend
                      O Abwesend
                      #130
                      @tombo1969
                      Ist richtig, habe ich mich vertan.
                        @tombo1969
                        TomBo1969
                        #131
                        Geht bei allen anderen der Adapter? Liefert er die aktuellen Datenpunkte zu den Events?
                        Wenn ja, wo könnte ich ansetzen?
                        Danke für jede Unterstützung!
                        • PackElendP Offline
                          PackElendP Offline
                          PackElend
                          #132
                          Guten Abend zusammen,
                          Unterstützt dies auch die https://shop.netatmo.com/en-gb/energy/accessories/valves
                          Ich überlege mit diese zu kaufen, um die fussbodenheizung zu automatisieren.
                          Bei HA heißt es, es geht nicht ohne Thermostat https://community.home-assistant.io/t/newbie-question-on-netatmo-smart-radiator-valve-integration/283723/3
                          H 1 Antwort Letzte Antwort
                          • PackElendP PackElend
                            helfi9999
                            #133
                            @packelend sagte in Netatmo?:
                            schau dir mal das von @Newpicsel an Blockly Heizung
                            Vielleicht hilft es dir.
                            Habe meine Heizung darüber am steuern.
                            Intel NUC mit Iobroker
                            PackElendP 1 Antwort Letzte Antwort
                            • H helfi9999
                              PackElendP Offline
                              PackElendP Offline
                              PackElend
                              #134
                              @helfi9999 danke für die fixe Antwort.
                              Da du Netatmo auch für dein Heizung zu verwenden scheinst, darf ich dir ein paar Fragen dazustellen?
                              Ich finde die Antworten sicher auch sonst wo im Forum aber ist für mich Netatmo, habe es vor kurzem bei einem Besuch gesehen und sehe gerade, dass Netatmo ne Black Week am laufen hat: https://shop.netatmo.com/
                              Ich würde mich riesig freuen, wenn du mir folgendes, zumindest zum Teil, beantworten könntest:
                              1. wenn ich mehrere Heizkreise habe, muss ich für jeden ein Thermostat von Netatmo kaufen, Fremdgeräte kann ich nicht einbinden?
                              2. Läuft das System lokal oder geht es über die Cloud von Netatmo
                              3. Kann ich später die Ventile über iobrocker direkt ansprechen oder werden die Netatmo Infos nur ausgelesen?
                              4. ist das Überhaupt das richtige System für eine Fussbodenheizung. Netatmo geht auf Fussbodenheizung in https://pro.netatmo.com/eu/thermostat/compatibility ein aber beworben werden immer nur Radiatoren
                              Ein Teil der Fragen ist wohl schon durch https://www.netatmo.com/en-gb/energy/additional-valve beantwortet:
                              Can i use a different brand of thermostat together with the netatmo Smart Radiator Valves?
                              No, because a different brand of thermostat will interfere with the scheduling of the Additional Smart Radiator Valves.
                              How many additional Smart Radiator Valves can i add to the thermostat or to the pack for district heating?
                              If you already have a Thermostat, simply check in the settings of the Netatmo Energy app to see how many Additional Smart Radiator Valves you can add. If you are fitting a new Netatmo Thermostat or a pack for district heating, you can add up to 20 Smart Radiator Valves in maximum 10 different rooms.
                              Vielleicht ist eine Homematic IP Fußbodenheizungsaktor HmIP-FAL24-C10 – 10fach, 24 V | ELV Elektronik | Smart Home Systeme | ELV Elektronik das bessere System für meinen Fall:
                              H NewpicselN 2 Antworten Letzte Antwort
                                helfi9999
                                #135
                                habe damals mir die Netatmo Starterpaket geholt,
                                das Thermostat ist mit meiner Therme verbunden das Relais steht irgendwo rum da ich mir auch die Heizkörperthermostate geholt habe die ich an die Heizungen installiert habe.
                                zu Punkt 1 und 4: schau mal hier Netatmo
                                zu Punkt 2: läuft über Netatmo da du Internet brauchst.
                                zu Punkt 3: Ich kann jeden Heizkörperthermostat einzeln über Iobroker ansprechen. Es gibt eine Netatmo Energy Adapter in Iobroker oder das Script von @Newpicsel was ich gestern schon gepostet habe, was auch für mich persönlich besser ist da man mehr erreichen kann.
