  5. Bewegungsmelder blockly
    5.2k
blockly
117 Beiträge 15 Kommentatoren 35.8k Aufrufe 4 Beobachtet
  • K Offline
    knopers1
    Danke Dutchman,
    die Lampen gehen mit Ein, gehen aber nicht aus! Hast Du eine Idee weshalb?
     <xml xmlns="http://www.w3.org/1999/xhtml"><block type="on_ext" id="zBkZB8ijuy}8jed3+y8+" x="-437" y="-37"><mutation items="1"></mutation>
        <value name="OID0"><shadow type="field_oid" id="tO[d(C?x:r{3EYzS8*|I"><field name="oid">rflink.0.channels.Eurodomest_2.SWITCH_05</field></shadow></value>
        <statement name="STATEMENT"><block type="controls_if" id="=~*uGJ2^k@}2pGW8ioG("><mutation else="1"></mutation>
            <value name="IF0"><block type="logic_compare" id="MzmVRpO}C95Ik1~D1n~b"><field name="OP">LT</field>
                <value name="A"><block type="get_value" id="7;7#~]XTS%8e^(x8/wZS"><field name="ATTR">val</field>
                    <field name="OID">hm-rpc.0.LEQ0240879.1.BRIGHTNESS</field></block></value>
                <value name="B"><block type="math_number" id="IoLBjb4QA|i|p{e_|Cy%"><field name="NUM">200</field></block></value></block></value>
            <statement name="DO0"><block type="timeouts_cleartimeout" id="YihiGR+F6WhCE^yaUqWi"><field name="NAME">timeout</field>
                <next><block type="control" id="rfS#FPojQg-yU0e:;dIy"><mutation delay_input="false"></mutation>
                    <field name="OID">sonoff.0.Sonoff-Dimmer1.POWER</field>
                    <value name="VALUE"><block type="logic_boolean" id="REEAcX?9l/:{F0_qO+K3"><field name="BOOL">TRUE</field></block></value></block></next></block></statement>
            <statement name="ELSE"><block type="timeouts_cleartimeout" id="f!LTX-V:9_qvP!MI_d}s"><field name="NAME">timeout</field>
                <next><block type="timeouts_settimeout" id="6w^hCzjF@b}a==Va@.PR"><field name="NAME">timeout</field>
                    <field name="DELAY">1</field>
                    <field name="UNIT">min</field>
                    <statement name="STATEMENT"><block type="control" id="l[g1cNgy^|XxH?ny2o;U"><mutation delay_input="false"></mutation>
                        <value name="VALUE"><block type="logic_boolean" id="Xc:4/vVhw%cS*ghQY^:w"><field name="BOOL">FALSE</field></block></value></block></statement></block></next></block></statement></block></statement></block></xml>
    • DutchmanD Offline
      DutchmanD Offline
      Dutchman
      Poste mal Screenshot bitte der Export liest sich schwer auf tapatalk
      Send from mobile device
      Das schöne ios hat Auto Korrektur zum k****
      Wer Schreibfehler findet darf sie behalten oder auf eBay verkaufen, mindest Umsatz 10% für die community
      • K Offline
        knopers1
        ok.
        • DutchmanD Offline
          DutchmanD Offline
          Dutchman
          Baue Mal debug Blöcke ein vor der falls Abfrage, nach der ersten und nach der zweiten Mal schauen was im Log passiert
          • rantanplanR Online
            rantanplanR Online
            rantanplan
            Hängt der BM im Bereich der Lampe?
            Wenn ja und die eingeschaltet ist, wird wahrscheinlich BRIGHTNESS nicht <200
            Rantanplan
            • K Offline
              knopers1
              hmm,
              Brightnes ist momentan 196! Lampe ist zum Test woanders, und das Einschalten der Lampe beeinflust nicht Brightnes.
              Wenn der BM auslösst, kommt im Log:
              javascript.0 2018-05-01 11:33:21.504 info script.js.common.testBM: 2
              javascript.0 2018-05-01 11:33:21.503 info script.js.common.testBM: 1
              Das Licht geht ein, schaltet sich aber nicht aus! Ist das Blockly überhaupt korrekt zum AUS Schalten? Was ist da der Trigger? Der Timer von einer min. ???
