  4. Blockly - Pushover & Attachment
    5.7k
45 Beiträge 9 Kommentatoren 8.7k Aufrufe 3 Beobachtet
    Kuddel
    root@ioBroker-TEST:~# cd /opt/iobroker/
    root@ioBroker-TEST:/opt/iobroker# npm install pushover-notifications
    > bufferutil@1.1.0 install /opt/iobroker/node_modules/bufferutil
    > node-gyp rebuild
    make: Verzeichnis „/opt/iobroker/node_modules/bufferutil/build“ wird betreten
      CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
    In file included from ../node_modules/nan/nan.h:82:0,
                     from ../src/bufferutil.cc:16:
    ../node_modules/nan/nan_new.h: In function ‘v8::Local NanIntern::To(v8::Handle<v8::integer>) [with T = v8::Int32; v8::Handle <v8::integer>= v8::Local<v8::integer>]’:
    ../node_modules/nan/nan_new.h:34:64: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
     To<v8::int32>(v8::Handle <v8::integer>i)   { return i->ToInt32(); }
    In file included from ../src/bufferutil.cc:7:0:
    /root/.node-gyp/8.11.3/include/node/v8.h:9796:14: note: declared here
     Local <int32>Value::ToInt32() const {
    ../node_modules/nan/nan_new.h: In function ‘v8::Local NanIntern::To(v8::Handle<v8::integer>) [with T = v8::Uint32; v8::Handle <v8::integer>= v8::Local<v8::integer>]’:
    ../node_modules/nan/nan_new.h:39:65: warning: ‘v8::Local <v8::uint32>v8::Value::ToUint32() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
     To<v8::uint32>(v8::Handle <v8::integer>i)  { return i->ToUint32(); }
    /root/.node-gyp/8.11.3/include/node/v8.h:9790:15: note: declared here
     Local <uint32>Value::ToUint32() const {
    In file included from ../node_modules/nan/nan_new.h:189:0,
                     from ../node_modules/nan/nan.h:82,
    ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::booleanobject>::return_t NanIntern::Factory<v8::booleanobject>::New(bool)’:
    ../node_modules/nan/nan_implementation_12_inl.h:49:38: warning: ‘static v8::Local <v8::value>v8::BooleanObject::New(bool)’ is deprecated: Pass an isolate [-Wdeprecated-declarations]
       return v8::BooleanObject::New(value).As<v8::booleanobject>();
    In file included from /root/.node-gyp/8.11.3/include/node/v8.h:26:0,
    /root/.node-gyp/8.11.3/include/node/v8.h:4845:56: note: declared here
       V8_DEPRECATED("Pass an isolate", static Local <value>New(bool value));
    /root/.node-gyp/8.11.3/include/node/v8config.h:318:3: note: in definition of macro ‘V8_DEPRECATED’
       declarator __attribute__((deprecated(message)))
    ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::script>::return_t NanIntern::Factory<v8::script>::New(v8::Local<v8::string>)’:
    ../node_modules/nan/nan_implementation_12_inl.h:166:69: warning: ‘static v8::Local <v8::script>v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);
    /root/.node-gyp/8.11.3/include/node/v8.h:1425:21: note: declared here
           Local</v8::script></v8::string></v8::script></v8::script></value></v8::booleanobject></v8::value></v8::booleanobject></v8::booleanobject></uint32></v8::integer></v8::uint32></v8::uint32></v8::integer></v8::integer></v8::integer></int32></v8::integer></v8::int32></v8::int32></v8::integer></v8::integer></v8::integer>
    • DutchmanD Offline
      DutchmanD Offline
      Dutchman
      Geht doch Installation gelungen welche Version steht jetzt bei deinen Adaptern ?
      • R Offline
        Rambo79
        Hab den selben Fehler gemacht. War auch nicht ioB Verzeichnis
          Kuddel
          • DutchmanD Offline
            DutchmanD Offline
            Dutchman
            Sieht soweit OK aus
              Kuddel
              Leider nichts bzgl. Anhang zu erkennen
              • DutchmanD Offline
                DutchmanD Offline
                Dutchman
                System Neustart könnte auch Mal helfen nach Al dem gefummel und Browser + Cache refresh
                  Kuddel
                  @Dutchman:
                  Sent from my iPhone using Tapatalk `
                  ioBroker und Browser neu gestartet, leider keine Verbesserung
                  • DutchmanD Offline
                    DutchmanD Offline
                    Dutchman
                    Mit Shift F5 Browser refresh UND cahe gelöscht ?
                      Kuddel
                      @Dutchman:
                      Hat auch keinen Erfolg gebracht.
                      Was mich auf jeden Fall wundert, ist die Version, die angezeigt.
                      Per Console uwrde ja Version 1.2.0 installiert.