                                Hoffe ich konnte dir ein wenig helfen.
                                P.S. Ich würde wahrscheinlich jetzt wenn ich nicht schon soviel in Netatmo an Geld reingesteckt hätte auf Tado wechseln.
                                Da die Thermostate wenn ich das richtig in Erinnerung habe auch Feuchtigkeit messen was die Netatmo nicht machen.
                                Gruss helfi
                                • H helfi9999
                                  Gruss helfi
                                  PackElendP Offline
                                  PackElendP Offline
                                  PackElend
                                  #136
                                  @helfi9999 Netatmo Erklärung zur fussboden Heizung zielt auf einen einzelnen Boiler ab.
                                  Es sollte auch unterschiedliche Heizzonen unterstützt aber muss ich in jeder Heizone eine Temperaturmessung von Netatmo unterbringen.
                                  Das könnte dann anständig ins Geld gehen
                                  Nur noch mal zu Ablauf, iobroker spricht die Logik von dem Thermostat an, dieses wiederum die Ventile.
                                  Die Ventile werden nicht direkt von iobroker angesprochen.
                                  Iobroker übermittelt auch keinen gemessene Temperatur an das Thermostat, dieses arbeitet nur mit Netatmo Geräten.
                                  Korrekt?
                                  Ich schreibe mit diesen Infos mal an Mail an Netatmo.
                                  Schaue ich mir auch noch gerne Tado an
                                    Korrekt?
                                    helfi9999
                                    #137
                                    Korrekt?
                                    So sehe ich das auch
                                      NewpicselN Offline
                                      NewpicselN Offline
                                      Newpicsel
                                      #138
                                      Moin @packelend
                                      Verstehe ich das richtig, dass du die Ventile für die Fußbodenheizung irgendwo zentral zusammenliegen hast und sich diese nicht in dem Raum befinden, der auch geheizt werden soll?
                                      Dies ist in jeder Hinsicht äußerst ungünstig 😅
                                      Sind diese Ventile Thermostate oder tasächlich nur Ventile?
                                      Sind es nur Ventile, könntest du die Heizleistung über den Boiler regeln, ein anpassen der Zonen ist dann aber nur über die Ventile möglich…
                                      Bei Thermostaten (digital oder mechanisch), haben das Problem, dass sie eben die Temperatur direkt im Umfeld des Thermostates berücksichtigen, wie es bei anderen smarten Herstellern ist, weiß ich nicht, aber bei Netatmo kannst du keine separate Quelle der "ist" Temperatur angeben…
                                      Einzige Möglichkeit die ich hier sehe, ist die Steuerung (auch den Heizplan) komplett in iobroker zu bauen, was kein Hexenwerk ist, aber etwas Grundwissen und ein stabiles System mit etwas Leistungspuffer vorraussetzt.
                                      (Die Temperatur der Räume muss relativ häufig abgefragt und darauf reagiert werden)
                                      Gerne helfe ich dabei, solltest du dich für diesen Weg entscheiden…
                                      Netatmo selbst läuft ausschließlich über deren Cloud leider 🤷‍♂️
                                      • NewpicselN Newpicsel
                                        Moin @packelend
                                        PackElendP Offline
                                        PackElendP Offline
                                        PackElend
                                        schrieb am zuletzt editiert von PackElend
                                        #139
                                        @newpicsel said in Netatmo?:
                                        yep, von hier geht es in die jeweiligen Räume/Heizzonen
                                        Mit Netatmo oder Tado komme ich nicht weiter, da bräuchte es pro Zimmer ein Thermostat, welches dann mit dem Ventil redet, ist ein gebastelt schlussendlich, ohne Erfolgsgaratie.
                                        ich mach mal ein neues Thema auf wir driften hier sonst ab :)
                                        https://forum.iobroker.net/topic/60291/zentrale-manuell-gesteuerte-fussbodenheizung-automatisieren
                                          O Abwesend
                                          O Abwesend
                                          schrieb am zuletzt editiert von oFbEQnpoLKKl6mbY5e13
                                          #140
                                          Hat sich erledigt.