                  <statement name="STATEMENT"><block type="debug" id="UYWy~9fb1C8F=++V?G)_"><field name="Severity">log</field>
                      <value name="TEXT"><shadow type="text" id="XNYH^r(Ru~24vhOLTwAq"><field name="TEXT">1</field></shadow></value>
                      <next><block type="controls_if" id="=~*uGJ2^k@}2pGW8ioG("><mutation else="1"></mutation>
                          <statement name="DO0"><block type="debug" id="CivfHpdM~@.)pF0Ba`bF"><field name="Severity">log</field>
                              <value name="TEXT"><shadow type="text" id="{glbtY/i:uXZJt@bztbh"><field name="TEXT">2</field></shadow></value>
                              <next><block type="timeouts_cleartimeout" id="YihiGR+F6WhCE^yaUqWi"><field name="NAME">timeout</field>
                                      <next><block type="control" id=")3M*.KOZTKdD/[)xwP]M"><mutation delay_input="false"></mutation>
                                          <field name="OID">sonoff.0.Sonoff-Dimmer1.Dimmer</field>
                                          <value name="VALUE"><block type="math_number" id="rE#D*=,;*B6g3|stV)=}"><field name="NUM">100</field></block></value></block></next></block></next></block></next></block></statement>
                          <statement name="ELSE"><block type="debug" id="(l;K]W*tQemk3hv%!Bi]"><field name="Severity">log</field>
                              <value name="TEXT"><shadow type="text" id=";*~GDy=l-Ea:u+eSj}dP"><field name="TEXT">3</field></shadow></value>
                              <next><block type="timeouts_cleartimeout" id="f!LTX-V:9_qvP!MI_d}s"><field name="NAME">timeout</field>
                                          <value name="VALUE"><block type="logic_boolean" id="Xc:4/vVhw%cS*ghQY^:w"><field name="BOOL">FALSE</field></block></value></block></statement></block></next></block></next></block></statement></block></next></block></statement></block></xml>
              • DutchmanD Offline
                DutchmanD Offline
                Dutchman
                Oh man ich Depp der bwm von dir Triggert ja nicht zum auschalten….
                Lass den ersten Block so wie er ist, nimm den sonst Weck und hänge das auschalten einfach unter den falls Block...
                Dan geht die Lampe nur an wen brigthness < xxx und startet der off time Out.
                Bei der nästen Bewegung resetet sich der time-out
                • K Offline
                  knopers1
                  Geil, es geht! Danke vielmals! Jetzt sind die BM erst etwas Wert. Das Licht geht jetzt erst aus, wenn die Person die Küche oder das Treppenhaus verlassen hat!
                          <value name="TEXT"><shadow type="text" id="XNYH^r(Ru~24vhOLTwAq"><field name="TEXT">Bewegung Küche erkannt.</field></shadow></value>
                          <next><block type="controls_if" id="=~*uGJ2^k@}2pGW8ioG("><value name="IF0"><block type="logic_compare" id="MzmVRpO}C95Ik1~D1n~b"><field name="OP">LT</field>
                                  <value name="TEXT"><shadow type="text" id="{glbtY/i:uXZJt@bztbh"><field name="TEXT">Lampe Einschalten</field></shadow></value>
                                              <next><block type="debug" id="(l;K]W*tQemk3hv%!Bi]"><field name="Severity">log</field>
                                                          <field name="DELAY">20</field>
                                                              <value name="VALUE"><block type="logic_boolean" id="Xc:4/vVhw%cS*ghQY^:w"><field name="BOOL">FALSE</field></block></value></block></statement></block></next></block></next></block></next></block></next></block></next></block></next></block></statement></block></next></block></statement></block></xml>
                  • DutchmanD Offline
                    DutchmanD Offline
                    Dutchman
                    Na super, der zweite Stop timeout und time Out zum auschalten sollte aber unter den gesamten falls Block hängen.