                      In der Adapter-Übersicht steht aber immer noch Version 1.1.0
                      • DutchmanD Offline
                        DutchmanD Offline
                        Dutchman
                        Hmm dann ist doch die ältere Version installiert.
                        Also nochmal per github installieren und dann den Upload Befehl und nicht aus npm (da ist die neuere Version noch nicht bekannt)
                        • FredFF Online
                          FredFF Online
                          FredF
                          Most Active Forum Testing
                          @Kev0:
                          Issues würden geschlossen und gemerged, sollte jetzt gehen:
                          https://github.com/qbit/node-pushover/b … /README.md
                          Wer ist so nett und adaptiert die blockly Variante? :oops:
                          Kevin ` Diese Repo hat doch nichts mit iobroker zu tun…
                          Gesendet von meinem HUAWEI VNS-L31 mit Tapatalk
                            dtp
                            @FredF:
                            Diese Repo hat doch nichts mit iobroker zu tun… `
                            Genau. Der Pushover-Adapter 1.1.0 des ioBroker ist etwas anderes, als die npm-Version 1.2.0 der pushover-notifications. Ich befürchte, dass auch die Version 1.1.0 des Pushover-Adapters leider noch nicht mit Attachments umgehen kann.
                            Würde mich aber auch sehr freuen, wenn das bald mal ginge, damit ich meine mit dem phantomjs-Adapter erstellten Screenshots per Pushover verschicken kann.
                            • DutchmanD Offline
                              DutchmanD Offline
                              Dutchman
                              Ist dazu bereits ein issue erstellt für den ioBroker pushover Adapter?
                                Kev0
                                Ja, darum habe ich ja gefragt ob jemand das dort implementieren kann.
                                https://github.com/ioBroker/ioBroker.pushover/issues/5
                                Ist mir schon klar gewesen das die zuvor genannte Repo nicht für iobroker war…
                                • DutchmanD Offline
                                  DutchmanD Offline
                                  Dutchman
                                  Dachte mir bereits dass wir hier von 2 verschiedenen Sachen reden.
                                  Vor 1nem Monat wurde die dependency gelöst im pushover npm Paket, ich habe das in git verlinkt nöste Frage ist wann der Entwickler Zeit hat sich die an zu nehmen ;)
                                    dtp
                                    Hängt die Änderung in Blockly direkt mit der Änderung des Pushover-Adapters zusammen? Evtl. könnte man das ja getrennt voneinander machen. Im Pushover-Adapter müsste man ja theoretisch nur das aktuelle npm-Repository von pushover-notifications einbinden, oder? Dann könnten zumindest schon mal die mit Attachments arbeiten, die den Pushover-Adapter direkt per Javaskript aufrufen.
                                    Oder geht das sogar schon direkt durch Aufruf von
                                    Gruß,
                                    Thorsten
                                    • DutchmanD Offline
                                      DutchmanD Offline
                                      Dutchman
                                      Hängt miteinander zusammen
                                        dtp
                                        Also ohne Blockly funktioniert es auf jeden Fall schon mal mit der Version 1.2.0 von pushover-notifications.
                                        Hier die Ausgabe auf dem iPhone:
                                        Und hier die Ausgabe auf der Watch:
                                        Hier das zugehörige Javaskript:
                                        sendTo("pushover", {
                                          message: 'Dies ist eine Test-Nachricht', // mandatory - your text message
                                          title: 'ioBroker', // optional - your message's title, otherwise your app's name is used
                                          sound: 'magic', // optional - the name of one of the sounds supported by device clients to override the user's default sound choice
                                                          // pushover, bike, bugle, cashregister, classical, cosmic, falling,
                                                          // gamelan, incoming, intermission, magic, mechanical, pianobar, siren,
                                                          // spacealarm, tugboat, alien, climb, persistent, echo, updown, none
                                          priority: 0, // optional (-2, -1, 0, 1, 2)
                                                          // -2 to always send as a quiet notification,
                                                          // 1 to display as high-priority and bypass the user's quiet hours, or
                                                          // 2 to also require confirmation from the user
                                          file: '/opt/iobroker/phantomjs_images/Gasverbrauch.png', // optional - attachment
                                          //token: 'API/KEY token', // optional - add other than configurated token to the call
                                          //url: , // optional - a supplementary URL to show with your message
                                          //url_title: , // optional - a title for your supplementary URL, otherwise just the URL is shown
                                          //device: , // optional - your user's device name to send the message directly to that device, rather than all of the user's devices
                                          //timestamp // optional - a Unix timestamp of your message's date and time to display to the user, rather than the time your message is received by our API
                                        Der Pfad für die angehängte PNG-Datei ist natürlich an meine Docker-Installation angepasst.
                                        • DutchmanD Offline
                                          DutchmanD Offline
                                          Dutchman
                                          Update das bitte Mal im gut issue Holz den Entwickler auch :)
