  4. Blockly - Pushover & Attachment
    5.7k
45 Beiträge 9 Kommentatoren 8.7k Aufrufe 3 Beobachtet
  • DutchmanD Offline
    DutchmanD Offline
    Dutchman
    Logisch, du bist nicht im ioBroker Verzeichnis!
    Also erst````
    cd /opt/iobroker
    • K Offline
      Kuddel
      root@ioBroker-TEST:~# cd /opt/iobroker/
      root@ioBroker-TEST:/opt/iobroker# npm install pushover-notifications
      > bufferutil@1.1.0 install /opt/iobroker/node_modules/bufferutil
      > node-gyp rebuild
      make: Verzeichnis „/opt/iobroker/node_modules/bufferutil/build“ wird betreten
        CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
      In file included from ../node_modules/nan/nan.h:82:0,
                       from ../src/bufferutil.cc:16:
      ../node_modules/nan/nan_new.h: In function ‘v8::Local NanIntern::To(v8::Handle<v8::integer>) [with T = v8::Int32; v8::Handle <v8::integer>= v8::Local<v8::integer>]’:
      ../node_modules/nan/nan_new.h:34:64: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       To<v8::int32>(v8::Handle <v8::integer>i)   { return i->ToInt32(); }
      In file included from ../src/bufferutil.cc:7:0:
      /root/.node-gyp/8.11.3/include/node/v8.h:9796:14: note: declared here
       Local <int32>Value::ToInt32() const {
      ../node_modules/nan/nan_new.h: In function ‘v8::Local NanIntern::To(v8::Handle<v8::integer>) [with T = v8::Uint32; v8::Handle <v8::integer>= v8::Local<v8::integer>]’:
      ../node_modules/nan/nan_new.h:39:65: warning: ‘v8::Local <v8::uint32>v8::Value::ToUint32() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       To<v8::uint32>(v8::Handle <v8::integer>i)  { return i->ToUint32(); }
      /root/.node-gyp/8.11.3/include/node/v8.h:9790:15: note: declared here
       Local <uint32>Value::ToUint32() const {
      In file included from ../node_modules/nan/nan_new.h:189:0,
                       from ../node_modules/nan/nan.h:82,
      ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::booleanobject>::return_t NanIntern::Factory<v8::booleanobject>::New(bool)’:
      ../node_modules/nan/nan_implementation_12_inl.h:49:38: warning: ‘static v8::Local <v8::value>v8::BooleanObject::New(bool)’ is deprecated: Pass an isolate [-Wdeprecated-declarations]
         return v8::BooleanObject::New(value).As<v8::booleanobject>();
      In file included from /root/.node-gyp/8.11.3/include/node/v8.h:26:0,
      /root/.node-gyp/8.11.3/include/node/v8.h:4845:56: note: declared here
         V8_DEPRECATED("Pass an isolate", static Local <value>New(bool value));
      /root/.node-gyp/8.11.3/include/node/v8config.h:318:3: note: in definition of macro ‘V8_DEPRECATED’
         declarator __attribute__((deprecated(message)))
      ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::script>::return_t NanIntern::Factory<v8::script>::New(v8::Local<v8::string>)’:
      ../node_modules/nan/nan_implementation_12_inl.h:166:69: warning: ‘static v8::Local <v8::script>v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);
      /root/.node-gyp/8.11.3/include/node/v8.h:1425:21: note: declared here
             Local</v8::script></v8::string></v8::script></v8::script></value></v8::booleanobject></v8::value></v8::booleanobject></v8::booleanobject></uint32></v8::integer></v8::uint32></v8::uint32></v8::integer></v8::integer></v8::integer></int32></v8::integer></v8::int32></v8::int32></v8::integer></v8::integer></v8::integer>
      • DutchmanD Offline
        DutchmanD Offline
        Dutchman
        Geht doch Installation gelungen welche Version steht jetzt bei deinen Adaptern ?
          Rambo79
          Hab den selben Fehler gemacht. War auch nicht ioB Verzeichnis
          • K Offline
            Kuddel
            • DutchmanD Offline
              DutchmanD Offline
              Dutchman
              Sieht soweit OK aus
              • K Offline
                Kuddel
                Leider nichts bzgl. Anhang zu erkennen
                • DutchmanD Offline
                  DutchmanD Offline
                  Dutchman
                  System Neustart könnte auch Mal helfen nach Al dem gefummel und Browser + Cache refresh
                  • K Offline
                    Kuddel
                    @Dutchman:
                    Sent from my iPhone using Tapatalk `
                    ioBroker und Browser neu gestartet, leider keine Verbesserung
                    • DutchmanD Offline
                      DutchmanD Offline
                      Dutchman
                      Mit Shift F5 Browser refresh UND cahe gelöscht ?
                      • K Offline
                        Kuddel
                        @Dutchman:
                        Hat auch keinen Erfolg gebracht.