                    Jetzt bleibt die Lampe nicht an wenn Bewegung erkannt und Lichtstärke >200! :)
                    • K Offline
                      knopers1
                      Danke für deine Hilfe!
                      Ist es so i.O?
                                                              <value name="VALUE"><block type="logic_boolean" id="Xc:4/vVhw%cS*ghQY^:w"><field name="BOOL">FALSE</field></block></value></block></statement></block></next></block></next></block></next></block></next></block></next></block></statement>
                                  <next><block type="timeouts_cleartimeout" id="f!LTX-V:9_qvP!MI_d}s"><field name="NAME">timeout</field></block></next></block></next></block></statement></block></xml>
                      • DutchmanD Offline
                        DutchmanD Offline
                        Dutchman
                        Fast, der Stop timeout ist richtig aber das ausführen muss da drunter !
                        • K Offline
                          knopers1
                          Du meinst es sicherlich so oder?
                          • DutchmanD Offline
                            DutchmanD Offline
                            Dutchman
                            @knopers1:
                            Du meinst es sicherlich so oder? `
                            wie mein vadder immer sagte : Grüüüüüünnnnaaauuuuuu :mrgreen:
                            damit wird dieser letzte Baustein jetzt ausserhalb deiner IF immer getigert und resettet den timer wie es sein soll.
                            Nachteil jetzt, dieses schalte Lampe aus commando wird immer gesendet, also auch wen die Lampe nicht an ist und Bewegung erkannt wird.
                            Das könnte man noch mit ner IF-Abfragen
                            ~Dutch
                            • K Offline
                              knopers1
                              ja :mrgreen: , habe noch die IF Abfrage der Lampe dazu gebastelt. Danke Dir, jetzt zumindest geht mir das Licht nicht aus/an, wenn ich in der Küche
                              am Werkeln bin. Dies ging mir schon so ziemlich auf den Sack!
                              G 1 Antwort Letzte Antwort
                              • L Offline
                                ltsalvatore
                                hey leute,
                                ich würde auch gerne einen bewegungsmelder für das einschalten der leds in der küche benutzen;
                                welche hardware habt ihr bei euch in nutzung?
                                • F Offline
                                  Flauschi
                                  Xiaomi Bewegungsmelder und/oder HM-Sen-MDIR-WM55
                                  • K Offline
                                    knopers1
                                    HM-Sen-MDIR-WM55 und ein BM KERUI aus China über den RFLink-Adapter angebunden.
                                    • L Offline
                                      ltsalvatore
                                      @Flauschi:
                                      Xiaomi Bewegungsmelder und/oder HM-Sen-MDIR-WM55 `
                                      meinst du den hier: Xiaomi Aqara Human Body Sensor
                                      wenn ja, brauch ich dafür noch zusätzliche hardware, um den sensor über den iobroker zu steuern?
                                      der von Homematic ist auch interssant, aber kostet wieder das dreifache..
                                      • F Offline
                                        Flauschi
                                        @ltsalvatore:
                                        wenn ja, brauch ich dafür noch zusätzliche hardware, um den sensor über den iobroker zu steuern? `
                                        jop der isses…man braucht dazu noch ein Gateway (welches man mit ioBroker koppelt) und dann die Sensoren als reine Objekte hat
                                        • L Offline
                                          ltsalvatore
                                          @Flauschi:
                                          @ltsalvatore:
                                          jop der isses…man braucht dazu noch ein Gateway (welches man mit ioBroker koppelt) und dann die Sensoren als reine Objekte hat `
                                          OK danke.
                                          gibt es davon eigentlich auch Sensoren für Fenster?
                                          für den Winter müsste ich noch Fenster Sensoren kaufen, und die von Homematic für meine CCU sind ein Tick zu teuer, finde ich.
                                          deshalb wäre es natürlich optimal, wenn ich von dem gleichen Hersteller beide Geräte erwerben könnte.
                                          würde nämlich schon versuchen wollen so wenig unterschiedliche Hersteller wie möglich zu betreiben.