                        Was mich auf jeden Fall wundert, ist die Version, die angezeigt.
                        Per Console uwrde ja Version 1.2.0 installiert.
                        In der Adapter-Übersicht steht aber immer noch Version 1.1.0
                        • DutchmanD Offline
                          DutchmanD Offline
                          Dutchman
                          Hmm dann ist doch die ältere Version installiert.
                          Also nochmal per github installieren und dann den Upload Befehl und nicht aus npm (da ist die neuere Version noch nicht bekannt)
                          • FredFF Online
                            FredFF Online
                            FredF
                            Most Active Forum Testing
                            @Kev0:
                            Issues würden geschlossen und gemerged, sollte jetzt gehen:
                            https://github.com/qbit/node-pushover/b … /README.md
                            Wer ist so nett und adaptiert die blockly Variante? :oops:
                            Grüße
                            Kevin ` Diese Repo hat doch nichts mit iobroker zu tun…
                            Gesendet von meinem HUAWEI VNS-L31 mit Tapatalk
                              dtp
                              @FredF:
                              Diese Repo hat doch nichts mit iobroker zu tun… `
                              Genau. Der Pushover-Adapter 1.1.0 des ioBroker ist etwas anderes, als die npm-Version 1.2.0 der pushover-notifications. Ich befürchte, dass auch die Version 1.1.0 des Pushover-Adapters leider noch nicht mit Attachments umgehen kann.
                              Würde mich aber auch sehr freuen, wenn das bald mal ginge, damit ich meine mit dem phantomjs-Adapter erstellten Screenshots per Pushover verschicken kann.
                              • DutchmanD Offline
                                DutchmanD Offline
                                Dutchman
                                Ist dazu bereits ein issue erstellt für den ioBroker pushover Adapter?
                                • K Offline
                                  Kev0
                                  Ja, darum habe ich ja gefragt ob jemand das dort implementieren kann.
                                  https://github.com/ioBroker/ioBroker.pushover/issues/5
                                  Ist mir schon klar gewesen das die zuvor genannte Repo nicht für iobroker war…
                                  • DutchmanD Offline
                                    DutchmanD Offline
                                    Dutchman
                                    Dachte mir bereits dass wir hier von 2 verschiedenen Sachen reden.
                                    Vor 1nem Monat wurde die dependency gelöst im pushover npm Paket, ich habe das in git verlinkt nöste Frage ist wann der Entwickler Zeit hat sich die an zu nehmen ;)
                                      dtp
                                      Hängt die Änderung in Blockly direkt mit der Änderung des Pushover-Adapters zusammen? Evtl. könnte man das ja getrennt voneinander machen. Im Pushover-Adapter müsste man ja theoretisch nur das aktuelle npm-Repository von pushover-notifications einbinden, oder? Dann könnten zumindest schon mal die mit Attachments arbeiten, die den Pushover-Adapter direkt per Javaskript aufrufen.
                                      Oder geht das sogar schon direkt durch Aufruf von
                                      Gruß,
                                      Thorsten
                                      • DutchmanD Offline
                                        DutchmanD Offline
                                        Dutchman
                                        Hängt miteinander zusammen
                                          dtp
                                          Also ohne Blockly funktioniert es auf jeden Fall schon mal mit der Version 1.2.0 von pushover-notifications.
                                          Hier die Ausgabe auf dem iPhone:
                                          Und hier die Ausgabe auf der Watch:
                                          Hier das zugehörige Javaskript:
                                          sendTo("pushover", {
                                            message: 'Dies ist eine Test-Nachricht', // mandatory - your text message
                                            title: 'ioBroker', // optional - your message's title, otherwise your app's name is used
                                            sound: 'magic', // optional - the name of one of the sounds supported by device clients to override the user's default sound choice
                                                            // pushover, bike, bugle, cashregister, classical, cosmic, falling,
                                                            // gamelan, incoming, intermission, magic, mechanical, pianobar, siren,
                                                            // spacealarm, tugboat, alien, climb, persistent, echo, updown, none
                                            priority: 0, // optional (-2, -1, 0, 1, 2)
                                                            // -2 to always send as a quiet notification,
                                                            // 1 to display as high-priority and bypass the user's quiet hours, or
                                                            // 2 to also require confirmation from the user
                                            file: '/opt/iobroker/phantomjs_images/Gasverbrauch.png', // optional - attachment
                                            //token: 'API/KEY token', // optional - add other than configurated token to the call
                                            //url: , // optional - a supplementary URL to show with your message
                                            //url_title: , // optional - a title for your supplementary URL, otherwise just the URL is shown
                                            //device: , // optional - your user's device name to send the message directly to that device, rather than all of the user's devices
                                            //timestamp // optional - a Unix timestamp of your message's date and time to display to the user, rather than the time your message is received by our API
                                          Der Pfad für die angehängte PNG-Datei ist natürlich an meine Docker-Installation angepasst.
